Uniprocessor implementation of nested mutex problem of priority inversion.
Saurabh Gadia
gadia at usc.edu
Thu Aug 13 22:55:13 UTC 2015
How can we get mutex->queue.priority_before data structure without having
the mutex structure. We need that to change the priority_before for every
acquired mutex by a thread to ensure that there is proper stepdown of
priority. We just need to have mutex to get the start point of the
chain_control and then we traverse upto the head of the chain to manipulate
the priority_before if required.
Thanks,
Saurabh Gadia
On Thu, Aug 13, 2015 at 12:51 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Saurabh,
> Remove the commit "Updated the motivation for creating the new
> branch", don't add the .tags files, and don't add the .m4 changes that
> are not related to your project.
> Switch to using RTEMS_CONTAINER_OF macro and remove the typeaddr one.
> coremutexseize.c : remove the modification where you deleted a blank
> space randomly.
> threadimpl.h : follow the score naming conventions (
> https://devel.rtems.org/wiki/Developer/Coding/NamingRules ) for the
> new functions you introduce. Can you explain clearly why new functions
> are needed? Also, I'm not particularly satisfied with the use of the
> CORE_mutex_order_list type in these Thread functions. I don't see why
> the mutex should be "baked in" to the Thread functions interface.
> Tracking through the code, I can't even tell if it is necessary to
> pass this argument around. Can you say whether or not you need to keep
> this argument?
> Read the coding conventions for the style guidelines with respect to
> block scoping. Also watch out for line lengths > 80 characters. Add
> doxygen for new functions you introduce if they are kept around.
> For changes where the UP function invoked differs from the SMP, can
> you please add a comment to justify the difference. I want to
> understand why a particular code-path is followed for UP but not SMP.
> That's all for now, thanks!
> Gedare
> On Thu, Aug 13, 2015 at 1:55 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> > Hi,
> > I have created a new branch for uniprocessor solution of priority
> inversion
> > problem caused by nested mutex behavior.
> > link: https://github.com/saurabhgadia4/rtems/tree/nested-mutex
> > test case results:
> https://drive.google.com/folderview?id=0B44HRKVuGCkFfnFDVmxqQzZZUzljNUg4YmVPZmEybEp2Q0NNclpvS2FvemZ4Tm5Xa19nemM&usp=sharing
> > Thanks,
> > Saurabh Gadia
> > On Thu, Aug 13, 2015 at 9:10 AM, Saurabh Gadia <gadia at usc.edu> wrote:
> >> That is how we were doing in JPF. The validate method was triggered
> after
> >> every release of mutex by any thread and we would check for all the
> waiting
> >> threads on mutex's held by the holder. And if it finds a thread with
> higher
> >> priority blocked then it would panic or give assertion failure.
> >> Thanks,
> >> Saurabh Gadia
> >> On Thu, Aug 13, 2015 at 9:08 AM, Gedare Bloom <gedare at rtems.org> wrote:
> >>> Thanks. Would it be possible for you to turn the failure cases into
> >>> real test failures? In other words, add some logic to detect the
> >>> priority inversion and abort the test?
> >>> Gedare
> >>> On Thu, Aug 13, 2015 at 12:05 PM, Saurabh Gadia <gadia at usc.edu> wrote:
> >>> > Hi,
> >>> > Following is the result of spsem04 test without the patch:
> >>> > *** BEGIN OF TEST SPSEM 4 ***
> >>> > init: S0 created
> >>> > init: S1 created
> >>> > init: TA01 created with priority 36
> >>> > init: TA02 created with priority 34
> >>> > init: TA03 created with priority 32
> >>> > TA01: started with priority 36
> >>> > TA01: priority 36, holding S0
> >>> > TA02: started with priority 34
> >>> > TA02: priority 34, holding S1
> >>> > TA01: priority 34, holding S0 and now creating TA03
> >>> > TA03: started with priority 32
> >>> > TA01: priority 34 Releasing s0 (This is priority inheritance problem
> as
> >>> > TA02
> >>> > waits on mutex held by TA01 and has higher priority than TA01. TA03
> >>> > just
> >>> > promotes the priority TA02.)
> >>> > TA02: priority 32, holding S1,S0
> >>> > TA02: priority 32 before releasing S0
> >>> > TA02: priority 32 after releasing S0
> >>> > TA02: priority 32 before releasing S1
> >>> > TA03: priority 32, holding S1
> >>> > TA03: priority 32
> >>> > TA03: suspending
> >>> > TA02: priority 34 after releasing S1
> >>> > TA02: suspending
> >>> > TA01: priority 36
> >>> > TA01: exiting
> >>> > *** END OF TEST SPSEM 4 ***
> >>> > You can see the difference in highlighted portions of both outputs.
> >>> > Thanks,
> >>> > Saurabh Gadia
> >>> > On Thu, Aug 13, 2015 at 8:17 AM, Saurabh Gadia <gadia at usc.edu>
> wrote:
> >>> >> Ok. I will mail you back soon.
> >>> >> On Thursday, August 13, 2015, Gedare Bloom <gedare at rtems.org>
> wrote:
> >>> >>> Saurabh,
> >>> >>> Please pull from rtems.git again, create a new branch from
> 'master',
> >>> >>> and apply your changes to the branch. It's too hard to review code
> >>> >>> that is not all by itself on a branch.
> >>> >>> Gedare
> >>> >>> On Thu, Aug 13, 2015 at 5:28 AM, Saurabh Gadia <gadia at usc.edu>
> wrote:
> >>> >>> > Hi,
> >>> >>> > I have implemented uniprocessor model of nested mutex problem in
> >>> >>> > rtems.
> >>> >>> > its
> >>> >>> > still in basic form. I tried to multiplex it with the existing
> >>> >>> > solution
> >>> >>> > but
> >>> >>> > was finding hard time. To push ahead, I decided to have separate
> >>> >>> > functions
> >>> >>> > for uniprocessor and SMP(kept default behavior) and with your
> >>> >>> > review
> >>> >>> > comments will know what to do. Following is the link for the git
> >>> >>> > repo:
> >>> >>> > https://github.com/saurabhgadia4/rtems/commits/master and its
> JPF
> >>> >>> > branch:
> https://github.com/saurabhgadia4/lock-model/blob/uniproc-new1/rtems/Mutex.java
> >>> >>> > I have also tested spsem01, 02, 03 test cases. Following are the
> >>> >>> > links
> >>> >>> > for
> >>> >>> > the test case results which states output before solution and
> after
> >>> >>> > applying
> >>> >>> > the solution. I am still not getting whether my code is passing
> >>> >>> > spsem03
> >>> >>> > test
> >>> >>> > or not. How can I verify that?
> >>> >>> > Test Case Link:
> >>> >>> > Thanks,
> >>> >>> > Saurabh Gadia
> >>> >> Thanks,
> >>> >> Saurabh Gadia
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150813/2874a868/attachment-0001.html>
