[PATCH] powerpc/ep1a: Remove
Aun-Ali Zaidi
admin at kodeit.net
Wed Dec 9 04:01:15 UTC 2015
updates #2457.
c/src/lib/libbsp/powerpc/acinclude.m4 | 6 +-
c/src/lib/libbsp/powerpc/ep1a/Makefile.am | 100 --
c/src/lib/libbsp/powerpc/ep1a/bsp_specs | 14 -
c/src/lib/libbsp/powerpc/ep1a/configure.ac | 46 -
c/src/lib/libbsp/powerpc/ep1a/console/alloc360.c | 110 ---
c/src/lib/libbsp/powerpc/ep1a/console/config.c | 439 ---------
c/src/lib/libbsp/powerpc/ep1a/console/console.h | 20 -
c/src/lib/libbsp/powerpc/ep1a/console/init68360.c | 35 -
c/src/lib/libbsp/powerpc/ep1a/console/m68360.h | 978 -------------------
.../lib/libbsp/powerpc/ep1a/console/mc68360_scc.c | 904 -----------------
c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.c | 53 -
c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h | 43 -
c/src/lib/libbsp/powerpc/ep1a/console/polled_io.c | 1026 --------------------
.../libbsp/powerpc/ep1a/console/printk_support.c | 49 -
c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.c | 402 --------
c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.h | 163 ----
c/src/lib/libbsp/powerpc/ep1a/include/bsp.h | 209 ----
c/src/lib/libbsp/powerpc/ep1a/include/tm27.h | 64 --
c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c | 216 -----
.../lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c | 234 -----
c/src/lib/libbsp/powerpc/ep1a/make/custom/ep1a.cfg | 17 -
c/src/lib/libbsp/powerpc/ep1a/pci/no_host_bridge.c | 28 -
c/src/lib/libbsp/powerpc/ep1a/preinstall.am | 143 ---
c/src/lib/libbsp/powerpc/ep1a/start/start.S | 146 ---
c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c | 353 -------
c/src/lib/libbsp/powerpc/ep1a/startup/linkcmds | 208 ----
c/src/lib/libbsp/powerpc/ep1a/vme/VMEConfig.h | 113 ---
27 files changed, 2 insertions(+), 6117 deletions(-)
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/Makefile.am
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/bsp_specs
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/configure.ac
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/alloc360.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/config.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/console.h
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/init68360.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/m68360.h
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/polled_io.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/printk_support.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.h
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/include/bsp.h
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/include/tm27.h
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/make/custom/ep1a.cfg
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/pci/no_host_bridge.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/preinstall.am
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/start/start.S
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/startup/linkcmds
delete mode 100644 c/src/lib/libbsp/powerpc/ep1a/vme/VMEConfig.h
diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4 b/c/src/lib/libbsp/powerpc/acinclude.m4
index 6442399..b0a2513 100644
--- a/c/src/lib/libbsp/powerpc/acinclude.m4
+++ b/c/src/lib/libbsp/powerpc/acinclude.m4
@@ -4,8 +4,6 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
case "$1" in
beatnik )
AC_CONFIG_SUBDIRS([beatnik]);;
- ep1a )
- AC_CONFIG_SUBDIRS([ep1a]);;
gen5200 )
AC_CONFIG_SUBDIRS([gen5200]);;
gen83xx )
@@ -38,12 +36,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
AC_CONFIG_SUBDIRS([t32mppc]);;
tqm8xx )
AC_CONFIG_SUBDIRS([tqm8xx]);;
- virtex )
- AC_CONFIG_SUBDIRS([virtex]);;
virtex4 )
AC_CONFIG_SUBDIRS([virtex4]);;
virtex5 )
AC_CONFIG_SUBDIRS([virtex5]);;
+ virtex )
+ AC_CONFIG_SUBDIRS([virtex]);;
AC_MSG_ERROR([Invalid BSP]);;
esac
diff --git a/c/src/lib/libbsp/powerpc/ep1a/Makefile.am b/c/src/lib/libbsp/powerpc/ep1a/Makefile.am
deleted file mode 100644
index b1d0394..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/Makefile.am
+++ /dev/null
@@ -1,100 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../../aclocal
-include $(top_srcdir)/../../../../automake/compile.am
-include_bspdir = $(includedir)/bsp
-dist_project_lib_DATA = bsp_specs
-include_HEADERS = include/bsp.h
-include_HEADERS += include/tm27.h
-nodist_include_HEADERS = include/bspopts.h
-nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
-DISTCLEANFILES = include/bspopts.h
-nodist_include_HEADERS += ../../shared/include/coverhd.h
-dist_project_lib_DATA += startup/linkcmds
-noinst_LIBRARIES = libbspstart.a
-libbspstart_a_SOURCES = start/start.S
-project_lib_DATA = start.$(OBJEXT)
-libbspstart_a_SOURCES += ../../powerpc/shared/start/rtems_crti.S
-project_lib_DATA += rtems_crti.$(OBJEXT)
-noinst_LIBRARIES += libbsp.a
-libbsp_a_SOURCES =
-# startup
-libbsp_a_SOURCES += startup/bspstart.c ../../shared/bootcard.c \
- ../../shared/bsppost.c ../../shared/bsppredriverhook.c \
- ../../powerpc/shared/startup/bspgetworkarea.c ../../shared/bsplibc.c \
- ../../powerpc/shared/startup/sbrk.c \
- ../../shared/bspclean.c ../../shared/gnatinstallhandler.c \
- ../../powerpc/shared/startup/pgtbl_setup.c \
- ../../powerpc/shared/startup/pgtbl_activate.c \
- ../../powerpc/shared/showbats.c
-# pclock
-libbsp_a_SOURCES += ../../powerpc/shared/clock/p_clock.c
-include_bsp_HEADERS = ../../powerpc/shared/console/uart.h \
- ../../powerpc/shared/motorola/motorola.h \
- ../../powerpc/shared/residual/residual.h \
- ../../powerpc/shared/residual/pnp.h \
- ../../powerpc/shared/console/consoleIo.h console/rsPMCQ1.h \
- ../../shared/console_private.h
-# console
-libbsp_a_SOURCES += console/ns16550cfg.c \
- console/mc68360_scc.c console/rsPMCQ1.c console/alloc360.c \
- console/init68360.c console/config.c console/printk_support.c \
- ../../shared/console.c ../../shared/console_select.c \
- ../../shared/console_read.c ../../shared/console_write.c \
- ../../shared/console_control.c
-include_bsp_HEADERS += ../../powerpc/shared/openpic/openpic.h
-# openpic
-libbsp_a_SOURCES += ../../powerpc/shared/openpic/openpic.h \
- ../../powerpc/shared/openpic/openpic.c
-include_bsp_HEADERS += ../../powerpc/shared/pci/pci.h
-# pci
-libbsp_a_SOURCES += pci/no_host_bridge.c ../../powerpc/shared/pci/pci.c \
- ../../powerpc/shared/pci/pcifinddevice.c
-include_bsp_HEADERS += ../../powerpc/shared/irq/irq.h \
- ../../../libcpu/@RTEMS_CPU@/@exceptions@/bspsupport/irq_supp.h
-# irq
-libbsp_a_SOURCES += irq/irq_init.c irq/openpic_xxx_irq.c ../../powerpc/shared/irq/i8259.c
-include_bsp_HEADERS += ../../shared/vmeUniverse/vmeUniverse.h \
- vme/VMEConfig.h \
- ../../shared/vmeUniverse/vme_am_defs.h \
- ../../shared/vmeUniverse/VME.h \
- ../../shared/vmeUniverse/vmeUniverseDMA.h\
- ../../shared/vmeUniverse/bspVmeDmaList.h\
- ../../shared/vmeUniverse/VMEDMA.h
-# vme
-libbsp_a_SOURCES += ../../shared/vmeUniverse/vmeUniverse.c \
- ../../shared/vmeUniverse/bspVmeDmaList.c \
- ../shared/vme/vmeconfig.c \
- ../shared/vme/vme_universe.c \
-libbsp_a_LIBADD = \
- ../../../libcpu/@RTEMS_CPU@/shared/cache.rel \
- ../../../libcpu/@RTEMS_CPU@/shared/cpuIdent.rel \
- ../../../libcpu/@RTEMS_CPU@/shared/stack.rel \
- ../../../libcpu/@RTEMS_CPU@/@exceptions@/rtems-cpu.rel \
- ../../../libcpu/@RTEMS_CPU@/mpc6xx/clock.rel \
- ../../../libcpu/@RTEMS_CPU@/@exceptions@/exc_bspsupport.rel \
- ../../../libcpu/@RTEMS_CPU@/@exceptions@/irq_bspsupport.rel \
- ../../../libcpu/@RTEMS_CPU@/mpc6xx/mmu.rel \
- ../../../libcpu/@RTEMS_CPU@/mpc6xx/timer.rel
-include $(srcdir)/preinstall.am
-include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/powerpc/ep1a/bsp_specs b/c/src/lib/libbsp/powerpc/ep1a/bsp_specs
index d11921e..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/bsp_specs
+++ /dev/null
@@ -1,14 +0,0 @@
-%rename endfile old_endfile
-%rename startfile old_startfile
-%rename link old_link
-*startfile:
-%{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: ecrti%O%s rtems_crti%O%s crtbegin.o%s start.o%s \
- -e __rtems_entry_point -u __vectors}}
-*link:
-%{!qrtems: %(old_link)} %{qrtems: -dp -Bstatic}
-*endfile:
-%{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s ecrtn.o%s}
diff --git a/c/src/lib/libbsp/powerpc/ep1a/configure.ac b/c/src/lib/libbsp/powerpc/ep1a/configure.ac
index c76623d..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/configure.ac
+++ /dev/null
@@ -1,46 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-powerpc-ep1a],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([bsp_specs])
-RTEMS_TOP(../../../../../..)
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
-RTEMS_BSP_CONFIGURE
-RTEMS_PROG_CC_FOR_TARGET
-RTEMS_CANONICALIZE_TOOLS
-RTEMS_PROG_CCAS
-RTEMS_BSPOPTS_SET_DATA_CACHE_ENABLED([*],[])
-RTEMS_BSPOPTS_HELP_DATA_CACHE_ENABLED
-RTEMS_BSPOPTS_SET_INSTRUCTION_CACHE_ENABLED([*],[])
-RTEMS_BSPOPTS_HELP_INSTRUCTION_CACHE_ENABLED
-RTEMS_BSPOPTS_SET([CONSOLE_USE_INTERRUPTS],[*],[0])
-RTEMS_BSPOPTS_HELP([CONSOLE_USE_INTERRUPTS],
-[whether using console interrupts])
-RTEMS_BSPOPTS_SET([CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK], [*], [1])
-RTEMS_BSPOPTS_HELP([CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK],
-[If defined then the BSP may reduce the available memory size
-initially. This can be useful for debugging (reduce the core
-size) or dynamic loading (std gcc text offsets/jumps are < +/-32M).
-Note that the policy can still be defined by the application
-(see sbrk.c, BSP_sbrk_policy). By undefining
-CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK this feature is removed
-and a little memory is saved.])
-RTEMS_CHECK_NETWORKING
-AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
-RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile])
-RTEMS_PPC_EXCEPTIONS
-AC_OUTPUT
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/alloc360.c b/c/src/lib/libbsp/powerpc/ep1a/console/alloc360.c
index edc13ff..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/alloc360.c
+++ /dev/null
@@ -1,110 +0,0 @@
- * MC68360 buffer descriptor allocation routines
- * W. Eric Norum
- * Saskatchewan Accelerator Laboratory
- * University of Saskatchewan
- * Saskatoon, Saskatchewan, CANADA
- * eric at skatter.usask.ca
- * COPYRIGHT (c) 2008.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <rtems.h>
-#include <bsp.h>
-#include "m68360.h"
-#include <rtems/error.h>
-#include "rsPMCQ1.h"
-#include <rtems/bspIo.h>
-#define DEBUG_PRINT 1
-void M360SetupMemory( M68360_t ptr )
- volatile m360_t *m360;
- m360 = ptr->m360;
-#if DEBUG_PRINT
-printk("m360->mcr:0x%08x Q1_360_SIM_MCR:0x%08x\n",
- (unsigned int)&(m360->mcr), ((unsigned int)m360+Q1_360_SIM_MCR));
-#endif
- ptr->bdregions[0].base = &m360->dpram1[0];
- ptr->bdregions[0].size = sizeof m360->dpram1;
- ptr->bdregions[0].used = 0;
- ptr->bdregions[1].base = &m360->dpram3[0];
- ptr->bdregions[1].size = sizeof m360->dpram3;
- ptr->bdregions[1].used = 0;
- ptr->bdregions[2].base = &m360->dpram0[0];
- ptr->bdregions[2].size = sizeof m360->dpram0;
- ptr->bdregions[2].used = 0;
- ptr->bdregions[3].base = &m360->dpram2[0];
- ptr->bdregions[3].size = sizeof m360->dpram2;
- ptr->bdregions[3].used = 0;
- * Send a command to the CPM RISC processer
-void *
-M360AllocateBufferDescriptors (M68360_t ptr, int count)
- unsigned int i;
- rtems_interrupt_level level;
- volatile unsigned char *bdp = NULL;
- unsigned int want = count * sizeof(m360BufferDescriptor_t);
- int have;
- * Running with interrupts disabled is usually considered bad
- * form, but this routine is probably being run as part of an
- * initialization sequence so the effect shouldn't be too severe.
- rtems_interrupt_disable(level);
- for (i = 0 ; i < M360_NUM_DPRAM_REAGONS ; i++) {
- * Verify that the region exists.
- * This test is necessary since some chips have
- * less dual-port RAM.
- if (ptr->bdregions[i].used == 0) {
- volatile unsigned char *cp = ptr->bdregions[i].base;
- *cp = 0xAA;
- if (*cp != 0xAA) {
- ptr->bdregions[i].used = ptr->bdregions[i].size;
- continue;
- *cp = 0x55;
- if (*cp != 0x55) {
- continue;
- *cp = 0x0;
- have = ptr->bdregions[i].size - ptr->bdregions[i].used;
- if (have >= want) {
- bdp = ptr->bdregions[i].base + ptr->bdregions[i].used;
- ptr->bdregions[i].used += want;
- break;
- rtems_interrupt_enable(level);
- if (bdp == NULL){
- printk("rtems_panic can't allocate %d buffer descriptor(s).\n");
- rtems_panic ("Can't allocate %d buffer descriptor(s).\n", count);
- return (void *)bdp;
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/config.c b/c/src/lib/libbsp/powerpc/ep1a/console/config.c
index 8253c69..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/config.c
+++ /dev/null
@@ -1,439 +0,0 @@
- * This file contains the TTY driver table for the EP1A
- * COPYRIGHT (c) 1989-2008.
-#include <libchip/serial.h>
-#include <libchip/ns16550.h>
-#include "ns16550cfg.h"
-#include <bsp.h>
-#include <libcpu/io.h>
- * Based on BSP configuration information decide whether to do polling IO
- * or interrupt driven IO.
