[PATCH 5/6] video outch support for rpi bsp
YANG QIAO
yangqiao0505 at me.com
Mon Aug 10 12:47:14 UTC 2015
c/src/lib/libbsp/arm/raspberrypi/Makefile.am | 1 +
.../lib/libbsp/arm/raspberrypi/console/font_data.h | 4639 ++++++++++++++++++++
c/src/lib/libbsp/arm/raspberrypi/console/outch.c | 405 ++
c/src/lib/libbsp/arm/raspberrypi/include/bsp.h | 3 +
.../lib/libbsp/arm/raspberrypi/startup/bspstart.c | 8 +
.../libbsp/arm/raspberrypi/startup/bspstarthooks.c | 1 +
6 files changed, 5057 insertions(+)
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/font_data.h
create mode 100644 c/src/lib/libbsp/arm/raspberrypi/console/outch.c
diff --git a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
index 41817b1..ea33adb 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
+++ b/c/src/lib/libbsp/arm/raspberrypi/Makefile.am
@@ -114,6 +114,7 @@ libbsp_a_SOURCES += ../../shared/console_write.c
libbsp_a_SOURCES += console/console-config.c
libbsp_a_SOURCES += console/usart.c
libbsp_a_SOURCES += console/fb.c
+libbsp_a_SOURCES += console/outch.c
# clock
libbsp_a_SOURCES += clock/clockdrv.c ../../../shared/clockdrv_shell.h
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/font_data.h b/c/src/lib/libbsp/arm/raspberrypi/console/font_data.h
new file mode 100644
index 0000000..1f473e5
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/font_data.h
@@ -0,0 +1,4639 @@
+ * @file
+ * @ingroup raspberrypi
+ * @brief graphic text console font file
+ * Copyright (c) 2015 Yang Qiao
+ * http://www.rtems.org/license/LICENSE
+#ifndef LIBBSP_ARM_RASPBERRYPI_FONT_DATA_H
+#define LIBBSP_ARM_RASPBERRYPI_FONT_DATA_H
+#define RPI_FONT_CHARS 256
+#define RPI_FONT_WIDTH 8
+#define RPI_FONT_HEIGHT 16
+#define RPI_FONT_SIZE (RPI_FONT_CHARS * RPI_FONT_HEIGHT)
+static unsigned char rpi_font[RPI_FONT_SIZE] = {
+ /* 0 0x00 '^@' */
+ 0x00, /* 00000000 */
+ /* 1 0x01 '^A' */
+ 0x7e, /* 01111110 */
+ 0x81, /* 10000001 */
+ 0xa5, /* 10100101 */
+ 0xbd, /* 10111101 */
+ 0x99, /* 10011001 */
+ /* 2 0x02 '^B' */
+ 0xff, /* 11111111 */
+ 0xdb, /* 11011011 */
+ 0xc3, /* 11000011 */
+ 0xe7, /* 11100111 */
+ /* 3 0x03 '^C' */
+ 0x6c, /* 01101100 */
+ 0xfe, /* 11111110 */
+ 0x7c, /* 01111100 */
+ 0x38, /* 00111000 */
+ 0x10, /* 00010000 */
+ /* 4 0x04 '^D' */
+ /* 5 0x05 '^E' */
+ 0x18, /* 00011000 */
+ 0x3c, /* 00111100 */
+ /* 6 0x06 '^F' */
+ /* 7 0x07 '^G' */
