Linker Set Based Initialization
Tue Dec 8 15:49:41 UTC 2015
On Tue, Dec 8, 2015 at 10:45 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Dec 8, 2015 at 9:09 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 08/12/15 16:03, Joel Sherrill wrote:
>>> What BSPs/architectures have you tested?
>> I temporarily moved the splinkersets01 test to the samples/ticker and
>> tested that all BSPs build and link this test.
>> I executed the splinkersets01 test on sis, psim and
>> arm_realview_pbx_a9_qemu.
>>> Is this something that breaks on a per BSP basis? or per architecture
>>> basis?
>>> I am assuming that since it is linker based, each BSP could have broken
>>> linkcmds.
>>> Is that right?
>> It breaks on a per linker command file basis. Since all the maintained
>> BSPs use a linkercmds.base, which shouldn't be a big issue.
> That means a LOT of the BSPs are broken. You have defined maintained in your
> own way.
> There are only a handful of architectures with linkcmds.base in them:
> ./or1k/shared/startup/linkcmds.base
> ./arm/shared/startup/linkcmds.base
> ./m68k/shared/startup/linkcmds.base
> ./powerpc/tqm8xx/startup/linkcmds.base
> ./powerpc/gen5200/startup/linkcmds.base
> ./powerpc/shared/startup/linkcmds.base
> ./sparc/shared/startup/linkcmds.base
> I am not sure how many BSPs within arm, m68k, or powerpc actually use the
> linkcmds.base.
> By my count, 13 of 94 BSP families have linkcmds.base.
>> For requirements on the linker command file, see new chapter in user
>> manual. However BSPs should not deal with this in copy and paste linker
>> command files and instead use a linkercmds.base file.
> So 85% of the BSP families don't use linkcmds.base and by the above
> statement,
> they must immediately be migrated to linkcmds.base.
> Unless you have a plan to address this problem, I am on the side of
> rejecting the
> part of this patch that changes the initialization.  And the issue must be
> addressed
> before this can be merged.
How hard to make updating 1 BSP as a GCI task? Sebastian to mentor... ;-)
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> devel mailing list
> devel at rtems.org