-#define NS16550_FUNCTIONS &ns16550_fns_polled
-#define MC68360_SCC_FUNCTIONS &mc68360_scc_fns
- * Configuration specific probe routines
-static bool config_68360_scc_base_probe_1(int minor);
-static bool config_68360_scc_base_probe_2(int minor);
-static bool config_68360_scc_base_probe_3(int minor);
-static bool config_68360_scc_base_probe_4(int minor);
-static bool config_68360_scc_base_probe_5(int minor);
-static bool config_68360_scc_base_probe_6(int minor);
-static bool config_68360_scc_base_probe_7(int minor);
-static bool config_68360_scc_base_probe_8(int minor);
-static bool config_68360_scc_base_probe_9(int minor);
-static bool config_68360_scc_base_probe_10(int minor);
-static bool config_68360_scc_base_probe_11(int minor);
-static bool config_68360_scc_base_probe_12(int minor);
-extern const console_fns mc68360_scc_fns;
- * The following table configures the console drivers used in this BSP.
- * The first entry which, when probed, is available, will be named /dev/console,
- * all others being given the name indicated.
- * Each field is interpreted thus:
- * sDeviceName This is the name of the device.
- * pDeviceFns This is a pointer to the set of driver routines to use.
- * pDeviceFlow This is a pointer to the set of flow control routines to
- * use. Serial device drivers will typically supply RTSCTS
- * and DTRCTS handshake routines for DCE to DCE communication,
- * however for DCE to DTE communication, no such routines
- * should be necessary as RTS will be driven automatically
- * when the transmitter is active.
- * ulMargin The high water mark in the input buffer is set to the buffer
- * size less ulMargin. Once this level is reached, the driver's
- * flow control routine used to stop the remote transmitter will
- * be called. This figure should be greater than or equal to
- * the number of stages of FIFO between the transmitter and
- * receiver.
- * ulHysteresis After the high water mark specified by ulMargin has been
- * reached, the driver's routine to re-start the remote
- * transmitter will be called once the level in the input
- * buffer has fallen by ulHysteresis bytes.
- * pDeviceParams This contains either device specific data or a pointer to a
- * device specific structure containing additional information
- * not provided in this table.
- * ulCtrlPort1 This is the primary control port number for the device. This
- * may be used to specify different instances of the same device
- * type.
- * ulCtrlPort2 This is the secondary control port number, of use when a given
- * device has more than one available channel.
- * ulDataPort This is the port number for the data port of the device
- * ulIntVector This encodes the interrupt vector of the device.
-console_tbl Console_Configuration_Ports[] = {
- * NS16550 Chips provide first COM1 and COM2 Ports.
- "/dev/com1", /* sDeviceName */
- SERIAL_NS16550, /* deviceType */
- NS16550_FUNCTIONS, /* pDeviceFns */
- NULL, /* deviceProbe */
- &ns16550_flow_RTSCTS, /* pDeviceFlow */
- 16, /* ulMargin */
- 8, /* ulHysteresis */
- (void *)9600, /* baud rate */ /* pDeviceParams */
- UART_BASE_COM1, /* ulCtrlPort1 */
- 0, /* ulCtrlPort2 */
- UART_BASE_COM1, /* ulDataPort */
- Read_ns16550_register, /* getRegister */
- Write_ns16550_register, /* setRegister */
- NULL, /* getData */
- NULL, /* setData */
- 7372800, /* ulClock */
- 0 /* ulIntVector */
- "/dev/com2", /* sDeviceName */
- UART_BASE_COM2, /* ulCtrlPort1-Filled in at runtime */
- UART_BASE_COM2, /* ulDataPort-Filled in at runtime*/
- * Up to 12 serial ports are provided by MC68360 SCC ports.
- * EP1A may have one MC68360 providing 4 ports (A,B,C,D).
- "/dev/rs232_2", /* sDeviceName */
- SERIAL_CUSTOM, /* deviceType */
- MC68360_SCC_FUNCTIONS, /* pDeviceFns */
- config_68360_scc_base_probe_1, /* deviceProbe */
- NULL, /* pDeviceFlow */
- 0, /* ulCtrlPort1 */
- 0, /* ulDataPort */
- NULL, /* getRegister */
- NULL, /* setRegister */
- 0, /* ulClock */
- "/dev/rs422_1", /* sDeviceName */
- config_68360_scc_base_probe_2, /* deviceProbe */
- 0, /* ulClock */
- "/dev/rs422_2", /* sDeviceName */
- config_68360_scc_base_probe_3, /* deviceProbe */
- 0, /* ulClock */
- "/dev/ep1a_d", /* sDeviceName */
- config_68360_scc_base_probe_4, /* deviceProbe */
- 0, /* ulClock */
- * PMC1 may have one MC16550 providing 4 ports (A,B,C,D).
- "/dev/rs422_3", /* sDeviceName */
- config_68360_scc_base_probe_5, /* deviceProbe */
- 0, /* ulClock */
- "/dev/rs422_4", /* sDeviceName */
- config_68360_scc_base_probe_6, /* deviceProbe */
- 0, /* ulClock */
- "/dev/rs422_5", /* sDeviceName */
- config_68360_scc_base_probe_7, /* deviceProbe */
- 0, /* ulClock */
- "/dev/rs422_6", /* sDeviceName */
- config_68360_scc_base_probe_8, /* deviceProbe */
- 0, /* ulClock */
- * PMC2 may have one MC16550 providing 4 ports (A,B,C,D).
- "/dev/rs232_3", /* sDeviceName */
- config_68360_scc_base_probe_9, /* deviceProbe */
- 0, /* ulClock */
- "/dev/rs232_4", /* sDeviceName */
- config_68360_scc_base_probe_10, /* deviceProbe */
- 0, /* ulClock */
- "/dev/rs232_5", /* sDeviceName */
- config_68360_scc_base_probe_11, /* deviceProbe */
- 0, /* ulClock */
- "/dev/rs232_6", /* sDeviceName */
- config_68360_scc_base_probe_12, /* deviceProbe */
- 0, /* ulClock */
- * Define a variable that contains the number of statically configured
- * console devices.
-unsigned long Console_Configuration_Count = \
- (sizeof(Console_Configuration_Ports)/sizeof(console_tbl));
-static bool config_68360_scc_base_probe(int minor, unsigned long busNo, unsigned long slotNo, int channel)
- M68360_t chip = M68360_chips;
- * Find out if the chip is installed.
- while (chip) {
- if ((chip->board_data->slotNo == slotNo) && (chip->board_data->busNo == busNo))
- break;
- chip = chip->next;
- if (!chip)
- return false;
- Console_Port_Tbl[minor]->pDeviceParams = &chip->port[ channel-1 ];
- chip->port[ channel-1 ].minor = minor;
- return true;
-static bool config_68360_scc_base_probe_1( int minor ) {
- return config_68360_scc_base_probe(minor, 0, 11, 1);
-static bool config_68360_scc_base_probe_2( int minor ) {
- return config_68360_scc_base_probe(minor, 0, 11, 2);
-static bool config_68360_scc_base_probe_3( int minor ) {
- return config_68360_scc_base_probe( minor, 0, 11, 3);
-static bool config_68360_scc_base_probe_4( int minor ) {
- return config_68360_scc_base_probe( minor, 0, 11, 4);
-static bool config_68360_scc_base_probe_5( int minor ) {
- return config_68360_scc_base_probe( minor, 0, 16, 1);
-static bool config_68360_scc_base_probe_6( int minor ) {
- return config_68360_scc_base_probe( minor, 0, 16, 2);
-static bool config_68360_scc_base_probe_7( int minor ) {
- return config_68360_scc_base_probe( minor, 0, 16, 3);
-static bool config_68360_scc_base_probe_8( int minor ) {
- return config_68360_scc_base_probe( minor, 0, 16, 4);
-static bool config_68360_scc_base_probe_9( int minor ) {
- return config_68360_scc_base_probe( minor, 0, 15, 1);
-static bool config_68360_scc_base_probe_10( int minor ) {
- return config_68360_scc_base_probe( minor, 0, 15, 2);
-static bool config_68360_scc_base_probe_11( int minor ) {
- return config_68360_scc_base_probe( minor, 0, 15, 3);
-static bool config_68360_scc_base_probe_12( int minor ) {
- return config_68360_scc_base_probe( minor, 0, 15, 4);
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/console.h b/c/src/lib/libbsp/powerpc/ep1a/console/console.h
index c2354d2..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/console.h
+++ /dev/null
@@ -1,20 +0,0 @@
- * This driver uses the termios pseudo driver.
-#include <rtems/ringbuf.h>
-extern console_tbl Console_Port_Tbl[];
-extern console_data Console_Port_Data[];
-extern unsigned long Console_Port_Count;
-bool Console_Port_Tbl_Init_ppc8245(int minor);
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/init68360.c b/c/src/lib/libbsp/powerpc/ep1a/console/init68360.c
index bafcf8d..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/init68360.c
+++ /dev/null
@@ -1,35 +0,0 @@
- * MC68360 support routines - reduced from gen68360 BSP
- * W. Eric Norum
- * COPYRIGHT (c) 1989-1999.
-#include <rtems.h>
-#include <bsp.h>
-void M360ExecuteRISC( volatile m360_t *m360, uint16_t command)
- uint16_t sr;
- rtems_interrupt_disable(sr);
- while (m360->cr & M360_CR_FLG)
- continue;
- m360->cr = command | M360_CR_FLG;
- rtems_interrupt_enable(sr);
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/m68360.h b/c/src/lib/libbsp/powerpc/ep1a/console/m68360.h
index 3645486..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/m68360.h
+++ /dev/null
@@ -1,978 +0,0 @@
- * MOTOROLA MC68360 QUAD INTEGRATED COMMUNICATIONS CONTROLLER (QUICC)
- * HARDWARE DECLARATIONS
- * Submitted By:
- * W. Eric Norum
- * 107 North Road
- * S7N 5C6
-#ifndef __MC68360_h
-#define __MC68360_h
- * REGISTER SUBBLOCKS *
- * Memory controller registers
-typedef struct m360MEMCRegisters_ {
- uint32_t br;
- uint32_t or;
- uint32_t _pad[2];
-} m360MEMCRegisters_t;
-#define M360_GSMR_RFW 0x00000020
-#define M360_GSMR_RINV 0x02000000
-#define M360_GSMR_TINV 0x01000000
-#define M360_GSMR_TDCR_16X 0x00020000
-#define M360_GSMR_RDCR_16X 0x00008000
-#define M360_GSMR_DIAG_LLOOP 0x00000040
-#define M360_GSMR_ENR 0x00000020
-#define M360_GSMR_ENT 0x00000010
-#define M360_GSMR_MODE_UART 0x00000004
-#define M360_PSMR_FLC 0x8000
-#define M360_PSMR_SL_1 0x0000
-#define M360_PSMR_SL_2 0x4000
-#define M360_PSMR_CL5 0x0000
-#define M360_PSMR_CL6 0x1000
-#define M360_PSMR_CL7 0x2000
-#define M360_PSMR_CL8 0x3000
-#define M360_PSMR_UM_NORMAL 0x0000
-#define M360_PSMR_FRZ 0x0200
-#define M360_PSMR_RZS 0x0100
-#define M360_PSMR_SYN 0x0080
-#define M360_PSMR_DRT 0x0040
-#define M360_PSMR_PEN 0x0010
-#define M360_PSMR_RPM_ODD 0x0000
-#define M360_PSMR_RPM_LOW 0x0004
-#define M360_PSMR_RPM_EVEN 0x0008
-#define M360_PSMR_RPM_HI 0x000c
-#define M360_PSMR_TPM_ODD 0x0000
-#define M360_PSMR_TPM_LOW 0x0001
-#define M360_PSMR_TPM_EVEN 0x0002
-#define M360_PSMR_TPM_HI 0x0003
- * Serial Communications Controller registers
-typedef struct m360SCCRegisters_ {
- uint32_t gsmr_l;
- uint32_t gsmr_h;
- uint16_t psmr;
- uint16_t _pad0;
- uint16_t todr;
- uint16_t dsr;
- uint16_t scce;
- uint16_t _pad1;
- uint16_t sccm;
- uint8_t _pad2;
- uint8_t sccs;
- uint32_t _pad3[2];
-} m360SCCRegisters_t;
- * Serial Management Controller registers
-typedef struct m360SMCRegisters_ {
- uint16_t _pad0;
- uint16_t smcmr;
- uint16_t _pad1;
- uint8_t smce;
- uint8_t _pad2;
- uint16_t _pad3;
- uint8_t smcm;
- uint8_t _pad4;
- uint32_t _pad5;
-} m360SMCRegisters_t;
- * Miscellaneous Parameters *
-typedef struct m360MiscParms_ {
- uint16_t rev_num;
- uint16_t _res1;
- uint32_t _res2;
- uint32_t _res3;
-} m360MiscParms_t;
- * RISC Timers *
-typedef struct m360TimerParms_ {
- uint16_t tm_base;
- uint16_t _tm_ptr;
- uint16_t _r_tmr;
- uint16_t _r_tmv;
- uint32_t tm_cmd;
- uint32_t tm_cnt;
-} m360TimerParms_t;
- * RISC Controller Configuration Register (RCCR)
- * All other bits in this register are either reserved or
- * used only with a Motorola-supplied RAM microcode packge.
-#define M360_RCCR_TIME (1<<15) /* Enable timer */
-#define M360_RCCR_TIMEP(x) ((x)<<8) /* Timer period */
- * Command register
- * Set up this register before issuing a M360_CR_OP_SET_TIMER command.
