[PATCH v3] ARMv7M: Fix exception handler for supporting FPU
sudarshan.rajagopalan sudarshan.rajagopalan at vecna.com
Mon Aug 31 19:22:24 UTC 2015
On 2015-08-31 13:39, Daniel Gutson wrote:
> On Mon, Aug 31, 2015 at 2:34 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> I'd approve 2 patches in case you want to give credit. First patch
>> with Sudarshan's fix, and Martin's improvement second.
> +1
Sounds fair enough! :) Thanks for the support, Daniel. Should I make a
separate ticket for committing the initial patch or Martin's ticket
works out well for this?
Thanks and Regards,
Sudarshan
>> On Mon, Aug 31, 2015 at 1:28 PM, Daniel Gutson
>> <daniel.gutson at tallertechnologies.com> wrote:
>>> Side question to Joel and others: is this enough to credit Sudarshan?
>>> He did an amazing job for finding the bug and proposing an initial
>>> solution.
>>> On Mon, Aug 31, 2015 at 11:37 AM, Martin Galvan
>>> <martin.galvan at tallertechnologies.com> wrote:
>>>> On exception entry, _ARMV7M_Exception_default stores the previous
>>>> Stack Pointer
>>>> in a CPU_Exception_frame. The SP can be MSP or PSP, depending on the
>>>> mode
>>>> in which the exception was taken. To know this, we must check the
>>>> value of LR.
>>>> Right now the code checks whether it should store MSP or PSP by
>>>> comparing LR to
>>>> -3. However, this doesn't work if we're using an FPU. This patch
>>>> fixes that
>>>> by checking bit 2 of LR, which indicates which SP we were using.
>>>> Thanks to Sudarshan Rajagopalan for finding the bug and proposing a
>>>> first
>>>> version of the fix.
>>>> Closes #2401.
>>>>  cpukit/score/cpu/arm/armv7m-exception-default.c | 27
>>>>  1 file changed, 19 insertions(+), 8 deletions(-)
>>>> diff --git a/cpukit/score/cpu/arm/armv7m-exception-default.c
>>>> b/cpukit/score/cpu/arm/armv7m-exception-default.c
>>>> index e890cdf..d04dbea 100644
>>>> --- a/cpukit/score/cpu/arm/armv7m-exception-default.c
>>>> +++ b/cpukit/score/cpu/arm/armv7m-exception-default.c
>>>> @@ -22,16 +22,27 @@
>>>>  void __attribute__((naked)) _ARMV7M_Exception_default( void )
>>>> +    /* On exception entry, ARMv7M saves context state onto a stack
>>>> pointed to
>>>> +     * by either MSP or PSP. The value stored in LR indicates
>>>> whether we were
>>>> +     * in Thread or Handler mode, whether we were using the FPU (if
>>>> any),
>>>> +     * and which stack pointer we were using.
>>>> +     * In particular, bit 2 of LR will be 0 if we were using MSP.
>>>> +     * For a more detailed explanation, see the Exception Entry
>>>> Behavior
>>>> +     * section of the ARMv7M Architecture Reference Manual.
>>>> +    /* As we're in Handler mode here, we'll always operate on MSP.
>>>> +     * However, we need to store the right SP in our
>>>>    __asm__ volatile (
>>>> -    "sub sp, %[cpufsz]\n"
>>>> +    "sub sp, %[cpufsz]\n" /* Allocate space for a
>>>> CPU_Exception_frame. */
>>>>      "stm sp, {r0-r12}\n"
>>>> -    "mov r2, lr\n"
>>>> -    "mrs r1, msp\n"
>>>> -    "mrs r0, psp\n"
>>>> -    "cmn r2, #3\n"
>>>> -    "itt ne\n"
>>>> -    "movne r0, r1\n"
>>>> -    "addne r0, %[cpufsz]\n"
>>>> +    "tst lr, #4\n"       /* Check if bit 2 of LR is zero. (If so,
>>>> PSR.Z = 1) */
>>>> +    "itte eq\n"          /* IF bit 2 of LR is zero... (PSR.Z == 1)
>>>> +    "mrseq r0, msp\n"    /* THEN we were using MSP. */
>>>> +    "addeq r0, %[cpufsz]\n" /* THEN, set r0 = old MSP. */
>>>> +    "mrsne r0, psp\n"    /* ELSE it's not zero; we were using PSP.
>>>>      "add r2, r0, %[v7mlroff]\n"
>>>>      "add r1, sp, %[cpulroff]\n"
>>>>      "ldm r2, {r3-r5}\n"
>>>> 1.9.1
>>> Daniel F. Gutson
>>> Chief Engineering Officer, SPD
>>> San Lorenzo 47, 3rd Floor, Office 5
>>> Córdoba, Argentina
>>> Phone:   +54 351 4217888 / +54 351 4218211
>>> Skype:    dgutson
>>> LinkedIn: http://ar.linkedin.com/in/danielgutson
