[PATCH] [libbsd] Pulled and ported DWC OTG driver for RPi from FreeBSD. Modified USB sources during porting. Added driver to build by waf and make
Yurii Shevtsov
ungetch at gmail.com
Fri Aug 21 17:47:01 UTC 2015
Subject: [PATCH] Pulled and ported DWC OTG driver for RPi from FreeBSD.
Makefile | 3 +
freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c | 116 +
freebsd/sys/dev/usb/controller/dwc_otg.c | 4903
freebsd/sys/dev/usb/controller/dwc_otg.h | 223 +
freebsd/sys/dev/usb/controller/dwc_otg_fdt.c | 235 +
freebsd/sys/dev/usb/controller/dwc_otg_fdt.h | 39 +
freebsd/sys/dev/usb/controller/dwc_otgreg.h | 800 ++++
freebsd/sys/dev/usb/usb.h | 9 +
freebsd/sys/dev/usb/usb_bus.h | 3 +
freebsd/sys/dev/usb/usb_core.c | 7 +
freebsd/sys/dev/usb/usb_core.h | 8 +
rtemsbsd/include/bsp/nexus-devices.h | 19 +
rtemsbsd/include/machine/rtems-bsd-sysinit.h | 3 +
wscript | 3 +
14 files changed, 6371 insertions(+), 0 deletions(-)
create mode 100644 freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
create mode 100644 freebsd/sys/dev/usb/controller/dwc_otg.c
create mode 100644 freebsd/sys/dev/usb/controller/dwc_otg.h
create mode 100644 freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
create mode 100644 freebsd/sys/dev/usb/controller/dwc_otg_fdt.h
create mode 100644 freebsd/sys/dev/usb/controller/dwc_otgreg.h
diff --git a/Makefile b/Makefile
index da2a5ef..02964d3 100644
--- a/Makefile
+++ b/Makefile
@@ -186,6 +186,7 @@ LIB_C_FILES += freebsd/sys/dev/tsec/if_tsec.c
LIB_C_FILES += freebsd/sys/dev/cadence/if_cgem.c
LIB_C_FILES += freebsd/sys/dev/dwc/if_dwc.c
LIB_C_FILES += freebsd/sys/arm/xilinx/zy7_slcr.c
+LIB_C_FILES += freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
LIB_C_FILES += freebsd/sys/dev/random/harvest.c
LIB_C_FILES += freebsd/sys/netinet/tcp_hostcache.c
LIB_C_FILES += freebsd/sys/dev/led/led.c
@@ -244,6 +245,8 @@ LIB_C_FILES += freebsd/sys/dev/usb/usb_process.c
LIB_C_FILES += freebsd/sys/dev/usb/usb_request.c
LIB_C_FILES += freebsd/sys/dev/usb/usb_transfer.c
LIB_C_FILES += freebsd/sys/dev/usb/usb_util.c
+LIB_C_FILES += freebsd/sys/dev/usb/controller/dwc_otg.c
+LIB_C_FILES += freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
LIB_C_FILES += freebsd/sys/dev/usb/controller/ohci.c
LIB_C_FILES += freebsd/sys/dev/usb/controller/ehci.c
LIB_C_FILES += freebsd/sys/dev/usb/controller/usb_controller.c
diff --git a/freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
b/freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
new file mode 100644
index 0000000..71ff670
--- /dev/null
+++ b/freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c
@@ -0,0 +1,116 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright 2015 Andrew Turner.
+ * All rights reserved.
+ * modification, are permitted provided that the following conditions are
+ * met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+ * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
+ * BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
+ * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
+ * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
+ * ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/sys/param.h>
+#include <sys/kernel.h>
+#include <sys/bus.h>
+#include <sys/callout.h>
+#include <sys/condvar.h>
+#include <sys/module.h>
+#ifndef __rtems__
+#include <dev/ofw/ofw_bus_subr.h>
+#endif
+#include <dev/usb/usb.h>
+#include <dev/usb/usbdi.h>
+#include <dev/usb/usb_busdma.h>
+#include <dev/usb/usb_process.h>
+#include <dev/usb/usb_controller.h>
+#include <dev/usb/usb_bus.h>
+#include <dev/usb/controller/dwc_otg.h>
+#include <dev/usb/controller/dwc_otg_fdt.h>
+#ifndef __rtems__
+#include <arm/broadcom/bcm2835/bcm2835_mbox_prop.h>
+#else
+#include <bsp/vc.h>
+#endif
+static device_probe_t bcm283x_dwc_otg_probe;
+static device_attach_t bcm283x_dwc_otg_attach;
+static int
+bcm283x_dwc_otg_probe(device_t dev)
+ #ifndef __rtems__
+ if (!ofw_bus_status_okay(dev))
+ return (ENXIO);
+ if (!ofw_bus_is_compatible(dev, "broadcom,bcm2835-usb"))
+ return (ENXIO);
+ #endif
+ device_set_desc(dev, "DWC OTG 2.0 integrated USB controller
(bcm283x)");
+ return (BUS_PROBE_VENDOR);
+static int
+bcm283x_dwc_otg_attach(device_t dev)
+ #ifndef __rtems__
+ bcm2835_mbox_set_power_state(dev, BCM2835_MBOX_POWER_ID_USB_HCD, TRUE);
+ #else
+ bcm2835_set_power_state_entries entries;
+ entries.dev_id = bcm2835_mailbox_power_udid_usb_hcd;
+ entries.state = BCM2835_MAILBOX_SET_POWER_STATE_REQ_ON
+ | BCM2835_MAILBOX_SET_POWER_STATE_REQ_WAIT;
+ int ret = bcm2835_mailbox_set_power_state(&entries);
+ if (ret) return ENXIO;
+ #endif
+ return (dwc_otg_attach(dev));
+static device_method_t bcm283x_dwc_otg_methods[] = {
+ /* bus interface */
+ DEVMETHOD(device_probe, bcm283x_dwc_otg_probe),
+ DEVMETHOD(device_attach, bcm283x_dwc_otg_attach),
+ DEVMETHOD_END
+static devclass_t bcm283x_dwc_otg_devclass;
+DEFINE_CLASS_1(bcm283x_dwcotg, bcm283x_dwc_otg_driver,
bcm283x_dwc_otg_methods,
+ sizeof(struct dwc_otg_fdt_softc), dwc_otg_driver);
+#ifndef __rtems__
+DRIVER_MODULE(bcm283x_dwcotg, simplebus, bcm283x_dwc_otg_driver,
+ bcm283x_dwc_otg_devclass, 0, 0);
+#else
+DRIVER_MODULE(bcm283x_dwcotg, nexus, bcm283x_dwc_otg_driver,
+#endif
+MODULE_DEPEND(bcm283x_dwcotg, usb, 1, 1, 1);
diff --git a/freebsd/sys/dev/usb/controller/dwc_otg.c
b/freebsd/sys/dev/usb/controller/dwc_otg.c
index 0000000..f84a896
--- /dev/null
+++ b/freebsd/sys/dev/usb/controller/dwc_otg.c
@@ -0,0 +1,4903 @@
+ * Copyright (c) 2012 Hans Petter Selasky. All rights reserved.
+ * Copyright (c) 2010-2011 Aleksandr Rybalko. All rights reserved.
+ * are met:
PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This file contains the driver for the DesignWare series USB 2.0 OTG
+ * Controller.
+ * LIMITATION: Drivers must be bound to all OUT endpoints in the
+ * active configuration for this driver to work properly. Blocking any
+ * OUT endpoint will block all OUT endpoints including the control
+ * endpoint. Usually this is not a problem.
+ * NOTE: Writing to non-existing registers appears to cause an
+ * internal reset.
+#include <sys/stdint.h>
+#include <sys/stddef.h>
+#include <sys/queue.h>
+#include <rtems/bsd/sys/types.h>
+#include <sys/systm.h>
+#include <rtems/bsd/sys/lock.h>
+#include <sys/mutex.h>
+#include <sys/sysctl.h>
+#include <sys/sx.h>
+#include <rtems/bsd/sys/unistd.h>
+#include <sys/malloc.h>
+#include <sys/priv.h>
+#define USB_DEBUG_VAR dwc_otg_debug
+#include <dev/usb/usb_core.h>
+#include <dev/usb/usb_debug.h>
+#include <dev/usb/usb_transfer.h>
+#include <dev/usb/usb_device.h>
+#include <dev/usb/usb_hub.h>
+#include <dev/usb/usb_util.h>
+#include <dev/usb/controller/dwc_otgreg.h>
+#define DWC_OTG_BUS2SC(bus) \
+ ((struct dwc_otg_softc *)(((uint8_t *)(bus)) - \
+ ((uint8_t *)&(((struct dwc_otg_softc *)0)->sc_bus))))
+#define DWC_OTG_PC2UDEV(pc) \
+ (USB_DMATAG_TO_XROOT((pc)->tag_parent)->udev)
+#define DWC_OTG_MSK_GINT_ENABLED \
+ (GINTMSK_ENUMDONEMSK | \
+ GINTMSK_USBRSTMSK | \
+ GINTMSK_USBSUSPMSK | \
+ GINTMSK_IEPINTMSK | \
+ GINTMSK_SESSREQINTMSK | \
+ GINTMSK_RXFLVLMSK | \
+ GINTMSK_HCHINTMSK | \
+ GINTMSK_OTGINTMSK | \
+ GINTMSK_PRTINTMSK)
+#define DWC_OTG_MSK_GINT_THREAD_IRQ \
+ (GINTSTS_USBRST | GINTSTS_ENUMDONE | GINTSTS_PRTINT | \
+ GINTSTS_WKUPINT | GINTSTS_USBSUSP | GINTMSK_OTGINTMSK | \
+ GINTSTS_SESSREQINT)
+#define DWC_OTG_PHY_ULPI 0
+#define DWC_OTG_PHY_HSIC 1
+#define DWC_OTG_PHY_INTERNAL 2
+#ifndef DWC_OTG_PHY_DEFAULT
+#define DWC_OTG_PHY_DEFAULT DWC_OTG_PHY_ULPI
+#endif
+static int dwc_otg_phy_type = DWC_OTG_PHY_DEFAULT;
+static SYSCTL_NODE(_hw_usb, OID_AUTO, dwc_otg, CTLFLAG_RW, 0, "USB DWC
OTG");
+SYSCTL_INT(_hw_usb_dwc_otg, OID_AUTO, phy_type, CTLFLAG_RDTUN,
+ &dwc_otg_phy_type, 0, "DWC OTG PHY TYPE - 0/1/2 - ULPI/HSIC/INTERNAL");
+#ifdef USB_DEBUG
+static int dwc_otg_debug;
+SYSCTL_INT(_hw_usb_dwc_otg, OID_AUTO, debug, CTLFLAG_RWTUN,
+ &dwc_otg_debug, 0, "DWC OTG debug level");
+#endif
+#define DWC_OTG_INTR_ENDPT 1
+/* prototypes */
+extern struct usb_bus_methods dwc_otg_bus_methods;
+extern struct usb_pipe_methods dwc_otg_device_non_isoc_methods;
+extern struct usb_pipe_methods dwc_otg_device_isoc_methods;
+static dwc_otg_cmd_t dwc_otg_setup_rx;
+static dwc_otg_cmd_t dwc_otg_data_rx;
+static dwc_otg_cmd_t dwc_otg_data_tx;
+static dwc_otg_cmd_t dwc_otg_data_tx_sync;
+static dwc_otg_cmd_t dwc_otg_host_setup_tx;
+static dwc_otg_cmd_t dwc_otg_host_data_tx;
+static dwc_otg_cmd_t dwc_otg_host_data_rx;
+static void dwc_otg_device_done(struct usb_xfer *, usb_error_t);
+static void dwc_otg_do_poll(struct usb_bus *);
+static void dwc_otg_standard_done(struct usb_xfer *);
+static void dwc_otg_root_intr(struct dwc_otg_softc *);
+static void dwc_otg_interrupt_poll_locked(struct dwc_otg_softc *);
+static void dwc_otg_host_channel_disable(struct dwc_otg_softc *, uint8_t);
+ * Here is a configuration that the chip supports.
+struct usb_hw_ep_profile dwc_otg_ep_profile[1] = {
+ [0] = {
+ .max_in_frame_size = 64,/* fixed */
+ .max_out_frame_size = 64, /* fixed */
+ .is_simplex = 1,
+ .support_control = 1,
+static void
+dwc_otg_get_hw_ep_profile(struct usb_device *udev,
+ const struct usb_hw_ep_profile **ppf, uint8_t ep_addr)
+ struct dwc_otg_softc *sc;
+ sc = DWC_OTG_BUS2SC(udev->bus);
+ if (ep_addr < sc->sc_dev_ep_max)
+ *ppf = &sc->sc_hw_ep_profile[ep_addr].usb;
+ else
+ *ppf = NULL;
+static int
+dwc_otg_init_fifo(struct dwc_otg_softc *sc, uint8_t mode)
+ struct dwc_otg_profile *pf;
+ uint32_t fifo_size;
+ uint32_t fifo_regs;
+ uint32_t tx_start;
+ uint8_t x;
+ fifo_size = sc->sc_fifo_size;
+ * NOTE: Reserved fixed size area at end of RAM, which must
+ * not be allocated to the FIFOs:
+ fifo_regs = 4 * 16;
+ if (fifo_size < fifo_regs) {
+ DPRINTF("Too little FIFO\n");
+ return (EINVAL);
+ /* subtract FIFO regs from total once */
+ fifo_size -= fifo_regs;
+ /* split equally for IN and OUT */
+ fifo_size /= 2;
+ /* align to 4 bytes boundary */
+ fifo_size &= ~3;
+ /* set global receive FIFO size */
+ DWC_OTG_WRITE_4(sc, DOTG_GRXFSIZ, fifo_size / 4);
+ tx_start = fifo_size;
+ if (fifo_size < 64) {
+ DPRINTFN(-1, "Not enough data space for EP0 FIFO.\n");
+ return (EINVAL);
+ /* disable any leftover host channels */
+ for (x = 0; x != sc->sc_host_ch_max; x++) {
+ if (sc->sc_chan_state[x].wait_sof == 0)
+ continue;
+ dwc_otg_host_channel_disable(sc, x);
+ if (mode == DWC_MODE_HOST) {
+ /* reset active endpoints */
+ sc->sc_active_rx_ep = 0;
+ /* split equally for periodic and non-periodic */
+ fifo_size /= 2;
+ fifo_size &= ~3;
+ DWC_OTG_WRITE_4(sc, DOTG_GNPTXFSIZ,
+ ((fifo_size / 4) << 16) |
+ (tx_start / 4));
+ tx_start += fifo_size;
+ /* disable all host interrupts */
+ DWC_OTG_WRITE_4(sc, DOTG_HCINTMSK(x),
+ HCINT_DEFAULT_MASK);
+ DWC_OTG_WRITE_4(sc, DOTG_HPTXFSIZ,
+ (tx_start / 4));
+ /* reset host channel state */
+ memset(sc->sc_chan_state, 0, sizeof(sc->sc_chan_state));
+ /* reset FIFO TX levels */
+ sc->sc_tx_cur_p_level = 0;
+ sc->sc_tx_cur_np_level = 0;
+ /* store maximum periodic and non-periodic FIFO TX size */
+ sc->sc_tx_max_size = fifo_size;
+ /* enable all host channel interrupts */
+ DWC_OTG_WRITE_4(sc, DOTG_HAINTMSK,
+ (1U << sc->sc_host_ch_max) - 1U);
+ if (mode == DWC_MODE_DEVICE) {
+ (0x10 << 16) | (tx_start / 4));
+ fifo_size -= 0x40;
+ tx_start += 0x40;
+ /* setup control endpoint profile */
+ sc->sc_hw_ep_profile[0].usb = dwc_otg_ep_profile[0];
+ sc->sc_active_rx_ep = 1;
+ for (x = 1; x != sc->sc_dev_ep_max; x++) {
+ pf = sc->sc_hw_ep_profile + x;
+ pf->usb.max_out_frame_size = 1024 * 3;
+ pf->usb.is_simplex = 0; /* assume duplex */
+ pf->usb.support_bulk = 1;
+ pf->usb.support_interrupt = 1;
+ pf->usb.support_isochronous = 1;
+ pf->usb.support_out = 1;
+ if (x < sc->sc_dev_in_ep_max) {
+ uint32_t limit;
+ limit = (x == 1) ? MIN(DWC_OTG_TX_MAX_FIFO_SIZE,
+ DWC_OTG_MAX_TXN) : MIN(DWC_OTG_MAX_TXN / 2,
+ DWC_OTG_TX_MAX_FIFO_SIZE);
+ /* see if there is enough FIFO space */
+ if (limit <= fifo_size) {
+ pf->max_buffer = limit;
+ pf->usb.support_in = 1;
+ } else {
+ limit = MIN(DWC_OTG_TX_MAX_FIFO_SIZE, 0x40);
+ } else {
+ pf->usb.is_simplex = 1;
+ limit = 0;
+ /* set FIFO size */
+ DWC_OTG_WRITE_4(sc, DOTG_DIEPTXF(x),
+ ((limit / 4) << 16) | (tx_start / 4));
+ tx_start += limit;
+ fifo_size -= limit;
+ pf->usb.max_in_frame_size = limit;
+ } else {
+ DPRINTF("FIFO%d = IN:%d / OUT:%d\n", x,
+ pf->usb.max_in_frame_size,
+ pf->usb.max_out_frame_size);
+ /* reset RX FIFO */
+ DWC_OTG_WRITE_4(sc, DOTG_GRSTCTL,
+ GRSTCTL_RXFFLSH);
+ if (mode != DWC_MODE_OTG) {
+ /* reset all TX FIFOs */
+ GRSTCTL_TXFIFO(0x10) |
+ GRSTCTL_TXFFLSH);
+ } else {
+ /* reset periodic and non-periodic FIFO TX size */
+ return (0);
+static void
+dwc_otg_update_host_frame_interval(struct dwc_otg_softc *sc)
+ * Disabled until further. Assuming that the register is already
+ * programmed correctly by the boot loader.
