[PATCH] GSoC: Cache configurations Raspberry Pi 2 support
Rohini Kulkarni krohini1593 at gmail.com
Mon Aug 10 20:23:53 UTC 2015
I did a readelf on the rki elf. I have attached the file. Is this
information helping in anyway?
On Wed, Aug 5, 2015 at 9:16 PM, Gedare Bloom <gedare at gwu.edu> wrote:
> In arm/shared/startup/linkcmds.base these barriers are used to add
> gaps in the memory layout at link-time to accommodate for the size
> requirements of the MMU. xbarrier aligns the executable region,
> robarrier aligns the read-only memory, and rwbarrier aligns the
> read-write memory.
> On Tue, Aug 4, 2015 at 6:23 PM, Rohini Kulkarni <krohini1593 at gmail.com>
> wrote:
> > On Wed, Aug 5, 2015 at 1:47 AM, Gedare Bloom <gedare at gwu.edu> wrote:
> >> On Tue, Aug 4, 2015 at 2:18 PM, Rohini Kulkarni <krohini1593 at gmail.com>
> >> wrote:
> >> > On Tue, Jul 28, 2015 at 5:51 AM, Pavel Pisa <ppisa4lists at pikron.com>
> >> > wrote:
> >> >> Hello Rohini and Gedare,
> >> >> On Friday 24 of July 2015 15:33:03 Gedare Bloom wrote:
> >> >> > What are the values of bsp_section_bss_begin, and
> >> >> > bsp_section_bss_size?
> >> >> > Apparently, the memset is trying to write into the .text (code)
> >> >> > section, which is a very bad thing to do indeed.
> >> >> Qiao Yang in RPi 1 BSP now works in the similar
> >> >> area to enable right graphic memory mapping.
> >> >> So my guess is that there could be problem caused
> >> >> by used MMU mode granularity, which is is 1 MB so
> >> >> if RO and RW sections are present in the same 1MB
> >> >> aligned block ten there can be problem. It depends
> >> >> which section is filled the first. If data and then
> >> >> text (RO) the troubles begin. If the order is vice
> >> >> versa then some part of text can be RW instead of RO,
> >> >> but it should work and cache should not be a problem.
> >> >> But I have not dig into this case too much.
> >> >> Only short glimpse.
> >> >> One option is to define 1 MB alignment between text
> >> >> ad data for RPi case. There is quite a lot of memory
> >> >> when compared to most RTEMS embedded targets to the
> >> >> waste is not so important.
> >> > I didn't quite get what this means. I have no clue on how to proceed
> >> > with
> >> > this.
> >> The MMU defines memory regions in 1MB chunks. Each chunk can have its
> >> own permissions (read-only, or read-write) set. If the .text and .data
> >> (or some other section) overlaps in the same 1MB chunk, and the wrong
> >> permission gets set, then there can be a problem e.g. part of .data
> >> might be RO or part of .text might be RW.
> >> Did you try the code Sebastian posted? to change the robarrier to
> >> rwbarrier?
> > What exactly are these barriers?
> >> Gedare
> >> >> Best wishes,
> >> >>               Pavel
> >> >> On Friday 24 of July 2015 21:55:00 Rohini Kulkarni wrote:
> >> >> > Hi,
> >> >> > I have attached the report containing outputs of arm-rtems4.11-size
> >> >> > and
> >> >> > arm-rtems4.11-nm -S.
> >> >> > From arm-rtems4.11-nm -S I don't see how memset() is accessing
> .text
> >> >> > section. The start and end values for both are not overlapping.
> >> >> > On Fri, Jul 24, 2015 at 7:03 PM, Gedare Bloom <gedare at gwu.edu>
> wrote:
> >> >> > > On Fri, Jul 24, 2015 at 3:30 AM, Rohini Kulkarni
> >> >> > > wrote:
> >> >> > > > On 24 Jul 2015 12:35, "Sebastian Huber" <
> >> >> > > sebastian.huber at embedded-brains.de>
> >> >> > > > wrote:
> >> >> > > >> On 23/07/15 23:24, Rohini Kulkarni wrote:
> >> >> > > >>> I could finally get back to this issue. I used Pi 1 for
> >> >> > > >>> debugging,
> >> >> > > >>> but the reason for this problem will apply to Pi 2 also.
> >> >> > > >>> With text section set to ARMV7_MMU_CODE_CACHED ( which
> implies
> >> >> > > >>> read
> >> >> > > only)
> >> >> > > >>> , a data abort exception occurs with memset() inside
> >> >> > > bsp_start_clear_bss()
> >> >> > > >>> function. An illegal write access to an address according to
> >> >> > > >>> me.
> >> >> > > >> Which exception and which address? Something is not working
> >> >> > > >> here.
> >> >> > > > This is a part of the debugging output. When I used
> >> >> > > ARMV7_MMU_CODE_CACHED.
> >> >> > > > (gdb) s
> >> >> > > > bsp_start_clear_bss ()
> >> >> > > >     at
> >> >> > > > ../../../../../.././raspberrypi/lib/include/bsp/start.h:126
> >> >> > > > 126      memset(bsp_section_bss_begin, 0, (size_t)
> >> >> > > > bsp_section_bss_size);
> >> >> > > > (gdb) s
> >> >> > > > memset (m=0x1157e0, c=0, n=64176)
> >> >> > > >     at ../../../../../gcc-4.9.2/newlib/libc/string/memset.c:59
> >> >> > > > 59    ../../../../../gcc-4.9.2/newlib/libc/string/memset.c: No
> >> >> > > > such
> >> >> > > > file
> >> >> > > or
> >> >> > > > directory.
> >> >> > > > (gdb) s
> >> >> > > > 49    in ../../../../../gcc-4.9.2/newlib/libc/string/memset.c
> >> >> > > > (gdb) s
> >> >> > > > _ARMV4_Exception_data_abort_default ()
> >> >> > > >     at
> ../../../../../../../../rtems-local/rtems/c/src/../../cpukit/score/cpu/ar
> >> >> > >m/armv4-exception-default.S:71
> >> >> > > > 71        sub    sp, #MORE_CONTEXT_SIZE
> >> >> > > > When I set text section flag to ARMV7_MMU_READ_WRITE, the
> system
> >> >> > > > starts
> >> >> > > > successfully.
> >> >> > > >> Sebastian Huber, embedded brains GmbH
> >> >> > > >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> >> > > >> Phone   : +49 89 189 47 41-16
> >> >> > > >> Fax     : +49 89 189 47 41-09
> >> >> > > >> E-Mail  : sebastian.huber at embedded-brains.de
> >> >> > > >> PGP     : Public key available on request.
> >> >> > > >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> des
> >> >> > > >> EHUG.
> >> >> > > > _______________________________________________
> >> >> > > > devel mailing list
> >> >> > > > devel at rtems.org
> >> >> > > > http://lists.rtems.org/mailman/listinfo/devel
> >> > Rohini Kulkarni
> >> > devel mailing list
> >> > devel at rtems.org
> > Rohini Kulkarni
Rohini Kulkarni
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150811/982d0a26/attachment-0002.html>
ELF Header:
  Magic:   7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
  Class:                             ELF32
  Data:                              2's complement, little endian
  Version:                           1 (current)
  OS/ABI:                            UNIX - System V
  ABI Version:                       0
  Type:                              EXEC (Executable file)
  Machine:                           ARM
  Version:                           0x1
  Entry point address:               0x8040
  Start of program headers:          52 (bytes into file)
  Start of section headers:          8353528 (bytes into file)
  Flags:                             0x5000202, has entry point, Version5 EABI, <unknown>
  Size of this header:               52 (bytes)
  Size of program headers:           32 (bytes)
  Number of program headers:         4
  Size of section headers:           40 (bytes)
  Number of section headers:         30
  Section header string table index: 27
Section Headers:
  [Nr] Name              Type            Addr     Off    Size   ES Flg Lk Inf Al
  [ 0]                   NULL            00000000 000000 000000 00      0   0  0
  [ 1] .start            PROGBITS        00008000 0000b8 000360 00  AX  0   0  4
  [ 2] .text             PROGBITS        00008360 000418 0934a4 00 WAX  0   0  8
  [ 3] .init             PROGBITS        0009b804 0938bc 000018 00  AX  0   0  4
  [ 4] .fini             PROGBITS        0009b81c 0938d4 000018 00  AX  0   0  4
  [ 5] .robarrier        NOBITS          0009b834 0938ec 0647cc 00  WA  0   0  1
  [ 6] .rodata           PROGBITS        00100000 093900 0106b8 00   A  0   0  8
  [ 7] .ARM.exidx        ARM_EXIDX       001106b8 0a3fb8 000008 00  AL  2   0  4
  [ 8] .eh_frame         PROGBITS        001106c0 0a3fc0 000048 00   A  0   0  4
  [ 9] .init_array       INIT_ARRAY      00110708 0a4008 000004 00  WA  0   0  4
  [10] .fini_array       FINI_ARRAY      0011070c 0a400c 000004 00  WA  0   0  4
  [11] .jcr              PROGBITS        00110710 0a4010 000004 00  WA  0   0  4
  [12] .rtemsroset       PROGBITS        00110714 0a4014 000124 00   A  0   0  4
  [13] .vector           NOBITS          00000000 0000b4 005040 00  WA  0   0  1
  [14] .data             PROGBITS        00110838 0a4138 004ea0 00  WA  0   0  8
  [15] .bss              NOBITS          001156e0 0a8fd8 00fab0 00  WA  0   0 32
  [16] .work             NOBITS          00125190 0a8fd8 7ed6e70 00  WA  0   0  1
  [17] .comment          PROGBITS        00000000 0a8fd8 00006c 01  MS  0   0  1
  [18] .debug_aranges    PROGBITS        00000000 0a9048 006c28 00      0   0  8
  [19] .debug_info       PROGBITS        00000000 0afc70 4dfa7d 00      0   0  1
  [20] .debug_abbrev     PROGBITS        00000000 58f6ed 083bab 00      0   0  1
  [21] .debug_line       PROGBITS        00000000 613298 0d2c8d 00      0   0  1
  [22] .debug_frame      PROGBITS        00000000 6e5f28 015af0 00      0   0  4
  [23] .debug_str        PROGBITS        00000000 6fba18 031981 01  MS  0   0  1
  [24] .debug_loc        PROGBITS        00000000 72d399 0bb83b 00      0   0  1
  [25] .debug_ranges     PROGBITS        00000000 7e8bd4 00e9d0 00      0   0  1
  [26] .ARM.attributes   ARM_ATTRIBUTES  00000000 7f75a4 000036 00      0   0  1
  [27] .shstrtab         STRTAB          00000000 7f75da 00011d 00      0   0  1
  [28] .symtab           SYMTAB          00000000 7f7ba8 022280 10     29 6468  4
  [29] .strtab           STRTAB          00000000 819e28 01265b 00      0   0  1
Key to Flags:
  W (write), A (alloc), X (execute), M (merge), S (strings)
  I (info), L (link order), G (group), T (TLS), E (exclude), x (unknown)
  O (extra OS processing required) o (OS specific), p (processor specific)
There are no section groups in this file.
Program Headers:
  Type           Offset   VirtAddr   PhysAddr   FileSiz MemSiz  Flg Align
  EXIDX          0x0a3fb8 0x001106b8 0x001106b8 0x00008 0x00008 R   0x4
  LOAD           0x0000b4 0x00000000 0x00000000 0x00000 0x05040 RW  0x1
  LOAD           0x0000b8 0x00008000 0x00008000 0x93834 0xf8000 RWE 0x8
  LOAD           0x093900 0x00100000 0x00100000 0x156d8 0x7efc000 RW  0x20
 Section to Segment mapping:
  Segment Sections...
   00     .ARM.exidx
   01     .vector
   02     .start .text .init .fini .robarrier
   03     .rodata .ARM.exidx .eh_frame .init_array .fini_array .jcr .rtemsroset .data .bss .work
There is no dynamic section in this file.
There are no relocations in this file.
Unwind table index '.ARM.exidx' at offset 0xa3fb8 contains 1 entries:
0x9b300 <__divdi3>: 0x1 [cantunwind]
Symbol table '.symtab' contains 8744 entries:
   Num:    Value  Size Type    Bind   Vis      Ndx Name
     0: 00000000     0 NOTYPE  LOCAL  DEFAULT  UND
     1: 00008000     0 SECTION LOCAL  DEFAULT    1
     2: 00008360     0 SECTION LOCAL  DEFAULT    2
     3: 0009b804     0 SECTION LOCAL  DEFAULT    3
     4: 0009b81c     0 SECTION LOCAL  DEFAULT    4
     5: 0009b834     0 SECTION LOCAL  DEFAULT    5
     6: 00100000     0 SECTION LOCAL  DEFAULT    6
     7: 001106b8     0 SECTION LOCAL  DEFAULT    7
     8: 001106c0     0 SECTION LOCAL  DEFAULT    8
     9: 00110708     0 SECTION LOCAL  DEFAULT    9
    10: 0011070c     0 SECTION LOCAL  DEFAULT   10
    11: 00110710     0 SECTION LOCAL  DEFAULT   11
    12: 00110714     0 SECTION LOCAL  DEFAULT   12
    13: 00000000     0 SECTION LOCAL  DEFAULT   13
    14: 00110838     0 SECTION LOCAL  DEFAULT   14
    15: 001156e0     0 SECTION LOCAL  DEFAULT   15
    16: 00125190     0 SECTION LOCAL  DEFAULT   16
    17: 00000000     0 SECTION LOCAL  DEFAULT   17
    18: 00000000     0 SECTION LOCAL  DEFAULT   18
    19: 00000000     0 SECTION LOCAL  DEFAULT   19
    20: 00000000     0 SECTION LOCAL  DEFAULT   20
    21: 00000000     0 SECTION LOCAL  DEFAULT   21
    22: 00000000     0 SECTION LOCAL  DEFAULT   22
    23: 00000000     0 SECTION LOCAL  DEFAULT   23
    24: 00000000     0 SECTION LOCAL  DEFAULT   24
    25: 00000000     0 SECTION LOCAL  DEFAULT   25
    26: 00000000     0 SECTION LOCAL  DEFAULT   26
    27: 00000000     0 FILE    LOCAL  DEFAULT  ABS /home/rck/development/rte
    28: 00008020     0 NOTYPE  LOCAL  DEFAULT    1 handler_addr_reset
    29: 00008000     0 NOTYPE  LOCAL  DEFAULT    1 $a
    30: 00008024     0 NOTYPE  LOCAL  DEFAULT    1 handler_addr_undef
    31: 00008028     0 NOTYPE  LOCAL  DEFAULT    1 handler_addr_swi
    32: 0000802c     0 NOTYPE  LOCAL  DEFAULT    1 handler_addr_prefetch
    33: 00008030     0 NOTYPE  LOCAL  DEFAULT    1 handler_addr_abort
    34: 00008014     0 NOTYPE  LOCAL  DEFAULT    1 $d
    35: 00008038     0 NOTYPE  LOCAL  DEFAULT    1 handler_addr_irq
    36: 00008018     0 NOTYPE  LOCAL  DEFAULT    1 $a
    37: 0000803c     0 NOTYPE  LOCAL  DEFAULT    1 handler_addr_fiq
    38: 00008020     0 NOTYPE  LOCAL  DEFAULT    1 $d
    39: 00008034     0 NOTYPE  LOCAL  DEFAULT    1 handler_addr_reserved
    40: 00008040     0 NOTYPE  LOCAL  DEFAULT    1 $a
    41: 0000808c     0 NOTYPE  LOCAL  DEFAULT    1 bsp_start_hook_0_done
    42: 000080ac     0 NOTYPE  LOCAL  DEFAULT    1 bsp_vector_table_copy_don
    43: 000080b8     0 NOTYPE  LOCAL  DEFAULT    1 twiddle
    44: 000080c0     0 NOTYPE  LOCAL  DEFAULT    1 $d
    45: 0000000c     0 NOTYPE  LOCAL  DEFAULT   18 $d
    46: 00000000     0 FILE    LOCAL  DEFAULT  ABS bspstarthooks.c
    47: 000080dc     0 NOTYPE  LOCAL  DEFAULT    1 $a
    48: 00008154     0 NOTYPE  LOCAL  DEFAULT    1 $d
    49: 00000c98     0 NOTYPE  LOCAL  DEFAULT   22 $d
    50: 00000000     0 FILE    LOCAL  DEFAULT  ABS libbsp_a-bsp-start-memcpy
    51: 0000819c     0 NOTYPE  LOCAL  DEFAULT    1 $a
    52: 000081dc     0 NOTYPE  LOCAL  DEFAULT    1 worker_begin
    53: 00000684     0 NOTYPE  LOCAL  DEFAULT   18 $d
    54: 00000000     0 FILE    LOCAL  DEFAULT  ABS mminit.c
    55: 000081f4     0 NOTYPE  LOCAL  DEFAULT    1 $a
    56: 000082cc     0 NOTYPE  LOCAL  DEFAULT    1 $d
    57: 00001010     0 NOTYPE  LOCAL  DEFAULT   22 $d
    58: 00000000     0 FILE    LOCAL  DEFAULT  ABS mm_config_table.c
    59: 000082d8     0 NOTYPE  LOCAL  DEFAULT    1 $d
    60: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtsock.c
    61: 00008360     0 NOTYPE  LOCAL  DEFAULT    2 $a
    62: 00008360   100 FUNC    LOCAL  DEFAULT    2 rt_setmetrics
    63: 0001e918     0 NOTYPE  LOCAL  DEFAULT    2 $a
    64: 0001e918   284 FUNC    LOCAL  DEFAULT    2 rt_msg1
    65: 0001ea34   396 FUNC    LOCAL  DEFAULT    2 rt_msg2
    66: 0001ebc0   276 FUNC    LOCAL  DEFAULT    2 sysctl_dumpentry
    67: 0001ecd4   440 FUNC    LOCAL  DEFAULT    2 route_usrreq
    68: 0001ee84     0 NOTYPE  LOCAL  DEFAULT    2 $d
    69: 0001ee8c     0 NOTYPE  LOCAL  DEFAULT    2 $a
    70: 0001ee8c  2036 FUNC    LOCAL  DEFAULT    2 route_output
    71: 0001f1e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
    72: 0001f200     0 NOTYPE  LOCAL  DEFAULT    2 $a
    73: 0001f66c     0 NOTYPE  LOCAL  DEFAULT    2 $d
    74: 0001f680     0 NOTYPE  LOCAL  DEFAULT    2 $a
    75: 0001f680   656 FUNC    LOCAL  DEFAULT    2 sysctl_rtsock
    76: 0001f904     0 NOTYPE  LOCAL  DEFAULT    2 $d
    77: 0001f910     0 NOTYPE  LOCAL  DEFAULT    2 $a
    78: 0001f97c     0 NOTYPE  LOCAL  DEFAULT    2 $d
    79: 0001f984     0 NOTYPE  LOCAL  DEFAULT    2 $a
    80: 0001fa28     0 NOTYPE  LOCAL  DEFAULT    2 $d
    81: 0001fa30     0 NOTYPE  LOCAL  DEFAULT    2 $a
    82: 0001fc08     0 NOTYPE  LOCAL  DEFAULT    2 $d
    83: 00110830     0 NOTYPE  LOCAL  DEFAULT   12 $d
    84: 00110830     4 OBJECT  LOCAL  DEFAULT   12 __set_domain_set_sym_rout
    85: 00113300     0 NOTYPE  LOCAL  DEFAULT   14 $d
    86: 00113300    16 OBJECT  LOCAL  DEFAULT   14 route_src
    87: 00113310    16 OBJECT  LOCAL  DEFAULT   14 sa_zero
    88: 00113320     4 OBJECT  LOCAL  DEFAULT   14 route_proto
    89: 00113324    16 OBJECT  LOCAL  DEFAULT   14 route_dst
    90: 00113360    52 OBJECT  LOCAL  DEFAULT   14 routesw
    91: 00113394    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_routetable
    92: 0010242c     0 NOTYPE  LOCAL  DEFAULT    6 $d
    93: 00110714     0 NOTYPE  LOCAL  DEFAULT   12 $d
    94: 00110714     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
    95: 00003dfc     0 NOTYPE  LOCAL  DEFAULT   22 $d
    96: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_dd.c
    97: 000083c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
    98: 000083c4    40 FUNC    LOCAL  DEFAULT    2 parity
    99: 000083ec   200 FUNC    LOCAL  DEFAULT    2 getfdtype
   100: 000084b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   101: 0002e314     0 NOTYPE  LOCAL  DEFAULT    2 $a
   102: 0002e608     0 NOTYPE  LOCAL  DEFAULT    2 $d
   103: 0002e620     0 NOTYPE  LOCAL  DEFAULT    2 $a
   104: 0002e620  2296 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_dd
   105: 0002eeb8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   106: 0011384c     0 NOTYPE  LOCAL  DEFAULT   14 $d
   107: 0010cd84     0 NOTYPE  LOCAL  DEFAULT    6 $d
   108: 001169b0     0 NOTYPE  LOCAL  DEFAULT   15 $d
   109: 001169b0     8 OBJECT  LOCAL  DEFAULT   15 pending
   110: 001169b8     4 OBJECT  LOCAL  DEFAULT   15 warned.10100
   111: 00006dcc     0 NOTYPE  LOCAL  DEFAULT   22 $d
   112: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_ln.c
   113: 000084b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   114: 000084b4   696 FUNC    LOCAL  DEFAULT    2 linkit
   115: 00008754     0 NOTYPE  LOCAL  DEFAULT    2 $d
   116: 00034814     0 NOTYPE  LOCAL  DEFAULT    2 $a
   117: 00034814    56 FUNC    LOCAL  DEFAULT    2 usage
   118: 00034844     0 NOTYPE  LOCAL  DEFAULT    2 $d
   119: 0003484c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   120: 0003484c   668 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_ln
   121: 000348d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   122: 0003491c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   123: 00034ad0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   124: 0011399c     0 NOTYPE  LOCAL  DEFAULT   14 $d
   125: 0010cd84     0 NOTYPE  LOCAL  DEFAULT    6 $d
   126: 00007578     0 NOTYPE  LOCAL  DEFAULT   22 $d
   127: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_ls.c
   128: 00034b14     0 NOTYPE  LOCAL  DEFAULT    2 $a
   129: 00034b14   140 FUNC    LOCAL  DEFAULT    2 mastercmp_no_listdir
   130: 00034b9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   131: 00034ba0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   132: 00034ba0   104 FUNC    LOCAL  DEFAULT    2 mastercmp_listdir
   133: 00034c04     0 NOTYPE  LOCAL  DEFAULT    2 $d
   134: 0000876c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   135: 0000876c  1364 FUNC    LOCAL  DEFAULT    2 display
   136: 00008cb0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   137: 00008cc0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   138: 00008cc0   516 FUNC    LOCAL  DEFAULT    2 traverse
   139: 00008d8c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   140: 00008da8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   141: 00008ea8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   142: 00034c08     0 NOTYPE  LOCAL  DEFAULT    2 $a
   143: 00034c1c  1676 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_ls
   144: 00034ce4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   145: 00034e04     0 NOTYPE  LOCAL  DEFAULT    2 $a
   146: 00035258     0 NOTYPE  LOCAL  DEFAULT    2 $d
   147: 001139dc     0 NOTYPE  LOCAL  DEFAULT   14 $d
   148: 001139dc     8 OBJECT  LOCAL  DEFAULT   14 dotav.10240
   149: 001139e4     2 OBJECT  LOCAL  DEFAULT   14 dot.10239
   150: 00103294     0 NOTYPE  LOCAL  DEFAULT    6 $d
   151: 001169c4     0 NOTYPE  LOCAL  DEFAULT   15 $d
   152: 001169c4     4 OBJECT  LOCAL  DEFAULT   15 sortfcn
   153: 001169c8     4 OBJECT  LOCAL  DEFAULT   15 printfcn
   154: 00007618     0 NOTYPE  LOCAL  DEFAULT   22 $d
   155: 00000000     0 FILE    LOCAL  DEFAULT  ABS bdbuf.c
   156: 00045e9c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   157: 00045e9c   380 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_swapout_modif
   158: 00046014     0 NOTYPE  LOCAL  DEFAULT    2 $d
   159: 00046018     0 NOTYPE  LOCAL  DEFAULT    2 $a
   160: 00046018    16 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_transfer_done
   161: 00046028    16 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_fatal
   162: 00046038    68 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_wait_for_even
   163: 0004607c    12 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_fatal_with_st
   164: 00046088    52 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_wait_for_tran
   165: 000460bc    40 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_wake_swapper
   166: 000460e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   167: 000460e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   168: 000460e4    92 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_avl_search.is
   169: 00046140    28 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_wake.part.14
   170: 0004615c    36 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_lock.isra.18
   171: 00046180    28 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_unlock.isra.2
   172: 0004619c   216 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_add_to_modifi
   173: 0004626c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   174: 00046274     0 NOTYPE  LOCAL  DEFAULT    2 $a
   175: 00046274   212 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_anonymous_wai
   176: 00046340     0 NOTYPE  LOCAL  DEFAULT    2 $d
   177: 00046348     0 NOTYPE  LOCAL  DEFAULT    2 $a
   178: 00046348    76 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_wait
   179: 00008ec4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   180: 00008ec4    64 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_create_task.c
   181: 00008f00     0 NOTYPE  LOCAL  DEFAULT    2 $d
   182: 00046394  1508 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_init_once
   183: 0004693c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   184: 00047aa0   668 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_swapout_task
   185: 00047dd4   320 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_read_ahead_ta
   186: 00047d3c   152 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_swapout_worke
   187: 00046978     0 NOTYPE  LOCAL  DEFAULT    2 $a
   188: 00046978   900 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_remove_from_t
   189: 00046cf8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   190: 00046cfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   191: 00046cfc    60 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_remove_from_t
   192: 00046d38  1008 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_get_buffer_fr
   193: 0004711c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   194: 00047128     0 NOTYPE  LOCAL  DEFAULT    2 $a
   195: 00047128    88 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_get_buffer_fo
   196: 0004717c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   197: 00047180     0 NOTYPE  LOCAL  DEFAULT    2 $a
   198: 00047180   516 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_get_buffer_fo
   199: 000471dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
   200: 00047204     0 NOTYPE  LOCAL  DEFAULT    2 $a
   201: 00047218     0 NOTYPE  LOCAL  DEFAULT    2 $d
   202: 00047244     0 NOTYPE  LOCAL  DEFAULT    2 $a
   203: 00047370     0 NOTYPE  LOCAL  DEFAULT    2 $d
   204: 00047384     0 NOTYPE  LOCAL  DEFAULT    2 $a
   205: 00047384    56 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_discard_buffe
   206: 000473b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   207: 000473bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   208: 000473bc   120 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_discard_buffe
   209: 00047430     0 NOTYPE  LOCAL  DEFAULT    2 $d
   210: 00047434     0 NOTYPE  LOCAL  DEFAULT    2 $a
   211: 00047434   528 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_do_purge_dev
   212: 000474d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   213: 00047500     0 NOTYPE  LOCAL  DEFAULT    2 $a
   214: 00047638     0 NOTYPE  LOCAL  DEFAULT    2 $d
   215: 00047644     0 NOTYPE  LOCAL  DEFAULT    2 $a
   216: 00047644   540 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_execute_trans
   217: 0004784c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   218: 00047860     0 NOTYPE  LOCAL  DEFAULT    2 $a
   219: 00047860   248 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_execute_read_
   220: 00047954     0 NOTYPE  LOCAL  DEFAULT    2 $d
   221: 00047958     0 NOTYPE  LOCAL  DEFAULT    2 $a
   222: 00047958   328 FUNC    LOCAL  DEFAULT    2 rtems_bdbuf_swapout_write
   223: 00047a9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   224: 00047aa0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   225: 00047d24     0 NOTYPE  LOCAL  DEFAULT    2 $d
   226: 00047d3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   227: 00047dd0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   228: 00047dd4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   229: 00047f0c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   230: 00047f14     0 NOTYPE  LOCAL  DEFAULT    2 $a
   231: 00047f40     0 NOTYPE  LOCAL  DEFAULT    2 $d
   232: 00047f4c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   233: 0004802c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   234: 00048030     0 NOTYPE  LOCAL  DEFAULT    2 $a
   235: 000481f4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   236: 000481f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   237: 0004822c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   238: 0004823c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   239: 000482e4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   240: 000482e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   241: 0004835c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   242: 00048360     0 NOTYPE  LOCAL  DEFAULT    2 $a
   243: 000483fc     0 NOTYPE  LOCAL  DEFAULT    2 $d
   244: 00048424     0 NOTYPE  LOCAL  DEFAULT    2 $a
   245: 000484c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   246: 000484d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   247: 00048534     0 NOTYPE  LOCAL  DEFAULT    2 $d
   248: 00048538     0 NOTYPE  LOCAL  DEFAULT    2 $a
   249: 00048568     0 NOTYPE  LOCAL  DEFAULT    2 $d
   250: 0004856c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   251: 00048668     0 NOTYPE  LOCAL  DEFAULT    2 $d
   252: 00048670     0 NOTYPE  LOCAL  DEFAULT    2 $a
   253: 000486b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   254: 000486b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   255: 000486f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   256: 00113ef4     0 NOTYPE  LOCAL  DEFAULT   14 $d
   257: 00113ef4     8 OBJECT  LOCAL  DEFAULT   14 rtems_bdbuf_once_state
   258: 00119040     0 NOTYPE  LOCAL  DEFAULT   15 $d
   259: 00119040   160 OBJECT  LOCAL  DEFAULT   15 bdbuf_cache
   260: 00009594     0 NOTYPE  LOCAL  DEFAULT   22 $d
   261: 00000000     0 FILE    LOCAL  DEFAULT  ABS ns_print.c
   262: 00078e04     0 NOTYPE  LOCAL  DEFAULT    2 $a
   263: 00078e04   156 FUNC    LOCAL  DEFAULT    2 prune_origin
   264: 00008f04     0 NOTYPE  LOCAL  DEFAULT    2 $a
   265: 00008f04    40 FUNC    LOCAL  DEFAULT    2 addlen.part.0
   266: 00008f1c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   267: 00078ea0   340 FUNC    LOCAL  DEFAULT    2 addname
   268: 00078ff4   120 FUNC    LOCAL  DEFAULT    2 addstr
   269: 0007906c   280 FUNC    LOCAL  DEFAULT    2 charstr
   270: 00079178     0 NOTYPE  LOCAL  DEFAULT    2 $d
   271: 00079184     0 NOTYPE  LOCAL  DEFAULT    2 $a
   272: 00079184   160 FUNC    LOCAL  DEFAULT    2 addtab
   273: 0007921c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   274: 00079224     0 NOTYPE  LOCAL  DEFAULT    2 $a
   275: 000793e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   276: 00079474     0 NOTYPE  LOCAL  DEFAULT    2 $a
   277: 0007a224     0 NOTYPE  LOCAL  DEFAULT    2 $d
   278: 0007a2b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   279: 0007aa30     0 NOTYPE  LOCAL  DEFAULT    2 $d
   280: 0010e9dc     0 NOTYPE  LOCAL  DEFAULT    6 $d
   281: 0010e9dc     7 OBJECT  LOCAL  DEFAULT    6 __FUNCTION__.9105
   282: 0010e9e4     0 NOTYPE  LOCAL  DEFAULT    6 $d
   283: 00010ddc     0 NOTYPE  LOCAL  DEFAULT   22 $d
   284: 00000000     0 FILE    LOCAL  DEFAULT  ABS strtod.c
   285: 00008f2c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   286: 00008f2c   108 FUNC    LOCAL  DEFAULT    2 sulp
   287: 000948f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   288: 00094940     0 NOTYPE  LOCAL  DEFAULT    2 $d
   289: 000949f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   290: 00095324     0 NOTYPE  LOCAL  DEFAULT    2 $d
   291: 000953bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   292: 00095a24     0 NOTYPE  LOCAL  DEFAULT    2 $d
   293: 00095a40     0 NOTYPE  LOCAL  DEFAULT    2 $a
   294: 00095b10     0 NOTYPE  LOCAL  DEFAULT    2 $d
   295: 00095b8c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   296: 001104f8     0 NOTYPE  LOCAL  DEFAULT    6 $d
   297: 001104f8    20 OBJECT  LOCAL  DEFAULT    6 fpi.5539
   298: 0011050c    20 OBJECT  LOCAL  DEFAULT    6 fpinan.5575
   299: 00110520    40 OBJECT  LOCAL  DEFAULT    6 tinytens
   300: 00101ac8     0 NOTYPE  LOCAL  DEFAULT    6 $d
   301: 00015088     0 NOTYPE  LOCAL  DEFAULT   22 $d
   302: 00000000     0 FILE    LOCAL  DEFAULT  ABS /home/rck/development/rte
   303: 0009b804     0 NOTYPE  LOCAL  DEFAULT    3 $a
   304: 0009b81c     0 NOTYPE  LOCAL  DEFAULT    4 $a
   305: 00000000     0 FILE    LOCAL  DEFAULT  ABS crtstuff.c
   306: 001106c0     0 OBJECT  LOCAL  DEFAULT    8 __EH_FRAME_BEGIN__
   307: 00110710     0 OBJECT  LOCAL  DEFAULT   11 __JCR_LIST__
   308: 00008f98     0 NOTYPE  LOCAL  DEFAULT    2 $a
   309: 00008f98     0 FUNC    LOCAL  DEFAULT    2 deregister_tm_clones
   310: 00008fbc     0 NOTYPE  LOCAL  DEFAULT    2 $d
   311: 00008fc8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   312: 00008fc8     0 FUNC    LOCAL  DEFAULT    2 register_tm_clones
   313: 00008ff4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   314: 00110838     0 NOTYPE  LOCAL  DEFAULT   14 $d
   315: 00009000     0 NOTYPE  LOCAL  DEFAULT    2 $a
   316: 00009000     0 FUNC    LOCAL  DEFAULT    2 __do_global_dtors_aux
   317: 00009038     0 NOTYPE  LOCAL  DEFAULT    2 $d
   318: 001156e0     0 NOTYPE  LOCAL  DEFAULT   15 completed.6255
   319: 0011070c     0 NOTYPE  LOCAL  DEFAULT   10 $d
   320: 0011070c     0 OBJECT  LOCAL  DEFAULT   10 __do_global_dtors_aux_fin
   321: 00009044     0 NOTYPE  LOCAL  DEFAULT    2 $a
   322: 00009044     0 FUNC    LOCAL  DEFAULT    2 frame_dummy
   323: 0000908c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   324: 001156e4     0 NOTYPE  LOCAL  DEFAULT   15 object.6260
   325: 00110708     0 NOTYPE  LOCAL  DEFAULT    9 $d
   326: 00110708     0 OBJECT  LOCAL  DEFAULT    9 __frame_dummy_init_array_
   327: 001156e0     0 NOTYPE  LOCAL  DEFAULT   15 $d
   328: 00000000     0 FILE    LOCAL  DEFAULT  ABS init.c
   329: 000090a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   330: 00009148     0 NOTYPE  LOCAL  DEFAULT    2 $d
   331: 00009188     0 NOTYPE  LOCAL  DEFAULT    2 $a
   332: 00009198     0 NOTYPE  LOCAL  DEFAULT    2 $d
   333: 00100000     0 NOTYPE  LOCAL  DEFAULT    6 $d
   334: 00100064   108 OBJECT  LOCAL  DEFAULT    6 Configuration_Initial_Ext
   335: 00115700  3108 OBJECT  LOCAL  DEFAULT   15 _Configuration_Scheduler_
   336: 00100158    12 OBJECT  LOCAL  DEFAULT    6 _Configure_IMFS_mount_dat
   337: 00116324    68 OBJECT  LOCAL  DEFAULT   15 _Configure_IMFS_fs_info
   338: 00100174    76 OBJECT  LOCAL  DEFAULT    6 _Configure_IMFS_ops
   339: 00100164    16 OBJECT  LOCAL  DEFAULT    6 _Configure_IMFS_mknod_con
   340: 0011083c     0 NOTYPE  LOCAL  DEFAULT   14 $d
   341: 0010b514     0 NOTYPE  LOCAL  DEFAULT    6 $d
   342: 001156fc     0 NOTYPE  LOCAL  DEFAULT   15 $d
   343: 00000010     0 NOTYPE  LOCAL  DEFAULT   22 $d
   344: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems_net.c
   345: 0000919c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   346: 0000005c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   347: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems_net_svc.c
   348: 000091a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   349: 0000007c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   350: 00000000     0 FILE    LOCAL  DEFAULT  ABS local_shell_cmds.c
   351: 000091a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   352: 00009238     0 NOTYPE  LOCAL  DEFAULT    2 $d
   353: 00009254     0 NOTYPE  LOCAL  DEFAULT    2 $a
   354: 000092b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   355: 000092c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   356: 0000932c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   357: 00009340     0 NOTYPE  LOCAL  DEFAULT    2 $a
   358: 000093bc     0 NOTYPE  LOCAL  DEFAULT    2 $d
   359: 0010043c     0 NOTYPE  LOCAL  DEFAULT    6 $d
   360: 0000009c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   361: 00000000     0 FILE    LOCAL  DEFAULT  ABS filesys.c
   362: 000093fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   363: 000095c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   364: 000095fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   365: 000096d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   366: 000096f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   367: 0000975c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   368: 00100674     0 NOTYPE  LOCAL  DEFAULT    6 $d
   369: 0000014c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   370: 00000000     0 FILE    LOCAL  DEFAULT  ABS ramdisk.c
   371: 00009780     0 NOTYPE  LOCAL  DEFAULT    2 $a
   372: 000097b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   373: 00100ad4     0 NOTYPE  LOCAL  DEFAULT    6 $d
   374: 00116370     0 NOTYPE  LOCAL  DEFAULT   15 $d
   375: 000001e0     0 NOTYPE  LOCAL  DEFAULT   22 $d
   376: 00000000     0 FILE    LOCAL  DEFAULT  ABS nvramdisk.c
   377: 00100ae4     0 NOTYPE  LOCAL  DEFAULT    6 $d
   378: 0011098c     0 NOTYPE  LOCAL  DEFAULT   14 $d
   379: 00000000     0 FILE    LOCAL  DEFAULT  ABS task_cmd.c
   380: 000097c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   381: 00009814     0 NOTYPE  LOCAL  DEFAULT    2 $d
   382: 00009818     0 NOTYPE  LOCAL  DEFAULT    2 $a
   383: 00009960     0 NOTYPE  LOCAL  DEFAULT    2 $d
   384: 00100af8     0 NOTYPE  LOCAL  DEFAULT    6 $d
   385: 0000020c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   386: 00000000     0 FILE    LOCAL  DEFAULT  ABS hello_cmd.c
   387: 00009988     0 NOTYPE  LOCAL  DEFAULT    2 $a
   388: 000099a4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   389: 00100b60     0 NOTYPE  LOCAL  DEFAULT    6 $d
   390: 0000026c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   391: 00000000     0 FILE    LOCAL  DEFAULT  ABS dhrystone_cmd.c
   392: 000099ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
   393: 000099d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   394: 00100b90     0 NOTYPE  LOCAL  DEFAULT    6 $d
   395: 00000298     0 NOTYPE  LOCAL  DEFAULT   22 $d
   396: 00000000     0 FILE    LOCAL  DEFAULT  ABS whetstone_cmd.c
   397: 000099dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   398: 00009a48     0 NOTYPE  LOCAL  DEFAULT    2 $d
   399: 00100bc0     0 NOTYPE  LOCAL  DEFAULT    6 $d
   400: 00100bcc     0 NOTYPE  LOCAL  DEFAULT    6 $d
   401: 000002c4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   402: 00000000     0 FILE    LOCAL  DEFAULT  ABS benchmarks.c
   403: 00009a54     0 NOTYPE  LOCAL  DEFAULT    2 $a
   404: 00009a7c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   405: 00009a84     0 NOTYPE  LOCAL  DEFAULT    2 $a
   406: 00009ab0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   407: 00009ab8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   408: 00009ae4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   409: 00009af0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   410: 00009b0c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   411: 00009b14     0 NOTYPE  LOCAL  DEFAULT    2 $a
   412: 00009b68     0 NOTYPE  LOCAL  DEFAULT    2 $d
   413: 00009b6c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   414: 00009c2c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   415: 00009c34     0 NOTYPE  LOCAL  DEFAULT    2 $a
   416: 00009ca8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   417: 00009cac     0 NOTYPE  LOCAL  DEFAULT    2 $a
   418: 00009cc8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   419: 00009ccc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   420: 00009d1c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   421: 00009d24     0 NOTYPE  LOCAL  DEFAULT    2 $a
   422: 0000a3cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
   423: 0000a4c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   424: 0000a630     0 NOTYPE  LOCAL  DEFAULT    2 $d
   425: 0000a63c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   426: 0000a688     0 NOTYPE  LOCAL  DEFAULT    2 $d
   427: 0000a698     0 NOTYPE  LOCAL  DEFAULT    2 $a
   428: 0000b2e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   429: 0000b384     0 NOTYPE  LOCAL  DEFAULT    2 $a
   430: 0000b404     0 NOTYPE  LOCAL  DEFAULT    2 $d
   431: 0000b40c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   432: 0000b42c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   433: 00100c00     0 NOTYPE  LOCAL  DEFAULT    6 $d
   434: 00116378     0 NOTYPE  LOCAL  DEFAULT   15 $d
   435: 000002f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   436: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_atan.c
   437: 0000b430     0 NOTYPE  LOCAL  DEFAULT    2 $a
   438: 0000b830     0 NOTYPE  LOCAL  DEFAULT    2 $d
   439: 00101310     0 NOTYPE  LOCAL  DEFAULT    6 $d
   440: 00101310    32 OBJECT  LOCAL  DEFAULT    6 atanhi
   441: 00101330    32 OBJECT  LOCAL  DEFAULT    6 atanlo
   442: 00000530     0 NOTYPE  LOCAL  DEFAULT   22 $d
   443: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_cos.c
   444: 0000b8c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   445: 0000b9b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   446: 000005a8     0 NOTYPE  LOCAL  DEFAULT   22 $d
   447: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_fabs.c
   448: 0000b9bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   449: 000005ec     0 NOTYPE  LOCAL  DEFAULT   22 $d
   450: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_sin.c
   451: 0000b9c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   452: 0000babc     0 NOTYPE  LOCAL  DEFAULT    2 $d
   453: 0000060c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   454: 00000000     0 FILE    LOCAL  DEFAULT  ABS w_exp.c
   455: 0000bac8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   456: 0000bc40     0 NOTYPE  LOCAL  DEFAULT    2 $d
   457: 00101350     0 NOTYPE  LOCAL  DEFAULT    6 $d
   458: 00000648     0 NOTYPE  LOCAL  DEFAULT   22 $d
   459: 00000000     0 FILE    LOCAL  DEFAULT  ABS w_log.c
   460: 0000bc60     0 NOTYPE  LOCAL  DEFAULT    2 $a
   461: 0000be04     0 NOTYPE  LOCAL  DEFAULT    2 $d
   462: 00101354     0 NOTYPE  LOCAL  DEFAULT    6 $d
   463: 000006a0     0 NOTYPE  LOCAL  DEFAULT   22 $d
   464: 00000000     0 FILE    LOCAL  DEFAULT  ABS w_sqrt.c
   465: 0000be18     0 NOTYPE  LOCAL  DEFAULT    2 $a
   466: 0000bf4c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   467: 00101358     0 NOTYPE  LOCAL  DEFAULT    6 $d
   468: 000006f8     0 NOTYPE  LOCAL  DEFAULT   22 $d
   469: 00000000     0 FILE    LOCAL  DEFAULT  ABS e_exp.c
   470: 0000bf58     0 NOTYPE  LOCAL  DEFAULT    2 $a
   471: 0000c2f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   472: 00101360     0 NOTYPE  LOCAL  DEFAULT    6 $d
   473: 00101360    16 OBJECT  LOCAL  DEFAULT    6 ln2HI
   474: 00101370    16 OBJECT  LOCAL  DEFAULT    6 ln2LO
   475: 00101380    16 OBJECT  LOCAL  DEFAULT    6 halF
   476: 0000074c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   477: 0000c36c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   478: 00000000     0 FILE    LOCAL  DEFAULT  ABS e_log.c
   479: 0000c370     0 NOTYPE  LOCAL  DEFAULT    2 $a
   480: 0000c830     0 NOTYPE  LOCAL  DEFAULT    2 $d
   481: 0000c8a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   482: 0000c910     0 NOTYPE  LOCAL  DEFAULT    2 $d
   483: 000007d0     0 NOTYPE  LOCAL  DEFAULT   22 $d
   484: 00000000     0 FILE    LOCAL  DEFAULT  ABS e_rem_pio2.c
   485: 0000c920     0 NOTYPE  LOCAL  DEFAULT    2 $a
   486: 0000ccb0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   487: 0000ccfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   488: 0000cf40     0 NOTYPE  LOCAL  DEFAULT    2 $d
   489: 00101390     0 NOTYPE  LOCAL  DEFAULT    6 $d
   490: 00101390   128 OBJECT  LOCAL  DEFAULT    6 npio2_hw
   491: 00101410   264 OBJECT  LOCAL  DEFAULT    6 two_over_pi
   492: 00000854     0 NOTYPE  LOCAL  DEFAULT   22 $d
   493: 00000000     0 FILE    LOCAL  DEFAULT  ABS e_sqrt.c
   494: 0000cf68     0 NOTYPE  LOCAL  DEFAULT    2 $a
   495: 0000d184     0 NOTYPE  LOCAL  DEFAULT    2 $d
   496: 000008c4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   497: 00000000     0 FILE    LOCAL  DEFAULT  ABS k_cos.c
   498: 0000d188     0 NOTYPE  LOCAL  DEFAULT    2 $a
   499: 0000d490     0 NOTYPE  LOCAL  DEFAULT    2 $d
   500: 00000918     0 NOTYPE  LOCAL  DEFAULT   22 $d
   501: 00000000     0 FILE    LOCAL  DEFAULT  ABS k_rem_pio2.c
   502: 0000d4d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   503: 0000dc84     0 NOTYPE  LOCAL  DEFAULT    2 $d
   504: 0000dc94     0 NOTYPE  LOCAL  DEFAULT    2 $a
   505: 0000dddc     0 NOTYPE  LOCAL  DEFAULT    2 $d
   506: 0000ddec     0 NOTYPE  LOCAL  DEFAULT    2 $a
   507: 0000e074     0 NOTYPE  LOCAL  DEFAULT    2 $d
   508: 00101518     0 NOTYPE  LOCAL  DEFAULT    6 $d
   509: 00101518    16 OBJECT  LOCAL  DEFAULT    6 init_jk
   510: 00101528    64 OBJECT  LOCAL  DEFAULT    6 PIo2
   511: 00000988     0 NOTYPE  LOCAL  DEFAULT   22 $d
   512: 00000000     0 FILE    LOCAL  DEFAULT  ABS k_sin.c
   513: 0000e098     0 NOTYPE  LOCAL  DEFAULT    2 $a
   514: 0000e260     0 NOTYPE  LOCAL  DEFAULT    2 $d
   515: 000009d8     0 NOTYPE  LOCAL  DEFAULT   22 $d
   516: 0000e294     0 NOTYPE  LOCAL  DEFAULT    2 $a
   517: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_finite.c
   518: 0000e298     0 NOTYPE  LOCAL  DEFAULT    2 $a
   519: 00000a34     0 NOTYPE  LOCAL  DEFAULT   22 $d
   520: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_floor.c
   521: 0000e2a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   522: 0000e438     0 NOTYPE  LOCAL  DEFAULT    2 $d
   523: 00000a54     0 NOTYPE  LOCAL  DEFAULT   22 $d
   524: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_fpclassify.c
   525: 0000e448     0 NOTYPE  LOCAL  DEFAULT    2 $a
   526: 0000e4ac     0 NOTYPE  LOCAL  DEFAULT    2 $d
   527: 00000aa4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   528: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_lib_ver.c
   529: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_matherr.c
   530: 0000e4b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   531: 00000ac4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   532: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_nan.c
   533: 0000e4bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   534: 0000e4c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   535: 00000ae4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   536: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_scalbn.c
   537: 0000e4d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   538: 0000e640     0 NOTYPE  LOCAL  DEFAULT    2 $d
   539: 00000b04     0 NOTYPE  LOCAL  DEFAULT   22 $d
   540: 0000e66c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   541: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_copysign.c
   542: 0000e670     0 NOTYPE  LOCAL  DEFAULT    2 $a
   543: 00000b58     0 NOTYPE  LOCAL  DEFAULT   22 $d
   544: 00000000     0 FILE    LOCAL  DEFAULT  ABS _arm_addsubdf3.o
   545: 0000e680     0 NOTYPE  LOCAL  DEFAULT    2 $a
   546: 0000045c     0 NOTYPE  LOCAL  DEFAULT   18 $d
   547: 00000000     0 FILE    LOCAL  DEFAULT  ABS _arm_muldivdf3.o
   548: 0000ea9c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   549: 0000047c     0 NOTYPE  LOCAL  DEFAULT   18 $d
   550: 00000000     0 FILE    LOCAL  DEFAULT  ABS _arm_cmpdf2.o
   551: 0000ef38     0 NOTYPE  LOCAL  DEFAULT    2 $a
   552: 0000049c     0 NOTYPE  LOCAL  DEFAULT   18 $d
   553: 00000000     0 FILE    LOCAL  DEFAULT  ABS _arm_fixdfsi.o
   554: 0000f07c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   555: 000004bc     0 NOTYPE  LOCAL  DEFAULT   18 $d
   556: 00000000     0 FILE    LOCAL  DEFAULT  ABS _arm_truncdfsf2.o
   557: 0000f0d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   558: 000004dc     0 NOTYPE  LOCAL  DEFAULT   18 $d
   559: 00000000     0 FILE    LOCAL  DEFAULT  ABS _arm_addsubsf3.o
   560: 0000f178     0 NOTYPE  LOCAL  DEFAULT    2 $a
   561: 000004fc     0 NOTYPE  LOCAL  DEFAULT   18 $d
   562: 00000000     0 FILE    LOCAL  DEFAULT  ABS _arm_muldivsf3.o
   563: 0000f424     0 NOTYPE  LOCAL  DEFAULT    2 $a
   564: 0000051c     0 NOTYPE  LOCAL  DEFAULT   18 $d
   565: 00000000     0 FILE    LOCAL  DEFAULT  ABS _arm_cmpsf2.o
   566: 0000f71c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   567: 0000053c     0 NOTYPE  LOCAL  DEFAULT   18 $d
   568: 00000000     0 FILE    LOCAL  DEFAULT  ABS bootcard.c
   569: 0000f830     0 NOTYPE  LOCAL  DEFAULT    2 $a
   570: 0000f870     0 NOTYPE  LOCAL  DEFAULT    2 $d
   571: 00000b78     0 NOTYPE  LOCAL  DEFAULT   22 $d
   572: 00000000     0 FILE    LOCAL  DEFAULT  ABS bspclean.c
   573: 0000f874     0 NOTYPE  LOCAL  DEFAULT    2 $a
   574: 00000ba0     0 NOTYPE  LOCAL  DEFAULT   22 $d
   575: 00000000     0 FILE    LOCAL  DEFAULT  ABS bspgetworkarea.c
   576: 0000f878     0 NOTYPE  LOCAL  DEFAULT    2 $a
   577: 0000f8c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   578: 00000bc0     0 NOTYPE  LOCAL  DEFAULT   22 $d
   579: 00000000     0 FILE    LOCAL  DEFAULT  ABS bsplibc.c
   580: 0000f8d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   581: 0000f8e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   582: 00000bec     0 NOTYPE  LOCAL  DEFAULT   22 $d
   583: 00000000     0 FILE    LOCAL  DEFAULT  ABS bsppost.c
   584: 0000f8ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
   585: 0000f8f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   586: 00000c18     0 NOTYPE  LOCAL  DEFAULT   22 $d
   587: 00000000     0 FILE    LOCAL  DEFAULT  ABS bsppredriverhook.c
   588: 0000f8fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   589: 00000c38     0 NOTYPE  LOCAL  DEFAULT   22 $d
   590: 00000000     0 FILE    LOCAL  DEFAULT  ABS bsppretaskinghook.c
   591: 0000f900     0 NOTYPE  LOCAL  DEFAULT    2 $a
   592: 00000c58     0 NOTYPE  LOCAL  DEFAULT   22 $d
   593: 00000000     0 FILE    LOCAL  DEFAULT  ABS bspreset_loop.c
   594: 0000f904     0 NOTYPE  LOCAL  DEFAULT    2 $a
   595: 00000c78     0 NOTYPE  LOCAL  DEFAULT   22 $d
   596: 00000000     0 FILE    LOCAL  DEFAULT  ABS bspstart.c
   597: 0000f908     0 NOTYPE  LOCAL  DEFAULT    2 $a
   598: 00000cd4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   599: 00000000     0 FILE    LOCAL  DEFAULT  ABS clockdrv.c
   600: 0000f90c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   601: 0000f90c     8 FUNC    LOCAL  DEFAULT    2 raspberrypi_clock_nanosec
   602: 0000f934     0 NOTYPE  LOCAL  DEFAULT    2 $d
   603: 0000f93c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   604: 0000f960     0 NOTYPE  LOCAL  DEFAULT    2 $d
   605: 0000f968     0 NOTYPE  LOCAL  DEFAULT    2 $a
   606: 0000f9ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
   607: 00101568     0 NOTYPE  LOCAL  DEFAULT    6 $d
   608: 00000cf4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   609: 00000000     0 FILE    LOCAL  DEFAULT  ABS console_control.c
   610: 0000fa10     0 NOTYPE  LOCAL  DEFAULT    2 $a
   611: 00000d5c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   612: 00000000     0 FILE    LOCAL  DEFAULT  ABS console.c
   613: 0000fa18     0 NOTYPE  LOCAL  DEFAULT    2 $a
   614: 0000fa18    16 FUNC    LOCAL  DEFAULT    2 bsp_fatal
   615: 0000fa28   108 FUNC    LOCAL  DEFAULT    2 console_initialize_pointe
   616: 0000fa88     0 NOTYPE  LOCAL  DEFAULT    2 $d
   617: 0000fa94     0 NOTYPE  LOCAL  DEFAULT    2 $a
   618: 0000fb5c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   619: 0000fb60     0 NOTYPE  LOCAL  DEFAULT    2 $a
   620: 0000fc94     0 NOTYPE  LOCAL  DEFAULT    2 $d
   621: 0000fc98     0 NOTYPE  LOCAL  DEFAULT    2 $a
   622: 0000fd1c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   623: 0000fd20     0 NOTYPE  LOCAL  DEFAULT    2 $a
   624: 0000fe38     0 NOTYPE  LOCAL  DEFAULT    2 $d
   625: 0010052c     0 NOTYPE  LOCAL  DEFAULT    6 $d
   626: 0011637c     0 NOTYPE  LOCAL  DEFAULT   15 $d
   627: 00116384     1 OBJECT  LOCAL  DEFAULT   15 console_initialized
   628: 00000d7c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   629: 00000000     0 FILE    LOCAL  DEFAULT  ABS console_read.c
   630: 0000fe40     0 NOTYPE  LOCAL  DEFAULT    2 $a
   631: 00000e64     0 NOTYPE  LOCAL  DEFAULT   22 $d
   632: 00000000     0 FILE    LOCAL  DEFAULT  ABS console_select.c
   633: 0000fe48     0 NOTYPE  LOCAL  DEFAULT    2 $a
   634: 0000ff10     0 NOTYPE  LOCAL  DEFAULT    2 $d
   635: 00000e84     0 NOTYPE  LOCAL  DEFAULT   22 $d
   636: 00000000     0 FILE    LOCAL  DEFAULT  ABS console_write.c
   637: 0000ff1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   638: 00000eb4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   639: 00000000     0 FILE    LOCAL  DEFAULT  ABS irq-generic.c
   640: 0000ff24     0 NOTYPE  LOCAL  DEFAULT    2 $a
   641: 0000ff24     4 FUNC    LOCAL  DEFAULT    2 bsp_interrupt_handler_emp
   642: 0000ff28    16 FUNC    LOCAL  DEFAULT    2 bsp_interrupt_unlock.part
   643: 0000ff34     0 NOTYPE  LOCAL  DEFAULT    2 $d
   644: 0000ff38     0 NOTYPE  LOCAL  DEFAULT    2 $a
   645: 0000ff90     0 NOTYPE  LOCAL  DEFAULT    2 $d
   646: 0000ff9c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   647: 00010238     0 NOTYPE  LOCAL  DEFAULT    2 $d
   648: 00010250     0 NOTYPE  LOCAL  DEFAULT    2 $a
   649: 0001041c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   650: 00010434     0 NOTYPE  LOCAL  DEFAULT    2 $a
   651: 00010528     0 NOTYPE  LOCAL  DEFAULT    2 $d
   652: 00116390     0 NOTYPE  LOCAL  DEFAULT   15 $d
   653: 00116390    10 OBJECT  LOCAL  DEFAULT   15 bsp_interrupt_handler_uni
   654: 00000ed4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   655: 00000000     0 FILE    LOCAL  DEFAULT  ABS irq.c
   656: 00010540     0 NOTYPE  LOCAL  DEFAULT    2 $a
   657: 00010550     0 NOTYPE  LOCAL  DEFAULT    2 $d
   658: 00010554     0 NOTYPE  LOCAL  DEFAULT    2 $a
   659: 000105a4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   660: 000105ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
   661: 000105ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
   662: 000105f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   663: 00010630     0 NOTYPE  LOCAL  DEFAULT    2 $d
   664: 00010634     0 NOTYPE  LOCAL  DEFAULT    2 $a
   665: 00010640     0 NOTYPE  LOCAL  DEFAULT    2 $d
   666: 00010644     0 NOTYPE  LOCAL  DEFAULT    2 $a
   667: 00010670     0 NOTYPE  LOCAL  DEFAULT    2 $d
   668: 00101570     0 NOTYPE  LOCAL  DEFAULT    6 $d
   669: 00000f98     0 NOTYPE  LOCAL  DEFAULT   22 $d
   670: 00000000     0 FILE    LOCAL  DEFAULT  ABS version.c
   671: 00101588     0 NOTYPE  LOCAL  DEFAULT    6 $d
   672: 00000000     0 FILE    LOCAL  DEFAULT  ABS console-config.c
   673: 00010678     0 NOTYPE  LOCAL  DEFAULT    2 $a
   674: 00010678    96 FUNC    LOCAL  DEFAULT    2 output_char
   675: 000106d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   676: 001131bc     0 NOTYPE  LOCAL  DEFAULT   14 $d
   677: 001015b0     0 NOTYPE  LOCAL  DEFAULT    6 $d
   678: 0011639c     0 NOTYPE  LOCAL  DEFAULT   15 $d
   679: 0000103c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   680: 00000000     0 FILE    LOCAL  DEFAULT  ABS usart.c
   681: 000106d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   682: 000106d8   240 FUNC    LOCAL  DEFAULT    2 usart_initialize
   683: 000107b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   684: 000107c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   685: 000107c8     8 FUNC    LOCAL  DEFAULT    2 usart_last_close
   686: 000107d0    32 FUNC    LOCAL  DEFAULT    2 usart_write_polled
   687: 000107ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
   688: 000107f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   689: 000107f0    60 FUNC    LOCAL  DEFAULT    2 usart_write_support_polle
   690: 00010828     0 NOTYPE  LOCAL  DEFAULT    2 $d
   691: 0001082c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   692: 0001082c     8 FUNC    LOCAL  DEFAULT    2 usart_set_attributes
   693: 00010834    76 FUNC    LOCAL  DEFAULT    2 usart_read_polled
   694: 00010878     0 NOTYPE  LOCAL  DEFAULT    2 $d
   695: 00010880     0 NOTYPE  LOCAL  DEFAULT    2 $a
   696: 00010880    64 FUNC    LOCAL  DEFAULT    2 usart_first_open
   697: 000108b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   698: 001015bc     0 NOTYPE  LOCAL  DEFAULT    6 $d
   699: 001015e0     0 NOTYPE  LOCAL  DEFAULT    6 $d
   700: 00001078     0 NOTYPE  LOCAL  DEFAULT   22 $d
   701: 00000000     0 FILE    LOCAL  DEFAULT  ABS serprobe.c
   702: 000108c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   703: 00001128     0 NOTYPE  LOCAL  DEFAULT   22 $d
   704: 00000000     0 FILE    LOCAL  DEFAULT  ABS blkdev.c
   705: 000108c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   706: 00010b34     0 NOTYPE  LOCAL  DEFAULT    2 $d
   707: 00001148     0 NOTYPE  LOCAL  DEFAULT   22 $d
   708: 00000000     0 FILE    LOCAL  DEFAULT  ABS check.c
   709: 00010b38     0 NOTYPE  LOCAL  DEFAULT    2 $a
   710: 00010b38   296 FUNC    LOCAL  DEFAULT    2 Stack_check_Dump_threads_
   711: 00010c48     0 NOTYPE  LOCAL  DEFAULT    2 $d
   712: 00010c60     0 NOTYPE  LOCAL  DEFAULT    2 $a
   713: 00010cbc     0 NOTYPE  LOCAL  DEFAULT    2 $d
   714: 00010cd4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   715: 00010cf4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   716: 00010cf8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   717: 00010d94     0 NOTYPE  LOCAL  DEFAULT    2 $d
   718: 00010db0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   719: 00010e10     0 NOTYPE  LOCAL  DEFAULT    2 $d
   720: 00010e14     0 NOTYPE  LOCAL  DEFAULT    2 $a
   721: 00010eac     0 NOTYPE  LOCAL  DEFAULT    2 $d
   722: 00010eb8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   723: 00010f00     0 NOTYPE  LOCAL  DEFAULT    2 $d
   724: 00010f10     0 NOTYPE  LOCAL  DEFAULT    2 $a
   725: 00010f1c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   726: 00101604     0 NOTYPE  LOCAL  DEFAULT    6 $d
   727: 001163a0     0 NOTYPE  LOCAL  DEFAULT   15 $d
   728: 001163a0     4 OBJECT  LOCAL  DEFAULT   15 print_handler
   729: 001163a4     4 OBJECT  LOCAL  DEFAULT   15 print_context
   730: 001163a8     4 OBJECT  LOCAL  DEFAULT   15 Stack_check_Initialized
   731: 00001208     0 NOTYPE  LOCAL  DEFAULT   22 $d
   732: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_are_nodes_equal.c
   733: 00010f20     0 NOTYPE  LOCAL  DEFAULT    2 $a
   734: 000012fc     0 NOTYPE  LOCAL  DEFAULT   22 $d
   735: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_fsunmount.c
   736: 00010f38     0 NOTYPE  LOCAL  DEFAULT    2 $a
   737: 0000131c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   738: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_lock_and_unlock.c
   739: 00010f3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   740: 00010f50     0 NOTYPE  LOCAL  DEFAULT    2 $d
   741: 00010f54     0 NOTYPE  LOCAL  DEFAULT    2 $a
   742: 00010f60     0 NOTYPE  LOCAL  DEFAULT    2 $d
   743: 0000133c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   744: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_statvfs.c
   745: 00010f64     0 NOTYPE  LOCAL  DEFAULT    2 $a
   746: 0000136c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   747: 00000000     0 FILE    LOCAL  DEFAULT  ABS diskdevs.c
   748: 00010f7c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   749: 00010f7c   156 FUNC    LOCAL  DEFAULT    2 get_disk_entry
   750: 00011014     0 NOTYPE  LOCAL  DEFAULT    2 $d
   751: 00011018     0 NOTYPE  LOCAL  DEFAULT    2 $a
   752: 00011018     8 FUNC    LOCAL  DEFAULT    2 null_handler
   753: 00011020    48 FUNC    LOCAL  DEFAULT    2 disk_lock
   754: 0001104c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   755: 00011050     0 NOTYPE  LOCAL  DEFAULT    2 $a
   756: 00011050   400 FUNC    LOCAL  DEFAULT    2 create_disk
   757: 000111d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   758: 000111e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   759: 000111e0    48 FUNC    LOCAL  DEFAULT    2 disk_unlock
   760: 00011208     0 NOTYPE  LOCAL  DEFAULT    2 $d
   761: 00011210     0 NOTYPE  LOCAL  DEFAULT    2 $a
   762: 00011210    80 FUNC    LOCAL  DEFAULT    2 free_disk_device
   763: 0001125c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   764: 00011260     0 NOTYPE  LOCAL  DEFAULT    2 $a
   765: 00011418     0 NOTYPE  LOCAL  DEFAULT    2 $d
   766: 0001141c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   767: 000114e4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   768: 000114e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   769: 000115d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   770: 000115d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   771: 00011644     0 NOTYPE  LOCAL  DEFAULT    2 $d
   772: 00011648     0 NOTYPE  LOCAL  DEFAULT    2 $a
   773: 00011768     0 NOTYPE  LOCAL  DEFAULT    2 $d
   774: 0001176c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   775: 00011814     0 NOTYPE  LOCAL  DEFAULT    2 $d
   776: 0001181c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   777: 000118b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   778: 001163ac     0 NOTYPE  LOCAL  DEFAULT   15 $d
   779: 001163ac     4 OBJECT  LOCAL  DEFAULT   15 disktab_size
   780: 001163b0     4 OBJECT  LOCAL  DEFAULT   15 disktab
   781: 001163b4     4 OBJECT  LOCAL  DEFAULT   15 diskdevs_mutex
   782: 001163b8     1 OBJECT  LOCAL  DEFAULT   15 diskdevs_protected
   783: 00001394     0 NOTYPE  LOCAL  DEFAULT   22 $d
   784: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_chown.c
   785: 000118bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   786: 00001588     0 NOTYPE  LOCAL  DEFAULT   22 $d
   787: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_dir_default.c
   788: 000118f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   789: 000118f0    64 FUNC    LOCAL  DEFAULT    2 IMFS_stat_directory
   790: 00011930   340 FUNC    LOCAL  DEFAULT    2 IMFS_dir_read
   791: 00011a80     0 NOTYPE  LOCAL  DEFAULT    2 $d
   792: 00101780     0 NOTYPE  LOCAL  DEFAULT    6 $d
   793: 00101794    60 OBJECT  LOCAL  DEFAULT    6 IMFS_dir_default_handlers
   794: 000015b8     0 NOTYPE  LOCAL  DEFAULT   22 $d
   795: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_dir.c
   796: 00011a84     0 NOTYPE  LOCAL  DEFAULT    2 $a
   797: 00001608     0 NOTYPE  LOCAL  DEFAULT   22 $d
   798: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_eval.c
   799: 00011af4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   800: 00011af4    28 FUNC    LOCAL  DEFAULT    2 IMFS_eval_is_directory
   801: 00011b10   472 FUNC    LOCAL  DEFAULT    2 IMFS_eval_token
   802: 00011cf4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   803: 001017d0     0 NOTYPE  LOCAL  DEFAULT    6 $d
   804: 001017d0     8 OBJECT  LOCAL  DEFAULT    6 IMFS_eval_config
   805: 00001640     0 NOTYPE  LOCAL  DEFAULT   22 $d
   806: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_fchmod.c
   807: 00011cf8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   808: 0000169c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   809: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_handlers_device.c
   810: 00011d28     0 NOTYPE  LOCAL  DEFAULT    2 $a
   811: 00011d28    20 FUNC    LOCAL  DEFAULT    2 IMFS_node_initialize_devi
   812: 00011d3c    24 FUNC    LOCAL  DEFAULT    2 IMFS_stat_device
   813: 001017d8     0 NOTYPE  LOCAL  DEFAULT    6 $d
   814: 001017ec    60 OBJECT  LOCAL  DEFAULT    6 IMFS_device_handlers
   815: 000016cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
   816: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_init.c
   817: 00011d54     0 NOTYPE  LOCAL  DEFAULT    2 $a
   818: 00011db4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   819: 00101828     0 NOTYPE  LOCAL  DEFAULT    6 $d
   820: 00101828    76 OBJECT  LOCAL  DEFAULT    6 IMFS_ops
   821: 00101874    16 OBJECT  LOCAL  DEFAULT    6 IMFS_default_mknod_contro
   822: 000016fc     0 NOTYPE  LOCAL  DEFAULT   22 $d
   823: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_initsupp.c
   824: 00011db8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   825: 00011dbc    24 FUNC    LOCAL  DEFAULT    2 IMFS_node_initialize_enos
   826: 00011f58     0 NOTYPE  LOCAL  DEFAULT    2 $d
   827: 00011f6c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   828: 00101884     0 NOTYPE  LOCAL  DEFAULT    6 $d
   829: 001065cc     0 NOTYPE  LOCAL  DEFAULT    6 $d
   830: 001163bc     0 NOTYPE  LOCAL  DEFAULT   15 $d
   831: 0000172c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   832: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_link.c
   833: 00011fbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   834: 00011fbc    80 FUNC    LOCAL  DEFAULT    2 IMFS_stat_hard_link
   835: 0001200c     8 FUNC    LOCAL  DEFAULT    2 IMFS_node_initialize_hard
   836: 00012014   132 FUNC    LOCAL  DEFAULT    2 IMFS_node_remove_hard_lin
   837: 0001213c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   838: 00101898     0 NOTYPE  LOCAL  DEFAULT    6 $d
   839: 00101898    16 OBJECT  LOCAL  DEFAULT    6 IMFS_node_control_hard_li
   840: 001018a8    60 OBJECT  LOCAL  DEFAULT    6 IMFS_link_handlers
   841: 00001810     0 NOTYPE  LOCAL  DEFAULT   22 $d
   842: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_memfile.c
   843: 00012144     0 NOTYPE  LOCAL  DEFAULT    2 $a
   844: 00012144    52 FUNC    LOCAL  DEFAULT    2 memfile_alloc_block
   845: 00012170     0 NOTYPE  LOCAL  DEFAULT    2 $d
   846: 00012178     0 NOTYPE  LOCAL  DEFAULT    2 $a
   847: 00012178   524 FUNC    LOCAL  DEFAULT    2 IMFS_memfile_get_block_po
   848: 00012380     0 NOTYPE  LOCAL  DEFAULT    2 $d
   849: 00012384     0 NOTYPE  LOCAL  DEFAULT    2 $a
   850: 00012384   128 FUNC    LOCAL  DEFAULT    2 memfile_free_blocks_in_ta
   851: 00012400     0 NOTYPE  LOCAL  DEFAULT    2 $d
   852: 00012404     0 NOTYPE  LOCAL  DEFAULT    2 $a
   853: 00012404   472 FUNC    LOCAL  DEFAULT    2 IMFS_memfile_extend
   854: 000125d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   855: 000125dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   856: 000125dc    92 FUNC    LOCAL  DEFAULT    2 memfile_ftruncate
   857: 00012638   412 FUNC    LOCAL  DEFAULT    2 memfile_read
   858: 000127d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   859: 000127d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   860: 000127d4   316 FUNC    LOCAL  DEFAULT    2 IMFS_memfile_destroy
   861: 0001290c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   862: 00012910     0 NOTYPE  LOCAL  DEFAULT    2 $a
   863: 00012abc     0 NOTYPE  LOCAL  DEFAULT    2 $d
   864: 00012ac0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   865: 00012ac0    92 FUNC    LOCAL  DEFAULT    2 memfile_write
   866: 001018e4     0 NOTYPE  LOCAL  DEFAULT    6 $d
   867: 001018f8    60 OBJECT  LOCAL  DEFAULT    6 IMFS_memfile_handlers
   868: 001163c0     0 NOTYPE  LOCAL  DEFAULT   15 $d
   869: 00001894     0 NOTYPE  LOCAL  DEFAULT   22 $d
   870: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_mknod.c
   871: 00012b1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   872: 00001a3c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   873: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_mount.c
   874: 00012bc0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   875: 00001a70     0 NOTYPE  LOCAL  DEFAULT   22 $d
   876: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_rename.c
   877: 00012c1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   878: 00001a98     0 NOTYPE  LOCAL  DEFAULT   22 $d
   879: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_rmnod.c
   880: 00012d18     0 NOTYPE  LOCAL  DEFAULT    2 $a
   881: 00001ad4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   882: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_stat_file.c
   883: 00012d74     0 NOTYPE  LOCAL  DEFAULT    2 $a
   884: 00012da0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   885: 00001afc     0 NOTYPE  LOCAL  DEFAULT   22 $d
   886: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_stat.c
   887: 00012da4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   888: 00001b28     0 NOTYPE  LOCAL  DEFAULT   22 $d
   889: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_symlink.c
   890: 00012e08     0 NOTYPE  LOCAL  DEFAULT    2 $a
   891: 00012e08    28 FUNC    LOCAL  DEFAULT    2 IMFS_node_initialize_sym_
   892: 00012e24    52 FUNC    LOCAL  DEFAULT    2 IMFS_stat_sym_link
   893: 00012ec8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   894: 00012ed0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   895: 00101934     0 NOTYPE  LOCAL  DEFAULT    6 $d
   896: 00101934    16 OBJECT  LOCAL  DEFAULT    6 IMFS_node_control_sym_lin
   897: 00101944    60 OBJECT  LOCAL  DEFAULT    6 IMFS_link_handlers
   898: 00001b58     0 NOTYPE  LOCAL  DEFAULT   22 $d
   899: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_unmount.c
   900: 00012f34     0 NOTYPE  LOCAL  DEFAULT    2 $a
   901: 00001be4     0 NOTYPE  LOCAL  DEFAULT   22 $d
   902: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_utime.c
   903: 00012f98     0 NOTYPE  LOCAL  DEFAULT    2 $a
   904: 00001c0c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   905: 00000000     0 FILE    LOCAL  DEFAULT  ABS ioman.c
   906: 00012fbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   907: 00012fe4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   908: 00012fe8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   909: 00001c34     0 NOTYPE  LOCAL  DEFAULT   22 $d
   910: 00000000     0 FILE    LOCAL  DEFAULT  ABS tftpDriver.c
   911: 0001304c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   912: 0001304c     8 FUNC    LOCAL  DEFAULT    2 rtems_tftp_ftruncate
   913: 00013054    64 FUNC    LOCAL  DEFAULT    2 rtems_tftp_fstat
   914: 0001308c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   915: 00013094     0 NOTYPE  LOCAL  DEFAULT    2 $a
   916: 00013094    28 FUNC    LOCAL  DEFAULT    2 rtems_tftp_are_nodes_equa
   917: 000130b0     8 FUNC    LOCAL  DEFAULT    2 rtems_tftp_free_node_info
   918: 000130b8   116 FUNC    LOCAL  DEFAULT    2 releaseStream
   919: 0001312c    88 FUNC    LOCAL  DEFAULT    2 rtems_tftpfs_shutdown
   920: 00013184    60 FUNC    LOCAL  DEFAULT    2 rtems_tftp_clone
   921: 000131c0   520 FUNC    LOCAL  DEFAULT    2 rtems_tftp_eval_path
   922: 000133c8   104 FUNC    LOCAL  DEFAULT    2 sendAck
   923: 00013430    84 FUNC    LOCAL  DEFAULT    2 sendStifle.isra.8
   924: 00013480     0 NOTYPE  LOCAL  DEFAULT    2 $d
   925: 00013484     0 NOTYPE  LOCAL  DEFAULT    2 $a
   926: 00013484   268 FUNC    LOCAL  DEFAULT    2 getPacket
   927: 00013584     0 NOTYPE  LOCAL  DEFAULT    2 $d
   928: 00013590     0 NOTYPE  LOCAL  DEFAULT    2 $a
   929: 00013590   296 FUNC    LOCAL  DEFAULT    2 rtems_tftp_flush
   930: 000136b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   931: 000136b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   932: 000136b8   404 FUNC    LOCAL  DEFAULT    2 rtems_tftp_read
   933: 00013844     0 NOTYPE  LOCAL  DEFAULT    2 $d
   934: 0001384c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   935: 0001384c   184 FUNC    LOCAL  DEFAULT    2 rtems_tftp_write
   936: 00013904   172 FUNC    LOCAL  DEFAULT    2 rtems_tftp_close
   937: 000139ac     0 NOTYPE  LOCAL  DEFAULT    2 $d
   938: 000139b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   939: 000139b0  1344 FUNC    LOCAL  DEFAULT    2 rtems_tftp_open
   940: 00013ec8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   941: 00013ef0     0 NOTYPE  LOCAL  DEFAULT    2 $a
   942: 00014048     0 NOTYPE  LOCAL  DEFAULT    2 $d
   943: 00101980     0 NOTYPE  LOCAL  DEFAULT    6 $d
   944: 00101980    32 OBJECT  LOCAL  DEFAULT    6 errorMap.10839
   945: 001019a0    60 OBJECT  LOCAL  DEFAULT    6 rtems_tftp_handlers
   946: 001019dc    76 OBJECT  LOCAL  DEFAULT    6 rtems_tftp_ops
   947: 00101a28     0 NOTYPE  LOCAL  DEFAULT    6 $d
   948: 00001c80     0 NOTYPE  LOCAL  DEFAULT   22 $d
   949: 00000000     0 FILE    LOCAL  DEFAULT  ABS gethostnamadr.c
   950: 00014058     0 NOTYPE  LOCAL  DEFAULT    2 $a
   951: 00014058   356 FUNC    LOCAL  DEFAULT    2 init_services
   952: 000141a4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   953: 000141bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
   954: 000141bc   264 FUNC    LOCAL  DEFAULT    2 __dns_decodename.constpro
   955: 000142c4   680 FUNC    LOCAL  DEFAULT    2 __dns_gethostbyx_r.constp
   956: 0001459c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   957: 000145ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
   958: 000145f4     0 NOTYPE  LOCAL  DEFAULT    2 $d
   959: 000145f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
   960: 00014634     0 NOTYPE  LOCAL  DEFAULT    2 $d
   961: 00014638     0 NOTYPE  LOCAL  DEFAULT    2 $a
   962: 0001466c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   963: 0001467c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   964: 000146d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
   965: 000146d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
   966: 00101a64     0 NOTYPE  LOCAL  DEFAULT    6 $d
   967: 00101a64    88 OBJECT  LOCAL  DEFAULT    6 service_names
   968: 00101abc     0 NOTYPE  LOCAL  DEFAULT    6 $d
   969: 001163c4     0 NOTYPE  LOCAL  DEFAULT   15 $d
   970: 001163c4     4 OBJECT  LOCAL  DEFAULT   15 service_order
   971: 001163c8     4 OBJECT  LOCAL  DEFAULT   15 service_done
   972: 00001ef8     0 NOTYPE  LOCAL  DEFAULT   22 $d
   973: 00000000     0 FILE    LOCAL  DEFAULT  ABS inet_addr.c
   974: 0001493c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   975: 00014a7c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   976: 00014a90     0 NOTYPE  LOCAL  DEFAULT    2 $a
   977: 00014b14     0 NOTYPE  LOCAL  DEFAULT    2 $d
   978: 00014b18     0 NOTYPE  LOCAL  DEFAULT    2 $a
   979: 0000207c     0 NOTYPE  LOCAL  DEFAULT   22 $d
   980: 00000000     0 FILE    LOCAL  DEFAULT  ABS inet_pton.c
   981: 00014b3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   982: 00014b3c   248 FUNC    LOCAL  DEFAULT    2 inet_pton4
   983: 00014c30     0 NOTYPE  LOCAL  DEFAULT    2 $d
   984: 00014c34     0 NOTYPE  LOCAL  DEFAULT    2 $a
   985: 00014e5c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   986: 00101b24     0 NOTYPE  LOCAL  DEFAULT    6 $d
   987: 00101b24    11 OBJECT  LOCAL  DEFAULT    6 digits.7895
   988: 00101b30    17 OBJECT  LOCAL  DEFAULT    6 xdigits_u.7911
   989: 00101b44    17 OBJECT  LOCAL  DEFAULT    6 xdigits_l.7910
   990: 000020d8     0 NOTYPE  LOCAL  DEFAULT   22 $d
   991: 00000000     0 FILE    LOCAL  DEFAULT  ABS res_init.c
   992: 00014e68     0 NOTYPE  LOCAL  DEFAULT    2 $a
   993: 00014e68   436 FUNC    LOCAL  DEFAULT    2 res_setoptions
   994: 00014ff8     0 NOTYPE  LOCAL  DEFAULT    2 $d
   995: 0001501c     0 NOTYPE  LOCAL  DEFAULT    2 $a
   996: 0001501c   100 FUNC    LOCAL  DEFAULT    2 net_mask
   997: 0001507c     0 NOTYPE  LOCAL  DEFAULT    2 $d
   998: 00015080     0 NOTYPE  LOCAL  DEFAULT    2 $a
   999: 0001587c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1000: 00101b58     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1001: 00101b58     3 OBJECT  LOCAL  DEFAULT    6 sort_mask
  1002: 00101b5c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1003: 00002158     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1004: 00000000     0 FILE    LOCAL  DEFAULT  ABS res_query.c
  1005: 000158d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1006: 000158d0   372 FUNC    LOCAL  DEFAULT    2 __hostalias.part.0
