Pi2 Mailbox IRQs was Re: Fwd: SMP support for Raspberry Pi 2
Sat Aug 15 21:37:38 UTC 2015
Alan .. can you confirm what I am interpreting?
On 08/15/2015 02:56 PM, Rohini Kulkarni wrote:
> On Sun, Aug 16, 2015 at 1:13 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>> wrote:
>     On 08/15/2015 02:35 PM, Rohini Kulkarni wrote:
>         Hi
>         I need some help with this. I am unable to figure out yet how
>         to add an interrupt for the mailbox and determine interrupt
>         number to be associated with it.
>     If you can enable it and cause it, the fault handler will be one
>     way to do it :)
>     Can you tell from the documentation which pin(s) on the interrupt
>     controller
>     is associated with the mailbox?
>     FWIW I don't even know what documentation to look at for the SoC to
>     find this. If you point me to it, I will see what I can find.
> This
> <https://www.raspberrypi.org/documentation/hardware/raspberrypi/bcm2836/QA7_rev3.4.pdf>
> is the only official document which seems to be available. The Cortex
> A7 mpcore document didn't help here.
Putitng this back on the devel list.
Page 16 of that PDF (4.10) follows up on a previous section. There
are sixteen mailboxes. Each core has four associated with it. In
4.10, there is a list of per-core interrupt sources. There are four
addresses for core specific interrupt source registers.
It looks like the interrupts are numerically next to the GPU interrupt.
This much looks fairly straight-forward.  Pick a mailbox to dedicate
to interprocessor-interrupts. If you pick Bit 7 (mailbox 3), I would expect
it to be one logical interrupt lower than the GPU interrupt source.
Check the irq list for the BSP. This should be in a .h file.
You will install one SMP IRQ handler. But based on the core number it
is running on, you will have to do slightly different things to clear it
(I think) since the interrupt registers are duplicated per core.
>         Thanks.
>         On Sat, Aug 15, 2015 at 10:52 PM, Rohini Kulkarni
>         <krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>
>         <mailto:krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>>>
>         wrote:
>             On Wed, Aug 12, 2015 at 1:29 AM, Joel Sherrill
>         <mailto:joel.sherrill at oarcorp.com>>> wrote:
>                 On 8/11/2015 2:06 PM, Rohini Kulkarni wrote:
>                     Hi,
>                     I would have to register the related mailbox
>         interrupt and
>                     associate it with a handler that should be same as
>                     _SMP_Inter_processor_interrupt_handler(). Am I right?
>                 That sounds correct.
>                      From where can I get a reference of how to do this?
>                 I would look at the Xilinx code that registers
>         interrupts. The API
>                 should be the same. Also the clock driver, etc. The
>         actual handler
>                 and IRQ number will vary.
>             How do I determine the interrupt number?
>             I could fine the IPi handler being installed here in
>             arm-a9mpcore-smp.c
>             rtems_interrupt_handler_install(
>                   ARM_GIC_IRQ_SGI_0,
>                   "IPI",
>                   RTEMS_INTERRUPT_UNIQUE,
>                   bsp_inter_processor_interrupt,
>                   NULL
>                     On 11 Aug 2015 00:41, "Joel Sherrill"
>         <mailto:joel.sherrill at oarcorp.com>>>> wrote:
>                         The source for the CPU supplement is in
>                     doc/cpu_supplement in
>                         the RTEMS tree.
>                         I do not know when the latest online was built so
>                     reading it
>                         there is probably safest.
>                         To build it, you will likely have to install some
>                     texinfo and
>                         texlive tools.
>                         cd $r/doc
>                         ../bootstrap
>                         cd ../..
>                         mkdir b-doc
>                         cd b-doc
>                         $r/doc/configure --enable-maintainer-mode \
>                            --prefix=DIRECTORY
>                         make
>                         make install
>                         That should be similar to how it is built.
>                         --joel
>                         On 8/10/2015 1:35 PM, Rohini Kulkarni wrote:
>                             The documentation that Sebastian was
>         referring to.