+#if 0
+ uint32_t temp;
+ /* setup HOST frame interval register, based on existing value */
+ temp = DWC_OTG_READ_4(sc, DOTG_HFIR) & HFIR_FRINT_MASK;
+ if (temp >= 10000)
+ temp /= 1000;
+ else
+ temp /= 125;
+ /* figure out nearest X-tal value */
+ if (temp >= 54)
+ temp = 60; /* MHz */
+ else if (temp >= 39)
+ temp = 48; /* MHz */
+ else
+ temp = 30; /* MHz */
+ if (sc->sc_flags.status_high_speed)
+ temp *= 125;
+ else
+ temp *= 1000;
+ DPRINTF("HFIR=0x%08x\n", temp);
+ DWC_OTG_WRITE_4(sc, DOTG_HFIR, temp);
+#endif
+static void
+dwc_otg_clocks_on(struct dwc_otg_softc *sc)
+ if (sc->sc_flags.clocks_off &&
+ sc->sc_flags.port_powered) {
+ DPRINTFN(5, "\n");
+ /* TODO - platform specific */
+ sc->sc_flags.clocks_off = 0;
+static void
+dwc_otg_clocks_off(struct dwc_otg_softc *sc)
+ if (!sc->sc_flags.clocks_off) {
+ sc->sc_flags.clocks_off = 1;
+static void
+dwc_otg_pull_up(struct dwc_otg_softc *sc)
+ uint32_t temp;
+ /* pullup D+, if possible */
+ if (!sc->sc_flags.d_pulled_up &&
+ sc->sc_flags.d_pulled_up = 1;
+ temp = DWC_OTG_READ_4(sc, DOTG_DCTL);
+ temp &= ~DCTL_SFTDISCON;
+ DWC_OTG_WRITE_4(sc, DOTG_DCTL, temp);
+static void
+dwc_otg_pull_down(struct dwc_otg_softc *sc)
+ uint32_t temp;
+ /* pulldown D+, if possible */
+ if (sc->sc_flags.d_pulled_up) {
+ sc->sc_flags.d_pulled_up = 0;
+ temp |= DCTL_SFTDISCON;
+static void
+dwc_otg_enable_sof_irq(struct dwc_otg_softc *sc)
+ /* In device mode we don't use the SOF interrupt */
+ if (sc->sc_flags.status_device_mode != 0 ||
+ (sc->sc_irq_mask & GINTMSK_SOFMSK) != 0)
+ return;
+ sc->sc_irq_mask |= GINTMSK_SOFMSK;
+ DWC_OTG_WRITE_4(sc, DOTG_GINTMSK, sc->sc_irq_mask);
+static void
+dwc_otg_resume_irq(struct dwc_otg_softc *sc)
+ if (sc->sc_flags.status_suspend) {
+ /* update status bits */
+ sc->sc_flags.status_suspend = 0;
+ sc->sc_flags.change_suspend = 1;
+ if (sc->sc_flags.status_device_mode) {
+ * Disable resume interrupt and enable suspend
+ * interrupt:
+ sc->sc_irq_mask &= ~GINTMSK_WKUPINTMSK;
+ sc->sc_irq_mask |= GINTMSK_USBSUSPMSK;
+ /* complete root HUB interrupt endpoint */
+ dwc_otg_root_intr(sc);
+static void
+dwc_otg_suspend_irq(struct dwc_otg_softc *sc)
+ if (!sc->sc_flags.status_suspend) {
+ sc->sc_flags.status_suspend = 1;
+ * Disable suspend interrupt and enable resume
+ * interrupt:
+ sc->sc_irq_mask &= ~GINTMSK_USBSUSPMSK;
+ sc->sc_irq_mask |= GINTMSK_WKUPINTMSK;
+static void
+dwc_otg_wakeup_peer(struct dwc_otg_softc *sc)
+ return;
+ DPRINTFN(5, "Remote wakeup\n");
+ uint32_t temp;
+ /* enable remote wakeup signalling */
+ temp |= DCTL_RMTWKUPSIG;
+ /* Wait 8ms for remote wakeup to complete. */
+ usb_pause_mtx(&sc->sc_bus.bus_mtx, hz / 125);
+ temp &= ~DCTL_RMTWKUPSIG;
+ } else {
+ /* enable USB port */
+ DWC_OTG_WRITE_4(sc, DOTG_PCGCCTL, 0);
+ /* wait 10ms */
+ usb_pause_mtx(&sc->sc_bus.bus_mtx, hz / 100);
+ /* resume port */
+ sc->sc_hprt_val |= HPRT_PRTRES;
+ DWC_OTG_WRITE_4(sc, DOTG_HPRT, sc->sc_hprt_val);
+ /* Wait 100ms for resume signalling to complete. */
+ usb_pause_mtx(&sc->sc_bus.bus_mtx, hz / 10);
+ /* clear suspend and resume */
+ sc->sc_hprt_val &= ~(HPRT_PRTSUSP | HPRT_PRTRES);
+ /* Wait 4ms */
+ usb_pause_mtx(&sc->sc_bus.bus_mtx, hz / 250);
+ /* need to fake resume IRQ */
+ dwc_otg_resume_irq(sc);
+static void
+dwc_otg_set_address(struct dwc_otg_softc *sc, uint8_t addr)
+ uint32_t temp;
+ DPRINTFN(5, "addr=%d\n", addr);
+ temp = DWC_OTG_READ_4(sc, DOTG_DCFG);
+ temp &= ~DCFG_DEVADDR_SET(0x7F);
+ temp |= DCFG_DEVADDR_SET(addr);
+ DWC_OTG_WRITE_4(sc, DOTG_DCFG, temp);
+static void
+dwc_otg_common_rx_ack(struct dwc_otg_softc *sc)
+ DPRINTFN(5, "RX status clear\n");
+ /* enable RX FIFO level interrupt */
+ sc->sc_irq_mask |= GINTMSK_RXFLVLMSK;
+ /* clear cached status */
+ sc->sc_last_rx_status = 0;
+static void
+dwc_otg_clear_hcint(struct dwc_otg_softc *sc, uint8_t x)
+ uint32_t hcint;
+ /* clear all pending interrupts */
+ hcint = DWC_OTG_READ_4(sc, DOTG_HCINT(x));
+ DWC_OTG_WRITE_4(sc, DOTG_HCINT(x), hcint);
+ /* clear buffered interrupts */
+ sc->sc_chan_state[x].hcint = 0;
+static uint8_t
+dwc_otg_host_channel_alloc(struct dwc_otg_softc *sc, struct dwc_otg_td
*td, uint8_t is_out)
+ uint32_t tx_p_size;
+ uint32_t tx_np_size;
+ uint8_t x;
+ if (td->channel < DWC_OTG_MAX_CHANNELS)
+ return (0); /* already allocated */
+ /* check if device is suspended */
+ if (DWC_OTG_PC2UDEV(td->pc)->flags.self_suspended != 0)
+ return (1); /* busy - cannot transfer data */
+ /* compute needed TX FIFO size */
+ if (is_out != 0) {
+ if (td->ep_type == UE_ISOCHRONOUS) {
+ tx_p_size = td->max_packet_size;
+ tx_np_size = 0;
+ if (td->hcsplt != 0 && tx_p_size > HCSPLT_XACTLEN_BURST)
+ tx_p_size = HCSPLT_XACTLEN_BURST;
+ if ((sc->sc_tx_cur_p_level + tx_p_size) > sc->sc_tx_max_size) {
+ DPRINTF("Too little FIFO space\n");
+ return (1); /* too little FIFO */
+ } else {
+ tx_p_size = 0;
+ tx_np_size = td->max_packet_size;
+ if (td->hcsplt != 0 && tx_np_size > HCSPLT_XACTLEN_BURST)
+ tx_np_size = HCSPLT_XACTLEN_BURST;
+ if ((sc->sc_tx_cur_np_level + tx_np_size) >
+ } else {
+ /* not a TX transaction */
+ tx_p_size = 0;
+ tx_np_size = 0;
+ if (sc->sc_chan_state[x].allocated != 0)
+ continue;
+ /* check if channel is still enabled */
+ if (sc->sc_chan_state[x].wait_sof != 0)
+ continue;
+ sc->sc_chan_state[x].allocated = 1;
+ sc->sc_chan_state[x].tx_p_size = tx_p_size;
+ sc->sc_chan_state[x].tx_np_size = tx_np_size;
+ /* keep track of used TX FIFO, if any */
+ sc->sc_tx_cur_p_level += tx_p_size;
+ sc->sc_tx_cur_np_level += tx_np_size;
+ /* clear interrupts */
+ dwc_otg_clear_hcint(sc, x);
+ DPRINTF("CH=%d HCCHAR=0x%08x "
+ "HCSPLT=0x%08x\n", x, td->hcchar, td->hcsplt);
+ /* set active channel */
+ sc->sc_active_rx_ep |= (1 << x);
+ /* set channel */
+ td->channel = x;
+ return (0); /* allocated */
+ /* wait a bit */
+ dwc_otg_enable_sof_irq(sc);
+ return (1); /* busy */
+static void
+dwc_otg_host_channel_free(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ uint8_t x;
+ if (td->channel >= DWC_OTG_MAX_CHANNELS)
+ return; /* already freed */
+ /* free channel */
+ x = td->channel;
+ td->channel = DWC_OTG_MAX_CHANNELS;
+ DPRINTF("CH=%d\n", x);
+ * We need to let programmed host channels run till complete
+ * else the host channel will stop functioning. Assume that
+ * after a fixed given amount of time the host channel is no
+ * longer doing any USB traffic:
+ /* double buffered */
+ sc->sc_chan_state[x].wait_sof = DWC_OTG_SLOT_IDLE_MAX;
+ } else {
+ /* single buffered */
+ sc->sc_chan_state[x].wait_sof = DWC_OTG_SLOT_IDLE_MIN;
+ sc->sc_chan_state[x].allocated = 0;
+ /* ack any pending messages */
+ if (sc->sc_last_rx_status != 0 &&
+ GRXSTSRD_CHNUM_GET(sc->sc_last_rx_status) == x) {
+ dwc_otg_common_rx_ack(sc);
+ /* clear active channel */
+ sc->sc_active_rx_ep &= ~(1 << x);
+static void
+dwc_otg_host_dump_rx(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ /* dump any pending messages */
+ if (sc->sc_last_rx_status != 0) {
+ if (td->channel < DWC_OTG_MAX_CHANNELS &&
+ td->channel == GRXSTSRD_CHNUM_GET(sc->sc_last_rx_status)) {
+static uint8_t
+dwc_otg_host_setup_tx(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ struct usb_device_request req __aligned(4);
+ uint32_t hcint;
+ uint32_t hcchar;
+ uint8_t delta;
+ dwc_otg_host_dump_rx(sc, td);
+ if (td->channel < DWC_OTG_MAX_CHANNELS) {
+ hcint = sc->sc_chan_state[td->channel].hcint;
+ DPRINTF("CH=%d ST=%d HCINT=0x%08x HCCHAR=0x%08x HCTSIZ=0x%08x\n",
+ td->channel, td->state, hcint,
+ DWC_OTG_READ_4(sc, DOTG_HCCHAR(td->channel)),
+ DWC_OTG_READ_4(sc, DOTG_HCTSIZ(td->channel)));
+ } else {
+ hcint = 0;
+ goto check_state;
+ if (hcint & (HCINT_RETRY |
+ HCINT_ACK | HCINT_NYET)) {
+ /* give success bits priority over failure bits */
+ } else if (hcint & HCINT_STALL) {
+ DPRINTF("CH=%d STALL\n", td->channel);
+ td->error_stall = 1;
+ td->error_any = 1;
+ goto complete;
+ } else if (hcint & HCINT_ERRORS) {
+ DPRINTF("CH=%d ERROR\n", td->channel);
+ td->errcnt++;
+ if (td->hcsplt != 0 || td->errcnt >= 3) {
+ goto complete;
+ if (hcint & (HCINT_ERRORS | HCINT_RETRY |
+ if (!(hcint & HCINT_ERRORS))
+ td->errcnt = 0;
+check_state:
+ switch (td->state) {
+ case DWC_CHAN_ST_START:
+ goto send_pkt;
+ case DWC_CHAN_ST_WAIT_ANE:
+ if (hcint & (HCINT_RETRY | HCINT_ERRORS)) {
+ td->did_nak++;
+ td->tt_scheduled = 0;
+ goto send_pkt;
+ } else if (hcint & (HCINT_ACK | HCINT_NYET)) {
+ td->offset += td->tx_bytes;
+ td->remainder -= td->tx_bytes;
+ td->toggle = 1;
+ goto complete;
+ break;
+ case DWC_CHAN_ST_WAIT_S_ANE:
+ td->did_nak++;
+ goto send_pkt;
+ goto send_cpkt;
+ break;
+ case DWC_CHAN_ST_WAIT_C_ANE:
+ if (hcint & HCINT_NYET) {
+ goto send_cpkt;
+ } else if (hcint & (HCINT_RETRY | HCINT_ERRORS)) {
+ td->did_nak++;
+ goto send_pkt;
+ } else if (hcint & HCINT_ACK) {
+ td->toggle = 1;
+ goto complete;
+ break;
+ case DWC_CHAN_ST_WAIT_C_PKT:
+ goto send_cpkt;
+ default:
+ break;
+ goto busy;
+send_pkt:
+ /* free existing channel, if any */
+ dwc_otg_host_channel_free(sc, td);
+ if (sizeof(req) != td->remainder) {
+ goto complete;
+ if (td->hcsplt != 0) {
+ delta = td->tt_start_slot - sc->sc_last_frame_num - 1;
+ if (td->tt_scheduled == 0 || delta < DWC_OTG_TT_SLOT_MAX) {
+ td->state = DWC_CHAN_ST_START;
+ goto busy;
+ delta = sc->sc_last_frame_num - td->tt_start_slot;
+ if (delta > 5) {
+ /* missed it */
+ goto busy;
+ /* allocate a new channel */
+ if (dwc_otg_host_channel_alloc(sc, td, 1)) {
+ goto busy;
+ td->hcsplt &= ~HCSPLT_COMPSPLT;
+ td->state = DWC_CHAN_ST_WAIT_S_ANE;
+ } else {
+ td->state = DWC_CHAN_ST_WAIT_ANE;
+ usbd_copy_out(td->pc, 0, &req, sizeof(req));
+ DWC_OTG_WRITE_4(sc, DOTG_HCTSIZ(td->channel),
+ (sizeof(req) << HCTSIZ_XFERSIZE_SHIFT) |
+ (1 << HCTSIZ_PKTCNT_SHIFT) |
+ (HCTSIZ_PID_SETUP << HCTSIZ_PID_SHIFT));
+ DWC_OTG_WRITE_4(sc, DOTG_HCSPLT(td->channel), td->hcsplt);
+ hcchar = td->hcchar;
+ hcchar &= ~(HCCHAR_EPDIR_IN | HCCHAR_EPTYPE_MASK);
+ hcchar |= UE_CONTROL << HCCHAR_EPTYPE_SHIFT;
+ /* must enable channel before writing data to FIFO */
+ DWC_OTG_WRITE_4(sc, DOTG_HCCHAR(td->channel), hcchar);
+ /* transfer data into FIFO */
+ bus_space_write_region_4(sc->sc_io_tag, sc->sc_io_hdl,
+ DOTG_DFIFO(td->channel), (uint32_t *)&req, sizeof(req) / 4);
+ /* wait until next slot before trying complete split */
+ td->tt_complete_slot = sc->sc_last_frame_num + 1;
+ /* store number of bytes transmitted */
+ td->tx_bytes = sizeof(req);
+ goto busy;
+send_cpkt:
+ delta = td->tt_complete_slot - sc->sc_last_frame_num - 1;
+ td->state = DWC_CHAN_ST_WAIT_C_PKT;
+ goto busy;
+ if (delta > DWC_OTG_TT_SLOT_MAX) {
+ /* we missed the service interval */
+ if (td->ep_type != UE_ISOCHRONOUS)
+ goto complete;
+ if (dwc_otg_host_channel_alloc(sc, td, 0)) {
+ goto busy;
+ td->hcsplt |= HCSPLT_COMPSPLT;
+ td->state = DWC_CHAN_ST_WAIT_C_ANE;
+busy:
+complete:
+ return (0); /* complete */
+static uint8_t
+dwc_otg_setup_rx(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ uint32_t temp;
+ uint16_t count;
+ /* check endpoint status */
+ if (sc->sc_last_rx_status == 0)
+ goto not_complete;
+ if (GRXSTSRD_CHNUM_GET(sc->sc_last_rx_status) != 0)
+ if ((sc->sc_last_rx_status & GRXSTSRD_DPID_MASK) !=
+ GRXSTSRD_DPID_DATA0) {
+ /* release FIFO */
+ if ((sc->sc_last_rx_status & GRXSTSRD_PKTSTS_MASK) !=
+ GRXSTSRD_STP_DATA) {
+ DPRINTFN(5, "GRXSTSR=0x%08x\n", sc->sc_last_rx_status);
+ /* clear did stall */
+ td->did_stall = 0;
+ /* get the packet byte count */
+ count = GRXSTSRD_BCNT_GET(sc->sc_last_rx_status);
+ /* verify data length */
+ if (count != td->remainder) {
+ DPRINTFN(0, "Invalid SETUP packet "
+ "length, %d bytes\n", count);
+ if (count != sizeof(req)) {
+ DPRINTFN(0, "Unsupported SETUP packet "
+ /* copy in control request */
+ memcpy(&req, sc->sc_rx_bounce_buffer, sizeof(req));
+ /* copy data into real buffer */
+ usbd_copy_in(td->pc, 0, &req, sizeof(req));
+ td->offset = sizeof(req);
+ td->remainder = 0;
+ /* sneak peek the set address */
+ if ((req.bmRequestType == UT_WRITE_DEVICE) &&
+ (req.bRequest == UR_SET_ADDRESS)) {
+ /* must write address before ZLP */
+ dwc_otg_set_address(sc, req.wValue[0] & 0x7F);
+ /* don't send any data by default */
+ DWC_OTG_WRITE_4(sc, DOTG_DIEPTSIZ(0),
+ DXEPTSIZ_SET_NPKT(0) |
+ DXEPTSIZ_SET_NBYTES(0));
+ temp = sc->sc_in_ctl[0];
+ /* enable IN endpoint */
+ DWC_OTG_WRITE_4(sc, DOTG_DIEPCTL(0),
+ temp | DIEPCTL_EPENA);
+ temp | DIEPCTL_SNAK);
+ /* reset IN endpoint buffer */
+ GRSTCTL_TXFIFO(0) |
+ GRSTCTL_TXFFLSH);
+ /* acknowledge RX status */
+not_complete:
+ /* abort any ongoing transfer, before enabling again */
+ temp = sc->sc_out_ctl[0];
+ temp |= DOEPCTL_EPENA |
+ DOEPCTL_SNAK;
+ /* enable OUT endpoint */
+ DWC_OTG_WRITE_4(sc, DOTG_DOEPCTL(0), temp);
+ if (!td->did_stall) {
+ td->did_stall = 1;
+ DPRINTFN(5, "stalling IN and OUT direction\n");
+ /* set stall after enabling endpoint */
+ temp | DOEPCTL_STALL);
+ /* set stall assuming endpoint is enabled */
+ temp | DIEPCTL_STALL);
+ /* setup number of buffers to receive */
+ DWC_OTG_WRITE_4(sc, DOTG_DOEPTSIZ(0),
+ DXEPTSIZ_SET_MULTI(3) |
+ DXEPTSIZ_SET_NPKT(1) |
+ DXEPTSIZ_SET_NBYTES(sizeof(req)));
+ return (1); /* not complete */
+static uint8_t
+dwc_otg_host_rate_check_interrupt(struct dwc_otg_softc *sc, struct
dwc_otg_td *td)
+ uint8_t delta;
+ delta = sc->sc_tmr_val - td->tmr_val;
+ if (delta >= 128)
+ td->tmr_val = sc->sc_tmr_val + td->tmr_res;
+ /* set toggle, if any */
+ if (td->set_toggle) {
+ td->set_toggle = 0;
+ td->toggle = 1;
+ return (0);
+static uint8_t
+dwc_otg_host_rate_check(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ /* non TT isochronous traffic */
+ if ((td->tmr_val != 0) ||
+ (sc->sc_last_frame_num & (td->tmr_res - 1))) {
+ goto busy;
+ td->tmr_val = 1; /* executed */
+ td->toggle = 0;
+ } else if (td->ep_type == UE_INTERRUPT) {
+ if (!td->tt_scheduled)
+ goto busy;
+ } else if (td->did_nak >= DWC_OTG_NAK_MAX) {
+ goto busy;
+ } else if (td->set_toggle) {
+ td->toggle = 1;
+ return (0);
+busy:
+ return (1);
+static uint8_t
+dwc_otg_host_data_rx_sub(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ uint32_t count;
+ uint8_t channel;
+ goto busy;
+ channel = td->channel;
+ if (channel >= DWC_OTG_MAX_CHANNELS)
+ goto busy;
+ if (GRXSTSRD_CHNUM_GET(sc->sc_last_rx_status) != channel)
+ goto busy;
+ switch (sc->sc_last_rx_status & GRXSTSRD_PKTSTS_MASK) {
+ case GRXSTSRH_IN_DATA:
+ DPRINTF("DATA ST=%d STATUS=0x%08x\n",
+ (int)td->state, (int)sc->sc_last_rx_status);
+ if (sc->sc_chan_state[channel].hcint & HCINT_SOFTWARE_ONLY) {
+ * When using SPLIT transactions on interrupt
+ * endpoints, sometimes data occurs twice.
+ DPRINTF("Data already received\n");
+ break;
+ /* check for isochronous transfer or high-speed bandwidth endpoint
+ if (td->ep_type == UE_ISOCHRONOUS || td->max_packet_count > 1) {
+ td->tt_xactpos = HCSPLT_XACTPOS_MIDDLE;
+ } else {
+ td->tt_xactpos = HCSPLT_XACTPOS_BEGIN;
+ /* verify the packet byte count */
+ if (count < td->max_packet_size) {
+ /* we have a short packet */
+ td->short_pkt = 1;
+ td->got_short = 1;
+ td->toggle = 0;
+ } else {
+ if (count != td->max_packet_size) {
+ } else {
+ /* invalid USB packet */
+ goto complete;
+ td->toggle ^= 1;
+ if (count > td->remainder) {
+ goto complete;
+ usbd_copy_in(td->pc, td->offset,
+ sc->sc_rx_bounce_buffer, count);
+ td->remainder -= count;
+ td->offset += count;
+ sc->sc_chan_state[channel].hcint |= HCINT_SOFTWARE_ONLY;
+ break;
+ default:
+ break;
+busy:
+ return (0);
+complete:
+ return (1);
+static uint8_t
+dwc_otg_host_data_rx(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ uint32_t hcint;
+ uint32_t hcchar;
+ uint8_t delta;
+ uint8_t channel;
+ if (channel < DWC_OTG_MAX_CHANNELS) {
+ hcint = sc->sc_chan_state[channel].hcint;
+ channel, td->state, hcint,
+ DWC_OTG_READ_4(sc, DOTG_HCCHAR(channel)),
+ DWC_OTG_READ_4(sc, DOTG_HCTSIZ(channel)));
+ /* check interrupt bits */
+ DPRINTF("CH=%d STALL\n", channel);
+ goto complete;
+ DPRINTF("CH=%d ERROR\n", channel);
+ td->errcnt++;
+ if (td->ep_type != UE_ISOCHRONOUS) {
+ goto complete;
+ /* check channels for data, if any */
+ if (dwc_otg_host_data_rx_sub(sc, td))
+ goto complete;
+ /* refresh interrupt status */
+ td->errcnt = 0;
+ } else {
+ hcint = 0;
+ goto receive_spkt;
+ else
+ goto receive_pkt;
+ if (td->ep_type == UE_INTERRUPT) {
+ * The USB specification does not
+ * mandate a particular data toggle
+ * value for USB INTERRUPT
+ * transfers. Switch the data toggle
+ * value to receive the packet
+ * correctly:
+ if (hcint & HCINT_DATATGLERR) {
+ DPRINTF("Retrying packet due to "
+ "data toggle error\n");
+ td->toggle ^= 1;
+ goto receive_pkt;
+ td->did_nak++;
+ else
+ goto receive_pkt;
+ } else if (hcint & HCINT_NYET) {
+ /* try again */
+ goto receive_pkt;
+ } else {
+ /* not a valid token for IN endpoints */
+ goto complete;
+ /* wait for data - ACK arrived first */
+ if (!(hcint & HCINT_SOFTWARE_ONLY))
+ goto busy;
+ /* check if we are complete */
+ if ((td->remainder == 0) ||
+ (td->tt_xactpos == HCSPLT_XACTPOS_BEGIN)) {
+ goto complete;
+ /* get another packet */
+ goto receive_pkt;
+ } else {
+ if ((td->remainder == 0) || (td->got_short != 0)) {
+ if (td->short_pkt)
+ goto complete;
+ * Else need to receive a zero length
+ * packet.
+ td->did_nak = 0;
+ else
+ goto receive_pkt;
+ break;
+ * NOTE: The DWC OTG hardware provides a fake ACK in
+ * case of interrupt and isochronous transfers:
+ td->did_nak++;
+ td->did_nak = 0;
+ goto receive_pkt;
+ break;
+ goto receive_pkt;
+ default:
+ break;
+ goto busy;
+receive_pkt:
+ goto busy;
+ goto complete;
+ /* complete split */
+ } else if (td->tt_xactpos == HCSPLT_XACTPOS_BEGIN &&
+ dwc_otg_host_rate_check(sc, td)) {
+ goto busy;
+ goto busy;
+ td->toggle = 1;
+ /* receive one packet */
+ DWC_OTG_WRITE_4(sc, DOTG_HCTSIZ(channel),
+ (td->max_packet_size << HCTSIZ_XFERSIZE_SHIFT) |
+ (td->toggle ? (HCTSIZ_PID_DATA1 << HCTSIZ_PID_SHIFT) :
+ (HCTSIZ_PID_DATA0 << HCTSIZ_PID_SHIFT)));
+ DWC_OTG_WRITE_4(sc, DOTG_HCSPLT(channel), td->hcsplt);
+ hcchar |= HCCHAR_EPDIR_IN;
+ /* receive complete split ASAP */
+ if ((sc->sc_last_frame_num & 1) != 0)
+ hcchar |= HCCHAR_ODDFRM;
+ else
+ hcchar &= ~HCCHAR_ODDFRM;
+ /* must enable channel before data can be received */
+ DWC_OTG_WRITE_4(sc, DOTG_HCCHAR(channel), hcchar);
+ goto busy;
+receive_spkt:
+ /* free existing channel(s), if any */
+ goto busy;
+ if (delta > 5) {
+ /* missed it */
+ goto busy;
+ goto busy;
+ (HCTSIZ_PID_DATA0 << HCTSIZ_PID_SHIFT));
+ /* send after next SOF event */
+ if ((sc->sc_last_frame_num & 1) == 0)
+ td->hcchar |= HCCHAR_ODDFRM;
+ else
+ td->hcchar &= ~HCCHAR_ODDFRM;
+busy:
+complete:
+static uint8_t
+dwc_otg_data_rx(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ uint32_t temp;
+ uint16_t count;
+ uint8_t got_short;
+ got_short = 0;
+ if (GRXSTSRD_CHNUM_GET(sc->sc_last_rx_status) != td->ep_no)
+ /* check for SETUP packet */
+ if ((sc->sc_last_rx_status & GRXSTSRD_PKTSTS_MASK) ==
+ if (td->remainder == 0) {
+ * We are actually complete and have
+ * received the next SETUP
+ DPRINTFN(5, "faking complete\n");
+ * USB Host Aborted the transfer.