  1007: 00015a34     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1008: 00015a44     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1009: 00015c38     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1010: 00015c50     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1011: 00015da4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1012: 00015db8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1013: 00015df8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1014: 00015dfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1015: 00016178     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1016: 00101c44     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1017: 001163cc     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1018: 001163cc  1025 OBJECT  LOCAL  DEFAULT   15 abuf.9429
  1019: 000021f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1020: 00000000     0 FILE    LOCAL  DEFAULT  ABS res_send.c
  1021: 00016184     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1022: 00016184    88 FUNC    LOCAL  DEFAULT    2 Perror
  1023: 000161d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1024: 000161dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1025: 000161dc   132 FUNC    LOCAL  DEFAULT    2 Aerror.isra.0
  1026: 00016258     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1027: 00016260     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1028: 0001626c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1029: 00016270     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1030: 0001627c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1031: 00016280     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1032: 00016300     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1033: 00016304     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1034: 000163f4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1035: 000163f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1036: 0001652c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1037: 00016530     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1038: 00016564     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1039: 0001656c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1040: 000166c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1041: 000166d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1042: 00017058     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1043: 00017068     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1044: 00017354     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1045: 00113208     0 NOTYPE  LOCAL  DEFAULT   14 $d
  1046: 00113208     4 OBJECT  LOCAL  DEFAULT   14 s
  1047: 00101cf8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1048: 001167d0     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1049: 001167d0     4 OBJECT  LOCAL  DEFAULT   15 Qhook
  1050: 001167d4     4 OBJECT  LOCAL  DEFAULT   15 Rhook
  1051: 001167d8     4 OBJECT  LOCAL  DEFAULT   15 connected
  1052: 001167dc     4 OBJECT  LOCAL  DEFAULT   15 vc
  1053: 00002310     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1054: 00000000     0 FILE    LOCAL  DEFAULT  ABS send.c
  1055: 000173c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1056: 00002478     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1057: 00000000     0 FILE    LOCAL  DEFAULT  ABS base_fs.c
  1058: 000173e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1059: 0001743c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1060: 00101eb8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1061: 000024a4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1062: 00000000     0 FILE    LOCAL  DEFAULT  ABS calloc.c
  1063: 00017450     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1064: 000024d4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1065: 00000000     0 FILE    LOCAL  DEFAULT  ABS close.c
  1066: 0001747c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1067: 000174ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1068: 000174f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1069: 00002500     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1070: 00000000     0 FILE    LOCAL  DEFAULT  ABS free.c
  1071: 000174fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1072: 00017558     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1073: 00101ec0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1074: 0000253c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1075: 00000000     0 FILE    LOCAL  DEFAULT  ABS getegid.c
  1076: 00017560     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1077: 00002578     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1078: 00000000     0 FILE    LOCAL  DEFAULT  ABS geteuid.c
  1079: 00017570     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1080: 000025a0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1081: 00000000     0 FILE    LOCAL  DEFAULT  ABS getpid.c
  1082: 00017580     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1083: 000025c8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1084: 00000000     0 FILE    LOCAL  DEFAULT  ABS __gettod.c
  1085: 00017590     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1086: 000175ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1087: 000175f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1088: 00017658     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1089: 000025f8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1090: 00000000     0 FILE    LOCAL  DEFAULT  ABS issetugid.c
  1091: 00017660     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1092: 0000264c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1093: 00000000     0 FILE    LOCAL  DEFAULT  ABS libio_exit.c
  1094: 00017668     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1095: 0000266c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1096: 00000000     0 FILE    LOCAL  DEFAULT  ABS libio_init.c
  1097: 00017688     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1098: 00017738     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1099: 00002698     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1100: 00000000     0 FILE    LOCAL  DEFAULT  ABS libio.c
  1101: 00017758     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1102: 00017788     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1103: 0001778c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1104: 00017824     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1105: 0001782c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1106: 00017874     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1107: 00101ef8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1108: 00101ef8    48 OBJECT  LOCAL  DEFAULT    6 access_modes_assoc
  1109: 00101f28    48 OBJECT  LOCAL  DEFAULT    6 status_flags_assoc
  1110: 00101f58     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1111: 000026cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1112: 00000000     0 FILE    LOCAL  DEFAULT  ABS malloc_deferred.c
  1113: 0001787c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1114: 000178a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1115: 000178a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1116: 000178c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1117: 000178cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1118: 000178d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1119: 0011320c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  1120: 00002748     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1121: 00000000     0 FILE    LOCAL  DEFAULT  ABS malloc_initialize.c
  1122: 000178dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1123: 0001795c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1124: 00002790     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1125: 00000000     0 FILE    LOCAL  DEFAULT  ABS malloc.c
  1126: 00017968     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1127: 00017a10     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1128: 000027c8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1129: 00000000     0 FILE    LOCAL  DEFAULT  ABS mkdir.c
  1130: 00017a1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1131: 000027f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1132: 00000000     0 FILE    LOCAL  DEFAULT  ABS mknod.c
  1133: 00017a2c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1134: 00002814     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1135: 00000000     0 FILE    LOCAL  DEFAULT  ABS mount.c
  1136: 00017b14     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1137: 00017e6c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1138: 00101f90     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1139: 00113218     0 NOTYPE  LOCAL  DEFAULT   14 $d
  1140: 001102c4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1141: 00002878     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1142: 00000000     0 FILE    LOCAL  DEFAULT  ABS newlibc_init.c
  1143: 00017e7c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1144: 000028cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1145: 00000000     0 FILE    LOCAL  DEFAULT  ABS newlibc_reent.c
  1146: 00017e80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1147: 00017f24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1148: 00017f3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1149: 00101fc0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1150: 000028ec     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1151: 00000000     0 FILE    LOCAL  DEFAULT  ABS open_dev_console.c
  1152: 00017f44     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1153: 00017fa0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1154: 0010052c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1155: 0000292c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1156: 00000000     0 FILE    LOCAL  DEFAULT  ABS open.c
  1157: 00017fac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1158: 000181a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1159: 000181a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1160: 00002954     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1161: 00000000     0 FILE    LOCAL  DEFAULT  ABS printk.c
  1162: 000181b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1163: 000029c0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1164: 00000000     0 FILE    LOCAL  DEFAULT  ABS printk_plugin.c
  1165: 000181e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1166: 00002a04     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1167: 00000000     0 FILE    LOCAL  DEFAULT  ABS privateenv.c
  1168: 0001821c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1169: 0001823c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1170: 00018244     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1171: 00018274     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1172: 00018278     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1173: 00018278   100 FUNC    LOCAL  DEFAULT    2 free_user_env_protected
  1174: 000182d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1175: 000182dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1176: 000183a4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1177: 000183b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1178: 000183e4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1179: 00002a44     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1180: 00000000     0 FILE    LOCAL  DEFAULT  ABS read.c
  1181: 000183ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1182: 00018474     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1183: 0001847c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1184: 00002ae0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1185: 00000000     0 FILE    LOCAL  DEFAULT  ABS realloc.c
  1186: 0001848c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1187: 0001858c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1188: 00002b20     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1189: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems_heap_null_extend.c
  1190: 00018598     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1191: 00002b6c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1192: 00000000     0 FILE    LOCAL  DEFAULT  ABS stat.c
  1193: 000185a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1194: 00002b8c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1195: 00000000     0 FILE    LOCAL  DEFAULT  ABS sup_fs_check_permissions.
  1196: 0001860c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1197: 00002bcc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1198: 00000000     0 FILE    LOCAL  DEFAULT  ABS sup_fs_eval_path_generic.
  1199: 000186e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1200: 000188d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1201: 00103310     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1202: 00002c18     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1203: 00000000     0 FILE    LOCAL  DEFAULT  ABS sup_fs_eval_path.c
  1204: 000188e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1205: 000188e0    56 FUNC    LOCAL  DEFAULT    2 free_location
  1206: 00018970     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1207: 00018974     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1208: 00018974   172 FUNC    LOCAL  DEFAULT    2 check_access
  1209: 00018a94   224 FUNC    LOCAL  DEFAULT    2 eval_path_start
  1210: 00018cec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1211: 00018cf0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1212: 00103310     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1213: 00002c88     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1214: 00000000     0 FILE    LOCAL  DEFAULT  ABS sup_fs_location.c
  1215: 00018e50     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1216: 00018efc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1217: 00018f00     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1218: 00018f78     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1219: 00018f80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1220: 00018f80   168 FUNC    LOCAL  DEFAULT    2 release_with_count
  1221: 0001913c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1222: 00019148     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1223: 0001918c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1224: 00019194     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1225: 0001929c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1226: 000192a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1227: 001167e0     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1228: 001167e0     4 OBJECT  LOCAL  DEFAULT   15 deferred_released_global_
  1229: 00002e70     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1230: 00000000     0 FILE    LOCAL  DEFAULT  ABS sup_fs_next_token.c
  1231: 0001931c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1232: 00002fb0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1233: 00000000     0 FILE    LOCAL  DEFAULT  ABS termiosinitialize.c
  1234: 00019470     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1235: 000194b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1236: 00002fe8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1237: 00000000     0 FILE    LOCAL  DEFAULT  ABS termios.c
  1238: 000194b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1239: 000194b8    36 FUNC    LOCAL  DEFAULT    2 rtems_termios_callback_fi
  1240: 000194dc    20 FUNC    LOCAL  DEFAULT    2 rtems_termios_callback_la
  1241: 000194f0    16 FUNC    LOCAL  DEFAULT    2 rtems_termios_callback_po
  1242: 00019500    16 FUNC    LOCAL  DEFAULT    2 rtems_termios_callback_wr
  1243: 00019510    28 FUNC    LOCAL  DEFAULT    2 rtems_termios_callback_se
  1244: 0001952c    16 FUNC    LOCAL  DEFAULT    2 rtems_termios_callback_st
  1245: 0001953c    16 FUNC    LOCAL  DEFAULT    2 rtems_termios_callback_st
  1246: 0001954c   160 FUNC    LOCAL  DEFAULT    2 startXmit
  1247: 000195ec   404 FUNC    LOCAL  DEFAULT    2 rtems_termios_refill_tran
  1248: 00019778     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1249: 00019780     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1250: 00019780   124 FUNC    LOCAL  DEFAULT    2 rtems_termios_txdaemon
  1251: 000197f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1252: 000197fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1253: 000197fc   112 FUNC    LOCAL  DEFAULT    2 drainOutput.part.5
  1254: 0001986c   340 FUNC    LOCAL  DEFAULT    2 rtems_termios_destroy_tty
  1255: 000199bc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1256: 000199c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1257: 000199c0  1372 FUNC    LOCAL  DEFAULT    2 rtems_termios_open_tty
  1258: 00019ecc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1259: 0001b770   120 FUNC    LOCAL  DEFAULT    2 rtems_termios_rxdaemon
  1260: 00019f1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1261: 0001a044     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1262: 0001a04c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1263: 0001a134     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1264: 0001a13c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1265: 0001a20c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1266: 0001a214     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1267: 0001a300     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1268: 0001a308     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1269: 0001a3d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1270: 0001a3dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1271: 0001a440     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1272: 0001a444     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1273: 0001a458     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1274: 0001a45c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1275: 0001a8a8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1276: 0001a8b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1277: 0001aa10   356 FUNC    LOCAL  DEFAULT    2 oproc
  1278: 0001aa40     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1279: 0001aa58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1280: 0001ab68     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1281: 0001ab74     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1282: 0001ab74   132 FUNC    LOCAL  DEFAULT    2 echo
  1283: 0001abf4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1284: 0001abf8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1285: 0001abf8   492 FUNC    LOCAL  DEFAULT    2 erase
  1286: 0001add8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1287: 0001ade4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1288: 0001ade4   448 FUNC    LOCAL  DEFAULT    2 iproc
  1289: 0001af9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1290: 0001afa4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1291: 0001afa4   116 FUNC    LOCAL  DEFAULT    2 siproc
  1292: 0001b014     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1293: 0001b018     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1294: 0001b0dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1295: 0001b0e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1296: 0001b470     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1297: 0001b480     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1298: 0001b768     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1299: 0001b770     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1300: 0001b84c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1301: 00113224     0 NOTYPE  LOCAL  DEFAULT   14 $d
  1302: 00113224     4 OBJECT  LOCAL  DEFAULT   14 rtems_termios_raw_input_s
  1303: 00113228     4 OBJECT  LOCAL  DEFAULT   14 rtems_termios_raw_output_
  1304: 0011322c     4 OBJECT  LOCAL  DEFAULT   14 rtems_termios_cbufsize
  1305: 00113230     1 OBJECT  LOCAL  DEFAULT   14 c.9904
  1306: 00113234    12 OBJECT  LOCAL  DEFAULT   14 rtems_termios_devices
  1307: 00101fc4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1308: 001167e4     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1309: 001168e4     4 OBJECT  LOCAL  DEFAULT   15 rtems_termios_ttyHead
  1310: 001168e8     4 OBJECT  LOCAL  DEFAULT   15 rtems_termios_ttyTail
  1311: 00003018     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1312: 00000000     0 FILE    LOCAL  DEFAULT  ABS termios_setinitialbaud.c
  1313: 0001b850     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1314: 00003458     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1315: 00000000     0 FILE    LOCAL  DEFAULT  ABS unlink.c
  1316: 0001b884     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1317: 00003480     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1318: 00000000     0 FILE    LOCAL  DEFAULT  ABS __usrenv.c
  1319: 0001b918     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1320: 0001b918     8 FUNC    LOCAL  DEFAULT    2 null_handler_open
  1321: 0001b920     8 FUNC    LOCAL  DEFAULT    2 null_handler_fstat
  1322: 0001b928     4 FUNC    LOCAL  DEFAULT    2 null_op_lock_or_unlock
  1323: 0001b92c     8 FUNC    LOCAL  DEFAULT    2 null_op_mknod
  1324: 0001b934     8 FUNC    LOCAL  DEFAULT    2 null_op_rmnod
  1325: 0001b93c     8 FUNC    LOCAL  DEFAULT    2 null_op_link
  1326: 0001b944     8 FUNC    LOCAL  DEFAULT    2 null_op_fchmod
  1327: 0001b94c     8 FUNC    LOCAL  DEFAULT    2 null_op_chown
  1328: 0001b954     8 FUNC    LOCAL  DEFAULT    2 null_op_clonenode
  1329: 0001b95c     8 FUNC    LOCAL  DEFAULT    2 null_op_mount
  1330: 0001b964     8 FUNC    LOCAL  DEFAULT    2 null_op_unmount
  1331: 0001b96c     4 FUNC    LOCAL  DEFAULT    2 null_op_fsunmount_me
  1332: 0001b970     8 FUNC    LOCAL  DEFAULT    2 null_op_utime
  1333: 0001b978     8 FUNC    LOCAL  DEFAULT    2 null_op_symlink
  1334: 0001b980     8 FUNC    LOCAL  DEFAULT    2 null_op_readlink
  1335: 0001b988     8 FUNC    LOCAL  DEFAULT    2 null_op_rename
  1336: 0001b990     8 FUNC    LOCAL  DEFAULT    2 null_op_statvfs
  1337: 00101fcc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1338: 00101fcc    76 OBJECT  LOCAL  DEFAULT    6 null_ops
  1339: 00113244     0 NOTYPE  LOCAL  DEFAULT   14 $d
  1340: 001065cc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1341: 000034c0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1342: 00000000     0 FILE    LOCAL  DEFAULT  ABS vprintk.c
  1343: 0001b998     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1344: 0001be30     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1345: 001065cc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1346: 000035e0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1347: 00000000     0 FILE    LOCAL  DEFAULT  ABS write.c
  1348: 0001be38     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1349: 0001bec0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1350: 00003620     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1351: 00000000     0 FILE    LOCAL  DEFAULT  ABS writev.c
  1352: 0001bec8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1353: 0001bfb0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1354: 00003650     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1355: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems_glue.c
  1356: 0001bfb8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1357: 0001c168     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1358: 0001c180     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1359: 0001c1a8    36 FUNC    LOCAL  DEFAULT    2 taskEntry
  1360: 0001c1c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1361: 0001c1cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1362: 0001c270     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1363: 0001c284     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1364: 0001c2c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1365: 0001c2c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1366: 0001c338     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1367: 0001c33c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1368: 0001c33c   136 FUNC    LOCAL  DEFAULT    2 rtems_bsdnet_sleep
  1369: 0001c3c4   272 FUNC    LOCAL  DEFAULT    2 networkDaemon
  1370: 0001c4c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1371: 0001c4d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1372: 0001c560     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1373: 0001c564     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1374: 0001c570     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1375: 0001c574     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1376: 0001c5b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1377: 0001c5b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1378: 0001c5dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1379: 0001c5e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1380: 0001c6b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1381: 0001c6c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1382: 0001c714     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1383: 0001c71c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1384: 0001c7dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1385: 0001c7e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1386: 0001c814     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1387: 0001c818     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1388: 0001c858     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1389: 0001c85c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1390: 0001c89c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1391: 0001c8a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1392: 0001cc84     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1393: 0001ccb8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1394: 0001ccb8   556 FUNC    LOCAL  DEFAULT    2 rtems_bsdnet_setup_interf
  1395: 0001ceb4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1396: 0001cee4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1397: 0001d3f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1398: 0001d470     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1399: 0001d550     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1400: 0001d55c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1401: 0001d618     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1402: 0001d628     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1403: 0001d6e4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1404: 0001d6f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1405: 00102068     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1406: 00102068    16 OBJECT  LOCAL  DEFAULT    6 address_template
  1407: 001132f0     0 NOTYPE  LOCAL  DEFAULT   14 $d
  1408: 001132f0     4 OBJECT  LOCAL  DEFAULT   14 nmbuf
  1409: 00116920    12 OBJECT  LOCAL  DEFAULT   15 _rtems_bsdnet_nameserver
  1410: 00116914    12 OBJECT  LOCAL  DEFAULT   15 _rtems_bsdnet_ntpserver
  1411: 00102078     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1412: 001168ec     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1413: 001168ec     4 OBJECT  LOCAL  DEFAULT   15 networkSemaphore
  1414: 001168f0     4 OBJECT  LOCAL  DEFAULT   15 ticksWhenCalloutsLastChec
  1415: 001168f8     4 OBJECT  LOCAL  DEFAULT   15 networkDaemonTid
  1416: 001168fc     4 OBJECT  LOCAL  DEFAULT   15 networkDaemonPriority
  1417: 0000368c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1418: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems_malloc_mbuf.c
  1419: 0001d6f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1420: 00003ab8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1421: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems_syscall.c
  1422: 0001d6fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1423: 0001d6fc    16 FUNC    LOCAL  DEFAULT    2 rtems_bsdnet_fstat
  1424: 0001d70c    12 FUNC    LOCAL  DEFAULT    2 rtems_bsdnet_write
  1425: 0001d718    12 FUNC    LOCAL  DEFAULT    2 rtems_bsdnet_read
  1426: 0001d724   120 FUNC    LOCAL  DEFAULT    2 sockargstombuf
  1427: 0001d79c    88 FUNC    LOCAL  DEFAULT    2 rtems_bsdnet_fcntl
  1428: 0001d7f4   300 FUNC    LOCAL  DEFAULT    2 rtems_bsdnet_ioctl
  1429: 0001d91c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1430: 0001d920     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1431: 0001d920   104 FUNC    LOCAL  DEFAULT    2 rtems_bsdnet_close
  1432: 0001d988   168 FUNC    LOCAL  DEFAULT    2 rtems_bsdnet_makeFdForSoc
  1433: 0001da20     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1434: 0001da30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1435: 0001dac0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1436: 0001dacc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1437: 0001dacc   212 FUNC    LOCAL  DEFAULT    2 getpeersockname
  1438: 0001e864     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1439: 0001e878     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1440: 001023f0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1441: 001023f0    60 OBJECT  LOCAL  DEFAULT    6 socket_handlers
  1442: 00003ad8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1443: 00000000     0 FILE    LOCAL  DEFAULT  ABS sghostname.c
  1444: 0001fc10     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1445: 0001fc38     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1446: 0001fc40     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1447: 0001fcd0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1448: 001065cc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1449: 0011693c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1450: 0011693c     4 OBJECT  LOCAL  DEFAULT   15 rtems_hostname
  1451: 00003fd0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1452: 00000000     0 FILE    LOCAL  DEFAULT  ABS tcp_usrreq.c
  1453: 0001fcd4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1454: 0001fcd4    16 FUNC    LOCAL  DEFAULT    2 tcp_usr_sense
  1455: 0001fce4   156 FUNC    LOCAL  DEFAULT    2 tcp_usr_rcvoob
  1456: 0001fd80    36 FUNC    LOCAL  DEFAULT    2 tcp_usr_sockaddr
  1457: 0001fda4    40 FUNC    LOCAL  DEFAULT    2 tcp_usr_rcvd
  1458: 0001fdcc   172 FUNC    LOCAL  DEFAULT    2 tcp_usrclosed
  1459: 0001fde4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1460: 0001fdfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1461: 0001fe74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1462: 0001fe78     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1463: 0001fe78    64 FUNC    LOCAL  DEFAULT    2 tcp_usr_shutdown
  1464: 0001feb8    72 FUNC    LOCAL  DEFAULT    2 tcp_usr_listen
  1465: 0001ff00    84 FUNC    LOCAL  DEFAULT    2 tcp_usr_bind
  1466: 0001ff54   592 FUNC    LOCAL  DEFAULT    2 tcp_connect
  1467: 00020190     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1468: 000201a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1469: 000201a4   428 FUNC    LOCAL  DEFAULT    2 tcp_usr_send
  1470: 00020350   116 FUNC    LOCAL  DEFAULT    2 tcp_usr_connect
  1471: 000203c4    36 FUNC    LOCAL  DEFAULT    2 tcp_usr_peeraddr
  1472: 000203e8    36 FUNC    LOCAL  DEFAULT    2 tcp_usr_accept
  1473: 0002040c    44 FUNC    LOCAL  DEFAULT    2 tcp_usr_abort
  1474: 00020438     4 FUNC    LOCAL  DEFAULT    2 tcp_usr_control
  1475: 0002043c   116 FUNC    LOCAL  DEFAULT    2 tcp_disconnect
  1476: 000204b0    40 FUNC    LOCAL  DEFAULT    2 tcp_usr_disconnect
  1477: 000204d8    64 FUNC    LOCAL  DEFAULT    2 tcp_usr_detach
  1478: 00020518   224 FUNC    LOCAL  DEFAULT    2 tcp_usr_attach
  1479: 000205ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1480: 000205f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1481: 00020644     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1482: 00020664     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1483: 0002069c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1484: 000206bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1485: 00020860     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1486: 001133c0     0 NOTYPE  LOCAL  DEFAULT   14 $d
  1487: 001133c8    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp_rec
  1488: 001133f4    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp_sen
  1489: 00102454     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1490: 00110718     0 NOTYPE  LOCAL  DEFAULT   12 $d
  1491: 00110718     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1492: 0011071c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1493: 00004018     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1494: 00000000     0 FILE    LOCAL  DEFAULT  ABS udp_usrreq.c
  1495: 00020864     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1496: 00020864    68 FUNC    LOCAL  DEFAULT    2 udp_notify
  1497: 000208a8   480 FUNC    LOCAL  DEFAULT    2 udp_pcblist
  1498: 00020a84     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1499: 00020a88     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1500: 00020ab8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1501: 00020ac0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1502: 00021018     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1503: 00021034     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1504: 000210d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1505: 000210e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1506: 000210fc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1507: 00021100     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1508: 00021180     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1509: 000211d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1510: 0002152c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1511: 00110720     0 NOTYPE  LOCAL  DEFAULT   12 $d
  1512: 00110720     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1513: 00113480    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_udp_rec
  1514: 00110724     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1515: 001134ac    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_udp_max
  1516: 00110728     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1517: 001134d8    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_udp_pcb
  1518: 0011072c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1519: 00113504    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_udp_sta
  1520: 00110730     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1521: 00113530    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_udp_log
  1522: 00110734     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1523: 0011355c    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_udp_che
  1524: 00113464     0 NOTYPE  LOCAL  DEFAULT   14 $d
  1525: 00113464    16 OBJECT  LOCAL  DEFAULT   14 udp_in
  1526: 00113474     4 OBJECT  LOCAL  DEFAULT   14 udp_sendspace
  1527: 00113478     4 OBJECT  LOCAL  DEFAULT   14 udp_recvspace
  1528: 0011347c     4 OBJECT  LOCAL  DEFAULT   14 udpcksum
  1529: 00116940     4 OBJECT  LOCAL  DEFAULT   15 log_in_vain
  1530: 0010246c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1531: 00116940     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1532: 00004288     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1533: 00000000     0 FILE    LOCAL  DEFAULT  ABS uipc_domain.c
  1534: 00021544     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1535: 00021544   124 FUNC    LOCAL  DEFAULT    2 pfslowtimo
  1536: 000215b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1537: 000215c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1538: 000215c0   136 FUNC    LOCAL  DEFAULT    2 pffasttimo
  1539: 00021638     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1540: 00021648     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1541: 00021728     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1542: 00021748     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1543: 000217b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1544: 000217b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1545: 0002188c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1546: 00021890     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1547: 000218f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1548: 000043a8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1549: 00000000     0 FILE    LOCAL  DEFAULT  ABS uipc_mbuf.c
  1550: 000218fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1551: 00021960     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1552: 00021968     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1553: 00021a10     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1554: 00021a18     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1555: 00021ac4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1556: 00021acc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1557: 00021b60     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1558: 00021b68     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1559: 00021c00     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1560: 00021c08     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1561: 00021cb8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1562: 00021cc0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1563: 00021d84     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1564: 00021d98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1565: 00021e74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1566: 00021e88     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1567: 00021fa8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1568: 00021fb4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1569: 000222b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1570: 000222d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1571: 00022568     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1572: 00022580     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1573: 00022654     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1574: 00022658     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1575: 00022a70     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1576: 00022a84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1577: 00022d78     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1578: 00022d88     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1579: 000230d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1580: 000230f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1581: 00102534     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1582: 00116944     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1583: 00116944     4 OBJECT  LOCAL  DEFAULT   15 MCFail
  1584: 00116948     4 OBJECT  LOCAL  DEFAULT   15 MPFail
  1585: 00004470     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1586: 00000000     0 FILE    LOCAL  DEFAULT  ABS uipc_socket2.c
  1587: 0002323c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1588: 0002323c    44 FUNC    LOCAL  DEFAULT    2 old_abort
  1589: 00023268    44 FUNC    LOCAL  DEFAULT    2 old_accept
  1590: 00023294    44 FUNC    LOCAL  DEFAULT    2 old_attach
  1591: 000232c0    44 FUNC    LOCAL  DEFAULT    2 old_bind
  1592: 000232ec    44 FUNC    LOCAL  DEFAULT    2 old_connect
  1593: 00023318    44 FUNC    LOCAL  DEFAULT    2 old_connect2
  1594: 00023344    48 FUNC    LOCAL  DEFAULT    2 old_control
  1595: 00023374    44 FUNC    LOCAL  DEFAULT    2 old_detach
  1596: 000233a0    44 FUNC    LOCAL  DEFAULT    2 old_disconnect
  1597: 000233cc    44 FUNC    LOCAL  DEFAULT    2 old_listen
  1598: 000233f8    44 FUNC    LOCAL  DEFAULT    2 old_peeraddr
  1599: 00023424    44 FUNC    LOCAL  DEFAULT    2 old_rcvd
  1600: 00023450    48 FUNC    LOCAL  DEFAULT    2 old_rcvoob
  1601: 00023480    52 FUNC    LOCAL  DEFAULT    2 old_send
  1602: 000234b4    44 FUNC    LOCAL  DEFAULT    2 old_sense
  1603: 000234e0    44 FUNC    LOCAL  DEFAULT    2 old_shutdown
  1604: 0002350c    44 FUNC    LOCAL  DEFAULT    2 old_sockaddr
  1605: 0002354c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1606: 00023550     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1607: 000237dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1608: 000237e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1609: 00023898     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1610: 000238a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1611: 00023a90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1612: 00023a9c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1613: 00023b98     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1614: 00023b9c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1615: 00023d34     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1616: 00023d38     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1617: 000241d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1618: 000241f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1619: 00024248     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1620: 00024250     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1621: 00024344     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1622: 0002434c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1623: 00024690     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1624: 000246a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1625: 00110738     0 NOTYPE  LOCAL  DEFAULT   12 $d
  1626: 00110738     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1627: 001135d4    44 OBJECT  LOCAL  DEFAULT   14 sysctl___kern_sockbuf_was
  1628: 0011073c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1629: 00113600    44 OBJECT  LOCAL  DEFAULT   14 sysctl___kern_maxsockbuf
  1630: 00113588     0 NOTYPE  LOCAL  DEFAULT   14 $d
  1631: 00113588     4 OBJECT  LOCAL  DEFAULT   14 sb_efficiency
  1632: 00102548     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1633: 0011694c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1634: 0011694c     4 OBJECT  LOCAL  DEFAULT   15 old_mono_secs.9132
  1635: 00116950     4 OBJECT  LOCAL  DEFAULT   15 old_cnt.9134
  1636: 00116954     4 OBJECT  LOCAL  DEFAULT   15 cur_cnt.9133
  1637: 00116958     4 OBJECT  LOCAL  DEFAULT   15 rnd.9131
  1638: 00004718     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1639: 00000000     0 FILE    LOCAL  DEFAULT  ABS uipc_socket.c
  1640: 00024738     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1641: 00024738    68 FUNC    LOCAL  DEFAULT    2 rtems_sockbuf_close_notif
  1642: 000247ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1643: 000247f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1644: 00024830     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1645: 00024834     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1646: 00025034     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1647: 00025048     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1648: 00025e38     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1649: 00025e58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1650: 00025ffc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1651: 00026000     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1652: 00026284     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1653: 00026288     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1654: 00026610     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1655: 0002662c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1656: 000268d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1657: 000268ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1658: 0011362c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  1659: 0011362c     4 OBJECT  LOCAL  DEFAULT   14 somaxconn
  1660: 00113630    44 OBJECT  LOCAL  DEFAULT   14 sysctl___kern_somaxconn
  1661: 001025c0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1662: 00110740     0 NOTYPE  LOCAL  DEFAULT   12 $d
  1663: 00110740     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  1664: 00004c10     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1665: 00000000     0 FILE    LOCAL  DEFAULT  ABS keycreate.c
  1666: 000268f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1667: 00026958     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1668: 00004e70     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1669: 00000000     0 FILE    LOCAL  DEFAULT  ABS keygetspecific.c
  1670: 00026960     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1671: 00026a18     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1672: 00004ea0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1673: 00000000     0 FILE    LOCAL  DEFAULT  ABS key.c
  1674: 00026a28     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1675: 00026a28    92 FUNC    LOCAL  DEFAULT    2 _POSIX_Keys_Keypool_exten
  1676: 00026a80     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1677: 00026a84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1678: 00026b3c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1679: 0011695c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1680: 00004ed8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1681: 00000000     0 FILE    LOCAL  DEFAULT  ABS keysetspecific.c
  1682: 00026b4c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1683: 00026ca0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1684: 00004f3c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1685: 00000000     0 FILE    LOCAL  DEFAULT  ABS clockget.c
  1686: 00026cb4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1687: 00026d48     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1688: 00004f78     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1689: 00000000     0 FILE    LOCAL  DEFAULT  ABS clockgetsecondssinceepoch
  1690: 00026d4c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1691: 00026d98     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1692: 00004fa4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1693: 00000000     0 FILE    LOCAL  DEFAULT  ABS clockgettickspersecond.c
  1694: 00026d9c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1695: 00026db4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1696: 00004fcc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1697: 00000000     0 FILE    LOCAL  DEFAULT  ABS clockgettod.c
  1698: 00026dbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1699: 00027000     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1700: 00004ff4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1701: 00000000     0 FILE    LOCAL  DEFAULT  ABS clockgettodtimeval.c
  1702: 0002702c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1703: 0002708c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1704: 00005034     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1705: 00000000     0 FILE    LOCAL  DEFAULT  ABS clockgetuptimeseconds.c
  1706: 00027094     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1707: 000270b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1708: 00005064     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1709: 00000000     0 FILE    LOCAL  DEFAULT  ABS clockgetuptimetimeval.c
  1710: 000270b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1711: 000270f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1712: 00005084     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1713: 00000000     0 FILE    LOCAL  DEFAULT  ABS clocksetnsecshandler.c
  1714: 000270f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1715: 00027110     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1716: 000050b4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1717: 00000000     0 FILE    LOCAL  DEFAULT  ABS clocktick.c
  1718: 00027114     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1719: 00027170     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1720: 000050d4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1721: 00000000     0 FILE    LOCAL  DEFAULT  ABS clocktodtoseconds.c
  1722: 0002717c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1723: 00027214     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1724: 0010262c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1725: 000050fc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1726: 00000000     0 FILE    LOCAL  DEFAULT  ABS eventreceive.c
  1727: 00027228     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1728: 0002729c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1729: 00005124     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1730: 00000000     0 FILE    LOCAL  DEFAULT  ABS eventseize.c
  1731: 000272a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1732: 00027418     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1733: 0000515c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1734: 00000000     0 FILE    LOCAL  DEFAULT  ABS eventsend.c
  1735: 00027428     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1736: 00005188     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1737: 00000000     0 FILE    LOCAL  DEFAULT  ABS eventsurrender.c
  1738: 0002747c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1739: 00027594     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1740: 000051c0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1741: 00000000     0 FILE    LOCAL  DEFAULT  ABS eventtimeout.c
  1742: 0002759c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1743: 00027610     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1744: 000051f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1745: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtemsobjectgetname.c
  1746: 00027614     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1747: 00005210     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1748: 00000000     0 FILE    LOCAL  DEFAULT  ABS semcreate.c
  1749: 00027618     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1750: 00027820     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1751: 00005230     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1752: 00000000     0 FILE    LOCAL  DEFAULT  ABS semdata.c
  1753: 00000000     0 FILE    LOCAL  DEFAULT  ABS semdelete.c
  1754: 0002782c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1755: 00027988     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1756: 00005268     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1757: 00000000     0 FILE    LOCAL  DEFAULT  ABS semobtain.c
  1758: 00027994     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1759: 00027c58     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1760: 000052a8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1761: 00000000     0 FILE    LOCAL  DEFAULT  ABS semrelease.c
  1762: 00027c6c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1763: 00027d78     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1764: 000052f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1765: 00000000     0 FILE    LOCAL  DEFAULT  ABS semtranslatereturncode.c
  1766: 00102668     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1767: 00000000     0 FILE    LOCAL  DEFAULT  ABS statustext.c
  1768: 00027d88     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1769: 00027d9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1770: 00102678     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1771: 00102678   116 OBJECT  LOCAL  DEFAULT    6 status_code_text
  1772: 001026ec     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1773: 00005330     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1774: 00000000     0 FILE    LOCAL  DEFAULT  ABS systemeventreceive.c
  1775: 00027da4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1776: 00027e24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1777: 00005350     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1778: 00000000     0 FILE    LOCAL  DEFAULT  ABS systemeventsend.c
  1779: 00027e28     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1780: 00005388     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1781: 00000000     0 FILE    LOCAL  DEFAULT  ABS taskcreate.c
  1782: 00027e80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1783: 00027fc0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1784: 000053c0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1785: 00000000     0 FILE    LOCAL  DEFAULT  ABS taskdata.c
  1786: 00000000     0 FILE    LOCAL  DEFAULT  ABS taskdelete.c
  1787: 00027fd0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1788: 0002807c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1789: 00005408     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1790: 00000000     0 FILE    LOCAL  DEFAULT  ABS taskident.c
  1791: 00028080     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1792: 000280cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1793: 00005444     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1794: 00000000     0 FILE    LOCAL  DEFAULT  ABS taskinitusers.c
  1795: 000280d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1796: 00028188     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1797: 0000546c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1798: 00000000     0 FILE    LOCAL  DEFAULT  ABS taskself.c
  1799: 00028190     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1800: 000281a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1801: 000054a8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1802: 00000000     0 FILE    LOCAL  DEFAULT  ABS taskstart.c
  1803: 000281a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1804: 00028254     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1805: 000054c8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1806: 00000000     0 FILE    LOCAL  DEFAULT  ABS taskwakeafter.c
  1807: 00028258     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1808: 0002830c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1809: 00005508     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1810: 00000000     0 FILE    LOCAL  DEFAULT  ABS exinit.c
  1811: 00028318     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1812: 00028394     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1813: 000283ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1814: 000283d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1815: 00102974     0 NOTYPE  LOCAL  DEFAULT    6 $d
  1816: 00005534     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1817: 00000000     0 FILE    LOCAL  DEFAULT  ABS extension.c
  1818: 000283d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1819: 00028414     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1820: 000055ac     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1821: 00000000     0 FILE    LOCAL  DEFAULT  ABS fatal2.c
  1822: 0002841c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1823: 000055d8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1824: 00000000     0 FILE    LOCAL  DEFAULT  ABS fatal.c
  1825: 0002842c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1826: 00005600     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1827: 00000000     0 FILE    LOCAL  DEFAULT  ABS io.c
  1828: 00028440     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1829: 00028484     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1830: 00005628     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1831: 00000000     0 FILE    LOCAL  DEFAULT  ABS posixapi.c
  1832: 0002848c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1833: 000284b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1834: 00005654     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1835: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtemsapi.c
  1836: 000284bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1837: 000284fc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1838: 0000568c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1839: 00000000     0 FILE    LOCAL  DEFAULT  ABS apiext.c
  1840: 00028504     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1841: 00028518     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1842: 0002851c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1843: 00028528     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1844: 0002852c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1845: 00028558     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1846: 000056b8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1847: 00000000     0 FILE    LOCAL  DEFAULT  ABS apimutexlock.c
  1848: 0002855c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1849: 000286f4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1850: 00005704     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1851: 00000000     0 FILE    LOCAL  DEFAULT  ABS apimutex.c
  1852: 000286fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1853: 00028730     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1854: 00028734     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1855: 0002879c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1856: 0011696c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1857: 0011696c    56 OBJECT  LOCAL  DEFAULT   15 _API_Mutex_Information
  1858: 0000573c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1859: 00000000     0 FILE    LOCAL  DEFAULT  ABS apimutexunlock.c
  1860: 000287a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1861: 00028834     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1862: 0000578c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1863: 00000000     0 FILE    LOCAL  DEFAULT  ABS chainappend.c
  1864: 00028838     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1865: 000057c8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1866: 00000000     0 FILE    LOCAL  DEFAULT  ABS chainget.c
  1867: 00028864     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1868: 000057e8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1869: 00000000     0 FILE    LOCAL  DEFAULT  ABS chain.c
  1870: 00028898     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1871: 00005808     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1872: 00000000     0 FILE    LOCAL  DEFAULT  ABS coremutexflush.c
  1873: 000288ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1874: 00005834     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1875: 00000000     0 FILE    LOCAL  DEFAULT  ABS coremutex.c
  1876: 000288f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1877: 00028a48     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1878: 00005854     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1879: 00000000     0 FILE    LOCAL  DEFAULT  ABS coremutexseize.c
  1880: 00028a4c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1881: 00028b20     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1882: 00005880     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1883: 00000000     0 FILE    LOCAL  DEFAULT  ABS coremutexsurrender.c
  1884: 00028b28     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1885: 00028c38     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1886: 000058b4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1887: 00000000     0 FILE    LOCAL  DEFAULT  ABS coresemflush.c
  1888: 00028c3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1889: 000058e0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1890: 00000000     0 FILE    LOCAL  DEFAULT  ABS coresem.c
  1891: 00028c40     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1892: 00005900     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1893: 00000000     0 FILE    LOCAL  DEFAULT  ABS coresemsurrender.c
  1894: 00028c7c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1895: 0000592c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1896: 00000000     0 FILE    LOCAL  DEFAULT  ABS coretodget.c
  1897: 00028cc4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1898: 00028d2c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1899: 00005954     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1900: 00000000     0 FILE    LOCAL  DEFAULT  ABS coretod.c
  1901: 00028d30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1902: 00028d30     8 FUNC    LOCAL  DEFAULT    2 _TOD_Nanoseconds_since_ti
  1903: 00028d64     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1904: 00005988     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1905: 00000000     0 FILE    LOCAL  DEFAULT  ABS coretodsecondssinceepoch.
  1906: 00028d70     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1907: 00028d8c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1908: 000059b8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1909: 00000000     0 FILE    LOCAL  DEFAULT  ABS coretodtickle.c
  1910: 00028d90     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1911: 00028e18     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1912: 000059d8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1913: 00000000     0 FILE    LOCAL  DEFAULT  ABS freechain.c
  1914: 00028e30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1915: 00005a0c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1916: 00000000     0 FILE    LOCAL  DEFAULT  ABS heap.c
  1917: 00028ea4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1918: 00028ea4   268 FUNC    LOCAL  DEFAULT    2 _Heap_Block_split
  1919: 00005a54     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1920: 00000000     0 FILE    LOCAL  DEFAULT  ABS interr.c
  1921: 00029290     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1922: 000292f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1923: 00005b04     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1924: 00000000     0 FILE    LOCAL  DEFAULT  ABS isr.c
  1925: 00029304     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1926: 00029314     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1927: 00005b2c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1928: 00000000     0 FILE    LOCAL  DEFAULT  ABS iterateoverthreads.c
  1929: 00029318     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1930: 00029388     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1931: 00005b4c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1932: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectallocate.c
  1933: 0002938c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1934: 00029468     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1935: 00005b7c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1936: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectclose.c
  1937: 0002946c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1938: 00005bc4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1939: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectextendinformation.c
  1940: 00029480     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1941: 000297bc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1942: 00005be4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1943: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectfree.c
  1944: 000297c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1945: 00005c38     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1946: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectgetinfoid.c
  1947: 0002983c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1948: 00005c6c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1949: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectgetinfo.c
  1950: 00029850     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1951: 000298b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1952: 00005c8c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1953: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectgetisr.c
  1954: 000298b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1955: 00005cc0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1956: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectgetnameasstring.c
  1957: 00029924     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1958: 00029a78     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1959: 00005ce8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1960: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectget.c
  1961: 00029a80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1962: 00029b3c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1963: 00005d30     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1964: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectinitializeinformati
  1965: 00029b40     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1966: 00029bf8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1967: 001169a4     0 NOTYPE  LOCAL  DEFAULT   15 $d
  1968: 001169a4     4 OBJECT  LOCAL  DEFAULT   15 null_local_table.6564
  1969: 00005d60     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1970: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectnamespaceremove.c
  1971: 00029c00     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1972: 00005d9c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1973: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectnametoid.c
  1974: 00029c0c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1975: 00005dbc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1976: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectshrinkinformation.c
  1977: 00029c94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1978: 00005dfc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1979: 00000000     0 FILE    LOCAL  DEFAULT  ABS percpu.c
  1980: 00000000     0 FILE    LOCAL  DEFAULT  ABS pheapallocate.c
  1981: 00029d7c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1982: 00029dc4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1983: 00005e2c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1984: 00000000     0 FILE    LOCAL  DEFAULT  ABS pheapfree.c
  1985: 00029dc8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1986: 00029e00     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1987: 00005e5c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1988: 00000000     0 FILE    LOCAL  DEFAULT  ABS pheapgetblocksize.c
  1989: 00029e04     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1990: 00029e44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1991: 00005e88     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1992: 00000000     0 FILE    LOCAL  DEFAULT  ABS pheapresizeblock.c
  1993: 00029e48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1994: 00029ea0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  1995: 00005eb8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  1996: 00000000     0 FILE    LOCAL  DEFAULT  ABS rbtreeextract.c
  1997: 00029ea4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  1998: 00029ea4   608 FUNC    LOCAL  DEFAULT    2 _RBTree_Extract_validate
  1999: 00005eec     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2000: 00000000     0 FILE    LOCAL  DEFAULT  ABS rbtreefind.c
  2001: 0002a288     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2002: 00005f38     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2003: 00000000     0 FILE    LOCAL  DEFAULT  ABS rbtreeinsert.c
  2004: 0002a2f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2005: 00005f68     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2006: 00000000     0 FILE    LOCAL  DEFAULT  ABS rbtreenext.c
  2007: 0002a540     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2008: 00005f9c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2009: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerdefaultnodedestr
  2010: 0002a5d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2011: 00005fbc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2012: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerdefaultnodeinit.
  2013: 0002a5d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2014: 00005fdc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2015: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerdefaultreleasejo
  2016: 0002a5dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2017: 00005ffc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2018: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerdefaultstartidle
  2019: 0002a5e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2020: 0002a5ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2021: 0000601c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2022: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerdefaulttick.c
  2023: 0002a5f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2024: 0002a670     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2025: 0000603c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2026: 00000000     0 FILE    LOCAL  DEFAULT  ABS scheduler.c
  2027: 0002a674     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2028: 0002a680     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2029: 00006064     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2030: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerpriorityblock.c
  2031: 0002a684     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2032: 0002a760     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2033: 00006084     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2034: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerprioritychangepr
  2035: 0002a768     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2036: 0002a8e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2037: 000060b4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2038: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerpriority.c
  2039: 0002a8f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2040: 0002a944     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2041: 000060e8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2042: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerprioritypriority
  2043: 0002a948     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2044: 00006110     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2045: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerpriorityschedule
  2046: 0002a950     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2047: 0002a9bc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2048: 00006130     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2049: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerpriorityunblock.
  2050: 0002a9c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2051: 0002aa50     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2052: 00006150     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2053: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerpriorityupdate.c
  2054: 0002aa54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2055: 0000617c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2056: 00000000     0 FILE    LOCAL  DEFAULT  ABS schedulerpriorityyield.c
  2057: 0002aab8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2058: 0002ab5c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2059: 000061a8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2060: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadchangepriority.c
  2061: 0002ab64     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2062: 0002ac00     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2063: 000061d0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2064: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadclearstate.c
  2065: 0002ac04     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2066: 0002ac50     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2067: 00006200     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2068: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadcreateidle.c
  2069: 0002ac54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2070: 0002acfc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2071: 0000622c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2072: 00000000     0 FILE    LOCAL  DEFAULT  ABS threaddelayended.c
  2073: 0002ad18     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2074: 0002ad24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2075: 00006260     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2076: 00000000     0 FILE    LOCAL  DEFAULT  ABS threaddispatch.c
  2077: 0002ad28     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2078: 0002ae64     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2079: 0002ae74     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2080: 0002aea8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2081: 00006280     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2082: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadget.c
  2083: 0002aeac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2084: 0002aeac    64 FUNC    LOCAL  DEFAULT    2 _Thread_Get_objects_infor
  2085: 0002aee8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2086: 0002aeec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2087: 0002af44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2088: 0002af48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2089: 0002afac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2090: 000062cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2091: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadglobalconstruction.
