[PATCH 1/2] m68k/sim68000: Remove
Aun-Ali Zaidi
admin at kodeit.net
Tue Dec 8 02:20:56 UTC 2015
updates #2445.
c/src/lib/libbsp/m68k/sim68000/Makefile.am | 52 ---
c/src/lib/libbsp/m68k/sim68000/README | 9 -
c/src/lib/libbsp/m68k/sim68000/bsp_specs | 13 -
c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c | 53 ---
c/src/lib/libbsp/m68k/sim68000/configure.ac | 30 --
c/src/lib/libbsp/m68k/sim68000/console/conscfg.c | 65 ----
c/src/lib/libbsp/m68k/sim68000/console/debugio.c | 21 --
c/src/lib/libbsp/m68k/sim68000/include/bsp.h | 48 ---
.../libbsp/m68k/sim68000/make/custom/sim68000.cfg | 20 -
.../libbsp/m68k/sim68000/make/custom/simcpu32.cfg | 20 -
c/src/lib/libbsp/m68k/sim68000/preinstall.am | 67 ----
c/src/lib/libbsp/m68k/sim68000/sim68000.setup | 8 -
c/src/lib/libbsp/m68k/sim68000/start/start.S | 406 ---------------------
.../m68k/sim68000/startup/bsppredriverhook.c | 20 -
c/src/lib/libbsp/m68k/sim68000/startup/linkcmds | 200 ----------
.../m68k/sim68000/startup/spurious_assistant.c | 27 --
16 files changed, 1059 deletions(-)
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/Makefile.am
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/README
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/bsp_specs
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/configure.ac
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/console/conscfg.c
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/console/debugio.c
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/include/bsp.h
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/preinstall.am
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/sim68000.setup
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/start/start.S
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/startup/bsppredriverhook.c
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/startup/linkcmds
delete mode 100644 c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c
diff --git a/c/src/lib/libbsp/m68k/sim68000/Makefile.am b/c/src/lib/libbsp/m68k/sim68000/Makefile.am
deleted file mode 100644
index ba7d98d..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/Makefile.am
+++ /dev/null
@@ -1,52 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../../aclocal
-include $(top_srcdir)/../../../../automake/compile.am
-include_bspdir = $(includedir)/bsp
-dist_project_lib_DATA = bsp_specs
-include_HEADERS = include/bsp.h
-include_HEADERS += ../../shared/include/tm27.h
-nodist_include_HEADERS = include/bspopts.h
-nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
-DISTCLEANFILES = include/bspopts.h
-noinst_PROGRAMS =
-nodist_include_HEADERS += ../../shared/include/coverhd.h
-noinst_LIBRARIES = libbspstart.a
-libbspstart_a_SOURCES = start/start.S
-project_lib_DATA = start.$(OBJEXT)
-dist_project_lib_DATA += startup/linkcmds
-noinst_LIBRARIES += libbsp.a
-libbsp_a_SOURCES =
-# startup
-libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
- ../../shared/bsppost.c ../../shared/bspstart.c ../../shared/bootcard.c \
- startup/bsppredriverhook.c ../../shared/bsppretaskinghook.c \
- ../../shared/bspgetworkarea.c ../../shared/sbrk.c \
- ../../shared/setvec.c ../../shared/gnatinstallhandler.c \
- ../../m68k/shared/bspspuriousinit.c ../../m68k/shared/m68000spurious.c \
- startup/spurious_assistant.c
-# clock
-libbsp_a_SOURCES += clock/clockdrv.c ../../../shared/clockdrv_shell.h
-# console
-libbsp_a_SOURCES += console/conscfg.c ../../shared/console.c \
- ../../shared/console_select.c ../../shared/console_control.c \
- ../../shared/console_read.c ../../shared/console_write.c
-# debugio
-libbsp_a_SOURCES += console/debugio.c
-# timer
-libbsp_a_SOURCES += ../../shared/timerstub.c
-libbsp_a_LIBADD = \
- ../../../libcpu/@RTEMS_CPU@/shared/cache.rel \
- ../../../libcpu/@RTEMS_CPU@/shared/misc.rel
-include $(srcdir)/preinstall.am
-include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/m68k/sim68000/README b/c/src/lib/libbsp/m68k/sim68000/README
index 4b082cb..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/README
+++ /dev/null
@@ -1,9 +0,0 @@
-BSP for the BSVC 68000 simulator. This is definitely under construction.
-The initialization/setup script for BSVC is the part that likely needs
-work. I have written the timer based on the timer sample included with
-bsvc 2.1.
-At this point, hello does not even print.
---joel
-1 August 2000
diff --git a/c/src/lib/libbsp/m68k/sim68000/bsp_specs b/c/src/lib/libbsp/m68k/sim68000/bsp_specs
index 5154de8..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/bsp_specs
+++ /dev/null
@@ -1,13 +0,0 @@
-%rename endfile old_endfile
-%rename startfile old_startfile
-%rename link old_link
-*startfile:
-%{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e start}}
-*link:
-%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
-*endfile:
-%{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c b/c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c
index 0a78abc..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c
+++ /dev/null
@@ -1,53 +0,0 @@
- * Instantiate the clock driver shell.
