[PATCH 1/1] add t1lib patch
QIAO YANG
yangqiao0505 at me.com
Wed Aug 12 13:18:39 UTC 2015
Hi,
So here I patch the configure.in file instead of its output. If this one is good to go, I'll send you the two other patches for microwindows-bset and t1lib-bset , with its' correct patch urls.
Best wishes
On Aug 12, 2015, at 02:16 AM, YANG QIAO <yangqiao0505 at me.com> wrote:
> From: YANG Qiao <yangqiao0505 at me.com>
> tools/4.11/t1lib/t1lib-5.1.2.diff | 58 +++++++++++++++++++++++++++++++++++++++
> 1 file changed, 58 insertions(+)
> create mode 100644 tools/4.11/t1lib/t1lib-5.1.2.diff
> diff --git a/tools/4.11/t1lib/t1lib-5.1.2.diff b/tools/4.11/t1lib/t1lib-5.1.2.diff
> new file mode 100644
> index 0000000..1c59e2b
> --- /dev/null
> +++ b/tools/4.11/t1lib/t1lib-5.1.2.diff
> @@ -0,0 +1,58 @@
> +--- t1lib-5.1.2.orig/configure.in 2015-08-12 14:35:01.064674452 +0200
> ++++ t1lib-5.1.2/configure.in 2015-08-12 14:35:05.148674279 +0200
> +@@ -225,14 +225,52 @@
> + dnl **** Check which ANSI integer type is 64 bit
> +-AC_CACHE_CHECK( "which ANSI integer type is 64 bit", ac_64bit_type,
> +- AC_TRY_RUN([
> ++echo $ECHO_N "checking \"which ANSI integer type is 64 bit\"... $ECHO_C" >&6
> ++if test "${ac_64bit_type+set}" = set; then
> ++ echo $ECHO_N "(cached) $ECHO_C" >&6
> ++else
> ++ if test "$cross_compiling" = yes; then
> ++ ac_64bit_type="<none>"
> ++else
> ++ cat >conftest.$ac_ext <<_ACEOF
> ++/* confdefs.h. */
> ++_ACEOF
> ++cat confdefs.h >>conftest.$ac_ext
> ++cat >>conftest.$ac_ext <<_ACEOF
> ++/* end confdefs.h. */
> + int main(void) {
> + if (sizeof(long)==8)
> + return(0);
> + else
> + return(1);
> +-}], ac_64bit_type="long", ac_64bit_type="<none>"))
> ++_ACEOF
> ++rm -f conftest$ac_exeext
> ++if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
> ++ (eval $ac_link) 2>&5
> ++ ac_status=$?
> ++ echo "$as_me:$LINENO: \$? = $ac_status" >&5
> ++ (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
> ++ { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
> ++ (eval $ac_try) 2>&5
> ++ ac_status=$?
> ++ (exit $ac_status); }; }; then
> ++ ac_64bit_type="long"
> ++else
> ++ echo "$as_me: program exited with status $ac_status" >&5
> ++echo "$as_me: failed program was:" >&5
> ++sed 's/^/| /' conftest.$ac_ext >&5
> ++( exit $ac_status )
> ++ac_64bit_type="<none>"
> ++fi
> ++rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
> ++fi
> ++fi
> ++echo "$as_me:$LINENO: result: $ac_64bit_type" >&5
> ++echo "${ECHO_T}$ac_64bit_type" >&6
> + if test "$ac_64bit_type" = "long"
> + then
> + T1_AA_TYPE64="-DT1_AA_TYPE64=long"
> 2.1.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150812/40ff2243/attachment-0002.html>
