[PATCH V2 1/2] RTEMS GPIO API definition and implementation.
André Marques andre.lousa.marques at gmail.com
Thu Aug 13 13:43:00 UTC 2015
Hello Ketul,
On 13-08-2015 13:04, Ketul Shah wrote:
> Hi Andre,
> Great API and happy to know that it is merged with main line.
> Eventually I implemented GPIO driver for BBB using this API. After
> debugging for rtems_gpio_get_value() on BBB I found the following bug.
> For BBB, GPIO pin nos. varies from 0 to 32. So function return type
> would be uint32_t instead of uint8_t.
> For BBB I wrote :-
> uint32_t rtems_gpio_bsp_get_value(uint32_t bank, uint32_t pin)
>   return (mmio_read(bbb_reg(bank, AM335X_GPIO_DATAIN)) & BIT(pin));
the rtems_gpio_bsp_get_value returns the value of a GPIO pin, which can
only be either 0 or 1. This is not platform dependent. Any value greater
than zero should map to 1.
I do notice that I forgot this detail in the Pi implementation too, so
it is also returning a 32 bit value.
The reasoning for the 8-bit return is that the return will always be
binary. 0 or non-zero, but by mapping a non-zero value to 1 may make
more sense than outputing a 32-bit bitmask, which was the initial approach.
> Thanks.
> Best Regards,
> Ketul
--André Marques.
[snip]
