[PATCH 2/2] score: Delete unused API extensions
Tue Dec 8 11:59:43 UTC 2015
Nvm I see the doxy in the patch, didn't at first. OK
On Tue, Dec 8, 2015 at 6:59 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Seems fine, is there any associated documentation/doxygen to update?
> On Tue, Dec 8, 2015 at 2:35 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Update #2408.
>>  cpukit/sapi/src/exinit.c                  |  7 -------
>>  cpukit/score/include/rtems/score/apiext.h | 28 +---------------------------
>>  cpukit/score/src/apiext.c                 | 24 +-----------------------
>>  3 files changed, 2 insertions(+), 57 deletions(-)
>> diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
>> index b29d8c0..794ccb4 100644
>> --- a/cpukit/sapi/src/exinit.c
>> +++ b/cpukit/sapi/src/exinit.c
>> @@ -164,13 +164,6 @@ void rtems_initialize_before_drivers(void)
>>    #if defined(RTEMS_MULTIPROCESSING)
>>      _MPCI_Create_server();
>>    #endif
>> -  #if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
>> -     *  Run the API and BSPs predriver hook.
>> -    _API_extensions_Run_predriver();
>> -  #endif
>>  void rtems_initialize_device_drivers(void)
>> diff --git a/cpukit/score/include/rtems/score/apiext.h b/cpukit/score/include/rtems/score/apiext.h
>> index 44f16e5..fca47f2 100644
>> --- a/cpukit/score/include/rtems/score/apiext.h
>> +++ b/cpukit/score/include/rtems/score/apiext.h
>> @@ -19,7 +19,6 @@
>>  #define _RTEMS_SCORE_APIEXT_H
>>  #include <rtems/score/chainimpl.h>
>> -#include <rtems/score/thread.h>
>>  #ifdef __cplusplus
>>  extern "C" {
>> @@ -39,13 +38,6 @@ extern "C" {
>> -#if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
>> -   *  This type defines the prototype of the Predriver Hook.
>> -  typedef void (*API_extensions_Predriver_hook)(void);
>> -#endif
>>   *  This type defines the prototype of the Postdriver Hook.
>> @@ -58,16 +50,7 @@ typedef void (*API_extensions_Postdriver_hook)(void);
>>  typedef struct {
>>    /** This field allows this structure to be used with the Chain Handler. */
>>    Chain_Node                      Node;
>> -     * This field is the callout invoked during RTEMS initialization after
>> -     * RTEMS data structures are initialized before device driver initialization
>> -     * has occurred.
>> -     * @note If this field is NULL, no extension is invoked.
>> -    API_extensions_Predriver_hook   predriver_hook;
>> -  #endif
>>     * RTEMS data structures and device driver initialization has occurred
>> @@ -94,15 +77,6 @@ void _API_extensions_Add(
>>    API_extensions_Control *the_extension
>> - *  @brief Execute all pre-driver extensions.
>> - *  This routine executes all of the predriver callouts.
>> -  void _API_extensions_Run_predriver( void );
>> -#endif
>>   *  @brief Execute all post-driver extensions.
>> diff --git a/cpukit/score/src/apiext.c b/cpukit/score/src/apiext.c
>> index 1d5ce96..fd8ca0f 100644
>> --- a/cpukit/score/src/apiext.c
>> +++ b/cpukit/score/src/apiext.c
>> @@ -30,25 +30,6 @@ void _API_extensions_Add(
>>    _Chain_Append( &_API_extensions_List, &the_extension->Node );
>> -    Chain_Node             *the_node;
>> -    API_extensions_Control *the_extension;
>> -    for ( the_node = _Chain_First( &_API_extensions_List );
>> -         !_Chain_Is_tail( &_API_extensions_List, the_node ) ;
>> -         the_node = the_node->next ) {
>> -      the_extension = (API_extensions_Control *) the_node;
>> -      if ( the_extension->predriver_hook )
>> -       (*the_extension->predriver_hook)();
>> -#endif
>>  void _API_extensions_Run_postdriver( void )
>> @@ -63,9 +44,6 @@ void _API_extensions_Run_postdriver( void )
>>       *  Currently all APIs configure this hook so it is always non-NULL.
>> -    if ( the_extension->postdriver_hook )
>> -#endif
>> -      (*the_extension->postdriver_hook)();
>> +    (*the_extension->postdriver_hook)();
>> 1.8.4.5
>> devel mailing list
>> devel at rtems.org