+ GRXSTSRD_OUT_DATA) {
+ got_short = 1;
+ } else {
+ return (0); /* we are complete */
+ usbd_copy_in(td->pc, td->offset, sc->sc_rx_bounce_buffer, count);
+ temp = sc->sc_out_ctl[td->ep_no];
+ /* check for isochronous mode */
+ if ((temp & DIEPCTL_EPTYPE_MASK) ==
+ (DIEPCTL_EPTYPE_ISOC << DIEPCTL_EPTYPE_SHIFT)) {
+ /* toggle odd or even frame bit */
+ if (temp & DIEPCTL_SETD1PID) {
+ temp &= ~DIEPCTL_SETD1PID;
+ temp |= DIEPCTL_SETD0PID;
+ } else {
+ temp &= ~DIEPCTL_SETD0PID;
+ temp |= DIEPCTL_SETD1PID;
+ sc->sc_out_ctl[td->ep_no] = temp;
+ if ((td->remainder == 0) || got_short) {
+ if (td->short_pkt) {
+ /* we are complete */
+ return (0);
+ /* else need to receive a zero length packet */
+not_complete:
+ temp |= DOEPCTL_EPENA | DOEPCTL_CNAK;
+ DWC_OTG_WRITE_4(sc, DOTG_DOEPCTL(td->ep_no), temp);
+ /* enable SETUP and transfer complete interrupt */
+ if (td->ep_no == 0) {
+ DXEPTSIZ_SET_NBYTES(td->max_packet_size));
+ } else {
+ /* allow reception of multiple packets */
+ DWC_OTG_WRITE_4(sc, DOTG_DOEPTSIZ(td->ep_no),
+ DXEPTSIZ_SET_MULTI(1) |
+ DXEPTSIZ_SET_NPKT(4) |
+ DXEPTSIZ_SET_NBYTES(4 *
+ ((td->max_packet_size + 3) & ~3)));
+static uint8_t
+dwc_otg_host_data_tx(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ uint32_t count;
+ uint32_t hcint;
+ uint32_t hcchar;
+ uint8_t delta;
+ uint8_t channel;
+ goto complete;
+ td->errcnt++;
+ goto complete;
+ td->errcnt = 0;
+ } else {
+ hcint = 0;
+ goto send_pkt;
+ td->did_nak++;
+ goto send_pkt;
+ td->toggle ^= 1;
+ td->did_nak = 0;
+ /* check remainder */
+ goto complete;
+ * Else we need to transmit a short
+ * packet:
+ goto send_pkt;
+ break;
+ td->did_nak++;
+ goto send_pkt;
+ td->did_nak = 0;
+ goto send_cpkt;
+ break;
+ goto send_cpkt;
+ td->did_nak++;
+ goto send_pkt;
+ td->toggle ^= 1;
+ td->did_nak = 0;
+ goto complete;
+ /* else we need to transmit a short packet */
+ goto send_pkt;
+ break;
+ goto send_cpkt;
+ case DWC_CHAN_ST_TX_WAIT_ISOC:
+ /* Check if isochronous OUT traffic is complete */
+ if ((hcint & HCINT_HCH_DONE_MASK) == 0)
+ break;
+ if (td->hcsplt != 0 || td->remainder == 0)
+ goto complete;
+ /* check for next packet */
+ if (td->max_packet_count > 1)
+ td->tt_xactpos++;
+ td->state = DWC_CHAN_ST_TX_PKT_ISOC;
+ /* FALLTHROUGH */
+ case DWC_CHAN_ST_TX_PKT_ISOC:
+ break;
+ goto send_isoc_pkt;
+ default:
+ break;
+ goto busy;
+send_pkt:
+ goto busy;
+ if (delta > 5) {
+ /* missed it */
+ goto busy;
+ } else if (dwc_otg_host_rate_check(sc, td)) {
+ goto busy;
+ goto busy;
+ td->toggle = 1;
+send_isoc_pkt:
+ /* Isochronous OUT transfers don't have any ACKs */
+ td->state = DWC_CHAN_ST_TX_WAIT_ISOC;
+ /* get maximum transfer length */
+ count = td->remainder;
+ if (count > HCSPLT_XACTLEN_BURST) {
+ DPRINTF("TT overflow\n");
+ goto complete;
+ /* Update transaction position */
+ td->hcsplt &= ~HCSPLT_XACTPOS_MASK;
+ td->hcsplt |= (HCSPLT_XACTPOS_ALL << HCSPLT_XACTPOS_SHIFT);
+ } else {
+ /* send one packet at a time */
+ count = td->max_packet_size;
+ if (td->remainder < count) {
+ } else if (td->hcsplt != 0) {
+ /* Wait for ACK/NAK/ERR from TT */
+ } else {
+ /* Wait for ACK/NAK/STALL from device */
+ /* check for High-Speed multi-packets */
+ if ((td->hcsplt == 0) && (td->max_packet_count > 1)) {
+ if (td->npkt == 0) {
+ if (td->remainder >= (3 * td->max_packet_size))
+ td->npkt = 3;
+ else if (td->remainder >= (2 * td->max_packet_size))
+ td->npkt = 2;
+ else
+ td->npkt = 1;
+ if (td->npkt > td->max_packet_count)
+ td->npkt = td->max_packet_count;
+ td->tt_xactpos = 1; /* overload */
+ if (td->tt_xactpos == td->npkt) {
+ if (td->npkt == 1) {
+ (count << HCTSIZ_XFERSIZE_SHIFT) |
+ } else if (td->npkt == 2) {
+ (HCTSIZ_PID_DATA1 << HCTSIZ_PID_SHIFT));
+ } else {
+ (HCTSIZ_PID_DATA2 << HCTSIZ_PID_SHIFT));
+ td->npkt = 0;
+ } else {
+ (HCTSIZ_PID_MDATA << HCTSIZ_PID_SHIFT));
+ } else {
+ /* TODO: HCTSIZ_DOPNG */
+ hcchar &= ~HCCHAR_EPDIR_IN;
+ else
+ /* must enable before writing data to FIFO */
+ if (count != 0) {
+ /* clear topmost word before copy */
+ sc->sc_tx_bounce_buffer[(count - 1) / 4] = 0;
+ /* copy out data */
+ usbd_copy_out(td->pc, td->offset,
+ sc->sc_tx_bounce_buffer, count);
+ DOTG_DFIFO(channel),
+ sc->sc_tx_bounce_buffer, (count + 3) / 4);
+ td->tx_bytes = count;
+ goto busy;
+send_cpkt:
+ goto busy;
+ goto complete;
+ goto busy;
+ else
+busy:
+complete:
+static uint8_t
+dwc_otg_data_tx(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ uint32_t max_buffer;
+ uint32_t count;
+ uint32_t fifo_left;
+ uint32_t mpkt;
+ uint32_t temp;
+ uint8_t to;
+ to = 3; /* don't loop forever! */
+ max_buffer = sc->sc_hw_ep_profile[td->ep_no].max_buffer;
+repeat:
+ /* check for for endpoint 0 data */
+ temp = sc->sc_last_rx_status;
+ if ((td->ep_no == 0) && (temp != 0) &&
+ (GRXSTSRD_CHNUM_GET(temp) == 0)) {
+ if ((temp & GRXSTSRD_PKTSTS_MASK) !=
+ /* dump data - wrong direction */
+ } else {
+ * The current transfer was cancelled
+ * by the USB Host:
+ /* fill in more TX data, if possible */
+ if (td->tx_bytes != 0) {
+ uint16_t cpkt;
+ /* check if packets have been transferred */
+ temp = DWC_OTG_READ_4(sc, DOTG_DIEPTSIZ(td->ep_no));
+ /* get current packet number */
+ cpkt = DXEPTSIZ_GET_NPKT(temp);
+ if (cpkt >= td->npkt) {
+ fifo_left = 0;
+ } else {
+ if (max_buffer != 0) {
+ fifo_left = (td->npkt - cpkt) *
+ td->max_packet_size;
+ if (fifo_left > max_buffer)
+ fifo_left = max_buffer;
+ } else {
+ fifo_left = td->max_packet_size;
+ count = td->tx_bytes;
+ if (count > fifo_left)
+ count = fifo_left;
+ if (count != 0) {
+ DOTG_DFIFO(td->ep_no),
+ td->tx_bytes -= count;
+ td->npkt = cpkt;
+ if (!to--)
+ /* check if not all packets have been transferred */
+ if (DXEPTSIZ_GET_NPKT(temp) != 0) {
+ DPRINTFN(5, "busy ep=%d npkt=%d DIEPTSIZ=0x%08x "
+ "DIEPCTL=0x%08x\n", td->ep_no,
+ DXEPTSIZ_GET_NPKT(temp),
+ temp, DWC_OTG_READ_4(sc, DOTG_DIEPCTL(td->ep_no)));
+ DPRINTFN(5, "rem=%u ep=%d\n", td->remainder, td->ep_no);
+ /* try to optimise by sending more data */
+ if ((max_buffer != 0) && ((td->max_packet_size & 3) == 0)) {
+ /* send multiple packets at the same time */
+ mpkt = max_buffer / td->max_packet_size;
+ if (mpkt > 0x3FE)
+ mpkt = 0x3FE;
+ if (count > 0x7FFFFF)
+ count = 0x7FFFFF - (0x7FFFFF % td->max_packet_size);
+ td->npkt = count / td->max_packet_size;
+ * NOTE: We could use 0x3FE instead of "mpkt" in the
+ * check below to get more throughput, but then we
+ * have a dependency towards non-generic chip features
+ * to disable the TX-FIFO-EMPTY interrupts on a per
+ * endpoint basis. Increase the maximum buffer size of
+ * the IN endpoint to increase the performance.
+ if (td->npkt > mpkt) {
+ td->npkt = mpkt;
+ count = td->max_packet_size * mpkt;
+ } else if ((count == 0) || (count % td->max_packet_size)) {
+ /* we are transmitting a short packet */
+ td->npkt++;
+ } else {
+ mpkt = 1;
+ td->npkt = 1;
+ DWC_OTG_WRITE_4(sc, DOTG_DIEPTSIZ(td->ep_no),
+ DXEPTSIZ_SET_NPKT(td->npkt) |
+ DXEPTSIZ_SET_NBYTES(count));
+ /* make room for buffering */
+ td->npkt += mpkt;
+ temp = sc->sc_in_ctl[td->ep_no];
+ } else {
+ sc->sc_in_ctl[td->ep_no] = temp;
+ DWC_OTG_WRITE_4(sc, DOTG_DIEPCTL(td->ep_no), temp |
+ DIEPCTL_EPENA | DIEPCTL_CNAK);
+ if (td->tx_bytes == 0 &&
+ td->remainder == 0) {
+ goto repeat;
+not_complete:
+static uint8_t
+dwc_otg_data_tx_sync(struct dwc_otg_softc *sc, struct dwc_otg_td *td)
+ uint32_t temp;
+ * If all packets are transferred we are complete:
+ /* check that all packets have been transferred */
+ DPRINTFN(5, "busy ep=%d\n", td->ep_no);
+ return (0);
+not_complete:
+ /* we only want to know if there is a SETUP packet or free IN packet */
+ if ((temp & GRXSTSRD_PKTSTS_MASK) ==
+ * Race condition: We are complete!
+ return (0);
+ } else {
+static void
+dwc_otg_xfer_do_fifo(struct dwc_otg_softc *sc, struct usb_xfer *xfer)
+ struct dwc_otg_td *td;
+ uint8_t toggle;
+ uint8_t tmr_val;
+ uint8_t tmr_res;
+ DPRINTFN(9, "\n");
+ td = xfer->td_transfer_cache;
+ if (td == NULL)
+ return;
+ while (1) {
+ if ((td->func) (sc, td)) {
+ /* operation in progress */
+ break;
+ if (((void *)td) == xfer->td_transfer_last) {
+ goto done;
+ if (td->error_any) {
+ goto done;
+ } else if (td->remainder > 0) {
+ * We had a short transfer. If there is no alternate
+ * next, stop processing !
+ if (!td->alt_next)
+ goto done;
+ * Fetch the next transfer descriptor and transfer
+ * some flags to the next transfer descriptor
+ tmr_res = td->tmr_res;
+ tmr_val = td->tmr_val;
+ toggle = td->toggle;
+ td = td->obj_next;
+ xfer->td_transfer_cache = td;
+ td->toggle = toggle; /* transfer toggle */
+ td->tmr_res = tmr_res;
+ td->tmr_val = tmr_val;
+ return;
+done:
+ xfer->td_transfer_cache = NULL;
+ sc->sc_xfer_complete = 1;
+static uint8_t
+dwc_otg_xfer_do_complete_locked(struct dwc_otg_softc *sc, struct usb_xfer
*xfer)
+ if (td == NULL) {
+ /* compute all actual lengths */
+ dwc_otg_standard_done(xfer);
+ return (1);
+ return (0);
+static void
+dwc_otg_timer(void *_sc)
+ struct dwc_otg_softc *sc = _sc;
+ struct usb_xfer *xfer;
+ USB_BUS_LOCK_ASSERT(&sc->sc_bus, MA_OWNED);
+ DPRINTF("\n");
+ USB_BUS_SPIN_LOCK(&sc->sc_bus);
+ /* increment timer value */
+ sc->sc_tmr_val++;
+ TAILQ_FOREACH(xfer, &sc->sc_bus.intr_q.head, wait_entry) {
+ if (td != NULL) {
+ /* reset NAK counter */
+ td->did_nak = 0;
+ /* enable SOF interrupt, which will poll jobs */
+ USB_BUS_SPIN_UNLOCK(&sc->sc_bus);
+ if (sc->sc_timer_active) {
+ /* restart timer */
+ usb_callout_reset(&sc->sc_timer,
+ hz / (1000 / DWC_OTG_HOST_TIMER_RATE),
+ &dwc_otg_timer, sc);
+static void
+dwc_otg_timer_start(struct dwc_otg_softc *sc)
+ if (sc->sc_timer_active != 0)
+ return;
+ sc->sc_timer_active = 1;
+static void
+dwc_otg_timer_stop(struct dwc_otg_softc *sc)
+ if (sc->sc_timer_active == 0)
+ return;
+ sc->sc_timer_active = 0;
+ /* stop timer */
+ usb_callout_stop(&sc->sc_timer);
+static void
+dwc_otg_host_channel_disable(struct dwc_otg_softc *sc, uint8_t x)
+ uint32_t hcchar;
+ hcchar = DWC_OTG_READ_4(sc, DOTG_HCCHAR(x));
+ /* disable host channel, if any */
+ if (hcchar & (HCCHAR_CHENA | HCCHAR_CHDIS)) {
+ /* disable channel */
+ DWC_OTG_WRITE_4(sc, DOTG_HCCHAR(x),
+ HCCHAR_CHENA | HCCHAR_CHDIS);
+ /* wait for chip to get its brains in order */
+ sc->sc_chan_state[x].wait_sof = 2;
+ /* release TX FIFO usage, if any */
+ sc->sc_tx_cur_p_level -= sc->sc_chan_state[x].tx_p_size;
+ sc->sc_tx_cur_np_level -= sc->sc_chan_state[x].tx_np_size;
+ /* don't release TX FIFO usage twice */
+ sc->sc_chan_state[x].tx_p_size = 0;
+ sc->sc_chan_state[x].tx_np_size = 0;
+static uint16_t
+dwc_otg_compute_isoc_rx_tt_slot(struct dwc_otg_tt_info *pinfo)
+ if (pinfo->slot_index < DWC_OTG_TT_SLOT_MAX)
+ pinfo->slot_index++;
+ return (pinfo->slot_index);
+static uint8_t
+dwc_otg_update_host_transfer_schedule_locked(struct dwc_otg_softc *sc)
+ TAILQ_HEAD(, usb_xfer) head;
+ struct usb_xfer *xfer_next;
+ uint16_t temp;
+ uint16_t slot;
+ uint8_t x;
+ temp = DWC_OTG_READ_4(sc, DOTG_HFNUM) & DWC_OTG_FRAME_MASK;
+ if (sc->sc_last_frame_num == temp)
+ return (0);
+ sc->sc_last_frame_num = temp;
+ TAILQ_INIT(&head);
+ continue;
+ sc->sc_needsof = 1;
+ if (--(sc->sc_chan_state[x].wait_sof) == 0)
+ if ((temp & 7) == 0) {
+ /* reset the schedule */
+ memset(sc->sc_tt_info, 0, sizeof(sc->sc_tt_info));
+ TAILQ_FOREACH_SAFE(xfer, &sc->sc_bus.intr_q.head, wait_entry,
xfer_next) {
+ if (td == NULL || td->ep_type != UE_ISOCHRONOUS)
+ continue;
+ /* check for IN direction */
+ if ((td->hcchar & HCCHAR_EPDIR_IN) != 0)
+ continue;
+ /* execute more frames */
+ td->tmr_val = 0;
+ if (td->hcsplt == 0 || td->tt_scheduled != 0)
+ continue;
+ /* compute slot */
+ slot = dwc_otg_compute_isoc_rx_tt_slot(
+ sc->sc_tt_info + td->tt_index);
+ if (slot > 3) {
+ * Not enough time to get complete
+ * split executed.
+ continue;
+ /* Delayed start */
+ td->tt_start_slot = temp + slot;
+ td->tt_scheduled = 1;
+ TAILQ_REMOVE(&sc->sc_bus.intr_q.head, xfer, wait_entry);
+ TAILQ_INSERT_TAIL(&head, xfer, wait_entry);
xfer_next) {
+ continue;
+ /* check for OUT direction */
+ if ((td->hcchar & HCCHAR_EPDIR_IN) == 0)
+ continue;
+ td->tmr_val = 0;
+ continue;
+ /* Start ASAP */
+ td->tt_start_slot = temp;
xfer_next) {
+ if (td == NULL || td->ep_type != UE_INTERRUPT)
+ continue;
+ if (td->tt_scheduled != 0) {
+ continue;
+ if (dwc_otg_host_rate_check_interrupt(sc, td))
+ continue;
+ if (td->hcsplt == 0) {
+ continue;
+ /* start ASAP */
xfer_next) {
+ if (td == NULL ||
+ td->ep_type != UE_CONTROL ||
+ td->did_nak >= DWC_OTG_NAK_MAX) {
+ continue;
+ continue;
+ /* start ASAP */
+ if ((temp & 7) < 6) {
xfer_next) {
+ if (td == NULL ||
+ td->ep_type != UE_BULK ||
+ continue;
+ continue;
+ /* start ASAP */
+ /* Put TT transfers in execution order at the end */
+ TAILQ_CONCAT(&sc->sc_bus.intr_q.head, &head, wait_entry);
+ /* move all TT transfers in front, keeping the current order */
xfer_next) {
+ if (td == NULL || td->hcsplt == 0)
+ continue;
+ TAILQ_CONCAT(&head, &sc->sc_bus.intr_q.head, wait_entry);
+ /* put non-TT BULK transfers last */
xfer_next) {
+ if (td == NULL || td->hcsplt != 0 || td->ep_type != UE_BULK)
+ continue;
+ DPRINTFN(12, "SOF interrupt #%d, needsof=%d\n",
+ (int)temp, (int)sc->sc_needsof);
+ /* update SOF IRQ mask */
+ if (sc->sc_irq_mask & GINTMSK_SOFMSK) {
+ if (sc->sc_needsof == 0) {
+ sc->sc_irq_mask &= ~GINTMSK_SOFMSK;
+ } else {
+ if (sc->sc_needsof != 0) {
+ /* clear need SOF flag */
+ sc->sc_needsof = 0;
+ return (1);
+static void
+dwc_otg_interrupt_poll_locked(struct dwc_otg_softc *sc)
+ uint32_t temp;
+ uint8_t got_rx_status;
+ uint8_t x;
+repeat:
+ /* get all channel interrupts */
+ temp = DWC_OTG_READ_4(sc, DOTG_HCINT(x));
+ if (temp != 0) {
+ DWC_OTG_WRITE_4(sc, DOTG_HCINT(x), temp);
+ temp &= ~HCINT_SOFTWARE_ONLY;
+ sc->sc_chan_state[x].hcint |= temp;
+ if (sc->sc_last_rx_status == 0) {
+ temp = DWC_OTG_READ_4(sc, DOTG_GINTSTS);
+ if (temp & GINTSTS_RXFLVL) {
+ /* pop current status */
+ DWC_OTG_READ_4(sc, DOTG_GRXSTSPD);
+ uint8_t ep_no;
+ temp = sc->sc_last_rx_status &
+ GRXSTSRD_PKTSTS_MASK;
+ /* non-data messages we simply skip */
+ if (temp != GRXSTSRD_STP_DATA &&
+ temp != GRXSTSRD_OUT_DATA) {
+ goto repeat;
+ temp = GRXSTSRD_BCNT_GET(
+ sc->sc_last_rx_status);
+ ep_no = GRXSTSRD_CHNUM_GET(
+ /* receive data, if any */
+ if (temp != 0) {
+ DPRINTF("Reading %d bytes from ep %d\n", temp, ep_no);
+ bus_space_read_region_4(sc->sc_io_tag, sc->sc_io_hdl,
+ DOTG_DFIFO(ep_no),
+ sc->sc_rx_bounce_buffer, (temp + 3) / 4);
+ /* check if we should dump the data */
+ if (!(sc->sc_active_rx_ep & (1U << ep_no))) {
+ goto repeat;
+ got_rx_status = 1;
+ DPRINTFN(5, "RX status = 0x%08x: ch=%d pid=%d bytes=%d
sts=%d\n",
+ sc->sc_last_rx_status, ep_no,
+ (sc->sc_last_rx_status >> 15) & 3,
+ GRXSTSRD_BCNT_GET(sc->sc_last_rx_status),
+ (sc->sc_last_rx_status >> 17) & 15);
+ } else {
+ got_rx_status = 0;
+ } else {
+ uint8_t ep_no;
+ goto repeat;
+ /* execute FIFOs */
+ dwc_otg_xfer_do_fifo(sc, xfer);
+ if (got_rx_status) {
+ /* check if data was consumed */
+ goto repeat;
+ /* disable RX FIFO level interrupt */
+ sc->sc_irq_mask &= ~GINTMSK_RXFLVLMSK;
+ if (sc->sc_flags.status_device_mode == 0 && sc->sc_xfer_complete == 0)
+ /* update host transfer schedule, so that new transfers can be
issued */
+ if (dwc_otg_update_host_transfer_schedule_locked(sc))
+ goto repeat;
+static void
+dwc_otg_interrupt_complete_locked(struct dwc_otg_softc *sc)
+repeat:
+ /* scan for completion events */
+ if (dwc_otg_xfer_do_complete_locked(sc, xfer))
+ goto repeat;
+static void
+dwc_otg_vbus_interrupt(struct dwc_otg_softc *sc, uint8_t is_on)
+ DPRINTFN(5, "vbus = %u\n", is_on);
+ * If the USB host mode is forced, then assume VBUS is always
+ * present else rely on the input to this function:
+ if ((is_on != 0) || (sc->sc_mode == DWC_MODE_HOST)) {
+ if (!sc->sc_flags.status_vbus) {
+ sc->sc_flags.status_vbus = 1;
+ } else {
+ if (sc->sc_flags.status_vbus) {
+ sc->sc_flags.status_vbus = 0;
+ sc->sc_flags.status_bus_reset = 0;
+ sc->sc_flags.change_suspend = 0;
+ sc->sc_flags.change_connect = 1;
+int
+dwc_otg_filter_interrupt(void *arg)
+ struct dwc_otg_softc *sc = arg;
+ int retval = FILTER_HANDLED;
+ uint32_t status;
+ /* read and clear interrupt status */
+ status = DWC_OTG_READ_4(sc, DOTG_GINTSTS);
+ /* clear interrupts we are handling here */
+ DWC_OTG_WRITE_4(sc, DOTG_GINTSTS, status &
~DWC_OTG_MSK_GINT_THREAD_IRQ);
+ /* check for USB state change interrupts */
+ if ((status & DWC_OTG_MSK_GINT_THREAD_IRQ) != 0)
+ retval = FILTER_SCHEDULE_THREAD;
+ /* clear all IN endpoint interrupts */
+ if (status & GINTSTS_IEPINT) {
+ uint32_t temp;
+ uint8_t x;
+ for (x = 0; x != sc->sc_dev_in_ep_max; x++) {
+ temp = DWC_OTG_READ_4(sc, DOTG_DIEPINT(x));
+ if (temp & DIEPMSK_XFERCOMPLMSK) {
+ DWC_OTG_WRITE_4(sc, DOTG_DIEPINT(x),
+ DIEPMSK_XFERCOMPLMSK);
+ /* poll FIFOs, if any */
+ dwc_otg_interrupt_poll_locked(sc);
+ if (sc->sc_xfer_complete != 0)
+ return (retval);
+void
+dwc_otg_interrupt(void *arg)
+ uint32_t status;
+ USB_BUS_LOCK(&sc->sc_bus);
+ DPRINTFN(14, "GINTSTS=0x%08x HAINT=0x%08x HFNUM=0x%08x\n",
+ status, DWC_OTG_READ_4(sc, DOTG_HAINT),
+ DWC_OTG_READ_4(sc, DOTG_HFNUM));
+ if (status & GINTSTS_USBRST) {
+ /* set correct state */
+ sc->sc_flags.status_device_mode = 1;
+ /* Disable SOF interrupt */
+ /* check for any bus state change interrupts */
+ if (status & GINTSTS_ENUMDONE) {
+ uint32_t temp;
+ DPRINTFN(5, "end of reset\n");
+ sc->sc_flags.status_bus_reset = 1;
+ sc->sc_flags.status_low_speed = 0;
+ sc->sc_flags.port_enabled = 1;
+ /* reset FIFOs */
+ (void) dwc_otg_init_fifo(sc, DWC_MODE_DEVICE);
+ /* reset function address */
+ dwc_otg_set_address(sc, 0);
+ /* figure out enumeration speed */
+ temp = DWC_OTG_READ_4(sc, DOTG_DSTS);
+ if (DSTS_ENUMSPD_GET(temp) == DSTS_ENUMSPD_HI)
+ sc->sc_flags.status_high_speed = 1;
+ else
+ sc->sc_flags.status_high_speed = 0;
+ * Disable resume and SOF interrupt, and enable
+ * suspend and RX frame interrupt:
+ sc->sc_irq_mask &= ~(GINTMSK_WKUPINTMSK | GINTMSK_SOFMSK);
+ if (status & GINTSTS_PRTINT) {
+ uint32_t hprt;
+ hprt = DWC_OTG_READ_4(sc, DOTG_HPRT);
+ /* clear change bits */
+ DWC_OTG_WRITE_4(sc, DOTG_HPRT, (hprt & (
+ HPRT_PRTPWR | HPRT_PRTENCHNG |
+ HPRT_PRTCONNDET | HPRT_PRTOVRCURRCHNG)) |
+ sc->sc_hprt_val);
+ DPRINTFN(12, "GINTSTS=0x%08x, HPRT=0x%08x\n", status, hprt);
+ sc->sc_flags.status_device_mode = 0;
+ if (hprt & HPRT_PRTCONNSTS)
+ else
+ if (hprt & HPRT_PRTENCHNG)
+ sc->sc_flags.change_enabled = 1;
+ if (hprt & HPRT_PRTENA)
+ else
+ sc->sc_flags.port_enabled = 0;
+ if (hprt & HPRT_PRTOVRCURRCHNG)
+ sc->sc_flags.change_over_current = 1;
+ if (hprt & HPRT_PRTOVRCURRACT)
+ sc->sc_flags.port_over_current = 1;
+ else
+ sc->sc_flags.port_over_current = 0;
+ if (hprt & HPRT_PRTPWR)
+ sc->sc_flags.port_powered = 1;
+ else
+ sc->sc_flags.port_powered = 0;
+ if (((hprt & HPRT_PRTSPD_MASK)
+ >> HPRT_PRTSPD_SHIFT) == HPRT_PRTSPD_LOW)
+ sc->sc_flags.status_low_speed = 1;
+ else
+ >> HPRT_PRTSPD_SHIFT) == HPRT_PRTSPD_HIGH)
+ else
+ if (hprt & HPRT_PRTCONNDET)
+ if (hprt & HPRT_PRTSUSP)
+ dwc_otg_suspend_irq(sc);
+ else
+ /* update host frame interval */
+ dwc_otg_update_host_frame_interval(sc);
+ * If resume and suspend is set at the same time we interpret
+ * that like RESUME. Resume is set when there is at least 3
+ * milliseconds of inactivity on the USB BUS.