  2092: 0002afb0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2093: 0002b040     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2094: 0000633c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2095: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadinitialize.c
  2096: 0002b048     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2097: 0002b280     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2098: 00006368     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2099: 00000000     0 FILE    LOCAL  DEFAULT  ABS thread.c
  2100: 0002b2a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2101: 0002b324     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2102: 000063c0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2103: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadqenqueue.c
  2104: 0002b330     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2105: 0002b330    52 FUNC    LOCAL  DEFAULT    2 _Thread_queue_Requeue_pri
  2106: 0002b360     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2107: 0002b364     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2108: 0002b364    84 FUNC    LOCAL  DEFAULT    2 _Thread_blocking_operatio
  2109: 0002b3b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2110: 0002b3b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2111: 0002b4a8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2112: 0002b4b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2113: 0002b544     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2114: 0002b54c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2115: 0002b608     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2116: 000063f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2117: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadqflush.c
  2118: 0002b610     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2119: 000064c8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2120: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadq.c
  2121: 0002b638     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2122: 000064f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2123: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadqtimeout.c
  2124: 0002b69c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2125: 0002b6d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2126: 00006524     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2127: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadrestart.c
  2128: 0002b6d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2129: 0002b6d8   132 FUNC    LOCAL  DEFAULT    2 _Thread_Make_zombie
  2130: 0002b758     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2131: 0002b75c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2132: 0002b75c   460 FUNC    LOCAL  DEFAULT    2 _Thread_Request_life_chan
  2133: 0002b920     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2134: 0002b928     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2135: 0002b9d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2136: 0002b9dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2137: 0002baec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2138: 0002baf8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2139: 0002bc70     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2140: 0011365c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2141: 0011365c    12 OBJECT  LOCAL  DEFAULT   14 _Thread_Zombies
  2142: 00006550     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2143: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadsetpriority.c
  2144: 0002bc74     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2145: 0002bc90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2146: 00006654     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2147: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadsetstate.c
  2148: 0002bc94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2149: 0002bcd4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2150: 00006674     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2151: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadstackallocate.c
  2152: 0002bcd8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2153: 0002bd18     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2154: 000066a0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2155: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadstackfree.c
  2156: 0002bd20     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2157: 0002bd30     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2158: 000066cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2159: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadstartmultitasking.c
  2160: 0002bd34     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2161: 0002bd54     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2162: 000066ec     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2163: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadstart.c
  2164: 0002bd58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2165: 0002bdd8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2166: 00006714     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2167: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadyield.c
  2168: 0002bde0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2169: 0002be14     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2170: 0000673c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2171: 00000000     0 FILE    LOCAL  DEFAULT  ABS timespecaddto.c
  2172: 0002be18     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2173: 0002be84     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2174: 00006764     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2175: 00000000     0 FILE    LOCAL  DEFAULT  ABS timespecsubtract.c
  2176: 0002be88     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2177: 0002bed8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2178: 0000678c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2179: 00000000     0 FILE    LOCAL  DEFAULT  ABS userextiterate.c
  2180: 0002bedc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2181: 0002c018     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2182: 00113668     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2183: 000067b4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2184: 00000000     0 FILE    LOCAL  DEFAULT  ABS userext.c
  2185: 0002c024     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2186: 0002c024    68 FUNC    LOCAL  DEFAULT    2 _User_extensions_Switch_v
  2187: 0002c064     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2188: 0002c068     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2189: 0002c0a8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2190: 00113674     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2191: 0000686c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2192: 00000000     0 FILE    LOCAL  DEFAULT  ABS watchdoginsert.c
  2193: 0002c0b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2194: 0002c1c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2195: 000068b0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2196: 00000000     0 FILE    LOCAL  DEFAULT  ABS watchdog.c
  2197: 0002c1d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2198: 0002c218     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2199: 000068e0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2200: 00000000     0 FILE    LOCAL  DEFAULT  ABS watchdogremove.c
  2201: 0002c22c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2202: 0002c2c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2203: 0000690c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2204: 00000000     0 FILE    LOCAL  DEFAULT  ABS watchdogtickle.c
  2205: 0002c2d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2206: 00006934     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2207: 00000000     0 FILE    LOCAL  DEFAULT  ABS watchdogtickssinceboot.c
  2208: 00000000     0 FILE    LOCAL  DEFAULT  ABS wkspace.c
  2209: 0002c368     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2210: 0002c4d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2211: 0002c4f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2212: 0002c504     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2213: 0002c508     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2214: 0002c520     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2215: 0002c524     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2216: 0002c530     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2217: 0002c534     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2218: 0002c560     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2219: 00006964     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2220: 00000000     0 FILE    LOCAL  DEFAULT  ABS libscorecpu_a-arm_exc_int
  2221: 0002c564     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2222: 0002c5f0     0 NOTYPE  LOCAL  DEFAULT    2 thread_dispatch_done
  2223: 0002c620     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2224: 00002414     0 NOTYPE  LOCAL  DEFAULT   18 $d
  2225: 00000000     0 FILE    LOCAL  DEFAULT  ABS libscorecpu_a-armv4-excep
  2226: 0002c624     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2227: 0002c69c     0 NOTYPE  LOCAL  DEFAULT    2 save_more_context
  2228: 0002c6e0     0 NOTYPE  LOCAL  DEFAULT    2 twiddle
  2229: 00002434     0 NOTYPE  LOCAL  DEFAULT   18 $d
  2230: 00000000     0 FILE    LOCAL  DEFAULT  ABS libscorecpu_a-cpu_asm.o
  2231: 0002c6e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2232: 00002454     0 NOTYPE  LOCAL  DEFAULT   18 $d
  2233: 00000000     0 FILE    LOCAL  DEFAULT  ABS cpu.c
  2234: 0002c700     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2235: 0002c798     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2236: 0002c7b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2237: 00113680     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2238: 000069ec     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2239: 00000000     0 FILE    LOCAL  DEFAULT  ABS fdisk.c
  2240: 0002c808     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2241: 0002c808  1644 FUNC    LOCAL  DEFAULT    2 rtems_bdpart_shell_main
  2242: 0002ca14     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2243: 0002ca24     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2244: 0002ce0c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2245: 001029c0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2246: 001029c0   734 OBJECT  LOCAL  DEFAULT    6 rtems_bdpart_shell_usage
  2247: 00113684     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2248: 00102ca0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2249: 00006a5c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2250: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_alias.c
  2251: 0002ce74     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2252: 0002ce74   108 FUNC    LOCAL  DEFAULT    2 rtems_shell_rtems_main_al
  2253: 0002ced8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2254: 001136a4     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2255: 001030a8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2256: 00006aa4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2257: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_blkstats.c
  2258: 0002cee0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2259: 0002cee0   164 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_blkstats
  2260: 0002cf74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2261: 001136c4     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2262: 00102f1c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2263: 00006ad0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2264: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_blksync.c
  2265: 0002cf84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2266: 0002cf84   320 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_blksync
  2267: 0002d0b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2268: 001136e4     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2269: 00102f68     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2270: 00006afc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2271: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_cat.c
  2272: 0002d0c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2273: 0002d0c4   172 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_cat
  2274: 0002d16c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2275: 00113704     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2276: 00103010     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2277: 00006b28     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2278: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_cd.c
  2279: 00113724     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2280: 00103050     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2281: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_chdir.c
  2282: 0002d170     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2283: 0002d170    92 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_chdir
  2284: 0002d1c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2285: 0011372c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2286: 001102c4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2287: 00006b70     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2288: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_chmod.c
  2289: 0002d1cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2290: 0002d1cc   180 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_chmod
  2291: 0002d278     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2292: 0011374c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2293: 001030a4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2294: 00006b9c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2295: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_chroot.c
  2296: 0002d280     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2297: 0002d280    96 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_chroot
  2298: 0002d2d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2299: 0011376c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2300: 001102c4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2301: 00006bd4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2302: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_cmdchmod.c
  2303: 0002d2e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2304: 0002d2e0    40 FUNC    LOCAL  DEFAULT    2 error
  2305: 0002d304     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2306: 0002d308     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2307: 0002d308   240 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_cmdchmod
  2308: 0002d3f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2309: 0011378c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2310: 00103014     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2311: 00006c00     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2312: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_cmdchown.c
  2313: 0002d3f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2314: 0002d3f8    40 FUNC    LOCAL  DEFAULT    2 error
  2315: 0002d41c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2316: 0002d420     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2317: 0002d420   360 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_cmdchown
  2318: 0002d578     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2319: 001137ac     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2320: 00103014     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2321: 00006c58     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2322: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_cmdls.c
  2323: 0002d588     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2324: 0002d588   188 FUNC    LOCAL  DEFAULT    2 print_cmd.part.0
  2325: 0002d640     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2326: 0002d644     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2327: 0002d644   192 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_cmdls
  2328: 0002d6fc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2329: 001137cc     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2330: 001031c0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2331: 00006cb4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2332: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_cp.c
  2333: 0002d704     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2334: 0002d704   120 FUNC    LOCAL  DEFAULT    2 mastercmp
  2335: 0002d820     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2336: 0002d8dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2337: 0002db4c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2338: 0002db70     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2339: 0002e160     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2340: 001137ec     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2341: 001031fc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2342: 001169a8     0 NOTYPE  LOCAL  DEFAULT   15 $d
  2343: 001169a8     4 OBJECT  LOCAL  DEFAULT   15 rflag
  2344: 001169ac     4 OBJECT  LOCAL  DEFAULT   15 Rflag
  2345: 00006d0c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2346: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_cpuuse.c
  2347: 0002e1b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2348: 0002e1b4   136 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_cpuuse
  2349: 0002e22c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2350: 0011380c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2351: 00102f1c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2352: 00006d64     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2353: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_date.c
  2354: 0002e23c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2355: 0002e23c   216 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_date
  2356: 0002e304     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2357: 0011382c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2358: 0010cd84     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2359: 00006d90     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2360: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_debugrfs.c
  2361: 0011386c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2362: 00103580     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2363: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_df.c
  2364: 0002ef18     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2365: 0002ef18   120 FUNC    LOCAL  DEFAULT    2 rtems_shell_df_humanize_s
  2366: 0002ef84     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2367: 0002ef90     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2368: 0002ef90   344 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_df
  2369: 0002f0d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2370: 0002f0e8   552 FUNC    LOCAL  DEFAULT    2 rtems_shell_df_print_entr
  2371: 0002f0e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2372: 0002f304     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2373: 0010359c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2374: 0010359c     5 OBJECT  LOCAL  DEFAULT    6 suffixes
  2375: 0011388c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2376: 001035a4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2377: 00006e84     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2378: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_dir.c
  2379: 001138ac     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2380: 001036fc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2381: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_echo.c
  2382: 0002f310     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2383: 0002f310  1332 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_echo
  2384: 0002f3b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2385: 0002f4cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2386: 0002f83c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2387: 001138b4     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2388: 00103704     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2389: 00006f18     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2390: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_edit.c
  2391: 0002f844     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2392: 0002f844   128 FUNC    LOCAL  DEFAULT    2 copy
  2393: 0002f8c4    84 FUNC    LOCAL  DEFAULT    2 line_length
  2394: 0002f918   220 FUNC    LOCAL  DEFAULT    2 prev_line
  2395: 0002f9f4   124 FUNC    LOCAL  DEFAULT    2 column
  2396: 0002fa70   588 FUNC    LOCAL  DEFAULT    2 moveto
  2397: 0002fcbc   116 FUNC    LOCAL  DEFAULT    2 get_selected_text
  2398: 0002fd30   152 FUNC    LOCAL  DEFAULT    2 adjust
  2399: 0002fdc8    76 FUNC    LOCAL  DEFAULT    2 clear_undo
  2400: 0002fe14    92 FUNC    LOCAL  DEFAULT    2 delete_editor
  2401: 0002fe70    88 FUNC    LOCAL  DEFAULT    2 create_editor
  2402: 0002fec8   244 FUNC    LOCAL  DEFAULT    2 load_file
  2403: 0002ffbc   132 FUNC    LOCAL  DEFAULT    2 new_file
  2404: 0003003c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2405: 00030040     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2406: 00030040   352 FUNC    LOCAL  DEFAULT    2 move_gap
  2407: 000301a0   848 FUNC    LOCAL  DEFAULT    2 replace
  2408: 000304f0   140 FUNC    LOCAL  DEFAULT    2 erase_selection
  2409: 0003057c   108 FUNC    LOCAL  DEFAULT    2 insert_char
  2410: 000305e8    28 FUNC    LOCAL  DEFAULT    2 outstr
  2411: 00030604    48 FUNC    LOCAL  DEFAULT    2 gotoxy
  2412: 00030630     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2413: 00030634     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2414: 00030634   164 FUNC    LOCAL  DEFAULT    2 draw_full_statusline
  2415: 000306d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2416: 000306d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2417: 000306d8   128 FUNC    LOCAL  DEFAULT    2 draw_statusline
  2418: 00030754     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2419: 00030758     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2420: 00030758   100 FUNC    LOCAL  DEFAULT    2 display_message
  2421: 000307b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2422: 000307bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2423: 000307bc    36 FUNC    LOCAL  DEFAULT    2 update_selection.part.0
  2424: 000307e0    84 FUNC    LOCAL  DEFAULT    2 select_toggle
  2425: 00030834   132 FUNC    LOCAL  DEFAULT    2 copy_selection
  2426: 000308b8   296 FUNC    LOCAL  DEFAULT    2 bottom
  2427: 000309e0   116 FUNC    LOCAL  DEFAULT    2 find_editor.isra.2
  2428: 00030a54    88 FUNC    LOCAL  DEFAULT    2 getachar
  2429: 00030aac  2388 FUNC    LOCAL  DEFAULT    2 getkey
  2430: 00030b1c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2431: 00030e64     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2432: 00031014     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2433: 00031050     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2434: 00031084     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2435: 00031130     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2436: 00031370     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2437: 00031400     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2438: 00031400   180 FUNC    LOCAL  DEFAULT    2 outch
  2439: 000314b4   312 FUNC    LOCAL  DEFAULT    2 prompt.constprop.9
  2440: 000315d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2441: 000315ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2442: 000315ec   368 FUNC    LOCAL  DEFAULT    2 save_editor
  2443: 0003174c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2444: 0003175c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2445: 0003175c   244 FUNC    LOCAL  DEFAULT    2 find_text
  2446: 0003184c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2447: 00031850     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2448: 00031850   516 FUNC    LOCAL  DEFAULT    2 display_line
  2449: 00031a44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2450: 00031a54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2451: 00031a54   192 FUNC    LOCAL  DEFAULT    2 draw_screen
  2452: 00031b0c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2453: 00031b14     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2454: 00031b14   368 FUNC    LOCAL  DEFAULT    2 help
  2455: 00031c1c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2456: 00031c84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2457: 00031c84  8764 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_edit
  2458: 00031ea0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2459: 00032358     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2460: 00032c90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2461: 00032cd4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2462: 00033eb4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2463: 001138d4     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2464: 00103720     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2465: 001169c0     0 NOTYPE  LOCAL  DEFAULT   15 $d
  2466: 001169c0     4 OBJECT  LOCAL  DEFAULT   15 linux_console
  2467: 00006f4c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2468: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_exit.c
  2469: 001138f4     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2470: 00103efc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2471: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_getenv.c
  2472: 00033ec0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2473: 00033ec0    88 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_getenv
  2474: 00033f10     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2475: 001138fc     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2476: 00103f0c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2477: 0000743c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2478: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_halt.c
  2479: 00033f18     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2480: 00033f18    40 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_shutdown
  2481: 00033f3c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2482: 0011391c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2483: 00103f68     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2484: 00007464     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2485: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_help.c
  2486: 00033f40     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2487: 00033f40   712 FUNC    LOCAL  DEFAULT    2 rtems_shell_help_cmd.part
  2488: 000341f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2489: 00034208     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2490: 00034208   812 FUNC    LOCAL  DEFAULT    2 rtems_shell_help
  2491: 00034504     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2492: 0011393c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2493: 00103f9c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2494: 0000748c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2495: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_hexdump.c
  2496: 00034534     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2497: 00034548   516 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_hexdump
  2498: 00034748     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2499: 0011395c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2500: 00104098     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2501: 000074f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2502: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_id.c
  2503: 0003474c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2504: 0003474c   200 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_id
  2505: 00034808     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2506: 0011397c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2507: 001065cc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2508: 00007544     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2509: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_logoff.c
  2510: 00034ae8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2511: 00034ae8    44 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_logoff
  2512: 00034b10     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2513: 001139bc     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2514: 00104200     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2515: 000075f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2516: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_lsof.c
  2517: 000352a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2518: 000352a8    60 FUNC    LOCAL  DEFAULT    2 print_location
  2519: 000352e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2520: 000352e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2521: 000352e4   288 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_lsof
  2522: 000353e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2523: 00113a08     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2524: 001042a4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2525: 000076f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2526: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_mallocinfo.c
  2527: 00035404     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2528: 00035404   124 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_malloc_i
  2529: 00035474     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2530: 00113a28     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2531: 00104390     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2532: 00007750     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2533: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_md5.c
  2534: 00035480     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2535: 00035480   508 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_md5
  2536: 00035664     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2537: 00113a48     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2538: 001043b4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2539: 00007784     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2540: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_mdump.c
  2541: 0003567c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2542: 0003567c   220 FUNC    LOCAL  DEFAULT    2 args_parse
  2543: 0003574c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2544: 00035758     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2545: 000359f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2546: 00035a1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2547: 00035a1c    64 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_mdump
  2548: 00035a5c    68 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_wdump
  2549: 00035aa0    68 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_ldump
  2550: 00113a68     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2551: 00104430     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2552: 000077c4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2553: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_medit.c
  2554: 00035ae4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2555: 00035ae4   216 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_medit
  2556: 00035bb0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2557: 00113ac8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2558: 001030a4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2559: 00007884     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2560: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_mfill.c
  2561: 00035bbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2562: 00035bbc   228 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_mfill
  2563: 00035c90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2564: 00113ae8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2565: 001030a4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2566: 000078c0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2567: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_mkdir.c
  2568: 00035ca0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2569: 00035ca0   132 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_mkdir
  2570: 00035d1c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2571: 00113b08     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2572: 00104654     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2573: 000078f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2574: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_mknod.c
  2575: 00035d24     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2576: 00035d24     8 FUNC    LOCAL  DEFAULT    2 compare_format
  2577: 00035d2c    32 FUNC    LOCAL  DEFAULT    2 pack_native
  2578: 00035d48     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2579: 00035d4c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2580: 00035d4c   148 FUNC    LOCAL  DEFAULT    2 pack_netbsd
  2581: 00035dd0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2582: 00035de0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2583: 00035de0   108 FUNC    LOCAL  DEFAULT    2 pack_freebsd
  2584: 00035e40     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2585: 00035e4c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2586: 00035e4c   104 FUNC    LOCAL  DEFAULT    2 pack_8_8
  2587: 00035ea8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2588: 00035eb4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2589: 00035eb4   104 FUNC    LOCAL  DEFAULT    2 pack_12_20
  2590: 00035f10     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2591: 00035f1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2592: 00035f1c   104 FUNC    LOCAL  DEFAULT    2 pack_14_18
  2593: 00035f78     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2594: 00035f84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2595: 00035f84    96 FUNC    LOCAL  DEFAULT    2 pack_8_24
  2596: 00035fd8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2597: 00035fe4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2598: 00035fe4   220 FUNC    LOCAL  DEFAULT    2 pack_bsdos
  2599: 000360a8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2600: 000360c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2601: 000360c0    80 FUNC    LOCAL  DEFAULT    2 usage
  2602: 00036104     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2603: 00036110     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2604: 00036110  1576 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_mknod
  2605: 000361c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2606: 00036280     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2607: 000366fc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2608: 00104694     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2609: 00104694    21 OBJECT  LOCAL  DEFAULT    6 iMajorError
  2610: 001046ac    21 OBJECT  LOCAL  DEFAULT    6 iMinorError
  2611: 001046c4    27 OBJECT  LOCAL  DEFAULT    6 tooManyFields
  2612: 00113b28     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2613: 001046e0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2614: 00007924     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2615: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_mkrfs.c
  2616: 00113bc8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2617: 00104980     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2618: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_mmove.c
  2619: 00036738     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2620: 00036738   220 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_mmove
  2621: 00036804     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2622: 00113be8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2623: 001030a4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2624: 00007a1c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2625: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_mount.c
  2626: 00036814     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2627: 00036814    28 FUNC    LOCAL  DEFAULT    2 print_filesystem
  2628: 0003682c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2629: 00036830     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2630: 00036830   624 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_mount
  2631: 00036a74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2632: 00113c08     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2633: 00104a44     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2634: 00007a50     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2635: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_msdosfmt.c
  2636: 00036aa0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2637: 00036aa0  1040 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_msdos_fo
  2638: 00036b2c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2639: 00036bb0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2640: 00036e48     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2641: 00113c28     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2642: 00104ba4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2643: 00007aa8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2644: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_mv.c
  2645: 00036eb0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2646: 00036eb0  1476 FUNC    LOCAL  DEFAULT    2 do_move_mv
  2647: 0003741c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2648: 00037474     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2649: 00037474    56 FUNC    LOCAL  DEFAULT    2 usage_mv
  2650: 000374a4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2651: 000374ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2652: 00037744     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2653: 00113c68     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2654: 001065cc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2655: 001169cc     0 NOTYPE  LOCAL  DEFAULT   15 $d
  2656: 001169cc     4 OBJECT  LOCAL  DEFAULT   15 bp.10133
  2657: 00007af0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2658: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_perioduse.c
  2659: 00037750     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2660: 00037750   136 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_periodus
  2661: 000377c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2662: 00113c88     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2663: 00102f1c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2664: 00007b80     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2665: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_profreport.c
  2666: 000377d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2667: 000377d8    64 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_profrepo
  2668: 0003780c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2669: 00113ca8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2670: 00104fd4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2671: 00007bac     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2672: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_pwd.c
  2673: 00037818     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2674: 00037818    48 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_pwd
  2675: 00113cc8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2676: 00104fe8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2677: 00007bd8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2678: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_rmdir.c
  2679: 00037848     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2680: 00037848   152 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_rmdir
  2681: 000378dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2682: 00113ce8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2683: 00103010     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2684: 00007c08     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2685: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_rm.c
  2686: 000378e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2687: 000378e0   516 FUNC    LOCAL  DEFAULT    2 check_rm
  2688: 00037acc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2689: 00037ae4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2690: 00037ae4   720 FUNC    LOCAL  DEFAULT    2 rm_overwrite_rm
  2691: 00037da8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2692: 00037db4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2693: 00037db4   380 FUNC    LOCAL  DEFAULT    2 rm_file_rm
  2694: 00037f24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2695: 00037f30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2696: 00037f30    60 FUNC    LOCAL  DEFAULT    2 usage_rm
  2697: 00037f60     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2698: 00037f6c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2699: 0003803c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2700: 000380f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2701: 00038570     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2702: 00038598     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2703: 0003889c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2704: 00113d08     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2705: 001065cc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2706: 00007c4c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2707: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_rtc.c
  2708: 000388e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2709: 000388e0   580 FUNC    LOCAL  DEFAULT    2 rtems_rtc_shell_main
  2710: 00038aec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2711: 0010520c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2712: 00105228   143 OBJECT  LOCAL  DEFAULT    6 rtems_rtc_shell_usage
  2713: 00113d28     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2714: 001052b8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2715: 00007d38     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2716: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_rtrace.c
  2717: 00038b24     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2718: 00038b24   384 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_rtrace
  2719: 00038c74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2720: 00038ca4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2721: 00038ca4   244 FUNC    LOCAL  DEFAULT    2 rtems_trace_buffering_pri
  2722: 00038d80     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2723: 00038d98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2724: 00038d98   280 FUNC    LOCAL  DEFAULT    2 rtems_trace_buffering_she
  2725: 00038e98     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2726: 00038eb0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2727: 00038eb0   128 FUNC    LOCAL  DEFAULT    2 rtems_trace_buffering_fil
  2728: 00038f28     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2729: 00038f30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2730: 00038f30   864 FUNC    LOCAL  DEFAULT    2 rtems_trace_buffering_she
  2731: 00039248     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2732: 00039290     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2733: 00039290  1256 FUNC    LOCAL  DEFAULT    2 rtems_trace_buffering_she
  2734: 00039730     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2735: 00039778     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2736: 00039778   132 FUNC    LOCAL  DEFAULT    2 rtems_trace_buffering_she
  2737: 000397e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2738: 000397fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2739: 000397fc   132 FUNC    LOCAL  DEFAULT    2 rtems_trace_buffering_she
  2740: 0003986c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2741: 00039880     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2742: 00039880   132 FUNC    LOCAL  DEFAULT    2 rtems_trace_buffering_she
  2743: 000398f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2744: 00039904     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2745: 00039904   248 FUNC    LOCAL  DEFAULT    2 rtems_trace_buffering_she
  2746: 000399d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2747: 00105410     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2748: 00105410    84 OBJECT  LOCAL  DEFAULT    6 table
  2749: 00113d48     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2750: 00105464     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2751: 00007d7c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2752: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_setenv.c
  2753: 000399fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2754: 000399fc   288 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_setenv
  2755: 00039b10     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2756: 00113d68     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2757: 00105a8c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2758: 00007f40     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2759: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_sleep.c
  2760: 00039b1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2761: 00039b1c   192 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_sleep
  2762: 00039bd4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2763: 00113d88     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2764: 00105acc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2765: 00007f8c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2766: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_stackuse.c
  2767: 00039bdc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2768: 00039bdc    32 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_stackuse
  2769: 00039bf8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2770: 00113da8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2771: 00105b3c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2772: 00007fc4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2773: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_time.c
  2774: 00039bfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2775: 00039bfc   304 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_time
  2776: 00039d18     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2777: 00113dc8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2778: 00105b68     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2779: 00007fec     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2780: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_top.c
  2781: 00039d2c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2782: 00039d2c   136 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_top
  2783: 00039da4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2784: 00113de8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2785: 00102f1c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2786: 00008024     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2787: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_tty.c
  2788: 00039db4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2789: 00039db4    32 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_tty
  2790: 00113e08     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2791: 00105bcc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2792: 00008050     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2793: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_umask.c
  2794: 00039dd4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2795: 00039dd4   140 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_umask
  2796: 00039e58     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2797: 00113e28     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2798: 00105be0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2799: 00008078     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2800: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_unmount.c
  2801: 00039e60     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2802: 00039e60   220 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_unmount
  2803: 00039f2c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2804: 00113e48     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2805: 00105c28     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2806: 000080ac     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2807: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_unsetenv.c
  2808: 00039f3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2809: 00039f3c    92 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_unsetenv
  2810: 00039f90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2811: 00113e68     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2812: 00103f0c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2813: 000080d8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2814: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_whoami.c
  2815: 00039f98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2816: 00039f98    40 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_whoami
  2817: 00039fbc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2818: 00113e88     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2819: 00105cd0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2820: 00008100     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2821: 00000000     0 FILE    LOCAL  DEFAULT  ABS main_wkspaceinfo.c
  2822: 00039fc0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2823: 00039fc0   128 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_wkspace_
  2824: 0003a024     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2825: 0003a040     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2826: 0003a064     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2827: 00113ea8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2828: 00105cf4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2829: 00008128     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2830: 00000000     0 FILE    LOCAL  DEFAULT  ABS print_heapinfo.c
  2831: 0003a074     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2832: 0003a0a4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2833: 0003a0a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2834: 0003a10c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2835: 00105d64     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2836: 00008164     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2837: 00000000     0 FILE    LOCAL  DEFAULT  ABS print-ls.c
  2838: 0003a110     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2839: 0003a110   756 FUNC    LOCAL  DEFAULT    2 printtype
  2840: 0003a404   296 FUNC    LOCAL  DEFAULT    2 printaname
  2841: 0003a520     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2842: 0003a52c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2843: 0003a52c   296 FUNC    LOCAL  DEFAULT    2 printlink
  2844: 0003a644     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2845: 0003a654     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2846: 0003a654  1476 FUNC    LOCAL  DEFAULT    2 printtime.isra.0
  2847: 0003ac10     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2848: 0003ac18     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2849: 0003b0c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2850: 0003b0e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2851: 0003b54c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2852: 0003b558     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2853: 0003b95c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2854: 0003b960     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2855: 00113ec8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2856: 00113ec8     4 OBJECT  LOCAL  DEFAULT   14 lastentries.10065
  2857: 00106004     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2858: 001169d0     0 NOTYPE  LOCAL  DEFAULT   15 $d
  2859: 001169d0     4 OBJECT  LOCAL  DEFAULT   15 array.10064
  2860: 000081bc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2861: 00000000     0 FILE    LOCAL  DEFAULT  ABS pwcache.c
  2862: 0003bd98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2863: 0003be70     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2864: 0003be7c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2865: 0003bf54     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2866: 00104234     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2867: 001169d4     0 NOTYPE  LOCAL  DEFAULT   15 $d
  2868: 001169d4  4864 OBJECT  LOCAL  DEFAULT   15 c_uid.9372
  2869: 00117cd4     4 OBJECT  LOCAL  DEFAULT   15 pwopen.9373
  2870: 00117cd8  4864 OBJECT  LOCAL  DEFAULT   15 c_gid.9384
  2871: 00118fd8     4 OBJECT  LOCAL  DEFAULT   15 gropen.9385
  2872: 000083a0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2873: 00000000     0 FILE    LOCAL  DEFAULT  ABS shell_cmdset.c
  2874: 0003bf60     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2875: 0003bfa4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2876: 0003bfa8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2877: 0003bfec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2878: 0003bff0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2879: 0003c0f4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2880: 0003c0fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2881: 0003c2fc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2882: 00106058     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2883: 000083f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2884: 00000000     0 FILE    LOCAL  DEFAULT  ABS shell.c
  2885: 0003c300     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2886: 0003c300   136 FUNC    LOCAL  DEFAULT    2 rtems_shell_init_env
  2887: 0003c37c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2888: 0003c388     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2889: 0003c388    60 FUNC    LOCAL  DEFAULT    2 rtems_shell_env_free
  2890: 0003c3c4    52 FUNC    LOCAL  DEFAULT    2 rtems_shell_create_file
  2891: 0003c3f4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2892: 0003c3f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2893: 0003c3f8   180 FUNC    LOCAL  DEFAULT    2 rtems_shell_init_once
  2894: 0003c48c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2895: 0003c4ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2896: 0003c4ac   404 FUNC    LOCAL  DEFAULT    2 rtems_shell_run
  2897: 0003c62c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2898: 0003e024    44 FUNC    LOCAL  DEFAULT    2 rtems_shell_task
  2899: 0003c640     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2900: 0003c640    72 FUNC    LOCAL  DEFAULT    2 rtems_shell_init_user_env
  2901: 0003c680     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2902: 0003c688     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2903: 0003c694     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2904: 0003c698     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2905: 0003c6dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2906: 0003c6ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2907: 0003ca84     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2908: 0003cb58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2909: 0003cc70     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2910: 0003cccc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2911: 0003ce9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2912: 0003cebc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2913: 0003d170     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2914: 0003d36c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2915: 0003d6b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2916: 0003d778     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2917: 0003dcb4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2918: 0003ddfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2919: 0003e0c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2920: 0003e0d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2921: 00106070     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2922: 00106170    22 OBJECT  LOCAL  DEFAULT    6 __FUNCTION__.10666
  2923: 00113ecc     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2924: 00113ecc     8 OBJECT  LOCAL  DEFAULT   14 rtems_shell_once
  2925: 0010052c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2926: 00118fdc     0 NOTYPE  LOCAL  DEFAULT   15 $d
  2927: 00118fdc     4 OBJECT  LOCAL  DEFAULT   15 rtems_shell_current_env_k
  2928: 000084fc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2929: 00000000     0 FILE    LOCAL  DEFAULT  ABS shell_script.c
  2930: 0003e15c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2931: 0003e15c   180 FUNC    LOCAL  DEFAULT    2 findOnPATH.isra.0
  2932: 0003e20c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2933: 0003e210     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2934: 0003e210   528 FUNC    LOCAL  DEFAULT    2 rtems_shell_main_joel
  2935: 0003e278     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2936: 0003e298     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2937: 0003e3fc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2938: 0003e420     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2939: 0003e5e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2940: 00113ed4     0 NOTYPE  LOCAL  DEFAULT   14 $d
  2941: 001102c4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2942: 000086c8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2943: 00000000     0 FILE    LOCAL  DEFAULT  ABS utils-cp.c
  2944: 0003e608     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2945: 0003e648     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2946: 0003e64c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2947: 0003e88c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2948: 0003e898     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2949: 0003e970     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2950: 0003e97c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2951: 0003ea00     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2952: 0003ea08     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2953: 0003ea90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2954: 0003ea98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2955: 0003ef7c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2956: 0003efa4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2957: 0003efe0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2958: 0010687c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2959: 00118fe0     0 NOTYPE  LOCAL  DEFAULT   15 $d
  2960: 00118fe0    16 OBJECT  LOCAL  DEFAULT   15 tv.6772
  2961: 00008750     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2962: 00000000     0 FILE    LOCAL  DEFAULT  ABS utils-ls.c
  2963: 0003efec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2964: 0003f090     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2965: 0003f09c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2966: 0003f228     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2967: 0003f22c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2968: 0003f258     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2969: 00103240     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2970: 000088b0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2971: 00000000     0 FILE    LOCAL  DEFAULT  ABS vis.c
  2972: 0003f260     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2973: 0003f48c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2974: 0003f510     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2975: 0003f75c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2976: 0003f7ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2977: 0003f930     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2978: 0003f9b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2979: 0003fdac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2980: 0003fe30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2981: 0003ffbc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2982: 0003ffc8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2983: 000401e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2984: 00040264     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2985: 000405c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2986: 00040644     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2987: 000407a4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2988: 000407b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2989: 00040a64     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2990: 00040ae8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2991: 00040cb0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2992: 00040d34     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2993: 00040d5c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  2994: 00040d68     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2995: 00106a2c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  2996: 00008920     0 NOTYPE  LOCAL  DEFAULT   22 $d
  2997: 00000000     0 FILE    LOCAL  DEFAULT  ABS warn.c
  2998: 00040ebc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  2999: 00008a5c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3000: 00000000     0 FILE    LOCAL  DEFAULT  ABS warnx.c
  3001: 00040eec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3002: 00008aa0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3003: 00000000     0 FILE    LOCAL  DEFAULT  ABS stringtoint.c
  3004: 00040f1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3005: 00008ae4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3006: 00000000     0 FILE    LOCAL  DEFAULT  ABS stringtopointer.c
  3007: 00040fb8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3008: 00008b2c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3009: 00000000     0 FILE    LOCAL  DEFAULT  ABS stringtounsignedchar.c
  3010: 00040fc0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3011: 00008b4c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3012: 00000000     0 FILE    LOCAL  DEFAULT  ABS stringtounsignedlong.c
  3013: 00041084     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3014: 00008b9c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3015: 00000000     0 FILE    LOCAL  DEFAULT  ABS msdos_format.c
  3016: 0004111c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3017: 0004111c    88 FUNC    LOCAL  DEFAULT    2 msdos_format_printf
  3018: 00041174    80 FUNC    LOCAL  DEFAULT    2 msdos_format_write_sec
  3019: 000411c4   440 FUNC    LOCAL  DEFAULT    2 msdos_format_fill_sectors
  3020: 0004136c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3021: 0004137c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3022: 0004137c   136 FUNC    LOCAL  DEFAULT    2 msdos_set_sectors_per_clu
  3023: 000423b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3024: 00106a4c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3025: 00106a58     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3026: 00008be4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3027: 00000000     0 FILE    LOCAL  DEFAULT  ABS nvdisk.c
  3028: 0004242c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3029: 0004242c    88 FUNC    LOCAL  DEFAULT    2 rtems_nvdisk_write_checks
  3030: 00042484   120 FUNC    LOCAL  DEFAULT    2 rtems_nvdisk_error
  3031: 000424f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3032: 000424fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3033: 000424fc   132 FUNC    LOCAL  DEFAULT    2 rtems_nvdisk_get_device
  3034: 00042578     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3035: 00042580     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3036: 00042580  1368 FUNC    LOCAL  DEFAULT    2 rtems_nvdisk_ioctl
  3037: 00042ac0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3038: 00042ad8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3039: 00042d60     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3040: 00106ba0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3041: 00118ff0     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3042: 00118ff0     4 OBJECT  LOCAL  DEFAULT   15 rtems_nvdisk_count
  3043: 00118ff4     4 OBJECT  LOCAL  DEFAULT   15 rtems_nvdisks
  3044: 00118ff8     4 OBJECT  LOCAL  DEFAULT   15 rtems_nvdisk_crc16_factor
  3045: 00008ccc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3046: 00000000     0 FILE    LOCAL  DEFAULT  ABS nvdisk-sram.c
  3047: 00042d80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3048: 00042d80    36 FUNC    LOCAL  DEFAULT    2 rtems_nvdisk_sram_verify
  3049: 00042da4    28 FUNC    LOCAL  DEFAULT    2 rtems_nvdisk_sram_write
  3050: 00042dc0    28 FUNC    LOCAL  DEFAULT    2 rtems_nvdisk_sram_read
  3051: 00106c64     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3052: 00008db4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3053: 00000000     0 FILE    LOCAL  DEFAULT  ABS ramdisk-register.c
  3054: 00042ddc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3055: 00042e90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3056: 00106c70     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3057: 00008e0c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3058: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-rtems.c
  3059: 00042e98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3060: 00042e98    32 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_is_direct
  3061: 00042eb8   192 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_utime
  3062: 00042f78   180 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_chown
  3063: 0004302c   152 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_fchmod
  3064: 00043350     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3065: 00043354     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3066: 000433a4   160 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_statvfs
  3067: 00043440     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3068: 00043444     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3069: 00043444   160 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_rename
  3070: 000434e4    88 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_link
  3071: 0004353c    92 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_readlink
  3072: 00043598   132 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_symlink
  3073: 0004361c   356 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_mknod
  3074: 00043780   152 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_eval_path
  3075: 00043814     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3076: 00043818     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3077: 0004383c   520 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_eval_toke
  3078: 00043a44    80 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_unlock_by
  3079: 00043a90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3080: 00043a94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3081: 00043a94    84 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_lock_by_m
  3082: 00043ae4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3083: 00043ae8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3084: 00043d74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3085: 00106c88     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3086: 00106c88     8 OBJECT  LOCAL  DEFAULT    6 rtems_rfs_rtems_eval_conf
  3087: 00106d18     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3088: 00008e4c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3089: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-rtems-utils.c
  3090: 00043d94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3091: 00043e34     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3092: 00043e48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3093: 00106da4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3094: 00009134     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3095: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-shell.c
  3096: 00043e54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3097: 00043e54   632 FUNC    LOCAL  DEFAULT    2 rtems_rfs_shell_data
  3098: 00044070     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3099: 000440cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3100: 000440cc   540 FUNC    LOCAL  DEFAULT    2 rtems_rfs_shell_group
  3101: 000442d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3102: 000442e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3103: 000442e8   760 FUNC    LOCAL  DEFAULT    2 rtems_rfs_shell_block
  3104: 000445b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3105: 000445e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3106: 000445e0  1044 FUNC    LOCAL  DEFAULT    2 rtems_rfs_shell_dir
  3107: 000449c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3108: 000449f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3109: 000449f4  1496 FUNC    LOCAL  DEFAULT    2 rtems_rfs_shell_inode
  3110: 00044f80     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3111: 00044fcc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3112: 000451e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3113: 00045220     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3114: 000452a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3115: 00045358     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3116: 000454cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3117: 00106dc8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3118: 00106e04     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3119: 0000917c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3120: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-trace.c
  3121: 000454ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3122: 0004550c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3123: 00045510     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3124: 00045538     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3125: 0004553c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3126: 00045564     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3127: 00045568     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3128: 000457d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3129: 00107740     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3130: 001077dc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3131: 00119000     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3132: 00119000     8 OBJECT  LOCAL  DEFAULT   15 rtems_rfs_trace_flags
  3133: 0000931c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3134: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-trace-buffer-vars.c
  3135: 000457f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3136: 00045800     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3137: 00045804     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3138: 00045810     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3139: 00045814     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3140: 00045820     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3141: 00045824     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3142: 00045830     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3143: 00045834     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3144: 00045840     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3145: 00045844     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3146: 00045850     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3147: 00045854     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3148: 00045860     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3149: 00045864     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3150: 00045888     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3151: 0004588c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3152: 000458b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3153: 000458b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3154: 000458c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3155: 000458c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3156: 000458d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3157: 000458d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3158: 000458e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3159: 000458e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3160: 000458ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3161: 000458f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3162: 0004590c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3163: 00045910     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3164: 00045930     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3165: 00045934     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3166: 00045954     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3167: 00045958     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3168: 00045988     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3169: 00045994     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3170: 000459b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3171: 000459b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3172: 000459d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3173: 00119008     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3174: 000093b8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3175: 00000000     0 FILE    LOCAL  DEFAULT  ABS untar.c
  3176: 000459dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3177: 00045c20     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3178: 00045c38     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3179: 00045e58     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3180: 00045e60     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3181: 00107a68     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3182: 000094f8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3183: 00000000     0 FILE    LOCAL  DEFAULT  ABS bdpart-create.c
  3184: 000486f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3185: 00009b88     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3186: 00000000     0 FILE    LOCAL  DEFAULT  ABS bdpart-dump.c
  3187: 00048938     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3188: 00048a44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3189: 00107ad8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3190: 00009bc8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3191: 00000000     0 FILE    LOCAL  DEFAULT  ABS bdpart-mount.c
  3192: 00048a6c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3193: 00048be8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3194: 00048bf4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3195: 00048d04     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3196: 0010b098     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3197: 00009bfc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3198: 00000000     0 FILE    LOCAL  DEFAULT  ABS bdpart-read.c
  3199: 00048d08     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3200: 00048d08   252 FUNC    LOCAL  DEFAULT    2 rtems_bdpart_read_mbr_par
  3201: 00048e00     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3202: 00048e04     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3203: 00048e04   140 FUNC    LOCAL  DEFAULT    2 rtems_bdpart_read_record
  3204: 00048ecc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3205: 00048ed0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3206: 00048ef4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3207: 00048ef8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3208: 00048fc0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3209: 00048fc4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3210: 00107c78     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3211: 00107c78    16 OBJECT  LOCAL  DEFAULT    6 RTEMS_BDPART_MBR_MASTER_T
  3212: 00009c60     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3213: 00000000     0 FILE    LOCAL  DEFAULT  ABS bdpart-register.c
  3214: 00049248     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3215: 00049248    64 FUNC    LOCAL  DEFAULT    2 create_logical_disk_name
  3216: 00049370     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3217: 00049374     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3218: 00049480     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3219: 0010b098     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3220: 00009d48     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3221: 00000000     0 FILE    LOCAL  DEFAULT  ABS bdpart-write.c
  3222: 00049484     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3223: 00049484   156 FUNC    LOCAL  DEFAULT    2 rtems_bdpart_new_record
  3224: 00009df4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3225: 00000000     0 FILE    LOCAL  DEFAULT  ABS blkdev-blkstats.c
  3226: 000499d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3227: 00049b30     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3228: 00107c88     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3229: 00009e50     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3230: 00000000     0 FILE    LOCAL  DEFAULT  ABS blkdev-imfs.c
  3231: 00049b54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3232: 00049b54    92 FUNC    LOCAL  DEFAULT    2 rtems_blkdev_imfs_destroy
  3233: 00049bac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3234: 00049bb0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3235: 00049bb0    28 FUNC    LOCAL  DEFAULT    2 rtems_blkdev_imfs_initial
  3236: 00049bcc    40 FUNC    LOCAL  DEFAULT    2 rtems_blkdev_imfs_fstat
  3237: 00049bf4   316 FUNC    LOCAL  DEFAULT    2 rtems_blkdev_imfs_write
  3238: 00049d30   288 FUNC    LOCAL  DEFAULT    2 rtems_blkdev_imfs_read
  3239: 00049e50    52 FUNC    LOCAL  DEFAULT    2 rtems_blkdev_imfs_fsync_o
  3240: 00049e84    52 FUNC    LOCAL  DEFAULT    2 rtems_blkdev_imfs_ioctl
  3241: 00049eb4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3242: 00049eb8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3243: 00049f60     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3244: 00049f68     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3245: 0004a060     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3246: 00107d24     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3247: 00107d24    16 OBJECT  LOCAL  DEFAULT    6 rtems_blkdev_imfs_control
  3248: 00107d34    60 OBJECT  LOCAL  DEFAULT    6 rtems_blkdev_imfs_node
  3249: 00009e8c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3250: 00000000     0 FILE    LOCAL  DEFAULT  ABS blkdev-ioctl.c
  3251: 0004a06c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3252: 0004a1bc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3253: 00009ff4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3254: 00000000     0 FILE    LOCAL  DEFAULT  ABS blkdev-print-stats.c
  3255: 0004a1dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3256: 0004a234     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3257: 00107d70     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3258: 0000a01c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3259: 00000000     0 FILE    LOCAL  DEFAULT  ABS cpuusagereport.c
  3260: 0004a238     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3261: 0004a238   576 FUNC    LOCAL  DEFAULT    2 rtems_cpu_usage_report_wi
  3262: 0004a44c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3263: 0004a478     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3264: 0004a490     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3265: 00107f74     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3266: 0000a054     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3267: 00000000     0 FILE    LOCAL  DEFAULT  ABS cpuusagereset.c
  3268: 0004a494     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3269: 0004a494    16 FUNC    LOCAL  DEFAULT    2 CPU_usage_Per_thread_hand
  3270: 0004a4f4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3271: 0000a0b4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3272: 00000000     0 FILE    LOCAL  DEFAULT  ABS cpuusagetop.c
  3273: 0004a504     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3274: 0004a504   328 FUNC    LOCAL  DEFAULT    2 print_time
  3275: 0004a62c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3276: 0004a64c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3277: 0004a64c    16 FUNC    LOCAL  DEFAULT    2 task_counter
  3278: 0004a65c   736 FUNC    LOCAL  DEFAULT    2 task_usage
  3279: 0004a740     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3280: 0004a754     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3281: 0004a938     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3282: 0004a93c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3283: 0004a93c    92 FUNC    LOCAL  DEFAULT    2 print_memsize
  3284: 0004a98c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3285: 0004a998     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3286: 0004aa10     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3287: 0004aa14     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3288: 0004aa14  2056 FUNC    LOCAL  DEFAULT    2 rtems_cpuusage_top_thread
  3289: 0004b198     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3290: 0004b21c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3291: 0004b4c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3292: 0004b4ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3293: 0004b4f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3294: 00108200     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3295: 0000a0f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3296: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_chown.c
  3297: 0004b4fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3298: 0000a218     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3299: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_clone.c
  3300: 0004b514     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3301: 0000a240     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3302: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_close.c
  3303: 0004b51c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3304: 0000a260     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3305: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_eval_path.c
  3306: 0004b524     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3307: 0000a280     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3308: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_fchmod.c
  3309: 0004b538     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3310: 0000a2a0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3311: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_fcntl.c
  3312: 0004b550     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3313: 0000a2c8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3314: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_freenode.c
  3315: 0004b558     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3316: 0000a2e8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3317: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_fsync.c
  3318: 0004b55c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3319: 0000a308     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3320: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_fsync_success.c
  3321: 0004b574     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3322: 0000a330     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3323: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_ftruncate_directo
  3324: 0004b57c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3325: 0000a350     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3326: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_ftruncate.c
  3327: 0004b594     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3328: 0000a378     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3329: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_handlers.c
  3330: 00108520     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3331: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_ioctl.c
  3332: 0004b5ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3333: 0000a3a0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3334: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_kqfilter.c
  3335: 0004b5c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3336: 0000a3c8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3337: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_link.c
  3338: 0004b5cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3339: 0000a3e8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3340: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_lseek_directory.c
  3341: 0004b5e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3342: 0000a410     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3343: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_lseek_file.c
  3344: 0004b63c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3345: 0000a438     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3346: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_lseek.c
  3347: 0004b744     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3348: 0000a47c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3349: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_mknod.c
  3350: 0004b760     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3351: 0000a4a4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3352: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_mount.c
  3353: 0004b778     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3354: 0000a4cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3355: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_open.c
  3356: 0004b790     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3357: 0000a4f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3358: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_poll.c
  3359: 0004b798     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3360: 0000a514     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3361: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_readlink.c
  3362: 0004b7a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3363: 0000a534     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3364: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_read.c
  3365: 0004b7b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3366: 0000a55c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3367: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_readv.c
  3368: 0004b7d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3369: 0000a584     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3370: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_rename.c
  3371: 0004b858     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3372: 0000a5c4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3373: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_rmnod.c
  3374: 0004b870     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3375: 0000a5ec     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3376: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_symlink.c
  3377: 0004b888     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3378: 0000a614     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3379: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_unmount.c
  3380: 0004b8a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3381: 0000a63c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3382: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_utime.c
  3383: 0004b8b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3384: 0000a664     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3385: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_write.c
  3386: 0004b8d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3387: 0000a68c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3388: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_writev.c
  3389: 0004b8e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3390: 0000a6b4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3391: 00000000     0 FILE    LOCAL  DEFAULT  ABS deviceio.c
  3392: 0004b970     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3393: 0000a6f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3394: 00000000     0 FILE    LOCAL  DEFAULT  ABS diskdevs-init.c
  3395: 0004ba1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3396: 0004ba98     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3397: 0004ba9c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3398: 0000a794     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3399: 00000000     0 FILE    LOCAL  DEFAULT  ABS dummy-networking.c
  3400: 00113efc     0 NOTYPE  LOCAL  DEFAULT   14 $d
  3401: 0010855c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3402: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_config.c
  3403: 00108574     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3404: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_creat.c
  3405: 0004bb2c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3406: 0000a7f8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3407: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_fsunmount.c
  3408: 0004bbf0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3409: 0004bcc0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3410: 0000a83c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3411: 00000000     0 FILE    LOCAL  DEFAULT  ABS imfs_make_generic_node.c
  3412: 0004bcc4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3413: 0004bdd8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3414: 0000a870     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3415: 00000000     0 FILE    LOCAL  DEFAULT  ABS gethostbydns.c
  3416: 0004bddc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3417: 0004bddc    44 FUNC    LOCAL  DEFAULT    2 debugprintf.part.0
  3418: 0004be08  2564 FUNC    LOCAL  DEFAULT    2 gethostanswer
  3419: 0004c7c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3420: 0004c80c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3421: 0004cb2c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3422: 0004cb58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3423: 0004cdc0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3424: 0004cde8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3425: 0004ce2c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3426: 0004ce30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3427: 0004ce44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3428: 001085a4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3429: 001085a4    51 OBJECT  LOCAL  DEFAULT    6 AskedForGot
  3430: 001085d8    12 OBJECT  LOCAL  DEFAULT    6 mapped.9163
  3431: 001085e4    12 OBJECT  LOCAL  DEFAULT    6 tunnelled.9164
  3432: 001085f0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3433: 001190e0     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3434: 001190e0   144 OBJECT  LOCAL  DEFAULT   15 h_addr_ptrs
  3435: 00119170   140 OBJECT  LOCAL  DEFAULT   15 host_aliases
  3436: 001191fc    20 OBJECT  LOCAL  DEFAULT   15 host
  3437: 00119210  8192 OBJECT  LOCAL  DEFAULT   15 hostbuf
  3438: 0011b210    16 OBJECT  LOCAL  DEFAULT   15 host_addr
  3439: 0000a8bc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3440: 00000000     0 FILE    LOCAL  DEFAULT  ABS gethostbyht.c
  3441: 0004ce48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3442: 0004ce84     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3443: 0004ce90     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3444: 0004cebc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3445: 0004cec0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3446: 0004d0c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3447: 0004d0f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3448: 0004d688     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3449: 00101adc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3450: 0011b220     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3451: 0011b220     4 OBJECT  LOCAL  DEFAULT   15 hostf
  3452: 0011b224     4 OBJECT  LOCAL  DEFAULT   15 stayopen
  3453: 0011b228   140 OBJECT  LOCAL  DEFAULT   15 host_aliases
  3454: 0011b2b4    20 OBJECT  LOCAL  DEFAULT   15 host
  3455: 0011b2c8  1025 OBJECT  LOCAL  DEFAULT   15 hostbuf
  3456: 0011b6cc    16 OBJECT  LOCAL  DEFAULT   15 host_addr
  3457: 0011b6dc     8 OBJECT  LOCAL  DEFAULT   15 h_addr_ptrs
  3458: 0011b6e4     4 OBJECT  LOCAL  DEFAULT   15 hostlen
  3459: 0011b6e8     4 OBJECT  LOCAL  DEFAULT   15 hostmap
  3460: 0011b6ec     4 OBJECT  LOCAL  DEFAULT   15 cur
  3461: 0000a9dc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3462: 00000000     0 FILE    LOCAL  DEFAULT  ABS gethostbynis.c
  3463: 0004d690     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3464: 0000aac4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3465: 00000000     0 FILE    LOCAL  DEFAULT  ABS herror.c
