Linker Set Based Initialization
Sebastian Huber
Tue Dec 8 20:10:23 UTC 2015
----- Am 8. Dez 2015 um 16:03 schrieb Joel Sherrill <joel at rtems.org>:
> What BSPs/architectures have you tested?
I will test the with the attached patch tomorrow on all BSPs. This patch adds a link time test to ticker. This test verifies that the linker command file modifications for the RTEMS linker sets are all right. I verified by hand that it detects a missing KEEP(), SORT() or section description.
I think the linker set based initialization is very beneficial. For example with it we no longer need a build time option to disable/enable the POSIX API. We can enable it all the time with virtually no overhead for applications which don't use it.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151208/e5e8e040/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151208/e5e8e040/attachment.bin>
