Uniprocessor implementation of nested mutex problem of priority inversion.
Saurabh Gadia
gadia at usc.edu
Fri Aug 14 16:43:57 UTC 2015
When a thread releases a semaphore/mutex we call this validate method to
make sure that there does not exists any priority inversion. Following is
the course of action that needs to be performed:
1. Validate method needs to be called within mutex_surrender method because
after releasing a mutex a new holder thread can get scheduled and then we
can't call validate method. We need to do call validate before we enable
interrupts in uniprocessor or dispatching of threads.
2. Functioning of validate method: input param - executing thread (thread
which releases the mutex)
2.a) Go through the list of Mutex Chain i.e( Chain_Control lock_mutex;) in
TCB.
2.b) Extract mutex from the chain node linked list. This gives us
(the_mutex->queue.lock_queue) from which we will extract mutex by using
CONTAINER_OF() method.
2.c) Now access the thread wait queue of this mutex
i.e(the_mutex->Wait_queue) to get the information about the first waiting
thread in this waitqueue by calling
_Thread_queue_First_locked(&the_mutex->Wait_queue)
2.d) Now check whether
assert(releasingThread.current_priority<=first_locked_thread.currentPriority).
If assertion fails then there is priority inversion problem and we can
break out of loop and return error status.
2.e) Repeat from 2.a till all acquired resources are visited present in
Chain_Control of releasing thread.
So I am sceptical about how can I include this validate method in the
_CORE_mutex_Surrender(). We can have it as a separate call from user level
but then we need to make sure that the thread dispatch mechanism is
disabled. If not then whether including this validate method in
_CORE_mutex_Surrender for only strict_order_mutex and Priority inheritance
attribute is feasible or not.
Please guide me on this.
Thanks,
Saurabh Gadia
On Thu, Aug 13, 2015 at 9:10 AM, Saurabh Gadia <gadia at usc.edu> wrote:
> That is how we were doing in JPF. The validate method was triggered after
> every release of mutex by any thread and we would check for all the waiting
> threads on mutex's held by the holder. And if it finds a thread with higher
> priority blocked then it would panic or give assertion failure.
> Thanks,
> Saurabh Gadia
> On Thu, Aug 13, 2015 at 9:08 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> Thanks. Would it be possible for you to turn the failure cases into
>> real test failures? In other words, add some logic to detect the
>> priority inversion and abort the test?
>> Gedare
>> On Thu, Aug 13, 2015 at 12:05 PM, Saurabh Gadia <gadia at usc.edu> wrote:
>> > Hi,
>> > Following is the result of spsem04 test without the patch:
>> > *** BEGIN OF TEST SPSEM 4 ***
>> > init: S0 created
>> > init: S1 created
>> > init: TA01 created with priority 36
>> > init: TA02 created with priority 34
>> > init: TA03 created with priority 32
>> > TA01: started with priority 36
>> > TA01: priority 36, holding S0
>> > TA02: started with priority 34
>> > TA02: priority 34, holding S1
>> > TA01: priority 34, holding S0 and now creating TA03
>> > TA03: started with priority 32
>> > TA01: priority 34 Releasing s0 (This is priority inheritance problem as
>> TA02
>> > waits on mutex held by TA01 and has higher priority than TA01. TA03 just
>> > promotes the priority TA02.)
>> > TA02: priority 32, holding S1,S0
>> > TA02: priority 32 before releasing S0
>> > TA02: priority 32 after releasing S0
>> > TA02: priority 32 before releasing S1
>> > TA03: priority 32, holding S1
>> > TA03: priority 32
>> > TA03: suspending
>> > TA02: priority 34 after releasing S1
>> > TA02: suspending
>> > TA01: priority 36
>> > TA01: exiting
>> > *** END OF TEST SPSEM 4 ***
>> > You can see the difference in highlighted portions of both outputs.
>> > Thanks,
>> > Saurabh Gadia
>> > On Thu, Aug 13, 2015 at 8:17 AM, Saurabh Gadia <gadia at usc.edu> wrote:
>> >> Ok. I will mail you back soon.
>> >> On Thursday, August 13, 2015, Gedare Bloom <gedare at rtems.org> wrote:
>> >>> Saurabh,
>> >>> Please pull from rtems.git again, create a new branch from 'master',
>> >>> and apply your changes to the branch. It's too hard to review code
>> >>> that is not all by itself on a branch.
>> >>> Gedare
>> >>> On Thu, Aug 13, 2015 at 5:28 AM, Saurabh Gadia <gadia at usc.edu> wrote:
>> >>> > Hi,
>> >>> > I have implemented uniprocessor model of nested mutex problem in
>> rtems.
>> >>> > its
>> >>> > still in basic form. I tried to multiplex it with the existing
>> solution
>> >>> > but
>> >>> > was finding hard time. To push ahead, I decided to have separate
>> >>> > functions
>> >>> > for uniprocessor and SMP(kept default behavior) and with your review
>> >>> > comments will know what to do. Following is the link for the git
>> repo:
>> >>> > https://github.com/saurabhgadia4/rtems/commits/master and its JPF
>> >>> > branch:
>> https://github.com/saurabhgadia4/lock-model/blob/uniproc-new1/rtems/Mutex.java
>> >>> > I have also tested spsem01, 02, 03 test cases. Following are the
>> links
>> >>> > for
>> >>> > the test case results which states output before solution and after
>> >>> > applying
>> >>> > the solution. I am still not getting whether my code is passing
>> spsem03
>> >>> > test
>> >>> > or not. How can I verify that?
>> >>> > Test Case Link:
>> https://drive.google.com/folderview?id=0B44HRKVuGCkFfnFDVmxqQzZZUzljNUg4YmVPZmEybEp2Q0NNclpvS2FvemZ4Tm5Xa19nemM&usp=sharing
>> >>> > Thanks,
>> >>> > Saurabh Gadia
>> >> Thanks,
>> >> Saurabh Gadia
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150814/df0f5110/attachment-0002.html>