-#include <bsp.h>
-#define CLOCK_VECTOR 84
-#define Clock_driver_support_install_isr( _new, _old ) \
- do { _old = (rtems_isr_entry) set_vector( _new, CLOCK_VECTOR, 1 ); } while(0)
-typedef struct {
- volatile uint8_t cr; /* 0 - 0 : Timer Control Register */
- volatile uint8_t pad0; /* 1 - 1 : pad */
- volatile uint8_t ivr; /* 2 - 2 : Timer Interrupt Vector Register */
- volatile uint8_t pad1; /* 3 - 3 : pad */
- volatile uint32_t cpr; /* 4 - 7 : Timer Counter Preload Register */
- volatile uint8_t pad2[12]; /* 8 - 19 : pad */
- volatile uint32_t sr; /* 20 - 23 : Timer Status Register */
-} timer_hw_t;
-#define TIMER_BASE (timer_hw_t *)0x72001
-/* 8 microseconds per click, 125,000 per second */
-/* XXX should check that microseconds_per_tick is >= 8 */
-static void Clock_driver_support_initialize_hardware(void)
- timer_hw_t *t = TIMER_BASE;
- t->ivr = CLOCK_VECTOR;
- t->cpr = rtems_configuration_get_microseconds_per_tick() / 8;
- t->cr = 0xA0; /* initialize with timer disabled */
- t->cr = 0xA1; /* enable timer */
-static void Clock_driver_support_at_tick(void)
- t->sr = 0xA0; /* Negate timer interrupt request */
-static void Clock_driver_support_shutdown_hardware(void)
-#define CLOCK_DRIVER_USE_DUMMY_TIMECOUNTER
-#include "../../../shared/clockdrv_shell.h"
diff --git a/c/src/lib/libbsp/m68k/sim68000/configure.ac b/c/src/lib/libbsp/m68k/sim68000/configure.ac
index 8c0f385..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/configure.ac
+++ /dev/null
@@ -1,30 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-m68k-sim68000],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([bsp_specs])
-RTEMS_TOP(../../../../../..)
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
-RTEMS_BSP_CONFIGURE
-RTEMS_PROG_CC_FOR_TARGET
-RTEMS_CANONICALIZE_TOOLS
-RTEMS_PROG_CCAS
-## bsp-specific options
-RTEMS_BSPOPTS_SET([CONSOLE_USE_INTERRUPTS],[*],[0])
-RTEMS_BSPOPTS_HELP([CONSOLE_USE_INTERRUPTS],
-[The erc32 console driver can operate in either polled or interrupt mode.
-Under the simulator (especially when FAST_UART is defined), polled seems to operate
-better. It is common for a task to print a line (like the end of test message) and
-then exit. In this case, the program returns control to the simulator command line
-before the program has even queued the output to the uart. Thus sis has no chance
-of getting the data out.])
-RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile])
-AC_OUTPUT
diff --git a/c/src/lib/libbsp/m68k/sim68000/console/conscfg.c b/c/src/lib/libbsp/m68k/sim68000/console/conscfg.c
index 9d29140..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/console/conscfg.c
+++ /dev/null
@@ -1,65 +0,0 @@
- * COPYRIGHT (c) 1989-2000.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <bsp.h>
-#include <bspopts.h>
-#include <libchip/serial.h>
-#include <libchip/mc68681.h>
- * Fix these for the simulator
-#define MC68681_PORT_CONFIG MC68681_XBRG_IGNORED
-#define MC68681_PROBE libchip_serial_default_probe
-#define MC68681_VECTOR 0
-#define MC68681_BASE_ADDRESS 0x71001
-#define MC68681_DATA_ADDRESS 0x71007
- * Based on BSP configuration information decide whether to do polling IO
- * or interrupt driven IO.
-#if (CONSOLE_USE_INTERRUPTS)
-#define MC68681_FUNCTIONS &mc68681_fns
-#else
-#define MC68681_FUNCTIONS &mc68681_fns_polled
-#endif
-console_tbl Console_Configuration_Ports[] = {
- "/dev/com0", /* sDeviceName */
- SERIAL_MC68681, /* deviceType */
- MC68681_FUNCTIONS, /* pDeviceFns */
- NULL, /* deviceProbe */
- NULL, /* pDeviceFlow */
- 16, /* ulMargin */
- 8, /* ulHysteresis */
- (void *)9600, /* pDeviceParams */
- MC68681_BASE_ADDRESS, /* ulCtrlPort1 */
- MC68681_BASE_ADDRESS, /* ulCtrlPort2 */
- MC68681_DATA_ADDRESS, /* ulDataPort */
- mc68681_get_register_2, /* getRegister */
- mc68681_set_register_2, /* setRegister */
- NULL, /* unused */ /* getData */
- NULL, /* unused */ /* setData */
- (uint32_t)mc68681_baud_rate_table, /* ulClock */
- MC68681_VECTOR /* ulIntVector */
- * Declare some information used by the console driver
-#define NUM_CONSOLE_PORTS (sizeof(Console_Configuration_Ports)/sizeof(console_tbl))
-unsigned long Console_Configuration_Count = NUM_CONSOLE_PORTS;
diff --git a/c/src/lib/libbsp/m68k/sim68000/console/debugio.c b/c/src/lib/libbsp/m68k/sim68000/console/debugio.c
index c9993ce..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/console/debugio.c
+++ /dev/null
@@ -1,21 +0,0 @@
- * COPYRIGHT (c) 1989-2014.