  3466: 0004d6ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3467: 0004d780     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3468: 0004d798     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3469: 0004d7cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3470: 00113f4c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  3471: 001086e4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3472: 0000aafc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3473: 00000000     0 FILE    LOCAL  DEFAULT  ABS inet_ntoa.c
  3474: 0004d7d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3475: 0004d824     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3476: 00108794     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3477: 0011b6f0     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3478: 0011b6f0    18 OBJECT  LOCAL  DEFAULT   15 ret.8222
  3479: 0000ab40     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3480: 00000000     0 FILE    LOCAL  DEFAULT  ABS inet_ntop.c
  3481: 0004d82c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3482: 0004d82c   120 FUNC    LOCAL  DEFAULT    2 inet_ntop4
  3483: 0004d8a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3484: 0004d8a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3485: 0004dba8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3486: 001087a8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3487: 001087a8    12 OBJECT  LOCAL  DEFAULT    6 fmt.8640
  3488: 001087b4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3489: 0000ab70     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3490: 00000000     0 FILE    LOCAL  DEFAULT  ABS map_v4v6.c
  3491: 0004dbb0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3492: 0000abe8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3493: 00000000     0 FILE    LOCAL  DEFAULT  ABS ns_netint.c
  3494: 0004dce4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3495: 0000ac34     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3496: 00000000     0 FILE    LOCAL  DEFAULT  ABS recv.c
  3497: 0004dd48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3498: 0000ac84     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3499: 00000000     0 FILE    LOCAL  DEFAULT  ABS res_comp.c
  3500: 0004dd68     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3501: 0000acb0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3502: 00000000     0 FILE    LOCAL  DEFAULT  ABS res_debug.c
  3503: 0004df54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3504: 0004df54   276 FUNC    LOCAL  DEFAULT    2 precsize_aton
  3505: 0004e060     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3506: 0004e068     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3507: 0004e068  1076 FUNC    LOCAL  DEFAULT    2 latlon2ul
  3508: 0004e108     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3509: 0004e1d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3510: 0004e2b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3511: 0004e380     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3512: 0004e498     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3513: 0004e49c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3514: 0004e49c   136 FUNC    LOCAL  DEFAULT    2 precsize_ntoa
  3515: 0004e510     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3516: 0004e524     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3517: 0004e618     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3518: 0004e61c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3519: 0004e6b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3520: 0004e6b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3521: 0004e704     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3522: 0004e708     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3523: 0004e7f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3524: 0004e7f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3525: 0004e7f8   700 FUNC    LOCAL  DEFAULT    2 do_section
  3526: 0004ea8c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3527: 0004eab4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3528: 0004f088     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3529: 0004f0d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3530: 0004f170     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3531: 0004f178     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3532: 0004f188     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3533: 0004f18c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3534: 0004f1ac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3535: 0004f1b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3536: 0004f1c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3537: 0004f1c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3538: 0004f2ac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3539: 0004f2e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3540: 0004f3d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3541: 0004f3e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3542: 0004f420     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3543: 0004f428     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3544: 0004f8e4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3545: 0004f8ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3546: 0004fbf4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3547: 0004fc14     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3548: 0004fce8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3549: 001087b8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3550: 001087b8    40 OBJECT  LOCAL  DEFAULT    6 poweroften
  3551: 00108a98     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3552: 0011b704     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3553: 0011b704    12 OBJECT  LOCAL  DEFAULT   15 retbuf.10157
  3554: 0011b710    20 OBJECT  LOCAL  DEFAULT   15 unname.10105
  3555: 0011b724    20 OBJECT  LOCAL  DEFAULT   15 unname.10114
  3556: 0011b738    40 OBJECT  LOCAL  DEFAULT   15 nbuf.10135
  3557: 0011b760    40 OBJECT  LOCAL  DEFAULT   15 nbuf.10152
  3558: 0011b788    15 OBJECT  LOCAL  DEFAULT   15 output.10331
  3559: 0000ad98     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3560: 00000000     0 FILE    LOCAL  DEFAULT  ABS res_mkquery.c
  3561: 0004fcf0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3562: 0004ff98     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3563: 0010909c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3564: 0000b0bc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3565: 00000000     0 FILE    LOCAL  DEFAULT  ABS access.c
  3566: 0004ffa4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3567: 0000b104     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3568: 00000000     0 FILE    LOCAL  DEFAULT  ABS __assert.c
  3569: 00050014     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3570: 00050068     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3571: 001090bc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3572: 0000b134     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3573: 00000000     0 FILE    LOCAL  DEFAULT  ABS assoclocalbyremotebitfiel
  3574: 00050074     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3575: 0000b15c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3576: 00000000     0 FILE    LOCAL  DEFAULT  ABS assoclocalbyremote.c
  3577: 000500c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3578: 0000b18c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3579: 00000000     0 FILE    LOCAL  DEFAULT  ABS assocptrbyremote.c
  3580: 000500dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3581: 0005014c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3582: 001090fc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3583: 0000b1b4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3584: 00000000     0 FILE    LOCAL  DEFAULT  ABS cachealignedalloc.c
  3585: 00050150     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3586: 0000b1e0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3587: 00000000     0 FILE    LOCAL  DEFAULT  ABS chdir.c
  3588: 0005017c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3589: 000501fc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3590: 00050200     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3591: 0000b20c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3592: 00000000     0 FILE    LOCAL  DEFAULT  ABS chmod.c
  3593: 00050244     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3594: 0000b264     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3595: 00000000     0 FILE    LOCAL  DEFAULT  ABS chown.c
  3596: 00050284     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3597: 0000b294     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3598: 00000000     0 FILE    LOCAL  DEFAULT  ABS chroot.c
  3599: 000502c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3600: 000503d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3601: 0000b2c4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3602: 00000000     0 FILE    LOCAL  DEFAULT  ABS clonenode.c
  3603: 000503dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3604: 00050418     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3605: 0000b2f8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3606: 00000000     0 FILE    LOCAL  DEFAULT  ABS error.c
  3607: 0005041c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3608: 00050580     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3609: 00050598     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3610: 00050604     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3611: 0005060c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3612: 00050648     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3613: 00109108     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3614: 0000b324     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3615: 00000000     0 FILE    LOCAL  DEFAULT  ABS fchmod.c
  3616: 0005064c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3617: 0005072c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3618: 00050730     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3619: 000507b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3620: 0000b3ac     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3621: 00000000     0 FILE    LOCAL  DEFAULT  ABS fchown.c
  3622: 000507c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3623: 00050898     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3624: 0005089c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3625: 0005092c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3626: 0000b410     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3627: 00000000     0 FILE    LOCAL  DEFAULT  ABS freenode.c
  3628: 00050934     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3629: 0000b474     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3630: 00000000     0 FILE    LOCAL  DEFAULT  ABS fstat.c
  3631: 0005097c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3632: 00050a04     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3633: 00050a0c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3634: 0000b4a0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3635: 00000000     0 FILE    LOCAL  DEFAULT  ABS fsync.c
  3636: 00050a18     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3637: 00050a68     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3638: 0000b4ec     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3639: 00000000     0 FILE    LOCAL  DEFAULT  ABS ftruncate.c
  3640: 00050a70     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3641: 00050ae4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3642: 0000b51c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3643: 00000000     0 FILE    LOCAL  DEFAULT  ABS getgid.c
  3644: 00050aec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3645: 0000b54c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3646: 00000000     0 FILE    LOCAL  DEFAULT  ABS getgrnam.c
  3647: 00050afc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3648: 00050b30     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3649: 00050b34     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3650: 00050b68     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3651: 0011b798     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3652: 0011b798    16 OBJECT  LOCAL  DEFAULT   15 grent
  3653: 0011b7a8   200 OBJECT  LOCAL  DEFAULT   15 grbuf
  3654: 0000b574     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3655: 00000000     0 FILE    LOCAL  DEFAULT  ABS getpwent.c
  3656: 00050b6c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3657: 00050ba0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3658: 00050ba4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3659: 00050bd8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3660: 00050bdc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3661: 00050c18     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3662: 00050c1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3663: 00050c4c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3664: 00050c58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3665: 00050c6c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3666: 0010916c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3667: 0011b870     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3668: 0011b870    28 OBJECT  LOCAL  DEFAULT   15 pwent
  3669: 0011b88c   200 OBJECT  LOCAL  DEFAULT   15 pwbuf
  3670: 0011b954     4 OBJECT  LOCAL  DEFAULT   15 passwd_fp
  3671: 0000b5bc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3672: 00000000     0 FILE    LOCAL  DEFAULT  ABS getuid.c
  3673: 00050c70     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3674: 0000b644     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3675: 00000000     0 FILE    LOCAL  DEFAULT  ABS ioctl.c
  3676: 00050c80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3677: 00050cfc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3678: 0000b66c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3679: 00000000     0 FILE    LOCAL  DEFAULT  ABS link.c
  3680: 00050d04     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3681: 0000b6b0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3682: 00000000     0 FILE    LOCAL  DEFAULT  ABS lseek.c
  3683: 00050d98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3684: 00050df4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3685: 00050dfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3686: 0000b6f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3687: 00000000     0 FILE    LOCAL  DEFAULT  ABS lstat.c
  3688: 00050e04     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3689: 0000b734     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3690: 00000000     0 FILE    LOCAL  DEFAULT  ABS mallocinfo.c
  3691: 00050e70     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3692: 00050e9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3693: 0000b774     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3694: 00000000     0 FILE    LOCAL  DEFAULT  ABS malloc_walk.c
  3695: 00050ea0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3696: 00050eb4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3697: 0000b7a0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3698: 00000000     0 FILE    LOCAL  DEFAULT  ABS mkfifo.c
  3699: 00050eb8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3700: 0000b7c0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3701: 00000000     0 FILE    LOCAL  DEFAULT  ABS mount-mgr.c
  3702: 00050ec8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3703: 00050ec8    48 FUNC    LOCAL  DEFAULT    2 find_handler
  3704: 00050fa8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3705: 00050fb4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3706: 00050fe4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3707: 00050fe8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3708: 000510e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3709: 000510ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3710: 00051198     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3711: 00113f64     0 NOTYPE  LOCAL  DEFAULT   14 $d
  3712: 00113f64    12 OBJECT  LOCAL  DEFAULT   14 filesystem_chain
  3713: 0000b7e0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3714: 00000000     0 FILE    LOCAL  DEFAULT  ABS newlibc_exit.c
  3715: 000511a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3716: 000511c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3717: 0000b89c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3718: 00000000     0 FILE    LOCAL  DEFAULT  ABS pwdgrp.c
  3719: 000511c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3720: 000511c4    68 FUNC    LOCAL  DEFAULT    2 init_file
  3721: 00051204     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3722: 00051208     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3723: 00051208    68 FUNC    LOCAL  DEFAULT    2 pwdgrp_init
  3724: 00051234     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3725: 0005124c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3726: 0005124c   240 FUNC    LOCAL  DEFAULT    2 scanInt
  3727: 00051334     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3728: 0005133c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3729: 0005133c   228 FUNC    LOCAL  DEFAULT    2 scanString
  3730: 0005142c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3731: 00051434     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3732: 00051558   224 FUNC    LOCAL  DEFAULT    2 getpw_r
  3733: 00051628     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3734: 00051638     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3735: 000517f4   224 FUNC    LOCAL  DEFAULT    2 getgr_r
  3736: 000518c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3737: 000518d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3738: 00113f70     0 NOTYPE  LOCAL  DEFAULT   14 $d
  3739: 00113f70     8 OBJECT  LOCAL  DEFAULT   14 pwdgrp_once
  3740: 00109178     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3741: 0000b8c4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3742: 00000000     0 FILE    LOCAL  DEFAULT  ABS readlink.c
  3743: 00051934     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3744: 0000ba6c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3745: 00000000     0 FILE    LOCAL  DEFAULT  ABS realpath.c
  3746: 000519c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3747: 00051e8c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3748: 00103310     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3749: 0000baa4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3750: 00000000     0 FILE    LOCAL  DEFAULT  ABS rmdir.c
  3751: 00051e94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3752: 0000baf4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3753: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems_malloc.c
  3754: 00051f60     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3755: 00051f9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3756: 0000bb28     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3757: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems_mkdir.c
  3758: 00051fa0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3759: 00052134     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3760: 0000bb5c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3761: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems_putc.c
  3762: 00052138     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3763: 00052144     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3764: 0000bb9c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3765: 00000000     0 FILE    LOCAL  DEFAULT  ABS setegid.c
  3766: 00052148     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3767: 0000bbbc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3768: 00000000     0 FILE    LOCAL  DEFAULT  ABS seteuid.c
  3769: 00052160     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3770: 0000bbe4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3771: 00000000     0 FILE    LOCAL  DEFAULT  ABS setgid.c
  3772: 00052178     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3773: 0000bc0c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3774: 00000000     0 FILE    LOCAL  DEFAULT  ABS setuid.c
  3775: 00052190     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3776: 0000bc34     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3777: 00000000     0 FILE    LOCAL  DEFAULT  ABS statvfs.c
  3778: 000521a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3779: 0000bc5c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3780: 00000000     0 FILE    LOCAL  DEFAULT  ABS sup_fs_deviceio.c
  3781: 0005220c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3782: 0000bc8c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3783: 00000000     0 FILE    LOCAL  DEFAULT  ABS sup_fs_exist_in_same_inst
  3784: 00052390     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3785: 000523e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3786: 0000bd48     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3787: 00000000     0 FILE    LOCAL  DEFAULT  ABS sup_fs_mount_iterate.c
  3788: 000523ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3789: 0005245c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3790: 0000bd70     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3791: 00000000     0 FILE    LOCAL  DEFAULT  ABS symlink.c
  3792: 00052464     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3793: 0000bda4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3794: 00000000     0 FILE    LOCAL  DEFAULT  ABS tcdrain.c
  3795: 000524b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3796: 0000bdd4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3797: 00000000     0 FILE    LOCAL  DEFAULT  ABS tcgetattr.c
  3798: 000524bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3799: 0000bdf4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3800: 00000000     0 FILE    LOCAL  DEFAULT  ABS tcsetattr.c
  3801: 000524c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3802: 0000be14     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3803: 00000000     0 FILE    LOCAL  DEFAULT  ABS termios_num2baud.c
  3804: 00052520     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3805: 0005252c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3806: 0000be48     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3807: 00000000     0 FILE    LOCAL  DEFAULT  ABS uenvgetgroups.c
  3808: 00052530     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3809: 0000be68     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3810: 00000000     0 FILE    LOCAL  DEFAULT  ABS umask.c
  3811: 0005255c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3812: 000525e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3813: 0000be90     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3814: 00000000     0 FILE    LOCAL  DEFAULT  ABS unmount.c
  3815: 000525e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3816: 000526e4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3817: 0000bebc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3818: 00000000     0 FILE    LOCAL  DEFAULT  ABS utime.c
  3819: 000526e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3820: 0000bef0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3821: 00000000     0 FILE    LOCAL  DEFAULT  ABS md5.c
  3822: 00052754     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3823: 00052754  2620 FUNC    LOCAL  DEFAULT    2 Transform
  3824: 00053094     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3825: 00053190     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3826: 000531c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3827: 000531d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3828: 00053370     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3829: 00113f78     0 NOTYPE  LOCAL  DEFAULT   14 $d
  3830: 00113f78    64 OBJECT  LOCAL  DEFAULT   14 PADDING
  3831: 0000bf24     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3832: 00000000     0 FILE    LOCAL  DEFAULT  ABS if_ether.c
  3833: 00053374     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3834: 00053374   204 FUNC    LOCAL  DEFAULT    2 arplookup
  3835: 0005342c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3836: 00053440     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3837: 00053440   228 FUNC    LOCAL  DEFAULT    2 arprequest
  3838: 0005351c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3839: 00053524     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3840: 00053524   884 FUNC    LOCAL  DEFAULT    2 arp_rtrequest
  3841: 00053870     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3842: 00053898   252 FUNC    LOCAL  DEFAULT    2 arptimer
  3843: 00053898     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3844: 00053980     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3845: 00053994     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3846: 00053b9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3847: 00053ba8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3848: 000540a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3849: 000540c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3850: 00054118     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3851: 00110744     0 NOTYPE  LOCAL  DEFAULT   12 $d
  3852: 00110744     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3853: 00114028    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_link_ether_i
  3854: 00110748     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3855: 00114054    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_link_ether_i
  3856: 0011074c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3857: 00114080    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_link_ether_i
  3858: 00110750     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3859: 001140ac    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_link_ether_i
  3860: 00110754     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3861: 001140d8    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_link_ether_i
  3862: 00110758     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3863: 00114104    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_link_ether_i
  3864: 0011075c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3865: 00114130    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_link_ether_i
  3866: 00113fb8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  3867: 00113fb8    16 OBJECT  LOCAL  DEFAULT   14 sin.9437
  3868: 00113fc8    54 OBJECT  LOCAL  DEFAULT   14 null_sdl.9369
  3869: 00114000     4 OBJECT  LOCAL  DEFAULT   14 useloopback
  3870: 00114004     4 OBJECT  LOCAL  DEFAULT   14 arpt_prune
  3871: 00114008     4 OBJECT  LOCAL  DEFAULT   14 arp_maxtries
  3872: 0011400c     4 OBJECT  LOCAL  DEFAULT   14 arpt_down
  3873: 00114024     4 OBJECT  LOCAL  DEFAULT   14 arpt_keep
  3874: 0011b968     4 OBJECT  LOCAL  DEFAULT   15 arp_proxyall
  3875: 001091a8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3876: 0011b958     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3877: 0011b958     4 OBJECT  LOCAL  DEFAULT   15 arpinit_done.9370
  3878: 0011b95c     4 OBJECT  LOCAL  DEFAULT   15 llinfo_arp
  3879: 0011b960     4 OBJECT  LOCAL  DEFAULT   15 arp_inuse
  3880: 0011b964     4 OBJECT  LOCAL  DEFAULT   15 arp_allocated
  3881: 0000bfc4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3882: 00000000     0 FILE    LOCAL  DEFAULT  ABS if_ethersubr.c
  3883: 0005411c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3884: 00054470     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3885: 00054478     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3886: 000545b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3887: 000545c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3888: 00054600     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3889: 00054608     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3890: 00054690     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3891: 00054698     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3892: 00054880     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3893: 00054884     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3894: 00054a38     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3895: 00054a3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3896: 00054a80     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3897: 00054a84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3898: 00054ae4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3899: 00054ae8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3900: 00054ba0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3901: 0010936c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3902: 0010936c    64 OBJECT  LOCAL  DEFAULT    6 crctab.9602
  3903: 00110760     0 NOTYPE  LOCAL  DEFAULT   12 $d
  3904: 00110760     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3905: 00114174    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_link_ether
  3906: 0011415c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  3907: 001093ac     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3908: 0011b96c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3909: 0011b96c    32 OBJECT  LOCAL  DEFAULT   15 buf.9539
  3910: 0000c10c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3911: 00000000     0 FILE    LOCAL  DEFAULT  ABS if_loop.c
  3912: 00054ba8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3913: 00054ba8    36 FUNC    LOCAL  DEFAULT    2 lortrequest
  3914: 00054d00     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3915: 00054d10     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3916: 00054d10   304 FUNC    LOCAL  DEFAULT    2 loioctl
  3917: 00054d24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3918: 00054dc8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3919: 00054e38     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3920: 00054e40     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3921: 00054ea4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3922: 001093e4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3923: 0000c250     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3924: 00000000     0 FILE    LOCAL  DEFAULT  ABS if.c
  3925: 00054ebc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3926: 00054ebc   120 FUNC    LOCAL  DEFAULT    2 if_slowtimo
  3927: 00054f28     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3928: 00054f34     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3929: 00054f6c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3930: 00054f74     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3931: 00055150     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3932: 00055590   164 FUNC    LOCAL  DEFAULT    2 link_rtrequest
  3933: 00055168     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3934: 0005520c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3935: 00055210     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3936: 000552a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3937: 000552a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3938: 0005542c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3939: 00055438     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3940: 00055630     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3941: 00055634     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3942: 000557e4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3943: 000557e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3944: 00055c88     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3945: 00055cbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3946: 00055d6c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3947: 00110764     0 NOTYPE  LOCAL  DEFAULT   12 $d
  3948: 00110764     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3949: 001141a8    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_link_generic
  3950: 00110768     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3951: 001141d4    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_link
  3952: 001141a0     0 NOTYPE  LOCAL  DEFAULT   14 $d
  3953: 001141a4     4 OBJECT  LOCAL  DEFAULT   14 if_indexlim.9334
  3954: 00109414     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3955: 0011b98c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3956: 0000c2c4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3957: 00000000     0 FILE    LOCAL  DEFAULT  ABS in_cksum.c
  3958: 00055d74     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3959: 000562bc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3960: 00109468     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3961: 0000c4ac     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3962: 00000000     0 FILE    LOCAL  DEFAULT  ABS in.c
  3963: 000562c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3964: 000562c4    48 FUNC    LOCAL  DEFAULT    2 in_ifscrub.isra.0.part.1
  3965: 00056398     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3966: 000563a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3967: 00056630     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3968: 00056638     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3969: 00056638   812 FUNC    LOCAL  DEFAULT    2 in_ifinit
  3970: 00056958     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3971: 00056964     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3972: 000572ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3973: 00057324     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3974: 000573b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3975: 0011076c     0 NOTYPE  LOCAL  DEFAULT   12 $d
  3976: 0011076c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  3977: 00114200    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_subn
  3978: 00114200     0 NOTYPE  LOCAL  DEFAULT   14 $d
  3979: 0011b990     4 OBJECT  LOCAL  DEFAULT   15 subnetsarelocal
  3980: 001094a0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  3981: 0011b990     0 NOTYPE  LOCAL  DEFAULT   15 $d
  3982: 0011b994     4 OBJECT  LOCAL  DEFAULT   15 in_mk
  3983: 0011b998     4 OBJECT  LOCAL  DEFAULT   15 in_interfaces
  3984: 0000c508     0 NOTYPE  LOCAL  DEFAULT   22 $d
  3985: 00000000     0 FILE    LOCAL  DEFAULT  ABS in_pcb.c
  3986: 000573bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3987: 000573bc    40 FUNC    LOCAL  DEFAULT    2 in_rtchange
  3988: 000573e4   260 FUNC    LOCAL  DEFAULT    2 sysctl_net_ipport_check
  3989: 000574dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3990: 000574e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3991: 000577cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3992: 000577d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3993: 00057a00     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3994: 00057a08     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3995: 00058044     0 NOTYPE  LOCAL  DEFAULT    2 $d
  3996: 00058050     0 NOTYPE  LOCAL  DEFAULT    2 $a
  3997: 0011422c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  3998: 0011422c     4 OBJECT  LOCAL  DEFAULT   14 ipport_lowfirstauto
  3999: 00114230     4 OBJECT  LOCAL  DEFAULT   14 ipport_lowlastauto
  4000: 00114234     4 OBJECT  LOCAL  DEFAULT   14 ipport_firstauto
  4001: 00114238     4 OBJECT  LOCAL  DEFAULT   14 ipport_lastauto
  4002: 0011423c     4 OBJECT  LOCAL  DEFAULT   14 ipport_hifirstauto
  4003: 00114240     4 OBJECT  LOCAL  DEFAULT   14 ipport_hilastauto
  4004: 00114244    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_port
  4005: 00114270    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_port
  4006: 0011429c    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_port
  4007: 001142c8    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_port
  4008: 001142f4    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_port
  4009: 00114320    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_port
  4010: 0011434c    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_port
  4011: 00109504     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4012: 00110770     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4013: 00110770     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4014: 00110774     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4015: 00110778     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4016: 0011077c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4017: 00110780     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4018: 00110784     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4019: 00110788     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4020: 0000c614     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4021: 00000000     0 FILE    LOCAL  DEFAULT  ABS in_proto.c
  4022: 00110834     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4023: 00110834     4 OBJECT  LOCAL  DEFAULT   12 __set_domain_set_sym_inet
  4024: 00114378     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4025: 00114378    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_igmp
  4026: 001143a4    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp
  4027: 001143d0    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_udp
  4028: 001143fc    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_icmp
  4029: 00114428    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip
  4030: 00114454    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet
  4031: 00109550     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4032: 0011078c     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4033: 0011078c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4034: 00110790     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4035: 00110794     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4036: 00110798     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4037: 0011079c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4038: 001107a0     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4039: 00000000     0 FILE    LOCAL  DEFAULT  ABS in_rmx.c
  4040: 00058134     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4041: 00058134   144 FUNC    LOCAL  DEFAULT    2 in_clsroute
  4042: 000581bc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4043: 000581c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4044: 000581c4    52 FUNC    LOCAL  DEFAULT    2 in_matroute
  4045: 000581f8   504 FUNC    LOCAL  DEFAULT    2 in_addroute
  4046: 000583dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4047: 000583f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4048: 000583f0   312 FUNC    LOCAL  DEFAULT    2 in_rtqtimo
  4049: 00058510     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4050: 00058528   292 FUNC    LOCAL  DEFAULT    2 in_rtqkill
  4051: 00058528     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4052: 00058640     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4053: 0005864c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4054: 00058694     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4055: 0005869c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4056: 000586ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4057: 001107a4     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4058: 001107a4     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4059: 0011468c    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_rtma
  4060: 001107a8     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4061: 001146b8    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_rtmi
  4062: 001107ac     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4063: 001146e4    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_rtex
  4064: 00114680     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4065: 00114680     4 OBJECT  LOCAL  DEFAULT   14 rtq_reallyold
  4066: 00114684     4 OBJECT  LOCAL  DEFAULT   14 rtq_toomany
  4067: 00114688     4 OBJECT  LOCAL  DEFAULT   14 rtq_minreallyold
  4068: 001095a0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4069: 0011b99c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4070: 0011b99c     4 OBJECT  LOCAL  DEFAULT   15 last_adjusted_timeout.985
  4071: 0000c808     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4072: 00000000     0 FILE    LOCAL  DEFAULT  ABS ip_icmp.c
  4073: 000586fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4074: 000586fc   844 FUNC    LOCAL  DEFAULT    2 icmp_reflect
  4075: 00058a40     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4076: 00058a48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4077: 00058cd4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4078: 00058ce4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4079: 00058d50     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4080: 00058d5c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4081: 00058df8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4082: 00058e04     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4083: 00058f0c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4084: 00058f48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4085: 00059208     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4086: 00059248     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4087: 000593b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4088: 00109628     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4089: 00109628    52 OBJECT  LOCAL  DEFAULT    6 mtutab.10019
  4090: 001107b0     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4091: 001107b0     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4092: 00114748    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_icmp_al
  4093: 001107b4     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4094: 00114774    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_icmp_bm
  4095: 001107b8     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4096: 001147a0    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_icmp_ma
  4097: 001107bc     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4098: 001147cc    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_icmp_st
  4099: 00114710     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4100: 00114710    16 OBJECT  LOCAL  DEFAULT   14 icmpdst
  4101: 00114720    16 OBJECT  LOCAL  DEFAULT   14 icmpsrc
  4102: 00114730     4 OBJECT  LOCAL  DEFAULT   14 icmpallecho
  4103: 00114734     4 OBJECT  LOCAL  DEFAULT   14 icmpbmcastecho
  4104: 00114738    16 OBJECT  LOCAL  DEFAULT   14 icmpgw
  4105: 0011b9a0     4 OBJECT  LOCAL  DEFAULT   15 icmpmaskrepl
  4106: 0010965c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4107: 0011b9a0     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4108: 0000c91c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4109: 00000000     0 FILE    LOCAL  DEFAULT  ABS ip_input.c
  4110: 000593d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4111: 000593d4   128 FUNC    LOCAL  DEFAULT    2 ip_rtaddr
  4112: 00059450     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4113: 00059454     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4114: 00059454   764 FUNC    LOCAL  DEFAULT    2 ip_forward
  4115: 00059744     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4116: 00059750     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4117: 00059750   120 FUNC    LOCAL  DEFAULT    2 ip_freef
  4118: 000597c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4119: 000597c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4120: 000598cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4121: 000598f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4122: 0005a760     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4123: 0005a7a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4124: 0005a7f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4125: 0005a7fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4126: 0005a868     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4127: 0005a870     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4128: 0005a8b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4129: 0005a8bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4130: 0005a990     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4131: 0005a998     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4132: 0005aae0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4133: 0005aae4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4134: 0005ab54     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4135: 0005ab5c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4136: 0005ab8c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4137: 001107c0     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4138: 001107c0     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4139: 00114824    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_intr
  4140: 001107c4     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4141: 00114850    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_intr
  4142: 001107c8     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4143: 0011487c    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_acce
  4144: 001107cc     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4145: 001148a8    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_sour
  4146: 001107d0     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4147: 001148d4    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_ttl
  4148: 001107d4     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4149: 00114904    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_redi
  4150: 001107d8     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4151: 00114930    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_ip_forw
  4152: 001147f8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4153: 001147f8     4 OBJECT  LOCAL  DEFAULT   14 ipsendredirects
  4154: 001147fc    16 OBJECT  LOCAL  DEFAULT   14 ipaddr
  4155: 0011c0c8     4 OBJECT  LOCAL  DEFAULT   15 ip_acceptsourceroute
  4156: 0011c0c4     4 OBJECT  LOCAL  DEFAULT   15 ip_dosourceroute
  4157: 001096a0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4158: 0011b9a4     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4159: 0011b9a4    20 OBJECT  LOCAL  DEFAULT   15 ipforward_rt
  4160: 0011b9b8     4 OBJECT  LOCAL  DEFAULT   15 nipq
  4161: 0011b9bc     4 OBJECT  LOCAL  DEFAULT   15 maxnipq
  4162: 0011b9c0  1792 OBJECT  LOCAL  DEFAULT   15 ipq
  4163: 0011c0c0     4 OBJECT  LOCAL  DEFAULT   15 ip_nhops
  4164: 0011c0cc    48 OBJECT  LOCAL  DEFAULT   15 ip_srcrt
  4165: 0011c104     4 OBJECT  LOCAL  DEFAULT   15 ip_rsvp_on
  4166: 0000ca6c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4167: 00000000     0 FILE    LOCAL  DEFAULT  ABS ip_mroute.c
  4168: 0005ab94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4169: 0005ac30     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4170: 0005ac40     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4171: 0011495c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4172: 001097ec     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4173: 0011c108     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4174: 0000cc18     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4175: 00000000     0 FILE    LOCAL  DEFAULT  ABS ip_output.c
  4176: 0005ac58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4177: 0005baec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4178: 0005bb28     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4179: 0005bb94     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4180: 0005bbe4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4181: 0005bbf4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4182: 0005bc44     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4183: 0005bcc0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4184: 0005bcd8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4185: 0005bd08     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4186: 0005bd50     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4187: 0005bd6c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4188: 0005bd80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4189: 0005c300     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4190: 0005c348     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4191: 0005c720     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4192: 0005c72c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4193: 0010981c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4194: 0000cd00     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4195: 00000000     0 FILE    LOCAL  DEFAULT  ABS kern_mib.c
  4196: 00114974     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4197: 00114974    44 OBJECT  LOCAL  DEFAULT   14 sysctl___kern_ostype
  4198: 001149a0    44 OBJECT  LOCAL  DEFAULT   14 sysctl___kern_osrevision
  4199: 001149cc    44 OBJECT  LOCAL  DEFAULT   14 sysctl___kern_osrelease
  4200: 001149f8    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net
  4201: 00114a24    44 OBJECT  LOCAL  DEFAULT   14 sysctl___kern
  4202: 00114a50    44 OBJECT  LOCAL  DEFAULT   14 sysctl___sysctl
  4203: 00109850     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4204: 001107dc     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4205: 001107dc     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4206: 001107e0     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4207: 001107e4     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4208: 001107e8     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4209: 001107ec     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4210: 001107f0     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4211: 00000000     0 FILE    LOCAL  DEFAULT  ABS kern_subr.c
  4212: 0005c778     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4213: 0005c874     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4214: 0005c878     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4215: 0005c8d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4216: 0005c8dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4217: 0005c974     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4218: 00109924     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4219: 00109924   108 OBJECT  LOCAL  DEFAULT    6 primes
  4220: 00109990     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4221: 0000cda8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4222: 00000000     0 FILE    LOCAL  DEFAULT  ABS kern_sysctl.c
  4223: 0005c980     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4224: 0005c980   328 FUNC    LOCAL  DEFAULT    2 sysctl_sysctl_next_ls
  4225: 0005cac8   104 FUNC    LOCAL  DEFAULT    2 sysctl_sysctl_next
  4226: 0005cb2c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4227: 0005cb30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4228: 0005cb30   464 FUNC    LOCAL  DEFAULT    2 sysctl_sysctl_name2oid
  4229: 0005ccfc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4230: 0005cd00     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4231: 0005cd00    96 FUNC    LOCAL  DEFAULT    2 sysctl_new_kernel
  4232: 0005cd60   132 FUNC    LOCAL  DEFAULT    2 sysctl_old_kernel
  4233: 0005cde4   132 FUNC    LOCAL  DEFAULT    2 sysctl_old_user
  4234: 0005ce68    96 FUNC    LOCAL  DEFAULT    2 sysctl_new_user
  4235: 0005cec8   312 FUNC    LOCAL  DEFAULT    2 sysctl_sysctl_debug_dump_
  4236: 0005cf5c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4237: 0005cf70     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4238: 0005cfe0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4239: 0005d000     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4240: 0005d000    28 FUNC    LOCAL  DEFAULT    2 sysctl_sysctl_debug
  4241: 0005d018     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4242: 0005d01c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4243: 0005d01c   392 FUNC    LOCAL  DEFAULT    2 sysctl_sysctl_name
  4244: 0005d194     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4245: 0005d1a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4246: 0005d2c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4247: 0005d2cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4248: 0005d5c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4249: 0005d5c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4250: 0005d6c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4251: 0005d6cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4252: 0005d87c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4253: 0005d880     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4254: 0005d8c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4255: 0005d8c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4256: 0005db50     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4257: 0005db54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4258: 0005db90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4259: 0005db94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4260: 0005dc44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4261: 0005dc48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4262: 0005dc48   144 FUNC    LOCAL  DEFAULT    2 sysctl_sysctl_oidfmt
  4263: 0005dcd8   100 FUNC    LOCAL  DEFAULT    2 sysctl_sysctl_oiddescr
  4264: 0005dd3c   208 FUNC    LOCAL  DEFAULT    2 sysctl_root.isra.2
  4265: 0005defc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4266: 0005df08     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4267: 0005e0f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4268: 0005e0f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4269: 00114a98     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4270: 00114a98     4 OBJECT  LOCAL  DEFAULT   14 newoid.9255
  4271: 00114a9c    44 OBJECT  LOCAL  DEFAULT   14 sysctl___sysctl_oiddescr
  4272: 00114ac8    44 OBJECT  LOCAL  DEFAULT   14 sysctl___sysctl_oidfmt
  4273: 00114af4    44 OBJECT  LOCAL  DEFAULT   14 sysctl___sysctl_name2oid
  4274: 00114b20    44 OBJECT  LOCAL  DEFAULT   14 sysctl___sysctl_next
  4275: 00114b4c    44 OBJECT  LOCAL  DEFAULT   14 sysctl___sysctl_name
  4276: 00114b78    44 OBJECT  LOCAL  DEFAULT   14 sysctl___sysctl_debug
  4277: 001099d0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4278: 001107f4     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4279: 001107f4     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4280: 001107f8     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4281: 001107fc     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4282: 00110800     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4283: 00110804     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4284: 00110808     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4285: 0000ce10     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4286: 00000000     0 FILE    LOCAL  DEFAULT  ABS radix.c
  4287: 0005e18c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4288: 0005e18c   324 FUNC    LOCAL  DEFAULT    2 rn_walktree_from
  4289: 0005e2d0   212 FUNC    LOCAL  DEFAULT    2 rn_walktree
  4290: 0005e3a4   176 FUNC    LOCAL  DEFAULT    2 rn_satisfies_leaf.isra.0
  4291: 0005e450     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4292: 0005e454     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4293: 0005e67c   404 FUNC    LOCAL  DEFAULT    2 rn_insert.isra.1
  4294: 0005e810   152 FUNC    LOCAL  DEFAULT    2 rn_new_radix_mask
  4295: 0005e8a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4296: 0005e8a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4297: 0005e8a8   268 FUNC    LOCAL  DEFAULT    2 rn_inithead.part.3
  4298: 0005e998     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4299: 0005e9b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4300: 0005ed9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4301: 0005eda8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4302: 0005f28c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4303: 0005f290     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4304: 0005f69c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4305: 0005f6b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4306: 0005f7a8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4307: 00109b08     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4308: 00109b08     9 OBJECT  LOCAL  DEFAULT    6 normal_chars
  4309: 00109b14     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4310: 0011c114     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4311: 0011c114     4 OBJECT  LOCAL  DEFAULT   15 rn_ones
  4312: 0011c118     4 OBJECT  LOCAL  DEFAULT   15 rn_mkfreelist
  4313: 0011c11c     4 OBJECT  LOCAL  DEFAULT   15 rn_zeros
  4314: 0011c120     4 OBJECT  LOCAL  DEFAULT   15 max_keylen
  4315: 0011c124     4 OBJECT  LOCAL  DEFAULT   15 mask_rnhead
  4316: 0011c128     4 OBJECT  LOCAL  DEFAULT   15 addmask_key
  4317: 0011c12c     4 OBJECT  LOCAL  DEFAULT   15 last_zeroed.8550
  4318: 0000d2cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4319: 00000000     0 FILE    LOCAL  DEFAULT  ABS raw_ip.c
  4320: 0005f7c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4321: 0005f7ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4322: 0005f7f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4323: 0005fa24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4324: 0005fa34     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4325: 0005fbe8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4326: 0005fbf0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4327: 0005fc24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4328: 0005fdcc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4329: 0005ff90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4330: 0005ffa0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4331: 0005ffcc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4332: 00060014     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4333: 00060264     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4334: 00114ba4     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4335: 00114ba4    16 OBJECT  LOCAL  DEFAULT   14 ripsrc
  4336: 00109c64     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4337: 0011c130     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4338: 0011c130     4 OBJECT  LOCAL  DEFAULT   15 ripcb
  4339: 0011c138    32 OBJECT  LOCAL  DEFAULT   15 ripcbinfo
  4340: 0000d4ec     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4341: 00000000     0 FILE    LOCAL  DEFAULT  ABS raw_usrreq.c
  4342: 00060284     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4343: 00060294     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4344: 00060298     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4345: 00060438     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4346: 00060440     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4347: 000604a8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4348: 000604f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4349: 0006063c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4350: 00109c88     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4351: 0000d638     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4352: 00000000     0 FILE    LOCAL  DEFAULT  ABS route.c
  4353: 00060640     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4354: 00060640   132 FUNC    LOCAL  DEFAULT    2 rt_maskedcopy
  4355: 0006070c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4356: 00060714     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4357: 00060748     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4358: 0006074c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4359: 00060864     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4360: 00060878     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4361: 00060884     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4362: 00060888     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4363: 00060ab4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4364: 00061238   240 FUNC    LOCAL  DEFAULT    2 rt_fixchange
  4365: 00060ac0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4366: 00060f74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4367: 00061328    72 FUNC    LOCAL  DEFAULT    2 rt_fixdelete
  4368: 00060f8c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4369: 000610d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4370: 000610e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4371: 00061588     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4372: 00061594     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4373: 0006181c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4374: 00109c94     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4375: 0011c158     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4376: 0011c158     4 OBJECT  LOCAL  DEFAULT   15 rttrash
  4377: 0011c15c    10 OBJECT  LOCAL  DEFAULT   15 rtstat
  4378: 0000d6e8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4379: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems_bsdnet_malloc_starv
  4380: 00061820     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4381: 00061828     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4382: 00109d30     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4383: 0000d934     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4384: 00000000     0 FILE    LOCAL  DEFAULT  ABS tcp_input.c
  4385: 0006182c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4386: 0006182c   232 FUNC    LOCAL  DEFAULT    2 tcp_xmit_timer
  4387: 00061910     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4388: 00061914     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4389: 00061914   712 FUNC    LOCAL  DEFAULT    2 tcp_reass
  4390: 00061bd8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4391: 00061bdc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4392: 00061e84     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4393: 00061e98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4394: 00061e98   720 FUNC    LOCAL  DEFAULT    2 tcp_dooptions.isra.1
  4395: 00061eec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4396: 00061f1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4397: 00062164     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4398: 00062168     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4399: 000624ac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4400: 000624d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4401: 00062f98     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4402: 00062fac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4403: 00063074     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4404: 00063094     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4405: 00063118     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4406: 00063154     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4407: 00063e24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4408: 0011080c     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4409: 0011080c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4410: 00114bb4    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp_log
  4411: 00110810     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4412: 00114be0    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp_sta
  4413: 00114bb4     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4414: 0011c168     4 OBJECT  LOCAL  DEFAULT   15 log_in_vain
  4415: 00109d54     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4416: 0011c168     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4417: 0000d954     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4418: 00000000     0 FILE    LOCAL  DEFAULT  ABS tcp_output.c
  4419: 00063e28     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4420: 00063e8c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4421: 00063e94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4422: 000647e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4423: 00064834     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4424: 00064cb8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4425: 00109da0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4426: 00109da0    11 OBJECT  LOCAL  DEFAULT    6 tcp_outflags
  4427: 00109dac     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4428: 0000da50     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4429: 00000000     0 FILE    LOCAL  DEFAULT  ABS tcp_subr.c
  4430: 00064ce8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4431: 00064cfc   148 FUNC    LOCAL  DEFAULT    2 tcp_notify
  4432: 00064d90   444 FUNC    LOCAL  DEFAULT    2 tcp_pcblist.part.0
  4433: 00064f48     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4434: 00064f4c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4435: 00064f4c    92 FUNC    LOCAL  DEFAULT    2 tcp_pcblist
  4436: 00064fa4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4437: 00064fa8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4438: 0006501c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4439: 00065038     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4440: 000652e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4441: 000652f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4442: 00065384     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4443: 00065390     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4444: 0006559c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4445: 000655a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4446: 0006561c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4447: 00065620     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4448: 000656e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4449: 000656f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4450: 00065824     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4451: 00065830     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4452: 00114c0c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4453: 00114c10    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp_pcb
  4454: 00114c3c    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp_mss
  4455: 00109ddc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4456: 00110814     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4457: 00110814     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4458: 00110818     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4459: 0000dab4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4460: 00000000     0 FILE    LOCAL  DEFAULT  ABS tcp_timer.c
  4461: 00065858     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4462: 000658c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4463: 000658cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4464: 000658fc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4465: 0006590c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4466: 00065bfc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4467: 00065c0c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4468: 00065cf8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4469: 0011081c     0 NOTYPE  LOCAL  DEFAULT   12 $d
  4470: 0011081c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4471: 00114ca4    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp_alw
  4472: 00110820     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4473: 00114cd0    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp_kee
  4474: 00110824     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4475: 00114cfc    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp_kee
  4476: 00110828     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  4477: 00114d28    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_tcp_kee
  4478: 00114c68     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4479: 00114c68     4 OBJECT  LOCAL  DEFAULT   14 tcp_keepintvl
  4480: 0011c16c     4 OBJECT  LOCAL  DEFAULT   15 always_keepalive
  4481: 00109e40     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4482: 0011c16c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4483: 0000dc9c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4484: 00000000     0 FILE    LOCAL  DEFAULT  ABS clocksettime.c
  4485: 00065d0c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4486: 00065dec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4487: 0000dd54     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4488: 00000000     0 FILE    LOCAL  DEFAULT  ABS nanosleep.c
  4489: 00065df4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4490: 00065f70     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4491: 0000dd90     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4492: 00000000     0 FILE    LOCAL  DEFAULT  ABS pthreadonce.c
  4493: 00065f7c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4494: 0000ddc0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4495: 00000000     0 FILE    LOCAL  DEFAULT  ABS sigaddset.c
  4496: 00065fa4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4497: 0000dde0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4498: 00000000     0 FILE    LOCAL  DEFAULT  ABS sigemptyset.c
  4499: 00065ff4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4500: 0000de08     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4501: 00000000     0 FILE    LOCAL  DEFAULT  ABS sigprocmask.c
  4502: 00066028     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4503: 0000de30     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4504: 00000000     0 FILE    LOCAL  DEFAULT  ABS barrier.c
  4505: 00066030     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4506: 0006606c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4507: 0000de50     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4508: 00000000     0 FILE    LOCAL  DEFAULT  ABS clockgetuptime.c
  4509: 00066074     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4510: 0000de7c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4511: 00000000     0 FILE    LOCAL  DEFAULT  ABS clockset.c
  4512: 00066094     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4513: 00066150     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4514: 0000dea8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4515: 00000000     0 FILE    LOCAL  DEFAULT  ABS clocktodvalidate.c
  4516: 00066158     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4517: 0006624c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4518: 00109e78     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4519: 0000dee8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4520: 00000000     0 FILE    LOCAL  DEFAULT  ABS dpmem.c
  4521: 00066260     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4522: 0006629c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4523: 0000df10     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4524: 00000000     0 FILE    LOCAL  DEFAULT  ABS event.c
  4525: 000662a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4526: 0000df3c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4527: 00000000     0 FILE    LOCAL  DEFAULT  ABS getprocessorcount.c
  4528: 000662a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4529: 0000df5c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4530: 00000000     0 FILE    LOCAL  DEFAULT  ABS msg.c
  4531: 000662b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4532: 000662e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4533: 0000df7c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4534: 00000000     0 FILE    LOCAL  DEFAULT  ABS part.c
  4535: 000662f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4536: 0006632c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4537: 0000dfa8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4538: 00000000     0 FILE    LOCAL  DEFAULT  ABS ratemon.c
  4539: 00066334     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4540: 00066370     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4541: 0000dfd4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4542: 00000000     0 FILE    LOCAL  DEFAULT  ABS ratemonreportstatistics.c
  4543: 00066378     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4544: 00066378   500 FUNC    LOCAL  DEFAULT    2 rtems_rate_monotonic_repo
  4545: 00066540     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4546: 0006656c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4547: 00066584     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4548: 00109ee0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4549: 0000e000     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4550: 00000000     0 FILE    LOCAL  DEFAULT  ABS ratemonresetall.c
  4551: 00066588     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4552: 00066610     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4553: 0000e05c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4554: 00000000     0 FILE    LOCAL  DEFAULT  ABS ratemonresetstatistics.c
  4555: 00066618     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4556: 000666c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4557: 0000e088     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4558: 00000000     0 FILE    LOCAL  DEFAULT  ABS region.c
  4559: 000666c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4560: 00066704     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4561: 0000e0bc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4562: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtemstimer.c
  4563: 0006670c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4564: 00066754     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4565: 0000e0e8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4566: 00000000     0 FILE    LOCAL  DEFAULT  ABS semflush.c
  4567: 00066760     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4568: 00066808     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4569: 0000e118     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4570: 00000000     0 FILE    LOCAL  DEFAULT  ABS sem.c
  4571: 00066810     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4572: 0006684c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4573: 0000e148     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4574: 00000000     0 FILE    LOCAL  DEFAULT  ABS signal.c
  4575: 00066854     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4576: 0000e174     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4577: 00000000     0 FILE    LOCAL  DEFAULT  ABS status.c
  4578: 00066858     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4579: 0006688c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4580: 0010a038     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4581: 0010a038   116 OBJECT  LOCAL  DEFAULT    6 status_code_to_errno
  4582: 0000e194     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4583: 00000000     0 FILE    LOCAL  DEFAULT  ABS taskmode.c
  4584: 00066890     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4585: 00066a80     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4586: 0000e1bc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4587: 00000000     0 FILE    LOCAL  DEFAULT  ABS tasksetpriority.c
  4588: 00066a8c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4589: 00066b74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4590: 0000e218     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4591: 00000000     0 FILE    LOCAL  DEFAULT  ABS tasks.c
  4592: 00066b7c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4593: 00066b7c   104 FUNC    LOCAL  DEFAULT    2 _RTEMS_tasks_Create_exten
  4594: 00066bdc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4595: 00066be4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4596: 00066be4    20 FUNC    LOCAL  DEFAULT    2 _RTEMS_tasks_Start_extens
  4597: 00066bf8     4 FUNC    LOCAL  DEFAULT    2 _RTEMS_tasks_Delete_exten
  4598: 00066bfc    96 FUNC    LOCAL  DEFAULT    2 _RTEMS_tasks_Switch_exten
  4599: 00066c70     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4600: 00066c74     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4601: 00066c74    60 FUNC    LOCAL  DEFAULT    2 _RTEMS_tasks_Terminate_ex
  4602: 00066d00     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4603: 00114d58     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4604: 0000e258     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4605: 00000000     0 FILE    LOCAL  DEFAULT  ABS taskvariable_invoke_dtor.
  4606: 00066d10     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4607: 00066d54     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4608: 0000e300     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4609: 00000000     0 FILE    LOCAL  DEFAULT  ABS debug.c
  4610: 00066d58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4611: 00066d68     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4612: 00066d6c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4613: 00066d80     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4614: 00066d84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4615: 00066d98     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4616: 00066d9c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4617: 00066db4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4618: 0000e32c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4619: 00000000     0 FILE    LOCAL  DEFAULT  ABS exshutdown.c
  4620: 00066db8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4621: 0000e37c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4622: 00000000     0 FILE    LOCAL  DEFAULT  ABS extensiondata.c
  4623: 00000000     0 FILE    LOCAL  DEFAULT  ABS ioclose.c
  4624: 00066dcc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4625: 00066e08     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4626: 0000e3a4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4627: 00000000     0 FILE    LOCAL  DEFAULT  ABS iocontrol.c
  4628: 00066e10     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4629: 00066e4c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4630: 0000e3c4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4631: 00000000     0 FILE    LOCAL  DEFAULT  ABS ioinitialize.c
  4632: 00066e54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4633: 00066e8c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4634: 0000e3e4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4635: 00000000     0 FILE    LOCAL  DEFAULT  ABS ioopen.c
  4636: 00066e94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4637: 00066ed0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4638: 0000e404     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4639: 00000000     0 FILE    LOCAL  DEFAULT  ABS ioread.c
  4640: 00066ed8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4641: 00066f14     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4642: 0000e424     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4643: 00000000     0 FILE    LOCAL  DEFAULT  ABS ioregisterdriver.c
  4644: 00066f1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4645: 00067168     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4646: 0000e444     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4647: 00000000     0 FILE    LOCAL  DEFAULT  ABS iounregisterdriver.c
  4648: 00067178     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4649: 00067238     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4650: 0000e48c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4651: 00000000     0 FILE    LOCAL  DEFAULT  ABS iowrite.c
  4652: 00067244     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4653: 00067280     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4654: 0000e4b4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4655: 00000000     0 FILE    LOCAL  DEFAULT  ABS profilingreportxml.c
  4656: 00067288     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4657: 0000e4d4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4658: 00000000     0 FILE    LOCAL  DEFAULT  ABS coretodgetuptimetimespec.
  4659: 00067290     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4660: 000672b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4661: 0000e4f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4662: 00000000     0 FILE    LOCAL  DEFAULT  ABS coretodset.c
  4663: 000672bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4664: 00067378     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4665: 0000e524     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4666: 00000000     0 FILE    LOCAL  DEFAULT  ABS heapallocate.c
  4667: 00067384     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4668: 0000e554     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4669: 00000000     0 FILE    LOCAL  DEFAULT  ABS heapfree.c
  4670: 000675f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4671: 0000e598     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4672: 00000000     0 FILE    LOCAL  DEFAULT  ABS heapresizeblock.c
  4673: 000677cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4674: 0000e5e0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4675: 00000000     0 FILE    LOCAL  DEFAULT  ABS heapsizeofuserarea.c
  4676: 00067900     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4677: 0000e618     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4678: 00000000     0 FILE    LOCAL  DEFAULT  ABS log2table.c
  4679: 0010a0b4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4680: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectapimaximumclass.c
  4681: 00067984     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4682: 0006799c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4683: 0010a1b4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4684: 0010a1b4    12 OBJECT  LOCAL  DEFAULT    6 CSWTCH.1
  4685: 0000e644     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4686: 00000000     0 FILE    LOCAL  DEFAULT  ABS once.c
  4687: 000679a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4688: 00067a08     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4689: 0000e664     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4690: 00000000     0 FILE    LOCAL  DEFAULT  ABS pheapgetinfo.c
  4691: 00067a0c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4692: 00067a54     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4693: 0000e694     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4694: 00000000     0 FILE    LOCAL  DEFAULT  ABS pheapwalk.c
  4695: 00067a58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4696: 00067ab0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4697: 0000e6c8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4698: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadloadenv.c
  4699: 00067ab8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4700: 00067b08     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4701: 0000e704     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4702: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadqextractwithproxy.c
  4703: 00067b0c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4704: 0000e738     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4705: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadqprocesstimeout.c
  4706: 00067b20     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4707: 00067b84     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4708: 0000e758     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4709: 00000000     0 FILE    LOCAL  DEFAULT  ABS timespecdividebyinteger.c
  4710: 00067b88     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4711: 00067bf0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4712: 0000e778     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4713: 00000000     0 FILE    LOCAL  DEFAULT  ABS timespecdivide.c
  4714: 00067bf4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4715: 00067c88     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4716: 0000e7a4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4717: 00000000     0 FILE    LOCAL  DEFAULT  ABS timespecfromticks.c
  4718: 00067c90     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4719: 00067ccc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4720: 0000e7d8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4721: 00000000     0 FILE    LOCAL  DEFAULT  ABS timespecisvalid.c
  4722: 00067cd8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4723: 00067d0c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4724: 0000e800     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4725: 00000000     0 FILE    LOCAL  DEFAULT  ABS timespeclessthan.c
  4726: 00067d10     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4727: 0000e820     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4728: 00000000     0 FILE    LOCAL  DEFAULT  ABS timespectoticks.c
  4729: 00067d4c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4730: 00067dbc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4731: 0000e840     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4732: 00000000     0 FILE    LOCAL  DEFAULT  ABS userextaddset.c
  4733: 00067dc0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4734: 00067e18     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4735: 0000e86c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4736: 00000000     0 FILE    LOCAL  DEFAULT  ABS watchdogadjust.c
  4737: 00067e20     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4738: 0000e894     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4739: 00000000     0 FILE    LOCAL  DEFAULT  ABS arm-exception-default.c
  4740: 00067ed8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4741: 0000e8d4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4742: 00000000     0 FILE    LOCAL  DEFAULT  ABS cat_file.c
  4743: 00067ee8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4744: 00067f3c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4745: 00107820     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4746: 0000e8fc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4747: 00000000     0 FILE    LOCAL  DEFAULT  ABS cmds.c
  4748: 00067f40     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4749: 00067f40   124 FUNC    LOCAL  DEFAULT    2 rtems_shell_register_comm
  4750: 00067fb0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4751: 00067fbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4752: 0006801c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4753: 00103f04     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4754: 0000e928     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4755: 00000000     0 FILE    LOCAL  DEFAULT  ABS cmp-ls.c
  4756: 00068020     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4757: 0000e994     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4758: 00000000     0 FILE    LOCAL  DEFAULT  ABS dd-args.c
  4759: 0006823c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4760: 0006823c    12 FUNC    LOCAL  DEFAULT    2 c_arg
  4761: 00068248    12 FUNC    LOCAL  DEFAULT    2 c_conv
  4762: 00068254   496 FUNC    LOCAL  DEFAULT    2 get_off_t
  4763: 00068430     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4764: 00068444     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4765: 00068444    20 FUNC    LOCAL  DEFAULT    2 f_seek
  4766: 00068458    20 FUNC    LOCAL  DEFAULT    2 f_skip
  4767: 0006846c    24 FUNC    LOCAL  DEFAULT    2 f_of
  4768: 00068484    24 FUNC    LOCAL  DEFAULT    2 f_if
  4769: 0006849c   416 FUNC    LOCAL  DEFAULT    2 get_num
  4770: 00068628     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4771: 0006863c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4772: 0006863c   196 FUNC    LOCAL  DEFAULT    2 f_conv
  4773: 000686ec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4774: 00068700     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4775: 00068700   100 FUNC    LOCAL  DEFAULT    2 f_obs
  4776: 00068760     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4777: 00068764     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4778: 00068764   100 FUNC    LOCAL  DEFAULT    2 f_ibs
  4779: 000687c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4780: 000687c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4781: 000687c8    68 FUNC    LOCAL  DEFAULT    2 f_files
  4782: 00068808     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4783: 0006880c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4784: 0006880c    76 FUNC    LOCAL  DEFAULT    2 f_count
  4785: 00068854     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4786: 00068858     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4787: 00068858    88 FUNC    LOCAL  DEFAULT    2 f_cbs
  4788: 000688ac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4789: 000688b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4790: 000688b0    92 FUNC    LOCAL  DEFAULT    2 f_bs
  4791: 00068908     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4792: 0006890c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4793: 0006890c    56 FUNC    LOCAL  DEFAULT    2 f_fillchar
  4794: 00068940     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4795: 00068944     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4796: 00068b94     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4797: 0010a1c8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4798: 0010a1c8   216 OBJECT  LOCAL  DEFAULT    6 CSWTCH.15
  4799: 0010a2a0   216 OBJECT  LOCAL  DEFAULT    6 CSWTCH.21
  4800: 0010a378   320 OBJECT  LOCAL  DEFAULT    6 clist
  4801: 0010a4b8   224 OBJECT  LOCAL  DEFAULT    6 args
  4802: 0010cd84     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4803: 0011c170     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4804: 0011c170     4 OBJECT  LOCAL  DEFAULT   15 oper
  4805: 0000ea74     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4806: 00000000     0 FILE    LOCAL  DEFAULT  ABS dd-conv.c
  4807: 00068bd0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4808: 00068f2c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4809: 00068f30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4810: 000691a8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4811: 0010a8b4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4812: 0011c174     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4813: 0011c174     4 OBJECT  LOCAL  DEFAULT   15 intrunc.5258
  4814: 0000ec9c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4815: 00000000     0 FILE    LOCAL  DEFAULT  ABS dd-conv_tab.c
  4816: 0010a8cc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4817: 00000000     0 FILE    LOCAL  DEFAULT  ABS dd-misc.c
  4818: 000691ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4819: 00069374     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4820: 00069394     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4821: 00107600     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4822: 0000ed4c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4823: 00000000     0 FILE    LOCAL  DEFAULT  ABS dd-position.c
  4824: 000693b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4825: 00069534     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4826: 00069544     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4827: 000695f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4828: 0010cd84     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4829: 0000eda4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4830: 00000000     0 FILE    LOCAL  DEFAULT  ABS err.c
  4831: 000695fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4832: 0000ee00     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4833: 00000000     0 FILE    LOCAL  DEFAULT  ABS errx.c
  4834: 0006961c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4835: 0000ee30     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4836: 00000000     0 FILE    LOCAL  DEFAULT  ABS filemode.c
  4837: 0006963c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4838: 000698a4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4839: 0000ee60     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4840: 00000000     0 FILE    LOCAL  DEFAULT  ABS fts.c
  4841: 000698ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4842: 000698ac   208 FUNC    LOCAL  DEFAULT    2 fts_sort
  4843: 0006997c    76 FUNC    LOCAL  DEFAULT    2 fts_palloc.isra.1
  4844: 000699c8   384 FUNC    LOCAL  DEFAULT    2 fts_stat.isra.2
  4845: 00069b48   148 FUNC    LOCAL  DEFAULT    2 fts_alloc.isra.3
  4846: 00069bdc   240 FUNC    LOCAL  DEFAULT    2 fts_safe_changedir.isra.5
  4847: 00069ccc  1492 FUNC    LOCAL  DEFAULT    2 fts_build
  4848: 0006a29c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4849: 0006a2a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4850: 0006a5dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4851: 0006a5e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4852: 0006acb4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4853: 0006acbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4854: 0006ae44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4855: 0010317c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4856: 0000ee80     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4857: 00000000     0 FILE    LOCAL  DEFAULT  ABS hexdump-display.c
  4858: 0006ae48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4859: 0006aed4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4860: 0006aed8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4861: 0006b030     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4862: 0006b034     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4863: 0006b034   336 FUNC    LOCAL  DEFAULT    2 rtems_shell_hexdump_next.