-#define M360_TM_CMD_V (1<<31) /* Set to enable timer */
-#define M360_TM_CMD_R (1<<30) /* Set for automatic restart */
-#define M360_TM_CMD_TIMER(x) ((x)<<16) /* Select timer */
-#define M360_TM_CMD_PERIOD(x) (x) /* Timer period (16 bits) */
- * DMA Controllers *
-typedef struct m360IDMAparms_ {
- uint16_t ibase;
- uint16_t ibptr;
- uint32_t _istate;
- uint32_t _itemp;
-} m360IDMAparms_t;
- * Serial Communication Controllers *
-typedef struct m360SCCparms_ {
- uint16_t rbase;
- uint16_t tbase;
- uint8_t rfcr;
- uint8_t tfcr;
- uint16_t mrblr;
- uint32_t _rstate;
- uint32_t _pad0;
- uint16_t _rbptr;
- uint16_t _pad1;
- uint32_t _pad2;
- uint32_t _tstate;
- uint32_t _pad3;
- uint16_t _tbptr;
- uint16_t _pad4;
- uint32_t _pad5;
- uint32_t _rcrc;
- uint32_t _tcrc;
- union {
- struct {
- uint32_t _res0;
- uint32_t _res1;
- uint16_t max_idl;
- uint16_t _idlc;
- uint16_t brkcr;
- uint16_t parec;
- uint16_t frmec;
- uint16_t nosec;
- uint16_t brkec;
- uint16_t brklen;
- uint16_t uaddr[2];
- uint16_t _rtemp;
- uint16_t toseq;
- uint16_t character[8];
- uint16_t rccm;
- uint16_t rccr;
- uint16_t rlbc;
- } uart;
- struct {
- uint32_t crc_p;
- uint32_t crc_c;
- } transparent;
- } un;
-} m360SCCparms_t;
-typedef struct m360SCCENparms_ {
- uint16_t rbase;
- uint16_t tbase;
- uint8_t rfcr;
- uint8_t tfcr;
- uint16_t mrblr;
- uint32_t _rstate;
- uint32_t _pad0;
- uint16_t _rbptr;
- uint16_t _pad1;
- uint32_t _pad2;
- uint32_t _tstate;
- uint32_t _pad3;
- uint16_t _tbptr;
- uint16_t _pad4;
- uint32_t _pad5;
- uint32_t _rcrc;
- uint32_t _tcrc;
- union {
- struct {
- uint32_t _res0;
- uint32_t _res1;
- uint16_t max_idl;
- uint16_t _idlc;
- uint16_t brkcr;
- uint16_t parec;
- uint16_t frmec;
- uint16_t nosec;
- uint16_t brkec;
- uint16_t brklen;
- uint16_t _rtemp;
- uint16_t toseq;
- uint16_t rccm;
- uint16_t rccr;
- uint16_t rlbc;
- } uart;
- struct {
- uint32_t c_pres;
- uint32_t c_mask;
- uint32_t crcec;
- uint32_t alec;
- uint32_t disfc;
- uint16_t pads;
- uint16_t ret_lim;
- uint16_t _ret_cnt;
- uint16_t mflr;
- uint16_t minflr;
- uint16_t maxd1;
- uint16_t maxd2;
- uint16_t _maxd;
- uint16_t dma_cnt;
- uint16_t _max_b;
- uint16_t gaddr1;
- uint16_t gaddr2;
- uint16_t gaddr3;
- uint16_t gaddr4;
- uint32_t _tbuf0data0;
- uint32_t _tbuf0data1;
- uint32_t _tbuf0rba0;
- uint32_t _tbuf0crc;
- uint16_t _tbuf0bcnt;
- uint16_t paddr_h;
- uint16_t paddr_m;
- uint16_t paddr_l;
- uint16_t p_per;
- uint16_t _rfbd_ptr;
- uint16_t _tfbd_ptr;
- uint16_t _tlbd_ptr;
- uint32_t _tbuf1data0;
- uint32_t _tbuf1data1;
- uint32_t _tbuf1rba0;
- uint32_t _tbuf1crc;
- uint16_t _tbuf1bcnt;
- uint16_t _tx_len;
- uint16_t iaddr1;
- uint16_t iaddr2;
- uint16_t iaddr3;
- uint16_t iaddr4;
- uint16_t _boff_cnt;
- uint16_t taddr_h;
- uint16_t taddr_m;
- uint16_t taddr_l;
- } ethernet;
- struct {
- uint32_t crc_p;
- uint32_t crc_c;
- } transparent;
- } un;
-} m360SCCENparms_t;
- * Receive and transmit function code register bits
- * These apply to the function code registers of all devices, not just SCC.
-#define M360_RFCR_MOT (1<<4)
-#define M360_RFCR_DMA_SPACE 0x8
-#define M360_TFCR_MOT (1<<4)
-#define M360_TFCR_DMA_SPACE 0x8
- * Serial Management Controllers *
-typedef struct m360SMCparms_ {
- uint16_t rbase;
- uint16_t tbase;
- uint8_t rfcr;
- uint8_t tfcr;
- uint16_t mrblr;
- uint32_t _rstate;
- uint32_t _pad0;
- uint16_t _rbptr;
- uint16_t _pad1;
- uint32_t _pad2;
- uint32_t _tstate;
- uint32_t _pad3;
- uint16_t _tbptr;
- uint16_t _pad4;
- uint32_t _pad5;
- union {
- struct {
- uint16_t max_idl;
- uint16_t _pad0;
- uint16_t brklen;
- uint16_t brkec;
- uint16_t brkcr;
- uint16_t _r_mask;
- } uart;
- struct {
- uint16_t _pad0[5];
- } transparent;
- } un;
-} m360SMCparms_t;
- * Mode register
-#define M360_SMCMR_CLEN(x) ((x)<<11) /* Character length */
-#define M360_SMCMR_2STOP (1<<10) /* 2 stop bits */
-#define M360_SMCMR_PARITY (1<<9) /* Enable parity */
-#define M360_SMCMR_EVEN (1<<8) /* Even parity */
-#define M360_SMCMR_SM_GCI (0<<4) /* GCI Mode */
-#define M360_SMCMR_SM_UART (2<<4) /* UART Mode */
-#define M360_SMCMR_SM_TRANSPARENT (3<<4) /* Transparent Mode */
-#define M360_SMCMR_DM_LOOPBACK (1<<2) /* Local loopback mode */
-#define M360_SMCMR_DM_ECHO (2<<2) /* Echo mode */
-#define M360_SMCMR_TEN (1<<1) /* Enable transmitter */
-#define M360_SMCMR_REN (1<<0) /* Enable receiver */
- * Event and mask registers (SMCE, SMCM)
-#define M360_SMCE_BRK (1<<4)
-#define M360_SMCE_BSY (1<<2)
-#define M360_SMCE_TX (1<<1)
-#define M360_SMCE_RX (1<<0)
- * Serial Peripheral Interface *
-typedef struct m360SPIparms_ {
- uint16_t rbase;
- uint16_t tbase;
- uint8_t rfcr;
- uint8_t tfcr;
- uint16_t mrblr;
- uint32_t _rstate;
- uint32_t _pad0;
- uint16_t _rbptr;
- uint16_t _pad1;
- uint32_t _pad2;
- uint32_t _tstate;
- uint32_t _pad3;
- uint16_t _tbptr;
- uint16_t _pad4;
- uint32_t _pad5;
-} m360SPIparms_t;
- * Mode register (SPMODE)
-#define M360_SPMODE_LOOP (1<<14) /* Local loopback mode */
-#define M360_SPMODE_CI (1<<13) /* Clock invert */
-#define M360_SPMODE_CP (1<<12) /* Clock phase */
-#define M360_SPMODE_DIV16 (1<<11) /* Divide BRGCLK by 16 */
-#define M360_SPMODE_REV (1<<10) /* Reverse data */
-#define M360_SPMODE_MASTER (1<<9) /* SPI is master */
-#define M360_SPMODE_EN (1<<8) /* Enable SPI */
-#define M360_SPMODE_CLEN(x) ((x)<<4) /* Character length */
-#define M360_SPMODE_PM(x) (x) /* Prescaler modulus */
- * Mode register (SPCOM)
-#define M360_SPCOM_STR (1<<7) /* Start transmit */
- * Event and mask registers (SPIE, SPIM)
-#define M360_SPIE_MME (1<<5) /* Multi-master error */
-#define M360_SPIE_TXE (1<<4) /* Tx error */
-#define M360_SPIE_BSY (1<<2) /* Busy condition*/
-#define M360_SPIE_TXB (1<<1) /* Tx buffer */
-#define M360_SPIE_RXB (1<<0) /* Rx buffer */
- * SDMA (SCC, SMC, SPI) Buffer Descriptors *
-typedef struct m360BufferDescriptor_ {
- uint16_t status;
- uint16_t length;
- uint32_t buffer; /* this is a void * to the 360 */
-} m360BufferDescriptor_t;
- * Bits in receive buffer descriptor status word
-#define M360_BD_EMPTY (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
-#define M360_BD_WRAP (1<<13) /* Ethernet, SCC UART, SMC UART, SPI */
-#define M360_BD_INTERRUPT (1<<12) /* Ethernet, SCC UART, SMC UART, SPI */
-#define M360_BD_LAST (1<<11) /* Ethernet, SPI */
-#define M360_BD_CONTROL_CHAR (1<<11) /* SCC UART */
-#define M360_BD_FIRST_IN_FRAME (1<<10) /* Ethernet */
-#define M360_BD_ADDRESS (1<<10) /* SCC UART */
-#define M360_BD_CONTINUOUS (1<<9) /* SCC UART, SMC UART, SPI */
-#define M360_BD_MISS (1<<8) /* Ethernet */
-#define M360_BD_IDLE (1<<8) /* SCC UART, SMC UART */
-#define M360_BD_ADDRSS_MATCH (1<<7) /* SCC UART */
-#define M360_BD_LONG (1<<5) /* Ethernet */
-#define M360_BD_BREAK (1<<5) /* SCC UART, SMC UART */
-#define M360_BD_NONALIGNED (1<<4) /* Ethernet */
-#define M360_BD_FRAMING_ERROR (1<<4) /* SCC UART, SMC UART */
-#define M360_BD_SHORT (1<<3) /* Ethernet */
-#define M360_BD_PARITY_ERROR (1<<3) /* SCC UART, SMC UART */
-#define M360_BD_CRC_ERROR (1<<2) /* Ethernet */
-#define M360_BD_OVERRUN (1<<1) /* Ethernet, SCC UART, SMC UART, SPI */
-#define M360_BD_COLLISION (1<<0) /* Ethernet */
-#define M360_BD_CARRIER_LOST (1<<0) /* SCC UART */
-#define M360_BD_MASTER_ERROR (1<<0) /* SPI */
- * Bits in transmit buffer descriptor status word
- * Many bits have the same meaning as those in receiver buffer descriptors.
-#define M360_BD_READY (1<<15) /* Ethernet, SCC UART, SMC UART, SPI */
-#define M360_BD_PAD (1<<14) /* Ethernet */
-#define M360_BD_CTS_REPORT (1<<11) /* SCC UART */
-#define M360_BD_TX_CRC (1<<10) /* Ethernet */
-#define M360_BD_DEFER (1<<9) /* Ethernet */
-#define M360_BD_HEARTBEAT (1<<8) /* Ethernet */
-#define M360_BD_PREAMBLE (1<<8) /* SCC UART, SMC UART */
-#define M360_BD_LATE_COLLISION (1<<7) /* Ethernet */
-#define M360_BD_NO_STOP_BIT (1<<7) /* SCC UART */
-#define M360_BD_RETRY_LIMIT (1<<6) /* Ethernet */
-#define M360_BD_RETRY_COUNT(x) (((x)&0x3C)>>2) /* Ethernet */
-#define M360_BD_UNDERRUN (1<<1) /* Ethernet, SPI */
-#define M360_BD_CARRIER_LOST (1<<0) /* Ethernet */
-#define M360_BD_CTS_LOST (1<<0) /* SCC UART */
- * IDMA Buffer Descriptors *
-typedef struct m360IDMABufferDescriptor_ {
- uint16_t status;
- uint16_t _pad;
- uint32_t length;
- void *source;
- void *destination;
-} m360IDMABufferDescriptor_t;
- * RISC Communication Processor Module Command Register (CR) *
-#define M360_CR_RST (1<<15) /* Reset communication processor */
-#define M360_CR_OP_INIT_RX_TX (0<<8) /* SCC, SMC UART, SMC GCI, SPI */
-#define M360_CR_OP_INIT_RX (1<<8) /* SCC, SMC UART, SPI */
-#define M360_CR_OP_INIT_TX (2<<8) /* SCC, SMC UART, SPI */
-#define M360_CR_OP_INIT_HUNT (3<<8) /* SCC, SMC UART */
-#define M360_CR_OP_STOP_TX (4<<8) /* SCC, SMC UART */
-#define M360_CR_OP_GR_STOP_TX (5<<8) /* SCC */
-#define M360_CR_OP_INIT_IDMA (5<<8) /* IDMA */
-#define M360_CR_OP_RESTART_TX (6<<8) /* SCC, SMC UART */
-#define M360_CR_OP_CLOSE_RX_BD (7<<8) /* SCC, SMC UART, SPI */
-#define M360_CR_OP_SET_GRP_ADDR (8<<8) /* SCC */
-#define M360_CR_OP_SET_TIMER (8<<8) /* Timer */
-#define M360_CR_OP_GCI_TIMEOUT (9<<8) /* SMC GCI */
-#define M360_CR_OP_RESERT_BCS (10<<8) /* SCC */
-#define M360_CR_OP_GCI_ABORT (10<<8) /* SMC GCI */
-#define M360_CR_CHAN_SCC1 (0<<4) /* Channel selection */
-#define M360_CR_CHAN_SCC2 (4<<4)
-#define M360_CR_CHAN_SPI (5<<4)
-#define M360_CR_CHAN_TIMER (5<<4)
-#define M360_CR_CHAN_SCC3 (8<<4)
-#define M360_CR_CHAN_SMC1 (9<<4)
-#define M360_CR_CHAN_IDMA1 (9<<4)
-#define M360_CR_CHAN_SCC4 (12<<4)
-#define M360_CR_CHAN_SMC2 (13<<4)
-#define M360_CR_CHAN_IDMA2 (13<<4)
-#define M360_CR_FLG (1<<0) /* Command flag */
- * System Protection Control Register (SYPCR) *
-#define M360_SYPCR_SWE (1<<7) /* Software watchdog enable */
-#define M360_SYPCR_SWRI (1<<6) /* Software watchdog reset select */
-#define M360_SYPCR_SWT1 (1<<5) /* Software watchdog timing bit 1 */
-#define M360_SYPCR_SWT0 (1<<4) /* Software watchdog timing bit 0 */
-#define M360_SYPCR_DBFE (1<<3) /* Double bus fault monitor enable */
-#define M360_SYPCR_BME (1<<2) /* Bus monitor external enable */
-#define M360_SYPCR_BMT1 (1<<1) /* Bus monitor timing bit 1 */
-#define M360_SYPCR_BMT0 (1<<0) /* Bus monitor timing bit 0 */
- * Memory Control Registers *
-#define M360_GMR_RCNT(x) ((x)<<24) /* Refresh count */
-#define M360_GMR_RFEN (1<<23) /* Refresh enable */
-#define M360_GMR_RCYC(x) ((x)<<21) /* Refresh cycle length */
-#define M360_GMR_PGS(x) ((x)<<18) /* Page size */
-#define M360_GMR_DPS_32BIT (0<<16) /* DRAM port size */
-#define M360_GMR_DPS_16BIT (1<<16)
-#define M360_GMR_DPS_8BIT (2<<16)
-#define M360_GMR_DPS_DSACK (3<<16)
-#define M360_GMR_WBT40 (1<<15) /* Wait between 040 transfers */
-#define M360_GMR_WBTQ (1<<14) /* Wait between 360 transfers */
-#define M360_GMR_SYNC (1<<13) /* Synchronous external access */
-#define M360_GMR_EMWS (1<<12) /* External master wait state */
-#define M360_GMR_OPAR (1<<11) /* Odd parity */
-#define M360_GMR_PBEE (1<<10) /* Parity bus error enable */
-#define M360_GMR_TSS40 (1<<9) /* TS* sample for 040 */
-#define M360_GMR_NCS (1<<8) /* No CPU space */
-#define M360_GMR_DWQ (1<<7) /* Delay write for 360 */
-#define M360_GMR_DW40 (1<<6) /* Delay write for 040 */
-#define M360_GMR_GAMX (1<<5) /* Global address mux enable */
-#define M360_MEMC_BR_FC(x) ((x)<<7) /* Function code limit */
-#define M360_MEMC_BR_TRLXQ (1<<6) /* Relax timing requirements */