-#include <unistd.h> /* write */
-#include <bsp.h>
-#include <rtems/bspIo.h>
-static void debug_putc( char c )
- write( 2, &c, 1 );
-BSP_output_char_function_type BSP_output_char = debug_putc;
-BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/c/src/lib/libbsp/m68k/sim68000/include/bsp.h b/c/src/lib/libbsp/m68k/sim68000/include/bsp.h
index c0337d1..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/include/bsp.h
+++ /dev/null
@@ -1,48 +0,0 @@
-/* bsp.h
- * This include file contains some definitions specific to the
- * BSVC simulator BSP.
-#ifndef LIBBSP_M68K_SIM68000_BSP_H
-#define LIBBSP_M68K_SIM68000_BSP_H
-#include <bsp/default-initial-extension.h>
-#include <rtems.h>
-#include <rtems/iosupp.h>
-#include <rtems/console.h>
-#include <rtems/clockdrv.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * Define some hardware constants here
-/* functions */
-rtems_isr_entry set_vector( rtems_isr_entry, rtems_vector_number, int );
- * Prototype for methods in the BSP that cross file boundaries.
-void bsp_spurious_initialize(void);
-void bsp_spurious_handler_assistant(rtems_vector_number vector);
-rtems_isr bsp_spurious_handler(rtems_vector_number vector);
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg b/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg
index fb355cb..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg
+++ /dev/null
@@ -1,20 +0,0 @@
-# Config file for a BSVC m68k simulator
-include $(RTEMS_ROOT)/make/custom/default.cfg
-RTEMS_CPU=m68k
-RTEMS_CPU_MODEL=m68000
-# This contains the compiler options necessary to select the CPU model
-# and (hopefully) optimize for it.
-CPU_CFLAGS = -mcpu=68000
-# optimize flag: typically -O2
-CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
-define bsp-post-link
- $(default-bsp-post-link)
- $(OBJCOPY) -O srec $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
-endef
diff --git a/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg b/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg
index 817e162..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg
+++ /dev/null
@@ -1,20 +0,0 @@
-# Configuration file for a simcpu32 in BSCV
-RTEMS_CPU=m68k
-RTEMS_CPU_MODEL=mcpu32
-CPU_CFLAGS = -mcpu=cpu32
-endef
diff --git a/c/src/lib/libbsp/m68k/sim68000/preinstall.am b/c/src/lib/libbsp/m68k/sim68000/preinstall.am
index 347e43d..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/preinstall.am
+++ /dev/null
@@ -1,67 +0,0 @@
-## Automatically generated by ampolish3 - Do not edit
-if AMPOLISH3
-$(srcdir)/preinstall.am: Makefile.am
- $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
-endif
-PREINSTALL_DIRS =
-DISTCLEANFILES += $(PREINSTALL_DIRS)
-all-am: $(PREINSTALL_FILES)
-PREINSTALL_FILES =
-CLEANFILES = $(PREINSTALL_FILES)
-all-local: $(TMPINSTALL_FILES)
-TMPINSTALL_FILES =
-CLEANFILES += $(TMPINSTALL_FILES)
-$(PROJECT_LIB)/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_LIB)
- @: > $(PROJECT_LIB)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
-$(PROJECT_INCLUDE)/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_INCLUDE)
- @: > $(PROJECT_INCLUDE)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
-$(PROJECT_INCLUDE)/bsp/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
- @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
-PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
-$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
-$(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
-$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
-$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
-$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
-$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
-TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
-$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
-PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
diff --git a/c/src/lib/libbsp/m68k/sim68000/sim68000.setup b/c/src/lib/libbsp/m68k/sim68000/sim68000.setup
index efbbe75..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/sim68000.setup
+++ /dev/null
@@ -1,8 +0,0 @@
-BSVC Simulator Setup File
-UI_VERSION {2.0}
-SIMULATOR {sim68000}
-COMMAND {AttachDevice 0 RAM {BaseAddress = 0 Size = 40000}}
-COMMAND {AttachDevice 0 RAM {BaseAddress = 40000 Size = 20000}}
-COMMAND {AttachDevice 0 M68681 {BaseAddress = 71001 OffsetToFirstRegister = 0 OffsetBetweenRegisters = 2 InterruptLevel = 4 PortAStandardInputOutputFlag = 0 PortBStandardInputOutputFlag = 0 PortACommand = xterm -T "M68681 Port A" -132 -fn fixed -e /usr3/tmp/bsvc-2.1/bin/xtermpipe PortBCommand = }}
-COMMAND {AttachDevice 0 Timer {BaseAddress = 72001 IRQ = 5}}
diff --git a/c/src/lib/libbsp/m68k/sim68000/start/start.S b/c/src/lib/libbsp/m68k/sim68000/start/start.S
index 70b7a3c..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/start/start.S
+++ /dev/null
@@ -1,406 +0,0 @@
- * Re-written the gen68302 start-up code.
