[PATCH 1/6] add mailbox support for rpi bsp
Thu Aug 13 20:45:32 UTC 2015
Hmmm... Gedare had a little better luck than I did but
it still didn't work.
He sees a non-ASCII character in #5.
Not sure what's up.
On 8/13/2015 3:31 PM, QIAO YANG wrote:
> I rebased on the latest commit on master:
> commit 61e7c698a44137afbc1447ed328b14a0d9e55016
> Author: Andre Marques <andre.lousa.marques at gmail.com>
> Date:   Mon Jul 27 17:01:44 2015 +0100
>          Raspberry Pi implementation for the RTEMS GPIO API.
> I've just cloned it and the patches are all applied. Maybe I misunderstand which commit to rebase on?
> On Aug 13, 2015, at 09:16 AM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> This still doesn't apply for me.
>> Did you pull the latest changes and rebase?
>> --joel
>> On 8/12/2015 5:08 PM, YANG QIAO wrote:
>>> From: YANG Qiao <yangqiao0505 at me.com>
>>> c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 4 ++
>>> c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h | 32 +++++++++++++
>>> .../libbsp/arm/raspberrypi/include/raspberrypi.h | 49 +++++++++++++++++++
>>> c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c | 56 ++++++++++++++++++++++
>>> c/src/lib/libbsp/arm/raspberrypi/preinstall.am | 4 ++
>>> 5 files changed, 145 insertions(+)
>>> create mode 100644 c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
>>> create mode 100644 c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>> index 03be711..e1398bb 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
>>> @@ -45,6 +45,7 @@ include_bsp_HEADERS += include/mmu.h
>>> include_bsp_HEADERS += include/usart.h
>>> include_bsp_HEADERS += include/raspberrypi.h
>>> include_bsp_HEADERS += include/rpi-gpio.h
>>> +include_bsp_HEADERS += include/mailbox.h
>>> include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
>>> ../../../libcpu/arm/shared/include/arm-cp15.h
>>> @@ -128,6 +129,9 @@ libbsp_a_SOURCES += gpio/rpi-gpio.c
>>> # I2C
>>> +# Mailbox
>>> +libbsp_a_SOURCES += misc/mailbox.c
>>> # Cache
>>> libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
>>> libbsp_a_SOURCES += ../../../libcpu/arm/shared/include/cache_.h
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h b/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
>>> new file mode 100644
>>> index 0000000..e6cb0f8
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/include/mailbox.h
>>> @@ -0,0 +1,32 @@
>>> + * @file
>>> + * @ingroup raspberrypi
>>> + * @brief mailbox support.
>>> + * Copyright (c) 2015 Yang Qiao
>>> + * The license and distribution terms for this file may be
>>> + * found in the file LICENSE in this distribution or at
>>> + * http://www.rtems.org/license/LICENSE
>>> +#ifndef LIBBSP_ARM_RASPBERRYPI_MAILBOX_H
>>> +#define LIBBSP_ARM_RASPBERRYPI_MAILBOX_H
>>> +#ifdef __cplusplus
>>> +extern "C" {
>>> +#endif /* __cplusplus */
>>> +extern unsigned int raspberrypi_mailbox_read(unsigned int channel);
>>> +extern void raspberrypi_mailbox_write(unsigned int channel, unsigned int data);
>>> +#ifdef __cplusplus
>>> +#endif /* LIBBSP_ARM_RASPBERRYPI_MAILBOX_H */
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
>>> index ddcd4ff..ef7a061 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/include/raspberrypi.h
>>> @@ -7,6 +7,7 @@
>>> * Copyright (c) 2014 Andre Marques <andre.lousa.marques at gmail.com <http://gmail.com>>
>>> * Copyright (c) 2013 Alan Cudmore.
