Uniprocessor implementation of nested mutex problem of priority inversion.
Thu Aug 13 23:34:46 UTC 2015
On Thu, Aug 13, 2015 at 7:31 PM, Cyrille Artho <cyrille.artho at gmail.com> wrote:
> Hi Gedard,
> The CORE_mutex_order_list in the thread priority update functions is
> needed to step down the priority in the right way upon unlocking.
> Currently these functions are only used internally.
> If you'd like a simpler interface, that list would have to be part of
> the thread data structure (Thread_Control) itself. However, then we'd
> add a field to that struct inside an #IFDEF macro.
> Do you think this is preferable?
If they're used internally, can we make them static, or do they need
to be shared across multiple subsystems. Internal functions should get
extern'ed through the "impl.h" header file variants. I need to find
time (ha!) to look more closely at this. I think the design can be
either improved, or made "cleaner" with respect to information hiding
and interface creep.
Gedare
> On Fri, Aug 14, 2015 at 8:01 AM, Saurabh Gadia <gadia at usc.edu> wrote:
>> Thanks,
>> Saurabh Gadia
>> ---------- Forwarded message ----------
>> From: Gedare Bloom <gedare at rtems.org>
>> Date: Thu, Aug 13, 2015 at 12:51 PM
>> Subject: Re: Uniprocessor implementation of nested mutex problem of priority
>> inversion.
>> To: Saurabh Gadia <gadia at usc.edu>
>> Cc: "devel at rtems.org" <devel at rtems.org>
>> Saurabh,
>> Remove the commit "Updated the motivation for creating the new
>> branch", don't add the .tags files, and don't add the .m4 changes that
>> are not related to your project.
>> Switch to using RTEMS_CONTAINER_OF macro and remove the typeaddr one.
>> coremutexseize.c : remove the modification where you deleted a blank
>> space randomly.
>> threadimpl.h : follow the score naming conventions (
>> https://devel.rtems.org/wiki/Developer/Coding/NamingRules ) for the
>> new functions you introduce. Can you explain clearly why new functions
>> are needed? Also, I'm not particularly satisfied with the use of the
>> CORE_mutex_order_list type in these Thread functions. I don't see why
>> the mutex should be "baked in" to the Thread functions interface.
>> Tracking through the code, I can't even tell if it is necessary to
>> pass this argument around. Can you say whether or not you need to keep
>> this argument?
>> Read the coding conventions for the style guidelines with respect to
>> block scoping. Also watch out for line lengths > 80 characters. Add
>> doxygen for new functions you introduce if they are kept around.
>> For changes where the UP function invoked differs from the SMP, can
>> you please add a comment to justify the difference. I want to
>> understand why a particular code-path is followed for UP but not SMP.
>> That's all for now, thanks!
>> Gedare
>> On Thu, Aug 13, 2015 at 1:55 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>>> Hi,
>>> I have created a new branch for uniprocessor solution of priority
>>> inversion
>>> problem caused by nested mutex behavior.
>>> link: https://github.com/saurabhgadia4/rtems/tree/nested-mutex
>>> test case results:
>>> https://drive.google.com/folderview?id=0B44HRKVuGCkFfnFDVmxqQzZZUzljNUg4YmVPZmEybEp2Q0NNclpvS2FvemZ4Tm5Xa19nemM&usp=sharing
>>> Thanks,
>>> Saurabh Gadia
>>> On Thu, Aug 13, 2015 at 9:10 AM, Saurabh Gadia <gadia at usc.edu> wrote:
>>>> That is how we were doing in JPF. The validate method was triggered after
>>>> every release of mutex by any thread and we would check for all the
>>>> waiting
>>>> threads on mutex's held by the holder. And if it finds a thread with
>>>> higher
>>>> priority blocked then it would panic or give assertion failure.
>>>> Thanks,
>>>> Saurabh Gadia
>>>> On Thu, Aug 13, 2015 at 9:08 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> Thanks. Would it be possible for you to turn the failure cases into
>>>>> real test failures? In other words, add some logic to detect the
>>>>> priority inversion and abort the test?