- * Uses gas syntax only, removed the OAR asm.h.
- * Supplies a complete vector table in ROM.
- * Manages all vectors with seperate handlers to trap unhandled
- * execptions.
- * Uses the target specific header file to get the runtime
- * configuration
- * COPYRIGHT (c) 1996
- * Objective Design Systems Pty Ltd (ODS)
- * COPYRIGHT (c) 1989, 1990, 1991, 1992, 1993, 1994.
-#define STACK_AT_RESET 0x0
-| Boot boot code in a special section, ld postions
-| Initial stack pointer is in the dual ported RAM
- .sect .text
- .global _start | program entry
- .global M68Kvec | Vector Table
-_start: | standard name for program entry
-M68Kvec: | standard location for vectors
-| Make relative, can have the code positioned any where
-V___ISSP: .long STACK_AT_RESET
-V____IPC: .long start - V___ISSP
-| Create the rest of the vector table to point to the unhandled expection
-| handler
-| Lots of macros, how-ever it creates a simple ROM vector table
-#if defined(__mcpu32__)
- .space 1016 | reserve space for rest of vectors
-#else
-#define MAKE_EXCEPTION_VECTOR(n) V___##n: .long (_CPU_ISR_jump_table + (n * 10))
-MAKE_EXCEPTION_VECTOR(2)
-MAKE_EXCEPTION_VECTOR(3)
-MAKE_EXCEPTION_VECTOR(4)
-MAKE_EXCEPTION_VECTOR(5)
-MAKE_EXCEPTION_VECTOR(6)
-MAKE_EXCEPTION_VECTOR(7)
-MAKE_EXCEPTION_VECTOR(8)
-MAKE_EXCEPTION_VECTOR(9)
-MAKE_EXCEPTION_VECTOR(10)
-MAKE_EXCEPTION_VECTOR(11)
-MAKE_EXCEPTION_VECTOR(12)
-MAKE_EXCEPTION_VECTOR(13)
-MAKE_EXCEPTION_VECTOR(14)
-MAKE_EXCEPTION_VECTOR(15)
-MAKE_EXCEPTION_VECTOR(16)
-MAKE_EXCEPTION_VECTOR(17)
-MAKE_EXCEPTION_VECTOR(18)
-MAKE_EXCEPTION_VECTOR(19)
-MAKE_EXCEPTION_VECTOR(20)
-MAKE_EXCEPTION_VECTOR(21)
-MAKE_EXCEPTION_VECTOR(22)
-MAKE_EXCEPTION_VECTOR(23)
-MAKE_EXCEPTION_VECTOR(24)
-MAKE_EXCEPTION_VECTOR(25)
-MAKE_EXCEPTION_VECTOR(26)
-MAKE_EXCEPTION_VECTOR(27)
-MAKE_EXCEPTION_VECTOR(28)
-MAKE_EXCEPTION_VECTOR(29)
-MAKE_EXCEPTION_VECTOR(30)
-MAKE_EXCEPTION_VECTOR(31)
-MAKE_EXCEPTION_VECTOR(32)
-MAKE_EXCEPTION_VECTOR(33)
-MAKE_EXCEPTION_VECTOR(34)
-MAKE_EXCEPTION_VECTOR(35)
-MAKE_EXCEPTION_VECTOR(36)
-MAKE_EXCEPTION_VECTOR(37)
-MAKE_EXCEPTION_VECTOR(38)
-MAKE_EXCEPTION_VECTOR(39)
-MAKE_EXCEPTION_VECTOR(40)
-MAKE_EXCEPTION_VECTOR(41)
-MAKE_EXCEPTION_VECTOR(42)
-MAKE_EXCEPTION_VECTOR(43)
-MAKE_EXCEPTION_VECTOR(44)
-MAKE_EXCEPTION_VECTOR(45)
-MAKE_EXCEPTION_VECTOR(46)
-MAKE_EXCEPTION_VECTOR(47)
-MAKE_EXCEPTION_VECTOR(48)
-MAKE_EXCEPTION_VECTOR(49)
-MAKE_EXCEPTION_VECTOR(50)
-MAKE_EXCEPTION_VECTOR(51)
-MAKE_EXCEPTION_VECTOR(52)
-MAKE_EXCEPTION_VECTOR(53)
-MAKE_EXCEPTION_VECTOR(54)
-MAKE_EXCEPTION_VECTOR(55)
-MAKE_EXCEPTION_VECTOR(56)
-MAKE_EXCEPTION_VECTOR(57)
-MAKE_EXCEPTION_VECTOR(58)
-MAKE_EXCEPTION_VECTOR(59)
-MAKE_EXCEPTION_VECTOR(60)
-MAKE_EXCEPTION_VECTOR(61)