+ /* 8 0x08 '^H' */
+ /* 9 0x09 '^I' */
+ 0x66, /* 01100110 */
+ 0x42, /* 01000010 */
+ /* 10 0x0a '^J' */
+ /* 11 0x0b '^K' */
+ 0x1e, /* 00011110 */
+ 0x0e, /* 00001110 */
+ 0x1a, /* 00011010 */
+ 0x32, /* 00110010 */
+ 0x78, /* 01111000 */
+ 0xcc, /* 11001100 */
+ /* 12 0x0c '^L' */
+ /* 13 0x0d '^M' */
+ 0x3f, /* 00111111 */
+ 0x33, /* 00110011 */
+ 0x30, /* 00110000 */
+ 0x70, /* 01110000 */
+ 0xf0, /* 11110000 */
+ 0xe0, /* 11100000 */
+ /* 14 0x0e '^N' */
+ 0x7f, /* 01111111 */
+ 0x63, /* 01100011 */
+ 0x67, /* 01100111 */
+ 0xe6, /* 11100110 */
+ 0xc0, /* 11000000 */
+ /* 15 0x0f '^O' */
+ /* 16 0x10 '^P' */
+ 0x80, /* 10000000 */
+ 0xf8, /* 11111000 */
+ /* 17 0x11 '^Q' */
+ 0x02, /* 00000010 */
+ 0x06, /* 00000110 */
+ 0x3e, /* 00111110 */
+ /* 18 0x12 '^R' */
+ /* 19 0x13 '^S' */
+ /* 20 0x14 '^T' */
+ 0x7b, /* 01111011 */
+ 0x1b, /* 00011011 */
+ /* 21 0x15 '^U' */
+ 0xc6, /* 11000110 */
+ 0x60, /* 01100000 */
+ 0x0c, /* 00001100 */
+ /* 22 0x16 '^V' */
+ /* 23 0x17 '^W' */
+ /* 24 0x18 '^X' */
+ /* 25 0x19 '^Y' */
+ /* 26 0x1a '^Z' */
+ /* 27 0x1b '^[' */
+ /* 28 0x1c '^\' */
+ /* 29 0x1d '^]' */
+ 0x28, /* 00101000 */
+ /* 30 0x1e '^^' */
+ /* 31 0x1f '^_' */
+ /* 32 0x20 ' ' */
+ /* 33 0x21 '!' */
+ /* 34 0x22 '"' */
+ 0x24, /* 00100100 */
+ /* 35 0x23 '#' */
+ /* 36 0x24 '$' */
+ 0xc2, /* 11000010 */
+ 0x86, /* 10000110 */
+ /* 37 0x25 '%' */
+ /* 38 0x26 '&' */
+ 0x76, /* 01110110 */
+ 0xdc, /* 11011100 */
+ /* 39 0x27 ''' */
+ /* 40 0x28 '(' */
+ /* 41 0x29 ')' */
+ /* 42 0x2a '*' */
+ /* 43 0x2b '+' */
+ /* 44 0x2c ',' */
+ /* 45 0x2d '-' */
+ /* 46 0x2e '.' */
+ /* 47 0x2f '/' */
+ /* 48 0x30 '0' */
+ 0xd6, /* 11010110 */
+ /* 49 0x31 '1' */
+ /* 50 0x32 '2' */
+ /* 51 0x33 '3' */
+ /* 52 0x34 '4' */
+ 0x1c, /* 00011100 */
+ /* 53 0x35 '5' */
+ 0xfc, /* 11111100 */
+ /* 54 0x36 '6' */
+ /* 55 0x37 '7' */
+ /* 56 0x38 '8' */
+ /* 57 0x39 '9' */
+ /* 58 0x3a ':' */
+ /* 59 0x3b ';' */
+ /* 60 0x3c '<' */
+ /* 61 0x3d '=' */
+ /* 62 0x3e '>' */
+ /* 63 0x3f '?' */
+ /* 64 0x40 '@' */
+ 0xde, /* 11011110 */
+ /* 65 0x41 'A' */
+ /* 66 0x42 'B' */
+ /* 67 0x43 'C' */
+ /* 68 0x44 'D' */
+ /* 69 0x45 'E' */
+ 0x62, /* 01100010 */
+ 0x68, /* 01101000 */
+ /* 70 0x46 'F' */
+ /* 71 0x47 'G' */
+ 0x3a, /* 00111010 */
+ /* 72 0x48 'H' */
+ /* 73 0x49 'I' */
+ /* 74 0x4a 'J' */
+ /* 75 0x4b 'K' */