  4864: 0006b170     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4865: 0006b184     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4866: 0006b1ac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4867: 0006b1b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4868: 0006b434     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4869: 0006b444     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4870: 0006b6cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4871: 0006b6ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4872: 0006b75c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4873: 0006b77c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4874: 0006b990     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4875: 0010afa8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4876: 0011c178     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4877: 0011c178     4 OBJECT  LOCAL  DEFAULT   15 _argv
  4878: 0000f048     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4879: 00000000     0 FILE    LOCAL  DEFAULT  ABS hexdump-odsyntax.c
  4880: 0006b9a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4881: 0006b9a0    68 FUNC    LOCAL  DEFAULT    2 odadd
  4882: 0006b9dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4883: 0006b9e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4884: 0006b9e4  1216 FUNC    LOCAL  DEFAULT    2 odformat
  4885: 0006ba18     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4886: 0006ba78     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4887: 0006bb2c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4888: 0006bb70     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4889: 0006be74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4890: 0006bea4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4891: 0006bf20     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4892: 0006c000     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4893: 0006c1dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4894: 0006c230     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4895: 0006c568     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4896: 00114d9c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  4897: 00114d9c    10 OBJECT  LOCAL  DEFAULT   14 padding.6949
  4898: 0010b00c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4899: 0011c17c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4900: 0011c17c     4 OBJECT  LOCAL  DEFAULT   15 needpad.7063
  4901: 0011c180     1 OBJECT  LOCAL  DEFAULT   15 empty.6948
  4902: 0000f14c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4903: 00000000     0 FILE    LOCAL  DEFAULT  ABS hexdump-parse.c
  4904: 0006c5d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4905: 0006c674     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4906: 0006c744     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4907: 0006c818     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4908: 0006c824     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4909: 0006c88c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4910: 0006c8e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4911: 0006c954     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4912: 0006c958     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4913: 0006c96c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4914: 0006c970     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4915: 0006c988     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4916: 0006c98c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4917: 0006cbd0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4918: 0006cbd8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4919: 0006cd24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4920: 0006cd38     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4921: 0006cd50     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4922: 0006cd54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4923: 0006ce68     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4924: 0006cf38     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4925: 0006cf84     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4926: 0006cf98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4927: 0006d3f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4928: 0010b210     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4929: 0011c184     0 NOTYPE  LOCAL  DEFAULT   15 $d
  4930: 0011c184     4 OBJECT  LOCAL  DEFAULT   15 nextfs.6846
  4931: 0000f1d4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4932: 00000000     0 FILE    LOCAL  DEFAULT  ABS hexsyntax.c
  4933: 0006d408     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4934: 0006d448     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4935: 0006d458     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4936: 0006d4dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4937: 0006d5c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4938: 0006d7b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4939: 0010b2dc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4940: 0000f328     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4941: 00000000     0 FILE    LOCAL  DEFAULT  ABS login_prompt.c
  4942: 0006d7ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4943: 0006d7ec     4 FUNC    LOCAL  DEFAULT    2 rtems_shell_discard
  4944: 0006d7f0   360 FUNC    LOCAL  DEFAULT    2 rtems_shell_get_text
  4945: 0006d94c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4946: 0006d958     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4947: 0006dac8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4948: 0010b4ec     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4949: 0000f384     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4950: 00000000     0 FILE    LOCAL  DEFAULT  ABS shell_getchar.c
  4951: 0006dad4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4952: 0006db4c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4953: 0010b518     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4954: 0010b518    36 OBJECT  LOCAL  DEFAULT    6 trans_tab
  4955: 0010b644   120 OBJECT  LOCAL  DEFAULT    6 trans_tab_csi
  4956: 0010b53c   264 OBJECT  LOCAL  DEFAULT    6 trans_tab_O
  4957: 0010b6ec    24 OBJECT  LOCAL  DEFAULT    6 trans_one
  4958: 0010b6d4    24 OBJECT  LOCAL  DEFAULT    6 trans_two
  4959: 0010b6bc    24 OBJECT  LOCAL  DEFAULT    6 trans_three
  4960: 0000f3f8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4961: 00000000     0 FILE    LOCAL  DEFAULT  ABS shell_getprompt.c
  4962: 0006db50     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4963: 0006dbcc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4964: 001026ec     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4965: 0000f424     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4966: 00000000     0 FILE    LOCAL  DEFAULT  ABS shell_makeargs.c
  4967: 0006dbdc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4968: 0006dcf8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4969: 0000f45c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4970: 00000000     0 FILE    LOCAL  DEFAULT  ABS verr.c
  4971: 0006dcfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4972: 0006dd74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4973: 00106a60     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4974: 0000f490     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4975: 00000000     0 FILE    LOCAL  DEFAULT  ABS verrx.c
  4976: 0006dd7c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4977: 0000f4b8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4978: 00000000     0 FILE    LOCAL  DEFAULT  ABS vwarn.c
  4979: 0006ddc0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4980: 0006de2c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4981: 00106a60     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4982: 0000f4e0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4983: 00000000     0 FILE    LOCAL  DEFAULT  ABS vwarnx.c
  4984: 0006de34     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4985: 0000f514     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4986: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-command.c
  4987: 0006de6c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4988: 0006de6c   768 FUNC    LOCAL  DEFAULT    2 rtems_monitor_show_help
  4989: 0006e160     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4990: 0006e16c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4991: 0006e16c    60 FUNC    LOCAL  DEFAULT    2 rtems_monitor_command_loo
  4992: 0006e1dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4993: 0006e1e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4994: 0006e298     0 NOTYPE  LOCAL  DEFAULT    2 $d
  4995: 0006e29c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  4996: 0010b714     0 NOTYPE  LOCAL  DEFAULT    6 $d
  4997: 0000f548     0 NOTYPE  LOCAL  DEFAULT   22 $d
  4998: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-monitor.c
  4999: 0006e2ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5000: 0006e3cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5001: 0006e3d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5002: 0006e4f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5003: 0006e508     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5004: 0006e570     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5005: 0006e574     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5006: 0006e5d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5007: 0010b754     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5008: 0010b754   456 OBJECT  LOCAL  DEFAULT    6 rtems_monitor_commands
  5009: 00114da8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5010: 00114da8     4 OBJECT  LOCAL  DEFAULT   14 rtems_monitor_registered_
  5011: 0010b91c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5012: 0000f628     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5013: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-object.c
  5014: 0006e5d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5015: 0006e634     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5016: 0006e638     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5017: 0006e6d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5018: 0006e6d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5019: 0006e724     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5020: 0006e728     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5021: 0006e918     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5022: 0010c114     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5023: 0010c114   280 OBJECT  LOCAL  DEFAULT    6 rtems_monitor_object_info
  5024: 0010c22c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5025: 0000f744     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5026: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-part.c
  5027: 0006e930     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5028: 0006e974     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5029: 0006e978     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5030: 0010c274     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5031: 0000f7f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5032: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-prmisc.c
  5033: 0006ea34     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5034: 0006ea34   184 FUNC    LOCAL  DEFAULT    2 rtems_monitor_dump_assoc_
  5035: 0006eae0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5036: 0006eaec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5037: 0006eb0c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5038: 0006eb10     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5039: 0006eb3c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5040: 0006eb44     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5041: 0006eb64     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5042: 0006eb68     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5043: 0006eb88     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5044: 0006eb8c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5045: 0006ebac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5046: 0006ebb0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5047: 0006ebd0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5048: 0006ebd4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5049: 0006ec54     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5050: 0006ec5c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5051: 0006ec7c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5052: 0006ec80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5053: 0006ecb8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5054: 0006ecc0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5055: 0006ecf8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5056: 0006ed00     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5057: 0006ed38     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5058: 0006ed40     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5059: 0006ed78     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5060: 0006ed80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5061: 0006edec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5062: 0010c2bc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5063: 0010c2d0   312 OBJECT  LOCAL  DEFAULT    6 rtems_monitor_state_assoc
  5064: 0010c408   120 OBJECT  LOCAL  DEFAULT    6 rtems_monitor_attribute_a
  5065: 0010c480    48 OBJECT  LOCAL  DEFAULT    6 rtems_monitor_modes_assoc
  5066: 0010cd84     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5067: 0000f858     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5068: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-queue.c
  5069: 0006edf4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5070: 0006ee3c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5071: 0006ee40     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5072: 0010c5e4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5073: 0000fa00     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5074: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-region.c
  5075: 0006eef8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5076: 0006ef44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5077: 0006ef48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5078: 0010c61c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5079: 0000fa68     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5080: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-sema.c
  5081: 0006f004     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5082: 0006f074     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5083: 0006f078     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5084: 0010c664     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5085: 0000fad4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5086: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-symbols.c
  5087: 0006f118     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5088: 0006f118    36 FUNC    LOCAL  DEFAULT    2 rtems_symbol_compare
  5089: 0006f310     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5090: 0006f314     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5091: 0006f408     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5092: 0006f410     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5093: 0006f4a8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5094: 0006f4ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5095: 0006f51c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5096: 0006f520     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5097: 0006f5a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5098: 0006f5a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5099: 0006f720     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5100: 0006f730     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5101: 0006f854     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5102: 0010c69c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5103: 0000fb34     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5104: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-task.c
  5105: 0006f85c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5106: 0006f904     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5107: 0006f908     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5108: 0006f92c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5109: 0006f930     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5110: 0010c6c0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5111: 0000fcd4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5112: 00000000     0 FILE    LOCAL  DEFAULT  ABS ramdisk-driver.c
  5113: 0006fa3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5114: 0006fb4c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5115: 0000fd48     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5116: 00000000     0 FILE    LOCAL  DEFAULT  ABS ramdisk-init.c
  5117: 0006fb54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5118: 0000fd84     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5119: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-block.c
  5120: 0006fc18     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5121: 0006fc18   336 FUNC    LOCAL  DEFAULT    2 rtems_rfs_block_map_indir
  5122: 0006fd64     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5123: 0006fd68     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5124: 0006fd68   180 FUNC    LOCAL  DEFAULT    2 rtems_rfs_block_find_indi
  5125: 0006fe18     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5126: 0006fe1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5127: 0006fe1c   160 FUNC    LOCAL  DEFAULT    2 rtems_rfs_block_map_indir
  5128: 000708fc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5129: 00070900     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5130: 00070bf0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5131: 00070bf4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5132: 0010c710     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5133: 0000fdd8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5134: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-buffer.c
  5135: 00070bfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5136: 00070bfc   260 FUNC    LOCAL  DEFAULT    2 rtems_rfs_scan_chain
  5137: 00070cf0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5138: 00070d00     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5139: 00070d00   168 FUNC    LOCAL  DEFAULT    2 rtems_rfs_release_chain
  5140: 00070da4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5141: 00070da8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5142: 00070fbc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5143: 00070fd0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5144: 00071268     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5145: 00071284     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5146: 000713f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5147: 0007140c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5148: 00071488     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5149: 00071490     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5150: 00071504     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5151: 00071508     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5152: 000715f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5153: 00071600     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5154: 000716cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5155: 0010c804     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5156: 0000fffc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5157: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-dir.c
  5158: 000716d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5159: 00071b9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5160: 00071bcc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5161: 00071fe8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5162: 00072004     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5163: 0007245c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5164: 0007247c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5165: 000727d4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5166: 000727e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5167: 00072a24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5168: 0010cd04     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5169: 00010164     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5170: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-file.c
  5171: 00072a30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5172: 00072d70     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5173: 00072d84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5174: 00073054     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5175: 00073064     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5176: 00073268     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5177: 00073288     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5178: 00073504     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5179: 00073518     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5180: 0007362c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5181: 00073630     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5182: 00073944     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5183: 00073948     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5184: 0010d3d0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5185: 00010290     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5186: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-file-system.c
  5187: 00073984     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5188: 0007410c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5189: 00074154     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5190: 000741cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5191: 0010d718     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5192: 000103d4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5193: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-format.c
  5194: 000741d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5195: 00074efc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5196: 0010da54     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5197: 00010450     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5198: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-group.c
  5199: 00074fbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5200: 000751c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5201: 000751d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5202: 00075260     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5203: 00075264     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5204: 0007548c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5205: 0007549c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5206: 00075574     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5207: 00075580     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5208: 00075684     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5209: 00075690     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5210: 0010e270     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5211: 000104a0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5212: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-inode.c
  5213: 00075734     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5214: 00075734   152 FUNC    LOCAL  DEFAULT    2 rtems_rfs_inode_time_stam
  5215: 0007589c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5216: 000758a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5217: 000759a4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5218: 000759a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5219: 00075a88     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5220: 00075a94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5221: 00075b20     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5222: 00075b28     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5223: 00075c4c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5224: 00075c58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5225: 00076104     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5226: 00076130     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5227: 0010589c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5228: 0001059c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5229: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-link.c
  5230: 00076198     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5231: 00076354     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5232: 00076360     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5233: 00076768     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5234: 00076794     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5235: 00076a1c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5236: 00076a28     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5237: 00076bf0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5238: 0010e5a4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5239: 00010748     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5240: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-mutex.c
  5241: 00076bf4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5242: 00076c60     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5243: 00076c68     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5244: 00076cbc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5245: 0010e7d4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5246: 0001082c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5247: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-rtems-dev.c
  5248: 00076cc0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5249: 00076cc0     8 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_device_ft
  5250: 00076cc8    32 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_device_io
  5251: 00076ce8    32 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_device_wr
  5252: 00076d08    32 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_device_re
  5253: 00076d28    12 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_device_cl
  5254: 00076d34   588 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_device_op
  5255: 00076f78     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5256: 0010e81c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5257: 00106d40     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5258: 00010878     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5259: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-rtems-dir.c
  5260: 00076f80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5261: 00076f80     8 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_dir_close
  5262: 00076f88   472 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_dir_open
  5263: 00077158     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5264: 00077160     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5265: 00077160   476 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_dir_read
  5266: 00077330     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5267: 0010e858     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5268: 00106d40     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5269: 00010934     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5270: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-rtems-file.c
  5271: 0007733c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5272: 0007733c   232 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_file_ftru
  5273: 0007741c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5274: 00077424     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5275: 00077424   212 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_file_clos
  5276: 000774f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5277: 000774f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5278: 000774f8   336 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_file_lsee
  5279: 00077640     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5280: 00077648     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5281: 00077648   320 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_file_open
  5282: 00077780     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5283: 00077788     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5284: 00077788   480 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_file_read
  5285: 00077960     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5286: 00077968     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5287: 00077968   636 FUNC    LOCAL  DEFAULT    2 rtems_rfs_rtems_file_writ
  5288: 00077bdc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5289: 0010e894     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5290: 00106d40     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5291: 000109b8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5292: 00000000     0 FILE    LOCAL  DEFAULT  ABS unparse.c
  5293: 00077be4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5294: 00077be4   124 FUNC    LOCAL  DEFAULT    2 uuid_unparse_x
  5295: 00077c68     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5296: 00077c6c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5297: 00077c74     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5298: 00077c78     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5299: 00077c80     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5300: 0010e8d0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5301: 00010ad4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5302: 00000000     0 FILE    LOCAL  DEFAULT  ABS cpuusagedata.c
  5303: 00000000     0 FILE    LOCAL  DEFAULT  ABS default_fstat.c
  5304: 00077c84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5305: 00077c94     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5306: 00010b40     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5307: 00000000     0 FILE    LOCAL  DEFAULT  ABS syslog.c
  5308: 00077c98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5309: 00077f3c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5310: 00077f60     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5311: 0007809c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5312: 000780b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5313: 000780e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5314: 000780f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5315: 00078104     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5316: 00114dac     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5317: 00114dac     4 OBJECT  LOCAL  DEFAULT   14 LogMask
  5318: 00114db0     4 OBJECT  LOCAL  DEFAULT   14 LogFacility
  5319: 00114db4     4 OBJECT  LOCAL  DEFAULT   14 LogTag
  5320: 00114db8     4 OBJECT  LOCAL  DEFAULT   14 LogStatus
  5321: 00114dbc     4 OBJECT  LOCAL  DEFAULT   14 LogFd
  5322: 0010e938     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5323: 0011c188     0 NOTYPE  LOCAL  DEFAULT   15 $d
  5324: 0011c188     4 OBJECT  LOCAL  DEFAULT   15 LogSemaphore
  5325: 00010b60     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5326: 00000000     0 FILE    LOCAL  DEFAULT  ABS ns_name.c
  5327: 00078108     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5328: 0007818c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5329: 00078278     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5330: 00078374     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5331: 00078380     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5332: 00078554     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5333: 00078558     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5334: 0007892c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5335: 00078930     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5336: 00114dc0     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5337: 00114dc0    11 OBJECT  LOCAL  DEFAULT   14 digits
  5338: 00010c30     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5339: 00000000     0 FILE    LOCAL  DEFAULT  ABS ns_parse.c
  5340: 00078a4c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5341: 00078a4c   164 FUNC    LOCAL  DEFAULT    2 skiprr
  5342: 00078e00     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5343: 00114dcc     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5344: 00010d60     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5345: 00000000     0 FILE    LOCAL  DEFAULT  ABS ns_ttl.c
  5346: 0007aa34     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5347: 0007aa34   116 FUNC    LOCAL  DEFAULT    2 fmt1
  5348: 0007aaa4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5349: 0007aaa8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5350: 0007ac78     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5351: 0007ac88     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5352: 0007ad34     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5353: 0007ad84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5354: 0007adcc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5355: 001035a4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5356: 00010f24     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5357: 00000000     0 FILE    LOCAL  DEFAULT  ABS res_data.c
  5358: 00114e4c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5359: 00109034     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5360: 00000000     0 FILE    LOCAL  DEFAULT  ABS assocnamebylocal.c
  5361: 0007add0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5362: 00010fa4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5363: 00000000     0 FILE    LOCAL  DEFAULT  ABS assocptrbylocal.c
  5364: 0007adf8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5365: 0007ae68     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5366: 001090fc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5367: 00010fd0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5368: 00000000     0 FILE    LOCAL  DEFAULT  ABS assocremotebylocal.c
  5369: 0007ae6c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5370: 00010ffc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5371: 00000000     0 FILE    LOCAL  DEFAULT  ABS fchdir.c
  5372: 0007ae80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5373: 0007af90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5374: 00011024     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5375: 00000000     0 FILE    LOCAL  DEFAULT  ABS fcntl.c
  5376: 0007af98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5377: 0007afec     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5378: 0007b040     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5379: 0007b314     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5380: 0007b324     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5381: 00011060     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5382: 00000000     0 FILE    LOCAL  DEFAULT  ABS getgroups.c
  5383: 0007b334     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5384: 000110cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5385: 00000000     0 FILE    LOCAL  DEFAULT  ABS termios_baudtable.c
  5386: 0010ec08     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5387: 0010ed04     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5388: 00000000     0 FILE    LOCAL  DEFAULT  ABS igmp.c
  5389: 0007b408     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5390: 0007b408   116 FUNC    LOCAL  DEFAULT    2 find_rti
  5391: 0007b478     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5392: 0007b47c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5393: 0007b47c   416 FUNC    LOCAL  DEFAULT    2 igmp_sendpkt.isra.1
  5394: 0007b608     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5395: 0007b61c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5396: 0007b720     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5397: 0007b72c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5398: 0007bb4c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5399: 0007bb54     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5400: 0007bbe4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5401: 0007bbec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5402: 0007bc44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5403: 0007bc48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5404: 0007bd30     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5405: 0007bd38     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5406: 0007bd90     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5407: 0011082c     0 NOTYPE  LOCAL  DEFAULT   12 $d
  5408: 0011082c     4 OBJECT  LOCAL  DEFAULT   12 __set_sysctl_set_sym_sysc
  5409: 00114edc    44 OBJECT  LOCAL  DEFAULT   14 sysctl___net_inet_igmp_st
  5410: 00114edc     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5411: 0011c1a8    36 OBJECT  LOCAL  DEFAULT   15 igmpstat
  5412: 00102508     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5413: 0011c18c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  5414: 0011c18c     4 OBJECT  LOCAL  DEFAULT   15 Head
  5415: 0011c190     4 OBJECT  LOCAL  DEFAULT   15 router_alert
  5416: 0011c194    20 OBJECT  LOCAL  DEFAULT   15 igmprt
  5417: 0011c1cc     4 OBJECT  LOCAL  DEFAULT   15 igmp_all_hosts_group
  5418: 0011c1d0     4 OBJECT  LOCAL  DEFAULT   15 igmp_all_rtrs_group
  5419: 0011c1d4     4 OBJECT  LOCAL  DEFAULT   15 igmp_timers_are_running
  5420: 0001110c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5421: 00000000     0 FILE    LOCAL  DEFAULT  ABS raw_cb.c
  5422: 0007bd98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5423: 0007be08     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5424: 0007be0c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5425: 0001124c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5426: 00000000     0 FILE    LOCAL  DEFAULT  ABS keyrundestructors.c
  5427: 0007be3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5428: 0007bf0c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5429: 00011298     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5430: 00000000     0 FILE    LOCAL  DEFAULT  ABS barrierdata.c
  5431: 00000000     0 FILE    LOCAL  DEFAULT  ABS dpmemdata.c
  5432: 00000000     0 FILE    LOCAL  DEFAULT  ABS msgdata.c
  5433: 00000000     0 FILE    LOCAL  DEFAULT  ABS partdata.c
  5434: 00000000     0 FILE    LOCAL  DEFAULT  ABS ratemondata.c
  5435: 00000000     0 FILE    LOCAL  DEFAULT  ABS ratemongetstatistics.c
  5436: 0007bf1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5437: 0007c020     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5438: 000112d4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5439: 00000000     0 FILE    LOCAL  DEFAULT  ABS ratemongetstatus.c
  5440: 0007c028     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5441: 0007c174     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5442: 00011330     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5443: 00000000     0 FILE    LOCAL  DEFAULT  ABS ratemonperiod.c
  5444: 0007c17c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5445: 0007c22c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5446: 0007c234     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5447: 0007c234   220 FUNC    LOCAL  DEFAULT    2 _Rate_monotonic_Update_st
  5448: 0007c394     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5449: 0007c3a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5450: 0007c690     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5451: 00011374     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5452: 00000000     0 FILE    LOCAL  DEFAULT  ABS ratemontimeout.c
  5453: 0007c6a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5454: 0007c750     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5455: 00011428     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5456: 00000000     0 FILE    LOCAL  DEFAULT  ABS regiondata.c
  5457: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtemstimerdata.c
  5458: 00000000     0 FILE    LOCAL  DEFAULT  ABS signalcatch.c
  5459: 0007c760     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5460: 0007c7f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5461: 0007c7f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5462: 0007c888     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5463: 00011458     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5464: 00000000     0 FILE    LOCAL  DEFAULT  ABS coretodtickspersec.c
  5465: 0007c88c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5466: 0007c8a4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5467: 000114a8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5468: 00000000     0 FILE    LOCAL  DEFAULT  ABS heapgetinfo.c
  5469: 0007c8ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5470: 0007c8ac    52 FUNC    LOCAL  DEFAULT    2 _Heap_Get_information_vis
  5471: 0007c938     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5472: 000114d0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5473: 00000000     0 FILE    LOCAL  DEFAULT  ABS heapiterate.c
  5474: 0007c93c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5475: 0001150c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5476: 00000000     0 FILE    LOCAL  DEFAULT  ABS heapwalk.c
  5477: 0007c990     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5478: 0007c990    12 FUNC    LOCAL  DEFAULT    2 _Heap_Walk_print_nothing
  5479: 0007c99c    76 FUNC    LOCAL  DEFAULT    2 _Heap_Walk_print
  5480: 0007c9e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5481: 0007c9e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5482: 0007cf80     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5483: 0010eda4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5484: 0001153c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5485: 00000000     0 FILE    LOCAL  DEFAULT  ABS threadhandler.c
  5486: 0007cff8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5487: 0007d068     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5488: 000115cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5489: 00000000     0 FILE    LOCAL  DEFAULT  ABS hexdump-conv.c
  5490: 0007d074     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5491: 0007d0cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5492: 0007d104     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5493: 0007d2d0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5494: 0007d314     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5495: 0007d3f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5496: 0010f1fc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5497: 0010f1fc    27 OBJECT  LOCAL  DEFAULT    6 __FUNCTION__.6657
  5498: 0010f218   128 OBJECT  LOCAL  DEFAULT    6 list.6663
  5499: 00100b2c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5500: 000115f8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5501: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-config.c
  5502: 0007d404     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5503: 0007d478     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5504: 0007d47c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5505: 0007d4bc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5506: 0007d4c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5507: 0007d4e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5508: 0007d4ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5509: 0007d608     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5510: 0010f3b8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5511: 00011644     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5512: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-driver.c
  5513: 0007d628     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5514: 0007d6dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5515: 0007d6ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5516: 0007d710     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5517: 0007d714     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5518: 0007d868     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5519: 0010f4d0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5520: 000116cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5521: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-extension.c
  5522: 0007d884     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5523: 0007d918     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5524: 0007d91c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5525: 0007dadc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5526: 0010f534     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5527: 00011750     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5528: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-itask.c
  5529: 0007dafc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5530: 0007db9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5531: 0007dba4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5532: 0007dbc8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5533: 0007dbcc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5534: 0007dce0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5535: 0010f5ac     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5536: 000117cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5537: 00000000     0 FILE    LOCAL  DEFAULT  ABS mon-manager.c
  5538: 0007dce4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5539: 0001185c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5540: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-bitmaps.c
  5541: 0007dd1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5542: 0007dd1c    64 FUNC    LOCAL  DEFAULT    2 rtems_rfs_bitmap_load_map
  5543: 0007dd5c   652 FUNC    LOCAL  DEFAULT    2 rtems_rfs_search_map_for_
  5544: 0001188c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5545: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-buffer-bdbuf.c
  5546: 0007e540     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5547: 0007e5d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5548: 0010f608     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5549: 00011a6c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5550: 00000000     0 FILE    LOCAL  DEFAULT  ABS rtems-rfs-dir-hash.c
  5551: 0007e5e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5552: 0007e6dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5553: 0007e70c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5554: 0007e7b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5555: 00011ab0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5556: 00000000     0 FILE    LOCAL  DEFAULT  ABS unpack.c
  5557: 0007e7b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5558: 00011ae4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5559: 00000000     0 FILE    LOCAL  DEFAULT  ABS base64.c
  5560: 0007e820     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5561: 0007e9b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5562: 0007e9b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5563: 0007ea18     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5564: 0007ea28     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5565: 0007eb6c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5566: 0007eb7c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5567: 0007ebc4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5568: 0010f648     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5569: 0010f648    65 OBJECT  LOCAL  DEFAULT    6 Base64
  5570: 00011b0c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5571: 00000000     0 FILE    LOCAL  DEFAULT  ABS nsap_addr.c
  5572: 0007ebcc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5573: 0007ecdc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5574: 0007ece0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5575: 0007ed98     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5576: 0011c1d8     0 NOTYPE  LOCAL  DEFAULT   15 $d
  5577: 0011c1d8   765 OBJECT  LOCAL  DEFAULT   15 tmpbuf.8896
  5578: 00011b64     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5579: 00000000     0 FILE    LOCAL  DEFAULT  ABS assocnamebad.c
  5580: 0007ed9c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5581: 0007eda4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5582: 00114f08     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5583: 00114f08    40 OBJECT  LOCAL  DEFAULT   14 bad_buffer.7900
  5584: 00011bb0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5585: 00000000     0 FILE    LOCAL  DEFAULT  ABS getgrent.c
  5586: 0007eda8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5587: 0007eda8    44 FUNC    LOCAL  DEFAULT    2 grp_get_context
  5588: 0007edc8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5589: 0007edd4    20 FUNC    LOCAL  DEFAULT    2 grp_init
  5590: 0007edd4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5591: 0007ede0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5592: 0007ede8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5593: 0007eeac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5594: 0007eeb8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5595: 0007eef4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5596: 00114f30     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5597: 00114f30     8 OBJECT  LOCAL  DEFAULT   14 grp_once
  5598: 00109190     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5599: 0011c4d8     0 NOTYPE  LOCAL  DEFAULT   15 $d
  5600: 0011c4d8     4 OBJECT  LOCAL  DEFAULT   15 grp_key
  5601: 00011bd0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5602: 00000000     0 FILE    LOCAL  DEFAULT  ABS objectgetnext.c
  5603: 0007eef8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5604: 00011c64     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5605: 00000000     0 FILE    LOCAL  DEFAULT  ABS abort.c
  5606: 0007ef98     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5607: 00011c9c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5608: 00000000     0 FILE    LOCAL  DEFAULT  ABS asprintf.c
  5609: 0007efac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5610: 00011cc4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5611: 00000000     0 FILE    LOCAL  DEFAULT  ABS atexit.c
  5612: 0007f090     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5613: 00011d44     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5614: 00000000     0 FILE    LOCAL  DEFAULT  ABS atoi.c
  5615: 0007f0b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5616: 00011d70     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5617: 00000000     0 FILE    LOCAL  DEFAULT  ABS atol.c
  5618: 0007f0e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5619: 00011db8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5620: 00000000     0 FILE    LOCAL  DEFAULT  ABS bcmp.c
  5621: 0007f110     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5622: 00011e00     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5623: 00000000     0 FILE    LOCAL  DEFAULT  ABS bsearch.c
  5624: 0007f120     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5625: 00011e2c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5626: 00000000     0 FILE    LOCAL  DEFAULT  ABS closedir.c
  5627: 0007f1a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5628: 00011e80     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5629: 00000000     0 FILE    LOCAL  DEFAULT  ABS creat.c
  5630: 0007f1dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5631: 0007f1f4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5632: 00011eb4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5633: 00000000     0 FILE    LOCAL  DEFAULT  ABS ctime.c
  5634: 0007f1f8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5635: 00011ee0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5636: 00000000     0 FILE    LOCAL  DEFAULT  ABS ctype_.c
  5637: 0010f68c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5638: 00114f38     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5639: 00000000     0 FILE    LOCAL  DEFAULT  ABS errno.c
  5640: 0007f20c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5641: 00011f0c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5642: 00000000     0 FILE    LOCAL  DEFAULT  ABS exit.c
  5643: 0007f21c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5644: 0007f24c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5645: 00011f38     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5646: 00000000     0 FILE    LOCAL  DEFAULT  ABS fclose.c
  5647: 0007f250     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5648: 00011f60     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5649: 00000000     0 FILE    LOCAL  DEFAULT  ABS fflush.c
  5650: 0007f364     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5651: 0007f660     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5652: 00011fc4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5653: 00000000     0 FILE    LOCAL  DEFAULT  ABS fgetc.c
  5654: 0007f668     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5655: 00012074     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5656: 00000000     0 FILE    LOCAL  DEFAULT  ABS fgets.c
  5657: 0007f72c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5658: 000120d4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5659: 00000000     0 FILE    LOCAL  DEFAULT  ABS fileno.c
  5660: 0007f87c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5661: 00012154     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5662: 00000000     0 FILE    LOCAL  DEFAULT  ABS findfp.c
  5663: 0007f8d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5664: 0007f8d4     8 FUNC    LOCAL  DEFAULT    2 __fp_lock
  5665: 0007f8dc     8 FUNC    LOCAL  DEFAULT    2 __fp_unlock
  5666: 0007f8f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5667: 0007f8fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5668: 0007f8fc   332 FUNC    LOCAL  DEFAULT    2 __sinit.part.1
  5669: 0007fa38     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5670: 0007fa48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5671: 0007fb7c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5672: 0007fb80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5673: 0007fb9c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5674: 0007fba4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5675: 0007fbdc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5676: 0007fbe0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5677: 0007fbf8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5678: 00012184     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5679: 00000000     0 FILE    LOCAL  DEFAULT  ABS fini.c
  5680: 0007fbfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5681: 0007fc3c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5682: 000122f8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5683: 00000000     0 FILE    LOCAL  DEFAULT  ABS fopen.c
  5684: 0007fc44     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5685: 0007fd24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5686: 0007fd38     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5687: 0001232c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5688: 00000000     0 FILE    LOCAL  DEFAULT  ABS fprintf.c
  5689: 0007fd58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5690: 000123ac     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5691: 00000000     0 FILE    LOCAL  DEFAULT  ABS fputc.c
  5692: 0007fdc4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5693: 0001241c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5694: 00000000     0 FILE    LOCAL  DEFAULT  ABS fputs.c
  5695: 0007fe3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5696: 00012474     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5697: 00000000     0 FILE    LOCAL  DEFAULT  ABS fread.c
  5698: 0007fee8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5699: 000124d0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5700: 00000000     0 FILE    LOCAL  DEFAULT  ABS freopen.c
  5701: 00080154     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5702: 000803b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5703: 000803cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5704: 0001257c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5705: 00000000     0 FILE    LOCAL  DEFAULT  ABS fseek.c
  5706: 000803f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5707: 000125e8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5708: 00000000     0 FILE    LOCAL  DEFAULT  ABS fseeko.c
  5709: 0008044c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5710: 000809f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5711: 00080a00     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5712: 00012640     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5713: 00000000     0 FILE    LOCAL  DEFAULT  ABS ftell.c
  5714: 00080a30     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5715: 000126dc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5716: 00000000     0 FILE    LOCAL  DEFAULT  ABS ftello.c
  5717: 00080a94     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5718: 0001272c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5719: 00000000     0 FILE    LOCAL  DEFAULT  ABS fvwrite.c
  5720: 00080bc8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5721: 000810b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5722: 0001278c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5723: 00000000     0 FILE    LOCAL  DEFAULT  ABS fwalk.c
  5724: 000810b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5725: 0001280c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5726: 00000000     0 FILE    LOCAL  DEFAULT  ABS fwrite.c
  5727: 000811c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5728: 0001288c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5729: 00000000     0 FILE    LOCAL  DEFAULT  ABS getcwd.c
  5730: 0008129c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5731: 000817b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5732: 001102c4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5733: 000128fc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5734: 00000000     0 FILE    LOCAL  DEFAULT  ABS getenv.c
  5735: 000817b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5736: 0001294c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5737: 00000000     0 FILE    LOCAL  DEFAULT  ABS getenv_r.c
  5738: 00081800     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5739: 000818cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5740: 000818d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5741: 000129a4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5742: 00000000     0 FILE    LOCAL  DEFAULT  ABS getopt.c
  5743: 000818ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5744: 000818ec   160 FUNC    LOCAL  DEFAULT    2 permute
  5745: 0008198c  2348 FUNC    LOCAL  DEFAULT    2 getopt_internal
  5746: 00082294     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5747: 000822b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5748: 00082330     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5749: 00082338     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5750: 000823b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5751: 000823bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5752: 00082438     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5753: 00082440     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5754: 00114f3c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5755: 00104eb8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5756: 0011c4dc     0 NOTYPE  LOCAL  DEFAULT   15 $d
  5757: 0011c4e4     4 OBJECT  LOCAL  DEFAULT   15 optwhere
  5758: 00012a14     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5759: 00000000     0 FILE    LOCAL  DEFAULT  ABS gmtime.c
  5760: 000824cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5761: 00012bb0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5762: 00000000     0 FILE    LOCAL  DEFAULT  ABS gmtime_r.c
  5763: 000824ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5764: 000826e8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5765: 00012bdc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5766: 00000000     0 FILE    LOCAL  DEFAULT  ABS impure.c
  5767: 0010f808     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5768: 00114f50   680 OBJECT  LOCAL  DEFAULT   14 impure_data
  5769: 00114f48     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5770: 00101fc0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5771: 00000000     0 FILE    LOCAL  DEFAULT  ABS init.c
  5772: 00082710     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5773: 00082780     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5774: 00012c14     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5775: 00000000     0 FILE    LOCAL  DEFAULT  ABS isatty.c
  5776: 00082790     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5777: 00012c48     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5778: 00000000     0 FILE    LOCAL  DEFAULT  ABS iswprint.c
  5779: 000827a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5780: 000827c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5781: 00012c74     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5782: 00000000     0 FILE    LOCAL  DEFAULT  ABS lcltime.c
  5783: 000827c4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5784: 00012c94     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5785: 00000000     0 FILE    LOCAL  DEFAULT  ABS lcltime_r.c
  5786: 000827e4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5787: 00082b5c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5788: 00012cc0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5789: 00000000     0 FILE    LOCAL  DEFAULT  ABS locale.c
  5790: 00082b74     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5791: 00082be4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5792: 00082bf0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5793: 00082bf8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5794: 00082bfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5795: 00082c08     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5796: 00082c0c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5797: 00082c14     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5798: 00082c18     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5799: 00082c28     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5800: 00082c2c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5801: 00082c60     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5802: 001151f8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5803: 001151f8    32 OBJECT  LOCAL  DEFAULT   14 lc_ctype_charset
  5804: 0011521c    32 OBJECT  LOCAL  DEFAULT   14 lc_message_charset
  5805: 0011523c    56 OBJECT  LOCAL  DEFAULT   14 lconv
  5806: 00101fc0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5807: 0011c4e8     0 NOTYPE  LOCAL  DEFAULT   15 $d
  5808: 00012d0c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5809: 00000000     0 FILE    LOCAL  DEFAULT  ABS makebuf.c
  5810: 00082c64     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5811: 00082dd0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5812: 00012dd0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5813: 00000000     0 FILE    LOCAL  DEFAULT  ABS mbrtowc.c
  5814: 00082dd8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5815: 00082e6c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5816: 00082e74     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5817: 00082f0c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5818: 001065cc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5819: 00012e28     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5820: 00000000     0 FILE    LOCAL  DEFAULT  ABS mbtowc_r.c
  5821: 00082f14     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5822: 00082fb0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5823: 00115274     0 NOTYPE  LOCAL  DEFAULT   14 $d
  5824: 00012ea0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5825: 00000000     0 FILE    LOCAL  DEFAULT  ABS memchr.c
  5826: 00082fb4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5827: 000830c4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5828: 00012f04     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5829: 00000000     0 FILE    LOCAL  DEFAULT  ABS memcmp.c
  5830: 000830cc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5831: 00012f40     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5832: 00000000     0 FILE    LOCAL  DEFAULT  ABS memcpy.c
  5833: 0008317c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5834: 00012f78     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5835: 00000000     0 FILE    LOCAL  DEFAULT  ABS memmove.c
  5836: 0008326c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5837: 00012fb0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5838: 00000000     0 FILE    LOCAL  DEFAULT  ABS memset.c
  5839: 00083398     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5840: 00012ff0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5841: 00000000     0 FILE    LOCAL  DEFAULT  ABS mktime.c
