[PATCH 6/6] Add libtecla: Not building yet
Tue Aug 25 23:02:09 UTC 2015
 rtems/config/4.11/devel/libtecla.bset   |   20 ++++++++
 rtems/config/devel/libtecla-1.6.3-1.cfg |   21 ++++++++
 source-builder/config/libtecla-1.cfg    |   78 +++++++++++++++++++++++++++++++
 3 files changed, 119 insertions(+), 0 deletions(-)
 create mode 100644 rtems/config/4.11/devel/libtecla.bset
 create mode 100644 rtems/config/devel/libtecla-1.6.3-1.cfg
 create mode 100644 source-builder/config/libtecla-1.cfg
diff --git a/rtems/config/4.11/devel/libtecla.bset b/rtems/config/4.11/devel/libtecla.bset
new file mode 100644
index 0000000..b1dd9e7
--- /dev/null
+++ b/rtems/config/4.11/devel/libtecla.bset
@@ -0,0 +1,20 @@
+# Build set for libtecla
+%define release 1
+# RTEMS Version
+%define rtems_version 4.11
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# Build libtecla.
+devel/libtecla-1.6.3-1.cfg
diff --git a/rtems/config/devel/libtecla-1.6.3-1.cfg b/rtems/config/devel/libtecla-1.6.3-1.cfg
index 0000000..de38edb
--- /dev/null
+++ b/rtems/config/devel/libtecla-1.6.3-1.cfg
@@ -0,0 +1,21 @@
+# libtecla
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# libjpeg Version
+%define libtecla_version 1.6.3
+%hash md5 libtecla-%{libtecla_version}.tar.gz 90105ca19e405fb92825a90978e4ab18
+# libjpeg Build configuration
+%include %{_configdir}/libtecla-1.cfg
diff --git a/source-builder/config/libtecla-1.cfg b/source-builder/config/libtecla-1.cfg
index 0000000..79f0051
--- /dev/null
+++ b/source-builder/config/libtecla-1.cfg
@@ -0,0 +1,78 @@
+# libtecla
+# This configuration file configure's, make's and install's libtecla.
+%define release 1
+%endif
+Name:      libtecla-%{libtecla_version}-%{_host}-%{release}
+Summary:   libtecla is a command line editing library
+Version:   %{libtecla_version}
+Release:   %{release}
+URL: 	   http://www.astro.caltech.edu/~mcs/tecla/
+BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
+# libtecla Source
+%source set libtecla http://www.astro.caltech.edu/~mcs/tecla/libtecla-%{libtecla_version}.tar.gz
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  # libtecla does not include version in source directory name
+  # source_dir_libtecla="libtecla-%{libtecla_version}"
+  # %source setup libtecla -q -n libtecla-%{libtecla_version}
+  source_dir_libtecla="libtecla"
+  %source setup libtecla -q -n libtecla
+  %patch setup libtecla -p1
+  cd ${build_top}
+# Running make distclean cleans up documentation files that require
+# special tools to regenerate.  Work around this problem by just
+# copying the documentation files from another directory.
+%build
+  build_top=$(pwd)
+  %{build_directory}
+  mkdir -p ${build_dir}
+  cd ${build_dir}
+  %{host_build_flags}
+  ../${source_dir_libtecla}/configure \
+    --host=%{_host} \
+    --prefix=%{_prefix} \
+    --bindir=%{_bindir} \
+    --exec_prefix=%{_exec_prefix} \
+    --includedir=%{_includedir} \
+    --libdir=%{_libdir} \
+    --libexecdir=%{_libexecdir} \
+    --mandir=%{_mandir} \
+    --infodir=%{_infodir} \
+    --datadir=%{_datadir}
+  %{__make} %{?_smp_mflags}
+  %{__make} %{?_smp_mflags} reentrant
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  %{__rmdir} $SB_BUILD_ROOT
+  cd ${build_dir}
+  %{__make} DESTDIR=$SB_BUILD_ROOT install
+  cd ${build_top}
1.7.1