-#define M360_MEMC_BR_BACK40 (1<<5) /* Burst acknowledge to 040 */
-#define M360_MEMC_BR_CSNT40 (1<<4) /* CS* negate timing for 040 */
-#define M360_MEMC_BR_CSNTQ (1<<3) /* CS* negate timing for 360 */
-#define M360_MEMC_BR_PAREN (1<<2) /* Enable parity checking */
-#define M360_MEMC_BR_WP (1<<1) /* Write Protect */
-#define M360_MEMC_BR_V (1<<0) /* Base/Option register are valid */
-#define M360_MEMC_OR_TCYC(x) ((x)<<28) /* Cycle length (clocks) */
-#define M360_MEMC_OR_WAITS(x) M360_MEMC_OR_TCYC((x)+1)
-#define M360_MEMC_OR_2KB 0x0FFFF800 /* Address range */
-#define M360_MEMC_OR_4KB 0x0FFFF000
-#define M360_MEMC_OR_8KB 0x0FFFE000
-#define M360_MEMC_OR_16KB 0x0FFFC000
-#define M360_MEMC_OR_32KB 0x0FFF8000
-#define M360_MEMC_OR_64KB 0x0FFF0000
-#define M360_MEMC_OR_128KB 0x0FFE0000
-#define M360_MEMC_OR_256KB 0x0FFC0000
-#define M360_MEMC_OR_512KB 0x0FF80000
-#define M360_MEMC_OR_1MB 0x0FF00000
-#define M360_MEMC_OR_2MB 0x0FE00000
-#define M360_MEMC_OR_4MB 0x0FC00000
-#define M360_MEMC_OR_8MB 0x0F800000
-#define M360_MEMC_OR_16MB 0x0F000000
-#define M360_MEMC_OR_32MB 0x0E000000
-#define M360_MEMC_OR_64MB 0x0C000000
-#define M360_MEMC_OR_128MB 0x08000000
-#define M360_MEMC_OR_256MB 0x00000000
-#define M360_MEMC_OR_FCMC(x) ((x)<<7) /* Function code mask */
-#define M360_MEMC_OR_BCYC(x) ((x)<<5) /* Burst cycle length (clocks) */
-#define M360_MEMC_OR_PGME (1<<3) /* Page mode enable */
-#define M360_MEMC_OR_32BIT (0<<1) /* Port size */
-#define M360_MEMC_OR_16BIT (1<<1)
-#define M360_MEMC_OR_8BIT (2<<1)
-#define M360_MEMC_OR_DSACK (3<<1)
-#define M360_MEMC_OR_DRAM (1<<0) /* Dynamic RAM select */
- * SI Mode Register (SIMODE) *
-#define M360_SI_SMC2_BITS 0xFFFF0000 /* All SMC2 bits */
-#define M360_SI_SMC2_TDM (1<<31) /* Multiplexed SMC2 */
-#define M360_SI_SMC2_BRG1 (0<<28) /* SMC2 clock souce */
-#define M360_SI_SMC2_BRG2 (1<<28)
-#define M360_SI_SMC2_BRG3 (2<<28)
-#define M360_SI_SMC2_BRG4 (3<<28)
-#define M360_SI_SMC2_CLK5 (0<<28)
-#define M360_SI_SMC2_CLK6 (1<<28)
-#define M360_SI_SMC2_CLK7 (2<<28)
-#define M360_SI_SMC2_CLK8 (3<<28)
-#define M360_SI_SMC1_BITS 0x0000FFFF /* All SMC1 bits */
-#define M360_SI_SMC1_TDM (1<<15) /* Multiplexed SMC1 */
-#define M360_SI_SMC1_BRG1 (0<<12) /* SMC1 clock souce */
-#define M360_SI_SMC1_BRG2 (1<<12)
-#define M360_SI_SMC1_BRG3 (2<<12)
-#define M360_SI_SMC1_BRG4 (3<<12)
-#define M360_SI_SMC1_CLK1 (0<<12)
-#define M360_SI_SMC1_CLK2 (1<<12)
-#define M360_SI_SMC1_CLK3 (2<<12)
-#define M360_SI_SMC1_CLK4 (3<<12)
- * SDMA Configuration Register (SDMA) *
-#define M360_SDMA_FREEZE (2<<13) /* Freeze on next bus cycle */
-#define M360_SDMA_SISM_7 (7<<8) /* Normal interrupt service mask */
-#define M360_SDMA_SAID_4 (4<<4) /* Normal arbitration ID */
-#define M360_SDMA_INTE (1<<1) /* SBER interrupt enable */
-#define M360_SDMA_INTB (1<<0) /* SBKP interrupt enable */
- * Baud (sic) Rate Generators *
-#define M360_BRG_RST (1<<17) /* Reset generator */
-#define M360_BRG_EN (1<<16) /* Enable generator */
-#define M360_BRG_EXTC_BRGCLK (0<<14) /* Source is BRGCLK */
-#define M360_BRG_EXTC_CLK2 (1<<14) /* Source is CLK2 pin */
-#define M360_BRG_EXTC_CLK6 (2<<14) /* Source is CLK6 pin */
-#define M360_BRG_ATB (1<<13) /* Autobaud */
-#define M360_BRG_115200 (13<<1) /* Assume 25 MHz clock */
-#define M360_BRG_57600 (26<<1)
-#define M360_BRG_38400 (40<<1)
-#define M360_BRG_19200 (80<<1)
-#define M360_BRG_9600 (162<<1)
-#define M360_BRG_4800 (324<<1)
-#define M360_BRG_2400 (650<<1)
-#define M360_BRG_1200 (1301<<1)
-#define M360_BRG_600 (2603<<1)
-#define M360_BRG_300 ((324<<1) | 1)
-#define M360_BRG_150 ((650<<1) | 1)
-#define M360_BRG_75 ((1301<<1) | 1)
- * sccm Bit Settings *
-#define M360_SCCE_TX 0x02
-#define M360_SCCE_RX 0x01
-#define M360_CR_INIT_TX_RX_PARAMS 0x0000
-#define M360_CR_CH_NUM 0x0040
-#define M360_NUM_DPRAM_REAGONS 4
- * MC68360 DUAL-PORT RAM AND REGISTERS *
-typedef struct m360_ {
- * Dual-port RAM
- volatile uint8_t dpram0[0x400]; /* Microcode program */
- volatile uint8_t dpram1[0x200];
- volatile uint8_t dpram2[0x100]; /* Microcode scratch */
- volatile uint8_t dpram3[0x100]; /* Not on REV A or B masks */
- volatile uint8_t _rsv0[0xC00-0x800];
- volatile m360SCCENparms_t scc1p;
- volatile uint8_t _rsv1[0xCB0-0xC00-sizeof(m360SCCENparms_t)];
- volatile m360MiscParms_t miscp;
- volatile uint8_t _rsv2[0xD00-0xCB0-sizeof(m360MiscParms_t)];
- volatile m360SCCparms_t scc2p;
- volatile uint8_t _rsv3[0xD80-0xD00-sizeof(m360SCCparms_t)];
- volatile m360SPIparms_t spip;
- volatile uint8_t _rsv4[0xDB0-0xD80-sizeof(m360SPIparms_t)];
- volatile m360TimerParms_t tmp;
- volatile uint8_t _rsv5[0xE00-0xDB0-sizeof(m360TimerParms_t)];
- volatile m360SCCparms_t scc3p;
- volatile uint8_t _rsv6[0xE70-0xE00-sizeof(m360SCCparms_t)];
- volatile m360IDMAparms_t idma1p;
- volatile uint8_t _rsv7[0xE80-0xE70-sizeof(m360IDMAparms_t)];
- volatile m360SMCparms_t smc1p;
- volatile uint8_t _rsv8[0xF00-0xE80-sizeof(m360SMCparms_t)];
- volatile m360SCCparms_t scc4p;
- volatile uint8_t _rsv9[0xF70-0xF00-sizeof(m360SCCparms_t)];
- volatile m360IDMAparms_t idma2p;
- volatile uint8_t _rsv10[0xF80-0xF70-sizeof(m360IDMAparms_t)];
- volatile m360SMCparms_t smc2p;
- volatile uint8_t _rsv11[0x1000-0xF80-sizeof(m360SMCparms_t)];
- * SIM Block
- volatile uint32_t mcr;
- volatile uint32_t _pad00;
- volatile uint8_t avr;
- volatile uint8_t rsr;
- volatile uint16_t _pad01;
- volatile uint8_t clkocr;
- volatile uint8_t _pad02;
- volatile uint16_t _pad03;
- volatile uint16_t pllcr;
- volatile uint16_t _pad04;
- volatile uint16_t cdvcr;
- volatile uint16_t pepar;
- volatile uint32_t _pad05[2];
- volatile uint16_t _pad06;
- volatile uint8_t sypcr;
- volatile uint8_t swiv;
- volatile uint16_t _pad07;
- volatile uint16_t picr;
- volatile uint16_t _pad08;
- volatile uint16_t pitr;
- volatile uint16_t _pad09;
- volatile uint8_t _pad10;
- volatile uint8_t swsr;
- volatile uint32_t bkar;
- volatile uint32_t bcar;
- volatile uint32_t _pad11[2];
- * MEMC Block
- volatile uint32_t gmr;
- volatile uint16_t mstat;
- volatile uint16_t _pad12;
- volatile uint32_t _pad13[2];
- volatile m360MEMCRegisters_t memc[8];
- volatile uint8_t _pad14[0xF0-0xD0];
- volatile uint8_t _pad15[0x100-0xF0];
- volatile uint8_t _pad16[0x500-0x100];
- * IDMA1 Block
- volatile uint16_t iccr;
- volatile uint16_t _pad17;
- volatile uint16_t cmr1;
- volatile uint16_t _pad18;
- volatile uint32_t sapr1;
- volatile uint32_t dapr1;
- volatile uint32_t bcr1;
- volatile uint8_t fcr1;
- volatile uint8_t _pad19;
- volatile uint8_t cmar1;
- volatile uint8_t _pad20;
- volatile uint8_t csr1;
- volatile uint8_t _pad21;
- volatile uint16_t _pad22;
- * SDMA Block
- volatile uint8_t sdsr;
- volatile uint8_t _pad23;
- volatile uint16_t sdcr;
- volatile uint32_t sdar;
- * IDMA2 Block
- volatile uint16_t _pad24;
- volatile uint16_t cmr2;
- volatile uint32_t sapr2;
- volatile uint32_t dapr2;
- volatile uint32_t bcr2;
- volatile uint8_t fcr2;
- volatile uint8_t _pad26;
- volatile uint8_t cmar2;
- volatile uint8_t _pad27;
- volatile uint8_t csr2;
- volatile uint8_t _pad28;
- volatile uint16_t _pad29;
- volatile uint32_t _pad30;
- * CPIC Block
- volatile uint32_t cicr;
- volatile uint32_t cipr;
- volatile uint32_t cimr;
- volatile uint32_t cisr;
- * Parallel I/O Block
- volatile uint16_t padir;
- volatile uint16_t papar;
- volatile uint16_t paodr;
- volatile uint16_t padat;
- volatile uint32_t _pad31[2];
- volatile uint16_t pcdir;
- volatile uint16_t pcpar;
- volatile uint16_t pcso;
- volatile uint16_t pcdat;
- volatile uint16_t pcint;
- volatile uint16_t _pad32;
- volatile uint32_t _pad33[5];
- * TIMER Block
- volatile uint16_t tgcr;
- volatile uint16_t _pad34;
- volatile uint32_t _pad35[3];
- volatile uint16_t tmr1;
- volatile uint16_t tmr2;
- volatile uint16_t trr1;
- volatile uint16_t trr2;
- volatile uint16_t tcr1;
- volatile uint16_t tcr2;
- volatile uint16_t tcn1;
- volatile uint16_t tcn2;
- volatile uint16_t tmr3;
- volatile uint16_t tmr4;
- volatile uint16_t trr3;
- volatile uint16_t trr4;
- volatile uint16_t tcr3;
- volatile uint16_t tcr4;
- volatile uint16_t tcn3;
- volatile uint16_t tcn4;
- volatile uint16_t ter1;
- volatile uint16_t ter2;
- volatile uint16_t ter3;
- volatile uint16_t ter4;
- volatile uint32_t _pad36[2];
- * CP Block
- volatile uint16_t cr;
- volatile uint16_t _pad37;
- volatile uint16_t rccr;
- volatile uint16_t _pad38;
- volatile uint32_t _pad39[3];
- volatile uint16_t _pad40;
- volatile uint16_t rter;
- volatile uint16_t _pad41;
- volatile uint16_t rtmr;
- volatile uint32_t _pad42[5];
- * BRG Block
- volatile uint32_t brgc1;
- volatile uint32_t brgc2;
- volatile uint32_t brgc3;
- volatile uint32_t brgc4;
- * SCC Block
- volatile m360SCCRegisters_t scc1;
- volatile m360SCCRegisters_t scc2;
- volatile m360SCCRegisters_t scc3;
- volatile m360SCCRegisters_t scc4;
- * SMC Block
- volatile m360SMCRegisters_t smc1;
- volatile m360SMCRegisters_t smc2;
- * SPI Block
- volatile uint16_t spmode;
- volatile uint16_t _pad43[2];
- volatile uint8_t spie;
- volatile uint8_t _pad44;
- volatile uint16_t _pad45;
- volatile uint8_t spim;
- volatile uint8_t _pad46[2];
- volatile uint8_t spcom;
- volatile uint16_t _pad47[2];
- * PIP Block
- volatile uint16_t pipc;
- volatile uint16_t _pad48;
- volatile uint16_t ptpr;
- volatile uint32_t pbdir;
- volatile uint32_t pbpar;
- volatile uint16_t _pad49;
- volatile uint16_t pbodr;
- volatile uint32_t pbdat;
- volatile uint32_t _pad50[6];
- * SI Block
- volatile uint32_t simode;
- volatile uint8_t sigmr;
- volatile uint8_t _pad51;
- volatile uint8_t sistr;
- volatile uint8_t sicmr;
- volatile uint32_t _pad52;
- volatile uint32_t sicr;
- volatile uint16_t _pad53;
- volatile uint16_t sirp[2];
- volatile uint16_t _pad54;
- volatile uint32_t _pad55[2];
- volatile uint8_t siram[256];
-} m360_t;
-struct bdregions_t {
- volatile unsigned char *base;
- unsigned int size;
- unsigned int used;
-#define M68360_RX_BUF_SIZE 1
-#define M68360_TX_BUF_SIZE 0x100
-struct _m68360_per_chip;
-typedef struct _m68360_per_chip *M68360_t;
-typedef struct _m68360_per_port {
- uint32_t channel;
- M68360_t chip;
- volatile uint32_t *pBRGC; /* m360->brgc# */
- volatile m360SCCparms_t *pSCCB; /* m360->scc#p */
- volatile m360SCCRegisters_t *pSCCR; /* m360->scc# */
- uint32_t baud;
- int minor;
- volatile uint8_t *rxBuf;
- volatile uint8_t *txBuf;
- volatile m360BufferDescriptor_t *sccRxBd;
- volatile m360BufferDescriptor_t *sccTxBd;
-}m68360_per_port_t, *M68360_serial_ports_t;
-typedef struct _m68360_per_chip {
- struct _m68360_per_chip *next;
- struct bdregions_t bdregions[4];
- volatile m360_t *m360; /* Pointer to base Address */
- int m360_interrupt;
- int m360_clock_rate;
- PPMCQ1BoardData board_data;
- m68360_per_port_t port[4];
-} m68360_per_chip_t;
-extern M68360_t M68360_chips;
-void M360SetupMemory( M68360_t ptr );
-void *M360AllocateBufferDescriptors (M68360_t ptr, int count);
-void M360ExecuteRISC( volatile m360_t *m360, uint16_t command);
-int mc68360_scc_create_chip( PPMCQ1BoardData BoardData, uint8_t int_vector );
-#endif /* __MC68360_h */
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c b/c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c
index b2dab2b..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/mc68360_scc.c
+++ /dev/null
@@ -1,904 +0,0 @@
-/* This file contains the termios TTY driver for the
- * Motorola MC68360 SCC ports.
