ARMv7M Exception Handler
Daniel Gutson daniel.gutson at tallertechnologies.com
Fri Aug 28 15:37:04 UTC 2015
On Fri, Aug 28, 2015 at 12:33 PM, sudarshan.rajagopalan
<sudarshan.rajagopalan at vecna.com> wrote:
> On 2015-08-27 17:06, Joel Sherrill wrote:
>> On 8/27/2015 3:58 PM, Daniel Gutson wrote:
>>> On Thu, Aug 27, 2015 at 3:53 PM, sudarshan.rajagopalan
>>>> Hey guys,
>>>> I was working on the exception handler for the CPU hard fault. Managed
>>>> to
>>>> register the fatal error user extension to RTEMS and call the user
>>>> defined
>>>> function when an exception occurs. But the pointer to the stacked frame
>>>> didn't have the correct register values(esp. the PC register). So I
>>>> looked
>>>> into the assembly code in
>>>> /cpukit/score/cpu/arm/armv7m-exception-default.c,
>>>> where it decides which stack pointer was used (MSP or PSP) before the
>>>> exception occurred depending on the error code returned in the Link
>>>> Register. After carefully examining all the assembly instructions, I
>>>> guess
>>>> theres a little bug in the code.
>>>> The instruction "cmn r2, #3\n" in line 31 basically compares the Link
>>>> Register(lr) to value 0xFFFFFFFD (negative #3, because CMN negates the
>>>> RHS
>>>> and compares with LHS) and chooses MSP or PSP in the following IT block.
>>>> This is pretty cool! But, it will not work if you have the
>>>> floating-point
>>>> unit (FPU) enabled in your processor, which is enabled in mine. With FPU
>>>> enabled, the error code returned is either 0xFFFFFFE9 or 0xFFFFFFED, for
>>>> which the above assembly instruction will not work out and MSP will be
>>>> selected always.
>>>> Better way to do is to check the 2nd bit of the error code to determine
>>>> which stack pointer was used before the exception happened - "tst lr,
>>>> #4\n"
>>>> and change the IT block from "itt ne" to "itt eq" and the "mov" and
>>>> "add"
>>>> within this IT block.
>>>> Have tested this with the above changes and it works. I have sent the
>>>> patch
>>>> "0001-Fix-exception-handler-for-supporting-FPU.patch" to the devel
>>>> mailing
>>>> list that fixes this problem. :)
>>> Nice. Have you tested this without FPU support too?
> Hi Daniel,
> Just tested the fix with FPU disabled in my processor and it works fine.
> This patch can be pushed!
As I mentioned before, please mention what architecture you tested
(what use cases) and which you didn't.
>> Daniel .. when you are happy, we can push it.
>> Should this go on the 4.11 branch and master? If so, it needs a ticket.
> Joel, I think this fix is vital and should be pushed to master. Will make a
> ticket for this.
> Thanks and Regards,
> Sudarshan
> Sudarshan Rajagopalan
> www.vecna.com
>>>> Thanks and Regards,
>>>> Sudarshan
>>>> _______________________________________________
>>>> devel mailing list
>>>> devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/devel
Daniel F. Gutson
Chief Engineering Officer, SPD
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone:   +54 351 4217888 / +54 351 4218211
Skype:    dgutson
LinkedIn: http://ar.linkedin.com/in/danielgutson