-MAKE_EXCEPTION_VECTOR(62)
-MAKE_EXCEPTION_VECTOR(63)
-MAKE_EXCEPTION_VECTOR(64)
-MAKE_EXCEPTION_VECTOR(65)
-MAKE_EXCEPTION_VECTOR(66)
-MAKE_EXCEPTION_VECTOR(67)
-MAKE_EXCEPTION_VECTOR(68)
-MAKE_EXCEPTION_VECTOR(69)
-MAKE_EXCEPTION_VECTOR(70)
-MAKE_EXCEPTION_VECTOR(71)
-MAKE_EXCEPTION_VECTOR(72)
-MAKE_EXCEPTION_VECTOR(73)
-MAKE_EXCEPTION_VECTOR(74)
-MAKE_EXCEPTION_VECTOR(75)
-MAKE_EXCEPTION_VECTOR(76)
-MAKE_EXCEPTION_VECTOR(77)
-MAKE_EXCEPTION_VECTOR(78)
-MAKE_EXCEPTION_VECTOR(79)
-MAKE_EXCEPTION_VECTOR(80)
-MAKE_EXCEPTION_VECTOR(81)
-MAKE_EXCEPTION_VECTOR(82)
-MAKE_EXCEPTION_VECTOR(83)
-MAKE_EXCEPTION_VECTOR(84)
-MAKE_EXCEPTION_VECTOR(85)
-MAKE_EXCEPTION_VECTOR(86)
-MAKE_EXCEPTION_VECTOR(87)
-MAKE_EXCEPTION_VECTOR(88)
-MAKE_EXCEPTION_VECTOR(89)
-MAKE_EXCEPTION_VECTOR(90)
-MAKE_EXCEPTION_VECTOR(91)
-MAKE_EXCEPTION_VECTOR(92)
-MAKE_EXCEPTION_VECTOR(93)
-MAKE_EXCEPTION_VECTOR(94)
-MAKE_EXCEPTION_VECTOR(95)
-MAKE_EXCEPTION_VECTOR(96)
-MAKE_EXCEPTION_VECTOR(97)
-MAKE_EXCEPTION_VECTOR(98)
-MAKE_EXCEPTION_VECTOR(99)
-MAKE_EXCEPTION_VECTOR(100)
-MAKE_EXCEPTION_VECTOR(101)
-MAKE_EXCEPTION_VECTOR(102)
-MAKE_EXCEPTION_VECTOR(103)
-MAKE_EXCEPTION_VECTOR(104)
-MAKE_EXCEPTION_VECTOR(105)
-MAKE_EXCEPTION_VECTOR(106)
-MAKE_EXCEPTION_VECTOR(107)
-MAKE_EXCEPTION_VECTOR(108)
-MAKE_EXCEPTION_VECTOR(109)
-MAKE_EXCEPTION_VECTOR(110)
-MAKE_EXCEPTION_VECTOR(111)
-MAKE_EXCEPTION_VECTOR(112)
-MAKE_EXCEPTION_VECTOR(113)
-MAKE_EXCEPTION_VECTOR(114)
-MAKE_EXCEPTION_VECTOR(115)
-MAKE_EXCEPTION_VECTOR(116)
-MAKE_EXCEPTION_VECTOR(117)
-MAKE_EXCEPTION_VECTOR(118)
-MAKE_EXCEPTION_VECTOR(119)
-MAKE_EXCEPTION_VECTOR(120)
-MAKE_EXCEPTION_VECTOR(121)
-MAKE_EXCEPTION_VECTOR(122)
-MAKE_EXCEPTION_VECTOR(123)
-MAKE_EXCEPTION_VECTOR(124)
-MAKE_EXCEPTION_VECTOR(125)
-MAKE_EXCEPTION_VECTOR(126)
-MAKE_EXCEPTION_VECTOR(127)
-MAKE_EXCEPTION_VECTOR(128)
-MAKE_EXCEPTION_VECTOR(129)
-MAKE_EXCEPTION_VECTOR(130)
-MAKE_EXCEPTION_VECTOR(131)
-MAKE_EXCEPTION_VECTOR(132)
-MAKE_EXCEPTION_VECTOR(133)
-MAKE_EXCEPTION_VECTOR(134)
-MAKE_EXCEPTION_VECTOR(135)
-MAKE_EXCEPTION_VECTOR(136)
-MAKE_EXCEPTION_VECTOR(137)
-MAKE_EXCEPTION_VECTOR(138)
-MAKE_EXCEPTION_VECTOR(139)
-MAKE_EXCEPTION_VECTOR(140)
-MAKE_EXCEPTION_VECTOR(141)
-MAKE_EXCEPTION_VECTOR(142)
-MAKE_EXCEPTION_VECTOR(143)
-MAKE_EXCEPTION_VECTOR(144)
-MAKE_EXCEPTION_VECTOR(145)
-MAKE_EXCEPTION_VECTOR(146)
-MAKE_EXCEPTION_VECTOR(147)
-MAKE_EXCEPTION_VECTOR(148)
-MAKE_EXCEPTION_VECTOR(149)
-MAKE_EXCEPTION_VECTOR(150)
-MAKE_EXCEPTION_VECTOR(151)
-MAKE_EXCEPTION_VECTOR(152)
-MAKE_EXCEPTION_VECTOR(153)
-MAKE_EXCEPTION_VECTOR(154)
-MAKE_EXCEPTION_VECTOR(155)
-MAKE_EXCEPTION_VECTOR(156)
-MAKE_EXCEPTION_VECTOR(157)
-MAKE_EXCEPTION_VECTOR(158)
-MAKE_EXCEPTION_VECTOR(159)
-MAKE_EXCEPTION_VECTOR(160)