-#include <stdio.h>
-#include <termios.h>
-#include <bsp.h>
-#include <rtems/libio.h>
-#include <bsp/pci.h>
-#include <bsp/irq.h>
-#include <libchip/sersupp.h>
-#include <stdlib.h>
-#include <string.h>
-/* #define DEBUG_360 */
-#if 1 /* XXX */
-int EP1A_READ_LENGTH_GREATER_THAN_1 = 0;
-#define MC68360_LENGTH_SIZE 400
-int mc68360_length_array[ MC68360_LENGTH_SIZE ];
-int mc68360_length_count=0;
-#endif
-M68360_t M68360_chips = NULL;
-#define SYNC eieio
-#define mc68360_scc_Is_422( _minor ) \
- (Console_Port_Tbl[minor]->sDeviceName[7] == '4' )
-static void scc_write8(
- const char *name,
- volatile uint8_t *address,
- uint8_t value
-#ifdef DEBUG_360
- printk( "WR8 %s 0x%08x 0x%02x\n", name, address, value );
-#endif
- *address = value;
-static uint16_t scc_read16(
- const char *name,
- volatile uint16_t *address
- uint16_t value;
-#ifdef DEBUG_360
- printk( "RD16 %s 0x%08x ", name, address );
-#endif
- value = *address;
-#ifdef DEBUG_360
- printk( "0x%04x\n", value );
-#endif
- return value;
-static void scc_write16(
- const char *name,
- volatile uint16_t *address,
- uint16_t value
-#ifdef DEBUG_360
- printk( "WR16 %s 0x%08x 0x%04x\n", name, address, value );
-#endif
- *address = value;
-static uint32_t scc_read32(
- const char *name,
- volatile uint32_t *address
- uint32_t value;
-#ifdef DEBUG_360
- printk( "RD32 %s 0x%08x ", name, address );
-#endif
- value = *address;
-#ifdef DEBUG_360
- printk( "0x%08x\n", value );
-#endif
- return value;
-static void scc_write32(
- const char *name,
- volatile uint32_t *address,
- uint32_t value
-#ifdef DEBUG_360
- printk( "WR32 %s 0x%08x 0x%08x\n", name, address, value );
-#endif
- *address = value;
-#define TX_BUFFER_ADDRESS( _ptr ) \
- ((char *)ptr->txBuf - (char *)ptr->chip->board_data->baseaddr)
-#define RX_BUFFER_ADDRESS( _ptr ) \
- ((char *)ptr->rxBuf - (char *)ptr->chip->board_data->baseaddr)
- * Function: mc68360_sccBRGC *
- * Description: *
- * This function is called to compute the divisor register values for *
- * a given baud rate. *
- * Inputs: *
- * int baud - Baud rate (in bps). *
- * Output: *
- * int - baud rate generator configuration. *
-static int
-mc68360_sccBRGC(int baud, int m360_clock_rate)
- int data;
- * configure baud rate generator for 16x bit rate, where.....
- * b = desired baud rate
- * clk = system clock (33mhz)
- * d = clock dividor value
- * for b > 300 : d = clk/(b*16)
- * for b<= 300 : d = (clk/ (b*16*16))-1)
- SYNC();
- if( baud > 300 ) data = 33333333 / (baud * 16 );
- else data = (33333333 / (baud * 16 * 16) ) - 1;
- data *= 2;
- data &= 0x00001ffe ;
- /* really data = 0x010000 | data | ((baud>300)? 0 : 1 ) ; */
- data |= ((baud>300)? 0 : 1 ) ;
- data |= 0x010000 ;
- return data;
- * sccInterruptHandler
- * This is the interrupt service routine for the console UART. It
- * handles both receive and transmit interrupts. The bulk of the
- * work is done by termios.
-static void mc68360_sccInterruptHandler( M68360_t chip )
- int port;
- uint16_t status;
- uint16_t length;
- int i;
- char data;
- int clear_isr;
-#ifdef DEBUG_360
- printk("mc68360_sccInterruptHandler\n");
-#endif
- for (port=0; port<4; port++) {
- clear_isr = FALSE;
- m360 = chip->m360;
- * XXX - Can we add something here to check if this is our interrupt.
- * XXX - We need a parameter here so that we know which 360 instead of
- * looping through them all!
- * Handle a RX interrupt.
- if ( scc_read16("scce", &chip->port[port].pSCCR->scce) & 0x1)
- clear_isr = TRUE;
- scc_write16("scce", &chip->port[port].pSCCR->scce, 0x1 );
- status =scc_read16( "sccRxBd->status", &chip->port[port].sccRxBd->status);
- while ((status & M360_BD_EMPTY) == 0)
- length= scc_read16("sccRxBd->length",&chip->port[port].sccRxBd->length);
-if (length > 1)
- EP1A_READ_LENGTH_GREATER_THAN_1 = length;
- for (i=0;i<length;i++) {
- data= chip->port[port].rxBuf[i];
- rtems_termios_enqueue_raw_characters(
- Console_Port_Data[ chip->port[port].minor ].termios_data,
- &data,
- 1);
- scc_write16( "sccRxBd->status", &chip->port[port].sccRxBd->status,
- M360_BD_EMPTY | M360_BD_WRAP | M360_BD_INTERRUPT );
- * Handle a TX interrupt.
- if (scc_read16("scce", &chip->port[port].pSCCR->scce) & 0x2)
- clear_isr = TRUE;
- scc_write16("scce", &chip->port[port].pSCCR->scce, 0x2);
- status = scc_read16("sccTxBd->status", &chip->port[port].sccTxBd->status);
- if ((status & M360_BD_EMPTY) == 0)
- scc_write16("sccTxBd->status",&chip->port[port].sccTxBd->status,0);
-#if 1
- rtems_termios_dequeue_characters(
- Console_Port_Data[chip->port[port].minor].termios_data,
- chip->port[port].sccTxBd->length);
-#else
- mc68360_scc_write_support_int(chip->port[port].minor,"*****", 5);
-#endif
- * Clear SCC interrupt-in-service bit.
- if ( clear_isr )
- scc_write32( "cisr", &m360->cisr, (0x80000000 >> chip->port[port].channel) );
- * mc68360_scc_open
- * This function opens a port for communication.
- * Default state is 9600 baud, 8 bits, No parity, and 1 stop bit.
-static int mc68360_scc_open(
- int major,
- int minor,
- void * arg
- M68360_serial_ports_t ptr;
- uint32_t data;
-#ifdef DEBUG_360
- printk("mc68360_scc_open %d\n", minor);
-#endif
- ptr = Console_Port_Tbl[minor]->pDeviceParams;
- * Enable the receiver and the transmitter.
- SYNC();
- data = scc_read32( "pSCCR->gsmr_l", &ptr->pSCCR->gsmr_l);
- scc_write32( "pSCCR->gsmr_l", &ptr->pSCCR->gsmr_l,
- (data | M360_GSMR_ENR | M360_GSMR_ENT) );
- data = PMCQ1_Read_EPLD(ptr->chip->board_data->baseaddr, PMCQ1_INT_MASK );
- data &= (~PMCQ1_INT_MASK_QUICC);
- PMCQ1_Write_EPLD(ptr->chip->board_data->baseaddr, PMCQ1_INT_MASK, data );
- data = PMCQ1_Read_EPLD(ptr->chip->board_data->baseaddr, PMCQ1_INT_STATUS );
- data &= (~PMCQ1_INT_STATUS_QUICC);
- PMCQ1_Write_EPLD(ptr->chip->board_data->baseaddr, PMCQ1_INT_STATUS, data );
- return RTEMS_SUCCESSFUL;
-static uint32_t mc68360_scc_calculate_pbdat( M68360_t chip )
- uint32_t i;
- uint32_t pbdat_data;
- int minor;
- uint32_t type422data[4] = {
- 0x00440, 0x00880, 0x10100, 0x20200
- pbdat_data = 0x3;
- for (i=0; i<4; i++) {
- minor = chip->port[i].minor;
- if mc68360_scc_Is_422( minor )
- pbdat_data |= type422data[i];
- return pbdat_data;
- * mc68360_scc_initialize_interrupts
- * This routine initializes the console's receive and transmit
- * ring buffers and loads the appropriate vectors to handle the interrupts.
-static void mc68360_scc_initialize_interrupts(int minor)
- uint32_t data;
- uint32_t buffers_start;
- uint32_t tmp_u32;
-#ifdef DEBUG_360
- printk("mc68360_scc_initialize_interrupts: minor %d\n", minor );
- printk("Console_Port_Tbl[minor]->pDeviceParams 0x%08x\n",
- Console_Port_Tbl[minor]->pDeviceParams );
-#endif
- m360 = ptr->chip->m360;
-#ifdef DEBUG_360
- printk("m360 0x%08x baseaddr 0x%08x\n",
- m360, ptr->chip->board_data->baseaddr);
-#endif
- buffers_start = ptr->chip->board_data->baseaddr + 0x00200000 +
- ( (M68360_RX_BUF_SIZE + M68360_TX_BUF_SIZE) * (ptr->channel-1));
- ptr->rxBuf = (uint8_t *) buffers_start;
- ptr->txBuf = (uint8_t *)(buffers_start + M68360_RX_BUF_SIZE);
-#ifdef DEBUG_360
- printk("rxBuf 0x%08x txBuf 0x%08x\n", ptr->rxBuf, ptr->txBuf );
-#endif
- * Set Channel Drive Enable bits in EPLD
- data = PMCQ1_Read_EPLD(ptr->chip->board_data->baseaddr, PMCQ1_DRIVER_ENABLE );
- SYNC();
- data = data & ~(PMCQ1_DRIVER_ENABLE_3 | PMCQ1_DRIVER_ENABLE_2 |
- PMCQ1_DRIVER_ENABLE_1 | PMCQ1_DRIVER_ENABLE_0);
- PMCQ1_Write_EPLD(ptr->chip->board_data->baseaddr, PMCQ1_DRIVER_ENABLE, data);
- SYNC();
- * Disable the receiver and the transmitter.
- SYNC();
- tmp_u32 = scc_read32( "gsmr_l", &ptr->pSCCR->gsmr_l );
- tmp_u32 &= (~(M360_GSMR_ENR | M360_GSMR_ENT ) ) ;
- scc_write32( "gsmr_l", &ptr->pSCCR->gsmr_l, tmp_u32 );
- * Disable Interrupt Error and Interrupt Breakpoint
- * Set SAID to 4 XXX - Shouldn't it be 7 for slave mode
- * Set SAISM to 7
- SYNC();
- scc_write16( "sdcr", &m360->sdcr, 0x0740 );
- * Clear status -- reserved interrupt, SDMA channel error, SDMA breakpoint
- scc_write8( "sdsr", &m360->sdsr, 0x07 );
- SYNC();
- * Initialize timer information in RISC Controller Configuration Register
- scc_write16( "rccr", &m360->rccr, 0x8100 );
- SYNC();
- * XXX
- scc_write16( "papar", &m360->papar, 0xffff );
- scc_write16( "padir", &m360->padir, 0x5500 ); /* From Memo */
- scc_write16( "paodr", &m360->paodr, 0x0000 );
- SYNC();
- * XXX
-#if 0
- scc_write32( "pbpar", &m360->pbpar, 0x00000000 );
- scc_write32( "pbdir", &m360->pbdir, 0x0003ffff );
- scc_write32( "pbdat", &m360->pbdat, 0x0000003f );
- SYNC();
-#else
- data = mc68360_scc_calculate_pbdat( ptr->chip );
- scc_write32( "pbdat", &m360->pbdat, data );
- SYNC();
- scc_write32( "pbdir", &m360->pbdir, 0x0003fc3 );
- SYNC();
-#endif
- * XXX
- scc_write16( "pcpar", &m360->pcpar, 0x0000 );
- scc_write16( "pcdir", &m360->pcdir, 0x0000 );
- scc_write16( "pcso", &m360->pcso, 0x0000 );
- SYNC();
- SYNC();
- if( ptr->baud > 300 ) data = 33333333 / (ptr->baud * 16 );
- else data = (33333333 / (ptr->baud * 16 * 16) ) - 1;
- data *= 2 ;
- data |= ((ptr->baud>300)? 0 : 1 ) ;
- scc_write32( "pBRGC", ptr->pBRGC, data );
- data = (((ptr->channel-1)*8) | (ptr->channel-1)) ;
- data = data << ((ptr->channel-1)*8) ;
- data |= scc_read32( "sicr", &m360->sicr );
- scc_write32( "sicr", &m360->sicr, data );
- * initialise SCC parameter ram
- SYNC();
- scc_write16( "pSCCB->rbase", &ptr->pSCCB->rbase,
- (char *)(ptr->sccRxBd) - (char *)m360 );
- scc_write16( "pSCCB->tbase", &ptr->pSCCB->tbase,
- (char *)(ptr->sccTxBd) - (char *)m360 );
- scc_write8( "pSCCB->rfcr", &ptr->pSCCB->rfcr, 0x15 ); /* 0x15 0x18 */
- scc_write8( "pSCCB->tfcr", &ptr->pSCCB->tfcr, 0x15 ); /* 0x15 0x18 */
- scc_write16( "pSCCB->mrblr", &ptr->pSCCB->mrblr, M68360_RX_BUF_SIZE );
- * initialise tx and rx scc parameters
- SYNC();
- data = M360_CR_INIT_TX_RX_PARAMS | 0x01;
- data |= (M360_CR_CH_NUM * (ptr->channel-1) );
- scc_write16( "CR", &m360->cr, data );
- * initialise uart specific parameter RAM
- SYNC();
- scc_write16( "pSCCB->un.uart.max_idl", &ptr->pSCCB->un.uart.max_idl, 15000 );
- scc_write16( "pSCCB->un.uart.brkcr", &ptr->pSCCB->un.uart.brkcr, 0x0001 );
- scc_write16( "pSCCB->un.uart.parec", &ptr->pSCCB->un.uart.parec, 0x0000 );
- scc_write16( "pSCCB->un,uart.frmec", &ptr->pSCCB->un.uart.frmec, 0x0000 );
- scc_write16( "pSCCB->un.uart.nosec", &ptr->pSCCB->un.uart.nosec, 0x0000 );
- scc_write16( "pSCCB->un.uart.brkec", &ptr->pSCCB->un.uart.brkec, 0x0000 );
- scc_write16( "pSCCB->un.uart.uaddr0", &ptr->pSCCB->un.uart.uaddr[0], 0x0000 );
- scc_write16( "pSCCB->un.uart.uaddr1", &ptr->pSCCB->un.uart.uaddr[1], 0x0000 );
- scc_write16( "pSCCB->un.uart.toseq", &ptr->pSCCB->un.uart.toseq, 0x0000 );
- scc_write16( "pSCCB->un.uart.char0",
- &ptr->pSCCB->un.uart.character[0], 0x0039 );
- scc_write16( "pSCCB->un.uart.char1",
- &ptr->pSCCB->un.uart.character[1], 0x8000 );
- scc_write16( "pSCCB->un.uart.char2",
- &ptr->pSCCB->un.uart.character[2], 0x8000 );
- scc_write16( "pSCCB->un.uart.char3",
- &ptr->pSCCB->un.uart.character[3], 0x8000 );
- scc_write16( "pSCCB->un.uart.char4",
- &ptr->pSCCB->un.uart.character[4], 0x8000 );
- scc_write16( "pSCCB->un.uart.char5",
- &ptr->pSCCB->un.uart.character[5], 0x8000 );
- scc_write16( "pSCCB->un.uart.char6",
- &ptr->pSCCB->un.uart.character[6], 0x8000 );
- scc_write16( "pSCCB->un.uart.char7",
- &ptr->pSCCB->un.uart.character[7], 0x8000 );
- scc_write16( "pSCCB->un.uart.rccm", &ptr->pSCCB->un.uart.rccm, 0xc0ff );
- * setup buffer descriptor stuff
- SYNC();
- scc_write16( "sccRxBd->status", &ptr->sccRxBd->status, 0x0000 );
- SYNC();
- scc_write16( "sccRxBd->length", &ptr->sccRxBd->length, 0x0000 );
- /* XXX Radstone Example writes RX buffer ptr as two u16's */
- scc_write32( "sccRxBd->buffer", &ptr->sccRxBd->buffer,
- RX_BUFFER_ADDRESS( ptr ) );
- SYNC();
- scc_write16( "sccTxBd->status", &ptr->sccTxBd->status, 0x0000 );
- SYNC();
- scc_write16( "sccTxBd->length", &ptr->sccTxBd->length, 0x0000 );
- /* XXX Radstone Example writes TX buffer ptr as two u16's */
- scc_write32( "sccTxBd->buffer", &ptr->sccTxBd->buffer,
- TX_BUFFER_ADDRESS( ptr ) );
- * clear previous events and set interrupt priorities
- scc_write16( "pSCCR->scce", &ptr->pSCCR->scce, 0x1bef ); /* From memo */
- SYNC();
- SYNC();
- scc_write32( "cicr", &m360->cicr, 0x001b9f40 );
- SYNC();
- /* scc_write32( "cicr", &m360->cicr, scc_read32( "cicr", &m360->cicr ) ); */
- scc_write16( "pSCCR->sccm", &ptr->pSCCR->sccm, M360_SCCE_TX | M360_SCCE_RX );
- data = scc_read32("cimr", &m360->cimr);
- data |= (0x80000000 >> ptr->channel);
- scc_write32( "cimr", &m360->cimr, data );
- SYNC();
- scc_write32( "cipr", &m360->cipr, scc_read32( "cipr", &m360->cipr ) );
- scc_write32( "pSCCR->gsmr_h", &ptr->pSCCR->gsmr_h, M360_GSMR_RFW );
- (M360_GSMR_TDCR_16X | M360_GSMR_RDCR_16X | M360_GSMR_MODE_UART) );
- scc_write16( "pSCCR->dsr", &ptr->pSCCR->dsr, 0x7e7e );
- SYNC();
- scc_write16( "pSCCR->psmr", &ptr->pSCCR->psmr,
- (M360_PSMR_CL8 | M360_PSMR_UM_NORMAL | M360_PSMR_TPM_ODD) );
- SYNC();
-#if 0 /* XXX - ??? */
- SYNC();
-#endif
- * mc68360_scc_write_support_int
- * Console Termios output entry point when using interrupt driven output.