  5842: 0008348c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5843: 0008348c   816 FUNC    LOCAL  DEFAULT    2 validate_structure
  5844: 000837b4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5845: 000837bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5846: 00083c80     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5847: 0010f814     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5848: 0010f814    48 OBJECT  LOCAL  DEFAULT    6 DAYS_IN_MONTH
  5849: 0010f844    48 OBJECT  LOCAL  DEFAULT    6 _DAYS_BEFORE_MONTH
  5850: 00013020     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5851: 00000000     0 FILE    LOCAL  DEFAULT  ABS month_lengths.c
  5852: 0010f874     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5853: 00000000     0 FILE    LOCAL  DEFAULT  ABS opendir.c
  5854: 00083c9c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5855: 00013094     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5856: 00000000     0 FILE    LOCAL  DEFAULT  ABS perror.c
  5857: 00083d44     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5858: 00083db8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5859: 00083dbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5860: 00106a60     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5861: 000130cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5862: 00000000     0 FILE    LOCAL  DEFAULT  ABS printf.c
  5863: 00083dd4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5864: 00013120     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5865: 00000000     0 FILE    LOCAL  DEFAULT  ABS putc.c
  5866: 00083e40     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5867: 00013194     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5868: 00000000     0 FILE    LOCAL  DEFAULT  ABS putchar.c
  5869: 00083f8c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5870: 000131f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5871: 00000000     0 FILE    LOCAL  DEFAULT  ABS puts.c
  5872: 00083fc0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5873: 00084050     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5874: 00084054     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5875: 0010b514     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5876: 0001323c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5877: 00000000     0 FILE    LOCAL  DEFAULT  ABS qsort.c
  5878: 0008406c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5879: 00013294     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5880: 00000000     0 FILE    LOCAL  DEFAULT  ABS raise.c
  5881: 0008497c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5882: 000132f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5883: 00000000     0 FILE    LOCAL  DEFAULT  ABS rand.c
  5884: 000849bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5885: 00084a20     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5886: 00013344     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5887: 00000000     0 FILE    LOCAL  DEFAULT  ABS readdir.c
  5888: 00084a28     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5889: 0001338c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5890: 00000000     0 FILE    LOCAL  DEFAULT  ABS reent.c
  5891: 00084acc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5892: 00084bb8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5893: 000133cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5894: 00000000     0 FILE    LOCAL  DEFAULT  ABS refill.c
  5895: 00084bbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5896: 00084bbc    44 FUNC    LOCAL  DEFAULT    2 lflush
  5897: 00084dc0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5898: 0001342c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5899: 00000000     0 FILE    LOCAL  DEFAULT  ABS rename.c
  5900: 00084dc8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5901: 000134b0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5902: 00000000     0 FILE    LOCAL  DEFAULT  ABS rewind.c
  5903: 00084dec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5904: 000134e4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5905: 00000000     0 FILE    LOCAL  DEFAULT  ABS rget.c
  5906: 00084e44     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5907: 0001352c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5908: 00000000     0 FILE    LOCAL  DEFAULT  ABS scanf.c
  5909: 00084eb0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5910: 00013580     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5911: 00000000     0 FILE    LOCAL  DEFAULT  ABS setbuf.c
  5912: 00084f1c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5913: 000135f4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5914: 00000000     0 FILE    LOCAL  DEFAULT  ABS setenv.c
  5915: 00084f3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5916: 00013620     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5917: 00000000     0 FILE    LOCAL  DEFAULT  ABS setenv_r.c
  5918: 00084f84     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5919: 000851c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5920: 000851c8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5921: 0008528c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5922: 0011c4f4     0 NOTYPE  LOCAL  DEFAULT   15 $d
  5923: 0011c4f4     4 OBJECT  LOCAL  DEFAULT   15 alloced.5021
  5924: 00013670     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5925: 00000000     0 FILE    LOCAL  DEFAULT  ABS lib_a-setjmp.o
  5926: 00085290     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5927: 000852a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5928: 000852a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5929: 000852b8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5930: 00005edc     0 NOTYPE  LOCAL  DEFAULT   18 $d
  5931: 00000000     0 FILE    LOCAL  DEFAULT  ABS setvbuf.c
  5932: 000852bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5933: 0008541c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5934: 0001370c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5935: 00000000     0 FILE    LOCAL  DEFAULT  ABS sleep.c
  5936: 00085424     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5937: 0001375c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5938: 00000000     0 FILE    LOCAL  DEFAULT  ABS snprintf.c
  5939: 0008546c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5940: 0001378c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5941: 00000000     0 FILE    LOCAL  DEFAULT  ABS sprintf.c
  5942: 00085624     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5943: 0001382c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5944: 00000000     0 FILE    LOCAL  DEFAULT  ABS sscanf.c
  5945: 000856f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5946: 00085764     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5947: 00085768     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5948: 000857e4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5949: 000138a4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5950: 00000000     0 FILE    LOCAL  DEFAULT  ABS stdio.c
  5951: 000857e8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5952: 0001391c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5953: 00000000     0 FILE    LOCAL  DEFAULT  ABS strcasecmp.c
  5954: 0008590c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5955: 00085974     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5956: 000139cc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5957: 00000000     0 FILE    LOCAL  DEFAULT  ABS strchr.c
  5958: 00085978     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5959: 00085ad0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5960: 000139f8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5961: 00000000     0 FILE    LOCAL  DEFAULT  ABS lib_a-strcmp.o
  5962: 00085ad8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5963: 00005ffc     0 NOTYPE  LOCAL  DEFAULT   18 $d
  5964: 001106d4     0 NOTYPE  LOCAL  DEFAULT    8 $d
  5965: 00000000     0 FILE    LOCAL  DEFAULT  ABS strcpy.c
  5966: 00085cfc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5967: 00013a40     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5968: 00000000     0 FILE    LOCAL  DEFAULT  ABS strdup.c
  5969: 00085dec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5970: 00013a60     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5971: 00000000     0 FILE    LOCAL  DEFAULT  ABS strdup_r.c
  5972: 00085e08     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5973: 00013a8c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5974: 00000000     0 FILE    LOCAL  DEFAULT  ABS strerror.c
  5975: 00085e48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5976: 00085e54     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5977: 00086090     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5978: 00086344     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5979: 00086488     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5980: 0010f8d4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  5981: 00013ac0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5982: 00000000     0 FILE    LOCAL  DEFAULT  ABS strlcat.c
  5983: 000864a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5984: 00013b0c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5985: 00000000     0 FILE    LOCAL  DEFAULT  ABS strlcpy.c
  5986: 00086568     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5987: 00013b44     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5988: 00000000     0 FILE    LOCAL  DEFAULT  ABS strlen.c
  5989: 000865b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5990: 00013b64     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5991: 00000000     0 FILE    LOCAL  DEFAULT  ABS strncat.c
  5992: 00086610     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5993: 000866b0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5994: 00013b84     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5995: 00000000     0 FILE    LOCAL  DEFAULT  ABS strncmp.c
  5996: 000866b8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  5997: 000867c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  5998: 00013bb4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  5999: 00000000     0 FILE    LOCAL  DEFAULT  ABS strncpy.c
  6000: 000867d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6001: 000868ac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6002: 00013bfc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6003: 00000000     0 FILE    LOCAL  DEFAULT  ABS strnlen.c
  6004: 000868b4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6005: 00013c38     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6006: 00000000     0 FILE    LOCAL  DEFAULT  ABS strpbrk.c
  6007: 00086910     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6008: 00013c58     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6009: 00000000     0 FILE    LOCAL  DEFAULT  ABS strptime.c
  6010: 000869a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6011: 000869a0   176 FUNC    LOCAL  DEFAULT    2 first_day
  6012: 00086a44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6013: 00086a50     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6014: 00086a50   120 FUNC    LOCAL  DEFAULT    2 match_string
  6015: 00086be8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6016: 00086dd0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6017: 000875f4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6018: 0010ffc4     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6019: 0010ffc4    48 OBJECT  LOCAL  DEFAULT    6 _DAYS_BEFORE_MONTH
  6020: 0010fff8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6021: 00013c90     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6022: 00000000     0 FILE    LOCAL  DEFAULT  ABS strrchr.c
  6023: 00087614     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6024: 00013d44     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6025: 00000000     0 FILE    LOCAL  DEFAULT  ABS strsep.c
  6026: 00087668     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6027: 00013d80     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6028: 00000000     0 FILE    LOCAL  DEFAULT  ABS strstr.c
  6029: 00087684     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6030: 00087684   276 FUNC    LOCAL  DEFAULT    2 critical_factorization
  6031: 00087798   928 FUNC    LOCAL  DEFAULT    2 two_way_long_needle
  6032: 00013dac     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6033: 00000000     0 FILE    LOCAL  DEFAULT  ABS strtok.c
  6034: 00087eb8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6035: 00013eb0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6036: 00000000     0 FILE    LOCAL  DEFAULT  ABS strtok_r.c
  6037: 00087ee4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6038: 00013ee4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6039: 00000000     0 FILE    LOCAL  DEFAULT  ABS strtol.c
  6040: 00087fac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6041: 00088184     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6042: 00088188     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6043: 00013f2c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6044: 00000000     0 FILE    LOCAL  DEFAULT  ABS strtoll.c
  6045: 000881b0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6046: 00013f9c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6047: 00000000     0 FILE    LOCAL  DEFAULT  ABS strtoll_r.c
  6048: 000881dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6049: 000884a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6050: 00013fd0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6051: 00000000     0 FILE    LOCAL  DEFAULT  ABS strtoul.c
  6052: 000884a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6053: 00088668     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6054: 00088670     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6055: 00014030     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6056: 00000000     0 FILE    LOCAL  DEFAULT  ABS vfprintf.c
  6057: 00088698     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6058: 000887c0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6059: 0008892c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6060: 00089a4c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6061: 00089a80     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6062: 0008aeb0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6063: 00110018     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6064: 00110018    16 OBJECT  LOCAL  DEFAULT    6 blanks.7248
  6065: 00110028    16 OBJECT  LOCAL  DEFAULT    6 zeroes.7249
  6066: 00110038     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6067: 000140a0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6068: 00000000     0 FILE    LOCAL  DEFAULT  ABS vfscanf.c
  6069: 0008aeb4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6070: 0008afac     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6071: 0008b198     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6072: 0008b1dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6073: 0008b1ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6074: 0008b2a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6075: 0008b3d8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6076: 0008b704     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6077: 0008b840     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6078: 0008bec4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6079: 0008bedc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6080: 00110050     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6081: 00110050    34 OBJECT  LOCAL  DEFAULT    6 basefix.7195
  6082: 00110074     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6083: 000140f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6084: 00000000     0 FILE    LOCAL  DEFAULT  ABS swab.c
  6085: 0008c508     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6086: 00014164     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6087: 00000000     0 FILE    LOCAL  DEFAULT  ABS telldir.c
  6088: 0008c560     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6089: 0008c5c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6090: 0008c5d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6091: 0008c6f0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6092: 0008c6f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6093: 0008c764     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6094: 00115278     0 NOTYPE  LOCAL  DEFAULT   14 $d
  6095: 00115278     4 OBJECT  LOCAL  DEFAULT   14 dd_loccnt
  6096: 0011c4f8     0 NOTYPE  LOCAL  DEFAULT   15 $d
  6097: 0011c4f8   128 OBJECT  LOCAL  DEFAULT   15 dd_hash
  6098: 00014190     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6099: 00000000     0 FILE    LOCAL  DEFAULT  ABS time.c
  6100: 0008c768     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6101: 00014248     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6102: 00000000     0 FILE    LOCAL  DEFAULT  ABS timelocal.c
  6103: 0008c7ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6104: 0008c7c8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6105: 0008c7d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6106: 0008c808     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6107: 0011007c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6108: 0011007c   252 OBJECT  LOCAL  DEFAULT    6 _C_time_locale
  6109: 00110178     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6110: 0011c578     0 NOTYPE  LOCAL  DEFAULT   15 $d
  6111: 0011c578   252 OBJECT  LOCAL  DEFAULT   15 _time_locale
  6112: 0011c674     4 OBJECT  LOCAL  DEFAULT   15 _time_using_locale
  6113: 0011c678     4 OBJECT  LOCAL  DEFAULT   15 time_locale_buf
  6114: 00014280     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6115: 00000000     0 FILE    LOCAL  DEFAULT  ABS ttyname.c
  6116: 0008c810     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6117: 0008c848     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6118: 0011527c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  6119: 0011527c  1030 OBJECT  LOCAL  DEFAULT   14 ttyname_buf
  6120: 000142c0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6121: 00000000     0 FILE    LOCAL  DEFAULT  ABS ttyname_r.c
  6122: 0008c850     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6123: 0008c978     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6124: 001102c0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6125: 000142f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6126: 00000000     0 FILE    LOCAL  DEFAULT  ABS tzcalc_limits.c
  6127: 0008c97c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6128: 0008cba4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6129: 0001433c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6130: 00000000     0 FILE    LOCAL  DEFAULT  ABS tzlock.c
  6131: 0008cbb4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6132: 00014384     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6133: 00000000     0 FILE    LOCAL  DEFAULT  ABS tzset.c
  6134: 0008cbbc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6135: 000143b4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6136: 00000000     0 FILE    LOCAL  DEFAULT  ABS tzset_r.c
  6137: 0008cbec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6138: 0008d054     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6139: 0008d084     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6140: 001102c8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6141: 0011c67c     0 NOTYPE  LOCAL  DEFAULT   15 $d
  6142: 0011c67c     4 OBJECT  LOCAL  DEFAULT   15 prev_tzenv
  6143: 0011c680    11 OBJECT  LOCAL  DEFAULT   15 __tzname_std
  6144: 0011c68c    11 OBJECT  LOCAL  DEFAULT   15 __tzname_dst
  6145: 000143fc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6146: 00000000     0 FILE    LOCAL  DEFAULT  ABS tzvars.c
  6147: 00115684     0 NOTYPE  LOCAL  DEFAULT   14 $d
  6148: 001102cc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6149: 0011c698     0 NOTYPE  LOCAL  DEFAULT   15 $d
  6150: 00000000     0 FILE    LOCAL  DEFAULT  ABS u_strerr.c
  6151: 0008d0a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6152: 00014478     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6153: 00000000     0 FILE    LOCAL  DEFAULT  ABS ungetc.c
  6154: 0008d0ac     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6155: 0008d2dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6156: 0008d2e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6157: 00014498     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6158: 00000000     0 FILE    LOCAL  DEFAULT  ABS vfprintf.c
  6159: 0008d300     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6160: 0008d470     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6161: 0008d5dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6162: 0008fb70   164 FUNC    LOCAL  DEFAULT    2 __sbprintf
  6163: 0008e768     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6164: 0008e79c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6165: 0008fb44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6166: 0008fb48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6167: 0011031c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6168: 0011031c    16 OBJECT  LOCAL  DEFAULT    6 blanks.7263
  6169: 0011032c    16 OBJECT  LOCAL  DEFAULT    6 zeroes.7264
  6170: 00110038     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6171: 0001453c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6172: 00000000     0 FILE    LOCAL  DEFAULT  ABS vfscanf.c
  6173: 0008fc14     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6174: 0008fd0c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6175: 0008fef8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6176: 0008ff3c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6177: 0008ff4c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6178: 00090000     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6179: 00090138     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6180: 00090464     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6181: 000905a0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6182: 00090c24     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6183: 00090c3c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6184: 0011033c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6185: 0011033c    34 OBJECT  LOCAL  DEFAULT    6 basefix.7214
  6186: 00110074     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6187: 0001460c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6188: 00000000     0 FILE    LOCAL  DEFAULT  ABS vprintf.c
  6189: 00091308     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6190: 000146f0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6191: 00000000     0 FILE    LOCAL  DEFAULT  ABS vsnprintf.c
  6192: 00091350     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6193: 00014740     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6194: 00000000     0 FILE    LOCAL  DEFAULT  ABS wbuf.c
  6195: 00091444     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6196: 000147ac     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6197: 00000000     0 FILE    LOCAL  DEFAULT  ABS wcwidth.c
  6198: 0009158c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6199: 00014808     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6200: 00000000     0 FILE    LOCAL  DEFAULT  ABS wsetup.c
  6201: 000915d4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6202: 00014844     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6203: 00000000     0 FILE    LOCAL  DEFAULT  ABS __atexit.c
  6204: 00091728     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6205: 00091800     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6206: 0011c6a0     0 NOTYPE  LOCAL  DEFAULT   15 $d
  6207: 0011c6a0   400 OBJECT  LOCAL  DEFAULT   15 _global_atexit0
  6208: 00014884     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6209: 00000000     0 FILE    LOCAL  DEFAULT  ABS __call_atexit.c
  6210: 0009180c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6211: 00091954     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6212: 0011c830     0 NOTYPE  LOCAL  DEFAULT   15 $d
  6213: 000148c0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6214: 00000000     0 FILE    LOCAL  DEFAULT  ABS _isatty.c
  6215: 0009195c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6216: 00014908     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6217: 00000000     0 FILE    LOCAL  DEFAULT  ABS asctime.c
  6218: 000919bc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6219: 0001493c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6220: 00000000     0 FILE    LOCAL  DEFAULT  ABS asctime_r.c
  6221: 000919dc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6222: 00091a50     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6223: 00110360     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6224: 00110360    21 OBJECT  LOCAL  DEFAULT    6 day_name.5081
  6225: 00110378    36 OBJECT  LOCAL  DEFAULT    6 mon_name.5082
  6226: 0011039c     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6227: 00014968     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6228: 00000000     0 FILE    LOCAL  DEFAULT  ABS div.c
  6229: 00091a58     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6230: 000149a4     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6231: 00000000     0 FILE    LOCAL  DEFAULT  ABS dtoa.c
  6232: 00091ac0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6233: 00091ac0   472 FUNC    LOCAL  DEFAULT    2 quorem
  6234: 00091f60     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6235: 00091f70     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6236: 000921e0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6237: 00092238     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6238: 001103bc     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6239: 000149e0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6240: 00000000     0 FILE    LOCAL  DEFAULT  ABS environ.c
  6241: 0011568c     0 NOTYPE  LOCAL  DEFAULT   14 $d
  6242: 0011c834     4 OBJECT  LOCAL  DEFAULT   15 initial_env
  6243: 0011c834     0 NOTYPE  LOCAL  DEFAULT   15 $d
  6244: 00000000     0 FILE    LOCAL  DEFAULT  ABS envlock.c
  6245: 00093338     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6246: 00014a8c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6247: 00000000     0 FILE    LOCAL  DEFAULT  ABS flags.c
  6248: 00093340     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6249: 00014abc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6250: 00000000     0 FILE    LOCAL  DEFAULT  ABS gettzinfo.c
  6251: 000933f0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6252: 000933f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6253: 00115690     0 NOTYPE  LOCAL  DEFAULT   14 $d
  6254: 00115690    64 OBJECT  LOCAL  DEFAULT   14 tzinfo
  6255: 00014af0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6256: 00000000     0 FILE    LOCAL  DEFAULT  ABS iswcntrl.c
  6257: 000933fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6258: 0009341c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6259: 00014b10     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6260: 00000000     0 FILE    LOCAL  DEFAULT  ABS iswspace.c
  6261: 00093420     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6262: 00093440     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6263: 00014b30     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6264: 00000000     0 FILE    LOCAL  DEFAULT  ABS ldpart.c
  6265: 00093444     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6266: 00093700     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6267: 001156d0     0 NOTYPE  LOCAL  DEFAULT   14 $d
  6268: 001156d0     2 OBJECT  LOCAL  DEFAULT   14 locale_buf_C.5348
  6269: 00101fc0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6270: 0011c838     0 NOTYPE  LOCAL  DEFAULT   15 $d
  6271: 0011c838     4 OBJECT  LOCAL  DEFAULT   15 num_lines.5349
  6272: 00014b50     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6273: 00000000     0 FILE    LOCAL  DEFAULT  ABS mprec.c
  6274: 00093718     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6275: 00093984     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6276: 00093988     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6277: 00093d88     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6278: 00093d90     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6279: 000940a0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6280: 000940a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6281: 00094390     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6282: 0009439c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6283: 001103d0     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6284: 001103d0    12 OBJECT  LOCAL  DEFAULT    6 p05.5570
  6285: 00014bb0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6286: 00000000     0 FILE    LOCAL  DEFAULT  ABS s_frexp.c
  6287: 0009448c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6288: 0009452c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6289: 00014e9c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6290: 00000000     0 FILE    LOCAL  DEFAULT  ABS sccl.c
  6291: 00094534     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6292: 00014edc     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6293: 00000000     0 FILE    LOCAL  DEFAULT  ABS sf_nan.c
  6294: 00094610     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6295: 00094618     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6296: 00014f18     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6297: 00000000     0 FILE    LOCAL  DEFAULT  ABS siprintf.c
  6298: 0009461c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6299: 00014f38     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6300: 00000000     0 FILE    LOCAL  DEFAULT  ABS siscanf.c
  6301: 000946ec     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6302: 0009475c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6303: 00094760     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6304: 000947dc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6305: 00014fb0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6306: 00000000     0 FILE    LOCAL  DEFAULT  ABS strcat.c
  6307: 000947e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6308: 0009485c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6309: 00015028     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6310: 00000000     0 FILE    LOCAL  DEFAULT  ABS strncasecmp.c
  6311: 00094864     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6312: 000948f4     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6313: 00015054     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6314: 00000000     0 FILE    LOCAL  DEFAULT  ABS strtoull_r.c
  6315: 00095fa8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6316: 00096208     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6317: 00015150     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6318: 00096214     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6319: 00000000     0 FILE    LOCAL  DEFAULT  ABS vfprintf.c
  6320: 00096218     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6321: 000964d8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6322: 00096644     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6323: 000973cc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6324: 000973e0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6325: 00110554     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6326: 00110554    16 OBJECT  LOCAL  DEFAULT    6 blanks.7227
  6327: 00110564    16 OBJECT  LOCAL  DEFAULT    6 zeroes.7228
  6328: 00102054     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6329: 0001519c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6330: 00000000     0 FILE    LOCAL  DEFAULT  ABS vfscanf.c
  6331: 00097670     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6332: 0009799c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6333: 00097b88     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6334: 00097ff0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6335: 00098128     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6336: 00098898     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6337: 000988a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6338: 00110574     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6339: 00110574    34 OBJECT  LOCAL  DEFAULT    6 basefix.6644
  6340: 00015238     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6341: 00000000     0 FILE    LOCAL  DEFAULT  ABS vfprintf.c
  6342: 00098934     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6343: 00098934   172 FUNC    LOCAL  DEFAULT    2 __sprint_r.part.0
  6344: 00098b60     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6345: 00098ccc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6346: 0009a02c   164 FUNC    LOCAL  DEFAULT    2 __sbprintf
  6347: 00099a64     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6348: 00099a7c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6349: 00110598     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6350: 00110598    16 OBJECT  LOCAL  DEFAULT    6 blanks.7241
  6351: 001105a8    16 OBJECT  LOCAL  DEFAULT    6 zeroes.7242
  6352: 00102054     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6353: 00015360     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6354: 00000000     0 FILE    LOCAL  DEFAULT  ABS fputwc.c
  6355: 0009a0d0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6356: 00015474     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6357: 00000000     0 FILE    LOCAL  DEFAULT  ABS gdtoa-gethex.c
  6358: 0009a254     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6359: 0009a254   244 FUNC    LOCAL  DEFAULT    2 rshift
  6360: 0009ab34     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6361: 001105b8     0 NOTYPE  LOCAL  DEFAULT    6 $d
  6362: 00015508     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6363: 00000000     0 FILE    LOCAL  DEFAULT  ABS gdtoa-hexnan.c
  6364: 0009ab38     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6365: 0009ada0     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6366: 000155b0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6367: 00000000     0 FILE    LOCAL  DEFAULT  ABS wcrtomb.c
  6368: 0009ada4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6369: 0009ae34     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6370: 0009ae38     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6371: 0009aecc     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6372: 00015620     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6373: 00000000     0 FILE    LOCAL  DEFAULT  ABS wctomb_r.c
  6374: 0009aed0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6375: 0009af44     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6376: 001156d4     0 NOTYPE  LOCAL  DEFAULT   14 $d
  6377: 00015698     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6378: 00000000     0 FILE    LOCAL  DEFAULT  ABS _udivsi3.o
  6379: 0009af48     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6380: 0009af48     0 NOTYPE  LOCAL  DEFAULT    2 .udivsi3_skip_div0_test
  6381: 000156e8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6382: 00006994     0 NOTYPE  LOCAL  DEFAULT   18 $d
  6383: 00000000     0 FILE    LOCAL  DEFAULT  ABS _divsi3.o
  6384: 0009b05c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6385: 0009b064     0 NOTYPE  LOCAL  DEFAULT    2 .divsi3_skip_div0_test
  6386: 00015708     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6387: 000069b4     0 NOTYPE  LOCAL  DEFAULT   18 $d
  6388: 00000000     0 FILE    LOCAL  DEFAULT  ABS _dvmd_tls.o
  6389: 0009b1a4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6390: 000069d4     0 NOTYPE  LOCAL  DEFAULT   18 $d
  6391: 00000000     0 FILE    LOCAL  DEFAULT  ABS _arm_fixunsdfsi.o
  6392: 0009b1a8     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6393: 000069f4     0 NOTYPE  LOCAL  DEFAULT   18 $d
  6394: 00000000     0 FILE    LOCAL  DEFAULT  ABS _aeabi_ldivmod.o
  6395: 0009b1fc     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6396: 00015728     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6397: 00006a14     0 NOTYPE  LOCAL  DEFAULT   18 $d
  6398: 00000000     0 FILE    LOCAL  DEFAULT  ABS _aeabi_uldivmod.o
  6399: 0009b240     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6400: 00015750     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6401: 00006a34     0 NOTYPE  LOCAL  DEFAULT   18 $d
  6402: 00000000     0 FILE    LOCAL  DEFAULT  ABS bpabi.c
  6403: 0009b27c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6404: 00015778     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6405: 00000000     0 FILE    LOCAL  DEFAULT  ABS libgcc2.c
  6406: 0009b300     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6407: 001106b8     0 NOTYPE  LOCAL  DEFAULT    7 $d
  6408: 000157e0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6409: 00000000     0 FILE    LOCAL  DEFAULT  ABS libgcc2.c
  6410: 0009b478     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6411: 001106c0     0 NOTYPE  LOCAL  DEFAULT    7 $d
  6412: 00015828     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6413: 00000000     0 FILE    LOCAL  DEFAULT  ABS _clzdi2.o
  6414: 0009b598     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6415: 00006ab4     0 NOTYPE  LOCAL  DEFAULT   18 $d
  6416: 00000000     0 FILE    LOCAL  DEFAULT  ABS _clzsi2.o
  6417: 0009b5c0     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6418: 0009b5f8     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6419: 00006ad4     0 NOTYPE  LOCAL  DEFAULT   18 $d
  6420: 00000000     0 FILE    LOCAL  DEFAULT  ABS cache_manager.c
  6421: 0009b608     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6422: 00015868     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6423: 00000000     0 FILE    LOCAL  DEFAULT  ABS _calloc_r.c
  6424: 0009b660     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6425: 00015998     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6426: 00000000     0 FILE    LOCAL  DEFAULT  ABS _free_r.c
  6427: 0009b66c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6428: 000159b8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6429: 00000000     0 FILE    LOCAL  DEFAULT  ABS getdents.c
  6430: 0009b674     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6431: 0009b71c     0 NOTYPE  LOCAL  DEFAULT    2 $d
  6432: 000159d8     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6433: 00000000     0 FILE    LOCAL  DEFAULT  ABS isatty_r.c
  6434: 0009b724     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6435: 00015a0c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6436: 00000000     0 FILE    LOCAL  DEFAULT  ABS kill_noposix.c
  6437: 0009b72c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6438: 00015a2c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6439: 00000000     0 FILE    LOCAL  DEFAULT  ABS _malloc_r.c
  6440: 0009b744     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6441: 00015a6c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6442: 00000000     0 FILE    LOCAL  DEFAULT  ABS _realloc_r.c
  6443: 0009b74c     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6444: 00015a8c     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6445: 00000000     0 FILE    LOCAL  DEFAULT  ABS _rename_r.c
  6446: 0009b758     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6447: 00015aac     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6448: 00000000     0 FILE    LOCAL  DEFAULT  ABS write_r.c
  6449: 0009b7f4     0 NOTYPE  LOCAL  DEFAULT    2 $a
  6450: 00015ae0     0 NOTYPE  LOCAL  DEFAULT   22 $d
  6451: 00000000     0 FILE    LOCAL  DEFAULT  ABS crtstuff.c
  6452: 00110704     0 NOTYPE  LOCAL  DEFAULT    8 $d
  6453: 00110704     0 OBJECT  LOCAL  DEFAULT    8 __FRAME_END__
  6454: 00110710     0 NOTYPE  LOCAL  DEFAULT   11 $d
  6455: 00110710     0 OBJECT  LOCAL  DEFAULT   11 __JCR_END__
  6456: 00000000     0 FILE    LOCAL  DEFAULT  ABS /home/rck/development/rte
  6457: 0009b810     0 NOTYPE  LOCAL  DEFAULT    3 $a
  6458: 0009b828     0 NOTYPE  LOCAL  DEFAULT    4 $a
  6459: 00000000     0 FILE    LOCAL  DEFAULT  ABS
  6460: 00110710     0 NOTYPE  LOCAL  DEFAULT   10 __fini_array_end
  6461: 0011070c     0 NOTYPE  LOCAL  DEFAULT   10 __fini_array_start
  6462: 0011070c     0 NOTYPE  LOCAL  DEFAULT    9 __init_array_end
  6463: 00110708     0 NOTYPE  LOCAL  DEFAULT    9 __preinit_array_end
  6464: 00110708     0 NOTYPE  LOCAL  DEFAULT    9 __init_array_start
  6465: 00110708     0 NOTYPE  LOCAL  DEFAULT    9 __preinit_array_start
  6466: 001109b8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  6467: 001131b8     0 NOTYPE  LOCAL  DEFAULT   14 $d
  6468: 001132b0    64 OBJECT  GLOBAL DEFAULT   14 rtems_filesystem_null_mt_
  6469: 001214a0     4 OBJECT  GLOBAL DEFAULT   15 Microseconds
  6470: 0006db50   140 FUNC    GLOBAL DEFAULT    2 rtems_shell_get_prompt
  6471: 0005d3d0   132 FUNC    GLOBAL DEFAULT    2 sysctl_ctx_entry_del
  6472: 000852a4    24 FUNC    GLOBAL DEFAULT    2 longjmp
  6473: 00053994   532 FUNC    GLOBAL DEFAULT    2 arpresolve
  6474: 00083fa0    32 FUNC    GLOBAL DEFAULT    2 putchar
  6475: 0004eab4  1568 FUNC    GLOBAL DEFAULT    2 __fp_nquery
  6476: 0006fa3c   280 FUNC    GLOBAL DEFAULT    2 ramdisk_ioctl
  6477: 00077c78    12 FUNC    GLOBAL DEFAULT    2 uuid_unparse
  6478: 00094344    88 FUNC    GLOBAL DEFAULT    2 _mprec_log10
  6479: 0006e6d8    80 FUNC    GLOBAL DEFAULT    2 rtems_monitor_object_cano
  6480: 001144ac   468 OBJECT  GLOBAL DEFAULT   14 inetsw
  6481: 0007ee34   132 FUNC    GLOBAL DEFAULT    2 setgrent
  6482: 0004b558     4 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6483: 0006dad4   124 FUNC    GLOBAL DEFAULT    2 rtems_shell_getchar
  6484: 00066030    68 FUNC    GLOBAL DEFAULT    2 _Barrier_Manager_initiali
  6485: 0009440c   128 FUNC    GLOBAL DEFAULT    2 __any_on
  6486: 0009b724     8 FUNC    GLOBAL DEFAULT    2 _isatty_r
  6487: 001104a8    40 OBJECT  GLOBAL DEFAULT    6 __mprec_tinytens
  6488: 0012511c    56 OBJECT  GLOBAL DEFAULT   15 _Region_Information
  6489: 0000f034    24 FUNC    GLOBAL HIDDEN     2 __aeabi_dcmple
  6490: 0006e340    88 FUNC    GLOBAL DEFAULT    2 rtems_monitor_pause_cmd
  6491: 000502c8   276 FUNC    GLOBAL DEFAULT    2 chroot
  6492: 00085cfc   240 FUNC    GLOBAL DEFAULT    2 strcpy
  6493: 000919bc    32 FUNC    GLOBAL DEFAULT    2 asctime
  6494: 00084acc    44 FUNC    GLOBAL DEFAULT    2 cleanup_glue
  6495: 00075580   272 FUNC    GLOBAL DEFAULT    2 rtems_rfs_group_bitmap_te
  6496: 00067178   204 FUNC    GLOBAL DEFAULT    2 rtems_io_unregister_drive
  6497: 0009b2c0    64 FUNC    GLOBAL HIDDEN     2 __gnu_uldivmod_helper
  6498: 0005e0f8   148 FUNC    GLOBAL DEFAULT    2 __sysctl
  6499: 00066588   144 FUNC    GLOBAL DEFAULT    2 rtems_rate_monotonic_rese
  6500: 00027228   120 FUNC    GLOBAL DEFAULT    2 rtems_event_receive
  6501: 00083fc0   148 FUNC    GLOBAL DEFAULT    2 _puts_r
  6502: 0002b3b8   256 FUNC    GLOBAL DEFAULT    2 _Thread_queue_Enqueue
  6503: 00113d48    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_RTRACE_Comman
  6504: 0011f470  8192 OBJECT  GLOBAL DEFAULT   15 file_buffer
  6505: 001214a8     8 OBJECT  GLOBAL DEFAULT   15 T2
  6506: 00045a18   544 FUNC    GLOBAL DEFAULT    2 Untar_FromMemory
  6507: 00084f68    28 FUNC    GLOBAL DEFAULT    2 unsetenv
  6508: 00113f4c     4 OBJECT  GLOBAL DEFAULT   14 h_nerr
  6509: 0000ef48   136 FUNC    GLOBAL HIDDEN     2 __cmpdf2
  6510: 0005ac44     8 FUNC    GLOBAL DEFAULT    2 ip_rsvp_vif_init
  6511: 0000b9bc     8 FUNC    GLOBAL DEFAULT    2 fabs
  6512: 00050dfc     8 FUNC    GLOBAL DEFAULT    2 _lseek_r
  6513: 0012499c     4 OBJECT  GLOBAL DEFAULT   15 ifnet
  6514: 00021d98   240 FUNC    GLOBAL DEFAULT    2 m_freem
  6515: 0000bc60   440 FUNC    GLOBAL DEFAULT    2 log
  6516: 0006eb68    36 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_addr
  6517: 0004d1cc  1220 FUNC    GLOBAL DEFAULT    2 gethostent_r
  6518: 000173e8   104 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_initiali
  6519: 00116934     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_bootp_boot_f
  6520: 0004b55c    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6521: 0002a288   108 FUNC    GLOBAL DEFAULT    2 _RBTree_Find
  6522: 0007f110    16 FUNC    GLOBAL DEFAULT    2 bcmp
  6523: 0009461c   104 FUNC    GLOBAL DEFAULT    2 _siprintf_r
  6524: 001246c8    28 OBJECT  GLOBAL DEFAULT   15 _TOD
  6525: 0000be18   316 FUNC    GLOBAL DEFAULT    2 sqrt
  6526: 001214b0     4 OBJECT  GLOBAL DEFAULT   15 Dhrystones_Per_Second
  6527: 0005aba4     8 FUNC    GLOBAL DEFAULT    2 _ip_mrouter_done
  6528: 00085290    20 FUNC    GLOBAL DEFAULT    2 setjmp
  6529: 00018600    12 FUNC    GLOBAL DEFAULT    2 _stat_r
  6530: 00113684    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_FDISK_Command
  6531: 0002c664     0 NOTYPE  GLOBAL DEFAULT    2 _ARMV4_Exception_reserved
  6532: 0003c1b0   136 FUNC    GLOBAL DEFAULT    2 rtems_shell_alias_cmd
  6533: 0001c5b4    20 FUNC    GLOBAL DEFAULT    2 soconnwakeup
  6534: 0006bea4  1840 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_oldsy
  6535: 000704e8  1048 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_map_grow
  6536: 00113590    68 OBJECT  GLOBAL DEFAULT   14 pru_oldstyle
  6537: 00093340   176 FUNC    GLOBAL DEFAULT    2 __sflags
  6538: 0004b870    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6539: 0006ddc0   116 FUNC    GLOBAL DEFAULT    2 rtems_shell_vwarn
  6540: 0000ef48   136 FUNC    GLOBAL HIDDEN     2 __eqdf2
  6541: 0002a540   148 FUNC    GLOBAL DEFAULT    2 _RBTree_Next
  6542: 00124ff8     8 OBJECT  GLOBAL DEFAULT   15 CPU_usage_Uptime_at_last_
  6543: 000097c0    88 FUNC    GLOBAL DEFAULT    2 Test_task
  6544: 0004b9cc    36 FUNC    GLOBAL DEFAULT    2 device_write
  6545: 00124cd4     2 OBJECT  GLOBAL DEFAULT   15 ip_id
  6546: 0009b300   376 FUNC    GLOBAL HIDDEN     2 __divdi3
  6547: 0010accc   256 OBJECT  GLOBAL DEFAULT    6 a2e_32V
  6548: 0011c10c     4 OBJECT  GLOBAL DEFAULT   15 legal_vif_num
  6549: 00050c80   132 FUNC    GLOBAL DEFAULT    2 ioctl
  6550: 00113c48    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MSDOSFMT_Comm
  6551: 00048ed0    40 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_to_mbr_parti
  6552: 0001bec8   240 FUNC    GLOBAL DEFAULT    2 writev
  6553: 000175f4   108 FUNC    GLOBAL DEFAULT    2 _gettimeofday_r
  6554: 00010cd4    36 FUNC    GLOBAL DEFAULT    2 rtems_stack_checker_begin
  6555: 0004b8d0    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6556: 000374ac   676 FUNC    GLOBAL DEFAULT    2 rtems_shell_main_mv
  6557: 0005d9a8   204 FUNC    GLOBAL DEFAULT    2 sysctl_handle_string
  6558: 0007d884   112 FUNC    GLOBAL DEFAULT    2 rtems_monitor_extension_c
  6559: 0005d380    80 FUNC    GLOBAL DEFAULT    2 sysctl_ctx_entry_find
  6560: 0007adf8   116 FUNC    GLOBAL DEFAULT    2 rtems_assoc_ptr_by_local
  6561: 00113334    44 OBJECT  GLOBAL DEFAULT   14 routedomain
  6562: 001247dc     1 OBJECT  GLOBAL DEFAULT   15 _IO_All_drivers_initializ
  6563: 00124b44   256 OBJECT  GLOBAL DEFAULT   15 ip_protox
  6564: 000082dc   132 OBJECT  GLOBAL DEFAULT    1 arm_cp15_start_mmu_config
  6565: 0006963c   624 FUNC    GLOBAL DEFAULT    2 strmode
  6566: 00087fa4     8 FUNC    GLOBAL DEFAULT    2 strtok_r
  6567: 0005a9f4   240 FUNC    GLOBAL DEFAULT    2 ip_savecontrol
  6568: 0000ea3c    96 FUNC    GLOBAL HIDDEN     2 __floatdidf
  6569: 000739a8  1964 FUNC    GLOBAL DEFAULT    2 rtems_rfs_fs_open
  6570: 0005a870    76 FUNC    GLOBAL DEFAULT    2 ip_drain
  6571: 0002b69c    60 FUNC    GLOBAL DEFAULT    2 _Thread_queue_Timeout
  6572: 00018d28    28 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  6573: 0002759c   120 FUNC    GLOBAL DEFAULT    2 _Event_Timeout
  6574: 0004ddd4   152 FUNC    GLOBAL DEFAULT    2 __res_hnok
  6575: 00050aec    16 FUNC    GLOBAL DEFAULT    2 getgid
  6576: 0009b734     8 FUNC    GLOBAL DEFAULT    2 _kill_r
  6577: 0006f078   160 FUNC    GLOBAL DEFAULT    2 rtems_monitor_sema_dump
  6578: 0005db94   180 FUNC    GLOBAL DEFAULT    2 sysctl_find_oid
  6579: 001249ac     4 OBJECT  GLOBAL DEFAULT   15 zeroin_addr
  6580: 0007c7f4   152 FUNC    GLOBAL DEFAULT    2 rtems_signal_catch
  6581: 000288f0   348 FUNC    GLOBAL DEFAULT    2 _CORE_mutex_Initialize
  6582: 00010250   484 FUNC    GLOBAL DEFAULT    2 rtems_interrupt_handler_r
  6583: 00083e08    56 FUNC    GLOBAL DEFAULT    2 printf
  6584: 0001b7e8   104 FUNC    GLOBAL DEFAULT    2 rtems_termios_dequeue_cha
  6585: 00110838     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_data_load_beg
  6586: 0002b928   180 FUNC    GLOBAL DEFAULT    2 _Thread_Kill_zombies
  6587: 0006f730   300 FUNC    GLOBAL DEFAULT    2 rtems_monitor_symbol_cmd
  6588: 0003ffc8  2024 FUNC    GLOBAL DEFAULT    2 strsvisx
  6589: 0006074c   300 FUNC    GLOBAL DEFAULT    2 rtfree
  6590: 0009ada4   148 FUNC    GLOBAL DEFAULT    2 _wcrtomb_r
  6591: 000526e8   108 FUNC    GLOBAL DEFAULT    2 utime
  6592: 00018f00   128 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_do_unmou
  6593: 00001040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_und_end
  6594: 00100048    24 OBJECT  GLOBAL DEFAULT    6 _Thread_Control_add_ons
  6595: 00077c84    20 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6596: 0002c700   180 FUNC    GLOBAL DEFAULT    2 _CPU_Context_Initialize
  6597: 00060440     4 FUNC    GLOBAL DEFAULT    2 raw_ctlinput
  6598: 0000fa10     8 FUNC    GLOBAL DEFAULT    2 console_control
  6599: 0007db3c   104 FUNC    GLOBAL DEFAULT    2 rtems_monitor_init_task_n
  6600: 00119018     4 OBJECT  WEAK   DEFAULT   15 __rtld_tbg_mode
  6601: 00110838     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_fast_data_loa
  6602: 00049374    68 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_register_fro
  6603: 00114900     4 OBJECT  GLOBAL DEFAULT   14 ip_defttl
  6604: 000146f4    24 FUNC    GLOBAL DEFAULT    2 sethostent
  6605: 000858a4    84 FUNC    GLOBAL DEFAULT    2 __sseek
  6606: 00053ba8  1312 FUNC    GLOBAL DEFAULT    2 arpintr
  6607: 0007fba4    16 FUNC    GLOBAL DEFAULT    2 __sinit
  6608: 00057324   152 FUNC    GLOBAL DEFAULT    2 in_delmulti
  6609: 00091444   296 FUNC    GLOBAL DEFAULT    2 __swbuf_r
  6610: 0011c69c     4 OBJECT  GLOBAL DEFAULT   15 _daylight
  6611: 0008c7d0    64 FUNC    GLOBAL DEFAULT    2 __time_load_locale
  6612: 000272a0   392 FUNC    GLOBAL DEFAULT    2 _Event_Seize
  6613: 000574e8   204 FUNC    GLOBAL DEFAULT    2 in_pcballoc
  6614: 0004dd48    32 FUNC    GLOBAL DEFAULT    2 recv
  6615: 0004dd68    56 FUNC    GLOBAL DEFAULT    2 __dn_expand
  6616: 0001c284    64 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_semaphore_re
  6617: 0001dcbc   360 FUNC    GLOBAL DEFAULT    2 connect
  6618: 00116370     8 OBJECT  GLOBAL DEFAULT   15 dev
  6619: 00082b74   124 FUNC    GLOBAL DEFAULT    2 _setlocale_r
  6620: 0009b618     8 FUNC    GLOBAL DEFAULT    2 rtems_cache_get_data_line
  6621: 00024710     8 FUNC    GLOBAL DEFAULT    2 pru_listen_notsupp
  6622: 001001fc   252 OBJECT  GLOBAL DEFAULT    6 rtems_shell_Initial_comma
  6623: 0007fa48    76 FUNC    GLOBAL DEFAULT    2 __sfmoreglue
  6624: 0008d2e0    32 FUNC    GLOBAL DEFAULT    2 ungetc
  6625: 0002c564     0 NOTYPE  GLOBAL DEFAULT    2 _ARMV4_Exception_interrup
  6626: 00108574    48 OBJECT  GLOBAL DEFAULT    6 IMFS_LIMITS_AND_OPTIONS
  6627: 0008d084    32 FUNC    GLOBAL DEFAULT    2 _tzset_r
  6628: 0001778c    64 FUNC    GLOBAL DEFAULT    2 rtems_libio_to_fcntl_flag
  6629: 00042ad8   680 FUNC    GLOBAL DEFAULT    2 rtems_nvdisk_initialize
  6630: 0005f290  1056 FUNC    GLOBAL DEFAULT    2 rn_delete
  6631: 000192a0   124 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_location
  6632: 0002c634     0 NOTYPE  GLOBAL DEFAULT    2 _ARMV4_Exception_swi_defa
  6633: 00100100     4 OBJECT  GLOBAL DEFAULT    6 _IO_Number_of_drivers
  6634: 0011083c     4 OBJECT  GLOBAL DEFAULT   14 _RTEMS_tasks_Initialize_u
  6635: 0002c624     0 NOTYPE  GLOBAL DEFAULT    2 _ARMV4_Exception_undef_de
  6636: 00045510    44 FUNC    GLOBAL DEFAULT    2 rtems_rfs_trace_set_mask
  6637: 00043b18   636 FUNC    GLOBAL DEFAULT    2 rtems_rfs_rtems_initialis
  6638: 00065ff4    52 FUNC    GLOBAL DEFAULT    2 sigemptyset
  6639: 0005ac4c     8 FUNC    GLOBAL DEFAULT    2 ip_rsvp_vif_done
  6640: 00116368     4 OBJECT  GLOBAL DEFAULT   15 rtems_telnetd_maximum_pty
  6641: 000948f8  5692 FUNC    GLOBAL DEFAULT    2 _strtod_r
  6642: 00114970     4 OBJECT  GLOBAL DEFAULT   14 ip_mrouter_set
  6643: 00026960   200 FUNC    GLOBAL DEFAULT    2 pthread_getspecific
  6644: 0001787c    44 FUNC    GLOBAL DEFAULT    2 malloc_is_system_state_OK
  6645: 0000f5bc   352 FUNC    GLOBAL HIDDEN     2 __divsf3
  6646: 00054a3c    72 FUNC    GLOBAL DEFAULT    2 ether_crc32_le
  6647: 0002bf58    16 FUNC    GLOBAL DEFAULT    2 _User_extensions_Thread_e
  6648: 0007d8f4    40 FUNC    GLOBAL DEFAULT    2 rtems_monitor_extension_d
  6649: 00086488    32 FUNC    GLOBAL DEFAULT    2 strerror
  6650: 00009a84    52 FUNC    GLOBAL DEFAULT    2 Proc_3
  6651: 00124c44     4 OBJECT  GLOBAL DEFAULT   15 ip_nat_ptr
  6652: 00078678   696 FUNC    GLOBAL DEFAULT    2 __ns_name_pack
  6653: 0012441c     4 OBJECT  GLOBAL DEFAULT   15 max_protohdr
  6654: 00024700     8 FUNC    GLOBAL DEFAULT    2 pru_connect2_notsupp
  6655: 00124d88     4 OBJECT  GLOBAL DEFAULT   15 tcb
  6656: 00050fb4    52 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_get_moun
  6657: 0007f0f8    24 FUNC    GLOBAL DEFAULT    2 _atol_r
  6658: 00113724     8 OBJECT  GLOBAL DEFAULT   14 rtems_shell_CD_Alias
  6659: 0001c5e0   228 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_newproc
  6660: 00017570    16 FUNC    GLOBAL DEFAULT    2 geteuid
  6661: 001214b4     4 OBJECT  GLOBAL DEFAULT   15 User_Time
  6662: 0001c8a0   112 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_rtrequest
  6663: 00014c34   564 FUNC    GLOBAL DEFAULT    2 inet_pton
  6664: 00066334    68 FUNC    GLOBAL DEFAULT    2 _Rate_monotonic_Manager_i
  6665: 0010abcc   256 OBJECT  GLOBAL DEFAULT    6 a2ibm_32V
  6666: 0007bc48   240 FUNC    GLOBAL DEFAULT    2 igmp_fasttimo
  6667: 00028838    44 FUNC    GLOBAL DEFAULT    2 _Chain_Append
  6668: 00113240     4 OBJECT  GLOBAL DEFAULT   14 rtems_termios_nlinesw
  6669: 00049f68   260 FUNC    GLOBAL DEFAULT    2 rtems_blkdev_create_parti
  6670: 000178cc    16 FUNC    GLOBAL DEFAULT    2 malloc_deferred_free
  6671: 0007c93c    84 FUNC    GLOBAL DEFAULT    2 _Heap_Iterate
  6672: 000090a4   228 FUNC    GLOBAL DEFAULT    2 Init
  6673: 0004588c    40 FUNC    GLOBAL DEFAULT    2 rtems_trace_trigger_set
  6674: 00045958    60 FUNC    GLOBAL DEFAULT    2 rtems_trace_buffering_sta
  6675: 0004f18c    36 FUNC    GLOBAL DEFAULT    2 __p_section
  6676: 0003b0e4  1140 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_printcol
  6677: 00124d8c   240 OBJECT  GLOBAL DEFAULT   15 tcpstat
  6678: 00043ae8    48 FUNC    GLOBAL DEFAULT    2 rtems_rfs_rtems_fdatasync
  6679: 000977d0   216 FUNC    GLOBAL DEFAULT    2 _sfread_r
  6680: 00110838     0 NOTYPE  GLOBAL DEFAULT   14 bsp_section_data_begin
  6681: 00012da4   100 FUNC    GLOBAL DEFAULT    2 IMFS_stat
  6682: 00063e28   108 FUNC    GLOBAL DEFAULT    2 tcp_setpersist
  6683: 0004bcc4     8 FUNC    GLOBAL DEFAULT    2 IMFS_node_initialize_gene
  6684: 000407b0  1464 FUNC    GLOBAL DEFAULT    2 vis
  6685: 000177cc    96 FUNC    GLOBAL DEFAULT    2 rtems_libio_allocate
  6686: 0008326c   300 FUNC    GLOBAL DEFAULT    2 memmove
  6687: 0006f314   252 FUNC    GLOBAL DEFAULT    2 rtems_symbol_value_lookup
  6688: 0005ac58  3792 FUNC    GLOBAL DEFAULT    2 ip_output
  6689: 001214b8     4 OBJECT  GLOBAL DEFAULT   15 Begin_Time
  6690: 00001440     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_abt_end
  6691: 0001923c   100 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_location
  6692: 00082338   132 FUNC    GLOBAL DEFAULT    2 getopt_long
  6693: 0007fb80    36 FUNC    GLOBAL DEFAULT    2 _cleanup
  6694: 00011f84    12 FUNC    GLOBAL DEFAULT    2 IMFS_node_destroy
  6695: 0000b40c    36 FUNC    GLOBAL DEFAULT    2 POUT
  6696: 00085544   224 FUNC    GLOBAL DEFAULT    2 snprintf
  6697: 00054ae8   192 FUNC    GLOBAL DEFAULT    2 ether_ioctl
  6698: 00114e9c    64 OBJECT  GLOBAL DEFAULT   14 _res_opcodes
  6699: 00100060     4 OBJECT  GLOBAL DEFAULT    6 _Thread_Control_size
  6700: 00040fb8     8 FUNC    GLOBAL DEFAULT    2 rtems_string_to_pointer
  6701: 00110708     0 NOTYPE  GLOBAL DEFAULT    9 _TLS_Data_begin
  6702: 00113a08    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_LSOF_Command
  6703: 00110708     0 NOTYPE  GLOBAL DEFAULT    9 _TLS_BSS_end
  6704: 0007e4dc    80 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_open
  6705: 00093718   144 FUNC    GLOBAL DEFAULT    2 _Balloc
  6706: 0004dda4    48 FUNC    GLOBAL DEFAULT    2 __dn_skipname
  6707: 0006e1a8    56 FUNC    GLOBAL DEFAULT    2 rtems_monitor_command_loo
  6708: 001106c0     0 NOTYPE  GLOBAL DEFAULT    7 __exidx_end
  6709: 0004b574     8 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6710: 00087ee4   192 FUNC    GLOBAL DEFAULT    2 __strtok_r
  6711: 0004b8b8    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6712: 000486f4   580 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_create
  6713: 0001782c    80 FUNC    GLOBAL DEFAULT    2 rtems_libio_free
  6714: 00051f60    64 FUNC    GLOBAL DEFAULT    2 rtems_heap_allocate_align
  6715: 00067dc0    96 FUNC    GLOBAL DEFAULT    2 _User_extensions_Add_set
  6716: 0010a8cc   256 OBJECT  GLOBAL DEFAULT    6 a2ibm_POSIX
  6717: 00067984    28 FUNC    GLOBAL DEFAULT    2 _Objects_API_maximum_clas
  6718: 0002c068    72 FUNC    GLOBAL DEFAULT    2 _User_extensions_Handler_
  6719: 001131b8     0 NOTYPE  GLOBAL DEFAULT   14 _binary_tarfile_end
  6720: 000545c0    72 FUNC    GLOBAL DEFAULT    2 ether_sprintf
  6721: 0001931c   100 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  6722: 001243a0     4 OBJECT  GLOBAL DEFAULT   15 nfs_diskless_valid
  6723: 000758a8   256 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_open
  6724: 00067d4c   116 FUNC    GLOBAL DEFAULT    2 _Timespec_To_ticks
  6725: 00119008     1 OBJECT  WEAK   DEFAULT   15 __rtld_tbg_triggered
  6726: 00010aec    76 FUNC    GLOBAL DEFAULT    2 rtems_blkdev_generic_ioct
  6727: 00017ab8    92 FUNC    GLOBAL DEFAULT    2 mknod
  6728: 0009b60c     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_invalidate_mu
  6729: 00052354    60 FUNC    GLOBAL DEFAULT    2 rtems_deviceio_control
  6730: 0000ef38   152 FUNC    GLOBAL HIDDEN     2 __gtdf2
  6731: 0007f0e0    24 FUNC    GLOBAL DEFAULT    2 atol
  6732: 001248cc     4 OBJECT  GLOBAL DEFAULT   15 _dns_ttl_
  6733: 0007f20c    16 FUNC    GLOBAL DEFAULT    2 __errno
  6734: 0002b048     4 FUNC    GLOBAL DEFAULT    2 _Thread_Priority_change_d
  6735: 0004e628   144 FUNC    GLOBAL DEFAULT    2 __p_fqnname
  6736: 00041404  4136 FUNC    GLOBAL DEFAULT    2 msdos_format
  6737: 00011648    80 FUNC    GLOBAL DEFAULT    2 rtems_disk_release
  6738: 00028258   192 FUNC    GLOBAL DEFAULT    2 rtems_task_wake_after
  6739: 0009b658     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_enable_instru
  6740: 00075c58   364 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_initialis
  6741: 00040fc0   196 FUNC    GLOBAL DEFAULT    2 rtems_string_to_unsigned_
  6742: 00108520    60 OBJECT  GLOBAL DEFAULT    6 rtems_filesystem_handlers
  6743: 000283d8    68 FUNC    GLOBAL DEFAULT    2 _Extension_Manager_initia
  6744: 00050b34    56 FUNC    GLOBAL DEFAULT    2 getgrgid
  6745: 001249b4     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_inet_children
  6746: 00016260    16 FUNC    GLOBAL DEFAULT    2 __res_send_setqhook
  6747: 00009c34    16 FUNC    GLOBAL DEFAULT    2 Proc_7
  6748: 0007be38     4 FUNC    GLOBAL DEFAULT    2 raw_disconnect
  6749: 00113c68    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MV_Command
  6750: 00029c0c   136 FUNC    GLOBAL DEFAULT    2 _Objects_Name_to_id_u32
  6751: 00124c48     4 OBJECT  GLOBAL DEFAULT   15 ip_fw_ctl_ptr
  6752: 000095fc   244 FUNC    GLOBAL DEFAULT    2 ReadTestCmd
  6753: 001109b8     0 NOTYPE  GLOBAL DEFAULT   14 _binary_tarfile_start
  6754: 0003efec   176 FUNC    GLOBAL DEFAULT    2 safe_print
  6755: 000458b4    16 FUNC    GLOBAL DEFAULT    2 rtems_trace_buffering_pre
  6756: 00018ea4    92 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_location
  6757: 000751d4   144 FUNC    GLOBAL DEFAULT    2 rtems_rfs_group_close
  6758: 0011376c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_CHROOT_Comman
  6759: 00110984     4 OBJECT  GLOBAL DEFAULT   14 RTEMS_Malloc_Heap
  6760: 000817d8    40 FUNC    GLOBAL DEFAULT    2 getenv
  6761: 000933fc    36 FUNC    GLOBAL DEFAULT    2 iswcntrl
  6762: 00119014     4 OBJECT  WEAK   DEFAULT   15 __rtld_tbg_buffer_size
  6763: 001001f0     4 OBJECT  GLOBAL DEFAULT    6 rtems_libio_exit_helper
  6764: 00125154    56 OBJECT  GLOBAL DEFAULT   15 _Timer_Information
  6765: 00050730   144 FUNC    GLOBAL DEFAULT    2 fchmod
  6766: 0000ff9c   692 FUNC    GLOBAL DEFAULT    2 rtems_interrupt_handler_i
  6767: 0004a1dc    92 FUNC    GLOBAL DEFAULT    2 rtems_blkdev_print_stats
  6768: 00028734   108 FUNC    GLOBAL DEFAULT    2 _API_Mutex_Allocate
  6769: 0011393c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_HELP_Command
  6770: 00102974    75 OBJECT  GLOBAL DEFAULT    6 _Copyright_Notice
  6771: 00050a0c    12 FUNC    GLOBAL DEFAULT    2 _fstat_r
  6772: 00011d54   100 FUNC    GLOBAL DEFAULT    2 IMFS_initialize
  6773: 00124398     4 OBJECT  GLOBAL DEFAULT   15 rtems_termios_ttyMutex
  6774: 00060444   508 FUNC    GLOBAL DEFAULT    2 raw_usrreq
  6775: 0002b9dc   284 FUNC    GLOBAL DEFAULT    2 _Thread_Life_action_handl
  6776: 0005d93c   108 FUNC    GLOBAL DEFAULT    2 sysctl_handle_long
  6777: 00084e98    24 FUNC    GLOBAL DEFAULT    2 __srget
  6778: 000183b0    60 FUNC    GLOBAL DEFAULT    2 rtems_libio_use_global_en
  6779: 0000e2a8   416 FUNC    GLOBAL DEFAULT    2 floor
  6780: 000578f4   276 FUNC    GLOBAL DEFAULT    2 in_pcbnotify
  6781: 000912a8    40 FUNC    GLOBAL DEFAULT    2 __svfscanf
  6782: 00085834     8 FUNC    GLOBAL DEFAULT    2 __seofread
  6783: 001249a0     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_link_generic_
  6784: 0007247c   876 FUNC    GLOBAL DEFAULT    2 rtems_rfs_dir_read
  6785: 00017560    16 FUNC    GLOBAL DEFAULT    2 getegid
  6786: 00037f6c  2420 FUNC    GLOBAL DEFAULT    2 rtems_shell_main_rm
  6787: 0001f910   116 FUNC    GLOBAL DEFAULT    2 rt_missmsg
  6788: 0004dbb0    64 FUNC    GLOBAL DEFAULT    2 _map_v4v6_address
  6789: 0000fb60   312 FUNC    GLOBAL DEFAULT    2 console_open
  6790: 00023eec   772 FUNC    GLOBAL DEFAULT    2 sbdrop
  6791: 0007bf1c   268 FUNC    GLOBAL DEFAULT    2 rtems_rate_monotonic_get_
  6792: 00028e8c    24 FUNC    GLOBAL DEFAULT    2 _Freechain_Put
  6793: 0005e454   552 FUNC    GLOBAL DEFAULT    2 rn_match
  6794: 00078c0c   504 FUNC    GLOBAL DEFAULT    2 __ns_parserr
  6795: 0011382c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_DATE_Command
  6796: 00001040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_fiq_begin
  6797: 0000efec    24 FUNC    GLOBAL HIDDEN     2 __aeabi_cdcmple
  6798: 000672bc   200 FUNC    GLOBAL DEFAULT    2 _TOD_Set_with_timestamp
  6799: 00025048  3600 FUNC    GLOBAL DEFAULT    2 soreceive
  6800: 0004bccc   272 FUNC    GLOBAL DEFAULT    2 IMFS_make_generic_node
  6801: 00016270    16 FUNC    GLOBAL DEFAULT    2 __res_send_setrhook
  6802: 00011698   212 FUNC    GLOBAL DEFAULT    2 rtems_disk_next
  6803: 00101884    20 OBJECT  GLOBAL DEFAULT    6 IMFS_mknod_control_enosys
  6804: 0007d47c    72 FUNC    GLOBAL DEFAULT    2 rtems_monitor_config_next
  6805: 00054f74   500 FUNC    GLOBAL DEFAULT    2 if_attach
  6806: 0007f120   132 FUNC    GLOBAL DEFAULT    2 bsearch
  6807: 0000f904     4 FUNC    GLOBAL DEFAULT    2 bsp_reset
  6808: 0004a484    16 FUNC    GLOBAL DEFAULT    2 rtems_cpu_usage_report
  6809: 000298b8   108 FUNC    GLOBAL DEFAULT    2 _Objects_Get_isr_disable
  6810: 00052390    92 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_location
  6811: 0004de6c    52 FUNC    GLOBAL DEFAULT    2 __res_ownok
  6812: 000218fc   108 FUNC    GLOBAL DEFAULT    2 m_reclaim
  6813: 0002b554   188 FUNC    GLOBAL DEFAULT    2 _Thread_queue_Dequeue
  6814: 0000f184   444 FUNC    GLOBAL HIDDEN     2 __aeabi_fadd
  6815: 000690f4   184 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_unblock_cl
  6816: 00012fbc    44 FUNC    GLOBAL DEFAULT    2 rtems_io_register_name
  6817: 0000a4d0   364 FUNC    GLOBAL DEFAULT    2 PA
  6818: 0011380c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_CPUUSE_Comman
  6819: 0007bbec    92 FUNC    GLOBAL DEFAULT    2 igmp_leavegroup
  6820: 0000f180   448 FUNC    GLOBAL HIDDEN     2 __subsf3
  6821: 0003bfa8    72 FUNC    GLOBAL DEFAULT    2 rtems_shell_lookup_cmd
  6822: 00078380   472 FUNC    GLOBAL DEFAULT    2 __ns_name_pton
  6823: 00124420     4 OBJECT  GLOBAL DEFAULT   15 mclfree
  6824: 0000f900     4 FUNC    GLOBAL DEFAULT    2 bsp_pretasking_hook
  6825: 0004b790     8 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6826: 00067b0c    20 FUNC    GLOBAL DEFAULT    2 _Thread_queue_Extract_wit
  6827: 0000f93c    44 FUNC    GLOBAL DEFAULT    2 Clock_exit
  6828: 00068198    80 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_sizecmp
  6829: 00017580     8 FUNC    GLOBAL DEFAULT    2 getpid
  6830: 0009b634     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_disable_data
  6831: 0007e5e4   464 FUNC    GLOBAL DEFAULT    2 rtems_rfs_dir_hash
  6832: 00114164     6 OBJECT  GLOBAL DEFAULT   14 ether_ipmulticast_min