+ /* 76 0x4c 'L' */
+ /* 77 0x4d 'M' */
+ 0xee, /* 11101110 */
+ /* 78 0x4e 'N' */
+ 0xf6, /* 11110110 */
+ 0xce, /* 11001110 */
+ /* 79 0x4f 'O' */
+ /* 80 0x50 'P' */
+ /* 81 0x51 'Q' */
+ /* 82 0x52 'R' */
+ /* 83 0x53 'S' */
+ /* 84 0x54 'T' */
+ 0x5a, /* 01011010 */
+ /* 85 0x55 'U' */
+ /* 86 0x56 'V' */
+ /* 87 0x57 'W' */
+ /* 88 0x58 'X' */
+ /* 89 0x59 'Y' */
+ /* 90 0x5a 'Z' */
+ /* 91 0x5b '[' */
+ /* 92 0x5c '\' */
+ /* 93 0x5d ']' */
+ /* 94 0x5e '^' */
+ /* 95 0x5f '_' */
+ /* 96 0x60 '`' */
+ /* 97 0x61 'a' */
+ /* 98 0x62 'b' */
+ /* 99 0x63 'c' */
+ /* 100 0x64 'd' */
+ /* 101 0x65 'e' */
+ /* 102 0x66 'f' */
+ 0x36, /* 00110110 */
+ /* 103 0x67 'g' */
+ /* 104 0x68 'h' */
+ /* 105 0x69 'i' */
+ /* 106 0x6a 'j' */
+ /* 107 0x6b 'k' */
+ /* 108 0x6c 'l' */
+ /* 109 0x6d 'm' */
+ 0xec, /* 11101100 */
+ /* 110 0x6e 'n' */
+ /* 111 0x6f 'o' */
+ /* 112 0x70 'p' */
+ /* 113 0x71 'q' */
+ /* 114 0x72 'r' */
+ /* 115 0x73 's' */
+ /* 116 0x74 't' */
+ /* 117 0x75 'u' */
+ /* 118 0x76 'v' */
+ /* 119 0x77 'w' */
+ /* 120 0x78 'x' */
+ /* 121 0x79 'y' */
+ /* 122 0x7a 'z' */
+ /* 123 0x7b '{' */
+ /* 124 0x7c '|' */
+ /* 125 0x7d '}' */
+ /* 126 0x7e '~' */
+ /* 127 0x7f '' */
+ /* 128 0x80 'â¬' */
+ /* 129 0x81 'Â' */
+ /* 130 0x82 'â' */
+ /* 131 0x83 'Æ' */
+ /* 132 0x84 'â' */
+ /* 133 0x85 'â¦' */
+ /* 134 0x86 'â ' */
+ /* 135 0x87 'â¡' */
+ /* 136 0x88 'Ë' */
+ /* 137 0x89 'â°' */
+ /* 138 0x8a 'Å ' */
+ /* 139 0x8b 'â¹' */
+ /* 140 0x8c 'Å' */
+ /* 141 0x8d 'Â' */
+ /* 142 0x8e 'Ž' */
+ /* 143 0x8f 'Â' */
+ /* 144 0x90 'Â' */
+ /* 145 0x91 'â' */
+ 0xd8, /* 11011000 */
+ 0x6e, /* 01101110 */
+ /* 146 0x92 'â' */
+ /* 147 0x93 'â' */
+ /* 148 0x94 'â' */
+ /* 149 0x95 'â¢' */
+ /* 150 0x96 'â' */
+ /* 151 0x97 'â' */
+ /* 152 0x98 'Ë' */
+ /* 153 0x99 'â¢' */
+ /* 154 0x9a 'Å¡' */
+ /* 155 0x9b 'âº' */
+ /* 156 0x9c 'Å' */
+ 0x64, /* 01100100 */
+ /* 157 0x9d 'Â' */
+ /* 158 0x9e 'ž' */
+ 0xc4, /* 11000100 */
+ /* 159 0x9f 'Ÿ' */
+ /* 160 0xa0 'Â ' */
+ /* 161 0xa1 '¡' */
+ /* 162 0xa2 '¢' */
+ /* 163 0xa3 '£' */
+ /* 164 0xa4 '¤' */
+ /* 165 0xa5 'Â¥' */
+ /* 166 0xa6 '¦' */
+ /* 167 0xa7 '§' */
+ /* 168 0xa8 '¨' */
+ /* 169 0xa9 '©' */
+ /* 170 0xaa 'ª' */
+ /* 171 0xab '«' */
+ /* 172 0xac '¬' */
+ 0x9a, /* 10011010 */
+ /* 173 0xad 'Â' */
+ /* 174 0xae '®' */
+ /* 175 0xaf '¯' */
+ /* 176 0xb0 '°' */