-static ssize_t mc68360_scc_write_support_int(
- int minor,
- const char *buf,
- size_t len
- rtems_interrupt_level Irql;
-#if 1
- mc68360_length_array[ mc68360_length_count ] = len;
- mc68360_length_count++;
- if ( mc68360_length_count >= MC68360_LENGTH_SIZE )
- mc68360_length_count=0;
-#endif
- * We are using interrupt driven output and termios only sends us
- * one character at a time.
- if ( !len )
- return 0;
-#ifdef DEBUG_360
- printk("mc68360_scc_write_support_int: char 0x%x length %d\n",
- (unsigned int)*buf, len );
-#endif
- * We must copy the data from the global memory space to MC68360 space
- rtems_interrupt_disable(Irql);
- scc_write16( "sccTxBd->status", &ptr->sccTxBd->status, 0 );
- memcpy((void *) ptr->txBuf, buf, len);
- TX_BUFFER_ADDRESS(ptr->txBuf) );
- scc_write16( "sccTxBd->length", &ptr->sccTxBd->length, len );
- (M360_BD_READY | M360_BD_WRAP | M360_BD_INTERRUPT) );
- rtems_interrupt_enable(Irql);
- return len;
- * mc68360_scc_write_polled
- * This routine polls out the requested character.
-static void mc68360_scc_write_polled(
- int minor,
- char cChar
-#ifdef DEBUG_360
- printk("mc68360_scc_write_polled: %c\n", cChar);
-#endif
- * mc68681_set_attributes
- * This function sets the DUART channel to reflect the requested termios
- * port settings.
-static int mc68360_scc_set_attributes(
- int minor,
- const struct termios *t
- int baud;
- uint16_t value;
-#ifdef DEBUG_360
-printk("mc68360_scc_set_attributes\n");
-#endif
- switch (t->c_cflag & CBAUD) {
- case B50: baud = 50; break;
- case B75: baud = 75; break;
- case B110: baud = 110; break;
- case B134: baud = 134; break;
- case B150: baud = 150; break;
- case B200: baud = 200; break;
- case B300: baud = 300; break;
- case B600: baud = 600; break;
- case B1200: baud = 1200; break;
- case B1800: baud = 1800; break;
- case B2400: baud = 2400; break;
- case B4800: baud = 4800; break;
- case B9600: baud = 9600; break;
- case B19200: baud = 19200; break;
- case B38400: baud = 38400; break;
- case B57600: baud = 57600; break;
- case B115200: baud = 115200; break;
- case B230400: baud = 230400; break;
- case B460800: baud = 460800; break;
- default: baud = -1; break;
- if (baud > 0) {
- scc_write32(
- "pBRGC",
- ptr->pBRGC,
- mc68360_sccBRGC(baud, ptr->chip->m360_clock_rate)
- /* Initial value of PSMR should be 0 */
- value = M360_PSMR_UM_NORMAL;
- /* set the number of data bits, 8 is most common */
- if (t->c_cflag & CSIZE) { /* was it specified? */
- switch (t->c_cflag & CSIZE) {
- case CS5: value |= M360_PSMR_CL5; break;
- case CS6: value |= M360_PSMR_CL6; break;
- case CS7: value |= M360_PSMR_CL7; break;
- case CS8: value |= M360_PSMR_CL8; break;
- } else {
- value |= M360_PSMR_CL8; /* default to 8 data bits */
- /* the number of stop bits */
- if (t->c_cflag & CSTOPB)
- value |= M360_PSMR_SL_2; /* Two stop bits */
- else
- value |= M360_PSMR_SL_1; /* One stop bit */
- /* Set Parity M360_PSMR_PEN bit should be clear on no parity so
- * do nothing in that case
- if (t->c_cflag & PARENB) { /* enable parity detection? */
- value |= M360_PSMR_PEN;
- if (t->c_cflag & PARODD){
- value |= M360_PSMR_RPM_ODD; /* select odd parity */
- value |= M360_PSMR_TPM_ODD;
- } else {
- value |= M360_PSMR_RPM_EVEN; /* select even parity */
- value |= M360_PSMR_TPM_EVEN;
- SYNC();
- scc_write16( "pSCCR->psmr", &ptr->pSCCR->psmr, value );
- SYNC();
- return 0;
- * mc68360_scc_close
- * This function shuts down the requested port.
-static int mc68360_scc_close(
- int major,
- int minor,
- void *arg
- * mc68360_scc_inbyte_nonblocking_polled
- * Console Termios polling input entry point.
-static int mc68360_scc_inbyte_nonblocking_polled(
- int minor
- return -1;
- * mc68360_scc_write_support_polled
- * Console Termios output entry point when using polled output.
-static ssize_t mc68360_scc_write_support_polled(
- int minor,
- const char *buf,
- size_t len
- printk("mc68360_scc_write_support_polled: minor %d char %c len %d\n",
- minor, buf, len );
- return len;
- * This function initializes the DUART to a quiecsent state.
-static void mc68360_scc_init(int minor)
-#ifdef DEBUG_360
- printk("mc68360_scc_init\n");
-#endif
- M68360_t chip;
- int i;
-#ifdef DEBUG_360
- printk("mc68360_scc_create_chip\n");
-#endif
- * Create console structure for this card
- * XXX - Note Does this need to be moved up to if a QUICC is fitted
- * section?
- if ((chip = malloc(sizeof(struct _m68360_per_chip))) == NULL)
- printk("Error Unable to allocate memory for _m68360_per_chip\n");
- return RTEMS_IO_ERROR;
- chip->next = M68360_chips;
- chip->m360 = (void *)BoardData->baseaddr;
- chip->m360_interrupt = int_vector;
- chip->m360_clock_rate = 25000000;
- chip->board_data = BoardData;
- M68360_chips = chip;
- for (i=1; i<=4; i++) {
- chip->port[i-1].channel = i;
- chip->port[i-1].chip = chip;
- chip->port[i-1].baud = 9600;
- switch( i ) {
- case 1:
- chip->port[i-1].pBRGC = &chip->m360->brgc1;
- chip->port[i-1].pSCCB = (m360SCCparms_t *) &chip->m360->scc1p;
- chip->port[i-1].pSCCR = &chip->m360->scc1;
- M360SetupMemory( chip ); /* Do this first time through */
- break;
- case 2:
- chip->port[i-1].pBRGC = &chip->m360->brgc2;
- chip->port[i-1].pSCCB = &chip->m360->scc2p;
- chip->port[i-1].pSCCR = &chip->m360->scc2;
- break;
- case 3:
- chip->port[i-1].pBRGC = &chip->m360->brgc3;
- chip->port[i-1].pSCCB = &chip->m360->scc3p;
- chip->port[i-1].pSCCR = &chip->m360->scc3;
- break;
- case 4:
- chip->port[i-1].pBRGC = &chip->m360->brgc4;
- chip->port[i-1].pSCCB = &chip->m360->scc4p;
- chip->port[i-1].pSCCR = &chip->m360->scc4;
- break;
- default:
- printk("Invalid mc68360 channel %d\n", i);
- * Allocate buffer descriptors.
- chip->port[i-1].sccRxBd = M360AllocateBufferDescriptors(chip, 1);
- chip->port[i-1].sccTxBd = M360AllocateBufferDescriptors(chip, 1);
- rsPMCQ1QuiccIntConnect(
- chip->board_data->busNo,
- chip->board_data->slotNo,
- chip->board_data->funcNo,
- (FUNCTION_PTR) &mc68360_sccInterruptHandler,
- (uintptr_t) chip
-const console_fns mc68360_scc_fns = {
- libchip_serial_default_probe, /* deviceProbe */
- mc68360_scc_open, /* deviceFirstOpen */
- NULL, /* deviceLastClose */
- NULL, /* deviceRead */
- mc68360_scc_write_support_int, /* deviceWrite */
- mc68360_scc_initialize_interrupts, /* deviceInitialize */
- mc68360_scc_write_polled, /* deviceWritePolled */
- mc68360_scc_set_attributes, /* deviceSetAttributes */
- TRUE /* deviceOutputUsesInterrupts */
-const console_fns mc68360_scc_polled = {
- mc68360_scc_close, /* deviceLastClose */
- mc68360_scc_inbyte_nonblocking_polled, /* deviceRead */
- mc68360_scc_write_support_polled, /* deviceWrite */
- mc68360_scc_init, /* deviceInitialize */
- FALSE /* deviceOutputUsesInterrupts */
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.c b/c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.c
deleted file mode 100644
index 12a423b..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.c
+++ /dev/null
@@ -1,53 +0,0 @@
- * This include file contains all console driver definitions for the ns16550.
