libfs: are we actually using User/Group IDs?
Martin Galvan martin.galvan at tallertechnologies.com
Fri Dec 4 19:49:26 UTC 2015
On Fri, Dec 4, 2015 at 4:39 PM, Joel Sherrill <joel at rtems.org> wrote:
> RTEMS has the concept of user/groups. :)
> FWIW you should look at the fstests. A subset of them are designed to be
> instanced for different file systems. They have been instanced for RFS,
> DOSFS, and JFFS2.
Got it.
> What's the license on this filesystem? Is there a way to ensure we stay
> in sync?
> Of course, that's assuming you plan to submit it. :)
Certainly! This filesystem has been so far implemented in Linux, so
I'd assume it's GPLv2. If this isn't compatible with the RTEMS
license, perhaps we could distribute it separately through the Source
Builder.