+ if (status & GINTSTS_WKUPINT) {
+ DPRINTFN(5, "resume interrupt\n");
+ } else if (status & GINTSTS_USBSUSP) {
+ DPRINTFN(5, "suspend interrupt\n");
+ /* check VBUS */
+ if (status & (GINTSTS_USBSUSP |
+ GINTSTS_USBRST |
+ GINTSTS_SESSREQINT)) {
+ uint32_t temp;
+ temp = DWC_OTG_READ_4(sc, DOTG_GOTGCTL);
+ DPRINTFN(5, "GOTGCTL=0x%08x\n", temp);
+ dwc_otg_vbus_interrupt(sc,
+ (temp & (GOTGCTL_ASESVLD | GOTGCTL_BSESVLD)) ? 1 : 0);
+ if (sc->sc_xfer_complete != 0) {
+ sc->sc_xfer_complete = 0;
+ /* complete FIFOs, if any */
+ dwc_otg_interrupt_complete_locked(sc);
+ if (sc->sc_flags.status_device_mode == 0) {
issued */
+ USB_BUS_UNLOCK(&sc->sc_bus);
+static void
+dwc_otg_setup_standard_chain_sub(struct dwc_otg_std_temp *temp)
+ /* get current Transfer Descriptor */
+ td = temp->td_next;
+ temp->td = td;
+ /* prepare for next TD */
+ temp->td_next = td->obj_next;
+ /* fill out the Transfer Descriptor */
+ td->func = temp->func;
+ td->pc = temp->pc;
+ td->offset = temp->offset;
+ td->remainder = temp->len;
+ td->tx_bytes = 0;
+ td->error_any = 0;
+ td->error_stall = 0;
+ td->npkt = 0;
+ td->did_stall = temp->did_stall;
+ td->short_pkt = temp->short_pkt;
+ td->alt_next = temp->setup_alt_next;
+ td->got_short = 0;
+ td->did_nak = 0;
+ td->state = 0;
+ td->errcnt = 0;
+static void
+dwc_otg_setup_standard_chain(struct usb_xfer *xfer)
+ struct dwc_otg_std_temp temp;
+ uint32_t x;
+ uint8_t need_sync;
+ uint8_t is_host;
+ DPRINTFN(9, "addr=%d endpt=%d sumlen=%d speed=%d\n",
+ xfer->address, UE_GET_ADDR(xfer->endpointno),
+ xfer->sumlen, usbd_get_speed(xfer->xroot->udev));
+ temp.max_frame_size = xfer->max_frame_size;
+ td = xfer->td_start[0];
+ xfer->td_transfer_first = td;
+ /* setup temp */
+ temp.pc = NULL;
+ temp.td = NULL;
+ temp.td_next = xfer->td_start[0];
+ temp.offset = 0;
+ temp.setup_alt_next = xfer->flags_int.short_frames_ok ||
+ xfer->flags_int.isochronous_xfr;
+ temp.did_stall = !xfer->flags_int.control_stall;
+ is_host = (xfer->xroot->udev->flags.usb_mode == USB_MODE_HOST);
+ /* check if we should prepend a setup message */
+ if (xfer->flags_int.control_xfr) {
+ if (xfer->flags_int.control_hdr) {
+ if (is_host)
+ temp.func = &dwc_otg_host_setup_tx;
+ else
+ temp.func = &dwc_otg_setup_rx;
+ temp.len = xfer->frlengths[0];
+ temp.pc = xfer->frbuffers + 0;
+ temp.short_pkt = temp.len ? 1 : 0;
+ /* check for last frame */
+ if (xfer->nframes == 1) {
+ /* no STATUS stage yet, SETUP is last */
+ if (xfer->flags_int.control_act)
+ temp.setup_alt_next = 0;
+ dwc_otg_setup_standard_chain_sub(&temp);
+ x = 1;
+ } else {
+ x = 0;
+ if (x != xfer->nframes) {
+ if (xfer->endpointno & UE_DIR_IN) {
+ if (is_host) {
+ temp.func = &dwc_otg_host_data_rx;
+ need_sync = 0;
+ } else {
+ temp.func = &dwc_otg_data_tx;
+ need_sync = 1;
+ } else {
+ if (is_host) {
+ temp.func = &dwc_otg_host_data_tx;
+ need_sync = 0;
+ } else {
+ temp.func = &dwc_otg_data_rx;
+ need_sync = 0;
+ /* setup "pc" pointer */
+ temp.pc = xfer->frbuffers + x;
+ } else {
+ need_sync = 0;
+ while (x != xfer->nframes) {
+ /* DATA0 / DATA1 message */
+ temp.len = xfer->frlengths[x];
+ x++;
+ if (x == xfer->nframes) {
+ if (xfer->flags_int.control_act) {
+ } else {
+ if (temp.len == 0) {
+ /* make sure that we send an USB packet */
+ temp.short_pkt = 0;
+ } else {
+ /* regular data transfer */
+ temp.short_pkt = (xfer->flags.force_short_xfer ? 0 : 1);
+ if (xfer->flags_int.isochronous_xfr) {
+ temp.offset += temp.len;
+ } else {
+ /* get next Page Cache pointer */
+ /* always setup a valid "pc" pointer for status and sync */
+ temp.len = 0;
+ /* check if we need to sync */
+ if (need_sync) {
+ /* we need a SYNC point after TX */
+ temp.func = &dwc_otg_data_tx_sync;
+ /* check if we should append a status stage */
+ if (!xfer->flags_int.control_act) {
+ * Send a DATA1 message and invert the current
+ * endpoint direction.
+ if (is_host) {
+ need_sync = 0;
+ } else {
+ need_sync = 0;
+ } else {
+ if (is_host) {
+ need_sync = 0;
+ } else {
+ need_sync = 1;
+ /* data toggle should be DATA1 */
+ td = temp.td;
+ td->set_toggle = 1;
+ if (need_sync) {
+ } else {
+ if (need_sync) {
+ temp.len = 0;
+ /* must have at least one frame! */
+ td = temp.td;
+ xfer->td_transfer_last = td;
+ if (is_host) {
+ uint32_t hcchar;
+ uint32_t hcsplt;
+ sc = DWC_OTG_BUS2SC(xfer->xroot->bus);
+ /* get first again */
+ td = xfer->td_transfer_first;
+ td->toggle = (xfer->endpoint->toggle_next ? 1 : 0);
+ hcchar =
+ (xfer->address << HCCHAR_DEVADDR_SHIFT) |
+ ((xfer->endpointno & UE_ADDR) << HCCHAR_EPNUM_SHIFT) |
+ (xfer->max_packet_size << HCCHAR_MPS_SHIFT) |
+ HCCHAR_CHENA;
+ * We are not always able to meet the timing
+ * requirements of the USB interrupt endpoint's
+ * complete split token, when doing transfers going
+ * via a transaction translator. Use the CONTROL
+ * transfer type instead of the INTERRUPT transfer
+ * type in general, as a means to workaround
+ * that. This trick should work for both FULL and LOW
+ * speed USB traffic going through a TT. For non-TT
+ * traffic it works aswell. The reason for using
+ * CONTROL type instead of BULK is that some TTs might
+ * reject LOW speed BULK traffic.
+ hcchar |= (UE_CONTROL << HCCHAR_EPTYPE_SHIFT);
+ else
+ hcchar |= (td->ep_type << HCCHAR_EPTYPE_SHIFT);
+ if (usbd_get_speed(xfer->xroot->udev) == USB_SPEED_LOW)
+ hcchar |= HCCHAR_LSPDDEV;
+ if (UE_GET_DIR(xfer->endpointno) == UE_DIR_IN)
+ switch (xfer->xroot->udev->speed) {
+ case USB_SPEED_FULL:
+ case USB_SPEED_LOW:
+ /* check if root HUB port is running High Speed */
+ if (xfer->xroot->udev->parent_hs_hub != NULL) {
+ hcsplt = HCSPLT_SPLTENA |
+ (xfer->xroot->udev->hs_port_no <<
+ HCSPLT_PRTADDR_SHIFT) |
+ (xfer->xroot->udev->hs_hub_addr <<
+ HCSPLT_HUBADDR_SHIFT);
+ } else {
+ hcsplt = 0;
+ uint32_t ival;
+ ival = xfer->interval / DWC_OTG_HOST_TIMER_RATE;
+ if (ival == 0)
+ ival = 1;
+ else if (ival > 127)
+ ival = 127;
+ td->tmr_val = sc->sc_tmr_val + ival;
+ td->tmr_res = ival;
+ } else if (td->ep_type == UE_ISOCHRONOUS) {
+ td->tmr_val = 0;
+ td->tmr_res = 1;
+ } else {
+ td->tmr_val = 0;
+ td->tmr_res = 0;
+ break;
+ case USB_SPEED_HIGH:
+ hcsplt = 0;
+ uint32_t ival;
+#if 0
+ hcchar |= ((xfer->max_packet_count & 3)
+ << HCCHAR_MC_SHIFT);
+#endif
+ if (ival == 0)
+ ival = 1;
+ ival = 127;
+ td->tmr_val = 0;
+ td->tmr_res = 1 << usbd_xfer_get_fps_shift(xfer);
+ } else {
+ td->tmr_val = 0;
+ td->tmr_res = 0;
+ break;
+ default:
+ hcsplt = 0;
+ td->tmr_val = 0;
+ td->tmr_res = 0;
+ break;
+ /* store configuration in all TD's */
+ while (1) {
+ td->hcchar = hcchar;
+ td->hcsplt = hcsplt;
+ break;
+static void
+dwc_otg_timeout(void *arg)
+ struct usb_xfer *xfer = arg;
+ DPRINTF("xfer=%p\n", xfer);
+ USB_BUS_LOCK_ASSERT(xfer->xroot->bus, MA_OWNED);
+ /* transfer is transferred */
+ dwc_otg_device_done(xfer, USB_ERR_TIMEOUT);
+static void
+dwc_otg_start_standard_chain(struct usb_xfer *xfer)
+ struct dwc_otg_softc *sc = DWC_OTG_BUS2SC(xfer->xroot->bus);
+ struct usb_xfer_root *xroot;
+ * Poll one time in device mode, which will turn on the
+ * endpoint interrupts. Else wait for SOF interrupt in host
+ * mode.
+ if (sc->sc_flags.status_device_mode != 0) {
+ goto done;
+ /* put transfer on interrupt queue */
+ usbd_transfer_enqueue(&xfer->xroot->bus->intr_q, xfer);
+ /* start timeout, if any */
+ if (xfer->timeout != 0) {
+ usbd_transfer_timeout_ms(xfer,
+ &dwc_otg_timeout, xfer->timeout);
+ goto done;
+ /* enable SOF interrupt, if any */
+ if (td->ep_type != UE_BULK)
+ goto done;
+ xroot = xfer->xroot;
+ * Optimise the ping-pong effect by waking up other BULK
+ * transfers belonging to the same device group:
+ if (td == NULL || td->ep_type != UE_BULK || xfer->xroot != xroot)
+ continue;
+ td->did_nak = 0;
+done:
+static void
+dwc_otg_root_intr(struct dwc_otg_softc *sc)
+ /* set port bit */
+ sc->sc_hub_idata[0] = 0x02; /* we only have one port */
+ uhub_root_intr(&sc->sc_bus, sc->sc_hub_idata,
+ sizeof(sc->sc_hub_idata));
+static usb_error_t
+dwc_otg_standard_done_sub(struct usb_xfer *xfer)
+ uint32_t len;
+ usb_error_t error;
+ do {
+ len = td->remainder;
+ /* store last data toggle */
+ xfer->endpoint->toggle_next = td->toggle;
+ if (xfer->aframes != xfer->nframes) {
+ * Verify the length and subtract
+ * the remainder from "frlengths[]":
+ if (len > xfer->frlengths[xfer->aframes]) {
+ } else {
+ xfer->frlengths[xfer->aframes] -= len;
+ /* Check for transfer error */
+ /* the transfer is finished */
+ error = (td->error_stall ?
+ USB_ERR_STALLED : USB_ERR_IOERROR);
+ td = NULL;
+ break;
+ /* Check for short transfer */
+ if (len > 0) {
+ if (xfer->flags_int.short_frames_ok ||
+ xfer->flags_int.isochronous_xfr) {
+ /* follow alt next */
+ if (td->alt_next) {
+ } else {
+ td = NULL;
+ } else {
+ td = NULL;
+ error = 0;
+ break;
+ /* this USB frame is complete */
+ error = 0;
+ break;
+ } while (0);
+ /* update transfer cache */
+ return (error);
+static void
+dwc_otg_standard_done(struct usb_xfer *xfer)
+ usb_error_t err = 0;
+ DPRINTFN(13, "xfer=%p endpoint=%p transfer done\n",
+ xfer, xfer->endpoint);
+ /* reset scanner */
+ xfer->td_transfer_cache = xfer->td_transfer_first;
+ err = dwc_otg_standard_done_sub(xfer);
+ xfer->aframes = 1;
+ if (xfer->td_transfer_cache == NULL) {
+ goto done;
+ while (xfer->aframes != xfer->nframes) {
+ xfer->aframes++;
+ goto done;
+ if (xfer->flags_int.control_xfr &&
+ !xfer->flags_int.control_act) {
+done:
+ dwc_otg_device_done(xfer, err);
+ * dwc_otg_device_done
+ * NOTE: this function can be called more than one time on the
+ * same USB transfer!
+static void
+dwc_otg_device_done(struct usb_xfer *xfer, usb_error_t error)
+ DPRINTFN(9, "xfer=%p, endpoint=%p, error=%d\n",
+ xfer, xfer->endpoint, error);
+ if (xfer->flags_int.usb_mode == USB_MODE_DEVICE) {
+ /* Interrupts are cleared by the interrupt handler */
+ } else {
+ if (td != NULL)
+ /* dequeue transfer and start next transfer */
+ usbd_transfer_done(xfer, error);
+static void
+dwc_otg_xfer_stall(struct usb_xfer *xfer)
+ dwc_otg_device_done(xfer, USB_ERR_STALLED);
+#ifndef __rtems__
+static void
+dwc_otg_set_stall(struct usb_device *udev,
+ struct usb_endpoint *ep, uint8_t *did_stall)
+#else
+static void
+dwc_otg_set_stall(struct usb_device *udev, struct usb_xfer *xfer,
+#endif
+ uint32_t temp;
+ uint32_t reg;
+ uint8_t ep_no;
+ USB_BUS_LOCK_ASSERT(udev->bus, MA_OWNED);
+ /* check mode */
+ if (udev->flags.usb_mode != USB_MODE_DEVICE) {
+ /* not supported */
+ return;
+ /* get endpoint address */
+ ep_no = ep->edesc->bEndpointAddress;
+ DPRINTFN(5, "endpoint=0x%x\n", ep_no);
+ if (ep_no & UE_DIR_IN) {
+ reg = DOTG_DIEPCTL(ep_no & UE_ADDR);
+ temp = sc->sc_in_ctl[ep_no & UE_ADDR];
+ } else {
+ reg = DOTG_DOEPCTL(ep_no & UE_ADDR);
+ temp = sc->sc_out_ctl[ep_no & UE_ADDR];
+ /* disable and stall endpoint */
+ DWC_OTG_WRITE_4(sc, reg, temp | DOEPCTL_EPDIS);
+ DWC_OTG_WRITE_4(sc, reg, temp | DOEPCTL_STALL);
+ /* clear active OUT ep */
+ if (!(ep_no & UE_DIR_IN)) {
+ sc->sc_active_rx_ep &= ~(1U << (ep_no & UE_ADDR));
+ (ep_no & UE_ADDR) == GRXSTSRD_CHNUM_GET(
+ sc->sc_last_rx_status)) {
+ /* dump data */
+ /* poll interrupt */
+ #ifdef __rtems__
+ if (xfer != NULL)
+ dwc_otg_xfer_stall(xfer);
+ #endif
+static void
+dwc_otg_clear_stall_sub_locked(struct dwc_otg_softc *sc, uint32_t mps,
+ uint8_t ep_no, uint8_t ep_type, uint8_t ep_dir)
+ uint32_t reg;
+ uint32_t temp;
+ if (ep_type == UE_CONTROL) {
+ /* clearing stall is not needed */
+ return;
+ if (ep_dir) {
+ reg = DOTG_DIEPCTL(ep_no);
+ } else {
+ reg = DOTG_DOEPCTL(ep_no);
+ sc->sc_active_rx_ep |= (1U << ep_no);
+ /* round up and mask away the multiplier count */
+ mps = (mps + 3) & 0x7FC;
+ if (ep_type == UE_BULK) {
+ temp = DIEPCTL_EPTYPE_SET(
+ DIEPCTL_EPTYPE_BULK) |
+ DIEPCTL_USBACTEP;
+ } else if (ep_type == UE_INTERRUPT) {
+ DIEPCTL_EPTYPE_INTERRUPT) |
+ DIEPCTL_USBACTEP;
+ } else {
+ DIEPCTL_EPTYPE_ISOC) |
+ DIEPCTL_USBACTEP;
+ temp |= DIEPCTL_MPS_SET(mps);
+ temp |= DIEPCTL_TXFNUM_SET(ep_no);
+ if (ep_dir)
+ sc->sc_in_ctl[ep_no] = temp;
+ else
+ sc->sc_out_ctl[ep_no] = temp;
+ DWC_OTG_WRITE_4(sc, reg, temp | DOEPCTL_SETD0PID);
+ DWC_OTG_WRITE_4(sc, reg, temp | DIEPCTL_SNAK);
+ /* we only reset the transmit FIFO */
+ if (ep_dir) {
+ GRSTCTL_TXFIFO(ep_no) |
+ GRSTCTL_TXFFLSH);
+ DOTG_DIEPTSIZ(ep_no), 0);
+static void
+dwc_otg_clear_stall(struct usb_device *udev, struct usb_endpoint *ep)
+ struct usb_endpoint_descriptor *ed;
+ DPRINTFN(5, "endpoint=%p\n", ep);
+ /* check mode */
+ return;
+ /* get softc */
+ /* get endpoint descriptor */
+ ed = ep->edesc;
+ /* reset endpoint */
+ dwc_otg_clear_stall_sub_locked(sc,
+ UGETW(ed->wMaxPacketSize),
+ (ed->bEndpointAddress & UE_ADDR),
+ (ed->bmAttributes & UE_XFERTYPE),
+ (ed->bEndpointAddress & (UE_DIR_IN | UE_DIR_OUT)));
+static void
+dwc_otg_device_state_change(struct usb_device *udev)
+ uint8_t x;
+ /* check mode */
+ return;
+ /* get softc */
+ /* deactivate all other endpoint but the control endpoint */
+ if (udev->state == USB_STATE_CONFIGURED ||
+ udev->state == USB_STATE_ADDRESSED) {
+ DWC_OTG_WRITE_4(sc, DOTG_DIEPCTL(x),
+ DIEPCTL_EPDIS);
+ DWC_OTG_WRITE_4(sc, DOTG_DIEPCTL(x), 0);
+ DWC_OTG_WRITE_4(sc, DOTG_DOEPCTL(x),
+ DOEPCTL_EPDIS);
+ DWC_OTG_WRITE_4(sc, DOTG_DOEPCTL(x), 0);
+int
+dwc_otg_init(struct dwc_otg_softc *sc)
+ uint32_t temp;
+ DPRINTF("start\n");
+ /* set up the bus structure */
+ sc->sc_bus.usbrev = USB_REV_2_0;
+ sc->sc_bus.methods = &dwc_otg_bus_methods;
+ usb_callout_init_mtx(&sc->sc_timer,
+ &sc->sc_bus.bus_mtx, 0);
+ /* turn on clocks */
+ dwc_otg_clocks_on(sc);
+ temp = DWC_OTG_READ_4(sc, DOTG_GSNPSID);
+ DPRINTF("Version = 0x%08x\n", temp);
+ /* disconnect */
+ DCTL_SFTDISCON);
+ /* wait for host to detect disconnect */
+ usb_pause_mtx(&sc->sc_bus.bus_mtx, hz / 32);
+ GRSTCTL_CSFTRST);
+ /* wait a little bit for block to reset */
+ usb_pause_mtx(&sc->sc_bus.bus_mtx, hz / 128);
+ switch (sc->sc_mode) {
+ case DWC_MODE_DEVICE:
+ temp = GUSBCFG_FORCEDEVMODE;
+ break;
+ case DWC_MODE_HOST:
+ temp = GUSBCFG_FORCEHOSTMODE;
+ break;
+ default:
+ temp = 0;
+ break;
+ /* select HSIC, ULPI or internal PHY mode */
+ switch (dwc_otg_phy_type) {
+ case DWC_OTG_PHY_HSIC:
+ DWC_OTG_WRITE_4(sc, DOTG_GUSBCFG,
+ GUSBCFG_PHYIF |
+ GUSBCFG_TRD_TIM_SET(5) | temp);
+ DWC_OTG_WRITE_4(sc, DOTG_GOTGCTL,
+ 0x000000EC);
+ temp = DWC_OTG_READ_4(sc, DOTG_GLPMCFG);
+ DWC_OTG_WRITE_4(sc, DOTG_GLPMCFG,
+ temp & ~GLPMCFG_HSIC_CONN);
+ temp | GLPMCFG_HSIC_CONN);
+ break;
+ case DWC_OTG_PHY_ULPI:
+ GUSBCFG_ULPI_UTMI_SEL |
+ DWC_OTG_WRITE_4(sc, DOTG_GOTGCTL, 0);
+ break;
+ case DWC_OTG_PHY_INTERNAL:
+ GUSBCFG_PHYSEL |
+ temp = DWC_OTG_READ_4(sc, DOTG_GGPIO);
+ temp &= ~(DOTG_GGPIO_NOVBUSSENS | DOTG_GGPIO_I2CPADEN);
+ temp |= (DOTG_GGPIO_VBUSASEN | DOTG_GGPIO_VBUSBSEN |
+ DOTG_GGPIO_PWRDWN);
+ DWC_OTG_WRITE_4(sc, DOTG_GGPIO, temp);
+ break;
+ default:
+ break;
+ /* clear global nak */
+ DCTL_CGOUTNAK |
+ DCTL_CGNPINNAK);
+ /* disable USB port */
+ DWC_OTG_WRITE_4(sc, DOTG_PCGCCTL, 0xFFFFFFFF);
+ /* wait 10ms */
+ /* wait 10ms */
+ temp = DWC_OTG_READ_4(sc, DOTG_GHWCFG3);
+ sc->sc_fifo_size = 4 * GHWCFG3_DFIFODEPTH_GET(temp);
+ temp = DWC_OTG_READ_4(sc, DOTG_GHWCFG2);
+ sc->sc_dev_ep_max = GHWCFG2_NUMDEVEPS_GET(temp);
+ if (sc->sc_dev_ep_max > DWC_OTG_MAX_ENDPOINTS)
+ sc->sc_dev_ep_max = DWC_OTG_MAX_ENDPOINTS;
+ sc->sc_host_ch_max = GHWCFG2_NUMHSTCHNL_GET(temp);
+ if (sc->sc_host_ch_max > DWC_OTG_MAX_CHANNELS)
+ sc->sc_host_ch_max = DWC_OTG_MAX_CHANNELS;
+ temp = DWC_OTG_READ_4(sc, DOTG_GHWCFG4);
+ sc->sc_dev_in_ep_max = GHWCFG4_NUM_IN_EP_GET(temp);
+ DPRINTF("Total FIFO size = %d bytes, Device EPs = %d/%d Host CHs =
%d\n",
+ sc->sc_fifo_size, sc->sc_dev_ep_max, sc->sc_dev_in_ep_max,
+ sc->sc_host_ch_max);
+ /* setup FIFO */
+ if (dwc_otg_init_fifo(sc, sc->sc_mode)) {
+ return (EINVAL);
+ /* enable interrupts */
+ sc->sc_irq_mask = DWC_OTG_MSK_GINT_ENABLED;
+ if (sc->sc_mode == DWC_MODE_OTG || sc->sc_mode == DWC_MODE_DEVICE) {
+ /* enable all endpoint interrupts */
+ if (temp & GHWCFG2_MPI) {
+ uint8_t x;
+ DPRINTF("Disable Multi Process Interrupts\n");
+ DWC_OTG_WRITE_4(sc, DOTG_DIEPEACHINTMSK(x), 0);
+ DWC_OTG_WRITE_4(sc, DOTG_DOEPEACHINTMSK(x), 0);
+ DWC_OTG_WRITE_4(sc, DOTG_DEACHINTMSK, 0);
+ DWC_OTG_WRITE_4(sc, DOTG_DIEPMSK,
+ DWC_OTG_WRITE_4(sc, DOTG_DOEPMSK, 0);
+ DWC_OTG_WRITE_4(sc, DOTG_DAINTMSK, 0xFFFF);
+ if (sc->sc_mode == DWC_MODE_OTG || sc->sc_mode == DWC_MODE_HOST) {
+ /* setup clocks */
+ temp = DWC_OTG_READ_4(sc, DOTG_HCFG);
+ temp &= ~(HCFG_FSLSSUPP | HCFG_FSLSPCLKSEL_MASK);
+ temp |= (1 << HCFG_FSLSPCLKSEL_SHIFT);
+ DWC_OTG_WRITE_4(sc, DOTG_HCFG, temp);
+ /* only enable global IRQ */
+ DWC_OTG_WRITE_4(sc, DOTG_GAHBCFG,
+ GAHBCFG_GLBLINTRMSK);
+ /* turn off clocks */
+ dwc_otg_clocks_off(sc);
+ /* read initial VBUS state */
+ DPRINTFN(5, "GOTCTL=0x%08x\n", temp);
+ /* catch any lost interrupts */
+ dwc_otg_do_poll(&sc->sc_bus);
+ return (0); /* success */
+void
+dwc_otg_uninit(struct dwc_otg_softc *sc)
+ /* stop host timer */
+ dwc_otg_timer_stop(sc);
+ /* set disconnect */
+ DCTL_SFTDISCON);
+ /* turn off global IRQ */
+ DWC_OTG_WRITE_4(sc, DOTG_GAHBCFG, 0);
+ dwc_otg_pull_down(sc);
+ usb_callout_drain(&sc->sc_timer);
+static void
+dwc_otg_suspend(struct dwc_otg_softc *sc)
+ return;
+static void
+dwc_otg_resume(struct dwc_otg_softc *sc)
+ return;
+static void
+dwc_otg_do_poll(struct usb_bus *bus)
+ struct dwc_otg_softc *sc = DWC_OTG_BUS2SC(bus);
issued */
+ * DWC OTG bulk support
+ * DWC OTG control support
+ * DWC OTG interrupt support
+static void
+dwc_otg_device_non_isoc_open(struct usb_xfer *xfer)
+static void
+dwc_otg_device_non_isoc_close(struct usb_xfer *xfer)
+ dwc_otg_device_done(xfer, USB_ERR_CANCELLED);
+static void
+dwc_otg_device_non_isoc_enter(struct usb_xfer *xfer)
+static void
+dwc_otg_device_non_isoc_start(struct usb_xfer *xfer)
+ /* setup TDs */
+ dwc_otg_setup_standard_chain(xfer);
+ dwc_otg_start_standard_chain(xfer);
+struct usb_pipe_methods dwc_otg_device_non_isoc_methods =
+ .open = dwc_otg_device_non_isoc_open,
+ .close = dwc_otg_device_non_isoc_close,
+ .enter = dwc_otg_device_non_isoc_enter,
+ .start = dwc_otg_device_non_isoc_start,
+ * DWC OTG full speed isochronous support
+static void
+dwc_otg_device_isoc_open(struct usb_xfer *xfer)
+static void
+dwc_otg_device_isoc_close(struct usb_xfer *xfer)
+static void
+dwc_otg_device_isoc_enter(struct usb_xfer *xfer)
+static void
+dwc_otg_device_isoc_start(struct usb_xfer *xfer)
+ uint32_t temp;
+ uint32_t msframes;
+ uint32_t framenum;
+ uint8_t shift = usbd_xfer_get_fps_shift(xfer);
+ DPRINTFN(6, "xfer=%p next=%d nframes=%d\n",
+ xfer, xfer->endpoint->isoc_next, xfer->nframes);
+ if (xfer->xroot->udev->flags.usb_mode == USB_MODE_HOST) {
+ temp = DWC_OTG_READ_4(sc, DOTG_HFNUM);
+ /* get the current frame index */
+ framenum = (temp & HFNUM_FRNUM_MASK);
+ } else {
+ framenum = DSTS_SOFFN_GET(temp);
+ framenum /= 8;
+ framenum &= DWC_OTG_FRAME_MASK;
+ * Compute number of milliseconds worth of data traffic for
+ * this USB transfer:
+ if (xfer->xroot->udev->speed == USB_SPEED_HIGH)
+ msframes = ((xfer->nframes << shift) + 7) / 8;
+ else
+ msframes = xfer->nframes;
+ * check if the frame index is within the window where the frames
+ * will be inserted
+ temp = (framenum - xfer->endpoint->isoc_next) & DWC_OTG_FRAME_MASK;
+ if ((xfer->endpoint->is_synced == 0) || (temp < msframes)) {
+ * If there is data underflow or the pipe queue is
+ * empty we schedule the transfer a few frames ahead
+ * of the current frame position. Else two isochronous
+ * transfers might overlap.
