libbsd - USB Host Stack for HID, WirelessLAN
Yurii Shevtsov
ungetch at gmail.com
Tue Aug 25 10:19:23 UTC 2015
2015-08-25 12:10 GMT+03:00 Thomas Kim <thomas73.kim at gmail.com>:
> Dear Yurii,
> Thank you very much.
> I want to review freeBSD source code.
> Please let me know where is libbsd's README file. there is not README file
> in current tree (https://git.rtems.org/rtems-libbsd/tree/).
> I want to check "Rules for Modiying FreeBSD source" in REAME file.
https://github.com/RTEMS/rtems-libbsd/blob/master/libbsd.txt
> Also, I want to compare FreeBSD original code and the modified FreeBSD
> code.
> I guess that FreeBSD original code version is 8.x.
it's actually 9.2 (from the readme)
> Please let me know how to get FreeBSD original code version which was used
> for libbsd porting work.
https://svnweb.freebsd.org/base/release/9.2.0/ It's Subversion
https://www.freebsd.org/doc/handbook/svn.html
> Best Regards,
> Thomas.
> 2015-08-21 23:57 GMT+09:00 Yurii Shevtsov <ungetch at gmail.com>:
>> Hi)
>> For porting guide check this blogpost
>> http://ragustechblog.blogspot.in/2015/06/porting-driver-from-freebsd-to-rtems.html
>> Also read libbsd's README, especially "Rules for Modifying FreeBSD Source"
>> Can't say anything specific about USB HID and WLAN. Definitely WLAN will
>> require porting libraries with auth protocols (WPA\WEP). About HID, you can
>> try searching how input works in RTEMS. Maybe you can implement API in your
>> future HID driver
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150825/0afe5b4c/attachment.html>