>>>>> Gedare
>>>>> On Thu, Aug 13, 2015 at 12:05 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>>>>> > Hi,
>>>>> > Following is the result of spsem04 test without the patch:
>>>>> > *** BEGIN OF TEST SPSEM 4 ***
>>>>> > init: S0 created
>>>>> > init: S1 created
>>>>> > init: TA01 created with priority 36
>>>>> > init: TA02 created with priority 34
>>>>> > init: TA03 created with priority 32
>>>>> > TA01: started with priority 36
>>>>> > TA01: priority 36, holding S0
>>>>> > TA02: started with priority 34
>>>>> > TA02: priority 34, holding S1
>>>>> > TA01: priority 34, holding S0 and now creating TA03
>>>>> > TA03: started with priority 32
>>>>> > TA01: priority 34 Releasing s0 (This is priority inheritance problem
>>>>> > as
>>>>> > TA02
>>>>> > waits on mutex held by TA01 and has higher priority than TA01. TA03
>>>>> > just
>>>>> > promotes the priority TA02.)
>>>>> > TA02: priority 32, holding S1,S0
>>>>> > TA02: priority 32 before releasing S0
>>>>> > TA02: priority 32 after releasing S0
>>>>> > TA02: priority 32 before releasing S1
>>>>> > TA03: priority 32, holding S1
>>>>> > TA03: priority 32
>>>>> > TA03: suspending
>>>>> > TA02: priority 34 after releasing S1
>>>>> > TA02: suspending
>>>>> > TA01: priority 36
>>>>> > TA01: exiting
>>>>> > *** END OF TEST SPSEM 4 ***
>>>>> > You can see the difference in highlighted portions of both outputs.
>>>>> > Thanks,
>>>>> > Saurabh Gadia
>>>>> > On Thu, Aug 13, 2015 at 8:17 AM, Saurabh Gadia <gadia at usc.edu> wrote:
>>>>> >> Ok. I will mail you back soon.
>>>>> >> On Thursday, August 13, 2015, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> >>> Saurabh,
>>>>> >>> Please pull from rtems.git again, create a new branch from 'master',
>>>>> >>> and apply your changes to the branch. It's too hard to review code
>>>>> >>> that is not all by itself on a branch.
>>>>> >>> Gedare
>>>>> >>> On Thu, Aug 13, 2015 at 5:28 AM, Saurabh Gadia <gadia at usc.edu>
>>>>> >>> wrote:
>>>>> >>> > Hi,
>>>>> >>> > I have implemented uniprocessor model of nested mutex problem in
>>>>> >>> > rtems.
>>>>> >>> > its
>>>>> >>> > still in basic form. I tried to multiplex it with the existing
>>>>> >>> > solution
>>>>> >>> > but
>>>>> >>> > was finding hard time. To push ahead, I decided to have separate
>>>>> >>> > functions
>>>>> >>> > for uniprocessor and SMP(kept default behavior) and with your
>>>>> >>> > review
>>>>> >>> > comments will know what to do. Following is the link for the git
>>>>> >>> > repo:
>>>>> >>> > https://github.com/saurabhgadia4/rtems/commits/master and its JPF
>>>>> >>> > branch:
>>>>> >>> > https://github.com/saurabhgadia4/lock-model/blob/uniproc-new1/rtems/Mutex.java
>>>>> >>> > I have also tested spsem01, 02, 03 test cases. Following are the
>>>>> >>> > links
>>>>> >>> > for
>>>>> >>> > the test case results which states output before solution and
>>>>> >>> > after
>>>>> >>> > applying
>>>>> >>> > the solution. I am still not getting whether my code is passing
>>>>> >>> > spsem03
>>>>> >>> > test
>>>>> >>> > or not. How can I verify that?
>>>>> >>> > Test Case Link:
>>>>> >>> > Thanks,
>>>>> >>> > Saurabh Gadia
>>>>> >> Thanks,
>>>>> >> Saurabh Gadia
> Regards,
> Cyrille Artho