+ 0x11, /* 00010001 */
+ 0x44, /* 01000100 */
+ /* 177 0xb1 '±' */
+ 0x55, /* 01010101 */
+ 0xaa, /* 10101010 */
+ /* 178 0xb2 '²' */
+ 0xdd, /* 11011101 */
+ 0x77, /* 01110111 */
+ /* 179 0xb3 '³' */
+ /* 180 0xb4 '´' */
+ /* 181 0xb5 'µ' */
+ /* 182 0xb6 '¶' */
+ /* 183 0xb7 '·' */
+ /* 184 0xb8 '¸' */
+ /* 185 0xb9 '¹' */
+ /* 186 0xba 'º' */
+ /* 187 0xbb '»' */
+ /* 188 0xbc '¼' */
+ /* 189 0xbd '½' */
+ /* 190 0xbe '¾' */
+ /* 191 0xbf '¿' */
+ /* 192 0xc0 'Ã' */
+ 0x1f, /* 00011111 */
+ /* 193 0xc1 'Ã' */
+ /* 194 0xc2 'Ã' */
+ /* 195 0xc3 'Ã' */
+ /* 196 0xc4 'Ã' */
+ /* 197 0xc5 'Ã
+ /* 198 0xc6 'Ã' */
+ /* 199 0xc7 'Ã' */
+ 0x37, /* 00110111 */
+ /* 200 0xc8 'Ã' */
+ /* 201 0xc9 'Ã' */
+ /* 202 0xca 'Ã' */
+ 0xf7, /* 11110111 */
+ /* 203 0xcb 'Ã' */
+ /* 204 0xcc 'Ã' */
+ /* 205 0xcd 'Ã' */
+ /* 206 0xce 'Ã' */
+ /* 207 0xcf 'Ã' */
+ /* 208 0xd0 'Ã' */
+ /* 209 0xd1 'Ã' */
+ /* 210 0xd2 'Ã' */
+ /* 211 0xd3 'Ã' */
+ /* 212 0xd4 'Ã' */
+ /* 213 0xd5 'Ã' */
+ /* 214 0xd6 'Ã' */
+ /* 215 0xd7 'Ã' */
+ /* 216 0xd8 'Ã' */
+ /* 217 0xd9 'Ã' */
+ /* 218 0xda 'Ã' */
+ /* 219 0xdb 'Ã' */
+ /* 220 0xdc 'Ã' */
+ /* 221 0xdd 'Ã' */
+ /* 222 0xde 'Ã' */
+ 0x0f, /* 00001111 */
+ /* 223 0xdf 'Ã' */
+ /* 224 0xe0 'Ã ' */
+ /* 225 0xe1 'á' */
+ /* 226 0xe2 'â' */
+ /* 227 0xe3 'ã' */
+ /* 228 0xe4 'ä' */
+ /* 229 0xe5 'Ã¥' */
+ /* 230 0xe6 'æ' */
+ /* 231 0xe7 'ç' */
+ /* 232 0xe8 'è' */
+ /* 233 0xe9 'é' */
+ /* 234 0xea 'ê' */
+ /* 235 0xeb 'ë' */
+ /* 236 0xec 'ì' */
+ /* 237 0xed 'Ã' */
+ 0x03, /* 00000011 */
+ 0xf3, /* 11110011 */
+ /* 238 0xee 'î' */
+ /* 239 0xef 'ï' */
+ /* 240 0xf0 'ð' */
+ /* 241 0xf1 'ñ' */
+ /* 242 0xf2 'ò' */
+ /* 243 0xf3 'ó' */
+ /* 244 0xf4 'ô' */
+ /* 245 0xf5 'õ' */
+ /* 246 0xf6 'ö' */
+ /* 247 0xf7 '÷' */
+ /* 248 0xf8 'ø' */
+ /* 249 0xf9 'ù' */
+ /* 250 0xfa 'ú' */
+ /* 251 0xfb 'û' */
+ /* 252 0xfc 'ü' */
+ /* 253 0xfd 'ý' */
+ /* 254 0xfe 'þ' */
+ /* 255 0xff 'ÿ' */
+#endif
diff --git a/c/src/lib/libbsp/arm/raspberrypi/console/outch.c b/c/src/lib/libbsp/arm/raspberrypi/console/outch.c
index 0000000..e04d273
--- /dev/null
+++ b/c/src/lib/libbsp/arm/raspberrypi/console/outch.c
@@ -0,0 +1,405 @@
+ * @file
+ * @brief displaying characters on the console
+ * based on work by:
+ * Copyright (C) 1998 Eric Valette (valette at crf.canon.fr)
+ * Canon Centre Recherche France.