>>> @@ -272,6 +273,54 @@
>>> +* @name Mailbox Registers
>>> +#define BCM2835_MBOX_BASE (RPI_PERIPHERAL_BASE+0xB880)
>>> +#define BCM2835_MBOX_PEEK (BCM2835_MBOX_BASE+0x10)
>>> +#define BCM2835_MBOX_READ (BCM2835_MBOX_BASE+0x00)
>>> +#define BCM2835_MBOX_WRITE (BCM2835_MBOX_BASE+0x20)
>>> +#define BCM2835_MBOX_STATUS (BCM2835_MBOX_BASE+0x18)
>>> +#define BCM2835_MBOX_SENDER (BCM2835_MBOX_BASE+0x14)
>>> +#define BCM2835_MBOX_CONFIG (BCM2835_MBOX_BASE+0x1C)
>>> +#define BCM2835_MBOX_FULL (BCM2835_MBOX_BASE+0x80000000)
>>> +#define BCM2835_MBOX_EMPTY (BCM2835_MBOX_BASE+0x40000000)
>>> +* @name Mailbox Channels
>>> +/* Power Manager channel */
>>> +#define BCM2835_MBOX_CHANNEL_PM 0
>>> +/* Framebuffer channel */
>>> +#define BCM2835_MBOX_CHANNEL_FB 1
>>> + /* Virtual UART channel */
>>> +#define BCM2835_MBOX_CHANNEL_VUART 2
>>> + /* VCHIQ channel */
>>> +#define BCM2835_MBOX_CHANNEL_VCHIQ 3
>>> + /* LEDs channel */
>>> +#define BCM2835_MBOX_CHANNEL_LED 4
>>> + /* Button channel */
>>> +#define BCM2835_MBOX_CHANNEL_BUTTON 5
>>> + /* Touch screen channel */
>>> +#define BCM2835_MBOX_CHANNEL_TOUCHS 6
>>> +/* Property tags (ARM <-> VC) channel */
>>> +#define BCM2835_MBOX_CHANNEL_PROP_AVC 8
>>> + /* Property tags (VC <-> ARM) channel */
>>> +#define BCM2835_MBOX_CHANNEL_PROP_VCA 9
>>> #endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c b/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
>>> index 0000000..8ec730a
>>> --- /dev/null
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/misc/mailbox.c
>>> @@ -0,0 +1,56 @@
>>> + * @file
>>> +#include <stdint.h>
>>> +#include <stdbool.h>
>>> +#include <bsp/raspberrypi.h>
>>> +#include <bsp/mailbox.h>
>>> +#define BCM2835_MBOX_DATA_MASK(data) (data & 0xFFFFFFF0U)
>>> +#define BCM2835_MBOX_CHANNEL_MASK(data) (data & 0xFU)
>>> +static inline bool bcm2835_mailbox_is_empty()
>>> + return (BCM2835_REG(BCM2835_MBOX_STATUS) & BCM2835_MBOX_EMPTY);
>>> +static inline bool bcm2835_mailbox_is_full()
>>> + return (BCM2835_REG(BCM2835_MBOX_STATUS) & BCM2835_MBOX_FULL);
>>> +unsigned int raspberrypi_mailbox_read(unsigned int channel)
>>> + unsigned int raw;
>>> + unsigned int read_channel;
>>> + while (1){
>>> + while (bcm2835_mailbox_is_empty());
>>> + raw = BCM2835_REG (BCM2835_MBOX_READ );
>>> + read_channel = BCM2835_MBOX_CHANNEL_MASK(raw) ;
>>> + if (read_channel == channel)
>>> + return BCM2835_MBOX_DATA_MASK(raw);
>>> +void raspberrypi_mailbox_write(unsigned int channel, unsigned int data)
>>> + while (bcm2835_mailbox_is_full());
>>> + BCM2835_REG(BCM2835_MBOX_WRITE) =
>>> + BCM2835_MBOX_DATA_MASK(data) |
>>> + BCM2835_MBOX_CHANNEL_MASK(channel);
>>> diff --git a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>>> index 122bc00..346e557 100644
>>> --- a/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>>> +++ b/c/src/lib/libbsp/arm/raspberrypi/preinstall.am
>>> @@ -134,6 +134,10 @@ $(PROJECT_INCLUDE)/bsp/rpi-gpio.h: include/rpi-gpio.h $(PROJECT_INCLUDE)/bsp/$(d
>>>  $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/rpi-gpio.h
>>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/rpi-gpio.h
>>> +$(PROJECT_INCLUDE)/bsp/mailbox.h: include/mailbox.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>> +  $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mailbox.h
>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mailbox.h
>>> $(PROJECT_INCLUDE)/libcpu/cache_.h: ../../../libcpu/arm/shared/include/cache_.h $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>  $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/cache_.h
>>> PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/cache_.h
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
