[PATCH 2/2] score: Delete unused API extensions
Tue Dec 8 11:59:22 UTC 2015
Seems fine, is there any associated documentation/doxygen to update?
On Tue, Dec 8, 2015 at 2:35 AM, Sebastian Huber
> Update #2408.
>  cpukit/sapi/src/exinit.c                  |  7 -------
>  cpukit/score/include/rtems/score/apiext.h | 28 +---------------------------
>  cpukit/score/src/apiext.c                 | 24 +-----------------------
>  3 files changed, 2 insertions(+), 57 deletions(-)
> diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
> index b29d8c0..794ccb4 100644
> --- a/cpukit/sapi/src/exinit.c
> +++ b/cpukit/sapi/src/exinit.c
> @@ -164,13 +164,6 @@ void rtems_initialize_before_drivers(void)
>    #if defined(RTEMS_MULTIPROCESSING)
>      _MPCI_Create_server();
>    #endif
> -  #if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
> -     *  Run the API and BSPs predriver hook.
> -    _API_extensions_Run_predriver();
> -  #endif
>  void rtems_initialize_device_drivers(void)
> diff --git a/cpukit/score/include/rtems/score/apiext.h b/cpukit/score/include/rtems/score/apiext.h
> index 44f16e5..fca47f2 100644
> --- a/cpukit/score/include/rtems/score/apiext.h
> +++ b/cpukit/score/include/rtems/score/apiext.h
> @@ -19,7 +19,6 @@
>  #define _RTEMS_SCORE_APIEXT_H
>  #include <rtems/score/chainimpl.h>
> -#include <rtems/score/thread.h>
>  #ifdef __cplusplus
>  extern "C" {
> @@ -39,13 +38,6 @@ extern "C" {
> -#if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
> -   *  This type defines the prototype of the Predriver Hook.
> -  typedef void (*API_extensions_Predriver_hook)(void);
> -#endif
>   *  This type defines the prototype of the Postdriver Hook.
> @@ -58,16 +50,7 @@ typedef void (*API_extensions_Postdriver_hook)(void);
>  typedef struct {
>    /** This field allows this structure to be used with the Chain Handler. */
>    Chain_Node                      Node;
> -     * This field is the callout invoked during RTEMS initialization after
> -     * RTEMS data structures are initialized before device driver initialization
> -     * has occurred.
> -     * @note If this field is NULL, no extension is invoked.
> -    API_extensions_Predriver_hook   predriver_hook;
> -  #endif
>     * RTEMS data structures and device driver initialization has occurred
> @@ -94,15 +77,6 @@ void _API_extensions_Add(
>    API_extensions_Control *the_extension
> - *  @brief Execute all pre-driver extensions.
> - *  This routine executes all of the predriver callouts.
> -  void _API_extensions_Run_predriver( void );
> -#endif
>   *  @brief Execute all post-driver extensions.
> diff --git a/cpukit/score/src/apiext.c b/cpukit/score/src/apiext.c
> index 1d5ce96..fd8ca0f 100644
> --- a/cpukit/score/src/apiext.c
> +++ b/cpukit/score/src/apiext.c
> @@ -30,25 +30,6 @@ void _API_extensions_Add(
>    _Chain_Append( &_API_extensions_List, &the_extension->Node );
> -    Chain_Node             *the_node;
> -    API_extensions_Control *the_extension;
> -    for ( the_node = _Chain_First( &_API_extensions_List );
> -         !_Chain_Is_tail( &_API_extensions_List, the_node ) ;
> -         the_node = the_node->next ) {
> -      the_extension = (API_extensions_Control *) the_node;
> -      if ( the_extension->predriver_hook )
> -       (*the_extension->predriver_hook)();
> -#endif
>  void _API_extensions_Run_postdriver( void )
> @@ -63,9 +44,6 @@ void _API_extensions_Run_postdriver( void )
>       *  Currently all APIs configure this hook so it is always non-NULL.
> -    if ( the_extension->postdriver_hook )
> -#endif
> -      (*the_extension->postdriver_hook)();
> +    (*the_extension->postdriver_hook)();
> 1.8.4.5
> devel mailing list
> devel at rtems.org
