[PATCH v3] ARMv7M: Fix exception handler for supporting FPU
Daniel Gutson daniel.gutson at tallertechnologies.com
Mon Aug 31 17:28:56 UTC 2015
Side question to Joel and others: is this enough to credit Sudarshan?
He did an amazing job for finding the bug and proposing an initial
solution.
On Mon, Aug 31, 2015 at 11:37 AM, Martin Galvan
<martin.galvan at tallertechnologies.com> wrote:
> On exception entry, _ARMV7M_Exception_default stores the previous Stack Pointer
> in a CPU_Exception_frame. The SP can be MSP or PSP, depending on the mode
> in which the exception was taken. To know this, we must check the value of LR.
> Right now the code checks whether it should store MSP or PSP by comparing LR to
> -3. However, this doesn't work if we're using an FPU. This patch fixes that
> by checking bit 2 of LR, which indicates which SP we were using.
> Thanks to Sudarshan Rajagopalan for finding the bug and proposing a first
> version of the fix.
> Closes #2401.
>  cpukit/score/cpu/arm/armv7m-exception-default.c | 27 +++++++++++++++++--------
>  1 file changed, 19 insertions(+), 8 deletions(-)
> diff --git a/cpukit/score/cpu/arm/armv7m-exception-default.c b/cpukit/score/cpu/arm/armv7m-exception-default.c
> index e890cdf..d04dbea 100644
> --- a/cpukit/score/cpu/arm/armv7m-exception-default.c
> +++ b/cpukit/score/cpu/arm/armv7m-exception-default.c
> @@ -22,16 +22,27 @@
>  void __attribute__((naked)) _ARMV7M_Exception_default( void )
> +    /* On exception entry, ARMv7M saves context state onto a stack pointed to
> +     * by either MSP or PSP. The value stored in LR indicates whether we were
> +     * in Thread or Handler mode, whether we were using the FPU (if any),
> +     * and which stack pointer we were using.
> +     * In particular, bit 2 of LR will be 0 if we were using MSP.
> +     * For a more detailed explanation, see the Exception Entry Behavior
> +     * section of the ARMv7M Architecture Reference Manual.
> +    /* As we're in Handler mode here, we'll always operate on MSP.
> +     * However, we need to store the right SP in our CPU_Exception_frame.
>    __asm__ volatile (
> -    "sub sp, %[cpufsz]\n"
> +    "sub sp, %[cpufsz]\n" /* Allocate space for a CPU_Exception_frame. */
>      "stm sp, {r0-r12}\n"
> -    "mov r2, lr\n"
> -    "mrs r1, msp\n"
> -    "mrs r0, psp\n"
> -    "cmn r2, #3\n"
> -    "itt ne\n"
> -    "movne r0, r1\n"
> -    "addne r0, %[cpufsz]\n"
> +    "tst lr, #4\n"       /* Check if bit 2 of LR is zero. (If so, PSR.Z = 1) */
> +    "itte eq\n"          /* IF bit 2 of LR is zero... (PSR.Z == 1) */
> +    "mrseq r0, msp\n"    /* THEN we were using MSP. */
> +    "addeq r0, %[cpufsz]\n" /* THEN, set r0 = old MSP. */
> +    "mrsne r0, psp\n"    /* ELSE it's not zero; we were using PSP. */
>      "add r2, r0, %[v7mlroff]\n"
>      "add r1, sp, %[cpulroff]\n"
>      "ldm r2, {r3-r5}\n"
> 1.9.1
Daniel F. Gutson
Chief Engineering Officer, SPD
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone:   +54 351 4217888 / +54 351 4218211
Skype:    dgutson
LinkedIn: http://ar.linkedin.com/in/danielgutson