+ * Till Straumann <strauman at slac.stanford.edu>, 2003/9:
+ * - added handling of basic escape sequences (cursor movement
+ * and erasing; just enough for the line editor 'libtecla' to
+ * work...)
+#include <bsp.h>
+#include <bsp/vc.h>
+#include <rtems/fb.h>
+#include <stdlib.h>
+#include <string.h>
+#include "font_data.h"
+// extern void wr_cursor(int, unsigned short);
+#define TAB_SPACE 4
+#define CONSOLE_BG_COL 0x00
+#define CONSOLE_FG_COL 0xa0
+static void* fb_mem = NULL;
+unsigned short maxCol;
+unsigned short maxRow;
+static unsigned short bytes_per_pixel;
+static unsigned int bytes_per_line;
+static unsigned int bytes_per_char_line;
+static unsigned char row;
+static unsigned char column;
+static unsigned int nLines;
+static uint32_t fgx,bgx,eorx;
+static const int video_font_draw_table32[16][4] = {
+ {0x00000000, 0x00000000, 0x00000000, 0x00000000},
+ {0x00000000, 0x00000000, 0x00000000, 0x00ffffff},
+ {0x00000000, 0x00000000, 0x00ffffff, 0x00000000},
+ {0x00000000, 0x00000000, 0x00ffffff, 0x00ffffff},
+ {0x00000000, 0x00ffffff, 0x00000000, 0x00000000},
+ {0x00000000, 0x00ffffff, 0x00000000, 0x00ffffff},
+ {0x00000000, 0x00ffffff, 0x00ffffff, 0x00000000},
+ {0x00000000, 0x00ffffff, 0x00ffffff, 0x00ffffff},
+ {0x00ffffff, 0x00000000, 0x00000000, 0x00000000},
+ {0x00ffffff, 0x00000000, 0x00000000, 0x00ffffff},
+ {0x00ffffff, 0x00000000, 0x00ffffff, 0x00000000},
+ {0x00ffffff, 0x00000000, 0x00ffffff, 0x00ffffff},
+ {0x00ffffff, 0x00ffffff, 0x00000000, 0x00000000},
+ {0x00ffffff, 0x00ffffff, 0x00000000, 0x00ffffff},
+ {0x00ffffff, 0x00ffffff, 0x00ffffff, 0x00000000},
+ {0x00ffffff, 0x00ffffff, 0x00ffffff, 0x00ffffff}
+static void
+scroll(void)
+ int i, j; /* Counters */
+ uint8_t *pt_scroll, *pt_bitmap; /* Pointers on the bit-map */
+ pt_bitmap = fb_mem;
+ j = 0;
+ pt_bitmap = pt_bitmap + j;
+ pt_scroll = pt_bitmap + bytes_per_char_line;
+ for (i = j; i < maxRow-1 ; i++) {
+ memcpy(pt_bitmap, pt_scroll, bytes_per_char_line);
+ pt_bitmap = pt_bitmap + bytes_per_char_line;
+ * Blank characters are displayed on the last line.