-#include <bsp.h>
-typedef struct uart_reg
- unsigned char reg;
- unsigned char pad[7];
-} uartReg;
-uint8_t Read_ns16550_register(
- uintptr_t ulCtrlPort,
- uint8_t ucRegNum
- volatile struct uart_reg *p = (volatile struct uart_reg *)ulCtrlPort;
- uint8_t ucData;
- ucData = p[ucRegNum].reg;
- __asm__ volatile("sync");
- return ucData;
-void Write_ns16550_register(
- uint8_t ucRegNum,
- uint8_t ucData
- volatile int i;
- p[ucRegNum].reg = ucData;
- __asm__ volatile("isync");
- __asm__ volatile("eieio");
- for (i=0;i<0x08ff;i++)
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h b/c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h
index 45d5208..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/ns16550cfg.h
+++ /dev/null
@@ -1,43 +0,0 @@
-#ifndef __NS16550_CONFIG_H
-#define __NS16550_CONFIG_H
-#ifdef __cplusplus
-extern "C" {
-#endif
- * Board specific register access routines
- uint8_t ucRegNum
- uint8_t ucRegNum,
- uint8_t ucData
-extern const console_fns ns16550_fns_8245;
-extern const console_fns ns16550_fns_polled_8245;
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/polled_io.c b/c/src/lib/libbsp/powerpc/ep1a/console/polled_io.c
index e0ae919..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/polled_io.c
+++ /dev/null
@@ -1,1026 +0,0 @@
- * polled_io.c -- Basic input/output for early boot
- * Copyright (C) 1998, 1999 Gabriel Paubert, paubert at iram.es
- * Modified to compile in RTEMS development environment
- * by Eric Valette
- * Copyright (C) 1999 Eric Valette. valette at crf.canon.fr
-#include <rtems/system.h>
-#include <sys/types.h>
-#include <libcpu/byteorder.h>
-#include <libcpu/page.h>
-#include <libcpu/mmu.h>
-#include <stdarg.h>
-#include <bsp/consoleIo.h>
-#include <bsp.h>
-#include <libcpu/spr.h>
-#if 0
-#ifdef BSP_KBD_IOBASE
-#define USE_KBD_SUPPORT
-#endif
-#ifdef BSP_VGA_IOBASE
-#define USE_VGA_SUPPORT
-#endif
-#ifdef USE_KBD_SUPPORT
-#include "keyboard.h"
-#endif
-#include "console.inl"
-#ifdef __BOOT__
-extern void boot_udelay();
-void * __palloc(u_long);
-void pfree(void *);
-#else
-#endif
-typedef unsigned long long u64;
-typedef long long s64;
-typedef unsigned int u32;
-#ifndef __BOOT__
-BSP_output_char_function_type BSP_output_char = debug_putc_onlcr;
-BSP_polling_getchar_function_type BSP_poll_char = NULL;
-#endif
-unsigned short plain_map[NR_KEYS] = {
- 0xf200, 0xf01b, 0xf031, 0xf032, 0xf033, 0xf034, 0xf035, 0xf036,
- 0xf037, 0xf038, 0xf039, 0xf030, 0xf02d, 0xf03d, 0xf07f, 0xf009,
- 0xfb71, 0xfb77, 0xfb65, 0xfb72, 0xfb74, 0xfb79, 0xfb75, 0xfb69,
- 0xfb6f, 0xfb70, 0xf05b, 0xf05d, 0xf201, 0xf702, 0xfb61, 0xfb73,
- 0xfb64, 0xfb66, 0xfb67, 0xfb68, 0xfb6a, 0xfb6b, 0xfb6c, 0xf03b,
- 0xf027, 0xf060, 0xf700, 0xf05c, 0xfb7a, 0xfb78, 0xfb63, 0xfb76,
- 0xfb62, 0xfb6e, 0xfb6d, 0xf02c, 0xf02e, 0xf02f, 0xf700, 0xf30c,
- 0xf703, 0xf020, 0xf207, 0xf100, 0xf101, 0xf102, 0xf103, 0xf104,
- 0xf105, 0xf106, 0xf107, 0xf108, 0xf109, 0xf208, 0xf209, 0xf307,
- 0xf308, 0xf309, 0xf30b, 0xf304, 0xf305, 0xf306, 0xf30a, 0xf301,
- 0xf302, 0xf303, 0xf300, 0xf310, 0xf206, 0xf200, 0xf03c, 0xf10a,
- 0xf10b, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200,
- 0xf30e, 0xf702, 0xf30d, 0xf01c, 0xf701, 0xf205, 0xf114, 0xf603,
- 0xf118, 0xf601, 0xf602, 0xf117, 0xf600, 0xf119, 0xf115, 0xf116,
- 0xf11a, 0xf10c, 0xf10d, 0xf11b, 0xf11c, 0xf110, 0xf311, 0xf11d,
- 0xf200, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200,
-unsigned short shift_map[NR_KEYS] = {
- 0xf200, 0xf01b, 0xf021, 0xf040, 0xf023, 0xf024, 0xf025, 0xf05e,
- 0xf026, 0xf02a, 0xf028, 0xf029, 0xf05f, 0xf02b, 0xf07f, 0xf009,
- 0xfb51, 0xfb57, 0xfb45, 0xfb52, 0xfb54, 0xfb59, 0xfb55, 0xfb49,
- 0xfb4f, 0xfb50, 0xf07b, 0xf07d, 0xf201, 0xf702, 0xfb41, 0xfb53,
- 0xfb44, 0xfb46, 0xfb47, 0xfb48, 0xfb4a, 0xfb4b, 0xfb4c, 0xf03a,
- 0xf022, 0xf07e, 0xf700, 0xf07c, 0xfb5a, 0xfb58, 0xfb43, 0xfb56,
- 0xfb42, 0xfb4e, 0xfb4d, 0xf03c, 0xf03e, 0xf03f, 0xf700, 0xf30c,
- 0xf703, 0xf020, 0xf207, 0xf10a, 0xf10b, 0xf10c, 0xf10d, 0xf10e,
- 0xf10f, 0xf110, 0xf111, 0xf112, 0xf113, 0xf213, 0xf203, 0xf307,
- 0xf302, 0xf303, 0xf300, 0xf310, 0xf206, 0xf200, 0xf03e, 0xf10a,
- 0xf30e, 0xf702, 0xf30d, 0xf200, 0xf701, 0xf205, 0xf114, 0xf603,
- 0xf20b, 0xf601, 0xf602, 0xf117, 0xf600, 0xf20a, 0xf115, 0xf116,
-unsigned short altgr_map[NR_KEYS] = {
- 0xf200, 0xf200, 0xf200, 0xf040, 0xf200, 0xf024, 0xf200, 0xf200,
- 0xf07b, 0xf05b, 0xf05d, 0xf07d, 0xf05c, 0xf200, 0xf200, 0xf200,
- 0xfb71, 0xfb77, 0xf918, 0xfb72, 0xfb74, 0xfb79, 0xfb75, 0xfb69,
- 0xfb6f, 0xfb70, 0xf200, 0xf07e, 0xf201, 0xf702, 0xf914, 0xfb73,
- 0xf917, 0xf919, 0xfb67, 0xfb68, 0xfb6a, 0xfb6b, 0xfb6c, 0xf200,
- 0xf200, 0xf200, 0xf700, 0xf200, 0xfb7a, 0xfb78, 0xf916, 0xfb76,
- 0xf915, 0xfb6e, 0xfb6d, 0xf200, 0xf200, 0xf200, 0xf700, 0xf30c,
- 0xf703, 0xf200, 0xf207, 0xf50c, 0xf50d, 0xf50e, 0xf50f, 0xf510,
- 0xf511, 0xf512, 0xf513, 0xf514, 0xf515, 0xf208, 0xf202, 0xf911,
- 0xf912, 0xf913, 0xf30b, 0xf90e, 0xf90f, 0xf910, 0xf30a, 0xf90b,
- 0xf90c, 0xf90d, 0xf90a, 0xf310, 0xf206, 0xf200, 0xf07c, 0xf516,
- 0xf517, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200,
-unsigned short ctrl_map[NR_KEYS] = {
- 0xf200, 0xf200, 0xf200, 0xf000, 0xf01b, 0xf01c, 0xf01d, 0xf01e,
- 0xf01f, 0xf07f, 0xf200, 0xf200, 0xf01f, 0xf200, 0xf008, 0xf200,
- 0xf011, 0xf017, 0xf005, 0xf012, 0xf014, 0xf019, 0xf015, 0xf009,
- 0xf00f, 0xf010, 0xf01b, 0xf01d, 0xf201, 0xf702, 0xf001, 0xf013,
- 0xf004, 0xf006, 0xf007, 0xf008, 0xf00a, 0xf00b, 0xf00c, 0xf200,
- 0xf007, 0xf000, 0xf700, 0xf01c, 0xf01a, 0xf018, 0xf003, 0xf016,
- 0xf002, 0xf00e, 0xf00d, 0xf200, 0xf20e, 0xf07f, 0xf700, 0xf30c,
- 0xf703, 0xf000, 0xf207, 0xf100, 0xf101, 0xf102, 0xf103, 0xf104,
- 0xf105, 0xf106, 0xf107, 0xf108, 0xf109, 0xf208, 0xf204, 0xf307,
- 0xf302, 0xf303, 0xf300, 0xf310, 0xf206, 0xf200, 0xf200, 0xf10a,
-unsigned short shift_ctrl_map[NR_KEYS] = {
- 0xf200, 0xf200, 0xf200, 0xf000, 0xf200, 0xf200, 0xf200, 0xf200,
- 0xf200, 0xf200, 0xf200, 0xf200, 0xf01f, 0xf200, 0xf200, 0xf200,
- 0xf00f, 0xf010, 0xf200, 0xf200, 0xf201, 0xf702, 0xf001, 0xf013,
- 0xf200, 0xf200, 0xf700, 0xf200, 0xf01a, 0xf018, 0xf003, 0xf016,
- 0xf002, 0xf00e, 0xf00d, 0xf200, 0xf200, 0xf200, 0xf700, 0xf30c,
- 0xf703, 0xf200, 0xf207, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200,
- 0xf200, 0xf200, 0xf200, 0xf200, 0xf200, 0xf208, 0xf200, 0xf307,
- 0xf302, 0xf303, 0xf300, 0xf310, 0xf206, 0xf200, 0xf200, 0xf200,
-unsigned short alt_map[NR_KEYS] = {
- 0xf200, 0xf81b, 0xf831, 0xf832, 0xf833, 0xf834, 0xf835, 0xf836,
- 0xf837, 0xf838, 0xf839, 0xf830, 0xf82d, 0xf83d, 0xf87f, 0xf809,
- 0xf871, 0xf877, 0xf865, 0xf872, 0xf874, 0xf879, 0xf875, 0xf869,
- 0xf86f, 0xf870, 0xf85b, 0xf85d, 0xf80d, 0xf702, 0xf861, 0xf873,
- 0xf864, 0xf866, 0xf867, 0xf868, 0xf86a, 0xf86b, 0xf86c, 0xf83b,
- 0xf827, 0xf860, 0xf700, 0xf85c, 0xf87a, 0xf878, 0xf863, 0xf876,
- 0xf862, 0xf86e, 0xf86d, 0xf82c, 0xf82e, 0xf82f, 0xf700, 0xf30c,
- 0xf703, 0xf820, 0xf207, 0xf500, 0xf501, 0xf502, 0xf503, 0xf504,
- 0xf505, 0xf506, 0xf507, 0xf508, 0xf509, 0xf208, 0xf209, 0xf907,
- 0xf908, 0xf909, 0xf30b, 0xf904, 0xf905, 0xf906, 0xf30a, 0xf901,
- 0xf902, 0xf903, 0xf900, 0xf310, 0xf206, 0xf200, 0xf83c, 0xf50a,
- 0xf50b, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200, 0xf200,
- 0xf118, 0xf210, 0xf211, 0xf117, 0xf600, 0xf119, 0xf115, 0xf116,
-unsigned short ctrl_alt_map[NR_KEYS] = {
- 0xf811, 0xf817, 0xf805, 0xf812, 0xf814, 0xf819, 0xf815, 0xf809,
- 0xf80f, 0xf810, 0xf200, 0xf200, 0xf201, 0xf702, 0xf801, 0xf813,
- 0xf804, 0xf806, 0xf807, 0xf808, 0xf80a, 0xf80b, 0xf80c, 0xf200,
- 0xf200, 0xf200, 0xf700, 0xf200, 0xf81a, 0xf818, 0xf803, 0xf816,
- 0xf802, 0xf80e, 0xf80d, 0xf200, 0xf200, 0xf200, 0xf700, 0xf30c,
- 0xf703, 0xf200, 0xf207, 0xf500, 0xf501, 0xf502, 0xf503, 0xf504,
- 0xf505, 0xf506, 0xf507, 0xf508, 0xf509, 0xf208, 0xf200, 0xf307,
- 0xf302, 0xf303, 0xf300, 0xf20c, 0xf206, 0xf200, 0xf200, 0xf50a,
- 0xf118, 0xf601, 0xf602, 0xf117, 0xf600, 0xf119, 0xf115, 0xf20c,
-ushort *key_maps[MAX_NR_KEYMAPS] = {
- plain_map, shift_map, altgr_map, 0,
- ctrl_map, shift_ctrl_map, 0, 0,
- alt_map, 0, 0, 0,
- ctrl_alt_map, 0
-unsigned int keymap_count = 7;
- * Philosophy: most people do not define more strings, but they who do
- * often want quite a lot of string space. So, we statically allocate
- * the default and allocate dynamically in chunks of 512 bytes.
-char func_buf[] = {
- '\033', '[', '[', 'A', 0,
- '\033', '[', '[', 'B', 0,
- '\033', '[', '[', 'C', 0,
- '\033', '[', '[', 'D', 0,
- '\033', '[', '[', 'E', 0,
- '\033', '[', '1', '7', '~', 0,
- '\033', '[', '1', '8', '~', 0,
- '\033', '[', '1', '9', '~', 0,
- '\033', '[', '2', '0', '~', 0,
- '\033', '[', '2', '1', '~', 0,
- '\033', '[', '2', '3', '~', 0,
- '\033', '[', '2', '4', '~', 0,
- '\033', '[', '2', '5', '~', 0,
- '\033', '[', '2', '6', '~', 0,
- '\033', '[', '2', '8', '~', 0,
- '\033', '[', '2', '9', '~', 0,
- '\033', '[', '3', '1', '~', 0,
- '\033', '[', '3', '2', '~', 0,
- '\033', '[', '3', '3', '~', 0,
- '\033', '[', '3', '4', '~', 0,
- '\033', '[', '1', '~', 0,
- '\033', '[', '2', '~', 0,
- '\033', '[', '3', '~', 0,
- '\033', '[', '4', '~', 0,
- '\033', '[', '5', '~', 0,
- '\033', '[', '6', '~', 0,
- '\033', '[', 'M', 0,
- '\033', '[', 'P', 0,
-char *funcbufptr = func_buf;
-int funcbufsize = sizeof(func_buf);
-int funcbufleft = 0; /* space left */
-char *func_table[MAX_NR_FUNC] = {
- func_buf + 0,
- func_buf + 5,
- func_buf + 10,
- func_buf + 15,
- func_buf + 20,
- func_buf + 25,
- func_buf + 31,
- func_buf + 37,
- func_buf + 43,
- func_buf + 49,
- func_buf + 55,
- func_buf + 61,
- func_buf + 67,
- func_buf + 73,
- func_buf + 79,
- func_buf + 85,
- func_buf + 91,
- func_buf + 97,
- func_buf + 103,
- func_buf + 109,
- func_buf + 115,
- func_buf + 120,
- func_buf + 125,
- func_buf + 130,
- func_buf + 135,
- func_buf + 140,
- func_buf + 145,
- 0,
- 0,
- func_buf + 149,
- 0,
-struct kbdiacr {
- unsigned char diacr, base, result;
-struct kbdiacr accent_table[MAX_DIACR] = {
- {'`', 'A', '\300'}, {'`', 'a', '\340'},
- {'\'', 'A', '\301'}, {'\'', 'a', '\341'},
- {'^', 'A', '\302'}, {'^', 'a', '\342'},
- {'~', 'A', '\303'}, {'~', 'a', '\343'},
- {'"', 'A', '\304'}, {'"', 'a', '\344'},
- {'O', 'A', '\305'}, {'o', 'a', '\345'},
- {'0', 'A', '\305'}, {'0', 'a', '\345'},
- {'A', 'A', '\305'}, {'a', 'a', '\345'},
- {'A', 'E', '\306'}, {'a', 'e', '\346'},
- {',', 'C', '\307'}, {',', 'c', '\347'},
- {'`', 'E', '\310'}, {'`', 'e', '\350'},
- {'\'', 'E', '\311'}, {'\'', 'e', '\351'},
- {'^', 'E', '\312'}, {'^', 'e', '\352'},
- {'"', 'E', '\313'}, {'"', 'e', '\353'},
- {'`', 'I', '\314'}, {'`', 'i', '\354'},
- {'\'', 'I', '\315'}, {'\'', 'i', '\355'},
- {'^', 'I', '\316'}, {'^', 'i', '\356'},
- {'"', 'I', '\317'}, {'"', 'i', '\357'},
- {'-', 'D', '\320'}, {'-', 'd', '\360'},
- {'~', 'N', '\321'}, {'~', 'n', '\361'},
- {'`', 'O', '\322'}, {'`', 'o', '\362'},
- {'\'', 'O', '\323'}, {'\'', 'o', '\363'},
- {'^', 'O', '\324'}, {'^', 'o', '\364'},
- {'~', 'O', '\325'}, {'~', 'o', '\365'},
- {'"', 'O', '\326'}, {'"', 'o', '\366'},
- {'/', 'O', '\330'}, {'/', 'o', '\370'},
- {'`', 'U', '\331'}, {'`', 'u', '\371'},
- {'\'', 'U', '\332'}, {'\'', 'u', '\372'},
- {'^', 'U', '\333'}, {'^', 'u', '\373'},
- {'"', 'U', '\334'}, {'"', 'u', '\374'},
- {'\'', 'Y', '\335'}, {'\'', 'y', '\375'},
- {'T', 'H', '\336'}, {'t', 'h', '\376'},
- {'s', 's', '\337'}, {'"', 'y', '\377'},
- {'s', 'z', '\337'}, {'i', 'j', '\377'},
-unsigned int accent_table_size = 68;
-/* These #defines have been copied from drivers/char/pc_keyb.h, by
- * Martin Mares (mj at ucw.cz).