+ xfer->endpoint->isoc_next = (framenum + 3) & DWC_OTG_FRAME_MASK;
+ xfer->endpoint->is_synced = 1;
+ DPRINTFN(3, "start next=%d\n", xfer->endpoint->isoc_next);
+ * compute how many milliseconds the insertion is ahead of the
+ * current frame position:
+ temp = (xfer->endpoint->isoc_next - framenum) & DWC_OTG_FRAME_MASK;
+ * pre-compute when the isochronous transfer will be finished:
+ xfer->isoc_time_complete =
+ usb_isoc_time_expand(&sc->sc_bus, framenum) + temp + msframes;
+ /* setup TDs */
+ /* compute frame number for next insertion */
+ xfer->endpoint->isoc_next += msframes;
+ /* start TD chain */
+struct usb_pipe_methods dwc_otg_device_isoc_methods =
+ .open = dwc_otg_device_isoc_open,
+ .close = dwc_otg_device_isoc_close,
+ .enter = dwc_otg_device_isoc_enter,
+ .start = dwc_otg_device_isoc_start,
+ * DWC OTG root control support
+ * Simulate a hardware HUB by handling all the necessary requests.
+struct usb_device_descriptor dwc_otg_devd = {
+ .bLength = sizeof(struct usb_device_descriptor),
+ .bDescriptorType = UDESC_DEVICE,
+ .bcdUSB = {0x00, 0x02},
+ .bDeviceClass = UDCLASS_HUB,
+ .bDeviceSubClass = UDSUBCLASS_HUB,
+ .bDeviceProtocol = UDPROTO_HSHUBSTT,
+ .bMaxPacketSize = 64,
+ .bcdDevice = {0x00, 0x01},
+ .iManufacturer = 1,
+ .iProduct = 2,
+ .bNumConfigurations = 1,
+struct dwc_otg_config_desc dwc_otg_confd = {
+ .confd = {
+ .bLength = sizeof(struct usb_config_descriptor),
+ .bDescriptorType = UDESC_CONFIG,
+ .wTotalLength[0] = sizeof(dwc_otg_confd),
+ .bNumInterface = 1,
+ .bConfigurationValue = 1,
+ .iConfiguration = 0,
+ .bmAttributes = UC_SELF_POWERED,
+ .bMaxPower = 0,
+ .ifcd = {
+ .bLength = sizeof(struct usb_interface_descriptor),
+ .bDescriptorType = UDESC_INTERFACE,
+ .bNumEndpoints = 1,
+ .bInterfaceClass = UICLASS_HUB,
+ .bInterfaceSubClass = UISUBCLASS_HUB,
+ .bInterfaceProtocol = 0,
+ .endpd = {
+ .bLength = sizeof(struct usb_endpoint_descriptor),
+ .bDescriptorType = UDESC_ENDPOINT,
+ .bEndpointAddress = (UE_DIR_IN | DWC_OTG_INTR_ENDPT),
+ .bmAttributes = UE_INTERRUPT,
+ .wMaxPacketSize[0] = 8,
+ .bInterval = 255,
+#define HSETW(ptr, val) ptr = { (uint8_t)(val), (uint8_t)((val) >> 8) }
+struct usb_hub_descriptor_min dwc_otg_hubd = {
+ .bDescLength = sizeof(dwc_otg_hubd),
+ .bDescriptorType = UDESC_HUB,
+ .bNbrPorts = 1,
+ HSETW(.wHubCharacteristics, (UHD_PWR_NO_SWITCH | UHD_OC_INDIVIDUAL)),
+ .bPwrOn2PwrGood = 50,
+ .bHubContrCurrent = 0,
+ .DeviceRemovable = {0}, /* port is removable */
+#define STRING_VENDOR \
+ "D\0W\0C\0O\0T\0G"
+#define STRING_PRODUCT \
+ "O\0T\0G\0 \0R\0o\0o\0t\0 \0H\0U\0B"
+USB_MAKE_STRING_DESC(STRING_VENDOR, dwc_otg_vendor);
+USB_MAKE_STRING_DESC(STRING_PRODUCT, dwc_otg_product);
+static usb_error_t
+dwc_otg_roothub_exec(struct usb_device *udev,
+ struct usb_device_request *req, const void **pptr, uint16_t *plength)
+ struct dwc_otg_softc *sc = DWC_OTG_BUS2SC(udev->bus);
+ const void *ptr;
+ uint16_t len;
+ uint16_t value;
+ uint16_t index;
+ usb_error_t err;
+ /* buffer reset */
+ ptr = (const void *)&sc->sc_hub_temp;
+ len = 0;
+ err = 0;
+ value = UGETW(req->wValue);
+ index = UGETW(req->wIndex);
+ /* demultiplex the control request */
+ switch (req->bmRequestType) {
+ case UT_READ_DEVICE:
+ switch (req->bRequest) {
+ case UR_GET_DESCRIPTOR:
+ goto tr_handle_get_descriptor;
+ case UR_GET_CONFIG:
+ goto tr_handle_get_config;
+ case UR_GET_STATUS:
+ goto tr_handle_get_status;
+ default:
+ goto tr_stalled;
+ break;
+ case UT_WRITE_DEVICE:
+ case UR_SET_ADDRESS:
+ goto tr_handle_set_address;
+ case UR_SET_CONFIG:
+ goto tr_handle_set_config;
+ case UR_CLEAR_FEATURE:
+ goto tr_valid; /* nop */
+ case UR_SET_DESCRIPTOR:
+ case UR_SET_FEATURE:
+ default:
+ goto tr_stalled;
+ break;
+ case UT_WRITE_ENDPOINT:
+ switch (UGETW(req->wValue)) {
+ case UF_ENDPOINT_HALT:
+ goto tr_handle_clear_halt;
+ case UF_DEVICE_REMOTE_WAKEUP:
+ goto tr_handle_clear_wakeup;
+ default:
+ goto tr_stalled;
+ break;
+ goto tr_handle_set_halt;
+ goto tr_handle_set_wakeup;
+ default:
+ goto tr_stalled;
+ break;
+ case UR_SYNCH_FRAME:
+ default:
+ goto tr_stalled;
+ break;
+ case UT_READ_ENDPOINT:
+ goto tr_handle_get_ep_status;
+ default:
+ goto tr_stalled;
+ break;
+ case UT_WRITE_INTERFACE:
+ case UR_SET_INTERFACE:
+ goto tr_handle_set_interface;
+ default:
+ goto tr_stalled;
+ break;
+ case UT_READ_INTERFACE:
+ case UR_GET_INTERFACE:
+ goto tr_handle_get_interface;
+ goto tr_handle_get_iface_status;
+ default:
+ goto tr_stalled;
+ break;
+ case UT_WRITE_CLASS_INTERFACE:
+ case UT_WRITE_VENDOR_INTERFACE:
+ /* XXX forward */
+ break;
+ case UT_READ_CLASS_INTERFACE:
+ case UT_READ_VENDOR_INTERFACE:
+ /* XXX forward */
+ break;
+ case UT_WRITE_CLASS_DEVICE:
+ goto tr_valid;
+ break;
+ default:
+ goto tr_stalled;
+ break;
+ case UT_WRITE_CLASS_OTHER:
+ goto tr_handle_clear_port_feature;
+ goto tr_handle_set_port_feature;
+ case UR_CLEAR_TT_BUFFER:
+ case UR_RESET_TT:
+ case UR_STOP_TT:
+ goto tr_valid;
+ default:
+ goto tr_stalled;
+ break;
+ case UT_READ_CLASS_OTHER:
+ case UR_GET_TT_STATE:
+ goto tr_handle_get_tt_state;
+ goto tr_handle_get_port_status;
+ default:
+ goto tr_stalled;
+ break;
+ case UT_READ_CLASS_DEVICE:
+ goto tr_handle_get_class_descriptor;
+ goto tr_handle_get_class_status;
+ default:
+ goto tr_stalled;
+ break;
+ default:
+ goto tr_stalled;
+ goto tr_valid;
+tr_handle_get_descriptor:
+ switch (value >> 8) {
+ case UDESC_DEVICE:
+ if (value & 0xff) {
+ goto tr_stalled;
+ len = sizeof(dwc_otg_devd);
+ ptr = (const void *)&dwc_otg_devd;
+ goto tr_valid;
+ case UDESC_CONFIG:
+ goto tr_stalled;
+ len = sizeof(dwc_otg_confd);
+ ptr = (const void *)&dwc_otg_confd;
+ goto tr_valid;
+ case UDESC_STRING:
+ switch (value & 0xff) {
+ case 0: /* Language table */
+ len = sizeof(usb_string_lang_en);
+ ptr = (const void *)&usb_string_lang_en;
+ goto tr_valid;
+ case 1: /* Vendor */
+ len = sizeof(dwc_otg_vendor);
+ ptr = (const void *)&dwc_otg_vendor;
+ goto tr_valid;
+ case 2: /* Product */
+ len = sizeof(dwc_otg_product);
+ ptr = (const void *)&dwc_otg_product;
+ goto tr_valid;
+ default:
+ break;
+ break;
+ default:
+ goto tr_stalled;
+ goto tr_stalled;
+tr_handle_get_config:
+ len = 1;
+ sc->sc_hub_temp.wValue[0] = sc->sc_conf;
+ goto tr_valid;
+tr_handle_get_status:
+ len = 2;
+ USETW(sc->sc_hub_temp.wValue, UDS_SELF_POWERED);
+ goto tr_valid;
+tr_handle_set_address:
+ if (value & 0xFF00) {
+ goto tr_stalled;
+ sc->sc_rt_addr = value;
+ goto tr_valid;
+tr_handle_set_config:
+ if (value >= 2) {
+ goto tr_stalled;
+ sc->sc_conf = value;
+ goto tr_valid;
+tr_handle_get_interface:
+ len = 1;
+ sc->sc_hub_temp.wValue[0] = 0;
+ goto tr_valid;
+tr_handle_get_tt_state:
+tr_handle_get_class_status:
+tr_handle_get_iface_status:
+tr_handle_get_ep_status:
+ len = 2;
+ USETW(sc->sc_hub_temp.wValue, 0);
+ goto tr_valid;
+tr_handle_set_halt:
+tr_handle_set_interface:
+tr_handle_set_wakeup:
+tr_handle_clear_wakeup:
+tr_handle_clear_halt:
+ goto tr_valid;
+tr_handle_clear_port_feature:
+ if (index != 1)
+ goto tr_stalled;
+ DPRINTFN(9, "UR_CLEAR_PORT_FEATURE on port %d\n", index);
+ switch (value) {
+ case UHF_PORT_SUSPEND:
+ dwc_otg_wakeup_peer(sc);
+ break;
+ case UHF_PORT_ENABLE:
+ sc->sc_hprt_val | HPRT_PRTENA);
+ break;
+ case UHF_C_PORT_RESET:
+ sc->sc_flags.change_reset = 0;
+ break;
+ case UHF_C_PORT_ENABLE:
+ sc->sc_flags.change_enabled = 0;
+ break;
+ case UHF_C_PORT_OVER_CURRENT:
+ sc->sc_flags.change_over_current = 0;
+ break;
+ case UHF_PORT_TEST:
+ case UHF_PORT_INDICATOR:
+ /* nops */
+ break;
+ case UHF_PORT_POWER:
+ if (sc->sc_mode == DWC_MODE_HOST || sc->sc_mode == DWC_MODE_OTG) {
+ sc->sc_hprt_val = 0;
+ DWC_OTG_WRITE_4(sc, DOTG_HPRT, HPRT_PRTENA);
+ break;
+ case UHF_C_PORT_CONNECTION:
+ /* clear connect change flag */
+ sc->sc_flags.change_connect = 0;
+ break;
+ case UHF_C_PORT_SUSPEND:
+ break;
+ default:
+ err = USB_ERR_IOERROR;
+ goto done;
+ goto tr_valid;
+tr_handle_set_port_feature:
+ if (index != 1) {
+ goto tr_stalled;
+ DPRINTFN(9, "UR_SET_PORT_FEATURE\n");
+ switch (value) {
+ break;
+ /* set suspend BIT */
+ sc->sc_hprt_val |= HPRT_PRTSUSP;
+ DWC_OTG_WRITE_4(sc, DOTG_HPRT, sc->sc_hprt_val);
+ /* generate HUB suspend event */
+ break;
+ case UHF_PORT_RESET:
+ DPRINTF("PORT RESET\n");
+ /* enable PORT reset */
+ DWC_OTG_WRITE_4(sc, DOTG_HPRT, sc->sc_hprt_val | HPRT_PRTRST);
+ /* Wait 62.5ms for reset to complete */
+ usb_pause_mtx(&sc->sc_bus.bus_mtx, hz / 16);
+ /* reset FIFOs */
+ (void) dwc_otg_init_fifo(sc, DWC_MODE_HOST);
+ sc->sc_flags.change_reset = 1;
+ } else {
+ break;
+ /* nops */
+ break;
+ sc->sc_hprt_val |= HPRT_PRTPWR;
+ if (sc->sc_mode == DWC_MODE_DEVICE || sc->sc_mode == DWC_MODE_OTG)
+ /* pull up D+, if any */
+ dwc_otg_pull_up(sc);
+ break;
+ default:
+ goto done;
+ goto tr_valid;
+tr_handle_get_port_status:
+ DPRINTFN(9, "UR_GET_PORT_STATUS\n");
+ if (index != 1)
+ goto tr_stalled;
+ else
+ /* Select Device Side Mode */
+ if (sc->sc_flags.status_device_mode) {
+ value = UPS_PORT_MODE_DEVICE;
+ } else {
+ value = 0;
+ dwc_otg_timer_start(sc);
+ if (sc->sc_flags.status_high_speed)
+ value |= UPS_HIGH_SPEED;
+ else if (sc->sc_flags.status_low_speed)
+ value |= UPS_LOW_SPEED;
+ if (sc->sc_flags.port_powered)
+ value |= UPS_PORT_POWER;
+ if (sc->sc_flags.port_enabled)
+ value |= UPS_PORT_ENABLED;
+ if (sc->sc_flags.port_over_current)
+ value |= UPS_OVERCURRENT_INDICATOR;
+ if (sc->sc_flags.status_vbus &&
+ sc->sc_flags.status_bus_reset)
+ value |= UPS_CURRENT_CONNECT_STATUS;
+ if (sc->sc_flags.status_suspend)
+ value |= UPS_SUSPEND;
+ USETW(sc->sc_hub_temp.ps.wPortStatus, value);
+ value = 0;
+ if (sc->sc_flags.change_connect)
+ value |= UPS_C_CONNECT_STATUS;
+ if (sc->sc_flags.change_suspend)
+ value |= UPS_C_SUSPEND;
+ if (sc->sc_flags.change_reset)
+ value |= UPS_C_PORT_RESET;
+ if (sc->sc_flags.change_over_current)
+ value |= UPS_C_OVERCURRENT_INDICATOR;
+ USETW(sc->sc_hub_temp.ps.wPortChange, value);
+ len = sizeof(sc->sc_hub_temp.ps);
+ goto tr_valid;
+tr_handle_get_class_descriptor:
+ if (value & 0xFF) {
+ goto tr_stalled;
+ ptr = (const void *)&dwc_otg_hubd;
+ len = sizeof(dwc_otg_hubd);
+ goto tr_valid;
+tr_stalled:
+ err = USB_ERR_STALLED;
+tr_valid:
+done:
+ *plength = len;
+ *pptr = ptr;
+ return (err);
+static void
+dwc_otg_xfer_setup(struct usb_setup_params *parm)
+ void *last_obj;
+ uint32_t ntd;
+ uint32_t n;
+ uint8_t ep_no;
+ uint8_t ep_type;
+ xfer = parm->curr_xfer;
+ * NOTE: This driver does not use any of the parameters that
+ * are computed from the following values. Just set some
+ * reasonable dummies:
+ parm->hc_max_packet_size = 0x500;
+ parm->hc_max_packet_count = 3;
+ parm->hc_max_frame_size = 3 * 0x500;
+ usbd_transfer_setup_sub(parm);
+ * compute maximum number of TDs
+ ep_type = (xfer->endpoint->edesc->bmAttributes & UE_XFERTYPE);
+ ntd = xfer->nframes + 1 /* STATUS */ + 1 /* SYNC 1 */
+ + 1 /* SYNC 2 */ + 1 /* SYNC 3 */;
+ } else {
+ ntd = xfer->nframes + 1 /* SYNC */ ;
+ * check if "usbd_transfer_setup_sub" set an error
+ if (parm->err)
+ return;
+ * allocate transfer descriptors
+ last_obj = NULL;
+ ep_no = xfer->endpointno & UE_ADDR;
+ * Check for a valid endpoint profile in USB device mode:
+ const struct usb_hw_ep_profile *pf;
+ dwc_otg_get_hw_ep_profile(parm->udev, &pf, ep_no);
+ if (pf == NULL) {
+ /* should not happen */
+ parm->err = USB_ERR_INVAL;
+ return;
+ /* align data */
+ parm->size[0] += ((-parm->size[0]) & (USB_HOST_ALIGN - 1));
+ for (n = 0; n != ntd; n++) {
+ if (parm->buf) {
+ td = USB_ADD_BYTES(parm->buf, parm->size[0]);
+ /* compute shared bandwidth resource index for TT */
+ if (parm->udev->parent_hs_hub != NULL && parm->udev->speed !=
USB_SPEED_HIGH) {
+ if (parm->udev->parent_hs_hub->ddesc.bDeviceProtocol ==
UDPROTO_HSHUBMTT)
+ td->tt_index = parm->udev->device_index;
+ else
+ td->tt_index = parm->udev->parent_hs_hub->device_index;
+ } else {
+ /* init TD */
+ td->max_packet_size = xfer->max_packet_size;
+ td->max_packet_count = xfer->max_packet_count;
+ td->ep_no = ep_no;
+ td->ep_type = ep_type;
+ td->obj_next = last_obj;
+ last_obj = td;
+ parm->size[0] += sizeof(*td);
+ xfer->td_start[0] = last_obj;
+static void
+dwc_otg_xfer_unsetup(struct usb_xfer *xfer)
+ return;
+static void
+dwc_otg_ep_init(struct usb_device *udev, struct usb_endpoint_descriptor
*edesc,
+ struct usb_endpoint *ep)
+ DPRINTFN(2, "endpoint=%p, addr=%d, endpt=%d, mode=%d (%d,%d)\n",
+ ep, udev->address,
+ edesc->bEndpointAddress, udev->flags.usb_mode,
+ sc->sc_rt_addr, udev->device_index);
+ if (udev->device_index != sc->sc_rt_addr) {
+ if (udev->flags.usb_mode == USB_MODE_DEVICE) {
+ if (udev->speed != USB_SPEED_FULL &&
+ udev->speed != USB_SPEED_HIGH) {
+ return;
+ } else {
+ if (udev->speed == USB_SPEED_HIGH) {
+ if ((UGETW(edesc->wMaxPacketSize) >> 11) & 3) {
+ /* high bandwidth endpoint - not tested */
+ DPRINTF("High Bandwidth Endpoint - not tested\n");
+ return;
+ if ((edesc->bmAttributes & UE_XFERTYPE) == UE_ISOCHRONOUS)
+ ep->methods = &dwc_otg_device_isoc_methods;
+ else
+ ep->methods = &dwc_otg_device_non_isoc_methods;
+static void
+dwc_otg_set_hw_power_sleep(struct usb_bus *bus, uint32_t state)