+ memset(pt_bitmap, 0, bytes_per_char_line);
+static void
+doCRNL(int cr, int nl)
+ if (nl) {
+ if (++row == maxRow) {
+ scroll(); /* Scroll the screen now */
+ row = maxRow - 1;
+ nLines++;
+ if (cr)
+ column = 0;
+ /* Move cursor on the next location */
+ if (cr || nl)
+ //wr_cursor(row * maxCol + column, ioCrtBaseAddr);
+int (*videoHook)(char, int *)=0;
+static void
+advanceCursor(void)
+ if (++column == maxCol)
+ doCRNL(1,1);
+ else
+static void
+gotorc(int r, int c)
+ column = c;
+ row = r;
+ // wr_cursor(row * maxCol + column, ioCrtBaseAddr);
+static void
+video_drawchars(int r, int c, unsigned char ch)
+ if (fb_mem == NULL)
+ return;
+ uint8_t *cdat, *dest, *dest0;
+ int rows, offset;
+ offset = r * bytes_per_char_line + c * bytes_per_pixel*RPI_FONT_WIDTH;
+ dest0 = fb_mem + offset;
+ // case GDF_32BIT_X888RGB:
+ cdat = rpi_font + ch * RPI_FONT_HEIGHT;
+ for (rows = RPI_FONT_HEIGHT, dest = dest0;
+ rows--; dest += bytes_per_line) {
+ uint8_t bits = *cdat++;
+ ((uint32_t *) dest)[0] =
+ (video_font_draw_table32
+ [bits >> 4][0] & eorx) ^ bgx;
+ ((uint32_t *) dest)[1] =
+ [bits >> 4][1] & eorx) ^ bgx;
+ ((uint32_t *) dest)[2] =
+ [bits >> 4][2] & eorx) ^ bgx;
+ ((uint32_t *) dest)[3] =
+ [bits >> 4][3] & eorx) ^ bgx;
+ ((uint32_t *) dest)[4] =
+ [bits & 15][0] & eorx) ^ bgx;
+ ((uint32_t *) dest)[5] =
+ [bits & 15][1] & eorx) ^ bgx;
+ ((uint32_t *) dest)[6] =
+ [bits & 15][2] & eorx) ^ bgx;
+ ((uint32_t *) dest)[7] =
+ [bits & 15][3] & eorx) ^ bgx;
+#define ESC ((char)27)
+/* erase current location without moving the cursor */
+#define BLANK ((char)0x7f)
+static void
+videoPutChar(char ch)
+ switch (ch) {
+ case '\b': {
+ if (column) column--;
+ /* Move cursor on the previous location */
+ return;
+ case '\t': {
+ int i;
+ i = TAB_SPACE - (column & (TAB_SPACE - 1));
+ column += i;
+ if (column >= maxCol) {
+ doCRNL(1,1);
+ return;
+ // while (i--) *pt_bitmap++ = ' ' | attribute;
+ return;
+ case '\n': {
+ doCRNL(0,1);
+ return;
+ case 7: { /* Bell code must be inserted here */
+ return;
+ case '\r' : {
+ doCRNL(1,0);
+ return;
+ case BLANK: {
+ // *pt_bitmap = ' ' | attribute;
+ /* DONT move the cursor... */
+ return;
+ default: {
+ // *pt_bitmap = (unsigned char)ch | attribute;
+ video_drawchars(row, column, ch);
+ advanceCursor();
+ return;
+/* trivial state machine to handle escape sequences:
+ * KEY: esc V [ DCABHKJ esc |
+ * STATE: 0 -----> 27 -----> '[' ----------> -1 -----
+ * KEY: | \other \ other \ other \ other
+ * in state '-1', the DCABHKJ cases are handled
+ * (cursor motion and screen clearing)
+#define DONE (-1)
+static int
+handleEscape(int oldState, char ch)
+int rval = 0;
+int ro,co;
+ switch ( oldState ) {
+ case DONE: /* means the previous char terminated an ESC sequence... */
+ case 0:
+ if ( 27 == ch ) {
+ rval = 27; /* START of an ESC sequence */
+ break;
+ case 27:
+ if ( '[' == ch ) {
+ rval = ch; /* received ESC '[', so far */
+ } else {
+ /* dump suppressed 'ESC'; outch will append the char */
+ videoPutChar(ESC);
+ break;
+ case '[':
+ /* handle 'ESC' '[' sequences here */
+ ro = row; co = column;
+ rval = DONE; /* done */
+ switch (ch) {
+ case 'D': /* left */
+ if ( co > 0 ) co--;
+ break;
+ case 'C': /* right */
+ if ( co < maxCol ) co++;
