libbsd - USB Host Stack for HID, WirelessLAN
Thomas Kim thomas73.kim at gmail.com
Tue Aug 25 09:10:55 UTC 2015
Dear Yurii,
Thank you very much.
I want to review freeBSD source code.
Please let me know where is libbsd's README file. there is not README file
in current tree (https://git.rtems.org/rtems-libbsd/tree/).
I want to check "Rules for Modiying FreeBSD source" in REAME file.
Also, I want to compare FreeBSD original code and the modified FreeBSD code.
I guess that FreeBSD original code version is 8.x.
Please let me know how to get FreeBSD original code version which was used
for libbsd porting work.
Best Regards,
Thomas.
2015-08-21 23:57 GMT+09:00 Yurii Shevtsov <ungetch at gmail.com>:
> Hi)
> For porting guide check this blogpost
> http://ragustechblog.blogspot.in/2015/06/porting-driver-from-freebsd-to-rtems.html
> Also read libbsd's README, especially "Rules for Modifying FreeBSD Source"
> Can't say anything specific about USB HID and WLAN. Definitely WLAN will
> require porting libraries with auth protocols (WPA\WEP). About HID, you can
> try searching how input works in RTEMS. Maybe you can implement API in your
> future HID driver
URL: <http://lists.rtems.org/pipermail/devel/attachments/20150825/928908bd/attachment-0002.html>
