Concurrency in JFFS2?
Martin Galvan martin.galvan at tallertechnologies.com
Fri Dec 4 14:47:06 UTC 2015
I see, thanks for your answer. What about the eCos mutexes though? You
mentioned eCos having a global lock for the filesystem, yet I saw more
fine-grained locked in e.g. jffs2_new_inode.
On Fri, Dec 4, 2015 at 3:36 AM, Sebastian Huber
> See
> struct _rtems_filesystem_operations_table {
>   rtems_filesystem_mt_entry_lock_t lock_h;
>   rtems_filesystem_mt_entry_unlock_t unlock_h;
> On 03/12/15 15:30, Martin Galvan wrote:
>> Oh, I see. Do you happen to remember where that lock is
>> acquired/released? I saw the up/down macros in the eCos code at the
>> points where the RTEMS mutex_lock/unlock would be called (e.g. in
>> jffs2_new_inode). up/down end up calling Cyg_Mutex::unlock/lock, which
>> aren't empty, so it seems that there's a bit of fine-grained locking
>> there.
>> On Thu, Dec 3, 2015 at 3:19 AM, Sebastian Huber
>>> Hello,
>>> I used the eCos port of JFFS2 as a base for the RTEMS port. Like in eCos,
>>> a global lock for a JFFS2 file system instance is used.
>>> ----- Martin Galvan <martin.galvan at tallertechnologies.com> schrieb:
>>>> Hi everyone! I'm working on porting F2FS from Linux based on the JFFS2
>>>> port Sebastian did. When inspecting the code I found that
>>>> libfs/jffs2/include/linux/mutex defines struct mutex to be empty, and
>>>> all the mutex-related functions to do nothing.
>>>> This seems to imply that there's no concurrency management in the
>>>> JFFS2 code. Is this intentional? Should I do the same when porting
>>>> F2FS?
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone   : +49 89 189 47 41-16
>>> Fax     : +49 89 189 47 41-09
>>> E-Mail  : sebastian.huber at embedded-brains.de
>>> PGP     : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Martin Galvan
Software Engineer
Taller Technologies Argentina
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: 54 351 4217888 / +54 351 4218211