+ switch (state) {
+ case USB_HW_POWER_SUSPEND:
+ dwc_otg_suspend(sc);
+ break;
+ case USB_HW_POWER_SHUTDOWN:
+ dwc_otg_uninit(sc);
+ break;
+ case USB_HW_POWER_RESUME:
+ dwc_otg_resume(sc);
+ break;
+ default:
+ break;
+static void
+dwc_otg_get_dma_delay(struct usb_device *udev, uint32_t *pus)
+ /* DMA delay - wait until any use of memory is finished */
+ *pus = (2125); /* microseconds */
+static void
+dwc_otg_device_resume(struct usb_device *udev)
+ DPRINTF("\n");
+ /* poll all transfers again to restart resumed ones */
+ dwc_otg_do_poll(udev->bus);
+static void
+dwc_otg_device_suspend(struct usb_device *udev)
+ DPRINTF("\n");
+struct usb_bus_methods dwc_otg_bus_methods =
+ .endpoint_init = &dwc_otg_ep_init,
+ .xfer_setup = &dwc_otg_xfer_setup,
+ .xfer_unsetup = &dwc_otg_xfer_unsetup,
+ .get_hw_ep_profile = &dwc_otg_get_hw_ep_profile,
+ #ifndef __rtems__
+ .xfer_stall = &dwc_otg_xfer_stall,
+ #endif
+ .set_stall = &dwc_otg_set_stall,
+ .clear_stall = &dwc_otg_clear_stall,
+ .roothub_exec = &dwc_otg_roothub_exec,
+ .xfer_poll = &dwc_otg_do_poll,
+ .device_state_change = &dwc_otg_device_state_change,
+ .set_hw_power_sleep = &dwc_otg_set_hw_power_sleep,
+ .get_dma_delay = &dwc_otg_get_dma_delay,
+ .device_resume = &dwc_otg_device_resume,
+ .device_suspend = &dwc_otg_device_suspend,
diff --git a/freebsd/sys/dev/usb/controller/dwc_otg.h
b/freebsd/sys/dev/usb/controller/dwc_otg.h
new file mode 100755
index 0000000..52b3b91
--- /dev/null
+++ b/freebsd/sys/dev/usb/controller/dwc_otg.h
@@ -0,0 +1,223 @@
+/* $FreeBSD$ */
+ * Copyright (c) 2012 Hans Petter Selasky. All rights reserved.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY
WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#ifndef _DWC_OTG_H_
+#define _DWC_OTG_H_
+#define DWC_OTG_MAX_DEVICES MIN(USB_MAX_DEVICES, 32)
+#define DWC_OTG_FRAME_MASK 0x7FF
+#define DWC_OTG_MAX_TXP 4
+#define DWC_OTG_MAX_TXN (0x200 * DWC_OTG_MAX_TXP)
+#define DWC_OTG_MAX_CHANNELS 16
+#define DWC_OTG_MAX_ENDPOINTS 16
+#define DWC_OTG_HOST_TIMER_RATE 10 /* ms */
+#define DWC_OTG_TT_SLOT_MAX 8
+#define DWC_OTG_SLOT_IDLE_MAX 3
+#define DWC_OTG_SLOT_IDLE_MIN 2
+#define DWC_OTG_NAK_MAX 8 /* 1 ms */
+#ifndef DWC_OTG_TX_MAX_FIFO_SIZE
+#define DWC_OTG_TX_MAX_FIFO_SIZE DWC_OTG_MAX_TXN
+#endif
+#define DWC_OTG_READ_4(sc, reg) \
+ bus_space_read_4((sc)->sc_io_tag, (sc)->sc_io_hdl, reg)
+#define DWC_OTG_WRITE_4(sc, reg, data) \
+ bus_space_write_4((sc)->sc_io_tag, (sc)->sc_io_hdl, reg, data)
+struct dwc_otg_td;
+struct dwc_otg_softc;
+typedef uint8_t (dwc_otg_cmd_t)(struct dwc_otg_softc *sc, struct
dwc_otg_td *td);
+struct dwc_otg_td {
+ struct dwc_otg_td *obj_next;
+ dwc_otg_cmd_t *func;
+ struct usb_page_cache *pc;
+ uint32_t tx_bytes;
+ uint32_t offset;
+ uint32_t remainder;
+ uint32_t hcchar; /* HOST CFG */
+ uint32_t hcsplt; /* HOST CFG */
+ uint16_t max_packet_size; /* packet_size */
+ uint16_t npkt;
+ uint8_t max_packet_count; /* packet_count */
+ uint8_t errcnt;
+ uint8_t tmr_res;
+ uint8_t tmr_val;
+ uint8_t did_nak; /* NAK counter */
+ uint8_t ep_no;
+ uint8_t ep_type;
+ uint8_t channel;
+ uint8_t tt_index; /* TT data */
+ uint8_t tt_start_slot; /* TT data */
+ uint8_t tt_complete_slot; /* TT data */
+ uint8_t tt_xactpos; /* TT data */
+ uint8_t state;
+#define DWC_CHAN_ST_START 0
+#define DWC_CHAN_ST_WAIT_ANE 1
+#define DWC_CHAN_ST_WAIT_S_ANE 2
+#define DWC_CHAN_ST_WAIT_C_ANE 3
+#define DWC_CHAN_ST_WAIT_C_PKT 4
+#define DWC_CHAN_ST_TX_PKT_ISOC 5
+#define DWC_CHAN_ST_TX_WAIT_ISOC 6
+ uint8_t error_any:1;
+ uint8_t error_stall:1;
+ uint8_t alt_next:1;
+ uint8_t short_pkt:1;
+ uint8_t did_stall:1;
+ uint8_t toggle:1;
+ uint8_t set_toggle:1;
+ uint8_t got_short:1;
+ uint8_t tt_scheduled:1;
+struct dwc_otg_tt_info {
+ uint8_t slot_index;
+struct dwc_otg_std_temp {
+ struct dwc_otg_td *td_next;
+ uint32_t len;
+ uint32_t offset;
+ uint16_t max_frame_size;
+ uint8_t short_pkt;
+ * short_pkt = 0: transfer should be short terminated
+ * short_pkt = 1: transfer should not be short terminated
+ uint8_t setup_alt_next;
+ uint8_t did_stall;
+ uint8_t bulk_or_control;
+struct dwc_otg_config_desc {
+ struct usb_config_descriptor confd;
+ struct usb_interface_descriptor ifcd;
+ struct usb_endpoint_descriptor endpd;
+} __packed;
+union dwc_otg_hub_temp {
+ uWord wValue;
+ struct usb_port_status ps;
+struct dwc_otg_flags {
+ uint8_t change_connect:1;
+ uint8_t change_suspend:1;
+ uint8_t change_reset:1;
+ uint8_t change_enabled:1;
+ uint8_t change_over_current:1;
+ uint8_t status_suspend:1; /* set if suspended */
+ uint8_t status_vbus:1; /* set if present */
+ uint8_t status_bus_reset:1; /* set if reset complete */
+ uint8_t status_high_speed:1; /* set if High Speed is selected */
+ uint8_t status_low_speed:1; /* set if Low Speed is selected */
+ uint8_t status_device_mode:1; /* set if device mode */
+ uint8_t self_powered:1;
+ uint8_t clocks_off:1;
+ uint8_t port_powered:1;
+ uint8_t port_enabled:1;
+ uint8_t port_over_current:1;
+ uint8_t d_pulled_up:1;
+struct dwc_otg_profile {
+ struct usb_hw_ep_profile usb;
+ uint16_t max_buffer;
+struct dwc_otg_chan_state {
+ uint16_t allocated;
+ uint16_t wait_sof;
+ uint32_t hcint;
+ uint16_t tx_p_size; /* periodic */
+ uint16_t tx_np_size; /* non-periodic */
+struct dwc_otg_softc {
+ struct usb_bus sc_bus;
+ union dwc_otg_hub_temp sc_hub_temp;
+ struct dwc_otg_profile sc_hw_ep_profile[DWC_OTG_MAX_ENDPOINTS];
+ struct dwc_otg_tt_info sc_tt_info[DWC_OTG_MAX_DEVICES];
+ struct usb_callout sc_timer;
+ struct usb_device *sc_devices[DWC_OTG_MAX_DEVICES];
+ struct resource *sc_io_res;
+ struct resource *sc_irq_res;
+ void *sc_intr_hdl;
+ bus_size_t sc_io_size;
+ bus_space_tag_t sc_io_tag;
+ bus_space_handle_t sc_io_hdl;
+ uint32_t sc_rx_bounce_buffer[1024 / 4];
+ uint32_t sc_tx_bounce_buffer[MAX(512 * DWC_OTG_MAX_TXP, 1024) / 4];
+ uint32_t sc_fifo_size;
+ uint32_t sc_tx_max_size;
+ uint32_t sc_tx_cur_p_level; /* periodic */
+ uint32_t sc_tx_cur_np_level; /* non-periodic */
+ uint32_t sc_irq_mask;
+ uint32_t sc_last_rx_status;
+ uint32_t sc_out_ctl[DWC_OTG_MAX_ENDPOINTS];
+ uint32_t sc_in_ctl[DWC_OTG_MAX_ENDPOINTS];
+ struct dwc_otg_chan_state sc_chan_state[DWC_OTG_MAX_CHANNELS];
+ uint32_t sc_tmr_val;
+ uint32_t sc_hprt_val;
+ uint32_t sc_xfer_complete;
+ uint16_t sc_active_rx_ep;
+ uint16_t sc_last_frame_num;
+ uint8_t sc_timer_active;
+ uint8_t sc_dev_ep_max;
+ uint8_t sc_dev_in_ep_max;
+ uint8_t sc_host_ch_max;
+ uint8_t sc_needsof;
+ uint8_t sc_rt_addr; /* root HUB address */
+ uint8_t sc_conf; /* root HUB config */
+ uint8_t sc_mode; /* mode of operation */
+#define DWC_MODE_OTG 0 /* both modes */
+#define DWC_MODE_DEVICE 1 /* device only */
+#define DWC_MODE_HOST 2 /* host only */
+ uint8_t sc_hub_idata[1];
+ struct dwc_otg_flags sc_flags;
+/* prototypes */
+driver_filter_t dwc_otg_filter_interrupt;
+driver_intr_t dwc_otg_interrupt;
+int dwc_otg_init(struct dwc_otg_softc *);
+void dwc_otg_uninit(struct dwc_otg_softc *);
+#endif /* _DWC_OTG_H_ */
diff --git a/freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
b/freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
new file mode 100644
index 0000000..1ebb6f0
--- /dev/null
+++ b/freebsd/sys/dev/usb/controller/dwc_otg_fdt.c
@@ -0,0 +1,235 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * are met:
PURPOSE
CONSEQUENTIAL
STRICT
WAY
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <rtems/bsd/sys/param.h>
+#include <sys/systm.h>
+#include <sys/bus.h>
+#include <sys/condvar.h>
+#include <sys/kernel.h>
+#include <rtems/bsd/sys/lock.h>
+#include <sys/malloc.h>
+#include <sys/module.h>
+#include <sys/mutex.h>
+#include <sys/rman.h>
+#ifndef __rtems__
+#include <dev/ofw/openfirm.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#endif
+#include <dev/usb/usb.h>
+#include <dev/usb/usbdi.h>
+#include <dev/usb/usb_core.h>
+#include <dev/usb/usb_busdma.h>
+#include <dev/usb/usb_process.h>
+#include <dev/usb/usb_util.h>
+#include <dev/usb/usb_controller.h>
+#include <dev/usb/usb_bus.h>
+#include <dev/usb/controller/dwc_otg.h>
+#include <dev/usb/controller/dwc_otg_fdt.h>
+static device_probe_t dwc_otg_probe;
+static device_detach_t dwc_otg_detach;
+static int
+dwc_otg_probe(device_t dev)
+ #ifndef __rtems__
+ if (!ofw_bus_status_okay(dev))
+ return (ENXIO);
+ if (!ofw_bus_is_compatible(dev, "synopsys,designware-hs-otg2"))
+ return (ENXIO);
+ #endif
+ device_set_desc(dev, "DWC OTG 2.0 integrated USB controller");
+ return (BUS_PROBE_DEFAULT);
+int
+dwc_otg_attach(device_t dev)
+ struct dwc_otg_fdt_softc *sc = device_get_softc(dev);
+ char usb_mode[24];
+ int err;
+ int rid;
+ /* initialise some bus fields */
+ sc->sc_otg.sc_bus.parent = dev;
+ sc->sc_otg.sc_bus.devices = sc->sc_otg.sc_devices;
+ sc->sc_otg.sc_bus.devices_max = DWC_OTG_MAX_DEVICES;
+ #ifndef __rtems__
+ sc->sc_otg.sc_bus.dma_bits = 32;
+ #endif
+ #ifndef __rtems__
+ /* get USB mode, if any */
+ if (OF_getprop(ofw_bus_get_node(dev), "dr_mode",
+ &usb_mode, sizeof(usb_mode)) > 0) {
+ /* ensure proper zero termination */
+ usb_mode[sizeof(usb_mode) - 1] = 0;
+ if (strcasecmp(usb_mode, "host") == 0)
+ sc->sc_otg.sc_mode = DWC_MODE_HOST;
+ else if (strcasecmp(usb_mode, "peripheral") == 0)
+ sc->sc_otg.sc_mode = DWC_MODE_DEVICE;
+ else if (strcasecmp(usb_mode, "otg") != 0) {
+ device_printf(dev, "Invalid FDT dr_mode: %s\n",
+ usb_mode);
+ #else
+ #endif
+ /* get all DMA memory */
+ if (usb_bus_mem_alloc_all(&sc->sc_otg.sc_bus,
+ USB_GET_DMA_TAG(dev), NULL)) {
+ return (ENOMEM);
+ rid = 0;
+ sc->sc_otg.sc_io_res =
+ bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid, RF_ACTIVE);
+ if (!(sc->sc_otg.sc_io_res)) {
+ err = ENOMEM;
+ goto error;
+ sc->sc_otg.sc_io_tag = rman_get_bustag(sc->sc_otg.sc_io_res);
+ sc->sc_otg.sc_io_hdl = rman_get_bushandle(sc->sc_otg.sc_io_res);
+ sc->sc_otg.sc_io_size = rman_get_size(sc->sc_otg.sc_io_res);
+ rid = 0;
+ sc->sc_otg.sc_irq_res =
+ bus_alloc_resource_any(dev, SYS_RES_IRQ, &rid, RF_ACTIVE);
+ if (sc->sc_otg.sc_irq_res == NULL)
+ goto error;
+ sc->sc_otg.sc_bus.bdev = device_add_child(dev, "usbus", -1);
+ if (sc->sc_otg.sc_bus.bdev == NULL)
+ goto error;
+ device_set_ivars(sc->sc_otg.sc_bus.bdev, &sc->sc_otg.sc_bus);
+ err = bus_setup_intr(dev, sc->sc_otg.sc_irq_res, INTR_TYPE_TTY |
INTR_MPSAFE,
+ &dwc_otg_filter_interrupt, &dwc_otg_interrupt, sc,
&sc->sc_otg.sc_intr_hdl);
+ if (err) {
+ sc->sc_otg.sc_intr_hdl = NULL;
+ goto error;
+ err = dwc_otg_init(&sc->sc_otg);
+ if (err == 0) {
+ err = device_probe_and_attach(sc->sc_otg.sc_bus.bdev);
+ if (err)
+ goto error;
+ return (0);
+error:
+ dwc_otg_detach(dev);
+ return (ENXIO);
+static int
+dwc_otg_detach(device_t dev)
+ device_t bdev;
+ int err;
+ if (sc->sc_otg.sc_bus.bdev) {
+ bdev = sc->sc_otg.sc_bus.bdev;
+ device_detach(bdev);
+ device_delete_child(dev, bdev);
+ /* during module unload there are lots of children leftover */
+ device_delete_children(dev);
+ if (sc->sc_otg.sc_irq_res && sc->sc_otg.sc_intr_hdl) {
+ * only call dwc_otg_uninit() after dwc_otg_init()
+ dwc_otg_uninit(&sc->sc_otg);
+ err = bus_teardown_intr(dev, sc->sc_otg.sc_irq_res,
+ sc->sc_otg.sc_intr_hdl);
+ /* free IRQ channel, if any */
+ if (sc->sc_otg.sc_irq_res) {
+ bus_release_resource(dev, SYS_RES_IRQ, 0,
+ sc->sc_otg.sc_irq_res);
+ sc->sc_otg.sc_irq_res = NULL;
+ /* free memory resource, if any */
+ if (sc->sc_otg.sc_io_res) {
+ bus_release_resource(dev, SYS_RES_MEMORY, 0,
+ sc->sc_otg.sc_io_res);
+ sc->sc_otg.sc_io_res = NULL;
+ usb_bus_mem_free_all(&sc->sc_otg.sc_bus, NULL);
+ return (0);
+static device_method_t dwc_otg_methods[] = {
+ /* Device interface */
+ DEVMETHOD(device_probe, dwc_otg_probe),
+ DEVMETHOD(device_attach, dwc_otg_attach),
+ DEVMETHOD(device_detach, dwc_otg_detach),
+ DEVMETHOD(device_suspend, bus_generic_suspend),
+ DEVMETHOD(device_resume, bus_generic_resume),
+ DEVMETHOD(device_shutdown, bus_generic_shutdown),
+ DEVMETHOD_END
+driver_t dwc_otg_driver = {
+ .name = "dwcotg",
+ .methods = dwc_otg_methods,
+ .size = sizeof(struct dwc_otg_fdt_softc),
+static devclass_t dwc_otg_devclass;
+#ifndef __rtems__
+DRIVER_MODULE(dwcotg, simplebus, dwc_otg_driver, dwc_otg_devclass, 0, 0);
+#else
+DRIVER_MODULE(dwcotg, nexus, dwc_otg_driver, dwc_otg_devclass, 0, 0);
+#endif
+MODULE_DEPEND(dwcotg, usb, 1, 1, 1);
diff --git a/freebsd/sys/dev/usb/controller/dwc_otg_fdt.h
b/freebsd/sys/dev/usb/controller/dwc_otg_fdt.h
index 0000000..9e01118
--- /dev/null
+++ b/freebsd/sys/dev/usb/controller/dwc_otg_fdt.h
@@ -0,0 +1,39 @@
+ * are met:
PURPOSE
CONSEQUENTIAL
STRICT
WAY
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _DWC_OTG_FDT_H_
+#define _DWC_OTG_FDT_H_
+struct dwc_otg_fdt_softc {
+ struct dwc_otg_softc sc_otg; /* must be first */
+extern driver_t dwc_otg_driver;
+device_attach_t dwc_otg_attach;
+#endif
diff --git a/freebsd/sys/dev/usb/controller/dwc_otgreg.h
b/freebsd/sys/dev/usb/controller/dwc_otgreg.h
index 0000000..8ab3582
--- /dev/null
+++ b/freebsd/sys/dev/usb/controller/dwc_otgreg.h
@@ -0,0 +1,800 @@
+/* $FreeBSD$ */
+ * Copyright (c) 2010,2011 Aleksandr Rybalko. All rights reserved.
+ * are met:
PURPOSE
CONSEQUENTIAL
STRICT
WAY
+ * SUCH DAMAGE.
