Linker Set Based Initialization
Tue Dec 8 15:16:12 UTC 2015
On 08/12/15 16:09, Sebastian Huber wrote:
>> Is this something that breaks on a per BSP basis? or per architecture
>> basis?
>> I am assuming that since it is linker based, each BSP could have
>> broken linkcmds.
>> Is that right?
> It breaks on a per linker command file basis. Since all the maintained
> BSPs use a linkercmds.base, which shouldn't be a big issue.
> For requirements on the linker command file, see new chapter in user
> manual. However BSPs should not deal with this in copy and paste
> linker command files and instead use a linkercmds.base file.
Sorry, its "linkcmds.base".
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