>                             On Tue, Jul 28, 2015 at 12:24 PM,
>         Sebastian Huber
>         <sebastian.huber at embedded-brains.de
>         <mailto:sebastian.huber at embedded-brains.de>
>         <mailto:sebastian.huber at embedded-brains.de>>
>         <mailto:sebastian.huber at embedded-brains.de>>>
>         <mailto:sebastian.huber at embedded-brains.de>>>>> wrote:
>                                  Hello Rohini,
>                                  please use the devel list.
>                                  On 28/07/15 07:41, Rohini Kulkarni wrote:
>                                      Hi,
>                                      I wish to understand where the
>                     interprocessor interrupts are used during the boot
>                     process. During final initialization of SMP I can see
>                                             ARM_GIC_IRQ_SGI_0,
>                                             "IPI",
>                                             NULL
>                                      Raspberry Pi 2 does not have the
>         generic
>                     interrupt controller. Interrupt routing will have
>         to be
>                     handled differently. So I wish to understand how/
>         where it
>                     is used. I suppose this might be the problem.
>                                  Sorry, that the documentation is so
>                     scattered.  I think we should move everything into
>         the CPU
>                     Architecture Supplement. It would be nice if you
>         can help
>                     to improve the documentation since you have a
>         different
>                     view point.
>                             What is the CPU Architecture Supplement?
>                                  You must install the IPI during the
>         system
>                     initialization. It is raised via the
>                     _CPU_SMP_Send_interrupt() function, for an example see
>                     arm-a9mpcore-smp.c.
>                                      Thanks.
>                                      On Wed, Jul 22, 2015 at 7:08 PM,
>         Rohini
>                     Kulkarni <krohini1593 at gmail.com
>         <mailto:krohini1593 at gmail.com <mailto:krohini1593 at gmail.com>>>>
>         <mailto:krohini1593 at gmail.com>>>>>> wrote:
>                                           Ok. Qemu suggestion seems
>         helpful
>                     for the cache configuration
>                                           issue though. I am trying
>         with Pi 1.
>                                           Thanks.
>                                           On 22 Jul 2015 18:59,
>         "Sebastian Huber"
>         <mailto:sebastian.huber at embedded-brains.de>>>>>> wrote:
>                                               Sorry, I cannot help you
>         here
>                     since I never worked with a
>                                               Raspberry Pi.
>                                               --         Sebastian Huber,
>                     embedded brains GmbH
>                                               Address : Dornierstr. 4,
>         D-82178
>                     Puchheim, Germany
>                                               Phone   : +49 89 189 47
>         41-16
>                                               Fax     : +49 89 189 47
>         41-09
>                                               E-Mail  :
>                                               PGP     : Public key
>         available
>                     on request.
>                                               Diese Nachricht ist keine
>                     geschäftliche Mitteilung im Sinne
>                                               des EHUG.
>                                      Rohini Kulkarni
>                                  Sebastian Huber, embedded brains GmbH
>                                  Address : Dornierstr. 4, D-82178
>         Puchheim,
>                     Germany
>                                  Phone   : +49 89 189 47 41-16
>                                  Fax     : +49 89 189 47 41-09
>                                  E-Mail  :
>                                  PGP     : Public key available on
>         request.
>                                  Diese Nachricht ist keine geschäftliche
>                     Mitteilung im Sinne des EHUG.
>                             Rohini Kulkarni
>                         Joel Sherrill, Ph.D.             Director of
>         Research
>         & Development
>                         joel.sherrill at OARcorp.com        On-Line
>         Applications
>                     Research
>                         Ask me about RTEMS: a free RTOS  Huntsville AL
>         35805
>                         Support Available                (256) 722-9985
>                 --         Joel Sherrill, Ph.D.             Director
>         of Research &
>                 Development
>                 joel.sherrill at OARcorp.com        On-Line Applications
>         Research
>                 Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>             --     Rohini Kulkarni
>         Rohini Kulkarni
>     -- Joel Sherrill
>     Support and Training Available
> Rohini Kulkarni
-- Joel Sherrill
