RTEMS lwIP porting
Daniel Gutson
daniel.gutson at tallertechnologies.com
Mon Aug 10 17:29:10 UTC 2015
El 10/8/2015 14:25, "ragu nath" <ragunath3252 at gmail.com> escribió:
> Hi Daniel,
> Most of the work comes from your/marcos port.
Roger that.
> The aim was to
> integrate a working lwIP port to RTEMS Source Builder.
> I took the port & understood what has been done. Then I wrote an
> application that uses lwip stack on RTEMS.
> I ran into some issues and fixed them.
Did you post them? (Marcos, are we aware of such bugs and fixes? I am very
interested about this matter).
> Now with the changes, the
> application works.
> I discussed with chris on how to integrate the changes to RSB. As per
> his suggestion, the idea is to separate lwip base and drivers. The
> lwip base is compiled as a library using RSB and driver will be
> compiled as a separate library . The application can then link to it.
> The driver is also from your port with some fixes.
> I am not aware of the issue with POSIX API. Once we get this working,
> I am ready to implement with native api in the future.
> Thanks,
> Ragunath
> On Mon, Aug 10, 2015 at 9:50 PM, Daniel Gutson
> <daniel.gutson at tallertechnologies.com> wrote:
> > On Mon, Aug 10, 2015 at 10:48 AM, Joel Sherrill
> > <joel.sherrill at oarcorp.com> wrote:
> >> On 8/9/2015 4:57 AM, ragu nath wrote:
> >>> Hi All,
> >>> I have sent the patches for building lwIP from RSB. First patch
> >>> contains changes for RTEMS Resource Builder. The second patch is RTEMS
> >>> specific changes that will be applied to lwIP base.This patch contains
> >>> only lwIP sources. I will be sending another patch for the driver to
> >>> be used with lwIP. The application can then link to both of the
> >>> libararies (lwip & driver).
> >> Has the LWIP patch been submitted upstream to the LWIP maintainers?
> >> And where do drivers come from? From what I have seen, LWIP seems
> >> to not have a unified base of device drivers. Would this just be to
> >> build the basic stack and then it is the users responsibility to
> >> find and compile a driver?
> > Also, what from these comes from our work? Sorry that I'm a little bit
> > confused and arrived late to the
> > subject. BTW, there is still work to do, since the state we left
> > working LWIP is using the posix layer,
> > which we observed introduces important overhead, so a further step is
> > to reimplement the LWIP's HAL
> > using the RTEMS native API instead. Any plan for that?
> > Thanks!
> > Daniel.
> >> What is your RTEMS configuration so I can try it?
> >> I will try to build it today.
> >> Joel Sherrill, Ph.D. Director of Research & Development
> >> joel.sherrill at OARcorp.com On-Line Applications Research
> >> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> >> Support Available (256) 722-9985
> >> _______________________________________________
> >> devel mailing list
> >> devel at rtems.org
> >> http://lists.rtems.org/mailman/listinfo/devel
> > Daniel F. Gutson
> > Chief Engineering Officer, SPD
> > San Lorenzo 47, 3rd Floor, Office 5
> > Córdoba, Argentina
> > Phone: +54 351 4217888 / +54 351 4218211
> > Skype: dgutson
> > LinkedIn: http://ar.linkedin.com/in/danielgutson
> ragu
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150810/51ba6c03/attachment-0002.html>
