building RTEMS 4.11 leon3 with floating point support?
Cudmore, Alan P. (GSFC-5820)
alan.p.cudmore at nasa.gov
Mon Aug 17 15:29:10 UTC 2015
Hi,
We are currently trying to use the leon3 BSP for RTEMS 4.11.
We have used the 4.10 RCC/Gaisler tools with the Driver Manager in the past, but we would like to be on 4.11 for the SMP support.
When I build the 4.11 leon3 BSP, I seem to only have soft-float support. When I try to build with the —enable-multilib configure switch, the build fails. Before I start trying to determine the cause of the compile failure, I wanted to make sure I am enabling floating point support for the LEON3 correctly.
Thanks,
Alan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150817/32e771c5/attachment.html>