-MAKE_EXCEPTION_VECTOR(161)
-MAKE_EXCEPTION_VECTOR(162)
-MAKE_EXCEPTION_VECTOR(163)
-MAKE_EXCEPTION_VECTOR(164)
-MAKE_EXCEPTION_VECTOR(165)
-MAKE_EXCEPTION_VECTOR(166)
-MAKE_EXCEPTION_VECTOR(167)
-MAKE_EXCEPTION_VECTOR(168)
-MAKE_EXCEPTION_VECTOR(169)
-MAKE_EXCEPTION_VECTOR(170)
-MAKE_EXCEPTION_VECTOR(171)
-MAKE_EXCEPTION_VECTOR(172)
-MAKE_EXCEPTION_VECTOR(173)
-MAKE_EXCEPTION_VECTOR(174)
-MAKE_EXCEPTION_VECTOR(175)
-MAKE_EXCEPTION_VECTOR(176)
-MAKE_EXCEPTION_VECTOR(177)
-MAKE_EXCEPTION_VECTOR(178)
-MAKE_EXCEPTION_VECTOR(179)
-MAKE_EXCEPTION_VECTOR(180)
-MAKE_EXCEPTION_VECTOR(181)
-MAKE_EXCEPTION_VECTOR(182)
-MAKE_EXCEPTION_VECTOR(183)
-MAKE_EXCEPTION_VECTOR(184)
-MAKE_EXCEPTION_VECTOR(185)
-MAKE_EXCEPTION_VECTOR(186)
-MAKE_EXCEPTION_VECTOR(187)
-MAKE_EXCEPTION_VECTOR(188)
-MAKE_EXCEPTION_VECTOR(189)
-MAKE_EXCEPTION_VECTOR(190)
-MAKE_EXCEPTION_VECTOR(191)
-MAKE_EXCEPTION_VECTOR(192)
-MAKE_EXCEPTION_VECTOR(193)
-MAKE_EXCEPTION_VECTOR(194)
-MAKE_EXCEPTION_VECTOR(195)
-MAKE_EXCEPTION_VECTOR(196)
-MAKE_EXCEPTION_VECTOR(197)
-MAKE_EXCEPTION_VECTOR(198)
-MAKE_EXCEPTION_VECTOR(199)
-MAKE_EXCEPTION_VECTOR(200)
-MAKE_EXCEPTION_VECTOR(201)
-MAKE_EXCEPTION_VECTOR(202)
-MAKE_EXCEPTION_VECTOR(203)
-MAKE_EXCEPTION_VECTOR(204)
-MAKE_EXCEPTION_VECTOR(205)
-MAKE_EXCEPTION_VECTOR(206)
-MAKE_EXCEPTION_VECTOR(207)
-MAKE_EXCEPTION_VECTOR(208)
-MAKE_EXCEPTION_VECTOR(209)
-MAKE_EXCEPTION_VECTOR(210)
-MAKE_EXCEPTION_VECTOR(211)
-MAKE_EXCEPTION_VECTOR(212)
-MAKE_EXCEPTION_VECTOR(213)
-MAKE_EXCEPTION_VECTOR(214)
-MAKE_EXCEPTION_VECTOR(215)
-MAKE_EXCEPTION_VECTOR(216)
-MAKE_EXCEPTION_VECTOR(217)
-MAKE_EXCEPTION_VECTOR(218)
-MAKE_EXCEPTION_VECTOR(219)
-MAKE_EXCEPTION_VECTOR(220)
-MAKE_EXCEPTION_VECTOR(221)
-MAKE_EXCEPTION_VECTOR(222)
-MAKE_EXCEPTION_VECTOR(223)
-MAKE_EXCEPTION_VECTOR(224)
-MAKE_EXCEPTION_VECTOR(225)
-MAKE_EXCEPTION_VECTOR(226)
-MAKE_EXCEPTION_VECTOR(227)
-MAKE_EXCEPTION_VECTOR(228)
-MAKE_EXCEPTION_VECTOR(229)
-MAKE_EXCEPTION_VECTOR(230)
-MAKE_EXCEPTION_VECTOR(231)
-MAKE_EXCEPTION_VECTOR(232)
-MAKE_EXCEPTION_VECTOR(233)
-MAKE_EXCEPTION_VECTOR(234)
-MAKE_EXCEPTION_VECTOR(235)
-MAKE_EXCEPTION_VECTOR(236)
-MAKE_EXCEPTION_VECTOR(237)
-MAKE_EXCEPTION_VECTOR(238)
-MAKE_EXCEPTION_VECTOR(239)
-MAKE_EXCEPTION_VECTOR(240)
-MAKE_EXCEPTION_VECTOR(241)
-MAKE_EXCEPTION_VECTOR(242)
-MAKE_EXCEPTION_VECTOR(243)
-MAKE_EXCEPTION_VECTOR(244)
-MAKE_EXCEPTION_VECTOR(245)
-MAKE_EXCEPTION_VECTOR(246)
-MAKE_EXCEPTION_VECTOR(247)
-MAKE_EXCEPTION_VECTOR(248)
-MAKE_EXCEPTION_VECTOR(249)
-MAKE_EXCEPTION_VECTOR(250)
-MAKE_EXCEPTION_VECTOR(251)
-MAKE_EXCEPTION_VECTOR(252)
-MAKE_EXCEPTION_VECTOR(253)
-MAKE_EXCEPTION_VECTOR(254)
-MAKE_EXCEPTION_VECTOR(255)
-#endif
-| Start
-| Entered from a hardware reset.