+#ifndef _DWC_OTGREG_H_
+#define _DWC_OTGREG_H_
+#define DOTG_GOTGCTL 0x0000
+#define DOTG_GOTGINT 0x0004
+#define DOTG_GAHBCFG 0x0008
+#define DOTG_GUSBCFG 0x000C
+#define DOTG_GRSTCTL 0x0010
+#define DOTG_GINTSTS 0x0014
+#define DOTG_GINTMSK 0x0018
+#define DOTG_GRXSTSRD 0x001C
+#define DOTG_GRXSTSRH 0x001C
+#define DOTG_GRXSTSPD 0x0020
+#define DOTG_GRXSTSPH 0x0020
+#define DOTG_GRXFSIZ 0x0024
+#define DOTG_GNPTXFSIZ 0x0028
+#define DOTG_GNPTXSTS 0x002C
+#define DOTG_GI2CCTL 0x0030
+#define DOTG_GPVNDCTL 0x0034
+#define DOTG_GGPIO 0x0038
+#define DOTG_GUID 0x003C
+#define DOTG_GSNPSID 0x0040
+#define DOTG_GHWCFG1 0x0044
+#define DOTG_GHWCFG2 0x0048
+#define DOTG_GHWCFG3 0x004C
+#define DOTG_GHWCFG4 0x0050
+#define DOTG_GLPMCFG 0x0054
+#define DOTG_GPWRDN 0x0058
+#define DOTG_GDFIFOCFG 0x005C
+#define DOTG_GADPCTL 0x0060
+#define DOTG_HPTXFSIZ 0x0100
+/* start from 0x104, but fifo0 not exists */
+#define DOTG_DPTXFSIZ(fifo) (0x0100 + (4*(fifo)))
+#define DOTG_DIEPTXF(fifo) (0x0100 + (4*(fifo)))
+#define DOTG_HCFG 0x0400
+#define DOTG_HFIR 0x0404
+#define DOTG_HFNUM 0x0408
+#define DOTG_HPTXSTS 0x0410
+#define DOTG_HAINT 0x0414
+#define DOTG_HAINTMSK 0x0418
+#define DOTG_HPRT 0x0440
+#define DOTG_HCCHAR(ch) (0x0500 + (32*(ch)))
+#define DOTG_HCSPLT(ch) (0x0504 + (32*(ch)))
+#define DOTG_HCINT(ch) (0x0508 + (32*(ch)))
+#define DOTG_HCINTMSK(ch) (0x050C + (32*(ch)))
+#define DOTG_HCTSIZ(ch) (0x0510 + (32*(ch)))
+#define DOTG_HCDMA(ch) (0x0514 + (32*(ch)))
+#define DOTG_HCDMAI(ch) (0x0514 + (32*(ch)))
+#define DOTG_HCDMAO(ch) (0x0514 + (32*(ch)))
+#define DOTG_HCDMAB(ch) (0x051C + (32*(ch)))
+/* Device Mode */
+#define DOTG_DCFG 0x0800
+#define DOTG_DCTL 0x0804
+#define DOTG_DSTS 0x0808
+#define DOTG_DIEPMSK 0x0810
+#define DOTG_DOEPMSK 0x0814
+#define DOTG_DAINT 0x0818
+#define DOTG_DAINTMSK 0x081C
+#define DOTG_DTKNQR1 0x0820
+#define DOTG_DTKNQR2 0x0824
+#define DOTG_DVBUSDIS 0x0828
+#define DOTG_DVBUSPULSE 0x082C
+#define DOTG_DTHRCTL 0x0830
+#define DOTG_DTKNQR4 0x0834
+#define DOTG_DIEPEMPMSK 0x0834
+#define DOTG_DEACHINT 0x0838
+#define DOTG_DEACHINTMSK 0x083C
+#define DOTG_DIEPEACHINTMSK(ch) (0x0840 + (4*(ch)))
+#define DOTG_DOEPEACHINTMSK(ch) (0x0880 + (4*(ch)))
+#define DOTG_DIEPCTL(ep) (0x0900 + (32*(ep)))
+#define DOTG_DIEPINT(ep) (0x0908 + (32*(ep)))
+#define DOTG_DIEPTSIZ(ep) (0x0910 + (32*(ep)))
+#define DOTG_DIEPDMA(ep) (0x0914 + (32*(ep)))
+#define DOTG_DTXFSTS(ep) (0x0918 + (32*(ep)))
+#define DOTG_DIEPDMAB(ep) (0x091c + (32*(ep)))
+#define DOTG_DOEPCTL(ep) (0x0B00 + (32*(ep)))
+#define DOTG_DOEPFN(ep) (0x0B04 + (32*(ep)))
+#define DOTG_DOEPINT(ep) (0x0B08 + (32*(ep)))
+#define DOTG_DOEPTSIZ(ep) (0x0B10 + (32*(ep)))
+#define DOTG_DOEPDMA(ep) (0x0B14 + (32*(ep)))
+#define DOTG_DOEPDMAB(ep) (0x0B1c + (32*(ep)))
+/* End Device Mode */
+/* Host Mode
+#define DOTG_CTL_STATUS 0x0800
+#define DOTG_DMA0_INB_CHN0 0x0818
+#define DOTG_DMA0_INB_CHN1 0x0820
+#define DOTG_DMA0_INB_CHN2 0x0828
+#define DOTG_DVBUSPULSE 0x082c
+#define DOTG_DMA0_INB_CHN3 0x0830
+#define DOTG_DMA0_INB_CHN4 0x0838
+#define DOTG_DMA0_INB_CHN5 0x0840
+#define DOTG_DMA0_INB_CHN6 0x0848
+#define DOTG_DMA0_INB_CHN7 0x0850
+#define DOTG_DMA0_OUTB_CHN0 0x0858
+#define DOTG_DMA0_OUTB_CHN1 0x0860
+#define DOTG_DMA0_OUTB_CHN2 0x0868
+#define DOTG_DMA0_OUTB_CHN3 0x0870
+#define DOTG_DMA0_OUTB_CHN4 0x0878
+#define DOTG_DMA0_OUTB_CHN5 0x0880
+#define DOTG_DMA0_OUTB_CHN6 0x0888
+#define DOTG_DMA0_OUTB_CHN7 0x0890
+ End Host Mode */
+/* Power and clock gating CSR */
+#define DOTG_PCGCCTL 0x0E00
+/* FIFO access registers (PIO-mode) */
+#define DOTG_DFIFO(n) (0x1000 + (0x1000 * (n)))
+#define GOTGCTL_CHIRP_ON (1<<27)
+#define GOTGCTL_BSESVLD (1<<19)
+#define GOTGCTL_ASESVLD (1<<18)
+#define GOTGCTL_DBNCTIME (1<<17)
+#define GOTGCTL_CONIDSTS (1<<16)
+#define GOTGCTL_DEVHNPEN (1<<11)
+#define GOTGCTL_HSTSETHNPEN (1<<10)
+#define GOTGCTL_HNPREQ (1<<9)
+#define GOTGCTL_HSTNEGSCS (1<<8)
+#define GOTGCTL_SESREQ (1<<1)
+#define GOTGCTL_SESREQSCS (1<<0)
+#define GOTGCTL_DBNCEDONE (1<<19)
+#define GOTGCTL_ADEVTOUTCHG (1<<18)
+#define GOTGCTL_HSTNEGDET (1<<17)
+#define GOTGCTL_HSTNEGSUCSTSCHG (1<<9)
+#define GOTGCTL_SESREQSUCSTSCHG (1<<8)
+#define GOTGCTL_SESENDDET (1<<2)
+#define GAHBCFG_PTXFEMPLVL (1<<8)
+#define GAHBCFG_NPTXFEMPLVL (1<<7)
+#define GAHBCFG_DMAEN (1<<5)
+#define GAHBCFG_HBSTLEN_MASK 0x0000001e
+#define GAHBCFG_HBSTLEN_SHIFT 1
+#define GAHBCFG_GLBLINTRMSK (1<<0)
+#define GUSBCFG_CORRUPTTXPACKET (1<<31)
+#define GUSBCFG_FORCEDEVMODE (1<<30)
+#define GUSBCFG_FORCEHOSTMODE (1<<29)
+#define GUSBCFG_NO_PULLUP (1<<27)
+#define GUSBCFG_IC_USB_CAP (1<<26)
+#define GUSBCFG_TERMSELDLPULSE (1<<22)
+#define GUSBCFG_ULPIEXTVBUSINDICATOR (1<<21)
+#define GUSBCFG_ULPIEXTVBUSDRV (1<<20)
+#define GUSBCFG_ULPICLKSUSM (1<<19)
+#define GUSBCFG_ULPIAUTORES (1<<18)
+#define GUSBCFG_ULPIFSLS (1<<17)
+#define GUSBCFG_OTGI2CSEL (1<<16)
+#define GUSBCFG_PHYLPWRCLKSEL (1<<15)
+#define GUSBCFG_USBTRDTIM_MASK 0x00003c00
+#define GUSBCFG_USBTRDTIM_SHIFT 10
+#define GUSBCFG_TRD_TIM_SET(x) (((x) & 15) << 10)
+#define GUSBCFG_HNPCAP (1<<9)
+#define GUSBCFG_SRPCAP (1<<8)
+#define GUSBCFG_DDRSEL (1<<7)
+#define GUSBCFG_PHYSEL (1<<6)
+#define GUSBCFG_FSINTF (1<<5)
+#define GUSBCFG_ULPI_UTMI_SEL (1<<4)
+#define GUSBCFG_PHYIF (1<<3)
+#define GUSBCFG_TOUTCAL_MASK 0x00000007
+#define GUSBCFG_TOUTCAL_SHIFT 0
+/* STM32F4 */
+#define DOTG_GGPIO_NOVBUSSENS (1 << 21)
+#define DOTG_GGPIO_SOFOUTEN (1 << 20)
+#define DOTG_GGPIO_VBUSBSEN (1 << 19)
+#define DOTG_GGPIO_VBUSASEN (1 << 18)
+#define DOTG_GGPIO_I2CPADEN (1 << 17)
+#define DOTG_GGPIO_PWRDWN (1 << 16)
+#define GRSTCTL_AHBIDLE (1<<31)
+#define GRSTCTL_DMAREQ (1<<30)
+#define GRSTCTL_TXFNUM_MASK 0x000007c0
+#define GRSTCTL_TXFNUM_SHIFT 6
+#define GRSTCTL_TXFIFO(n) (((n) & 31) << 6)
+#define GRSTCTL_TXFFLSH (1<<5)
+#define GRSTCTL_RXFFLSH (1<<4)
+#define GRSTCTL_INTKNQFLSH (1<<3)
+#define GRSTCTL_FRMCNTRRST (1<<2)
+#define GRSTCTL_HSFTRST (1<<1)
+#define GRSTCTL_CSFTRST (1<<0)
+#define GINTSTS_WKUPINT (1<<31)
+#define GINTSTS_SESSREQINT (1<<30)
+#define GINTSTS_DISCONNINT (1<<29)
+#define GINTSTS_CONIDSTSCHNG (1<<28)
+#define GINTSTS_LPM (1<<27)
+#define GINTSTS_PTXFEMP (1<<26)
+#define GINTSTS_HCHINT (1<<25)
+#define GINTSTS_PRTINT (1<<24)
+#define GINTSTS_RESETDET (1<<23)
+#define GINTSTS_FETSUSP (1<<22)
+#define GINTSTS_INCOMPLP (1<<21)
+#define GINTSTS_INCOMPISOIN (1<<20)
+#define GINTSTS_OEPINT (1<<19)
+#define GINTSTS_IEPINT (1<<18)
+#define GINTSTS_EPMIS (1<<17)
+#define GINTSTS_RESTORE_DONE (1<<16)
+#define GINTSTS_EOPF (1<<15)
+#define GINTSTS_ISOOUTDROP (1<<14)
+#define GINTSTS_ENUMDONE (1<<13)
+#define GINTSTS_USBRST (1<<12)
+#define GINTSTS_USBSUSP (1<<11)
+#define GINTSTS_ERLYSUSP (1<<10)
+#define GINTSTS_I2CINT (1<<9)
+#define GINTSTS_ULPICKINT (1<<8)
+#define GINTSTS_GOUTNAKEFF (1<<7)
+#define GINTSTS_GINNAKEFF (1<<6)
+#define GINTSTS_NPTXFEMP (1<<5)
+#define GINTSTS_RXFLVL (1<<4)
+#define GINTSTS_SOF (1<<3)
+#define GINTSTS_OTGINT (1<<2)
+#define GINTSTS_MODEMIS (1<<1)
+#define GINTSTS_CURMOD (1<<0)
+#define GINTMSK_WKUPINTMSK (1<<31)
+#define GINTMSK_SESSREQINTMSK (1<<30)
+#define GINTMSK_DISCONNINTMSK (1<<29)
+#define GINTMSK_CONIDSTSCHNGMSK (1<<28)
+#define GINTMSK_PTXFEMPMSK (1<<26)
+#define GINTMSK_HCHINTMSK (1<<25)
+#define GINTMSK_PRTINTMSK (1<<24)
+#define GINTMSK_FETSUSPMSK (1<<22)
+#define GINTMSK_INCOMPLPMSK (1<<21)
+#define GINTMSK_INCOMPISOINMSK (1<<20)
+#define GINTMSK_OEPINTMSK (1<<19)
+#define GINTMSK_IEPINTMSK (1<<18)
+#define GINTMSK_EPMISMSK (1<<17)
+#define GINTMSK_EOPFMSK (1<<15)
+#define GINTMSK_ISOOUTDROPMSK (1<<14)
+#define GINTMSK_ENUMDONEMSK (1<<13)
+#define GINTMSK_USBRSTMSK (1<<12)
+#define GINTMSK_USBSUSPMSK (1<<11)
+#define GINTMSK_ERLYSUSPMSK (1<<10)
+#define GINTMSK_I2CINTMSK (1<<9)
+#define GINTMSK_ULPICKINTMSK (1<<8)
+#define GINTMSK_GOUTNAKEFFMSK (1<<7)
+#define GINTMSK_GINNAKEFFMSK (1<<6)
+#define GINTMSK_NPTXFEMPMSK (1<<5)
+#define GINTMSK_RXFLVLMSK (1<<4)
+#define GINTMSK_SOFMSK (1<<3)
+#define GINTMSK_OTGINTMSK (1<<2)
+#define GINTMSK_MODEMISMSK (1<<1)
+#define GINTMSK_CURMODMSK (1<<0)
+#define GRXSTSRH_PKTSTS_MASK 0x001e0000
+#define GRXSTSRH_PKTSTS_SHIFT 17
+#define GRXSTSRH_DPID_MASK 0x00018000
+#define GRXSTSRH_DPID_SHIFT 15
+#define GRXSTSRH_BCNT_MASK 0x00007ff0
+#define GRXSTSRH_BCNT_SHIFT 4
+#define GRXSTSRH_CHNUM_MASK 0x0000000f
+#define GRXSTSRH_CHNUM_SHIFT 0
+#define GRXSTSRD_FN_MASK 0x01e00000
+#define GRXSTSRD_FN_GET(x) (((x) >> 21) & 15)
+#define GRXSTSRD_FN_SHIFT 21
+#define GRXSTSRD_PKTSTS_MASK 0x001e0000
+#define GRXSTSRD_PKTSTS_SHIFT 17
+#define GRXSTSRH_IN_DATA (2<<17)
+#define GRXSTSRH_IN_COMPLETE (3<<17)
+#define GRXSTSRH_DT_ERROR (5<<17)
+#define GRXSTSRH_HALTED (7<<17)
+#define GRXSTSRD_GLOB_OUT_NAK (1<<17)
+#define GRXSTSRD_OUT_DATA (2<<17)
+#define GRXSTSRD_OUT_COMPLETE (3<<17)
+#define GRXSTSRD_STP_COMPLETE (4<<17)
+#define GRXSTSRD_STP_DATA (6<<17)
+#define GRXSTSRD_DPID_MASK 0x00018000
+#define GRXSTSRD_DPID_SHIFT 15
+#define GRXSTSRD_DPID_DATA0 (0<<15)
+#define GRXSTSRD_DPID_DATA1 (2<<15)
+#define GRXSTSRD_DPID_DATA2 (1<<15)
+#define GRXSTSRD_DPID_MDATA (3<<15)
+#define GRXSTSRD_BCNT_MASK 0x00007ff0
+#define GRXSTSRD_BCNT_GET(x) (((x) >> 4) & 0x7FF)
+#define GRXSTSRD_BCNT_SHIFT 4
+#define GRXSTSRD_CHNUM_MASK 0x0000000f
+#define GRXSTSRD_CHNUM_GET(x) ((x) & 15)
+#define GRXSTSRD_CHNUM_SHIFT 0
+#define GRXFSIZ_RXFDEP_MASK 0x0000ffff
+#define GRXFSIZ_RXFDEP_SHIFT 0
+#define GNPTXFSIZ_NPTXFDEP_MASK 0xffff0000
+#define GNPTXFSIZ_NPTXFDEP_SHIFT 0
+#define GNPTXFSIZ_NPTXFSTADDR_MASK 0x0000ffff
+#define GNPTXFSIZ_NPTXFSTADDR_SHIFT 16
+#define GNPTXSTS_NPTXQTOP_SHIFT 24
+#define GNPTXSTS_NPTXQTOP_MASK 0x7f000000
+#define GNPTXSTS_NPTXQSPCAVAIL_SHIFT 16
+#define GNPTXSTS_NPTXQSPCAVAIL_MASK 0x00ff0000
+#define GNPTXSTS_NPTXFSPCAVAIL_SHIFT 0
+#define GNPTXSTS_NPTXFSPCAVAIL_MASK 0x0000ffff
+#define GI2CCTL_BSYDNE_SC (1<<31)
+#define GI2CCTL_RW (1<<30)
+#define GI2CCTL_I2CDATSE0 (1<<28)
+#define GI2CCTL_I2CDEVADR_SHIFT 26
+#define GI2CCTL_I2CDEVADR_MASK 0x0c000000
+#define GI2CCTL_I2CSUSPCTL (1<<25)
+#define GI2CCTL_ACK (1<<24)
+#define GI2CCTL_I2CEN (1<<23)
+#define GI2CCTL_ADDR_SHIFT 16
+#define GI2CCTL_ADDR_MASK 0x007f0000
+#define GI2CCTL_REGADDR_SHIFT 8
+#define GI2CCTL_REGADDR_MASK 0x0000ff00
+#define GI2CCTL_RWDATA_SHIFT 0
+#define GI2CCTL_RWDATA_MASK 0x000000ff
+#define GPVNDCTL_DISULPIDRVR (1<<31)
+#define GPVNDCTL_VSTSDONE (1<<27)
+#define GPVNDCTL_VSTSBSY (1<<26)
+#define GPVNDCTL_NEWREGREQ (1<<25)
+#define GPVNDCTL_REGWR (1<<22)
+#define GPVNDCTL_REGADDR_SHIFT 16
+#define GPVNDCTL_REGADDR_MASK 0x003f0000
+#define GPVNDCTL_VCTRL_SHIFT 8
+#define GPVNDCTL_VCTRL_MASK 0x0000ff00
+#define GPVNDCTL_REGDATA_SHIFT 0
+#define GPVNDCTL_REGDATA_MASK 0x000000ff
+#define GGPIO_GPO_SHIFT 16
+#define GGPIO_GPO_MASK 0xffff0000
+#define GGPIO_GPI_SHIFT 0
+#define GGPIO_GPI_MASK 0x0000ffff
+#define GHWCFG1_GET_DIR(x, n) (((x) >> (2 * (n))) & 3)
+#define GHWCFG1_BIDIR 0
+#define GHWCFG1_IN 1
+#define GHWCFG1_OUT 2
+#define GHWCFG2_TKNQDEPTH_SHIFT 26
+#define GHWCFG2_TKNQDEPTH_MASK 0x7c000000
+#define GHWCFG2_PTXQDEPTH_SHIFT 24
+#define GHWCFG2_PTXQDEPTH_MASK 0x03000000
+#define GHWCFG2_NPTXQDEPTH_SHIFT 22
+#define GHWCFG2_NPTXQDEPTH_MASK 0x00c00000
+#define GHWCFG2_MPI (1<<20)
+#define GHWCFG2_DYNFIFOSIZING (1<<19)
+#define GHWCFG2_PERIOSUPPORT (1<<18)
+#define GHWCFG2_NUMHSTCHNL_SHIFT 14
+#define GHWCFG2_NUMHSTCHNL_MASK 0x0003c000
+#define GHWCFG2_NUMHSTCHNL_GET(x) ((((x) >> 14) & 15) + 1)
+#define GHWCFG2_NUMDEVEPS_SHIFT 10
+#define GHWCFG2_NUMDEVEPS_MASK 0x00003c00
+#define GHWCFG2_NUMDEVEPS_GET(x) ((((x) >> 10) & 15) + 1)
+#define GHWCFG2_FSPHYTYPE_SHIFT 8
+#define GHWCFG2_FSPHYTYPE_MASK 0x00000300
+#define GHWCFG2_HSPHYTYPE_SHIFT 6
+#define GHWCFG2_HSPHYTYPE_MASK 0x000000c0
+#define GHWCFG2_SINGPNT (1<<5)
+#define GHWCFG2_OTGARCH_SHIFT 3
+#define GHWCFG2_OTGARCH_MASK 0x00000018
+#define GHWCFG2_OTGMODE_SHIFT 0
+#define GHWCFG2_OTGMODE_MASK 0x00000007
+#define GHWCFG3_DFIFODEPTH_SHIFT 16
+#define GHWCFG3_DFIFODEPTH_MASK 0xffff0000
+#define GHWCFG3_DFIFODEPTH_GET(x) ((x) >> 16)
+#define GHWCFG3_RSTTYPE (1<<11)
+#define GHWCFG3_OPTFEATURE (1<<10)
+#define GHWCFG3_VNDCTLSUPT (1<<9)
+#define GHWCFG3_I2CINTSEL (1<<8)
+#define GHWCFG3_OTGEN (1<<7)
+#define GHWCFG3_PKTSIZEWIDTH_SHIFT 4
+#define GHWCFG3_PKTSIZEWIDTH_MASK 0x00000070
+#define GHWCFG3_PKTSIZE_GET(x) (0x10<<(((x) >> 4) & 7))
+#define GHWCFG3_XFERSIZEWIDTH_SHIFT 0
+#define GHWCFG3_XFERSIZEWIDTH_MASK 0x0000000f
+#define GHWCFG3_XFRRSIZE_GET(x) (0x400<<(((x) >> 0) & 15))
+#define GHWCFG4_NUM_IN_EP_GET(x) ((((x) >> 26) & 15) + 1)
+#define GHWCFG4_SESSENDFLTR (1<<24)
+#define GHWCFG4_BVALIDFLTR (1<<23)
+#define GHWCFG4_AVALIDFLTR (1<<22)
+#define GHWCFG4_VBUSVALIDFLTR (1<<21)
+#define GHWCFG4_IDDGFLTR (1<<20)
+#define GHWCFG4_NUMCTLEPS_SHIFT 16
+#define GHWCFG4_NUMCTLEPS_MASK 0x000f0000
+#define GHWCFG4_NUMCTLEPS_GET(x) (((x) >> 16) & 15)
+#define GHWCFG4_PHYDATAWIDTH_SHIFT 14
+#define GHWCFG4_PHYDATAWIDTH_MASK 0x0000c000
+#define GHWCFG4_AHBFREQ (1<<5)
+#define GHWCFG4_ENABLEPWROPT (1<<4)
+#define GHWCFG4_NUMDEVPERIOEPS_SHIFT 0
+#define GHWCFG4_NUMDEVPERIOEPS_MASK 0x0000000f
+#define GHWCFG4_NUMDEVPERIOEPS_GET(x) (((x) >> 0) & 15)
+#define GLPMCFG_HSIC_CONN (1<<30)
+#define GPWRDN_BVALID (1<<22)
+#define GPWRDN_IDDIG (1<<21)
+#define GPWRDN_CONNDET_INT (1<<14)
+#define GPWRDN_CONNDET (1<<13)
+#define GPWRDN_DISCONN_INT (1<<12)
+#define GPWRDN_DISCONN (1<<11)
+#define GPWRDN_RESETDET_INT (1<<10)
+#define GPWRDN_RESETDET (1<<9)
+#define GPWRDN_LINESTATE_INT (1<<8)
+#define GPWRDN_LINESTATE (1<<7)
+#define GPWRDN_DISABLE_VBUS (1<<6)
+#define GPWRDN_POWER_DOWN (1<<5)
+#define GPWRDN_POWER_DOWN_RST (1<<4)
+#define GPWRDN_POWER_DOWN_CLAMP (1<<3)
+#define GPWRDN_RESTORE (1<<2)
+#define GPWRDN_PMU_ACTIVE (1<<1)
+#define GPWRDN_PMU_IRQ_SEL (1<<0)
+#define HPTXFSIZ_PTXFSIZE_SHIFT 16
+#define HPTXFSIZ_PTXFSIZE_MASK 0xffff0000
+#define HPTXFSIZ_PTXFSTADDR_SHIFT 0
+#define HPTXFSIZ_PTXFSTADDR_MASK 0x0000ffff
+#define DPTXFSIZN_DPTXFSIZE_SHIFT 16
+#define DPTXFSIZN_DPTXFSIZE_MASK 0xffff0000
+#define DPTXFSIZN_PTXFSTADDR_SHIFT 0
+#define DPTXFSIZN_PTXFSTADDR_MASK 0x0000ffff
+#define DIEPTXFN_INEPNTXFDEP_SHIFT 16
+#define DIEPTXFN_INEPNTXFDEP_MASK 0xffff0000
+#define DIEPTXFN_INEPNTXFSTADDR_SHIFT 0
+#define DIEPTXFN_INEPNTXFSTADDR_MASK 0x0000ffff
+#define HCFG_MODECHANGERDY (1<<31)
+#define HCFG_PERSCHEDENABLE (1<<26)
+#define HCFG_FLENTRIES_SHIFT 24
+#define HCFG_FLENTRIES_MASK 0x03000000
+#define HCFG_FLENTRIES_8 (0)
+#define HCFG_FLENTRIES_16 (1)
+#define HCFG_FLENTRIES_32 (2)
+#define HCFG_FLENTRIES_64 (3)
+#define HCFG_MULTISEGDMA (1<<23)
+#define HCFG_32KHZSUSPEND (1<<7)