  6833: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_fast_text_siz
  6834: 0002c508    28 FUNC    GLOBAL DEFAULT    2 _Workspace_Allocate_align
  6835: 0008406c  2320 FUNC    GLOBAL DEFAULT    2 qsort
  6836: 0002a5e0    16 FUNC    GLOBAL DEFAULT    2 _Scheduler_default_Start_
  6837: 00065390   532 FUNC    GLOBAL DEFAULT    2 tcp_close
  6838: 0006ed80   116 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_notepa
  6839: 0006aed8   212 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_peek
  6840: 0005089c   152 FUNC    GLOBAL DEFAULT    2 fchown
  6841: 0006ff1c   100 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_get_block
  6842: 0007f854    40 FUNC    GLOBAL DEFAULT    2 fgets
  6843: 00021890   108 FUNC    GLOBAL DEFAULT    2 pfctlinput
  6844: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS HeapSize
  6845: 00009988    36 FUNC    GLOBAL DEFAULT    2 hello_command
  6846: 00026ac0   140 FUNC    GLOBAL DEFAULT    2 _POSIX_Key_Manager_initia
  6847: 0011378c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_CMDCHMOD_Comm
  6848: 00008360     0 NOTYPE  GLOBAL DEFAULT    1 bsp_section_start_end
  6849: 00102018    60 OBJECT  GLOBAL DEFAULT    6 rtems_filesystem_null_han
  6850: 00068f30   112 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_block_clos
  6851: 0007e0bc   160 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_map_clea
  6852: 001249b0     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_inet_ip_portr
  6853: 0001da30   156 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_fdToSocket
  6854: 00056964  2496 FUNC    GLOBAL DEFAULT    2 in_control
  6855: 0004b9f0    36 FUNC    GLOBAL DEFAULT    2 device_ioctl
  6856: 00124424   540 OBJECT  GLOBAL DEFAULT   15 mbstat
  6857: 0006e638   160 FUNC    GLOBAL DEFAULT    2 rtems_monitor_object_cano
  6858: 0000c920  1608 FUNC    GLOBAL DEFAULT    2 __ieee754_rem_pio2
  6859: 0007ebcc   276 FUNC    GLOBAL DEFAULT    2 inet_nsap_addr
  6860: 00114e4c    16 OBJECT  GLOBAL DEFAULT   14 _res_sectioncodes
  6861: 00049288   236 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_register
  6862: 00066e54    64 FUNC    GLOBAL DEFAULT    2 rtems_io_initialize
  6863: 0007ae80   280 FUNC    GLOBAL DEFAULT    2 fchdir
  6864: 0004b5cc    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6865: 00083f8c    20 FUNC    GLOBAL DEFAULT    2 _putchar_r
  6866: 00012d18    92 FUNC    GLOBAL DEFAULT    2 IMFS_rmnod
  6867: 00066260    68 FUNC    GLOBAL DEFAULT    2 _Dual_ported_memory_Manag
  6868: 000500c8    20 FUNC    GLOBAL DEFAULT    2 rtems_assoc_local_by_remo
  6869: 00029318   116 FUNC    GLOBAL DEFAULT    2 rtems_iterate_over_all_th
  6870: 00114480    44 OBJECT  GLOBAL DEFAULT   14 inetdomain
  6871: 0008317c   240 FUNC    GLOBAL DEFAULT    2 memcpy
  6872: 0007e15c   124 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_map_test
  6873: 00028a4c   220 FUNC    GLOBAL DEFAULT    2 _CORE_mutex_Seize_interru
  6874: 001214bc     4 OBJECT  GLOBAL DEFAULT   15 K
  6875: 0009ab38   620 FUNC    GLOBAL DEFAULT    2 __hexnan
  6876: 0001d470   236 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_parse_driver
  6877: 0005ffa0   740 FUNC    GLOBAL DEFAULT    2 rip_usrreq
  6878: 0001b0e0   928 FUNC    GLOBAL DEFAULT    2 rtems_termios_read
  6879: 0000efd0    52 FUNC    GLOBAL HIDDEN     2 __aeabi_cdrcmple
  6880: 001248c4     4 OBJECT  GLOBAL DEFAULT   15 rtems_shell_first_cmd
  6881: 000563f4   164 FUNC    GLOBAL DEFAULT    2 in_broadcast
  6882: 0006f600    80 FUNC    GLOBAL DEFAULT    2 rtems_monitor_symbol_cano
  6883: 0002ae74    56 FUNC    GLOBAL DEFAULT    2 _Thread_Dispatch
  6884: 0006dcfc   128 FUNC    GLOBAL DEFAULT    2 rtems_shell_verr
  6885: 00066d6c    24 FUNC    GLOBAL DEFAULT    2 rtems_debug_enable
  6886: 000852bc   360 FUNC    GLOBAL DEFAULT    2 setvbuf
  6887: 00048e90    64 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_to_partition
  6888: 00000000     0 OBJECT  GLOBAL HIDDEN    26 __TMC_END__
  6889: 00070da8   552 FUNC    GLOBAL DEFAULT    2 rtems_rfs_buffer_handle_r
  6890: 0002bf88    16 FUNC    GLOBAL DEFAULT    2 _User_extensions_Thread_t
  6891: 001248dc     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_link_ether_ch
  6892: 00110708     0 NOTYPE  GLOBAL DEFAULT    9 _TLS_BSS_begin
  6893: 0000f818    24 FUNC    GLOBAL HIDDEN     2 __aeabi_fcmpgt
  6894: 0007add0    40 FUNC    GLOBAL DEFAULT    2 rtems_assoc_name_by_local
  6895: 00052274   112 FUNC    GLOBAL DEFAULT    2 rtems_deviceio_read
  6896: 0007f8e4    24 FUNC    GLOBAL DEFAULT    2 _cleanup_r
  6897: 0011c100     4 OBJECT  GLOBAL DEFAULT   15 rsvp_on
  6898: 0004ba1c   128 FUNC    GLOBAL DEFAULT    2 rtems_disk_init_phys
  6899: 00088698 10268 FUNC    GLOBAL DEFAULT    2 _svfprintf_r
  6900: 0006e508   108 FUNC    GLOBAL DEFAULT    2 rtems_monitor_insert_cmd
  6901: 0000e9c0    40 FUNC    GLOBAL HIDDEN     2 __floatsidf
  6902: 00113b28   128 OBJECT  GLOBAL DEFAULT   14 formats
  6903: 00045e60    60 FUNC    GLOBAL DEFAULT    2 _rtems_tar_header_checksu
  6904: 000237fc    60 FUNC    GLOBAL DEFAULT    2 socantrcvmore
  6905: 00071508   248 FUNC    GLOBAL DEFAULT    2 rtems_rfs_buffer_setblksi
  6906: 00067290    44 FUNC    GLOBAL DEFAULT    2 _TOD_Get_uptime_as_timesp
  6907: 00083dbc    24 FUNC    GLOBAL DEFAULT    2 perror
  6908: 001246e4    16 OBJECT  GLOBAL DEFAULT   15 _Objects_Information_tabl
  6909: 0006eb10    52 FUNC    GLOBAL DEFAULT    2 rtems_monitor_pad
  6910: 0005d2cc    60 FUNC    GLOBAL DEFAULT    2 sysctl_unregister_oid
  6911: 00005040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_section_vector_end
  6912: 00119028     4 OBJECT  WEAK   DEFAULT   15 __rtld_trace_triggers
  6913: 0000ef40   144 FUNC    GLOBAL HIDDEN     2 __ltdf2
  6914: 0002aa54   100 FUNC    GLOBAL DEFAULT    2 _Scheduler_priority_Updat
  6915: 0008c508    88 FUNC    GLOBAL DEFAULT    2 swab
  6916: 0000fa94   204 FUNC    GLOBAL DEFAULT    2 console_register_devices
  6917: 00018244    52 FUNC    GLOBAL DEFAULT    2 rtems_libio_free_user_env
  6918: 0007f1dc    28 FUNC    GLOBAL DEFAULT    2 creat
  6919: 00051934   148 FUNC    GLOBAL DEFAULT    2 readlink
  6920: 00124e80    32 OBJECT  GLOBAL DEFAULT   15 tcbinfo
  6921: 000677cc   308 FUNC    GLOBAL DEFAULT    2 _Heap_Resize_block
  6922: 000851c8   200 FUNC    GLOBAL DEFAULT    2 _unsetenv_r
  6923: 0009b240     0 FUNC    GLOBAL HIDDEN     2 __aeabi_uldivmod
  6924: 0002bf48    16 FUNC    GLOBAL DEFAULT    2 _User_extensions_Thread_b
  6925: 00084054    24 FUNC    GLOBAL DEFAULT    2 puts
  6926: 00065d0c   232 FUNC    GLOBAL DEFAULT    2 clock_settime
  6927: 0006f5c4    60 FUNC    GLOBAL DEFAULT    2 rtems_monitor_symbol_cano
  6928: 0011328c    36 OBJECT  GLOBAL DEFAULT   14 rtems_filesystem_global_l
  6929: 0006f004    92 FUNC    GLOBAL DEFAULT    2 rtems_monitor_sema_canoni
  6930: 0007e570   116 FUNC    GLOBAL DEFAULT    2 rtems_rfs_buffer_bdbuf_re
  6931: 0002a5d8     4 FUNC    GLOBAL DEFAULT    2 _Scheduler_default_Node_i
  6932: 00071284   392 FUNC    GLOBAL DEFAULT    2 rtems_rfs_buffer_open
  6933: 00100000    68 OBJECT  GLOBAL DEFAULT    6 Configuration
  6934: 00119030     4 OBJECT  WEAK   DEFAULT   15 __rtld_trace_enables
  6935: 0002848c    24 FUNC    GLOBAL DEFAULT    2 _POSIX_Fatal_error
  6936: 00024800    52 FUNC    GLOBAL DEFAULT    2 soaccept
  6937: 00082e74   160 FUNC    GLOBAL DEFAULT    2 mbrtowc
  6938: 0005864c    80 FUNC    GLOBAL DEFAULT    2 in_rtqdrain
  6939: 00067ab8    84 FUNC    GLOBAL DEFAULT    2 _Thread_Load_environment
  6940: 00085e48  1600 FUNC    GLOBAL DEFAULT    2 _strerror_r
  6941: 00021a18   180 FUNC    GLOBAL DEFAULT    2 m_retryhdr
  6942: 00012fe8   100 FUNC    GLOBAL DEFAULT    2 rtems_io_lookup_name
  6943: 0004e61c    12 FUNC    GLOBAL DEFAULT    2 __p_cdname
  6944: 001001f8     4 OBJECT  GLOBAL DEFAULT    6 rtems_libio_init_helper
  6945: 0000e448   108 FUNC    GLOBAL DEFAULT    2 __fpclassifyd
  6946: 00050c70    16 FUNC    GLOBAL DEFAULT    2 getuid
  6947: 000912d0    56 FUNC    GLOBAL DEFAULT    2 _vfscanf_r
  6948: 00010eb8    88 FUNC    GLOBAL DEFAULT    2 rtems_stack_checker_repor
  6949: 000942ac   152 FUNC    GLOBAL DEFAULT    2 __ratio
  6950: 0005fa34   444 FUNC    GLOBAL DEFAULT    2 rip_output
  6951: 0001821c    40 FUNC    GLOBAL DEFAULT    2 rtems_current_user_env_ge
  6952: 0005017c   132 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_chdir
  6953: 0000a698  3308 FUNC    GLOBAL DEFAULT    2 whetstonemain
  6954: 00067bf4   156 FUNC    GLOBAL DEFAULT    2 _Timespec_Divide
  6955: 000662b0    64 FUNC    GLOBAL DEFAULT    2 _Message_queue_Manager_in
  6956: 00066890   508 FUNC    GLOBAL DEFAULT    2 rtems_task_mode
  6957: 0006961c    32 FUNC    GLOBAL DEFAULT    2 rtems_shell_errx
  6958: 000658cc    24 FUNC    GLOBAL DEFAULT    2 tcp_canceltimers
  6959: 000606c4    80 FUNC    GLOBAL DEFAULT    2 route_init
  6960: 00110838     0 NOTYPE  GLOBAL DEFAULT   13 bsp_section_fast_text_beg
  6961: 001139e8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_LS_Command
  6962: 00119020     8 OBJECT  WEAK   DEFAULT   15 __rtld_trace_signatures
  6963: 0004bb2c   196 FUNC    GLOBAL DEFAULT    2 IMFS_create_node
  6964: 001248c8     4 OBJECT  GLOBAL DEFAULT   15 rtems_shell_first_topic
  6965: 00113674    12 OBJECT  GLOBAL DEFAULT   14 _User_extensions_Switches
  6966: 00015c50   360 FUNC    GLOBAL DEFAULT    2 __res_querydomain
  6967: 00017968   180 FUNC    GLOBAL DEFAULT    2 malloc
  6968: 00066158   264 FUNC    GLOBAL DEFAULT    2 _TOD_Validate
  6969: 00083dd4    52 FUNC    GLOBAL DEFAULT    2 _printf_r
  6970: 0009af48   244 FUNC    GLOBAL HIDDEN     2 __udivsi3
  6971: 00068074    60 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_revmodcmp
  6972: 00082790    16 FUNC    GLOBAL DEFAULT    2 isatty
  6973: 0004b594    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6974: 00009188    20 FUNC    GLOBAL DEFAULT    2 __getreent
  6975: 0009b608     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_flush_multipl
  6976: 0008497c    40 FUNC    GLOBAL DEFAULT    2 _raise_r
  6977: 0004d0f8   124 FUNC    GLOBAL DEFAULT    2 _gethostbyhtname
  6978: 000082d8     4 OBJECT  GLOBAL DEFAULT    1 arm_cp15_start_mmu_config
  6979: 00028504    24 FUNC    GLOBAL DEFAULT    2 _API_extensions_Initializ
  6980: 00058e04  1488 FUNC    GLOBAL DEFAULT    2 icmp_input
  6981: 00093420    36 FUNC    GLOBAL DEFAULT    2 iswspace
  6982: 0005abac     8 FUNC    GLOBAL DEFAULT    2 _ip_mforward
  6983: 00050c58    24 FUNC    GLOBAL DEFAULT    2 endpwent
  6984: 0004f0d4    12 FUNC    GLOBAL DEFAULT    2 __fp_query
  6985: 00070fd0   692 FUNC    GLOBAL DEFAULT    2 rtems_rfs_buffer_handle_r
  6986: 00050014    96 FUNC    GLOBAL DEFAULT    2 __assert_func
  6987: 0000f348    32 FUNC    GLOBAL HIDDEN     2 __aeabi_i2f
  6988: 0004b8a0    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  6989: 001103e0   200 OBJECT  GLOBAL DEFAULT    6 __mprec_tens
  6990: 0006febc    76 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_get_bpos
  6991: 0001d6f8     4 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_malloc_mbuf
  6992: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_nocache_heap_size
  6993: 0011902c     4 OBJECT  WEAK   DEFAULT   15 __rtld_trace_triggers_siz
  6994: 0005bb28  3076 FUNC    GLOBAL DEFAULT    2 ip_ctloutput
  6995: 00072004  1144 FUNC    GLOBAL DEFAULT    2 rtems_rfs_dir_del_entry
  6996: 000540c8    84 FUNC    GLOBAL DEFAULT    2 arp_ifinit
  6997: 00027c6c   284 FUNC    GLOBAL DEFAULT    2 rtems_semaphore_release
  6998: 00085424    72 FUNC    GLOBAL DEFAULT    2 sleep
  6999: 0002afb0   152 FUNC    GLOBAL DEFAULT    2 _Thread_Global_constructi
  7000: 0011c4dc     4 OBJECT  GLOBAL DEFAULT   15 optarg
  7001: 0011c840 11200 OBJECT  GLOBAL DEFAULT   15 rtems_libio_iops
  7002: 00002800     0 NOTYPE  GLOBAL DEFAULT  ABS _binary_tarfile_size
  7003: 07ffc000     0 NOTYPE  GLOBAL DEFAULT   17 bsp_section_stack_begin
  7004: 0006e930    48 FUNC    GLOBAL DEFAULT    2 rtems_monitor_part_canoni
  7005: 00065830    40 FUNC    GLOBAL DEFAULT    2 tcp_gettaocache
  7006: 0007d4c4    40 FUNC    GLOBAL DEFAULT    2 rtems_monitor_config_dump
  7007: 00082bf0    12 FUNC    GLOBAL DEFAULT    2 __locale_charset
  7008: 0000d188   848 FUNC    GLOBAL DEFAULT    2 __kernel_cos
  7009: 000099ac    48 FUNC    GLOBAL DEFAULT    2 dhrystone_command
  7010: 00091408    60 FUNC    GLOBAL DEFAULT    2 vsnprintf
  7011: 000881b0    44 FUNC    GLOBAL DEFAULT    2 strtoll
  7012: 0000f914    40 FUNC    GLOBAL DEFAULT    2 Clock_isr
  7013: 0005d880    72 FUNC    GLOBAL DEFAULT    2 sysctl_register_all
  7014: 0000f724   108 FUNC    GLOBAL HIDDEN     2 __lesf2
  7015: 00066094   196 FUNC    GLOBAL DEFAULT    2 rtems_clock_set
  7016: 00066e94    68 FUNC    GLOBAL DEFAULT    2 rtems_io_open
  7017: 0009b1a8    84 FUNC    GLOBAL HIDDEN     2 __fixunsdfsi
  7018: 00026288    68 FUNC    GLOBAL DEFAULT    2 soshutdown
  7019: 00045934    36 FUNC    GLOBAL DEFAULT    2 rtems_trace_buffering_tri
  7020: 0001e508   160 FUNC    GLOBAL DEFAULT    2 recvfrom
  7021: 0006e728   520 FUNC    GLOBAL DEFAULT    2 rtems_monitor_object_cmd
  7022: 001132fc     4 OBJECT  GLOBAL DEFAULT   14 rtems_bsdnet_ntpserver
  7023: 00124640     4 OBJECT  GLOBAL DEFAULT   15 mbutl
  7024: 001249b8     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_inet_udp_chil
  7025: 000247f0    16 FUNC    GLOBAL DEFAULT    2 soabort
  7026: 00027da4   132 FUNC    GLOBAL DEFAULT    2 rtems_event_system_receiv
  7027: 00113f50    20 OBJECT  GLOBAL DEFAULT   14 h_errlist
  7028: 000524b0    12 FUNC    GLOBAL DEFAULT    2 tcdrain
  7029: 00066dcc    68 FUNC    GLOBAL DEFAULT    2 rtems_io_close
  7030: 00097764   108 FUNC    GLOBAL DEFAULT    2 __ssrefill_r
  7031: 00024728    16 FUNC    GLOBAL DEFAULT    2 pru_sense_null
  7032: 00017588     8 FUNC    GLOBAL DEFAULT    2 _getpid_r
  7033: 0006e574    96 FUNC    GLOBAL DEFAULT    2 rtems_monitor_command_ite
  7034: 001141a0     4 OBJECT  GLOBAL DEFAULT   14 ifqmaxlen
  7035: 0004d174    88 FUNC    GLOBAL DEFAULT    2 _gethostbyhtaddr
  7036: 0003b960  1080 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_printstrea
  7037: 00015dfc   904 FUNC    GLOBAL DEFAULT    2 __res_search
  7038: 0011690c     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_ntpserver_co
  7039: 0001bfbc   452 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_semaphore_ob
  7040: 00010f10    16 FUNC    GLOBAL DEFAULT    2 rtems_stack_checker_repor
  7041: 00055634   120 FUNC    GLOBAL DEFAULT    2 if_down
  7042: 000458e4    12 FUNC    GLOBAL DEFAULT    2 rtems_trace_buffering_buf
  7043: 0002855c   416 FUNC    GLOBAL DEFAULT    2 _API_Mutex_Lock
  7044: 00113ed4    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_JOEL_Command
  7045: 00088670    40 FUNC    GLOBAL DEFAULT    2 strtoul
  7046: 00110838     0 OBJECT  GLOBAL HIDDEN    14 __dso_handle
  7047: 00009ab8    56 FUNC    GLOBAL DEFAULT    2 Proc_4
  7048: 00115218     4 OBJECT  GLOBAL DEFAULT   14 __mb_cur_max
  7049: 0000e99c    36 FUNC    GLOBAL HIDDEN     2 __aeabi_ui2d
  7050: 00040e08   180 FUNC    GLOBAL DEFAULT    2 strvisx
  7051: 0002c2d4   148 FUNC    GLOBAL DEFAULT    2 _Watchdog_Tickle
  7052: 00067e48   144 FUNC    GLOBAL DEFAULT    2 _Watchdog_Adjust_forward
  7053: 00082c20    12 FUNC    GLOBAL DEFAULT    2 _localeconv_r
  7054: 00095fa8   620 FUNC    GLOBAL DEFAULT    2 _strtoull_r
  7055: 00009254   112 FUNC    GLOBAL DEFAULT    2 shell_start
  7056: 000562f4   172 FUNC    GLOBAL DEFAULT    2 in_localaddr
  7057: 0002a684   228 FUNC    GLOBAL DEFAULT    2 _Scheduler_priority_Block
  7058: 00093a78    36 FUNC    GLOBAL DEFAULT    2 __i2b
  7059: 00080bc8  1260 FUNC    GLOBAL DEFAULT    2 __sfvwrite_r
  7060: 00023660    84 FUNC    GLOBAL DEFAULT    2 soisdisconnecting
  7061: 000115d8   112 FUNC    GLOBAL DEFAULT    2 rtems_disk_obtain
  7062: 00011ea4   200 FUNC    GLOBAL DEFAULT    2 IMFS_initialize_support
  7063: 0005d31c   100 FUNC    GLOBAL DEFAULT    2 sysctl_ctx_entry_add
  7064: 00061370   548 FUNC    GLOBAL DEFAULT    2 rtredirect
  7065: 00014638   156 FUNC    GLOBAL DEFAULT    2 gethostbyaddr
  7066: 001246f4    12 OBJECT  GLOBAL DEFAULT   15 _Internal_Objects
  7067: 0001471c   544 FUNC    GLOBAL DEFAULT    2 gethostbyname_r
  7068: 0000e680     0 FUNC    GLOBAL HIDDEN     2 __aeabi_drsub
  7069: 0003bf60    72 FUNC    GLOBAL DEFAULT    2 rtems_shell_lookup_topic
  7070: 0004b21c   720 FUNC    GLOBAL DEFAULT    2 rtems_cpu_usage_top_with_
  7071: 00066ed8    68 FUNC    GLOBAL DEFAULT    2 rtems_io_read
  7072: 0004b858    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7073: 00114f3c     4 OBJECT  GLOBAL DEFAULT   14 opterr
  7074: 00116910     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_timeoffset
  7075: 00051e94   204 FUNC    GLOBAL DEFAULT    2 rmdir
  7076: 001249a4     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_link_children
  7077: 00018bbc    64 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  7078: 00077c60    12 FUNC    GLOBAL DEFAULT    2 uuid_unparse_lower
  7079: 00055438   344 FUNC    GLOBAL DEFAULT    2 ifaof_ifpforaddr
  7080: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_stack_und_size
  7081: 00124180    16 OBJECT  GLOBAL DEFAULT   15 Stack_check_Pattern
  7082: 00102660     8 OBJECT  GLOBAL DEFAULT    6 _TOD_Days_since_last_leap
  7083: 0001dba0   132 FUNC    GLOBAL DEFAULT    2 socket
  7084: 00124700   104 OBJECT  GLOBAL DEFAULT   15 _Workspace_Area
  7085: 0007d628    88 FUNC    GLOBAL DEFAULT    2 rtems_monitor_driver_cano
  7086: 00084a28   164 FUNC    GLOBAL DEFAULT    2 readdir
  7087: 00051900    52 FUNC    GLOBAL DEFAULT    2 getgrgid_r
  7088: 0004e524   248 FUNC    GLOBAL DEFAULT    2 __p_cdnname
  7089: 00113a88    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_WDUMP_Command
  7090: 000284bc    72 FUNC    GLOBAL DEFAULT    2 _RTEMS_API_Initialize
  7091: 00025f2c   212 FUNC    GLOBAL DEFAULT    2 sofree
  7092: 000757f4    12 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_free
  7093: 001156fc     4 OBJECT  GLOBAL DEFAULT   15 rtems_malloc_dirty_helper
  7094: 0001847c    16 FUNC    GLOBAL DEFAULT    2 _read_r
  7095: 0012503c    56 OBJECT  GLOBAL DEFAULT   15 _Dual_ported_memory_Infor
  7096: 0002bde0    56 FUNC    GLOBAL DEFAULT    2 _Thread_Yield
  7097: 0010262c    52 OBJECT  GLOBAL DEFAULT    6 _TOD_Days_to_date
  7098: 00027428    84 FUNC    GLOBAL DEFAULT    2 rtems_event_send
  7099: 00073518    36 FUNC    GLOBAL DEFAULT    2 rtems_rfs_file_io_release
  7100: 001214c0 10000 OBJECT  GLOBAL DEFAULT   15 Arr_2_Glob
  7101: 00078558   288 FUNC    GLOBAL DEFAULT    2 __ns_name_unpack
  7102: 00069394    36 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_summaryx
  7103: 0010a0ac     5 OBJECT  GLOBAL DEFAULT    6 _Status_Object_name_error
  7104: 0004bbf0   212 FUNC    GLOBAL DEFAULT    2 IMFS_fsunmount
  7105: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS _TLS_BSS_size
  7106: 0000f01c    24 FUNC    GLOBAL HIDDEN     2 __aeabi_dcmplt
  7107: 000281a4   180 FUNC    GLOBAL DEFAULT    2 rtems_task_start
  7108: 00028864    52 FUNC    GLOBAL DEFAULT    2 _Chain_Get
  7109: 00001040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_irq_end
  7110: 0007f250   252 FUNC    GLOBAL DEFAULT    2 _fclose_r
  7111: 00072d84   736 FUNC    GLOBAL DEFAULT    2 rtems_rfs_file_close
  7112: 0002baf8    92 FUNC    GLOBAL DEFAULT    2 _Thread_Close
  7113: 00114964     4 OBJECT  GLOBAL DEFAULT   14 ip_mforward
  7114: 0002a948     8 FUNC    GLOBAL DEFAULT    2 _Scheduler_priority_Prior
  7115: 001137cc    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_CMDLS_Command
  7116: 000662a4     4 FUNC    GLOBAL DEFAULT    2 _Event_Manager_initializa
  7117: 000080e0   188 FUNC    GLOBAL DEFAULT    1 bsp_start_hook_1
  7118: 0000f8d0    28 FUNC    GLOBAL DEFAULT    2 bsp_libc_init
  7119: 00124644     4 OBJECT  GLOBAL DEFAULT   15 mclrefcnt
  7120: 0007f62c    60 FUNC    GLOBAL DEFAULT    2 fflush
  7121: 00124390     4 OBJECT  GLOBAL DEFAULT   15 rtems_libio_iop_freelist
  7122: 0009b628     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_freeze_data
  7123: 0006eb44    36 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_decima
  7124: 0004f1b0    20 FUNC    GLOBAL DEFAULT    2 __p_class
  7125: 00010c60   116 FUNC    GLOBAL DEFAULT    2 rtems_stack_checker_creat
  7126: 00075a94   148 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_close
  7127: 0002bf28    16 FUNC    GLOBAL DEFAULT    2 _User_extensions_Thread_s
  7128: 00072a30   852 FUNC    GLOBAL DEFAULT    2 rtems_rfs_file_open
  7129: 00110838     0 NOTYPE  GLOBAL DEFAULT   13 bsp_section_fast_data_end
  7130: 00029850   104 FUNC    GLOBAL DEFAULT    2 _Objects_Get_information
  7131: 00024834    16 FUNC    GLOBAL DEFAULT    2 soconnect2
  7132: 000499d8   380 FUNC    GLOBAL DEFAULT    2 rtems_blkstats
  7133: 0004ba14     8 FUNC    GLOBAL DEFAULT    2 device_ftruncate
  7134: 00000000     0 NOTYPE  GLOBAL DEFAULT   13 bsp_section_vector_begin
  7135: 000503dc    64 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_location
  7136: 0000e098   508 FUNC    GLOBAL DEFAULT    2 __kernel_sin
  7137: 0000e9e8    64 FUNC    GLOBAL HIDDEN     2 __extendsfdf2
  7138: 0008aeb4  5716 FUNC    GLOBAL DEFAULT    2 __ssvfscanf_r
  7139: 07ed6e70     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_work_size
  7140: 0006cbd8   352 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_addfi
  7141: 0000ed2c   524 FUNC    GLOBAL HIDDEN     2 __aeabi_ddiv
  7142: 0002bedc    60 FUNC    GLOBAL DEFAULT    2 _User_extensions_Thread_c
  7143: 00050a70   124 FUNC    GLOBAL DEFAULT    2 ftruncate
  7144: 0001181c   160 FUNC    GLOBAL DEFAULT    2 rtems_disk_io_done
  7145: 00012bc0    92 FUNC    GLOBAL DEFAULT    2 IMFS_mount
  7146: 0005ab5c    56 FUNC    GLOBAL DEFAULT    2 ip_rsvp_done
  7147: 00124648     4 OBJECT  GLOBAL DEFAULT   15 max_datalen
  7148: 0004b7d0   136 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7149: 0007f668    96 FUNC    GLOBAL DEFAULT    2 _fgetc_r
  7150: 0007353c   244 FUNC    GLOBAL DEFAULT    2 rtems_rfs_file_seek
  7151: 0004dbf0   244 FUNC    GLOBAL DEFAULT    2 _map_v4v6_hostent
  7152: 0010fff4     4 OBJECT  GLOBAL DEFAULT    6 tm_year_base
  7153: 0002c6e4     0 NOTYPE  GLOBAL DEFAULT    2 _CPU_Context_switch
  7154: 0005a8bc   220 FUNC    GLOBAL DEFAULT    2 ip_srcroute
  7155: 001001e8     4 OBJECT  GLOBAL DEFAULT    6 rtems_libio_number_iops
  7156: 0000e68c   784 FUNC    GLOBAL HIDDEN     2 __adddf3
  7157: 0000f72c   100 FUNC    GLOBAL HIDDEN     2 __nesf2
  7158: 000519c8  1228 FUNC    GLOBAL DEFAULT    2 realpath
  7159: 00022a84   772 FUNC    GLOBAL DEFAULT    2 m_split
  7160: 00066074    32 FUNC    GLOBAL DEFAULT    2 rtems_clock_get_uptime
  7161: 0011c110     4 OBJECT  GLOBAL DEFAULT   15 ip_mrouter
  7162: 00045834    16 FUNC    GLOBAL DEFAULT    2 rtems_trace_triggers_size
  7163: 000262cc   864 FUNC    GLOBAL DEFAULT    2 sosetopt
  7164: 00061bdc   700 FUNC    GLOBAL DEFAULT    2 tcp_mss
  7165: 00124eb0    56 OBJECT  GLOBAL DEFAULT   15 _Extension_Information
  7166: 00063dfc    44 FUNC    GLOBAL DEFAULT    2 tcp_mssopt
  7167: 0000819c     0 NOTYPE  GLOBAL DEFAULT    1 bsp_start_memcpy_arm
  7168: 00001000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_stack_irq_size
  7169: 000940a4   252 FUNC    GLOBAL DEFAULT    2 __b2d
  7170: 001106b8     0 NOTYPE  GLOBAL DEFAULT    7 __exidx_start
  7171: 0012485c    44 OBJECT  GLOBAL DEFAULT   15 _RTEMS_Objects
  7172: 0002c6e4     0 NOTYPE  GLOBAL DEFAULT    2 _CPU_Context_switch_arm
  7173: 00019148    76 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_global_l
  7174: 0000ea9c   656 FUNC    GLOBAL HIDDEN     2 __aeabi_dmul
  7175: 0000f830    68 FUNC    GLOBAL DEFAULT    2 boot_card
  7176: 0006acf0   344 FUNC    GLOBAL DEFAULT    2 rtems_shell_fts_children
  7177: 00050d98   100 FUNC    GLOBAL DEFAULT    2 lseek
  7178: 0012439c     4 OBJECT  GLOBAL DEFAULT   15 rtems_current_user_env_ke
  7179: 0009195c    96 FUNC    GLOBAL DEFAULT    2 _isatty
  7180: 001131b8     1 OBJECT  GLOBAL DEFAULT   14 __fdlib_version
  7181: 00065fa4    80 FUNC    GLOBAL DEFAULT    2 sigaddset
  7182: 0002bf98   140 FUNC    GLOBAL DEFAULT    2 _User_extensions_Iterate
  7183: 00124cd8     4 OBJECT  GLOBAL DEFAULT   15 sysctl__kern_children
  7184: 00024718     8 FUNC    GLOBAL DEFAULT    2 pru_rcvd_notsupp
  7185: 0005064c   228 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_chmod
  7186: 00108a44    84 OBJECT  GLOBAL DEFAULT    6 __p_class_syms
  7187: 000500dc   116 FUNC    GLOBAL DEFAULT    2 rtems_assoc_ptr_by_remote
  7188: 00114e5c    64 OBJECT  GLOBAL DEFAULT   14 _res_resultcodes
  7189: 000757cc    40 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_alloc
  7190: 0010f808     4 OBJECT  GLOBAL DEFAULT    6 _global_impure_ptr
  7191: 000716d8  1268 FUNC    GLOBAL DEFAULT    2 rtems_rfs_dir_lookup_ino
  7192: 00061820    12 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_malloc_starv
  7193: 00050284    68 FUNC    GLOBAL DEFAULT    2 chown
  7194: 0006fbdc    60 FUNC    GLOBAL DEFAULT    2 ramdisk_free
  7195: 0009b74c    12 FUNC    GLOBAL DEFAULT    2 _realloc_r
  7196: 0006ae48   144 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_bpad
  7197: 00094864   148 FUNC    GLOBAL DEFAULT    2 strncasecmp
  7198: 00082710   128 FUNC    GLOBAL DEFAULT    2 __libc_init_array
  7199: 0002bf68    32 FUNC    GLOBAL DEFAULT    2 _User_extensions_Fatal_vi
  7200: 00066d58    20 FUNC    GLOBAL DEFAULT    2 _Debug_Manager_initializa
  7201: 00124c4c     4 OBJECT  GLOBAL DEFAULT   15 in_ifaddr
  7202: 0006a708  1460 FUNC    GLOBAL DEFAULT    2 rtems_shell_fts_read
  7203: 07ffc000     0 NOTYPE  GLOBAL DEFAULT   17 bsp_section_nocache_begin
  7204: 0012464c     4 OBJECT  GLOBAL DEFAULT   15 max_hdr
  7205: 00021cc0   216 FUNC    GLOBAL DEFAULT    2 m_free
  7206: 0000bf58  1044 FUNC    GLOBAL DEFAULT    2 __ieee754_exp
  7207: 00121474    20 OBJECT  GLOBAL DEFAULT   15 Task_name
  7208: 00113e08    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_TTY_Command
  7209: 00029150   320 FUNC    GLOBAL DEFAULT    2 _Heap_Block_allocate
  7210: 0006e960    24 FUNC    GLOBAL DEFAULT    2 rtems_monitor_part_dump_h
  7211: 0002bf38    16 FUNC    GLOBAL DEFAULT    2 _User_extensions_Thread_r
  7212: 00027994   728 FUNC    GLOBAL DEFAULT    2 rtems_semaphore_obtain
  7213: 00057aa8   288 FUNC    GLOBAL DEFAULT    2 in_pcblookup
  7214: 00012f98    36 FUNC    GLOBAL DEFAULT    2 IMFS_utime
  7215: 001105b8   256 OBJECT  GLOBAL DEFAULT    6 __hexdig
  7216: 00024708     8 FUNC    GLOBAL DEFAULT    2 pru_control_notsupp
  7217: 000297c0   124 FUNC    GLOBAL DEFAULT    2 _Objects_Free
  7218: 0009b478   288 FUNC    GLOBAL HIDDEN     2 __udivdi3
  7219: 0007d4ec   316 FUNC    GLOBAL DEFAULT    2 rtems_monitor_config_dump
  7220: 00124658    56 OBJECT  GLOBAL DEFAULT   15 _Semaphore_Information
  7221: 00116908     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_nameserver_c
  7222: 000173c8    32 FUNC    GLOBAL DEFAULT    2 send
  7223: 000280d8   184 FUNC    GLOBAL DEFAULT    2 _RTEMS_tasks_Initialize_u
  7224: 0004b970    40 FUNC    GLOBAL DEFAULT    2 device_open
  7225: 0009a1fc    32 FUNC    GLOBAL DEFAULT    2 _fputwc_r
  7226: 0005d6cc   436 FUNC    GLOBAL DEFAULT    2 sysctl_add_oid
  7227: 001104d0    40 OBJECT  GLOBAL DEFAULT    6 __mprec_bigtens
  7228: 0009b620     8 FUNC    GLOBAL DEFAULT    2 rtems_cache_get_data_cach
  7229: 000938a0   232 FUNC    GLOBAL DEFAULT    2 __s2b
  7230: 0004b778    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7231: 00001400     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_stack_all_size
  7232: 0007ef98    20 FUNC    GLOBAL DEFAULT    2 abort
  7233: 00066578    16 FUNC    GLOBAL DEFAULT    2 rtems_rate_monotonic_repo
  7234: 00053290   228 FUNC    GLOBAL DEFAULT    2 MD5Final
  7235: 0001c968   848 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_ifconfig
  7236: 0003b558  1032 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_printacol
  7237: 0000e99c    36 FUNC    GLOBAL HIDDEN     2 __floatunsidf
  7238: 0002851c    16 FUNC    GLOBAL DEFAULT    2 _API_extensions_Add
  7239: 0004b998    16 FUNC    GLOBAL DEFAULT    2 device_close
  7240: 00027114   104 FUNC    GLOBAL DEFAULT    2 rtems_clock_tick
  7241: 00035758   708 FUNC    GLOBAL DEFAULT    2 rtems_mdump
  7242: 00093e88   100 FUNC    GLOBAL DEFAULT    2 __mcmp
  7243: 00049520  1208 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_write
  7244: 00067d10    60 FUNC    GLOBAL DEFAULT    2 _Timespec_Less_than
  7245: 00048670    72 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_get_device_st
  7246: 00101f90    48 OBJECT  GLOBAL DEFAULT    6 rtems_filesystem_default_
  7247: 000650d8   536 FUNC    GLOBAL DEFAULT    2 tcp_respond
  7248: 001249bc     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_inet_igmp_chi
  7249: 000824ec   548 FUNC    GLOBAL DEFAULT    2 gmtime_r
  7250: 00050244    64 FUNC    GLOBAL DEFAULT    2 chmod
  7251: 00019380   240 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  7252: 000210e0    32 FUNC    GLOBAL DEFAULT    2 rtems_set_udp_buffer_size
  7253: 0009b630     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_enable_data
  7254: 0007bb54   152 FUNC    GLOBAL DEFAULT    2 igmp_joingroup
  7255: 0005c778   256 FUNC    GLOBAL DEFAULT    2 uiomove
  7256: 07ffc000     0 NOTYPE  GLOBAL DEFAULT   16 bsp_section_work_end
  7257: 00114d54     4 OBJECT  GLOBAL DEFAULT   14 tcp_keepinit
  7258: 0007fbc4    28 FUNC    GLOBAL DEFAULT    2 __fp_lock_all
  7259: 0009b614     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_invalidate_en
  7260: 001243c4     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_routetable_ch
  7261: 00123bd0     8 OBJECT  GLOBAL DEFAULT   15 T
  7262: 0006f908    40 FUNC    GLOBAL DEFAULT    2 rtems_monitor_task_dump_h
  7263: 00018d44   104 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  7264: 00067cd8    56 FUNC    GLOBAL DEFAULT    2 _Timespec_Is_valid
  7265: 0011903c     4 OBJECT  WEAK   DEFAULT   15 __rtld_trace_names_size
  7266: 00023708   224 FUNC    GLOBAL DEFAULT    2 sodropablereq
  7267: 0009b804     0 FUNC    GLOBAL DEFAULT    3 _init
  7268: 00123bd8     4 OBJECT  GLOBAL DEFAULT   15 End_Time
  7269: 00028c40    60 FUNC    GLOBAL DEFAULT    2 _CORE_semaphore_Initializ
  7270: 0001f984   172 FUNC    GLOBAL DEFAULT    2 rt_ifmsg
  7271: 00124cf8   120 OBJECT  GLOBAL DEFAULT   15 rt_tables
  7272: 00124c50   100 OBJECT  GLOBAL DEFAULT   15 ipstat
  7273: 00073630   792 FUNC    GLOBAL DEFAULT    2 rtems_rfs_file_set_size
  7274: 0003f22c    52 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_usage
  7275: 00009d24  1948 FUNC    GLOBAL DEFAULT    2 dhrymain
  7276: 00110840     1 OBJECT  GLOBAL DEFAULT   14 rtems_maximum_priority
  7277: 0002b664    56 FUNC    GLOBAL DEFAULT    2 _Thread_queue_Initialize
  7278: 0001d6f4     4 FUNC    GLOBAL DEFAULT    2 microtime
  7279: 00019470    72 FUNC    GLOBAL DEFAULT    2 rtems_termios_initialize
  7280: 00088188    40 FUNC    GLOBAL DEFAULT    2 strtol
  7281: 00017e7c     4 FUNC    GLOBAL DEFAULT    2 libc_init
  7282: 00051fa0   408 FUNC    GLOBAL DEFAULT    2 rtems_mkdir
  7283: 0001c2c4   120 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_malloc
  7284: 00048ef8   204 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_get_disk_dat
  7285: 0007140c   132 FUNC    GLOBAL DEFAULT    2 rtems_rfs_buffer_sync
  7286: 00029e04    68 FUNC    GLOBAL DEFAULT    2 _Protected_heap_Get_block
  7287: 0004dce4    16 FUNC    GLOBAL DEFAULT    2 __ns_get16
  7288: 0009b62c     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_unfreeze_data
  7289: 00057d98   696 FUNC    GLOBAL DEFAULT    2 in_pcbbind
  7290: 00029d7c    76 FUNC    GLOBAL DEFAULT    2 _Protected_heap_Allocate_
  7291: 00123bdc     4 OBJECT  GLOBAL DEFAULT   15 Next_Ptr_Glob
  7292: 0008044c  1460 FUNC    GLOBAL DEFAULT    2 _fseeko_r
  7293: 00026d9c    32 FUNC    GLOBAL DEFAULT    2 rtems_clock_get_ticks_per
  7294: 000868b4    92 FUNC    GLOBAL DEFAULT    2 strnlen
  7295: 000493b8   204 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_unregister
  7296: 00009c44   104 FUNC    GLOBAL DEFAULT    2 Proc_8
  7297: 00066e10    68 FUNC    GLOBAL DEFAULT    2 rtems_io_control
  7298: 0006f17c    80 FUNC    GLOBAL DEFAULT    2 rtems_symbol_table_destro
  7299: 0005411c   860 FUNC    GLOBAL DEFAULT    2 ether_output
  7300: 0004fcf0   692 FUNC    GLOBAL DEFAULT    2 __res_mkquery
  7301: 0000f0d8   160 FUNC    GLOBAL HIDDEN     2 __aeabi_d2f
  7302: 0004b57c    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7303: 00125190     0 NOTYPE  GLOBAL DEFAULT   16 WorkAreaBase
  7304: 0009b73c     8 FUNC    GLOBAL DEFAULT    2 __kill
  7305: 0006d408    80 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_usage
  7306: 00113bc8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MKRFS_Command
  7307: 000827a0    36 FUNC    GLOBAL DEFAULT    2 iswprint
  7308: 0001c564    16 FUNC    GLOBAL DEFAULT    2 wakeup
  7309: 0002a674    16 FUNC    GLOBAL DEFAULT    2 _Scheduler_Handler_initia
  7310: 00085e08    64 FUNC    GLOBAL DEFAULT    2 _strdup_r
  7311: 0000f8ec    16 FUNC    GLOBAL DEFAULT    2 bsp_postdriver_hook
  7312: 0006f85c   172 FUNC    GLOBAL DEFAULT    2 rtems_monitor_task_canoni
  7313: 0001de7c   468 FUNC    GLOBAL DEFAULT    2 accept
  7314: 0004b8e8   136 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7315: 0000f180   448 FUNC    GLOBAL HIDDEN     2 __aeabi_fsub
  7316: 0000d4d8  3004 FUNC    GLOBAL DEFAULT    2 __kernel_rem_pio2
  7317: 00106c70    24 OBJECT  GLOBAL DEFAULT    6 ramdisk_ops
  7318: 0007fbfc    72 FUNC    GLOBAL DEFAULT    2 __libc_fini_array
  7319: 0006cd38    28 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_badco
  7320: 0007d404   120 FUNC    GLOBAL DEFAULT    2 rtems_monitor_config_cano
  7321: 001249c0     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_inet_icmp_chi
  7322: 0007e018   164 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_map_set
  7323: 0003ad38   940 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_printlong
  7324: 00066d9c    28 FUNC    GLOBAL DEFAULT    2 rtems_debug_is_enabled
  7325: 00067384   624 FUNC    GLOBAL DEFAULT    2 _Heap_Allocate_aligned_wi
  7326: 000108c8   232 FUNC    GLOBAL DEFAULT    2 rtems_blkdev_generic_read
  7327: 0007e52c    20 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_close
  7328: 00125190     0 NOTYPE  GLOBAL DEFAULT   16 bsp_section_work_begin
  7329: 00017f44   104 FUNC    GLOBAL DEFAULT    2 rtems_libio_post_driver
  7330: 00084dc8    36 FUNC    GLOBAL DEFAULT    2 rename
  7331: 0005869c    96 FUNC    GLOBAL DEFAULT    2 in_inithead
  7332: 0002b610    40 FUNC    GLOBAL DEFAULT    2 _Thread_queue_Flush
  7333: 0001b48c   740 FUNC    GLOBAL DEFAULT    2 rtems_termios_enqueue_raw
  7334: 000656f8    92 FUNC    GLOBAL DEFAULT    2 tcp_rtlookup
  7335: 00084af8   196 FUNC    GLOBAL DEFAULT    2 _reclaim_reent
  7336: 0002426c   224 FUNC    GLOBAL DEFAULT    2 soreserve
  7337: 00029c00    12 FUNC    GLOBAL DEFAULT    2 _Objects_Namespace_remove
  7338: 0008cbb8     4 FUNC    GLOBAL DEFAULT    2 __tz_unlock
  7339: 000186a8    56 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  7340: 00075dc4   876 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_create
  7341: 0006e978   188 FUNC    GLOBAL DEFAULT    2 rtems_monitor_part_dump
  7342: 00087614    84 FUNC    GLOBAL DEFAULT    2 strrchr
  7343: 000680b0    56 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_acccmp
  7344: 00093988    92 FUNC    GLOBAL DEFAULT    2 __hi0bits
  7345: 00054698   492 FUNC    GLOBAL DEFAULT    2 ether_addmulti
  7346: 0004f178    20 FUNC    GLOBAL DEFAULT    2 __p_type
  7347: 00076a28   460 FUNC    GLOBAL DEFAULT    2 rtems_rfs_symlink_read
  7348: 000457f4    16 FUNC    GLOBAL DEFAULT    2 rtems_trace_names_size
  7349: 001243a4     4 OBJECT  GLOBAL DEFAULT   15 the_networkSemaphore
  7350: 00058d5c   168 FUNC    GLOBAL DEFAULT    2 ip_next_mtu
  7351: 000556d4   276 FUNC    GLOBAL DEFAULT    2 ifunit
  7352: 00065df4   392 FUNC    GLOBAL DEFAULT    2 nanosleep
  7353: 0007aaa8   480 FUNC    GLOBAL DEFAULT    2 __ns_format_ttl
  7354: 0002938c   188 FUNC    GLOBAL DEFAULT    2 _Objects_Allocate_unprote
  7355: 0000f800    24 FUNC    GLOBAL HIDDEN     2 __aeabi_fcmpge
  7356: 001248d0     4 OBJECT  GLOBAL DEFAULT   15 h_errno
  7357: 00017450    44 FUNC    GLOBAL DEFAULT    2 calloc
  7358: 0000f07c    92 FUNC    GLOBAL HIDDEN     2 __fixdfsi
  7359: 00113420    68 OBJECT  GLOBAL DEFAULT   14 tcp_usrreqs
  7360: 00029290   116 FUNC    GLOBAL DEFAULT    2 _Terminate
  7361: 0002841c    16 FUNC    GLOBAL DEFAULT    2 rtems_fatal
  7362: 000481f8   240 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_release
  7363: 00000040     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_vector_table_end
  7364: 00024250    28 FUNC    GLOBAL DEFAULT    2 sbrelease
  7365: 00124650     4 OBJECT  GLOBAL DEFAULT   15 max_linkhdr
  7366: 000286fc    56 FUNC    GLOBAL DEFAULT    2 _API_Mutex_Initialization
  7367: 00011fb8     4 FUNC    GLOBAL DEFAULT    2 IMFS_node_initialize_defa
  7368: 00024560   324 FUNC    GLOBAL DEFAULT    2 sbdroprecord
  7369: 0006ebd4   136 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_name
  7370: 001248e0   188 OBJECT  GLOBAL DEFAULT   15 loif
  7371: 00000001     0 NOTYPE  GLOBAL DEFAULT  ABS _TLS_Alignment
  7372: 0004a998   124 FUNC    GLOBAL DEFAULT    2 rtems_iterate_over_all_th
  7373: 0004b5ac    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7374: 00124768     4 OBJECT  GLOBAL DEFAULT   15 _Once_Mutex
  7375: 0006803c    56 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_modcmp
  7376: 0000f378   172 FUNC    GLOBAL HIDDEN     2 __floatdisf
  7377: 0004df40     4 FUNC    GLOBAL DEFAULT    2 _getlong
  7378: 001248a0    28 OBJECT  GLOBAL DEFAULT   15 _Per_CPU_Information
  7379: 0006c824   280 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_escap
  7380: 0007c028   340 FUNC    GLOBAL DEFAULT    2 rtems_rate_monotonic_get_
  7381: 00095f34    32 FUNC    GLOBAL DEFAULT    2 strtod
  7382: 0007ed9c    12 FUNC    GLOBAL DEFAULT    2 rtems_assoc_name_bad
  7383: 00063e94  3668 FUNC    GLOBAL DEFAULT    2 tcp_output
  7384: 0006c98c   588 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_add
  7385: 0002bd20    20 FUNC    GLOBAL DEFAULT    2 _Thread_Stack_Free
  7386: 0001b910     8 FUNC    GLOBAL DEFAULT    2 _unlink_r
  7387: 00017a2c   140 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_mknod
  7388: 00110844     4 OBJECT  GLOBAL DEFAULT   14 rtems_minimum_stack_size
  7389: 0010e81c    60 OBJECT  GLOBAL DEFAULT    6 rtems_rfs_rtems_device_ha
  7390: 0006b444  1372 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_displ
  7391: 00040d68   160 FUNC    GLOBAL DEFAULT    2 strvis
  7392: 0005d454   372 FUNC    GLOBAL DEFAULT    2 sysctl_remove_oid
  7393: 00021fb4   800 FUNC    GLOBAL DEFAULT    2 m_copym
  7394: 0007fdc4    60 FUNC    GLOBAL DEFAULT    2 _fputc_r
  7395: 0007c88c    32 FUNC    GLOBAL DEFAULT    2 TOD_TICKS_PER_SECOND_meth
  7396: 0001be38   144 FUNC    GLOBAL DEFAULT    2 write
  7397: 000556ac    40 FUNC    GLOBAL DEFAULT    2 if_up
  7398: 0011692c     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_bootp_cmdlin
  7399: 0010adcc   256 OBJECT  GLOBAL DEFAULT    6 e2a_32V
  7400: 00083e40   164 FUNC    GLOBAL DEFAULT    2 _putc_r
  7401: 0001c180    40 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_semaphore_ob
  7402: 0004f100   120 FUNC    GLOBAL DEFAULT    2 __sym_ntop
  7403: 001163c0     4 OBJECT  GLOBAL DEFAULT   15 memfile_blocks_allocated
  7404: 00100000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_robarrier_ali
  7405: 00123be0     4 OBJECT  GLOBAL DEFAULT   15 J
  7406: 00026a84    60 FUNC    GLOBAL DEFAULT    2 _POSIX_Keys_Key_value_com
  7407: 0006e3d4   308 FUNC    GLOBAL DEFAULT    2 rtems_monitor_symbols_loa
  7408: 00124ee8   256 OBJECT  GLOBAL DEFAULT   15 casetab
  7409: 00084dec    40 FUNC    GLOBAL DEFAULT    2 _rewind_r
  7410: 0007bd98   116 FUNC    GLOBAL DEFAULT    2 raw_attach
  7411: 00115684     8 OBJECT  GLOBAL DEFAULT   14 _tzname
  7412: 0000f71c   116 FUNC    GLOBAL HIDDEN     2 __gtsf2
  7413: 000091a8   172 FUNC    GLOBAL DEFAULT    2 net_setup_command
  7414: 0004fc78   120 FUNC    GLOBAL DEFAULT    2 __p_secstodate
  7415: 000934d4     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_text_size
  7416: 0011568c     4 OBJECT  GLOBAL DEFAULT   14 environ
  7417: 0006de34    56 FUNC    GLOBAL DEFAULT    2 rtems_shell_vwarnx
  7418: 00061168   208 FUNC    GLOBAL DEFAULT    2 ifa_ifwithroute
  7419: 00049eb8   176 FUNC    GLOBAL DEFAULT    2 rtems_blkdev_create
  7420: 0001e888   144 FUNC    GLOBAL DEFAULT    2 sysctl
  7421: 00016304   244 FUNC    GLOBAL DEFAULT    2 __res_nameinquery
  7422: 0006f13c    64 FUNC    GLOBAL DEFAULT    2 rtems_symbol_table_create
  7423: 00045994    36 FUNC    GLOBAL DEFAULT    2 rtems_trace_buffering_sto
  7424: 0005097c   144 FUNC    GLOBAL DEFAULT    2 fstat
  7425: 0007fd88    60 FUNC    GLOBAL DEFAULT    2 fprintf
  7426: 00024878   108 FUNC    GLOBAL DEFAULT    2 soconnect
  7427: 00013ef0   360 FUNC    GLOBAL DEFAULT    2 rtems_tftpfs_initialize
  7428: 00051698   348 FUNC    GLOBAL DEFAULT    2 _libcsupport_scangr
  7429: 0004ce30    24 FUNC    GLOBAL DEFAULT    2 _endhostdnsent
  7430: 0002bb88   236 FUNC    GLOBAL DEFAULT    2 _Thread_Set_life_protecti
  7431: 00124cb4     4 OBJECT  GLOBAL DEFAULT   15 ip_rsvpd
  7432: 00060ac0  1228 FUNC    GLOBAL DEFAULT    2 rtrequest
  7433: 0000e68c   784 FUNC    GLOBAL HIDDEN     2 __aeabi_dadd
  7434: 00054f34    64 FUNC    GLOBAL DEFAULT    2 ifinit
  7435: 00028898    84 FUNC    GLOBAL DEFAULT    2 _Chain_Initialize
  7436: 0009b72c     8 FUNC    GLOBAL DEFAULT    2 kill
  7437: 0002b04c   600 FUNC    GLOBAL DEFAULT    2 _Thread_Initialize
  7438: 00084f84   580 FUNC    GLOBAL DEFAULT    2 _setenv_r
  7439: 00060298   424 FUNC    GLOBAL DEFAULT    2 raw_input
  7440: 00050c1c    60 FUNC    GLOBAL DEFAULT    2 setpwent
  7441: 0001a308   212 FUNC    GLOBAL DEFAULT    2 rtems_termios_close
  7442: 0007f1f8    20 FUNC    GLOBAL DEFAULT    2 ctime
  7443: 0000ef40   144 FUNC    GLOBAL HIDDEN     2 __ledf2
  7444: 0002702c   104 FUNC    GLOBAL DEFAULT    2 rtems_clock_get_tod_timev
  7445: 0008249c    48 FUNC    GLOBAL DEFAULT    2 __getopt_long_only_r
  7446: 000947e0   132 FUNC    GLOBAL DEFAULT    2 strcat
  7447: 0000f7e8    24 FUNC    GLOBAL HIDDEN     2 __aeabi_fcmple
  7448: 000090a0     4 FUNC    GLOBAL DEFAULT    2 _Thread_Idle_body
  7449: 000578b0    68 FUNC    GLOBAL DEFAULT    2 in_setpeeraddr
  7450: 000695fc    32 FUNC    GLOBAL DEFAULT    2 rtems_shell_err
  7451: 001247e0    56 OBJECT  GLOBAL DEFAULT   15 _POSIX_Keys_Information
  7452: 00012910   432 FUNC    GLOBAL DEFAULT    2 IMFS_memfile_write
  7453: 0001dc24   152 FUNC    GLOBAL DEFAULT    2 bind
  7454: 00018e50    84 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_location
  7455: 00116380     4 OBJECT  GLOBAL DEFAULT   15 Console_Port_Tbl
  7456: 0007dafc    64 FUNC    GLOBAL DEFAULT    2 rtems_monitor_init_task_c
  7457: 00093c8c   260 FUNC    GLOBAL DEFAULT    2 __pow5mult
  7458: 0005041c   380 FUNC    GLOBAL DEFAULT    2 rtems_verror
  7459: 0009b650     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_freeze_instru
  7460: 001248d8     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_link_ether_in
  7461: 0000ea28   116 FUNC    GLOBAL HIDDEN     2 __aeabi_ul2d
  7462: 0011c4f0     4 OBJECT  GLOBAL DEFAULT   15 __nlocale_changed
  7463: 0001c1cc   184 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_semaphore_re
  7464: 0005abbc     8 FUNC    GLOBAL DEFAULT    2 _ip_mcast_src
  7465: 00009cac    32 FUNC    GLOBAL DEFAULT    2 Func_1
  7466: 00060f8c   340 FUNC    GLOBAL DEFAULT    2 rtalloc1
  7467: 0004a06c   368 FUNC    GLOBAL DEFAULT    2 rtems_blkdev_ioctl
  7468: 00014b18    36 FUNC    GLOBAL DEFAULT    2 inet_addr
  7469: 00017688   208 FUNC    GLOBAL DEFAULT    2 rtems_libio_init
  7470: 00025e58   212 FUNC    GLOBAL DEFAULT    2 sorflush
  7471: 0003bff0   268 FUNC    GLOBAL DEFAULT    2 rtems_shell_add_cmd_struc
  7472: 00114010    20 OBJECT  GLOBAL DEFAULT   14 arpintrq
  7473: 00091308    40 FUNC    GLOBAL DEFAULT    2 vprintf
  7474: 0003e050   128 FUNC    GLOBAL DEFAULT    2 rtems_shell_init
  7475: 00084ee8    52 FUNC    GLOBAL DEFAULT    2 _scanf_r
  7476: 00050eb8    16 FUNC    GLOBAL DEFAULT    2 mkfifo
  7477: 00124fe8     4 OBJECT  GLOBAL DEFAULT   15 rtems_monitor_symbols
  7478: 0004fc14   100 FUNC    GLOBAL DEFAULT    2 __dn_count_labels
  7479: 0006815c    60 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_revstatcmp
  7480: 0007cff8   124 FUNC    GLOBAL DEFAULT    2 _Thread_Handler
  7481: 0001c554    16 FUNC    GLOBAL DEFAULT    2 sb_lock
  7482: 00065f7c    40 FUNC    GLOBAL DEFAULT    2 pthread_once
  7483: 00000000     0 NOTYPE  WEAK   DEFAULT  UND __deregister_frame_info
  7484: 00100000     0 NOTYPE  GLOBAL DEFAULT    6 bsp_section_rodata_begin
  7485: 0009b05c     0 FUNC    GLOBAL HIDDEN     2 __aeabi_idiv
  7486: 00010634    16 FUNC    GLOBAL DEFAULT    2 bsp_interrupt_handler_def
  7487: 00050200    68 FUNC    GLOBAL DEFAULT    2 chdir
  7488: 001163bc     4 OBJECT  GLOBAL DEFAULT   15 imfs_memfile_bytes_per_bl
  7489: 00029304    20 FUNC    GLOBAL DEFAULT    2 _ISR_Handler_initializati
  7490: 00076bf4   116 FUNC    GLOBAL DEFAULT    2 rtems_rfs_mutex_create
  7491: 00016530    60 FUNC    GLOBAL DEFAULT    2 __res_close
  7492: 0004ce48    72 FUNC    GLOBAL DEFAULT    2 _sethosthtent
  7493: 00094760   128 FUNC    GLOBAL DEFAULT    2 _siscanf_r
  7494: 0004b550     8 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7495: 00124654     4 OBJECT  GLOBAL DEFAULT   15 mmbfree
  7496: 00080a00    48 FUNC    GLOBAL DEFAULT    2 fseeko
  7497: 00113c88    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_PERIODUSE_Com
  7498: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS _TLS_Size
  7499: 00057a08   160 FUNC    GLOBAL DEFAULT    2 in_losing
  7500: 00067ed8    16 FUNC    GLOBAL DEFAULT    2 _ARM_Exception_default
  7501: 00066858    56 FUNC    GLOBAL DEFAULT    2 rtems_status_code_to_errn
  7502: 000186e0   512 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  7503: 0009b834     0 NOTYPE  GLOBAL DEFAULT    4 bsp_section_text_end
  7504: 0005a998    92 FUNC    GLOBAL DEFAULT    2 ip_stripoptions
  7505: 0007f0c8    24 FUNC    GLOBAL DEFAULT    2 _atoi_r
  7506: 0002aeec    92 FUNC    GLOBAL DEFAULT    2 _Thread_Get
  7507: 00124fec     4 OBJECT  GLOBAL DEFAULT   15 rtems_monitor_node
  7508: 00043818    36 FUNC    GLOBAL DEFAULT    2 rtems_rfs_rtems_shutdown
  7509: 00017668    32 FUNC    GLOBAL DEFAULT    2 rtems_libio_exit
  7510: 00110714     0 NOTYPE  GLOBAL DEFAULT   12 __start_set_sysctl_set
  7511: 0007eeb8    64 FUNC    GLOBAL DEFAULT    2 endgrent
  7512: 0001e5a8   188 FUNC    GLOBAL DEFAULT    2 setsockopt
  7513: 00065624   212 FUNC    GLOBAL DEFAULT    2 tcp_ctlinput
  7514: 00080154   632 FUNC    GLOBAL DEFAULT    2 _freopen_r
  7515: 00055210   148 FUNC    GLOBAL DEFAULT    2 ifa_ifwithdstaddr
  7516: 00119009     1 OBJECT  WEAK   DEFAULT   15 __rtld_tbg_finished
  7517: 0001a444    24 FUNC    GLOBAL DEFAULT    2 rtems_termios_bufsize
  7518: 00080414    56 FUNC    GLOBAL DEFAULT    2 fseek
  7519: 001017d8    20 OBJECT  GLOBAL DEFAULT    6 IMFS_mknod_control_device
  7520: 00004ea0     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_data_size
  7521: 00045844    16 FUNC    GLOBAL DEFAULT    2 rtems_trace_triggers
  7522: 00067288     8 FUNC    GLOBAL DEFAULT    2 rtems_profiling_report_xm
  7523: 00000000     0 NOTYPE  WEAK   DEFAULT  UND _ITM_registerTMCloneTable
  7524: 00110838     0 NOTYPE  GLOBAL DEFAULT   12 bsp_section_rodata_end
  7525: 0000a63c    92 FUNC    GLOBAL DEFAULT    2 P0
  7526: 00029dc8    60 FUNC    GLOBAL DEFAULT    2 _Protected_heap_Free
  7527: 0007e9b4   536 FUNC    GLOBAL DEFAULT    2 __b64_pton
  7528: 00017660     8 FUNC    GLOBAL DEFAULT    2 issetugid
  7529: 0011372c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_CHDIR_Command
  7530: 00124eac     4 OBJECT  GLOBAL DEFAULT   15 tcp_maxidle
  7531: 00110838     0 NOTYPE  GLOBAL DEFAULT   13 bsp_section_fast_text_end
  7532: 0000f064    24 FUNC    GLOBAL HIDDEN     2 __aeabi_dcmpgt
  7533: 0001a214   244 FUNC    GLOBAL DEFAULT    2 rtems_termios_open
  7534: 00008360     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_text_load_beg
  7535: 0009b5c0    72 FUNC    GLOBAL HIDDEN     2 __clzsi2
  7536: 000675f4   472 FUNC    GLOBAL DEFAULT    2 _Heap_Free
  7537: 00029a80   192 FUNC    GLOBAL DEFAULT    2 _Objects_Get
  7538: 0001656c  3676 FUNC    GLOBAL DEFAULT    2 __res_send
  7539: 0008c6f4   116 FUNC    GLOBAL DEFAULT    2 _cleanupdir
  7540: 0008546c   216 FUNC    GLOBAL DEFAULT    2 _snprintf_r
  7541: 0000b8c0   252 FUNC    GLOBAL DEFAULT    2 cos
  7542: 0000f8fc     4 FUNC    GLOBAL DEFAULT    2 bsp_predriver_hook
  7543: 0011c4e0     4 OBJECT  GLOBAL DEFAULT   15 optind
  7544: 00114960     4 OBJECT  GLOBAL DEFAULT   14 mrt_ioctl
  7545: 0007efac   112 FUNC    GLOBAL DEFAULT    2 _asprintf_r
  7546: 00113218    12 OBJECT  GLOBAL DEFAULT   14 rtems_filesystem_mount_ta
  7547: 0007fbb4     4 FUNC    GLOBAL DEFAULT    2 __sfp_lock_acquire
  7548: 000268f0   112 FUNC    GLOBAL DEFAULT    2 pthread_key_create
  7549: 00082fb4   280 FUNC    GLOBAL DEFAULT    2 memchr
  7550: 000552a4   404 FUNC    GLOBAL DEFAULT    2 ifa_ifwithnet
  7551: 0007eef8   160 FUNC    GLOBAL DEFAULT    2 _Objects_Get_next
  7552: 00085624   104 FUNC    GLOBAL DEFAULT    2 _sprintf_r
  7553: 0011358c     4 OBJECT  GLOBAL DEFAULT   14 sb_max
  7554: 00113ca8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_PROFREPORT_Co
  7555: 00045824    16 FUNC    GLOBAL DEFAULT    2 rtems_trace_enables
  7556: 0006e604    52 FUNC    GLOBAL DEFAULT    2 rtems_monitor_object_look
  7557: 00029448    36 FUNC    GLOBAL DEFAULT    2 _Objects_Allocate
  7558: 0009b66c     8 FUNC    GLOBAL DEFAULT    2 _free_r
  7559: 000178a8    36 FUNC    GLOBAL DEFAULT    2 malloc_deferred_frees_pro
  7560: 00017758    52 FUNC    GLOBAL DEFAULT    2 rtems_libio_fcntl_flags
  7561: 0011c830     4 OBJECT  GLOBAL DEFAULT   15 _global_atexit
  7562: 00060714    56 FUNC    GLOBAL DEFAULT    2 ifafree
  7563: 0005d1a4   296 FUNC    GLOBAL DEFAULT    2 sysctl_register_oid
  7564: 00113704    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_CAT_Command
  7565: 00116378     4 OBJECT  GLOBAL DEFAULT   15 Reg
  7566: 00045814    16 FUNC    GLOBAL DEFAULT    2 rtems_trace_enables_size
  7567: 00110838     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_fast_data_loa
  7568: 0005da74   224 FUNC    GLOBAL DEFAULT    2 sysctl_handle_opaque
  7569: 00082bfc    16 FUNC    GLOBAL DEFAULT    2 __locale_mb_cur_max
  7570: 07ffc000     0 NOTYPE  GLOBAL DEFAULT   17 bsp_nocache_heap_end
  7571: 0001a3dc   104 FUNC    GLOBAL DEFAULT    2 rtems_termios_device_clos
  7572: 000288ec     4 FUNC    GLOBAL DEFAULT    2 _CORE_mutex_Flush
  7573: 0000f04c    24 FUNC    GLOBAL HIDDEN     2 __aeabi_dcmpge
  7574: 00000400     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_stack_abt_size
  7575: 0009b834     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_text_load_end
  7576: 0005255c   136 FUNC    GLOBAL DEFAULT    2 umask
  7577: 00048bf4   276 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_unmount
  7578: 0007c17c   184 FUNC    GLOBAL DEFAULT    2 _Rate_monotonic_Get_statu
  7579: 00076130    24 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_time_stam
  7580: 00075264   568 FUNC    GLOBAL DEFAULT    2 rtems_rfs_group_bitmap_al
  7581: 0002b4b8   148 FUNC    GLOBAL DEFAULT    2 _Thread_queue_Extract_wit
  7582: 0009180c   336 FUNC    GLOBAL DEFAULT    2 __call_exitprocs
  7583: 00084e44    84 FUNC    GLOBAL DEFAULT    2 __srget_r
  7584: 00073984    16 FUNC    GLOBAL DEFAULT    2 rtems_rfs_fs_size
  7585: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_stack_size
  7586: 00079224  6040 FUNC    GLOBAL DEFAULT    2 __ns_sprintrrf
  7587: 00027094    32 FUNC    GLOBAL DEFAULT    2 rtems_clock_get_uptime_se
  7588: 00110708     0 NOTYPE  GLOBAL DEFAULT    9 _TLS_Data_end
  7589: 0007dfe8    16 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_mask
  7590: 0000f908     4 FUNC    GLOBAL DEFAULT    2 bsp_start
  7591: 0002c804     4 FUNC    GLOBAL DEFAULT    2 _CPU_Initialize
  7592: 001243c8    40 OBJECT  GLOBAL DEFAULT   15 udpstat
  7593: 000458c4    16 FUNC    GLOBAL DEFAULT    2 rtems_trace_buffering_mod
  7594: 000482e8   120 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_release_modif
  7595: 00097670   244 FUNC    GLOBAL DEFAULT    2 _sungetc_r
  7596: 00001440     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_main_end
  7597: 0011c4ec     4 OBJECT  GLOBAL DEFAULT   15 __mlocale_changed
  7598: 0001c910    44 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_attach
  7599: 0000e688   788 FUNC    GLOBAL HIDDEN     2 __aeabi_dsub
  7600: 000837bc  1248 FUNC    GLOBAL DEFAULT    2 mktime
  7601: 00102668     5 OBJECT  GLOBAL DEFAULT    6 _Semaphore_Translate_core
  7602: 00124190   512 OBJECT  GLOBAL DEFAULT   15 _res
  7603: 00113b08    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MKDIR_Command
  7604: 0002ac04    80 FUNC    GLOBAL DEFAULT    2 _Thread_Clear_state
  7605: 0007bd38    96 FUNC    GLOBAL DEFAULT    2 igmp_slowtimo
  7606: 00055cbc   184 FUNC    GLOBAL DEFAULT    2 ifpromisc
  7607: 00008040     0 NOTYPE  GLOBAL DEFAULT    1 _start
  7608: 00028fb0   140 FUNC    GLOBAL DEFAULT    2 _Heap_Get_first_and_last_
  7609: 00050e04    96 FUNC    GLOBAL DEFAULT    2 lstat
  7610: 0011c108     4 OBJECT  GLOBAL DEFAULT   15 rsvpdebug
  7611: 0006eef8    56 FUNC    GLOBAL DEFAULT    2 rtems_monitor_region_cano
  7612: 0006c93c    28 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_badcn
  7613: 0001bfb8     4 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_free
  7614: 00011dd4    40 FUNC    GLOBAL DEFAULT    2 IMFS_node_destroy_default
  7615: 00087b38   896 FUNC    GLOBAL DEFAULT    2 strstr
  7616: 0001fa30   480 FUNC    GLOBAL DEFAULT    2 rt_newaddrmsg
  7617: 000881dc   712 FUNC    GLOBAL DEFAULT    2 _strtoll_r
  7618: 07ffc000     0 NOTYPE  GLOBAL DEFAULT   17 bsp_nocache_heap_begin
  7619: 00066760   176 FUNC    GLOBAL DEFAULT    2 rtems_semaphore_flush
  7620: 00065620     4 FUNC    GLOBAL DEFAULT    2 tcp_drain
  7621: 0006802c    16 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_revnamecmp
  7622: 0002283c   584 FUNC    GLOBAL DEFAULT    2 m_pullup
  7623: 000789d0   124 FUNC    GLOBAL DEFAULT    2 ns_name_skip
  7624: 0000b9c4   256 FUNC    GLOBAL DEFAULT    2 sin
  7625: 0008d0a4     8 FUNC    GLOBAL DEFAULT    2 _user_strerror
  7626: 00022580   216 FUNC    GLOBAL DEFAULT    2 m_copydata
  7627: 001138b4    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_ECHO_Command
  7628: 0000ea28   116 FUNC    GLOBAL HIDDEN     2 __floatundidf
  7629: 001132f8     4 OBJECT  GLOBAL DEFAULT   14 rtems_bsdnet_nameserver
  7630: 001249c4     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_inet_ip_child
  7631: 000849dc    76 FUNC    GLOBAL DEFAULT    2 rand
  7632: 00110848    48 OBJECT  GLOBAL DEFAULT   14 Configuration_RTEMS_API
  7633: 0002be18   112 FUNC    GLOBAL DEFAULT    2 _Timespec_Add_to
  7634: 00080bb0    24 FUNC    GLOBAL DEFAULT    2 ftello
  7635: 00102670     6 OBJECT  GLOBAL DEFAULT    6 _Semaphore_Translate_core
  7636: 00113ea8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_WKSPACE_INFO_
  7637: 000246f8     8 FUNC    GLOBAL DEFAULT    2 pru_accept_notsupp
  7638: 0002478c   100 FUNC    GLOBAL DEFAULT    2 solisten
  7639: 00123be4     4 OBJECT  GLOBAL DEFAULT   15 Int_Glob
  7640: 00093d90   248 FUNC    GLOBAL DEFAULT    2 __lshift
  7641: 0007ac88   328 FUNC    GLOBAL DEFAULT    2 __ns_parse_ttl
  7642: 00052138    16 FUNC    GLOBAL DEFAULT    2 rtems_putc
  7643: 0007d074   672 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_conv_
  7644: 0005fbf0   944 FUNC    GLOBAL DEFAULT    2 rip_ctloutput
  7645: 0002bcd8    72 FUNC    GLOBAL DEFAULT    2 _Thread_Stack_Allocate
  7646: 0002bd58   136 FUNC    GLOBAL DEFAULT    2 _Thread_Start
  7647: 0011386c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_DEBUGRFS_Comm
  7648: 00052178    24 FUNC    GLOBAL DEFAULT    2 setgid
  7649: 00124cb8     4 OBJECT  GLOBAL DEFAULT   15 ip_nat_ctl_ptr
  7650: 00125004    56 OBJECT  GLOBAL DEFAULT   15 _Barrier_Information
  7651: 0005060c    64 FUNC    GLOBAL DEFAULT    2 rtems_panic
  7652: 000183ec   144 FUNC    GLOBAL DEFAULT    2 read
  7653: 00021968   176 FUNC    GLOBAL DEFAULT    2 m_retry
  7654: 0006f930   268 FUNC    GLOBAL DEFAULT    2 rtems_monitor_task_dump
  7655: 0004e778   128 FUNC    GLOBAL DEFAULT    2 __sym_ntos
  7656: 0000f348    32 FUNC    GLOBAL HIDDEN     2 __floatsisf
  7657: 0001c700    28 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_random
  7658: 00096218   432 FUNC    GLOBAL DEFAULT    2 __ssprint_r
  7659: 00064ce8    20 FUNC    GLOBAL DEFAULT    2 tcp_quench
  7660: 0004b51c     8 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7661: 0011388c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_DF_Command
  7662: 0006ee40   184 FUNC    GLOBAL DEFAULT    2 rtems_monitor_queue_dump
  7663: 00011f90    40 FUNC    GLOBAL DEFAULT    2 IMFS_node_free
  7664: 0011397c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_ID_Command
  7665: 0007b324    16 FUNC    GLOBAL DEFAULT    2 _fcntl_r
  7666: 00010cf8   184 FUNC    GLOBAL DEFAULT    2 Stack_check_report_blown_
  7667: 00077f90   296 FUNC    GLOBAL DEFAULT    2 openlog
  7668: 000181a8    16 FUNC    GLOBAL DEFAULT    2 _open_r
  7669: 0011480c    22 OBJECT  GLOBAL DEFAULT   14 inetctlerrmap
  7670: 07ffc000     0 NOTYPE  GLOBAL DEFAULT    1 bsp_translation_table_bas
  7671: 00091728   228 FUNC    GLOBAL DEFAULT    2 __register_exitproc
  7672: 00124ff0     4 OBJECT  GLOBAL DEFAULT   15 rtems_monitor_default_nod
  7673: 0002a5f0   132 FUNC    GLOBAL DEFAULT    2 _Scheduler_default_Tick
  7674: 0001b998  1184 FUNC    GLOBAL DEFAULT    2 vprintk
  7675: 0001e0b0   452 FUNC    GLOBAL DEFAULT    2 sendmsg
  7676: 0007e7b4   108 FUNC    GLOBAL DEFAULT    2 uuid_unpack
  7677: 00086568    72 FUNC    GLOBAL DEFAULT    2 strlcpy
  7678: 001137ac    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_CMDCHOWN_Comm
  7679: 000780b8    56 FUNC    GLOBAL DEFAULT    2 closelog
  7680: 0007c760   148 FUNC    GLOBAL DEFAULT    2 _Signal_Action_handler
  7681: 000866b8   280 FUNC    GLOBAL DEFAULT    2 strncmp
  7682: 00113ce8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_RMDIR_Command
  7683: 00020844    32 FUNC    GLOBAL DEFAULT    2 rtems_set_tcp_buffer_size
  7684: 00076c68    88 FUNC    GLOBAL DEFAULT    2 rtems_rfs_mutex_destroy
  7685: 0005c8dc   164 FUNC    GLOBAL DEFAULT    2 phashinit
  7686: 00045864    40 FUNC    GLOBAL DEFAULT    2 rtems_trace_enable_set
  7687: 07ff4000     0 NOTYPE  GLOBAL DEFAULT  ABS RamSize
  7688: 001136a4    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_ALIAS_Command
  7689: 0005eabc   748 FUNC    GLOBAL DEFAULT    2 rn_addmask
  7690: 00027618   532 FUNC    GLOBAL DEFAULT    2 rtems_semaphore_create
  7691: 00123be8     1 OBJECT  GLOBAL DEFAULT   15 Ch_1_Glob
  7692: 0001a13c   216 FUNC    GLOBAL DEFAULT    2 rtems_termios_device_open
  7693: 001249cc     4 OBJECT  GLOBAL DEFAULT   15 icmplenPanicAvoided
  7694: 0001fc40   148 FUNC    GLOBAL DEFAULT    2 sethostname
  7695: 000759a8   236 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_unload
  7696: 00034c08    20 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_exit
  7697: 0008246c    48 FUNC    GLOBAL DEFAULT    2 __getopt_long_r
  7698: 00093a9c   496 FUNC    GLOBAL DEFAULT    2 __multiply
  7699: 00019028   288 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_global_l
  7700: 00067e20    40 FUNC    GLOBAL DEFAULT    2 _Watchdog_Adjust_backward
  7701: 0007b72c  1064 FUNC    GLOBAL DEFAULT    2 igmp_input
  7702: 00009780    64 FUNC    GLOBAL DEFAULT    2 setup_ramdisk
  7703: 0002ab64   160 FUNC    GLOBAL DEFAULT    2 _Thread_Change_priority
  7704: 00101780    20 OBJECT  GLOBAL DEFAULT    6 IMFS_mknod_control_dir_de
  7705: 0009b640     8 FUNC    GLOBAL DEFAULT    2 rtems_cache_get_instructi
  7706: 0010f874    96 OBJECT  GLOBAL DEFAULT    6 __month_lengths
  7707: 0003f260  1420 FUNC    GLOBAL DEFAULT    2 svis
  7708: 000867d0   228 FUNC    GLOBAL DEFAULT    2 strncpy
  7709: 0001b884   140 FUNC    GLOBAL DEFAULT    2 unlink
  7710: 00124ce4     4 OBJECT  GLOBAL DEFAULT   15 sysctl__sysctl_next_child
  7711: 00084f3c    44 FUNC    GLOBAL DEFAULT    2 setenv
  7712: 0006f410   156 FUNC    GLOBAL DEFAULT    2 rtems_symbol_value_lookup
  7713: 00066d84    24 FUNC    GLOBAL DEFAULT    2 rtems_debug_disable
  7714: 0001b850    52 FUNC    GLOBAL DEFAULT    2 rtems_termios_set_initial
  7715: 00012d74    48 FUNC    GLOBAL DEFAULT    2 IMFS_stat_file
  7716: 000459dc    60 FUNC    GLOBAL DEFAULT    2 _rtems_octal2ulong
  7717: 0007e404   216 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_create_s
  7718: 0000f72c   100 FUNC    GLOBAL HIDDEN     2 __eqsf2
  7719: 0000f874     4 FUNC    GLOBAL DEFAULT    2 bsp_fatal_extension
  7720: 000941a0   268 FUNC    GLOBAL DEFAULT    2 __d2b
  7721: 00065858   116 FUNC    GLOBAL DEFAULT    2 tcp_fasttimo
  7722: 0008590c   108 FUNC    GLOBAL DEFAULT    2 strcasecmp
  7723: 00001040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_abt_begin
  7724: 0001e274    76 FUNC    GLOBAL DEFAULT    2 sendto
  7725: 0002ad28   332 FUNC    GLOBAL DEFAULT    2 _Thread_Do_dispatch
  7726: 00109e78   104 OBJECT  GLOBAL DEFAULT    6 _TOD_Days_per_month
  7727: 0000a4c0    16 FUNC    GLOBAL DEFAULT    2 Func_3
  7728: 00009b6c   200 FUNC    GLOBAL DEFAULT    2 Proc_1
  7729: 0007be3c   224 FUNC    GLOBAL DEFAULT    2 _POSIX_Keys_Run_destructo
  7730: 0004b4fc    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7731: 00001040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_fiq_end
  7732: 0004dcf4    36 FUNC    GLOBAL DEFAULT    2 __ns_get32
  7733: 0002b54c     8 FUNC    GLOBAL DEFAULT    2 _Thread_queue_Extract
  7734: 00023564   252 FUNC    GLOBAL DEFAULT    2 soisconnected
  7735: 07ffc000     0 NOTYPE  GLOBAL DEFAULT   17 bsp_section_nocache_end
  7736: 000915d0     4 FUNC    GLOBAL DEFAULT    2 wcwidth
  7737: 00010f20    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7738: 00029c94   232 FUNC    GLOBAL DEFAULT    2 _Objects_Shrink_informati
  7739: 0011384c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_DD_Command
  7740: 0002717c   172 FUNC    GLOBAL DEFAULT    2 _TOD_To_seconds
  7741: 0001848c   268 FUNC    GLOBAL DEFAULT    2 realloc
  7742: 00108858   492 OBJECT  GLOBAL DEFAULT    6 __p_type_syms
  7743: 00123be9     1 OBJECT  GLOBAL DEFAULT   15 Ch_2_Glob
  7744: 001087e0    60 OBJECT  GLOBAL DEFAULT    6 __p_update_section_syms
  7745: 00123cfc     4 OBJECT  GLOBAL DEFAULT   15 Clock_driver_ticks
  7746: 0006ebb0    36 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_id
  7747: 0002c7e8    28 FUNC    GLOBAL DEFAULT    2 _CPU_ISR_install_vector
  7748: 000884a4   460 FUNC    GLOBAL DEFAULT    2 _strtoul_r
  7749: 00066d10    72 FUNC    GLOBAL DEFAULT    2 _RTEMS_Tasks_Invoke_task_
  7750: 00066a8c   240 FUNC    GLOBAL DEFAULT    2 rtems_task_set_priority
  7751: 00124690    56 OBJECT  GLOBAL DEFAULT   15 _RTEMS_tasks_Information
  7752: 000114e8   240 FUNC    GLOBAL DEFAULT    2 rtems_disk_create_log
  7753: 00113ba8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MKNOD_Command
  7754: 0006ec5c    36 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_priori
  7755: 0004c80c   844 FUNC    GLOBAL DEFAULT    2 _gethostbydnsname
  7756: 00064fa8   144 FUNC    GLOBAL DEFAULT    2 tcp_init
  7757: 0004a4a4    96 FUNC    GLOBAL DEFAULT    2 rtems_cpu_usage_reset
  7758: 000283b0    16 FUNC    GLOBAL DEFAULT    2 rtems_initialize_device_d
  7759: 0006e3d0     4 FUNC    GLOBAL DEFAULT    2 rtems_monitor_debugger_cm
  7760: 0003e97c   140 FUNC    GLOBAL DEFAULT    2 rtems_shell_cp_copy_fifo
  7761: 0000f5bc   352 FUNC    GLOBAL HIDDEN     2 __aeabi_fdiv
  7762: 000174f4     8 FUNC    GLOBAL DEFAULT    2 _close_r
  7763: 000680e8    60 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_revacccmp
  7764: 00010f54    16 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7765: 0006ffc0   352 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_map_open
  7766: 0000e9c0    40 FUNC    GLOBAL HIDDEN     2 __aeabi_i2d
  7767: 00056498   416 FUNC    GLOBAL DEFAULT    2 in_addmulti
  7768: 00119034     4 OBJECT  WEAK   DEFAULT   15 __rtld_trace_enables_size
  7769: 00110988     4 OBJECT  GLOBAL DEFAULT   14 imfs_rq_memfile_bytes_per
  7770: 00065038   160 FUNC    GLOBAL DEFAULT    2 tcp_template
  7771: 00066854     4 FUNC    GLOBAL DEFAULT    2 _Signal_Manager_initializ
  7772: 001243a8     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_log_priority
  7773: 000182dc   212 FUNC    GLOBAL DEFAULT    2 rtems_libio_set_private_e
  7774: 0006ed40    64 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_events
  7775: 000507c0   220 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_chown
  7776: 00087eb8    44 FUNC    GLOBAL DEFAULT    2 strtok
  7777: 00091330    32 FUNC    GLOBAL DEFAULT    2 _vprintf_r
  7778: 00047f14    56 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_init
  7779: 00123bf0    40 OBJECT  GLOBAL DEFAULT   15 E1
  7780: 000284a4    24 FUNC    GLOBAL DEFAULT    2 _POSIX_API_Initialize
  7781: 0002e328   760 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_dd_out
  7782: 00023538    24 FUNC    GLOBAL DEFAULT    2 rtems_set_sb_efficiency
  7783: 00124818    16 OBJECT  GLOBAL DEFAULT   15 _POSIX_Keys_Keypool
  7784: 000830cc   176 FUNC    GLOBAL DEFAULT    2 memcmp
  7785: 0001de24    88 FUNC    GLOBAL DEFAULT    2 listen
  7786: 00123c18     4 OBJECT  GLOBAL DEFAULT   15 Ptr_Glob
  7787: 0002af48   104 FUNC    GLOBAL DEFAULT    2 _Thread_Get_interrupt_dis
  7788: 00047f4c   228 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_get
  7789: 0004d690     8 FUNC    GLOBAL DEFAULT    2 _gethostbynisname
  7790: 00125000     4 OBJECT  GLOBAL DEFAULT   15 rawcb_list