- .global start | Default entry point for GNU
-start:
- | Copy initialized data area from ROM to RAM
-copy_data:
- moveal #_etext,%a0 | find the end of .text
- moveal #_copy_start,%a1 | find the beginning of .data
- moveal #_edata,%a2 | find the end of .data
-copy_data_loop:
- movel %a0 at +,%a1 at + | copy the data
- cmpal %a2,%a1
- jlt copy_data_loop | loop until edata reached
- | zero out uninitialized data area
-zerobss:
- moveal #_clear_end,%a0 | find end of .bss
- moveal #_clear_start,%a1 | find beginning of .bss
- moveq #0,%d0
-zerobss_loop:
- movel %d0,%a1 at + | to zero out uninitialized
- cmpal %a0,%a1
- jlt zerobss_loop | loop until _end reached
- movel #_stack_init,%d0 | load stack top
- movw #0x3700,%sr | SUPV MODE,INTERRUPTS OFF!!!
- movel %d0,%a7 | set master stack pointer
- movel %d0,%a6 | set base pointer
- movel #0,%a7 at - | push argc
- jsr boot_card
- | if this returns, what do we do???
- .global bsp_exitted
-bsp_exitted:
- jmp bsp_exitted
-| Initialised data
- .sect .data
-| Uninitialised data
- .sect .bss
- .global environ
- .align 2
-environ:
- .long 0
diff --git a/c/src/lib/libbsp/m68k/sim68000/startup/bsppredriverhook.c b/c/src/lib/libbsp/m68k/sim68000/startup/bsppredriverhook.c
index b3a0674..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/startup/bsppredriverhook.c
+++ /dev/null
@@ -1,20 +0,0 @@
- * COPYRIGHT (c) 1989-1999.
-#include <bsp.h>
-#include <bsp/bootcard.h>
-extern void bsp_spurious_initialize(void);
-void bsp_predriver_hook(void)
- /* on CPU32: do something about vectors!!! */
- bsp_spurious_initialize();
diff --git a/c/src/lib/libbsp/m68k/sim68000/startup/linkcmds b/c/src/lib/libbsp/m68k/sim68000/startup/linkcmds
index 9a326b3..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/startup/linkcmds
+++ /dev/null
@@ -1,200 +0,0 @@
- * MC68302 Linker command file
- * Declare some sizes.
-_RomBase = DEFINED(_RomBase) ? _RomBase : 0x0;
-_RomSize = DEFINED(_RomSize) ? _RomSize : 512K;
-RamBase = DEFINED(RamBase) ? RamBase : 0x80000;
-RamSize = DEFINED(RamSize) ? RamSize : 128K;
-HeapSize = DEFINED(HeapSize) ? HeapSize : 0;
-_StackSize = DEFINED(_StackSize) ? _StackSize : 0x1000;
- * Declare on-board memory.
-MEMORY {
- eprom : ORIGIN = 0x00000000, LENGTH = 512K
- ram : ORIGIN = 0x00040000, LENGTH = 128K
-SECTIONS
- ram : {
- } >ram
- * Text, data and bss segments
- .text 0x0 : {
- *(.text*)
- * C++ constructors/destructors
- *(.gnu.linkonce.t.*)
- * Initialization and finalization code.
- * Various files can provide initialization and finalization
- * functions. crtbegin.o and crtend.o are two instances. The
- * body of these functions are in .init and .fini sections. We
- * accumulate the bodies here, and prepend function prologues
- * from crti.o and function epilogues from crtn.o. crti.o must
- * be linked first; crtn.o must be linked last. Because these
- * are wildcards, it doesn't matter if the user does not
- * actually link against crti.o and crtn.o; the linker won't
- * look for a file to match a wildcard. The wildcard also
- * means that it doesn't matter which directory crti.o and
- * crtn.o are in.