+#define HCFG_FSLSSUPP (1<<2)
+#define HCFG_FSLSPCLKSEL_SHIFT 0
+#define HCFG_FSLSPCLKSEL_MASK 0x00000003
+#define HFIR_RELOADCTRL (1<<16)
+#define HFIR_FRINT_SHIFT 0
+#define HFIR_FRINT_MASK 0x0000ffff
+#define HFNUM_FRREM_SHIFT 16
+#define HFNUM_FRREM_MASK 0xffff0000
+#define HFNUM_FRNUM_SHIFT 0
+#define HFNUM_FRNUM_MASK 0x0000ffff
+#define HPTXSTS_ODD (1<<31)
+#define HPTXSTS_CHAN_SHIFT 27
+#define HPTXSTS_CHAN_MASK 0x78000000
+#define HPTXSTS_TOKEN_SHIFT 25
+#define HPTXSTS_TOKEN_MASK 0x06000000
+#define HPTXSTS_TOKEN_ZL 0
+#define HPTXSTS_TOKEN_PING 1
+#define HPTXSTS_TOKEN_DISABLE 2
+#define HPTXSTS_TERMINATE (1<<24)
+#define HPTXSTS_PTXQSPCAVAIL_SHIFT 16
+#define HPTXSTS_PTXQSPCAVAIL_MASK 0x00ff0000
+#define HPTXSTS_PTXFSPCAVAIL_SHIFT 0
+#define HPTXSTS_PTXFSPCAVAIL_MASK 0x0000ffff
+#define HAINT_HAINT_SHIFT 0
+#define HAINT_HAINT_MASK 0x0000ffff
+#define HAINTMSK_HAINTMSK_SHIFT 0
+#define HAINTMSK_HAINTMSK_MASK 0x0000ffff
+#define HPRT_PRTSPD_SHIFT 17
+#define HPRT_PRTSPD_MASK 0x00060000
+#define HPRT_PRTSPD_HIGH 0
+#define HPRT_PRTSPD_FULL 1
+#define HPRT_PRTSPD_LOW 2
+#define HPRT_PRTTSTCTL_SHIFT 13
+#define HPRT_PRTTSTCTL_MASK 0x0001e000
+#define HPRT_PRTPWR (1<<12)
+#define HPRT_PRTLNSTS_SHIFT 10
+#define HPRT_PRTLNSTS_MASK 0x00000c00
+#define HPRT_PRTRST (1<<8)
+#define HPRT_PRTSUSP (1<<7)
+#define HPRT_PRTRES (1<<6)
+#define HPRT_PRTOVRCURRCHNG (1<<5)
+#define HPRT_PRTOVRCURRACT (1<<4)
+#define HPRT_PRTENCHNG (1<<3)
+#define HPRT_PRTENA (1<<2)
+#define HPRT_PRTCONNDET (1<<1)
+#define HPRT_PRTCONNSTS (1<<0)
+#define HCCHAR_CHENA (1<<31)
+#define HCCHAR_CHDIS (1<<30)
+#define HCCHAR_ODDFRM (1<<29)
+#define HCCHAR_DEVADDR_SHIFT 22
+#define HCCHAR_DEVADDR_MASK 0x1fc00000
+#define HCCHAR_MC_SHIFT 20
+#define HCCHAR_MC_MASK 0x00300000
+#define HCCHAR_EPTYPE_SHIFT 18
+#define HCCHAR_EPTYPE_MASK 0x000c0000
+#define HCCHAR_LSPDDEV (1<<17)
+#define HCCHAR_EPDIR (1<<15)
+#define HCCHAR_EPDIR_IN (1<<15)
+#define HCCHAR_EPDIR_OUT 0
+#define HCCHAR_EPNUM_SHIFT 11
+#define HCCHAR_EPNUM_MASK 0x00007800
+#define HCCHAR_MPS_SHIFT 0
+#define HCCHAR_MPS_MASK 0x000007ff
+#define HCSPLT_SPLTENA (1<<31)
+#define HCSPLT_COMPSPLT (1<<16)
+#define HCSPLT_XACTPOS_SHIFT 14
+#define HCSPLT_XACTPOS_MASK 0x0000c000
+#define HCSPLT_XACTPOS_MIDDLE 0
+#define HCSPLT_XACTPOS_LAST 1
+#define HCSPLT_XACTPOS_BEGIN 2
+#define HCSPLT_XACTPOS_ALL 3
+#define HCSPLT_XACTLEN_BURST 1023 /* bytes */
+#define HCSPLT_HUBADDR_SHIFT 7
+#define HCSPLT_HUBADDR_MASK 0x00003f80
+#define HCSPLT_PRTADDR_SHIFT 0
+#define HCSPLT_PRTADDR_MASK 0x0000007f
+#define HCINT_ERRORS \
+ (HCINT_BBLERR | HCINT_XACTERR)
+#define HCINT_RETRY \
+ (HCINT_DATATGLERR | HCINT_FRMOVRUN | HCINT_NAK)
+#define HCINT_DEFAULT_MASK \
+ (HCINT_STALL | HCINT_BBLERR | \
+ HCINT_XACTERR | HCINT_NAK | HCINT_ACK | HCINT_NYET | \
+ HCINT_CHHLTD | HCINT_FRMOVRUN | \
+ HCINT_DATATGLERR)
+#define HCINT_HCH_DONE_MASK \
+ (HCINT_ACK | HCINT_RETRY | HCINT_NYET | \
+ HCINT_ERRORS | HCINT_STALL | HCINT_SOFTWARE_ONLY)
+#define HCINT_SOFTWARE_ONLY (1<<20) /* BSD only */
+#define HCINT_DATATGLERR (1<<10)
+#define HCINT_FRMOVRUN (1<<9)
+#define HCINT_BBLERR (1<<8)
+#define HCINT_XACTERR (1<<7)
+#define HCINT_NYET (1<<6)
+#define HCINT_ACK (1<<5)
+#define HCINT_NAK (1<<4)
+#define HCINT_STALL (1<<3)
+#define HCINT_AHBERR (1<<2)
+#define HCINT_CHHLTD (1<<1)
+#define HCINT_XFERCOMPL (1<<0)
+#define HCINTMSK_DATATGLERRMSK (1<<10)
+#define HCINTMSK_FRMOVRUNMSK (1<<9)
+#define HCINTMSK_BBLERRMSK (1<<8)
+#define HCINTMSK_XACTERRMSK (1<<7)
+#define HCINTMSK_NYETMSK (1<<6)
+#define HCINTMSK_ACKMSK (1<<5)
+#define HCINTMSK_NAKMSK (1<<4)
+#define HCINTMSK_STALLMSK (1<<3)
+#define HCINTMSK_AHBERRMSK (1<<2)
+#define HCINTMSK_CHHLTDMSK (1<<1)
+#define HCINTMSK_XFERCOMPLMSK (1<<0)
+#define HCTSIZ_DOPNG (1<<31)
+#define HCTSIZ_PID_SHIFT 29
+#define HCTSIZ_PID_MASK 0x60000000
+#define HCTSIZ_PID_DATA0 0
+#define HCTSIZ_PID_DATA2 1
+#define HCTSIZ_PID_DATA1 2
+#define HCTSIZ_PID_MDATA 3
+#define HCTSIZ_PID_SETUP 3
+#define HCTSIZ_PKTCNT_SHIFT 19
+#define HCTSIZ_PKTCNT_MASK 0x1ff80000
+#define HCTSIZ_XFERSIZE_SHIFT 0
+#define HCTSIZ_XFERSIZE_MASK 0x0007ffff
+#define DCFG_EPMISCNT_SHIFT 18
+#define DCFG_EPMISCNT_MASK 0x007c0000
+#define DCFG_PERFRINT_SHIFT 11
+#define DCFG_PERFRINT_MASK 0x00001800
+#define DCFG_DEVADDR_SHIFT 4
+#define DCFG_DEVADDR_MASK 0x000007f0
+#define DCFG_DEVADDR_SET(x) (((x) & 0x7F) << 4)
+#define DCFG_NZSTSOUTHSHK (1<<2)
+#define DCFG_DEVSPD_SHIFT 0
+#define DCFG_DEVSPD_MASK 0x00000003
+#define DCFG_DEVSPD_SET(x) ((x) & 0x3)
+#define DCFG_DEVSPD_HI 0
+#define DCFG_DEVSPD_FULL20 1
+#define DCFG_DEVSPD_FULL10 3
+#define DCTL_PWRONPRGDONE (1<<11)
+#define DCTL_CGOUTNAK (1<<10)
+#define DCTL_SGOUTNAK (1<<9)
+#define DCTL_CGNPINNAK (1<<8)
+#define DCTL_SGNPINNAK (1<<7)
+#define DCTL_TSTCTL_SHIFT 4
+#define DCTL_TSTCTL_MASK 0x00000070
+#define DCTL_GOUTNAKSTS (1<<3)
+#define DCTL_GNPINNAKSTS (1<<2)
+#define DCTL_SFTDISCON (1<<1)
+#define DCTL_RMTWKUPSIG (1<<0)
+#define DSTS_SOFFN_SHIFT 8
+#define DSTS_SOFFN_MASK 0x003fff00
+#define DSTS_SOFFN_GET(x) (((x) >> 8) & 0x3FFF)
+#define DSTS_ERRTICERR (1<<3)
+#define DSTS_ENUMSPD_SHIFT 1
+#define DSTS_ENUMSPD_MASK 0x00000006
+#define DSTS_ENUMSPD_GET(x) (((x) >> 1) & 3)
+#define DSTS_ENUMSPD_HI 0
+#define DSTS_ENUMSPD_FULL20 1
+#define DSTS_ENUMSPD_LOW10 2
+#define DSTS_ENUMSPD_FULL10 3
+#define DSTS_SUSPSTS (1<<0)
+#define DIEPMSK_TXFIFOUNDRNMSK (1<<8)
+#define DIEPMSK_INEPNAKEFFMSK (1<<6)
+#define DIEPMSK_INTKNEPMISMSK (1<<5)
+#define DIEPMSK_INTKNTXFEMPMSK (1<<4)
+#define DIEPMSK_FIFOEMPTY (1<<4)
+#define DIEPMSK_TIMEOUTMSK (1<<3)
+#define DIEPMSK_AHBERRMSK (1<<2)
+#define DIEPMSK_EPDISBLDMSK (1<<1)
+#define DIEPMSK_XFERCOMPLMSK (1<<0)
+#define DOEPMSK_OUTPKTERRMSK (1<<8)
+#define DOEPMSK_BACK2BACKSETUP (1<<6)
+#define DOEPMSK_OUTTKNEPDISMSK (1<<4)
+#define DOEPMSK_FIFOEMPTY (1<<4)
+#define DOEPMSK_SETUPMSK (1<<3)
+#define DOEPMSK_AHBERRMSK (1<<2)
+#define DOEPMSK_EPDISBLDMSK (1<<1)
+#define DOEPMSK_XFERCOMPLMSK (1<<0)
+#define DIEPINT_TXFIFOUNDRN (1<<8)
+#define DIEPINT_INEPNAKEFF (1<<6)
+#define DIEPINT_INTKNEPMIS (1<<5)
+#define DIEPINT_INTKNTXFEMP (1<<4)
+#define DIEPINT_TIMEOUT (1<<3)
+#define DIEPINT_AHBERR (1<<2)
+#define DIEPINT_EPDISBLD (1<<1)
+#define DIEPINT_XFERCOMPL (1<<0)
+#define DOEPINT_OUTPKTERR (1<<8)
+#define DOEPINT_BACK2BACKSETUP (1<<6)
+#define DOEPINT_OUTTKNEPDIS (1<<4)
+#define DOEPINT_SETUP (1<<3)
+#define DOEPINT_AHBERR (1<<2)
+#define DOEPINT_EPDISBLD (1<<1)
+#define DOEPINT_XFERCOMPL (1<<0)
+#define DAINT_INEPINT_MASK 0xffff0000
+#define DAINT_INEPINT_SHIFT 0
+#define DAINT_OUTEPINT_MASK 0x0000ffff
+#define DAINT_OUTEPINT_SHIFT 16
+#define DAINTMSK_INEPINT_MASK 0xffff0000
+#define DAINTMSK_INEPINT_SHIFT 0
+#define DAINTMSK_OUTEPINT_MASK 0x0000ffff
+#define DAINTMSK_OUTEPINT_SHIFT 16
+#define DTKNQR1_EPTKN_SHIFT 8
+#define DTKNQR1_EPTKN_MASK 0xffffff00
+#define DTKNQR1_WRAPBIT (1<<7)
+#define DTKNQR1_INTKNWPTR_SHIFT 0
+#define DTKNQR1_INTKNWPTR_MASK 0x0000001f
+#define DVBUSDIS_DVBUSDIS_SHIFT 0
+#define DVBUSDIS_DVBUSDIS_MASK 0x0000ffff
+#define DVBUSPULSE_DVBUSPULSE_SHIFT 0
+#define DVBUSPULSE_DVBUSPULSE_MASK 0x00000fff
+#define DTHRCTL_ARBPRKEN (1<<27)
+#define DTHRCTL_RXTHRLEN_SHIFT 17
+#define DTHRCTL_RXTHRLEN_MASK 0x03fe0000
+#define DTHRCTL_RXTHREN (1<<16)
+#define DTHRCTL_TXTHRLEN_SHIFT 2
+#define DTHRCTL_TXTHRLEN_MASK 0x000007fc
+#define DTHRCTL_ISOTHREN (1<<1)
+#define DTHRCTL_NONISOTHREN (1<<0)
+#define DIEPEMPMSK_INEPTXFEMPMSK_SHIFT 0
+#define DIEPEMPMSK_INEPTXFEMPMSK_MASK 0x0000ffff
+#define DIEPCTL_EPENA (1<<31)
+#define DIEPCTL_EPDIS (1<<30)
+#define DIEPCTL_SETD1PID (1<<29)
+#define DIEPCTL_SETD0PID (1<<28)
+#define DIEPCTL_SNAK (1<<27)
+#define DIEPCTL_CNAK (1<<26)
+#define DIEPCTL_TXFNUM_SHIFT 22
+#define DIEPCTL_TXFNUM_MASK 0x03c00000
+#define DIEPCTL_TXFNUM_SET(n) (((n) & 15) << 22)
+#define DIEPCTL_STALL (1<<21)
+#define DIEPCTL_EPTYPE_SHIFT 18
+#define DIEPCTL_EPTYPE_MASK 0x000c0000
+#define DIEPCTL_EPTYPE_SET(n) (((n) & 3) << 18)
+#define DIEPCTL_EPTYPE_CONTROL 0
+#define DIEPCTL_EPTYPE_ISOC 1
+#define DIEPCTL_EPTYPE_BULK 2
+#define DIEPCTL_EPTYPE_INTERRUPT 3
+#define DIEPCTL_NAKSTS (1<<17)
+#define DIEPCTL_USBACTEP (1<<15)
+#define DIEPCTL_NEXTEP_SHIFT 11
+#define DIEPCTL_NEXTEP_MASK 0x00007800
+#define DIEPCTL_MPS_SHIFT 0
+#define DIEPCTL_MPS_MASK 0x000007ff
+#define DIEPCTL_MPS_SET(n) ((n) & 0x7FF)
+#define DIEPCTL_MPS_64 (0<<0)
+#define DIEPCTL_MPS_32 (1<<0)
+#define DIEPCTL_MPS_16 (2<<0)
+#define DIEPCTL_MPS_8 (3<<0)
+#define DOEPCTL_EPENA (1<<31)
+#define DOEPCTL_EPDIS (1<<30)
+#define DOEPCTL_SETD1PID (1<<29)
+#define DOEPCTL_SETD0PID (1<<28)
+#define DOEPCTL_SNAK (1<<27)
+#define DOEPCTL_CNAK (1<<26)
+#define DOEPCTL_FNUM_SET(n) (((n) & 15) << 22)
+#define DOEPCTL_STALL (1<<21)
+#define DOEPCTL_EPTYPE_SHIFT 18
+#define DOEPCTL_EPTYPE_MASK 0x000c0000
+#define DOEPCTL_EPTYPE_SET(n) (((n) & 3) << 18)
+#define DOEPCTL_NAKSTS (1<<17)
+#define DOEPCTL_USBACTEP (1<<15)
+#define DOEPCTL_MPS_SHIFT 0
+#define DOEPCTL_MPS_MASK 0x000007ff
+#define DOEPCTL_MPS_SET(n) ((n) & 0x7FF)
+#define DOEPCTL_MPS_64 (0<<0)
+#define DOEPCTL_MPS_32 (1<<0)
+#define DOEPCTL_MPS_16 (2<<0)
+#define DOEPCTL_MPS_8 (3<<0)
+/* common bits */
+#define DXEPINT_TXFEMP (1<<7)
+#define DXEPINT_SETUP (1<<3)
+#define DXEPINT_XFER_COMPL (1<<0)
+#define DIEPTSIZ_XFERSIZE_MASK 0x0007ffff
+#define DIEPTSIZ_XFERSIZE_SHIFT 0
+#define DIEPTSIZ_PKTCNT_MASK 0x1ff80000
+#define DIEPTSIZ_PKTCNT_SHIFT 19
+#define DIEPTSIZ_MC_MASK 0x60000000
+#define DIEPTSIZ_MC_SHIFT 29
+#define DOEPTSIZ_XFERSIZE_MASK 0x0007ffff
+#define DOEPTSIZ_XFERSIZE_SHIFT 0
+#define DOEPTSIZ_PKTCNT_MASK 0x1ff80000
+#define DOEPTSIZ_PKTCNT_SHIFT 19
+#define DOEPTSIZ_MC_MASK 0x60000000
+#define DOEPTSIZ_MC_SHIFT 29
+/* common bits */
+#define DXEPTSIZ_SET_MULTI(n) (((n) & 3) << 29)
+#define DXEPTSIZ_SET_NPKT(n) (((n) & 0x3FF) << 19)
+#define DXEPTSIZ_GET_NPKT(n) (((n) >> 19) & 0x3FF)
+#define DXEPTSIZ_SET_NBYTES(n) (((n) & 0x7FFFFF) << 0)
+#define DXEPTSIZ_GET_NBYTES(n) (((n) >> 0) & 0x7FFFFF)
+/* generic endpoint mask */
+#define ENDPOINT_MASK(x,in) \
+ ((in) ? (1U << ((x) & 15U)) : \
+ (0x10000U << ((x) & 15U)))
+#endif /* _DWC_OTGREG_H_ */
diff --git a/freebsd/sys/dev/usb/usb.h b/freebsd/sys/dev/usb/usb.h
index bb5a60c..c090d71 100644
--- a/freebsd/sys/dev/usb/usb.h
+++ b/freebsd/sys/dev/usb/usb.h
@@ -572,6 +572,15 @@ static const struct name name = { \
.bData = { m }, \
+#ifdef __rtems__
+struct usb_string_lang {
+ uByte bLength;
+ uByte bDescriptorType;
+ uByte bData[2];
+} __packed;
+typedef struct usb_string_lang usb_string_lang_t;
+#endif
struct usb_hub_descriptor {
uByte bDescLength;
diff --git a/freebsd/sys/dev/usb/usb_bus.h b/freebsd/sys/dev/usb/usb_bus.h
index 0a7350c..e3d546f 100644
--- a/freebsd/sys/dev/usb/usb_bus.h
+++ b/freebsd/sys/dev/usb/usb_bus.h
@@ -85,6 +85,9 @@ struct usb_bus {
* This mutex protects the USB hardware:
struct mtx bus_mtx;
+ #ifdef __rtems__
+ struct mtx bus_spin_lock;
+ #endif
struct usb_xfer_queue intr_q;
struct usb_callout power_wdog; /* power management */
diff --git a/freebsd/sys/dev/usb/usb_core.c b/freebsd/sys/dev/usb/usb_core.c
index 80f5ecd..8d5c609 100644
--- a/freebsd/sys/dev/usb/usb_core.c
+++ b/freebsd/sys/dev/usb/usb_core.c
@@ -54,6 +54,13 @@
+#ifdef __rtems__
+const struct usb_string_lang usb_string_lang_en = {
+ sizeof(usb_string_lang_en), UDESC_STRING,
+ { 0x09, 0x04 } /* American English */
+#endif
MALLOC_DEFINE(M_USB, "USB", "USB");
MALLOC_DEFINE(M_USBDEV, "USBdev", "USB device");
MALLOC_DEFINE(M_USBHC, "USBHC", "USB host controller");
diff --git a/freebsd/sys/dev/usb/usb_core.h b/freebsd/sys/dev/usb/usb_core.h
index 287e69f..8a2ab19 100644
--- a/freebsd/sys/dev/usb/usb_core.h
+++ b/freebsd/sys/dev/usb/usb_core.h
@@ -44,6 +44,11 @@
#define USB_BUS_LOCK(_b) mtx_lock(&(_b)->bus_mtx)
#define USB_BUS_UNLOCK(_b) mtx_unlock(&(_b)->bus_mtx)
#define USB_BUS_LOCK_ASSERT(_b, _t) mtx_assert(&(_b)->bus_mtx, _t)
+#ifdef __rtems__
+#define USB_BUS_SPIN_LOCK(_b) mtx_lock_spin(&(_b)->bus_spin_lock)
+#define USB_BUS_SPIN_UNLOCK(_b)
mtx_unlock_spin(&(_b)->bus_spin_lock)
+#define USB_BUS_SPIN_LOCK_ASSERT(_b, _t)
mtx_assert(&(_b)->bus_spin_lock, _t)
+#endif
#define USB_XFER_LOCK(_x) mtx_lock((_x)->xroot->xfer_mtx)
#define USB_XFER_UNLOCK(_x) mtx_unlock((_x)->xroot->xfer_mtx)
#define USB_XFER_LOCK_ASSERT(_x, _t)
mtx_assert((_x)->xroot->xfer_mtx, _t)
@@ -176,6 +181,9 @@ struct usb_xfer {
/* external variables */
extern struct mtx usb_ref_lock;
+#ifdef __rtems__
+extern const struct usb_string_lang usb_string_lang_en;
+#endif
/* typedefs */
diff --git a/rtemsbsd/include/bsp/nexus-devices.h
b/rtemsbsd/include/bsp/nexus-devices.h
index 6ccf726..58e26b2 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -125,6 +125,25 @@ SYSINIT_DRIVER_REFERENCE(lem, pci);
SYSINIT_DRIVER_REFERENCE(igb, pci);
SYSINIT_DRIVER_REFERENCE(em, pci);
+#elif defined(LIBBSP_ARM_RASPBERRYPI_BSP_H)
+#include <bsp/irq.h>
+static const rtems_bsd_device_resource bcm283x_dwcotg_res[] = {
+ .type = RTEMS_BSD_RES_MEMORY,
+ .start_request = 0,
+ .start_actual = 0x00980000
+ .type = RTEMS_BSD_RES_IRQ,
+ .start_actual = 17
+RTEMS_BSD_DEFINE_NEXUS_DEVICE(bcm283x_dwcotg, 0,
RTEMS_ARRAY_SIZE(bcm283x_dwcotg_res),
+ &bcm283x_dwcotg_res[0]);
#elif defined(LIBBSP_POWERPC_QORIQ_BSP_H)
#if !QORIQ_CHIP_IS_T_VARIANT(QORIQ_CHIP_VARIANT)
diff --git a/rtemsbsd/include/machine/rtems-bsd-sysinit.h
b/rtemsbsd/include/machine/rtems-bsd-sysinit.h
index c8af236..3e2fc02 100644
--- a/rtemsbsd/include/machine/rtems-bsd-sysinit.h
+++ b/rtemsbsd/include/machine/rtems-bsd-sysinit.h
@@ -56,6 +56,9 @@
SYSINIT_DRIVER_REFERENCE(ehci, nexus); \
SYSINIT_DRIVER_REFERENCE(usbus, ehci)
+#define SYSINIT_NEED_USB_BCM283X_DWC_OTG \
+ SYSINIT_DRIVER_REFERENCE(bcm283x_dwcotg, nexus)
#define SYSINIT_NEED_USB_MASS_STORAGE \
SYSINIT_DRIVER_REFERENCE(umass, uhub)
diff --git a/wscript b/wscript
index 8c0c242..85de476 100644
--- a/wscript
+++ b/wscript
@@ -626,6 +626,7 @@ def build(bld):
libbsd_use += ["objs06"]
source = ['freebsd/sys/arm/xilinx/zy7_slcr.c',
+ 'freebsd/sys/arm/broadcom/bcm2835/bcm283x_dwc_fdt.c',
'freebsd/sys/cam/cam.c',
'freebsd/sys/cam/scsi/scsi_all.c',
'freebsd/sys/contrib/altq/altq/altq_cbq.c',
@@ -710,6 +711,8 @@ def build(bld):
'freebsd/sys/dev/sdhci/sdhci.c',
'freebsd/sys/dev/smc/if_smc.c',
'freebsd/sys/dev/tsec/if_tsec.c',
+ 'freebsd/sys/dev/usb/controller/dwc_otg.c',
+ 'freebsd/sys/dev/usb/controller/dwc_otg_fdt.c',
'freebsd/sys/dev/usb/controller/ehci.c',
'freebsd/sys/dev/usb/controller/ohci.c',
'freebsd/sys/dev/usb/controller/usb_controller.c',
1.7.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150821/4a7ac150/attachment-0001.html>
