[PATCH 2/4] Code refactor Beagle BSP MMU initialization
Rohini Kulkarni krohini1593 at gmail.com
Thu Aug 13 21:44:22 UTC 2015
 c/src/lib/libbsp/arm/beagle/Makefile.am           |    4 ++++
 c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c |   25 ++++++++++-----------
 2 files changed, 16 insertions(+), 13 deletions(-)
diff --git a/c/src/lib/libbsp/arm/beagle/Makefile.am b/c/src/lib/libbsp/arm/beagle/Makefile.am
index abef8ba..7d96c7d 100644
--- a/c/src/lib/libbsp/arm/beagle/Makefile.am
+++ b/c/src/lib/libbsp/arm/beagle/Makefile.am
@@ -28,6 +28,7 @@ nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
 include_bsp_HEADERS += ../../shared/include/utility.h
+include_bsp_HEADERS += ../../../libbsp/shared/include/mm.h
 include_bsp_HEADERS += ../../shared/include/irq-generic.h
 include_bsp_HEADERS += ../../shared/include/irq-info.h
 include_bsp_HEADERS += ../../shared/include/stackalloc.h
@@ -94,6 +95,9 @@ libbsp_a_SOURCES += startup/bspstart.c
 libbsp_a_SOURCES += startup/bspstarthooks.c
 libbsp_a_SOURCES += startup/bspstartmmu.c
+# LIBMM
+libbsp_a_SOURCES += ../shared/mminit.c
 # IRQ
 libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
 libbsp_a_SOURCES += ../../shared/src/irq-generic.c
diff --git a/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c b/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
index 157edfa..c66151b 100644
--- a/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
+++ b/c/src/lib/libbsp/arm/beagle/startup/bspstartmmu.c
@@ -15,6 +15,7 @@
 #include <bsp.h>
+#include <bsp/mm.h>
 #include <bsp/start.h>
 #include <bsp/arm-cp15-start.h>
@@ -25,8 +26,8 @@
 //static uint32_t pagetable[ARM_SECTIONS] __attribute__((aligned (1024*16)));
-BSP_START_DATA_SECTION static const arm_cp15_start_section_config
-beagle_mmu_config_table[] = {
+BSP_START_DATA_SECTION const arm_cp15_start_section_config
+arm_cp15_start_mmu_config_table[] = {
   ARMV7_CP15_START_DEFAULT_SECTIONS,
     .begin = 0x40000000U,
@@ -43,16 +44,14 @@ BSP_START_TEXT_SECTION void beagle_setup_mmu_and_cache(void) __attribute__ ((wea
   /* turn mmu off first in case it's on */
-  uint32_t ctrl = arm_cp15_start_setup_mmu_and_cache(
-    ARM_CP15_CTRL_M | ARM_CP15_CTRL_A,	/* clear - mmu off */
-    ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z
-  arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache(
-    ctrl,
-    (uint32_t *) bsp_translation_table_base,
-    ARM_MMU_DEFAULT_CLIENT_DOMAIN,
-    &beagle_mmu_config_table[0],
-    RTEMS_ARRAY_SIZE(beagle_mmu_config_table)
+  uint32_t bsp_initial_mmu_ctrl_clear = ARM_CP15_CTRL_M | ARM_CP15_CTRL_A;
+  uint32_t bsp_initial_mmu_ctrl_set = ARM_CP15_CTRL_AFE | ARM_CP15_CTRL_Z;
+    bsp_memory_management_initialize(
+    bsp_initial_mmu_ctrl_set,
+    bsp_initial_mmu_ctrl_clear
+const size_t arm_cp15_start_mmu_config_table_size =
+  RTEMS_ARRAY_SIZE(arm_cp15_start_mmu_config_table);
\ No newline at end of file
1.7.9.5