- PROVIDE (_init = .);
- *crti.o(.init)
- *(.init)
- *crtn.o(.init)
- PROVIDE (_fini = .);
- *crti.o(.fini)
- *(.fini)
- *crtn.o(.fini)
- * Special FreeBSD sysctl sections.
- . = ALIGN (16);
- __start_set_sysctl_set = .;
- *(set_sysctl_*);
- __stop_set_sysctl_set = ABSOLUTE(.);
- *(set_domain_*);
- *(set_pseudo_*);
- * gcc uses crtbegin.o to find the start of the constructors
- * and destructors so we make sure it is first. Because this
- * is a wildcard, it doesn't matter if the user does not
- * actually link against crtbegin.o; the linker won't look for
- * a file to match a wildcard. The wildcard also means that
- * it doesn't matter which directory crtbegin.o is in. The
- * constructor and destructor list are terminated in
- * crtend.o. The same comments apply to it.
- . = ALIGN (16);
- *crtbegin.o(.ctors)
- *(.ctors)
- *crtend.o(.ctors)
- *crtbegin.o(.dtors)
- *(.dtors)
- *crtend.o(.dtors)
- * Exception frame info
- . = ALIGN (16);
- *(.eh_frame)
- * Read-only data
- . = ALIGN (16);
- _rodata_start = .;
- *(.rodata*)
- *(.gnu.linkonce.r*)
- . = ALIGN (16);
- PROVIDE (_etext = .);
- .tdata ADDR(.text) + SIZEOF (.text) : {
- _TLS_Data_begin = .;
- *(.tdata .tdata.* .gnu.linkonce.td.*)
- _TLS_Data_end = .;
- .tbss ADDR(.tdata) + SIZEOF (.tdata) : {
- _TLS_BSS_begin = .;
- *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
- _TLS_BSS_end = .;
- _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
- _TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
- _TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
- _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
- _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
- _TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
- .data 0x80000 : AT (ADDR(.tdata) + SIZEOF (.tdata)) {
- PROVIDE (_copy_start = .);
- *(.data*)
- *(.gnu.linkonce.d*)
- *(.gcc_except_table*)
- *(.jcr)
- . = ALIGN (16);
- PROVIDE (_edata = .);
- PROVIDE (_copy_end = .);
- .bss ADDR(.data) + SIZEOF(.data) : {
- _clear_start = .;
- *(.dynbss)
- *(.bss* .gnu.linkonce.b.*)
- *(COMMON)
- . = ALIGN (16);
- PROVIDE (end = .);
- . += _StackSize;
- . = ALIGN (16);
- _stack_init = .;
- _clear_end = .;
- WorkAreaBase = .;
- /* Stabs debugging sections. */
- .stab 0 : { *(.stab) }
- .stabstr 0 : { *(.stabstr) }
- .stab.excl 0 : { *(.stab.excl) }
- .stab.exclstr 0 : { *(.stab.exclstr) }
- .stab.index 0 : { *(.stab.index) }
- .stab.indexstr 0 : { *(.stab.indexstr) }
- .comment 0 : { *(.comment) }
- /* DWARF debug sections.
- Symbols in the DWARF debugging sections are relative to the beginning
- of the section so we begin them at 0. */
- /* DWARF 1 */
- .debug 0 : { *(.debug) }
- .line 0 : { *(.line) }
- /* GNU DWARF 1 extensions */
- .debug_srcinfo 0 : { *(.debug_srcinfo) }
- .debug_sfnames 0 : { *(.debug_sfnames) }
- /* DWARF 1.1 and DWARF 2 */
- .debug_aranges 0 : { *(.debug_aranges) }
- .debug_pubnames 0 : { *(.debug_pubnames) }
- /* DWARF 2 */
- .debug_info 0 : { *(.debug_info) }
- .debug_abbrev 0 : { *(.debug_abbrev) }
- .debug_line 0 : { *(.debug_line) }
- .debug_frame 0 : { *(.debug_frame) }
- .debug_str 0 : { *(.debug_str) }
- .debug_loc 0 : { *(.debug_loc) }
- .debug_macinfo 0 : { *(.debug_macinfo) }
- /* SGI/MIPS DWARF 2 extensions */
- .debug_weaknames 0 : { *(.debug_weaknames) }
- .debug_funcnames 0 : { *(.debug_funcnames) }
- .debug_typenames 0 : { *(.debug_typenames) }
- .debug_varnames 0 : { *(.debug_varnames) }
- /* These must appear regardless of . */
-/* _VBR = 0xFFFFFFFF; * indicates VBR table is in ROM */
-_VBR = 0x0; /* indicates VBR table is in RAM */
diff --git a/c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c b/c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c
index 032763e..0000000
--- a/c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c
+++ /dev/null
@@ -1,27 +0,0 @@
- * Spurious Trap Handler Assistant
-#include <bsp.h>
- * bsp_spurious_handler_assistant
- * We can't recover so just return to gdb.
- rtems_vector_number vector
- /* XXX do something here */
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