  7791: 00023838   104 FUNC    GLOBAL DEFAULT    2 sbreserve
  7792: 000575b4   540 FUNC    GLOBAL DEFAULT    2 in_pcbladdr
  7793: 000811c4   156 FUNC    GLOBAL DEFAULT    2 _fwrite_r
  7794: 00011dfc   168 FUNC    GLOBAL DEFAULT    2 IMFS_initialize_node
  7795: 000693b8   396 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_pos_in
  7796: 0003ea98  1292 FUNC    GLOBAL DEFAULT    2 rtems_shell_cp_copy_file
  7797: 0000f368   188 FUNC    GLOBAL HIDDEN     2 __floatundisf
  7798: 00124ce8     4 OBJECT  GLOBAL DEFAULT   15 sysctl__sysctl_oiddescr_c
  7799: 0007dce4    56 FUNC    GLOBAL DEFAULT    2 rtems_monitor_manager_nex
  7800: 00124888    12 OBJECT  GLOBAL DEFAULT   15 _Internal_errors_What_hap
  7801: 0011901c     1 OBJECT  WEAK   DEFAULT   15 __rtld_tbg_present
  7802: 0007d314   240 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_conv_
  7803: 000856f4   116 FUNC    GLOBAL DEFAULT    2 sscanf
  7804: 00080a94   284 FUNC    GLOBAL DEFAULT    2 _ftello_r
  7805: 000181b8    48 FUNC    GLOBAL DEFAULT    2 printk
  7806: 0004b798     8 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  7807: 00001040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_und_begin
  7808: 0004dea0   108 FUNC    GLOBAL DEFAULT    2 __res_mailok
  7809: 000915d4   340 FUNC    GLOBAL DEFAULT    2 __swsetup_r
  7810: 00113d88    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_SLEEP_Command
  7811: 00066f1c   604 FUNC    GLOBAL DEFAULT    2 rtems_io_register_driver
  7812: 0009b1a4     4 FUNC    WEAK   HIDDEN     2 __aeabi_ldiv0
  7813: 000521a8   100 FUNC    GLOBAL DEFAULT    2 statvfs
  7814: 0007ede8    76 FUNC    GLOBAL DEFAULT    2 getgrent
  7815: 0002be88    84 FUNC    GLOBAL DEFAULT    2 _Timespec_Subtract
  7816: 00113d08    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_RM_Command
  7817: 00000000     0 NOTYPE  GLOBAL DEFAULT   13 bsp_vector_table_begin
  7818: 0002c6f8     0 NOTYPE  GLOBAL DEFAULT    2 _CPU_Context_restore
  7819: 000109b0   260 FUNC    GLOBAL DEFAULT    2 rtems_blkdev_generic_writ
  7820: 00011a84    28 FUNC    GLOBAL DEFAULT    2 IMFS_node_initialize_dire
  7821: 0000ed2c   524 FUNC    GLOBAL HIDDEN     2 __divdf3
  7822: 0002ac54   196 FUNC    GLOBAL DEFAULT    2 _Thread_Create_idle
  7823: 0004d698    20 FUNC    GLOBAL DEFAULT    2 _gethostbynisaddr
  7824: 00043e48     8 FUNC    GLOBAL DEFAULT    2 rtems_rfs_rtems_imode
  7825: 001156e0     0 NOTYPE  GLOBAL DEFAULT   15 bsp_section_bss_begin
  7826: 00113d28    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_RTC_Command
  7827: 0007fa94   236 FUNC    GLOBAL DEFAULT    2 __sfp
  7828: 0001c6c4    60 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_event_receiv
  7829: 0006b1b0   660 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_get
  7830: 00086610   168 FUNC    GLOBAL DEFAULT    2 strncat
  7831: 0009439c   112 FUNC    GLOBAL DEFAULT    2 __copybits
  7832: 00023dd4    88 FUNC    GLOBAL DEFAULT    2 sbappend
  7833: 000230f0   332 FUNC    GLOBAL DEFAULT    2 m_copyback
  7834: 0010ec08   252 OBJECT  GLOBAL DEFAULT    6 rtems_termios_baud_table
  7835: 0002bf18    16 FUNC    GLOBAL DEFAULT    2 _User_extensions_Thread_d
  7836: 0000f340    40 FUNC    GLOBAL HIDDEN     2 __aeabi_ui2f
  7837: 000118bc    52 FUNC    GLOBAL DEFAULT    2 IMFS_chown
  7838: 0007fbc0     4 FUNC    GLOBAL DEFAULT    2 __sinit_lock_release
  7839: 0012476c     4 OBJECT  GLOBAL DEFAULT   15 _RTEMS_Allocator_Mutex
  7840: 00091350   184 FUNC    GLOBAL DEFAULT    2 _vsnprintf_r
  7841: 0006a2a0   836 FUNC    GLOBAL DEFAULT    2 rtems_shell_fts_open
  7842: 00124770     4 OBJECT  GLOBAL DEFAULT   15 _Watchdog_Sync_level
  7843: 0007e1d8   144 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_map_set_
  7844: 00054608   144 FUNC    GLOBAL DEFAULT    2 ether_ifattach
  7845: 001138ac     8 OBJECT  GLOBAL DEFAULT   14 rtems_shell_DIR_Alias
  7846: 0006e2f0    36 FUNC    GLOBAL DEFAULT    2 rtems_monitor_continue_cm
  7847: 0006e2ec     4 FUNC    WEAK   DEFAULT    2 rtems_monitor_reset_cmd
  7848: 00078930    84 FUNC    GLOBAL DEFAULT    2 __ns_name_uncompress
  7849: 0000ea9c   656 FUNC    GLOBAL HIDDEN     2 __muldf3
  7850: 0000fe40     8 FUNC    GLOBAL DEFAULT    2 console_read
  7851: 00028c7c    72 FUNC    GLOBAL DEFAULT    2 _CORE_semaphore_Surrender
  7852: 000150b0  2080 FUNC    GLOBAL DEFAULT    2 __res_init
  7853: 000857e8    76 FUNC    GLOBAL DEFAULT    2 __sread
  7854: 00106cdc    60 OBJECT  GLOBAL DEFAULT    6 rtems_rfs_rtems_link_hand
  7855: 001243f0     4 OBJECT  GLOBAL DEFAULT   15 udb
  7856: 00080118    60 FUNC    GLOBAL DEFAULT    2 fread
  7857: 0005a7a4    88 FUNC    GLOBAL DEFAULT    2 ipintr
  7858: 00073288   656 FUNC    GLOBAL DEFAULT    2 rtems_rfs_file_io_end
  7859: 0010e858    60 OBJECT  GLOBAL DEFAULT    6 rtems_rfs_rtems_dir_handl
  7860: 0011495c     4 OBJECT  GLOBAL DEFAULT   14 ip_mcast_src
  7861: 0002b2a4   140 FUNC    GLOBAL DEFAULT    2 _Thread_Handler_initializ
  7862: 0008c850   300 FUNC    GLOBAL DEFAULT    2 ttyname_r
  7863: 000597c8   304 FUNC    GLOBAL DEFAULT    2 ip_init
  7864: 00074fbc   536 FUNC    GLOBAL DEFAULT    2 rtems_rfs_group_open
  7865: 0001cee4  1420 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_initialize_n
  7866: 00113204     4 OBJECT  GLOBAL DEFAULT   14 Console_Configuration_Cou
  7867: 00055168   168 FUNC    GLOBAL DEFAULT    2 ifa_ifwithaddr
  7868: 0007fd58    48 FUNC    GLOBAL DEFAULT    2 _fprintf_r
  7869: 00000000     0 NOTYPE  WEAK   DEFAULT  UND _ITM_deregisterTMCloneTab
  7870: 00085dec    28 FUNC    GLOBAL DEFAULT    2 strdup
  7871: 0003e0d0   140 FUNC    GLOBAL DEFAULT    2 rtems_shell_script
  7872: 0000819c     0 NOTYPE  GLOBAL DEFAULT    1 bsp_start_memcpy
  7873: 001243ac     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_ticks_per_se
  7874: 00028c3c     4 FUNC    GLOBAL DEFAULT    2 _CORE_semaphore_Flush
  7875: 0007f5d8    84 FUNC    GLOBAL DEFAULT    2 _fflush_r
  7876: 0001493c   476 FUNC    GLOBAL DEFAULT    2 inet_aton
  7877: 0002c684     0 NOTYPE  GLOBAL DEFAULT    2 _ARMV4_Exception_fiq_defa
  7878: 001132f4     4 OBJECT  GLOBAL DEFAULT   14 nmbclusters
  7879: 0003e420   488 FUNC    GLOBAL DEFAULT    2 rtems_shell_script_file
  7880: 0009b660    12 FUNC    GLOBAL DEFAULT    2 _calloc_r
  7881: 00027e28    88 FUNC    GLOBAL DEFAULT    2 rtems_event_system_send
  7882: 00114968     4 OBJECT  GLOBAL DEFAULT   14 ip_mrouter_done
  7883: 0010e894    60 OBJECT  GLOBAL DEFAULT    6 rtems_rfs_rtems_file_hand
  7884: 00124cec     4 OBJECT  GLOBAL DEFAULT   15 sysctl__sysctl_oidfmt_chi
  7885: 0004e708   112 FUNC    GLOBAL DEFAULT    2 __sym_ston
  7886: 00028d70    32 FUNC    GLOBAL DEFAULT    2 _TOD_Seconds_since_epoch
  7887: 001109a4     4 OBJECT  GLOBAL DEFAULT   14 rtems_nvdisk_configuratio
  7888: 0004f2e4   256 FUNC    GLOBAL DEFAULT    2 __fp_resstat
  7889: 0008cbb4     4 FUNC    GLOBAL DEFAULT    2 __tz_lock
  7890: 0001470c    16 FUNC    GLOBAL DEFAULT    2 endhostent
  7891: 0000f72c   100 FUNC    GLOBAL HIDDEN     2 __cmpsf2
  7892: 0004dda0     4 FUNC    GLOBAL DEFAULT    2 __dn_comp
  7893: 00116904     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_log_host_add
  7894: 00075690   164 FUNC    GLOBAL DEFAULT    2 rtems_rfs_group_usage
  7895: 00052464    76 FUNC    GLOBAL DEFAULT    2 symlink
  7896: 000702e8   340 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_map_find
  7897: 0005786c    68 FUNC    GLOBAL DEFAULT    2 in_setsockaddr
  7898: 00017590   100 FUNC    GLOBAL DEFAULT    2 gettimeofday
  7899: 00073064   548 FUNC    GLOBAL DEFAULT    2 rtems_rfs_file_io_start
  7900: 00114a7c     6 OBJECT  GLOBAL DEFAULT   14 ostype
  7901: 0010aacc   256 OBJECT  GLOBAL DEFAULT    6 e2a_POSIX
  7902: 00113e68    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_UNSETENV_Comm
  7903: 00124cbc    20 OBJECT  GLOBAL DEFAULT   15 ipintrq
  7904: 0005a7fc   116 FUNC    GLOBAL DEFAULT    2 ip_slowtimo
  7905: 0007fd38    32 FUNC    GLOBAL DEFAULT    2 fopen
  7906: 000099dc   120 FUNC    GLOBAL DEFAULT    2 whetstone_command
  7907: 000919dc   124 FUNC    GLOBAL DEFAULT    2 asctime_r
  7908: 00113a28    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MALLOC_INFO_C
  7909: 00113c28    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MSDOSFMT_Alia
  7910: 000822b8   128 FUNC    GLOBAL DEFAULT    2 getopt
  7911: 00050ef8   188 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_iterate
  7912: 00023d38   156 FUNC    GLOBAL DEFAULT    2 sbappendrecord
  7913: 0002946c    20 FUNC    GLOBAL DEFAULT    2 _Objects_Close
  7914: 000283c0    24 FUNC    GLOBAL DEFAULT    2 rtems_initialize_start_mu
  7915: 000827c4    32 FUNC    GLOBAL DEFAULT    2 localtime
  7916: 00083398   244 FUNC    GLOBAL DEFAULT    2 memset
  7917: 00110830     0 NOTYPE  GLOBAL DEFAULT   12 __stop_set_sysctl_set
  7918: 0004f8ec   808 FUNC    GLOBAL DEFAULT    2 __loc_ntoa
  7919: 00024844    52 FUNC    GLOBAL DEFAULT    2 sodisconnect
  7920: 0009158c    68 FUNC    GLOBAL DEFAULT    2 __wcwidth
  7921: 0006dd7c    68 FUNC    GLOBAL DEFAULT    2 rtems_shell_verrx
  7922: 00123cf8     4 OBJECT  GLOBAL DEFAULT   15 bsp_boot_cmdline
  7923: 00067b88   108 FUNC    GLOBAL DEFAULT    2 _Timespec_Divide_by_integ
  7924: 0004b4ec    16 FUNC    GLOBAL DEFAULT    2 rtems_cpu_usage_top
  7925: 0003e898   228 FUNC    GLOBAL DEFAULT    2 rtems_shell_cp_copy_link
  7926: 00076148    80 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_get_size
  7927: 00058a48   668 FUNC    GLOBAL DEFAULT    2 icmp_error
  7928: 00101588    39 OBJECT  GLOBAL DEFAULT    6 _RTEMS_version
  7929: 0003ea08   144 FUNC    GLOBAL DEFAULT    2 rtems_shell_cp_copy_speci
  7930: 00123c20     8 OBJECT  GLOBAL DEFAULT   15 T1
  7931: 00022710   300 FUNC    GLOBAL DEFAULT    2 m_adj
  7932: 0007dbcc   280 FUNC    GLOBAL DEFAULT    2 rtems_monitor_init_task_d
  7933: 00080a5c    56 FUNC    GLOBAL DEFAULT    2 ftell
  7934: 001249c8     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_inet_tcp_chil
  7935: 0007c9e8  1552 FUNC    GLOBAL DEFAULT    2 _Heap_Walk
  7936: 0000f378   172 FUNC    GLOBAL HIDDEN     2 __aeabi_l2f
  7937: 00078984    76 FUNC    GLOBAL DEFAULT    2 __ns_name_compress
  7938: 0009156c    32 FUNC    GLOBAL DEFAULT    2 __swbuf
  7939: 000849bc    32 FUNC    GLOBAL DEFAULT    2 srand
  7940: 00011aa0    84 FUNC    GLOBAL DEFAULT    2 IMFS_node_remove_director
  7941: 00045854    16 FUNC    GLOBAL DEFAULT    2 rtems_trace_signatures
  7942: 001243b0     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_microseconds
  7943: 00060888   568 FUNC    GLOBAL DEFAULT    2 rt_setgate
  7944: 0000f724   108 FUNC    GLOBAL HIDDEN     2 __ltsf2
  7945: 0007fee8   560 FUNC    GLOBAL DEFAULT    2 _fread_r
  7946: 0002c534    48 FUNC    GLOBAL DEFAULT    2 _Workspace_Allocate_or_fa
  7947: 000864a8   192 FUNC    GLOBAL DEFAULT    2 strlcat
  7948: 001249a8     4 OBJECT  GLOBAL DEFAULT   15 ifnet_addrs
  7949: 0002903c   276 FUNC    GLOBAL DEFAULT    2 _Heap_Initialize
  7950: 0009af48     0 FUNC    GLOBAL HIDDEN     2 __aeabi_uidiv
  7951: 00066c5c    24 FUNC    GLOBAL DEFAULT    2 _RTEMS_tasks_Initialize_u
  7952: 00073948    60 FUNC    GLOBAL DEFAULT    2 rtems_rfs_file_get_shared
  7953: 00008000     0 NOTYPE  GLOBAL DEFAULT   16 RamBase
  7954: 00010ad4    24 FUNC    GLOBAL DEFAULT    2 rtems_blkdev_generic_clos
  7955: 0004a478    12 FUNC    GLOBAL DEFAULT    2 rtems_cpu_usage_report_wi
  7956: 00022658   184 FUNC    GLOBAL DEFAULT    2 m_cat
  7957: 000858f8    20 FUNC    GLOBAL DEFAULT    2 __sclose
  7958: 000518d4    44 FUNC    GLOBAL DEFAULT    2 getgrnam_r
  7959: 0000e4b4     8 FUNC    GLOBAL DEFAULT    2 matherr
  7960: 00061594   652 FUNC    GLOBAL DEFAULT    2 rtinit
  7961: 0006b184    44 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_next
  7962: 0005d5c8   260 FUNC    GLOBAL DEFAULT    2 sysctl_ctx_free
  7963: 00124ea0     4 OBJECT  GLOBAL DEFAULT   15 tcp_now
  7964: 00124cdc     4 OBJECT  GLOBAL DEFAULT   15 sysctl__net_children
  7965: 0007f34c    24 FUNC    GLOBAL DEFAULT    2 fclose
  7966: 00087fac   476 FUNC    GLOBAL DEFAULT    2 _strtol_r
  7967: 0000f0d8   160 FUNC    GLOBAL HIDDEN     2 __truncdfsf2
  7968: 00081800   208 FUNC    GLOBAL DEFAULT    2 _findenv_r
  7969: 001156d8     0 NOTYPE  GLOBAL DEFAULT   14 bsp_section_data_end
  7970: 0004d7d8    84 FUNC    GLOBAL DEFAULT    2 inet_ntoa
  7971: 00050e70    48 FUNC    GLOBAL DEFAULT    2 malloc_info
  7972: 0010a9cc   256 OBJECT  GLOBAL DEFAULT    6 a2e_POSIX
  7973: 000524bc    12 FUNC    GLOBAL DEFAULT    2 tcgetattr
  7974: 0006e5d4    48 FUNC    GLOBAL DEFAULT    2 rtems_monitor_id_fixup
  7975: 0003c238    24 FUNC    GLOBAL DEFAULT    2 rtems_shell_can_see_cmd
  7976: 000146d4    32 FUNC    GLOBAL DEFAULT    2 gethostbyaddr_r
  7977: 00091c98  5788 FUNC    GLOBAL DEFAULT    2 _dtoa_r
  7978: 0004f428  1220 FUNC    GLOBAL DEFAULT    2 __loc_aton
  7979: 00124774     4 OBJECT  GLOBAL DEFAULT   15 _Debug_Level
  7980: 0009b744     8 FUNC    GLOBAL DEFAULT    2 _malloc_r
  7981: 0006ed00    64 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_modes
  7982: 0009aed0    40 FUNC    GLOBAL DEFAULT    2 __ascii_wctomb
  7983: 0008c768    68 FUNC    GLOBAL DEFAULT    2 time
  7984: 00083c9c   168 FUNC    GLOBAL DEFAULT    2 opendir
  7985: 00067ee8    88 FUNC    GLOBAL DEFAULT    2 rtems_shell_cat_file
  7986: 00114c0c     4 OBJECT  GLOBAL DEFAULT   14 tcp_mssdflt
  7987: 0000b384   136 FUNC    GLOBAL DEFAULT    2 P3
  7988: 0004856c   260 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_set_block_siz
  7989: 0007b334   212 FUNC    GLOBAL DEFAULT    2 getgroups
  7990: 0006ef48   188 FUNC    GLOBAL DEFAULT    2 rtems_monitor_region_dump
  7991: 00018dac   164 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  7992: 0000ea3c    96 FUNC    GLOBAL HIDDEN     2 __aeabi_l2d
  7993: 00012f34   100 FUNC    GLOBAL DEFAULT    2 IMFS_unmount
  7994: 000577d0   156 FUNC    GLOBAL DEFAULT    2 in_pcbdetach
  7995: 00008040     0 NOTYPE  GLOBAL DEFAULT    1 bsp_start_vector_table_en
  7996: 0006e398    36 FUNC    GLOBAL DEFAULT    2 rtems_monitor_suspend
  7997: 00074154   124 FUNC    GLOBAL DEFAULT    2 rtems_rfs_fs_close
  7998: 00068c44    16 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_def_close
  7999: 00078af0   284 FUNC    GLOBAL DEFAULT    2 __ns_initparse
  8000: 00121488    20 OBJECT  GLOBAL DEFAULT   15 Task_id
  8001: 0002c644     0 NOTYPE  GLOBAL DEFAULT    2 _ARMV4_Exception_pref_abo
  8002: 0008d0ac   176 FUNC    GLOBAL DEFAULT    2 __submore
  8003: 0009333c     4 FUNC    GLOBAL DEFAULT    2 __env_unlock
  8004: 00061124    68 FUNC    GLOBAL DEFAULT    2 rtalloc_ign
  8005: 0001c7e8    48 FUNC    GLOBAL DEFAULT    2 hzto
  8006: 000287a0   152 FUNC    GLOBAL DEFAULT    2 _API_Mutex_Unlock
  8007: 000080dc     4 FUNC    GLOBAL DEFAULT    1 bsp_start_hook_0
  8008: 00018918    92 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  8009: 000817b4    36 FUNC    GLOBAL DEFAULT    2 _findenv
  8010: 000810b4   132 FUNC    GLOBAL DEFAULT    2 _fwalk
  8011: 00077f60    48 FUNC    GLOBAL DEFAULT    2 syslog
  8012: 00066cb0    96 FUNC    GLOBAL DEFAULT    2 _RTEMS_tasks_Manager_init
  8013: 00068c54   732 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_block
  8014: 00029b40   192 FUNC    GLOBAL DEFAULT    2 _Objects_Initialize_infor
  8015: 0007e314   240 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_map_allo
  8016: 00119010     4 OBJECT  WEAK   DEFAULT   15 __rtld_tbg_buffer
  8017: 00052160    24 FUNC    GLOBAL DEFAULT    2 seteuid
  8018: 0001a45c  1116 FUNC    GLOBAL DEFAULT    2 rtems_termios_ioctl
  8019: 0006c958    24 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_badsf
  8020: 0007f72c   296 FUNC    GLOBAL DEFAULT    2 _fgets_r
  8021: 00019194    32 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_global_l
  8022: 00082f60    84 FUNC    GLOBAL DEFAULT    2 _mbtowc_r
  8023: 0000f368   188 FUNC    GLOBAL HIDDEN     2 __aeabi_ul2f
  8024: 0000bac8   408 FUNC    GLOBAL DEFAULT    2 exp
  8025: 00021b68   160 FUNC    GLOBAL DEFAULT    2 m_gethdr
  8026: 0007e268   172 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_map_clea
  8027: 00083ee4   168 FUNC    GLOBAL DEFAULT    2 putc
  8028: 00050d8c    12 FUNC    GLOBAL DEFAULT    2 _link_r
  8029: 0000f7a0    24 FUNC    GLOBAL HIDDEN     2 __aeabi_cfcmple
  8030: 0009b05c   296 FUNC    GLOBAL HIDDEN     2 __divsi3
  8031: 0011391c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_SHUTDOWN_Comm
  8032: 000823bc   132 FUNC    GLOBAL DEFAULT    2 getopt_long_only
  8033: 0002782c   360 FUNC    GLOBAL DEFAULT    2 rtems_semaphore_delete
  8034: 00040eec    48 FUNC    GLOBAL DEFAULT    2 rtems_shell_warnx
  8035: 00023a9c   256 FUNC    GLOBAL DEFAULT    2 sbappendcontrol
  8036: 0005abb4     8 FUNC    GLOBAL DEFAULT    2 _mrt_ioctl
  8037: 00021c08   184 FUNC    GLOBAL DEFAULT    2 m_getclr
  8038: 00069544   184 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_pos_out
  8039: 001248c0     4 OBJECT  GLOBAL DEFAULT   15 linkf
  8040: 0011c0fc     4 OBJECT  GLOBAL DEFAULT   15 ipforwarding
  8041: 0011b98c     4 OBJECT  GLOBAL DEFAULT   15 if_index
  8042: 00017b14   872 FUNC    GLOBAL DEFAULT    2 mount
  8043: 0006f650   224 FUNC    GLOBAL DEFAULT    2 rtems_monitor_symbol_dump
  8044: 0000f424   408 FUNC    GLOBAL HIDDEN     2 __mulsf3
  8045: 00123c28     4 OBJECT  GLOBAL DEFAULT   15 L
  8046: 000081f4   228 FUNC    GLOBAL DEFAULT    1 bsp_memory_management_ini
  8047: 0004f1c4   288 FUNC    GLOBAL DEFAULT    2 __p_option
  8048: 0007ece0   188 FUNC    GLOBAL DEFAULT    2 inet_nsap_ntoa
  8049: 0002a2f4   588 FUNC    GLOBAL DEFAULT    2 _RBTree_Insert
  8050: 0000e298    16 FUNC    GLOBAL DEFAULT    2 finite
  8051: 001002f8    16 OBJECT  GLOBAL DEFAULT    6 rtems_shell_Initial_alias
  8052: 0001176c   176 FUNC    GLOBAL DEFAULT    2 rtems_disk_io_initialize
  8053: 0004b514     8 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8054: 00076794   660 FUNC    GLOBAL DEFAULT    2 rtems_rfs_symlink
  8055: 00051664    52 FUNC    GLOBAL DEFAULT    2 getpwuid_r
  8056: 0004d6ac   236 FUNC    GLOBAL DEFAULT    2 herror
  8057: 0007c6a4   188 FUNC    GLOBAL DEFAULT    2 _Rate_monotonic_Timeout
  8058: 0007e820   404 FUNC    GLOBAL DEFAULT    2 __b64_ntop
  8059: 0008cbbc    20 FUNC    GLOBAL DEFAULT    2 _tzset_unlocked
  8060: 0007dff8    32 FUNC    GLOBAL DEFAULT    2 rtems_rfs_bitmap_mask_sec
  8061: 00085ad8   548 FUNC    GLOBAL DEFAULT    2 strcmp
  8062: 0007a9bc   120 FUNC    GLOBAL DEFAULT    2 __ns_sprintrr
  8063: 0001e050    96 FUNC    GLOBAL DEFAULT    2 shutdown
  8064: 001243b4    16 OBJECT  GLOBAL DEFAULT   15 calltodo
  8065: 000946ec   116 FUNC    GLOBAL DEFAULT    2 siscanf
  8066: 0002c368   392 FUNC    GLOBAL DEFAULT    2 _Workspace_Handler_initia
  8067: 0002842c    20 FUNC    GLOBAL DEFAULT    2 rtems_fatal_error_occurre
  8068: 00071bcc  1080 FUNC    GLOBAL DEFAULT    2 rtems_rfs_dir_add_entry
  8069: 0003c688    16 FUNC    GLOBAL DEFAULT    2 rtems_shell_get_current_e
  8070: 0000ff1c     8 FUNC    GLOBAL DEFAULT    2 console_write
  8071: 00050e64    12 FUNC    GLOBAL DEFAULT    2 _lstat_r
  8072: 00123d00  1152 OBJECT  GLOBAL DEFAULT   15 bsp_interrupt_handler_tab
  8073: 0008c810    64 FUNC    GLOBAL DEFAULT    2 ttyname
  8074: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_stack_svc_size
  8075: 0009a004    40 FUNC    GLOBAL DEFAULT    2 vfiprintf
  8076: 0006ff80    64 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_get_size
  8077: 00050ba4    56 FUNC    GLOBAL DEFAULT    2 getpwuid
  8078: 0005aae4   120 FUNC    GLOBAL DEFAULT    2 ip_rsvp_init
  8079: 0011098c    24 OBJECT  GLOBAL DEFAULT   14 rtems_nvdisk_io_ops
  8080: 0005de0c   252 FUNC    GLOBAL DEFAULT    2 kernel_sysctl
  8081: 00028080    88 FUNC    GLOBAL DEFAULT    2 rtems_task_ident
  8082: 00043d94   180 FUNC    GLOBAL DEFAULT    2 rtems_rfs_rtems_set_handl
  8083: 00050fe8   260 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_register
  8084: 0000e670    16 FUNC    GLOBAL DEFAULT    2 copysign
  8085: 0008129c  1304 FUNC    GLOBAL DEFAULT    2 getcwd
  8086: 000454ec    36 FUNC    GLOBAL DEFAULT    2 rtems_rfs_trace
  8087: 0000ef48   136 FUNC    GLOBAL HIDDEN     2 __nedf2
  8088: 0002c0b0   292 FUNC    GLOBAL DEFAULT    2 _Watchdog_Insert
  8089: 0004cb58   656 FUNC    GLOBAL DEFAULT    2 _gethostbydnsaddr
  8090: 00021748   108 FUNC    GLOBAL DEFAULT    2 pffindtype
  8091: 00010554    88 FUNC    GLOBAL DEFAULT    2 bsp_interrupt_dispatch
  8092: 000145f8    64 FUNC    GLOBAL DEFAULT    2 gethostbyname
  8093: 00050b6c    56 FUNC    GLOBAL DEFAULT    2 getpwnam
  8094: 00060284    20 FUNC    GLOBAL DEFAULT    2 raw_init
  8095: 0004b5c4     8 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8096: 001133c0     4 OBJECT  GLOBAL DEFAULT   14 tcp_sendspace
  8097: 00076198   456 FUNC    GLOBAL DEFAULT    2 rtems_rfs_link
  8098: 0009b81c     0 FUNC    GLOBAL DEFAULT    4 _fini
  8099: 00106c90    76 OBJECT  GLOBAL DEFAULT    6 rtems_rfs_ops
  8100: 001001f4     4 OBJECT  GLOBAL DEFAULT    6 rtems_libio_post_driver_h
  8101: 0001b480    12 FUNC    GLOBAL DEFAULT    2 rtems_termios_rxirq_occur
  8102: 0003efa4     8 FUNC    GLOBAL DEFAULT    2 preserve_fd_acls
  8103: 000704b8    48 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_map_next_
  8104: 001136c4    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_BLKSTATS_Comm
  8105: 0005ac40     4 FUNC    GLOBAL DEFAULT    2 ipip_input
  8106: 00124828    52 OBJECT  GLOBAL DEFAULT   15 _POSIX_Objects
  8107: 00028318   148 FUNC    GLOBAL DEFAULT    2 rtems_initialize_data_str
  8108: 0000b430  1168 FUNC    GLOBAL DEFAULT    2 atan
  8109: 0007f6c8   100 FUNC    GLOBAL DEFAULT    2 fgetc
  8110: 000662f0    68 FUNC    GLOBAL DEFAULT    2 _Partition_Manager_initia
  8111: 0007b61c   272 FUNC    GLOBAL DEFAULT    2 igmp_init
  8112: 0001fc10    48 FUNC    GLOBAL DEFAULT    2 gethostname
  8113: 0008568c   104 FUNC    GLOBAL DEFAULT    2 sprintf
  8114: 0007c8e0    92 FUNC    GLOBAL DEFAULT    2 _Heap_Get_information
  8115: 0006dbdc   288 FUNC    GLOBAL DEFAULT    2 rtems_shell_make_args
  8116: 00053190    68 FUNC    GLOBAL DEFAULT    2 MD5Init
  8117: 0006ecc0    64 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_attrib
  8118: 00124cf0     4 OBJECT  GLOBAL DEFAULT   15 sysctl__children
  8119: 0001b018   200 FUNC    GLOBAL DEFAULT    2 rtems_termios_write
  8120: 00124778    12 OBJECT  GLOBAL DEFAULT   15 _Watchdog_Seconds_header
  8121: 0007f01c   116 FUNC    GLOBAL DEFAULT    2 asprintf
  8122: 0011c4e8     4 OBJECT  GLOBAL DEFAULT   15 _PathLocale
  8123: 00050934    72 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_location
  8124: 00050150    44 FUNC    GLOBAL DEFAULT    2 rtems_cache_aligned_mallo
  8125: 00028b28   276 FUNC    GLOBAL DEFAULT    2 _CORE_mutex_Surrender
  8126: 0007d6ec    40 FUNC    GLOBAL DEFAULT    2 rtems_monitor_driver_dump
  8127: 00125074    56 OBJECT  GLOBAL DEFAULT   15 _Message_queue_Informatio
  8128: 0001d55c   204 FUNC    GLOBAL DEFAULT    2 m_mballoc
  8129: 0011f400     4 OBJECT  GLOBAL DEFAULT   15 cpu_mailbox_write_set_reg
  8130: 0001141c   204 FUNC    GLOBAL DEFAULT    2 rtems_disk_create_phys
  8131: 0007be0c    44 FUNC    GLOBAL DEFAULT    2 raw_detach
  8132: 00095f54    80 FUNC    GLOBAL DEFAULT    2 strtof
  8133: 0007dba4    40 FUNC    GLOBAL DEFAULT    2 rtems_monitor_init_task_d
  8134: 0007f090    32 FUNC    GLOBAL DEFAULT    2 atexit
  8135: 0002852c    48 FUNC    GLOBAL DEFAULT    2 _API_extensions_Run_postd
  8136: 0001c85c    68 FUNC    GLOBAL DEFAULT    2 in_cksum_hdr
  8137: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_nocache_size
  8138: 0000f71c   116 FUNC    GLOBAL HIDDEN     2 __gesf2
  8139: 0006e1e0   188 FUNC    GLOBAL DEFAULT    2 rtems_monitor_command_usa
  8140: 0009b7f4    16 FUNC    GLOBAL DEFAULT    2 _write_r
  8141: 0002bd34    36 FUNC    GLOBAL DEFAULT    2 _Thread_Start_multitaskin
  8142: 000270f8    28 FUNC    GLOBAL DEFAULT    2 rtems_clock_set_nanosecon
  8143: 0009b610     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_flush_entire_
  8144: 0009b648     8 FUNC    GLOBAL DEFAULT    2 rtems_cache_get_instructi
  8145: 00008000     0 NOTYPE  GLOBAL DEFAULT    1 bsp_section_start_begin
  8146: 0011638c     4 OBJECT  GLOBAL DEFAULT   15 Console_Port_Minor
  8147: 00000008     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_stack_align
  8148: 00082c2c    32 FUNC    GLOBAL DEFAULT    2 setlocale
  8149: 0001e878     8 FUNC    GLOBAL DEFAULT    2 getpeername
  8150: 07ffc000     0 NOTYPE  GLOBAL DEFAULT   17 bsp_section_stack_end
  8151: 00027fd0   176 FUNC    GLOBAL DEFAULT    2 rtems_task_delete
  8152: 00084eb0    56 FUNC    GLOBAL DEFAULT    2 scanf
  8153: 0000f178   456 FUNC    GLOBAL HIDDEN     2 __aeabi_frsub
  8154: 001138d4    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_EDIT_Command
  8155: 0006eaec    36 FUNC    GLOBAL DEFAULT    2 rtems_monitor_separator
  8156: 00018a20   116 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  8157: 001136e4    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_BLKSYNC_Comma
  8158: 00116388     4 OBJECT  GLOBAL DEFAULT   15 Console_Port_Data
  8159: 000105ac    68 FUNC    GLOBAL DEFAULT    2 bsp_interrupt_vector_enab
  8160: 000093fc   512 FUNC    GLOBAL DEFAULT    2 WriteTestCmd
  8161: 00076360  1076 FUNC    GLOBAL DEFAULT    2 rtems_rfs_unlink
  8162: 0009b65c     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_disable_instr
  8163: 0002a5dc     4 FUNC    GLOBAL DEFAULT    2 _Scheduler_default_Releas
  8164: 0002a5d4     4 FUNC    GLOBAL DEFAULT    2 _Scheduler_default_Node_d
  8165: 00094610    12 FUNC    GLOBAL DEFAULT    2 nanf
  8166: 00114f48     4 OBJECT  GLOBAL DEFAULT   14 _impure_ptr
  8167: 0002983c    20 FUNC    GLOBAL DEFAULT    2 _Objects_Get_information_
  8168: 00009a54    48 FUNC    GLOBAL DEFAULT    2 Proc_2
  8169: 0000f7b8    24 FUNC    GLOBAL HIDDEN     2 __aeabi_fcmpeq
  8170: 00040f1c   156 FUNC    GLOBAL DEFAULT    2 rtems_string_to_int
  8171: 0004b538    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8172: 0007f364   628 FUNC    GLOBAL DEFAULT    2 __sflush_r
  8173: 00021100  1092 FUNC    GLOBAL DEFAULT    2 udp_usrreq
  8174: 0000e4d0   412 FUNC    GLOBAL DEFAULT    2 scalbn
  8175: 00082dd8   156 FUNC    GLOBAL DEFAULT    2 _mbrtowc_r
  8176: 0006f4ac   116 FUNC    GLOBAL DEFAULT    2 rtems_symbol_name_lookup
  8177: 000780f0    24 FUNC    GLOBAL DEFAULT    2 setlogmask
  8178: 000092c4   124 FUNC    GLOBAL DEFAULT    2 shell_init_script
  8179: 0000f424   408 FUNC    GLOBAL HIDDEN     2 __aeabi_fmul
  8180: 00082c18     8 FUNC    GLOBAL DEFAULT    2 __locale_cjk_lang
  8181: 0009b758   156 FUNC    GLOBAL DEFAULT    2 _rename_r
  8182: 000484d4   100 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_syncdev
  8183: 00100044     4 OBJECT  GLOBAL DEFAULT    6 _Thread_Control_add_on_co
  8184: 00066618   176 FUNC    GLOBAL DEFAULT    2 rtems_rate_monotonic_rese
  8185: 0000c370  1456 FUNC    GLOBAL DEFAULT    2 __ieee754_log
  8186: 00087668    28 FUNC    GLOBAL DEFAULT    2 strsep
  8187: 000205f8   588 FUNC    GLOBAL DEFAULT    2 tcp_ctloutput
  8188: 000803f4    32 FUNC    GLOBAL DEFAULT    2 _fseek_r
  8189: 0001a04c   240 FUNC    GLOBAL DEFAULT    2 rtems_termios_device_remo
  8190: 000531d4   188 FUNC    GLOBAL DEFAULT    2 MD5Update
  8191: 07ffc000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_nocache_load_
  8192: 0001c574    64 FUNC    GLOBAL DEFAULT    2 soconnsleep
  8193: 00050ea0    24 FUNC    GLOBAL DEFAULT    2 malloc_walk
  8194: 00052530    44 FUNC    GLOBAL DEFAULT    2 rtems_current_user_env_ge
  8195: 000963c8  4776 FUNC    GLOBAL DEFAULT    2 _svfiprintf_r
  8196: 000283ac     4 FUNC    GLOBAL DEFAULT    2 rtems_initialize_before_d
  8197: 00051638    44 FUNC    GLOBAL DEFAULT    2 getpwnam_r
  8198: 00084be8   480 FUNC    GLOBAL DEFAULT    2 __srefill_r
  8199: 0003a074    52 FUNC    GLOBAL DEFAULT    2 rtems_shell_print_heap_in
  8200: 0000f790    40 FUNC    GLOBAL HIDDEN     2 __aeabi_cfrcmple
  8201: 00113de8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_TOP_Command
  8202: 00048538    52 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_purge_dev
  8203: 00026dbc   624 FUNC    GLOBAL DEFAULT    2 rtems_clock_get_tod
  8204: 00068fa0   340 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_unblock
  8205: 0005d308    20 FUNC    GLOBAL DEFAULT    2 sysctl_ctx_init
  8206: 00067b20   104 FUNC    GLOBAL DEFAULT    2 _Thread_queue_Process_tim
  8207: 00068944   652 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_jcl
  8208: 00124784     4 OBJECT  GLOBAL DEFAULT   15 _Watchdog_Sync_count
  8209: 00040ebc    48 FUNC    GLOBAL DEFAULT    2 rtems_shell_warn
  8210: 00082f14    76 FUNC    GLOBAL DEFAULT    2 __ascii_mbtowc
  8211: 00028d38    56 FUNC    GLOBAL DEFAULT    2 _TOD_Handler_initializati
  8212: 00009ccc    88 FUNC    GLOBAL DEFAULT    2 Func_2
  8213: 0006d458   916 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_newsy
  8214: 0004f0e0    32 FUNC    GLOBAL DEFAULT    2 __p_query
  8215: 00106188   304 OBJECT  GLOBAL DEFAULT    6 rtems_global_shell_env
  8216: 0011695c    16 OBJECT  GLOBAL DEFAULT   15 _POSIX_Keys_Key_value_loo
  8217: 0011637c     4 OBJECT  GLOBAL DEFAULT   15 Console_Port_Count
  8218: 000563a0    84 FUNC    GLOBAL DEFAULT    2 in_canforward
  8219: 00094040   100 FUNC    GLOBAL DEFAULT    2 __ulp
  8220: 00050a18    88 FUNC    GLOBAL DEFAULT    2 fsync
  8221: 00106c64    12 OBJECT  GLOBAL DEFAULT    6 rtems_nvdisk_sram_handler
  8222: 0007fbe0    28 FUNC    GLOBAL DEFAULT    2 __fp_unlock_all
  8223: 0011415c     6 OBJECT  GLOBAL DEFAULT   14 etherbroadcastaddr
  8224: 001248bc     4 OBJECT  GLOBAL DEFAULT   15 _Watchdog_Ticks_since_boo
  8225: 0004b744    28 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8226: 000270b4    68 FUNC    GLOBAL DEFAULT    2 rtems_clock_get_uptime_ti
  8227: 0006e29c    80 FUNC    GLOBAL DEFAULT    2 rtems_monitor_help_cmd
  8228: 00060878    16 FUNC    GLOBAL DEFAULT    2 rtioctl
  8229: 0003efac     8 FUNC    GLOBAL DEFAULT    2 preserve_dir_acls
  8230: 0007fe00    60 FUNC    GLOBAL DEFAULT    2 fputc
  8231: 0004df38     4 FUNC    GLOBAL DEFAULT    2 __putlong
  8232: 0007c3a0   772 FUNC    GLOBAL DEFAULT    2 rtems_rate_monotonic_peri
  8233: 00048fc4   644 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_read
  8234: 000486b8    60 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_reset_device_
  8235: 0004b524    20 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8236: 000096f0   144 FUNC    GLOBAL DEFAULT    2 setup_filesystems
  8237: 00048030   456 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_read
  8238: 0011374c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_CHMOD_Command
  8239: 0005e9b4   264 FUNC    GLOBAL DEFAULT    2 rn_refines
  8240: 00042ddc   188 FUNC    GLOBAL DEFAULT    2 ramdisk_register
  8241: 0002477c    16 FUNC    GLOBAL DEFAULT    2 sobind
  8242: 0004b888    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8243: 00114f40     4 OBJECT  GLOBAL DEFAULT   14 optopt
  8244: 000458d4    16 FUNC    GLOBAL DEFAULT    2 rtems_trace_buffering_buf
  8245: 0008c7ac    36 FUNC    GLOBAL DEFAULT    2 __get_current_time_locale
  8246: 0005ab9c     8 FUNC    GLOBAL DEFAULT    2 _ip_mrouter_get
  8247: 00067a58    96 FUNC    GLOBAL DEFAULT    2 _Protected_heap_Walk
  8248: 000610e0    68 FUNC    GLOBAL DEFAULT    2 rtalloc
  8249: 00077c6c    12 FUNC    GLOBAL DEFAULT    2 uuid_unparse_upper
  8250: 00113ae8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MFILL_Command
  8251: 001138f4     8 OBJECT  GLOBAL DEFAULT   14 rtems_shell_EXIT_Alias
  8252: 0004e6b8    80 FUNC    GLOBAL DEFAULT    2 __p_fqname
  8253: 0009b1a8    84 FUNC    GLOBAL HIDDEN     2 __aeabi_d2uiz
  8254: 0001e664   532 FUNC    GLOBAL DEFAULT    2 getsockopt
  8255: 00009818   368 FUNC    GLOBAL DEFAULT    2 task_command
  8256: 00009340   188 FUNC    GLOBAL DEFAULT    2 rtems_add_local_cmds
  8257: 00116930     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_bootp_server
  8258: 0002a8f0    88 FUNC    GLOBAL DEFAULT    2 _Scheduler_priority_Initi
  8259: 0004df0c    44 FUNC    GLOBAL DEFAULT    2 __res_dnok
  8260: 00009b14    88 FUNC    GLOBAL DEFAULT    2 Proc_6
  8261: 0011c698     4 OBJECT  GLOBAL DEFAULT   15 _timezone
  8262: 000827e4   912 FUNC    GLOBAL DEFAULT    2 localtime_r
  8263: 0004d798    64 FUNC    GLOBAL DEFAULT    2 hstrerror
  8264: 0000919c     8 FUNC    GLOBAL DEFAULT    2 rtems_init_network
  8265: 0011320c    12 OBJECT  GLOBAL DEFAULT   14 RTEMS_Malloc_GC_list
  8266: 0006f520   136 FUNC    GLOBAL DEFAULT    2 rtems_monitor_symbol_next
  8267: 0006656c    12 FUNC    GLOBAL DEFAULT    2 rtems_rate_monotonic_repo
  8268: 0000e4bc    16 FUNC    GLOBAL DEFAULT    2 nan
  8269: 0000fd20   288 FUNC    GLOBAL DEFAULT    2 console_initialize
  8270: 0002c7b4    32 FUNC    GLOBAL DEFAULT    2 _CPU_ISR_Set_level
  8271: 0004b5e4    88 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8272: 000978a8  4236 FUNC    GLOBAL DEFAULT    2 __ssvfiscanf_r
  8273: 0006a5e4   292 FUNC    GLOBAL DEFAULT    2 rtems_shell_fts_close
  8274: 00054bcc   324 FUNC    GLOBAL DEFAULT    2 looutput
  8275: 000236b4    84 FUNC    GLOBAL DEFAULT    2 soisdisconnected
  8276: 00010f64    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8277: 00124788     4 OBJECT  GLOBAL DEFAULT   15 rtems_ada_self
  8278: 00067fbc    84 FUNC    GLOBAL DEFAULT    2 rtems_shell_main_monitor
  8279: 0000f7d0    24 FUNC    GLOBAL HIDDEN     2 __aeabi_fcmplt
  8280: 00005040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_secondary_proce
  8281: 0005ab94     8 FUNC    GLOBAL DEFAULT    2 _ip_mrouter_set
  8282: 0012478c    56 OBJECT  GLOBAL DEFAULT   15 _Thread_Internal_informat
  8283: 00082c4c    24 FUNC    GLOBAL DEFAULT    2 localeconv
  8284: 001138fc    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_GETENV_Comman
  8285: 000260ec   412 FUNC    GLOBAL DEFAULT    2 soclose
  8286: 00008000     0 NOTYPE  GLOBAL DEFAULT    1 bsp_start_vector_table_be
  8287: 00000004     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_processor_count
  8288: 00045220   716 FUNC    GLOBAL DEFAULT    2 rtems_shell_rfs_format
  8289: 00051434   292 FUNC    GLOBAL DEFAULT    2 _libcsupport_scanpw
  8290: 0000cf68   544 FUNC    GLOBAL DEFAULT    2 __ieee754_sqrt
  8291: 001168f4     4 OBJECT  GLOBAL DEFAULT   15 callfree
  8292: 0004b63c   264 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8293: 0004dd28    32 FUNC    GLOBAL DEFAULT    2 __ns_put32
  8294: 0006c5d4   592 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_size
  8295: 0006f060    24 FUNC    GLOBAL DEFAULT    2 rtems_monitor_sema_dump_h
  8296: 000185a0    96 FUNC    GLOBAL DEFAULT    2 stat
  8297: 00010ab4    32 FUNC    GLOBAL DEFAULT    2 rtems_blkdev_generic_open
  8298: 000430c4   656 FUNC    GLOBAL DEFAULT    2 rtems_rfs_rtems_fstat
  8299: 00113aa8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MDUMP_Command
  8300: 00114ca0     4 OBJECT  GLOBAL DEFAULT   14 tcp_keepidle
  8301: 00012b1c   164 FUNC    GLOBAL DEFAULT    2 IMFS_mknod
  8302: 00012ed0   100 FUNC    GLOBAL DEFAULT    2 IMFS_readlink
  8303: 00000001     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_rwbarrier_ali
  8304: 00015080    48 FUNC    GLOBAL DEFAULT    2 __res_randomid
  8305: 00113d68    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_SETENV_Comman
  8306: 0009b03c    32 FUNC    GLOBAL HIDDEN     2 __aeabi_uidivmod
  8307: 00044fcc   596 FUNC    GLOBAL DEFAULT    2 rtems_shell_debugrfs
  8308: 0004b7b8    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8309: 00045568   652 FUNC    GLOBAL DEFAULT    2 rtems_rfs_trace_shell_com
  8310: 0000f004    24 FUNC    GLOBAL HIDDEN     2 __aeabi_dcmpeq
  8311: 00113200     4 OBJECT  GLOBAL DEFAULT   14 BSP_output_char
  8312: 0007c310   144 FUNC    GLOBAL DEFAULT    2 _Rate_monotonic_Initiate_
  8313: 00020ac0  1396 FUNC    GLOBAL DEFAULT    2 udp_input
  8314: 0002bb54    52 FUNC    GLOBAL DEFAULT    2 _Thread_Restart
  8315: 001001c0    40 OBJECT  GLOBAL DEFAULT    6 rtems_filesystem_table
  8316: 00081260    60 FUNC    GLOBAL DEFAULT    2 fwrite
  8317: 00085768   128 FUNC    GLOBAL DEFAULT    2 _sscanf_r
  8318: 00050074    84 FUNC    GLOBAL DEFAULT    2 rtems_assoc_local_by_remo
  8319: 0007d680   108 FUNC    GLOBAL DEFAULT    2 rtems_monitor_driver_next
  8320: 0002747c   288 FUNC    GLOBAL DEFAULT    2 _Event_Surrender
  8321: 00100000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_rodata_load_b
  8322: 00113a68    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_LDUMP_Command
  8323: 00110838     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_rodata_load_e
  8324: 00034534    20 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_exit
  8325: 0002c7d4    20 FUNC    GLOBAL DEFAULT    2 _CPU_ISR_Get_level
  8326: 0001c510    68 FUNC    GLOBAL DEFAULT    2 sowakeup
  8327: 0002c1d4    88 FUNC    GLOBAL DEFAULT    2 _Watchdog_Handler_initial
  8328: 0004ffa4   112 FUNC    GLOBAL DEFAULT    2 access
  8329: 00028e48    68 FUNC    GLOBAL DEFAULT    2 _Freechain_Get
  8330: 00048938   308 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_dump
  8331: 00000360     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_start_size
  8332: 00011cf8    48 FUNC    GLOBAL DEFAULT    2 IMFS_fchmod
  8333: 0004ce90    48 FUNC    GLOBAL DEFAULT    2 _endhosthtent
  8334: 0009b638     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_invalidate_mu
  8335: 00055d74   564 FUNC    GLOBAL DEFAULT    2 in_cksum
  8336: 00016280   132 FUNC    GLOBAL DEFAULT    2 __res_isourserver
  8337: 00100ae4    20 OBJECT  GLOBAL DEFAULT    6 rtems_nvdisk_configuratio
  8338: 0011395c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_HEXDUMP_Comma
  8339: 0002662c   704 FUNC    GLOBAL DEFAULT    2 sogetopt
  8340: 00029924   348 FUNC    GLOBAL DEFAULT    2 _Objects_Get_name_as_stri
  8341: 00021648   256 FUNC    GLOBAL DEFAULT    2 domaininit
  8342: 0001d628   204 FUNC    GLOBAL DEFAULT    2 m_clalloc
  8343: 00027614     4 FUNC    GLOBAL DEFAULT    2 rtems_object_get_name
  8344: 000246a4    84 FUNC    GLOBAL DEFAULT    2 sbcreatecontrol
  8345: 000108c0     8 FUNC    GLOBAL DEFAULT    2 libchip_serial_default_pr
  8346: 0009a0d0   300 FUNC    GLOBAL DEFAULT    2 __fputwc
  8347: 00010540    20 FUNC    GLOBAL DEFAULT    2 raspberrypi_set_exception
  8348: 00091268    64 FUNC    GLOBAL DEFAULT    2 vfscanf
  8349: 00114d58    56 OBJECT  GLOBAL DEFAULT   14 _RTEMS_tasks_User_extensi
  8350: 00086ac8  2892 FUNC    GLOBAL DEFAULT    2 strptime
  8351: 0007fe3c   140 FUNC    GLOBAL DEFAULT    2 _fputs_r
  8352: 00084e14    48 FUNC    GLOBAL DEFAULT    2 rewind
  8353: 00067900   132 FUNC    GLOBAL DEFAULT    2 _Heap_Size_of_alloc_area
  8354: 0008cbec  1176 FUNC    GLOBAL DEFAULT    2 _tzset_unlocked_r
  8355: 00026cb4   152 FUNC    GLOBAL DEFAULT    2 rtems_clock_get
  8356: 0001c818    68 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_log
  8357: 0003efb4    56 FUNC    GLOBAL DEFAULT    2 rtems_shell_cp_usage
  8358: 000803cc    40 FUNC    GLOBAL DEFAULT    2 freopen
  8359: 0003f09c   400 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_printescap
  8360: 000522e4   112 FUNC    GLOBAL DEFAULT    2 rtems_deviceio_write
  8361: 0006d958   380 FUNC    GLOBAL DEFAULT    2 rtems_shell_login_prompt
  8362: 00066810    68 FUNC    GLOBAL DEFAULT    2 _Semaphore_Manager_initia
  8363: 0003c0fc   180 FUNC    GLOBAL DEFAULT    2 rtems_shell_add_cmd
  8364: 000241f0    96 FUNC    GLOBAL DEFAULT    2 sbflush
  8365: 0010a0b4   256 OBJECT  GLOBAL DEFAULT    6 __log2table
  8366: 00075800   168 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_load
  8367: 0000fe48   212 FUNC    GLOBAL DEFAULT    2 bsp_console_select
  8368: 0009b674   176 FUNC    GLOBAL DEFAULT    2 getdents
  8369: 0005df08   172 FUNC    GLOBAL DEFAULT    2 kernel_sysctlbyname
  8370: 00028e30    24 FUNC    GLOBAL DEFAULT    2 _Freechain_Initialize
  8371: 000248e4  1892 FUNC    GLOBAL DEFAULT    2 sosend
  8372: 0005f6c8   248 FUNC    GLOBAL DEFAULT    2 rn_init
  8373: 00043e50     4 FUNC    GLOBAL DEFAULT    2 rtems_rfs_rtems_mode
  8374: 0007d714   368 FUNC    GLOBAL DEFAULT    2 rtems_monitor_driver_dump
  8375: 00050598   116 FUNC    GLOBAL DEFAULT    2 rtems_error
  8376: 0002b638    44 FUNC    GLOBAL DEFAULT    2 _Thread_queue_Compare_pri
  8377: 00073994    20 FUNC    GLOBAL DEFAULT    2 rtems_rfs_fs_media_size
  8378: 00018bfc   244 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  8379: 0004cec0   568 FUNC    GLOBAL DEFAULT    2 gethostent
  8380: 0005d8c8   116 FUNC    GLOBAL DEFAULT    2 sysctl_handle_int
  8381: 0005eda8   124 FUNC    GLOBAL DEFAULT    2 rn_lookup
  8382: 0008583c   104 FUNC    GLOBAL DEFAULT    2 __swrite
  8383: 00110838     0 NOTYPE  GLOBAL DEFAULT   13 bsp_section_fast_data_beg
  8384: 00067a0c    76 FUNC    GLOBAL DEFAULT    2 _Protected_heap_Get_infor
  8385: 0009b654     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_unfreeze_inst
  8386: 00050d04   136 FUNC    GLOBAL DEFAULT    2 link
  8387: 001139bc    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_LOGOFF_Comman
  8388: 00070bf4     8 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_map_free_
  8389: 00113e28    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_UMASK_Command
  8390: 00010f3c    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8391: 0002a9c4   144 FUNC    GLOBAL DEFAULT    2 _Scheduler_priority_Unblo
  8392: 00083d44   120 FUNC    GLOBAL DEFAULT    2 _perror_r
  8393: 0006f1cc   328 FUNC    GLOBAL DEFAULT    2 rtems_symbol_create
  8394: 00001440     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_secondary_proce
  8395: 00082c0c    12 FUNC    GLOBAL DEFAULT    2 __locale_msgcharset
  8396: 000557e8  1236 FUNC    GLOBAL DEFAULT    2 ifioctl
  8397: 00052520    16 FUNC    GLOBAL DEFAULT    2 rtems_termios_number_to_b
  8398: 0005f7c0    48 FUNC    GLOBAL DEFAULT    2 rip_init
  8399: 00026000   236 FUNC    GLOBAL DEFAULT    2 socreate
  8400: 0007f21c    52 FUNC    GLOBAL DEFAULT    2 exit
  8401: 0000f878    88 FUNC    GLOBAL DEFAULT    2 bsp_work_area_initialize
  8402: 0001860c   156 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_check_ac
  8403: 000989f8  5644 FUNC    GLOBAL DEFAULT    2 _vfiprintf_r
  8404: 000105f0    68 FUNC    GLOBAL DEFAULT    2 bsp_interrupt_vector_disa
  8405: 00124ff4     4 OBJECT  GLOBAL DEFAULT   15 rtems_monitor_task_id
  8406: 000458f0    32 FUNC    GLOBAL DEFAULT    2 rtems_trace_buffering_buf
  8407: 0004553c    44 FUNC    GLOBAL DEFAULT    2 rtems_rfs_trace_clear_mas
  8408: 00081138   140 FUNC    GLOBAL DEFAULT    2 _fwalk_reent
  8409: 0002434c   532 FUNC    GLOBAL DEFAULT    2 sonewconn1
  8410: 0000f340    40 FUNC    GLOBAL HIDDEN     2 __floatunsisf
  8411: 00093eec   340 FUNC    GLOBAL DEFAULT    2 __mdiff
  8412: 0001c93c    44 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_detach
  8413: 0000f07c    92 FUNC    GLOBAL HIDDEN     2 __aeabi_d2iz
  8414: 00124894     1 OBJECT  GLOBAL DEFAULT   15 _System_state_Current
  8415: 000163f8   312 FUNC    GLOBAL DEFAULT    2 __res_queriesmatch
  8416: 00012098   172 FUNC    GLOBAL DEFAULT    2 IMFS_link
  8417: 00114a84    10 OBJECT  GLOBAL DEFAULT   14 osrelease
  8418: 000091a4     4 FUNC    GLOBAL DEFAULT    2 rtems_start_network_servi
  8419: 00123c2c   200 OBJECT  GLOBAL DEFAULT   15 Arr_1_Glob
  8420: 0000fc98   136 FUNC    GLOBAL DEFAULT    2 console_close
  8421: 001001ec     4 OBJECT  GLOBAL DEFAULT    6 rtems_fs_init_helper
  8422: 00057bc8   352 FUNC    GLOBAL DEFAULT    2 in_pcblookuphash
  8423: 001167e4   256 OBJECT  GLOBAL DEFAULT   15 rtems_termios_linesw
  8424: 00114f38     4 OBJECT  GLOBAL DEFAULT   14 __ctype_ptr__
  8425: 000525e4   260 FUNC    GLOBAL DEFAULT    2 unmount
  8426: 0005ac54     4 FUNC    GLOBAL DEFAULT    2 ip_rsvp_force_done
  8427: 00084f1c    32 FUNC    GLOBAL DEFAULT    2 setbuf
  8428: 0000f7a0    24 FUNC    GLOBAL HIDDEN     2 __aeabi_cfcmpeq
  8429: 0001c5c8    24 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_schednetisr
  8430: 00070900   756 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_map_shrin
  8431: 0011639c     4 OBJECT  GLOBAL DEFAULT   15 BSP_poll_char
  8432: 0003e64c   588 FUNC    GLOBAL DEFAULT    2 rtems_shell_cp_setfile
  8433: 0004d8a4   780 FUNC    GLOBAL DEFAULT    2 inet_ntop
  8434: 000666c8    68 FUNC    GLOBAL DEFAULT    2 _Region_Manager_initializ
  8435: 0002aab8   172 FUNC    GLOBAL DEFAULT    2 _Scheduler_priority_Yield
  8436: 00054884   440 FUNC    GLOBAL DEFAULT    2 ether_delmulti
  8437: 00010644    52 FUNC    GLOBAL DEFAULT    2 bsp_interrupt_facility_in
  8438: 00124cd0     4 OBJECT  GLOBAL DEFAULT   15 ip_fw_chk_ptr
  8439: 0007fbb8     4 FUNC    GLOBAL DEFAULT    2 __sfp_lock_release
  8440: 00050afc    56 FUNC    GLOBAL DEFAULT    2 getgrnam
  8441: 001248d4     4 OBJECT  GLOBAL DEFAULT   15 rtems_panic_in_progress
  8442: 0002c524    16 FUNC    GLOBAL DEFAULT    2 _Workspace_Free
  8443: 0004ba9c   144 FUNC    GLOBAL DEFAULT    2 rtems_disk_init_log
  8444: 0001456c   140 FUNC    GLOBAL DEFAULT    2 gethostbyname2
  8445: 0009b63c     4 FUNC    GLOBAL DEFAULT    2 rtems_cache_invalidate_en
  8446: 00116900     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_domain_name
  8447: 00113da8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_STACKUSE_Comm
  8448: 0002e314    20 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_exit
  8449: 00009af0    36 FUNC    GLOBAL DEFAULT    2 Proc_5
  8450: 00071600   216 FUNC    GLOBAL DEFAULT    2 rtems_rfs_buffer_close
  8451: 00029e48    92 FUNC    GLOBAL DEFAULT    2 _Protected_heap_Resize_bl
  8452: 00094684   104 FUNC    GLOBAL DEFAULT    2 siprintf
  8453: 00071490   120 FUNC    GLOBAL DEFAULT    2 rtems_rfs_buffers_release
  8454: 00043354    80 FUNC    GLOBAL DEFAULT    2 rtems_rfs_rtems_rmnod
  8455: 00124ea4     4 OBJECT  GLOBAL DEFAULT   15 tcp_iss
  8456: 00094534   220 FUNC    GLOBAL DEFAULT    2 __sccl
  8457: 0007f0b0    24 FUNC    GLOBAL DEFAULT    2 atoi
  8458: 0007e540    48 FUNC    GLOBAL DEFAULT    2 rtems_rfs_buffer_bdbuf_re
  8459: 00113a48    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MD5_Command
  8460: 00110838     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_fast_text_loa
  8461: 00008360     0 NOTYPE  GLOBAL DEFAULT    2 bsp_section_text_begin
  8462: 00005040     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_vector_size
  8463: 0002ad18    16 FUNC    GLOBAL DEFAULT    2 _Thread_Delay_ended
  8464: 0010f68c   257 OBJECT  GLOBAL DEFAULT    6 _ctype_
  8465: 000238a0   508 FUNC    GLOBAL DEFAULT    2 sbappendaddr
  8466: 0000f968   168 FUNC    GLOBAL DEFAULT    2 Clock_initialize
  8467: 0009b1a4     4 FUNC    WEAK   HIDDEN     2 __aeabi_idiv0
  8468: 00054e40   124 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_initialize_l
  8469: 00110878   240 OBJECT  GLOBAL DEFAULT   14 _IO_Driver_address_table
  8470: 0005c878   100 FUNC    GLOBAL DEFAULT    2 hashinit
  8471: 0006afac   136 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_doski
  8472: 00082440    44 FUNC    GLOBAL DEFAULT    2 __getopt_r
  8473: 00113cc8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_PWD_Command
  8474: 0007f87c    88 FUNC    GLOBAL DEFAULT    2 fileno
  8475: 00077c98   712 FUNC    GLOBAL DEFAULT    2 vsyslog
  8476: 0002a950   116 FUNC    GLOBAL DEFAULT    2 _Scheduler_priority_Sched
  8477: 00115274     4 OBJECT  GLOBAL DEFAULT   14 __mbtowc
  8478: 00124d70    20 OBJECT  GLOBAL DEFAULT   15 route_cb
  8479: 0006ef30    24 FUNC    GLOBAL DEFAULT    2 rtems_monitor_region_dump
  8480: 00065c0c   256 FUNC    GLOBAL DEFAULT    2 tcp_slowtimo
  8481: 000652f0   160 FUNC    GLOBAL DEFAULT    2 tcp_newtcpcb
  8482: 00010838     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_rodata_size
  8483: 0004b760    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8484: 00018598     8 FUNC    GLOBAL DEFAULT    2 rtems_heap_null_extend
  8485: 0003a0a8   104 FUNC    GLOBAL DEFAULT    2 rtems_shell_print_heap_st
  8486: 0006f5a8    28 FUNC    GLOBAL DEFAULT    2 rtems_monitor_symbol_cano
  8487: 0007fc44   244 FUNC    GLOBAL DEFAULT    2 _fopen_r
  8488: 0003f7ec  2012 FUNC    GLOBAL DEFAULT    2 strsvis
  8489: 00041084   152 FUNC    GLOBAL DEFAULT    2 rtems_string_to_unsigned_
  8490: 00021acc   156 FUNC    GLOBAL DEFAULT    2 m_get
  8491: 001250ac    56 OBJECT  GLOBAL DEFAULT   15 _Partition_Information
  8492: 000511a0    36 FUNC    GLOBAL DEFAULT    2 _exit
  8493: 0003bd98   228 FUNC    GLOBAL DEFAULT    2 user_from_uid
  8494: 000523ec   120 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_mount_it
  8495: 0006c970    28 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_badfm
  8496: 00012c1c   252 FUNC    GLOBAL DEFAULT    2 IMFS_rename
  8497: 00121470     4 OBJECT  GLOBAL DEFAULT   15 rki_nvdisk_base
  8498: 0011399c    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_LN_Command
  8499: 0005abc4   124 FUNC    GLOBAL DEFAULT    2 rsvp_input
  8500: 00028440    76 FUNC    GLOBAL DEFAULT    2 _IO_Initialize_all_driver
  8501: 00011db8     4 FUNC    GLOBAL DEFAULT    2 IMFS_node_remove_default
  8502: 0002c22c   168 FUNC    GLOBAL DEFAULT    2 _Watchdog_Remove
  8503: 0006cd54  1716 FUNC    GLOBAL DEFAULT    2 rtems_shell_hexdump_rewri
  8504: 0002c6f8     0 NOTYPE  GLOBAL DEFAULT    2 _CPU_Context_restore_arm
  8505: 00017e80   188 FUNC    GLOBAL DEFAULT    2 newlib_create_hook
  8506: 0007ae6c    20 FUNC    GLOBAL DEFAULT    2 rtems_assoc_remote_by_loc
  8507: 00050bdc    64 FUNC    GLOBAL DEFAULT    2 getpwent
  8508: 00019f1c   304 FUNC    GLOBAL DEFAULT    2 rtems_termios_device_inst
  8509: 000824cc    32 FUNC    GLOBAL DEFAULT    2 gmtime
  8510: 00113be8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MMOVE_Command
  8511: 001131bc    68 OBJECT  GLOBAL DEFAULT   14 Console_Configuration_Por
  8512: 00082c64   372 FUNC    GLOBAL DEFAULT    2 __smakebuf_r
  8513: 0002bc94    68 FUNC    GLOBAL DEFAULT    2 _Thread_Set_state
  8514: 0003e608    68 FUNC    GLOBAL DEFAULT    2 rtems_shell_cp_set_utimes
  8515: 00001040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_svc_end
  8516: 00001440     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_main_begin
  8517: 0007043c   124 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_map_seek
  8518: 00114d90    12 OBJECT  GLOBAL DEFAULT   14 _RTEMS_tasks_API_extensio
  8519: 0002c674     0 NOTYPE  GLOBAL DEFAULT    2 _ARMV4_Exception_irq_defa
  8520: 000510ec   180 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_unregist
  8521: 000865b0    96 FUNC    GLOBAL DEFAULT    2 strlen
  8522: 0000ff38   100 FUNC    GLOBAL DEFAULT    2 bsp_interrupt_initialize
  8523: 0002c654     0 NOTYPE  GLOBAL DEFAULT    2 _ARMV4_Exception_data_abo
  8524: 0004b9a8    36 FUNC    GLOBAL DEFAULT    2 device_read
  8525: 0012518c     4 OBJECT  GLOBAL DEFAULT   15 _Timer_server
  8526: 00029480   832 FUNC    GLOBAL DEFAULT    2 _Objects_Extend_informati
  8527: 00017fac   508 FUNC    GLOBAL DEFAULT    2 open
  8528: 00113680     4 OBJECT  GLOBAL DEFAULT   14 arm_cpu_mode
  8529: 00020a88    56 FUNC    GLOBAL DEFAULT    2 udp_init
  8530: 00045c38   552 FUNC    GLOBAL DEFAULT    2 Untar_FromFile
  8531: 00017f3c     8 FUNC    GLOBAL DEFAULT    2 newlib_terminate_hook
  8532: 00113ac8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MEDIT_Command
  8533: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_stack_fiq_size
  8534: 000237e8    20 FUNC    GLOBAL DEFAULT    2 socantsendmore
  8535: 001015bc    36 OBJECT  GLOBAL DEFAULT    6 bcm2835_usart_fns
  8536: 0000efec    24 FUNC    GLOBAL HIDDEN     2 __aeabi_cdcmpeq
  8537: 00054478   328 FUNC    GLOBAL DEFAULT    2 ether_input
  8538: 0000ef38   152 FUNC    GLOBAL HIDDEN     2 __gedf2
  8539: 00000001     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_xbarrier_alig
  8540: 00113e88    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_WHOAMI_Comman
  8541: 00068020    12 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_namecmp
  8542: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_stack_main_size
  8543: 0009a348  2032 FUNC    GLOBAL DEFAULT    2 __gethex
  8544: 00110968    28 OBJECT  GLOBAL DEFAULT   14 Initialization_tasks
  8545: 0006e3bc    20 FUNC    GLOBAL DEFAULT    2 rtems_monitor_wakeup
  8546: 00123cf4     4 OBJECT  GLOBAL DEFAULT   15 Bool_Glob
  8547: 00070120   456 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_map_close
  8548: 0007549c   228 FUNC    GLOBAL DEFAULT    2 rtems_rfs_group_bitmap_fr
  8549: 00011260   444 FUNC    GLOBAL DEFAULT    2 rtems_disk_delete
  8550: 000741d0  3564 FUNC    GLOBAL DEFAULT    2 rtems_rfs_format
  8551: 00078108   632 FUNC    GLOBAL DEFAULT    2 __ns_name_ntop
  8552: 00051420    20 FUNC    GLOBAL DEFAULT    2 _libcsupport_pwdgrp_init
  8553: 00113efc    80 OBJECT  GLOBAL DEFAULT   14 rtems_bsdnet_config
  8554: 00067c90    72 FUNC    GLOBAL DEFAULT    2 _Timespec_From_ticks
  8555: 0004b7a0    24 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8556: 00028d90   160 FUNC    GLOBAL DEFAULT    2 _TOD_Tickle_ticks
  8557: 00113244    72 OBJECT  GLOBAL DEFAULT   14 rtems_global_user_env
  8558: 001156d4     4 OBJECT  GLOBAL DEFAULT   14 __wctomb
  8559: 0009b27c    68 FUNC    GLOBAL HIDDEN     2 __gnu_ldivmod_helper
  8560: 00091a58   100 FUNC    GLOBAL DEFAULT    2 div
  8561: 00080a30    44 FUNC    GLOBAL DEFAULT    2 _ftell_r
  8562: 000681e8    84 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_revsizecmp
  8563: 00113e48    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_UNMOUNT_Comma
  8564: 001137ec    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_CP_Command
  8565: 00124ea8     4 OBJECT  GLOBAL DEFAULT   15 tcp_ccgen
  8566: 000989e0    24 FUNC    GLOBAL DEFAULT    2 __sprint_r
  8567: 0011900c     4 OBJECT  WEAK   DEFAULT   15 __rtld_tbg_buffer_in
  8568: 0005db54    64 FUNC    GLOBAL DEFAULT    2 sysctl_wire_old_buffer
  8569: 00085978   352 FUNC    GLOBAL DEFAULT    2 strchr
  8570: 0003be7c   228 FUNC    GLOBAL DEFAULT    2 group_from_gid
  8571: 0006edf4    36 FUNC    GLOBAL DEFAULT    2 rtems_monitor_queue_canon
  8572: 00114c6c    52 OBJECT  GLOBAL DEFAULT   14 tcp_backoff
  8573: 0002a104   388 FUNC    GLOBAL DEFAULT    2 _RBTree_Extract
  8574: 001167e4     0 OBJECT  GLOBAL DEFAULT   15 rtems_filesystem_mt_entry
  8575: 000181e8    52 FUNC    GLOBAL DEFAULT    2 printk_plugin
  8576: 00125190     0 NOTYPE  GLOBAL DEFAULT   15 bsp_section_bss_end
  8577: 0000e9e8    64 FUNC    GLOBAL HIDDEN     2 __aeabi_f2d
  8578: 00023550    20 FUNC    GLOBAL DEFAULT    2 soisconnecting
  8579: 0007fec8    32 FUNC    GLOBAL DEFAULT    2 fputs
  8580: 0006e314    44 FUNC    GLOBAL DEFAULT    2 rtems_monitor_fatal_cmd
  8581: 00015db8    68 FUNC    GLOBAL DEFAULT    2 __hostalias
  8582: 00116938     4 OBJECT  GLOBAL DEFAULT   15 rtems_bsdnet_bootp_server
  8583: 00124ce0     4 OBJECT  GLOBAL DEFAULT   15 sysctl__sysctl_children
  8584: 00052148    24 FUNC    GLOBAL DEFAULT    2 setegid
  8585: 001247c4    12 OBJECT  GLOBAL DEFAULT   15 _Watchdog_Ticks_header
  8586: 00068124    56 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_statcmp
  8587: 0005dfb4   324 FUNC    GLOBAL DEFAULT    2 userland_sysctl
  8588: 00000040     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_start_vector_table_si
  8589: 0010881c    60 OBJECT  GLOBAL DEFAULT    6 __p_default_section_syms
  8590: 0011416c     6 OBJECT  GLOBAL DEFAULT   14 ether_ipmulticast_max
  8591: 00012e58   120 FUNC    GLOBAL DEFAULT    2 IMFS_symlink
  8592: 00058050   176 FUNC    GLOBAL DEFAULT    2 in_pcbconnect
  8593: 00000040     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_vector_table_size
  8594: 00110838     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_fast_text_loa
  8595: 00045804    16 FUNC    GLOBAL DEFAULT    2 rtems_trace_names
  8596: 0007f1a4    56 FUNC    GLOBAL DEFAULT    2 closedir
  8597: 00010db0   100 FUNC    GLOBAL DEFAULT    2 rtems_stack_checker_switc
  8598: 00114a90     7 OBJECT  GLOBAL DEFAULT   14 machine
  8599: 0006acbc    52 FUNC    GLOBAL DEFAULT    2 rtems_shell_fts_set
  8600: 00058100    52 FUNC    GLOBAL DEFAULT    2 in_pcbdisconnect
  8601: 000727e8   584 FUNC    GLOBAL DEFAULT    2 rtems_rfs_dir_empty
  8602: 0004df44    16 FUNC    GLOBAL DEFAULT    2 _getshort
  8603: 00113668    12 OBJECT  GLOBAL DEFAULT   14 _User_extensions_List
  8604: 00065754   220 FUNC    GLOBAL DEFAULT    2 tcp_mtudisc
  8605: 0009aef8    80 FUNC    GLOBAL DEFAULT    2 _wctomb_r
  8606: 00093338     4 FUNC    GLOBAL DEFAULT    2 __env_lock
  8607: 0006ee18    40 FUNC    GLOBAL DEFAULT    2 rtems_monitor_queue_dump_
  8608: 0005ee24  1132 FUNC    GLOBAL DEFAULT    2 rn_addroute
  8609: 0003a040    52 FUNC    GLOBAL DEFAULT    2 rtems_shell_print_unified
  8610: 00000000     0 NOTYPE  WEAK   DEFAULT  UND _Jv_RegisterClasses
  8611: 00124394     4 OBJECT  GLOBAL DEFAULT   15 rtems_libio_semaphore
  8612: 00011ce8    16 FUNC    GLOBAL DEFAULT    2 IMFS_eval_path
  8613: 001133c4     4 OBJECT  GLOBAL DEFAULT   14 tcp_recvspace
  8614: 001156d8     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_data_load_end
  8615: 0009b598    40 FUNC    GLOBAL HIDDEN     2 __clzdi2
  8616: 0000e688   788 FUNC    GLOBAL HIDDEN     2 __subdf3
  8617: 0008d300 10312 FUNC    GLOBAL DEFAULT    2 _vfprintf_r
  8618: 00124418     4 OBJECT  GLOBAL DEFAULT   15 domains
  8619: 00001040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_svc_begin
  8620: 0001e2c0   584 FUNC    GLOBAL DEFAULT    2 recvmsg
  8621: 00055fa8   796 FUNC    GLOBAL DEFAULT    2 in4_cksum
  8622: 00113dc8    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_TIME_Command
  8623: 0001c71c   204 FUNC    GLOBAL DEFAULT    2 rtems_bsdnet_timeout
  8624: 00100144    20 OBJECT  GLOBAL DEFAULT    6 rtems_filesystem_root_con
  8625: 00018cf0    56 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  8626: 0002c4f0    24 FUNC    GLOBAL DEFAULT    2 _Workspace_Allocate
  8627: 00028190    20 FUNC    GLOBAL DEFAULT    2 rtems_task_self
  8628: 0004f3e4    68 FUNC    GLOBAL DEFAULT    2 __p_time
  8629: 000691ac   488 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_summary
  8630: 00010f38     4 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_default_
  8631: 0002a768   392 FUNC    GLOBAL DEFAULT    2 _Scheduler_priority_Chang
  8632: 0007af98   908 FUNC    GLOBAL DEFAULT    2 fcntl
  8633: 0008cbd0    28 FUNC    GLOBAL DEFAULT    2 tzset
  8634: 0011f408   104 OBJECT  GLOBAL DEFAULT   15 RTEMS_Malloc_Area
  8635: 000939e4   148 FUNC    GLOBAL DEFAULT    2 __lo0bits
  8636: 000662a8     8 FUNC    GLOBAL DEFAULT    2 rtems_get_processor_count
  8637: 00023b9c   412 FUNC    GLOBAL DEFAULT    2 sbcompress
  8638: 0008fc14  5716 FUNC    GLOBAL DEFAULT    2 __svfscanf_r
  8639: 0008c97c   568 FUNC    GLOBAL DEFAULT    2 __tzcalc_limits
  8640: 00024720     8 FUNC    GLOBAL DEFAULT    2 pru_rcvoob_notsupp
  8641: 0003c250   176 FUNC    GLOBAL DEFAULT    2 rtems_shell_execute_cmd
  8642: 000222d4   684 FUNC    GLOBAL DEFAULT    2 m_copypacket
  8643: 00075b28   304 FUNC    GLOBAL DEFAULT    2 rtems_rfs_inode_delete
  8644: 00052190    24 FUNC    GLOBAL DEFAULT    2 setuid
  8645: 0009b184    32 FUNC    GLOBAL HIDDEN     2 __aeabi_idivmod
  8646: 000191b4   136 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_location
  8647: 00045910    36 FUNC    GLOBAL DEFAULT    2 rtems_trace_buffering_fin
  8648: 001250e4    56 OBJECT  GLOBAL DEFAULT   15 _Rate_monotonic_Informati
  8649: 0005f6b0    24 FUNC    GLOBAL DEFAULT    2 rn_inithead
  8650: 0009b1fc     0 FUNC    GLOBAL HIDDEN     2 __aeabi_ldivmod
  8651: 0006fb54   136 FUNC    GLOBAL DEFAULT    2 ramdisk_allocate
  8652: 0008d15c   388 FUNC    GLOBAL DEFAULT    2 _ungetc_r
  8653: 0007d91c   480 FUNC    GLOBAL DEFAULT    2 rtems_monitor_extension_d
  8654: 0002d77c  2616 FUNC    GLOBAL DEFAULT    2 rtems_shell_main_cp
  8655: 00113c08    32 OBJECT  GLOBAL DEFAULT   14 rtems_shell_MOUNT_Command
  8656: 001249d0   372 OBJECT  GLOBAL DEFAULT   15 icmpstat
  8657: 000655a4   124 FUNC    GLOBAL DEFAULT    2 tcp_drop
  8658: 00011f6c    24 FUNC    GLOBAL DEFAULT    2 IMFS_node_clone
  8659: 0011496c     4 OBJECT  GLOBAL DEFAULT   14 ip_mrouter_get
  8660: 00021e88   300 FUNC    GLOBAL DEFAULT    2 m_prepend
  8661: 00048360   372 FUNC    GLOBAL DEFAULT    2 rtems_bdbuf_sync
  8662: 0004df3c     4 FUNC    GLOBAL DEFAULT    2 __putshort
  8663: 00066db8    20 FUNC    GLOBAL DEFAULT    2 rtems_shutdown_executive
  8664: 00057d28   112 FUNC    GLOBAL DEFAULT    2 in_pcbrehash
  8665: 001109a8    16 OBJECT  GLOBAL DEFAULT   14 rtems_nv_heap_device_desc
  8666: 00100104     4 OBJECT  GLOBAL DEFAULT    6 rtems_malloc_extend_handl
  8667: 000524c8    88 FUNC    GLOBAL DEFAULT    2 tcsetattr
  8668: 00015a44   524 FUNC    GLOBAL DEFAULT    2 __res_query
  8669: 00017a1c    16 FUNC    GLOBAL DEFAULT    2 mkdir
  8670: 000658e4   808 FUNC    GLOBAL DEFAULT    2 tcp_timers
  8671: 000459b8    36 FUNC    GLOBAL DEFAULT    2 rtems_trace_buffering_res
  8672: 00000000     0 NOTYPE  WEAK   DEFAULT  UND __register_frame_info
  8673: 0005c72c    76 FUNC    GLOBAL DEFAULT    2 ip_freemoptions
  8674: 00119038     4 OBJECT  WEAK   DEFAULT   15 __rtld_trace_names
  8675: 000268ec     4 FUNC    GLOBAL DEFAULT    2 sohasoutofband
  8676: 00054a84   100 FUNC    GLOBAL DEFAULT    2 ether_crc32_be
  8677: 0006ec80    64 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_state
  8678: 00114dcc   128 OBJECT  GLOBAL DEFAULT   14 _ns_flagdata
  8679: 0009ae38   152 FUNC    GLOBAL DEFAULT    2 wcrtomb
  8680: 00000040     0 NOTYPE  GLOBAL DEFAULT   13 bsp_stack_irq_begin
  8681: 00062168  7316 FUNC    GLOBAL DEFAULT    2 tcp_input
  8682: 00058ce4   120 FUNC    GLOBAL DEFAULT    2 iptime
  8683: 0005f7f0   580 FUNC    GLOBAL DEFAULT    2 rip_input
  8684: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_fast_data_siz
  8685: 00027d88    28 FUNC    GLOBAL DEFAULT    2 rtems_status_text
  8686: 00021034   172 FUNC    GLOBAL DEFAULT    2 udp_ctlinput
  8687: 0009448c   168 FUNC    GLOBAL DEFAULT    2 frexp
  8688: 0001747c   120 FUNC    GLOBAL DEFAULT    2 close
  8689: 0006ff08    20 FUNC    GLOBAL DEFAULT    2 rtems_rfs_block_get_pos
  8690: 0005220c    52 FUNC    GLOBAL DEFAULT    2 rtems_deviceio_open
  8691: 0000f184   444 FUNC    GLOBAL HIDDEN     2 __addsf3
  8692: 00068bd0   116 FUNC    GLOBAL DEFAULT    2 rtems_shell_dd_def
  8693: 000679a0   108 FUNC    GLOBAL DEFAULT    2 _Once
  8694: 000598f8  3756 FUNC    GLOBAL DEFAULT    2 ip_input
  8695: 00010434   268 FUNC    GLOBAL DEFAULT    2 rtems_interrupt_handler_i
  8696: 001247d0    12 OBJECT  GLOBAL DEFAULT   15 _API_extensions_List
  8697: 00018b74    72 FUNC    GLOBAL DEFAULT    2 rtems_filesystem_eval_pat
  8698: 00022d88   872 FUNC    GLOBAL DEFAULT    2 m_devget
  8699: 001000d0    48 OBJECT  GLOBAL DEFAULT    6 rtems_bdbuf_configuration
  8700: 0008c5d0   292 FUNC    GLOBAL DEFAULT    2 _seekdir
  8701: 00000000     0 NOTYPE  GLOBAL DEFAULT  ABS _TLS_Data_size
  8702: 0001a8b8   344 FUNC    GLOBAL DEFAULT    2 rtems_termios_puts
  8703: 001243f8    32 OBJECT  GLOBAL DEFAULT   15 udbinfo
  8704: 00028cc4   108 FUNC    GLOBAL DEFAULT    2 _TOD_Get_with_nanoseconds
  8705: 0008c560   112 FUNC    GLOBAL DEFAULT    2 telldir
  8706: 00067244    68 FUNC    GLOBAL DEFAULT    2 rtems_io_write
  8707: 000178dc   140 FUNC    GLOBAL DEFAULT    2 RTEMS_Malloc_Initialize
  8708: 0008fb48    40 FUNC    GLOBAL DEFAULT    2 vfprintf
  8709: 00052240    52 FUNC    GLOBAL DEFAULT    2 rtems_deviceio_close
  8710: 07ffc000     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_nocache_load_
  8711: 00124cf4     4 OBJECT  GLOBAL DEFAULT   15 sysctl__sysctl_name_child
  8712: 00100108    60 OBJECT  GLOBAL DEFAULT    6 _Scheduler_Table
  8713: 00086910   144 FUNC    GLOBAL DEFAULT    2 strpbrk
  8714: 0001c4d4    60 FUNC    GLOBAL DEFAULT    2 sbwait
  8715: 00026b4c   360 FUNC    GLOBAL DEFAULT    2 pthread_setspecific
  8716: 00048a6c   392 FUNC    GLOBAL DEFAULT    2 rtems_bdpart_mount
  8717: 0002bc74    32 FUNC    GLOBAL DEFAULT    2 _Thread_Set_priority
  8718: 0003c6ec  6456 FUNC    GLOBAL DEFAULT    2 rtems_shell_main_loop
  8719: 0009a21c    56 FUNC    GLOBAL DEFAULT    2 fputwc
  8720: 000933f0    12 FUNC    GLOBAL DEFAULT    2 __gettzinfo
  8721: 000849a4    24 FUNC    GLOBAL DEFAULT    2 raise
  8722: 00026d4c    80 FUNC    GLOBAL DEFAULT    2 rtems_clock_get_seconds_s
  8723: 00023e2c   192 FUNC    GLOBAL DEFAULT    2 sbinsertoob
  8724: 000174fc   100 FUNC    GLOBAL DEFAULT    2 free
  8725: 0007fbbc     4 FUNC    GLOBAL DEFAULT    2 __sinit_lock_acquire
  8726: 0004dd18    16 FUNC    GLOBAL DEFAULT    2 __ns_put16
  8727: 0004cde8    72 FUNC    GLOBAL DEFAULT    2 _sethostdnsent
  8728: 000937c4   220 FUNC    GLOBAL DEFAULT    2 __multadd
  8729: 0000fab0     0 NOTYPE  GLOBAL DEFAULT  ABS bsp_section_bss_size
  8730: 000937a8    28 FUNC    GLOBAL DEFAULT    2 _Bfree
  8731: 0003c698    84 FUNC    GLOBAL DEFAULT    2 rtems_shell_dup_current_e
  8732: 00068010    16 FUNC    GLOBAL DEFAULT    2 rtems_shell_register_moni
  8733: 00066028     8 FUNC    GLOBAL DEFAULT    2 sigprocmask
  8734: 000818d0    28 FUNC    GLOBAL DEFAULT    2 _getenv_r
  8735: 0003ac18   288 FUNC    GLOBAL DEFAULT    2 rtems_shell_ls_printscol
  8736: 000217b4   220 FUNC    GLOBAL DEFAULT    2 pffindproto
  8737: 0001e880     8 FUNC    GLOBAL DEFAULT    2 getsockname
  8738: 0006670c    84 FUNC    GLOBAL DEFAULT    2 _Timer_Manager_initializa
  8739: 00027e80   336 FUNC    GLOBAL DEFAULT    2 rtems_task_create
  8740: 001018e4    20 OBJECT  GLOBAL DEFAULT    6 IMFS_mknod_control_memfil
  8741: 0006eb8c    36 FUNC    GLOBAL DEFAULT    2 rtems_monitor_dump_hex
  8742: 00010e14   164 FUNC    GLOBAL DEFAULT    2 rtems_stack_checker_is_bl
  8743: 00093444   724 FUNC    GLOBAL DEFAULT    2 __part_load_locale
No version information found in this file.
Attribute Section: aeabi
File Attributes
  Tag_CPU_name: "ARM1176JZF-S"
  Tag_CPU_arch: v6KZ
  Tag_ARM_ISA_use: Yes
  Tag_THUMB_ISA_use: Thumb-1
  Tag_FP_arch: VFPv2
  Tag_ABI_PCS_wchar_t: 4
  Tag_ABI_FP_denormal: Needed
  Tag_ABI_FP_exceptions: Needed
  Tag_ABI_FP_number_model: IEEE 754
  Tag_ABI_align_needed: 8-byte
  Tag_ABI_enum_size: small
  Tag_CPU_unaligned_access: v6
  Tag_Virtualization_use: TrustZone