+ break;
+ case 'A': /* up */
+ if ( ro > 0 ) ro--;
+ break;
+ case 'B': /* down */
+ if ( ro < maxRow ) ro++;
+ break;
+ case 'H': /* home */
+ ro = co = 0;
+ break;
+ case 'K': /* clear to end of line */
+ while ( column < maxCol - 1 )
+ videoPutChar(' ');
+ videoPutChar(BLANK);
+ break;
+ case 'J': /* clear to end of screen */
+ while ( ((row < maxRow-1) || (column < maxCol-1)) )
+ break;
+ default:
+ videoPutChar('[');
+ /* DONT move the cursor */
+ ro = -1;
+ rval = 0;
+ break;
+ // /* reset cursor */
+ if ( ro >= 0)
+ gotorc(ro,co);
+ default:
+ break;
+ return rval;
+static void
+clear_screen(void)
+ int i,j;
+ for (j = 0; j < maxRow; j++) {
+ for (i = 0; i < maxCol; i++) {
+ column = 0;
+ row = 0;
+void
+_RPI_outch(char c)
+static int escaped = 0;
+ if ( ! (escaped = handleEscape(escaped, c)) ) {
+ if ( '\n' == c )
+ videoPutChar('\r');
+ videoPutChar(c);
+extern int fb_init(void);
+extern int raspberrypi_get_fix_screen_info( struct fb_fix_screeninfo *info );
+extern int raspberrypi_get_var_screen_info( struct fb_var_screeninfo *info );
+void
+_RPI_initVideo(void)
+ int ret = fb_init();
+ if (ret != -2 && ret != 0)
+ return;
+ struct fb_var_screeninfo fb_var_info;
+ struct fb_fix_screeninfo fb_fix_info;
+ raspberrypi_get_var_screen_info(&fb_var_info);
+ raspberrypi_get_fix_screen_info(&fb_fix_info);
+ maxCol = fb_var_info.xres/RPI_FONT_WIDTH;
+ maxRow = fb_var_info.yres/RPI_FONT_HEIGHT;
+ bytes_per_pixel = fb_var_info.bits_per_pixel/8;
+ bytes_per_line = bytes_per_pixel*fb_var_info.xres;
+ bytes_per_char_line = RPI_FONT_HEIGHT*bytes_per_line;
+ fb_mem = fb_fix_info.smem_start;
+ column = 0;
+ row = 0;
+ nLines = 0;
+ fgx = (CONSOLE_FG_COL << 24) |
+ (CONSOLE_FG_COL << 16) |
+ (CONSOLE_FG_COL << 8) |
+ CONSOLE_FG_COL;
+ bgx = (CONSOLE_BG_COL << 24) |
+ (CONSOLE_BG_COL << 16) |
+ (CONSOLE_BG_COL << 8) |
+ CONSOLE_BG_COL;
+ eorx = fgx ^ bgx;
+ clear_screen();
+/* for old DOS compatibility n-curses type of applications */
+void gotoxy( int x, int y );
+int whereX( void );
+int whereY( void );
+ gotorc(y,x);
+int whereX( void )
+ return row;
+int whereY( void )
+ return column;
diff --git a/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h b/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
index a3a0f71..55c932b 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
+++ b/c/src/lib/libbsp/arm/raspberrypi/include/bsp.h
@@ -37,6 +37,9 @@ extern "C" {
#define BSP_FEATURE_IRQ_EXTENSION
+void _RPI_initVideo(void);
+void _RPI_outch (char);
void rpi_init_cmdline(void);
const char* rpi_cmdline(void);
const char* rpi_cmdline_arg(const char* arg);
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c
index 884d5ef..3c66459 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstart.c
@@ -7,6 +7,13 @@
* Copyright (c) 2013 by Alan Cudmore
@@ -27,4 +34,5 @@ void bsp_start(void)
bsp_interrupt_initialize();
rpi_init_cmdline();
+ _RPI_initVideo();
diff --git a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
index 7d72fe7..ce71c63 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
+++ b/c/src/lib/libbsp/arm/raspberrypi/startup/bspstarthooks.c
@@ -31,6 +31,7 @@
void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
rpi_init_cmdline();
+ _RPI_initVideo();
2.1.0