- * converted to offsets by Till Straumann <strauman at slac.stanford.edu>
-#define KBD_STATUS_REG 0x4 /* Status register (R) */
-#define KBD_CNTL_REG 0x4 /* Controller command register (W) */
-#define KBD_DATA_REG 0x0 /* Keyboard data register (R/W) */
- * Keyboard Controller Commands
-#define KBD_CCMD_WRITE_MODE 0x60 /* Write mode bits */
-#define KBD_CCMD_GET_VERSION 0xA1 /* Get controller version */
-#define KBD_CCMD_MOUSE_DISABLE 0xA7 /* Disable mouse interface */
-#define KBD_CCMD_MOUSE_ENABLE 0xA8 /* Enable mouse interface */
-#define KBD_CCMD_TEST_MOUSE 0xA9 /* Mouse interface test */
-#define KBD_CCMD_SELF_TEST 0xAA /* Controller self test */
-#define KBD_CCMD_KBD_TEST 0xAB /* Keyboard interface test */
-#define KBD_CCMD_KBD_DISABLE 0xAD /* Keyboard interface disable */
-#define KBD_CCMD_KBD_ENABLE 0xAE /* Keyboard interface enable */
- * Keyboard Commands
-#define KBD_CMD_ENABLE 0xF4 /* Enable scanning */
-#define KBD_CMD_DISABLE 0xF5 /* Disable scanning */
-#define KBD_CMD_RESET 0xFF /* Reset */
- * Keyboard Replies
-#define KBD_REPLY_POR 0xAA /* Power on reset */
-#define KBD_REPLY_ACK 0xFA /* Command ACK */
-#define KBD_REPLY_RESEND 0xFE /* Command NACK, send the cmd again */
- * Status Register Bits
-#define KBD_STAT_OBF 0x01 /* Keyboard output buffer full */
-#define KBD_STAT_IBF 0x02 /* Keyboard input buffer full */
-#define KBD_STAT_UNLOCKED 0x10 /* Zero if keyboard locked */
-#define KBD_STAT_GTO 0x40 /* General receive/xmit timeout */
-#define KBD_STAT_PERR 0x80 /* Parity error */
- * Controller Mode Register Bits
-#define KBD_MODE_KBD_INT 0x01 /* Keyboard data generate IRQ1 */
-#define KBD_MODE_SYS 0x04 /* The system flag (?) */
-#define KBD_MODE_NO_KEYLOCK 0x08 /* The keylock doesn't affect the keyboard if set */
-#define KBD_MODE_DISABLE_KBD 0x10 /* Disable keyboard interface */
-#define KBD_MODE_DISABLE_MOUSE 0x20 /* Disable mouse interface */
-#define KBD_MODE_KCC 0x40 /* Scan code conversion to PC format */
-#define KBD_MODE_RFU 0x80
-#endif /* USE_KBD_SUPPORT */
-/* Early messages after mm init but before console init are kept in log
- * buffers.
-#define PAGE_LOG_CHARS (PAGE_SIZE-sizeof(int)-sizeof(u_long)-1)
-typedef struct _console_log {
- struct _console_log *next;
- int offset;
- u_char data[PAGE_LOG_CHARS];
-} console_log;
-#ifdef STATIC_LOG_ALLOC
-#define STATIC_LOG_DATA_PAGE_NB 3
-static u_char log_page_pool [STATIC_LOG_DATA_PAGE_NB * PAGE_SIZE];
-#endif
-#endif
-static board_memory_map mem_map = {
- (__io_ptr) _IO_BASE, /* from libcpu/io.h */
- (__io_ptr) _ISA_MEM_BASE,
-board_memory_map *ptr_mem_map = &mem_map;
-void log_putc(const u_char c) {
- console_log *l;
- for(l=console_global_data.log; l; l=l->next) {
- if (l->offset<PAGE_LOG_CHARS) break;
- if (!l) {
- l=__palloc(sizeof(console_log));
- memset(l, 0, sizeof(console_log));
- if (!console_global_data.log)
- console_global_data.log = l;
- else {
- console_log *p;
- for (p=console_global_data.log;
- p->next; p=p->next);
- p->next = l;
- l->data[l->offset++] = c;
-/* This puts is non standard since it does not automatically add a newline
- * at the end. So it is made private to avoid confusion in other files.
-static
-void puts(const u_char *s)
- char c;
- while ( ( c = *s++ ) != '\0' ) {
- debug_putc_onlcr((const char)c);
-static
-void flush_log(void) {
- console_log *p, *next;
- if (console_global_data.vacuum_sent) {
-#ifdef TRACE_FLUSH_LOG
- printk("%d characters sent into oblivion before MM init!\n",
- console_global_data.vacuum_sent);
-#endif
- for(p=console_global_data.log; p; p=next) {
- puts(p->data);
- next = p->next;
- pfree(p);
-#ifndef INL_CONSOLE_INB
-#error "BSP probably didn't define a console port"
-#endif
-void serial_putc(const u_char c)
- while ((INL_CONSOLE_INB(lsr) & LSR_THRE) == 0) ;
- INL_CONSOLE_OUTB(thr, c);
-int serial_getc(void)
- while ((INL_CONSOLE_INB(lsr) & LSR_DR) == 0) ;
- return (INL_CONSOLE_INB(rbr));
-int serial_tstc(void)
- return ((INL_CONSOLE_INB(lsr) & LSR_DR) != 0);
-#ifdef USE_VGA_SUPPORT
-static void scroll(void)
- int i;
- memcpy ( (u_char *)vidmem, (u_char *)vidmem + console_global_data.cols * 2,
- ( console_global_data.lines - 1 ) * console_global_data.cols * 2 );
- for ( i = ( console_global_data.lines - 1 ) * console_global_data.cols * 2;
- i < console_global_data.lines * console_global_data.cols * 2;
- i += 2 )
- vidmem[i] = ' ';
- * cursor() sets an offset (0-1999) into the 80x25 text area
-static void
-cursor(int x, int y)
- int pos = console_global_data.cols*y + x;
- vga_outb(14, 0x14);
- vga_outb(0x15, pos>>8);
- vga_outb(0x14, 15);
- vga_outb(0x15, pos);
-void
-vga_putc(const u_char c)
- int x,y;
- x = console_global_data.orig_x;
- y = console_global_data.orig_y;
- if ( c == '\n' ) {
- if ( ++y >= console_global_data.lines ) {
- scroll();
- y--;
- } else if (c == '\b') {
- if (x > 0) {
- x--;
- } else if (c == '\r') {
- x = 0;
- } else {
- vidmem [ ( x + console_global_data.cols * y ) * 2 ] = c;
- if ( ++x >= console_global_data.cols ) {
- x = 0;
- scroll();
- y--;
- cursor(x, y);
- console_global_data.orig_x = x;
- console_global_data.orig_y = y;
-#endif /* USE_VGA_SUPPORT */
-/* Keyboard support */
-static int kbd_getc(void)
- unsigned char dt, brk, val;
- unsigned code;
-loop:
- while((kbd_inb(KBD_STATUS_REG) & KBD_STAT_OBF) == 0) ;
- dt = kbd_inb(KBD_DATA_REG);
- brk = dt & 0x80; /* brk == 1 on key release */
- dt = dt & 0x7f; /* keycode */
- if (console_global_data.shfts)
- code = shift_map[dt];
- else if (console_global_data.ctls)
- code = ctrl_map[dt];
- else
- code = plain_map[dt];
- val = KVAL(code);
- switch (KTYP(code) & 0x0f) {
- case KT_LATIN:
- if (brk)
- break;
- if (console_global_data.alts)
- val |= 0x80;
- if (val == 0x7f) /* map delete to backspace */
- val = '\b';
- return val;
- case KT_LETTER:
- if (brk)
- break;
- if (console_global_data.caps)
- val -= 'a'-'A';
- return val;
- case KT_SPEC:
- if (brk)
- break;
- if (val == KVAL(K_CAPS))
- console_global_data.caps = !console_global_data.caps;
- else if (val == KVAL(K_ENTER)) {
-enter: /* Wait for key up */
- while (1) {
- if (dt & 0x80) /* key up */ break;
- return 10;
- break;
- case KT_PAD:
- if (brk)
- break;
- if (val < 10)
- return val;
- if (val == KVAL(K_PENTER))
- goto enter;
- break;
- case KT_SHIFT:
- switch (val) {
- case KG_SHIFT:
- case KG_SHIFTL:
- case KG_SHIFTR:
- console_global_data.shfts = brk ? 0 : 1;
- break;
- case KG_ALT:
- case KG_ALTGR:
- console_global_data.alts = brk ? 0 : 1;
- break;
- case KG_CTRL:
- case KG_CTRLL:
- case KG_CTRLR:
- console_global_data.ctls = brk ? 0 : 1;
- break;
- break;
- case KT_LOCK:
- switch (val) {
- case KG_SHIFT:
- case KG_SHIFTL:
- case KG_SHIFTR:
- if (brk)
- console_global_data.shfts = !console_global_data.shfts;
- break;
- case KG_ALT:
- case KG_ALTGR:
- if (brk)
- console_global_data.alts = !console_global_data.alts;
- break;
- case KG_CTRL:
- case KG_CTRLL:
- case KG_CTRLR:
- if (brk)
- console_global_data.ctls = !console_global_data.ctls;
- break;
- break;
- /* if (brk) return (0); */ /* Ignore initial 'key up' codes */
- goto loop;
-static int kbd_get(int ms) {
- int status, data;
- while(1) {
- status = kbd_inb(KBD_STATUS_REG);
- if (status & KBD_STAT_OBF) {
- data = kbd_inb(KBD_DATA_REG);
- if (status & (KBD_STAT_GTO | KBD_STAT_PERR))
- return -1;
- else
- return data;
- if (--ms < 0) return -1;
-#ifdef __BOOT__
- boot_udelay(1000);
-#else
- rtems_bsp_delay(1000);
-#endif
-static void kbd_put(u_char c, int ms, int port) {
- while (kbd_inb(KBD_STATUS_REG) & KBD_STAT_IBF) {
- if (--ms < 0) return;
-#ifdef __BOOT__
-#else
-#endif
- kbd_outb(port, c);
-int kbdreset(void)
- int c;
- /* Flush all pending data */
- while(kbd_get(10) != -1);
- /* Send self-test */
- kbd_put(KBD_CCMD_SELF_TEST, 10, KBD_CNTL_REG);
- c = kbd_get(1000);
- if (c != 0x55) return 1;
- /* Enable then reset the KB */
- kbd_put(KBD_CCMD_KBD_ENABLE, 10, KBD_CNTL_REG);
- while (1) {
- kbd_put(KBD_CMD_RESET, 10, KBD_DATA_REG);
- if (c == KBD_REPLY_ACK) break;
- if (c != KBD_REPLY_RESEND) return 2;
- if (kbd_get(1000) != KBD_REPLY_POR) return 3;
- /* Disable the keyboard while setting up the controller */
- kbd_put(KBD_CMD_DISABLE, 10, KBD_DATA_REG);
- if (kbd_get(10)!=KBD_REPLY_ACK) return 4;
- /* Enable interrupts and keyboard controller */
- kbd_put(KBD_CCMD_WRITE_MODE, 10, KBD_CNTL_REG);
- kbd_put(KBD_MODE_KBD_INT | KBD_MODE_SYS |
- KBD_MODE_DISABLE_MOUSE | KBD_MODE_KCC,
- 10, KBD_DATA_REG);
- /* Reenable the keyboard */
- kbd_put(KBD_CMD_ENABLE, 10, KBD_DATA_REG);
- if (kbd_get(10)!=KBD_REPLY_ACK) return 5;
- return 0;
-int kbd_tstc(void)
- return ((kbd_inb(KBD_STATUS_REG) & KBD_STAT_OBF) != 0);
-const struct console_io
-vacuum_console_functions = {
- vacuum_putc,
- vacuum_getc,
- vacuum_tstc
-static const struct console_io
-log_console_functions = {
- log_putc,
- vacuum_getc,
- vacuum_tstc
-serial_console_functions = {
- serial_putc,
- serial_getc,
- serial_tstc
-#if defined(USE_KBD_SUPPORT) && defined(USE_VGA_SUPPORT)
-vga_console_functions = {
- vga_putc,
- kbd_getc,
- kbd_tstc
-#endif
-console_io* curIo = (console_io*) &vacuum_console_functions;
-int select_console(ioType t) {
- static ioType curType = CONSOLE_VACUUM;
- switch (t) {
- case CONSOLE_VACUUM : curIo = (console_io*)&vacuum_console_functions; break;
- case CONSOLE_LOG : curIo = (console_io*)&log_console_functions; break;
- case CONSOLE_SERIAL : curIo = (console_io*)&serial_console_functions; break;
- case CONSOLE_VGA : curIo = (console_io*)&vga_console_functions; break;
-#endif
- default : curIo = (console_io*)&vacuum_console_functions;break;
- if (curType == CONSOLE_LOG) flush_log();
- curType = t;
- return 0;
-/* we use this so that we can do without the ctype library */
-#define is_digit(c) ((c) >= '0' && (c) <= '9')
-/* provide this for the bootloader only; otherwise
- * use libcpu implementation
-#if defined(__BOOT__)
-static int skip_atoi(const char **s)
- int i=0;
- while (is_digit(**s))
- i = i*10 + *((*s)++) - '0';
- return i;
-/* Based on linux/lib/vsprintf.c and modified to suit our needs,
- * bloat has been limited since we basically only need %u, %x, %s and %c.
- * But we need 64 bit values !
-int k_vsprintf(char *buf, const char *fmt, va_list args);
-int printk(const char *fmt, ...) {
- va_list args;
- int i;
- /* Should not be a problem with 8kB of stack */
- char buf[1024];
- va_start(args, fmt);
- i = k_vsprintf(buf, fmt, args);
- va_end(args);
- puts(buf);
- return i;
-#endif
-/* Necessary to avoid including a library, and GCC won't do this inline. */
-#define div10(num, rmd) \
-do { u32 t1, t2, t3; \
- __asm__ ("lis %4,0xcccd; " \
- "addi %4,%4,0xffffcccd; " /* Build 0xcccccccd */ \
- "mulhwu %3,%0+1,%4; " /* (num.l*cst.l).h */ \
- "mullw %2,%0,%4; " /* (num.h*cst.l).l */ \
- "addc %3,%3,%2; " \
- "mulhwu %2,%0,%4; " /* (num.h*cst.l).h */ \
- "addi %4,%4,-1; " /* Build 0xcccccccc */ \
- "mullw %1,%0,%4; " /* (num.h*cst.h).l */ \
- "adde %2,%2,%1; " \
- "mulhwu %1,%0,%4; " /* (num.h*cst.h).h */ \
- "addze %1,%1; " \
- "mullw %0,%0+1,%4; " /* (num.l*cst.h).l */ \
- "addc %3,%3,%0; " \
- "mulhwu %0,%0+1,%4; " /* (num.l*cst.h).h */ \
- "adde %2,%2,%0; " \
- "addze %1,%1; " \
- "srwi %2,%2,3; " \
- "srwi %0,%1,3; " \
- "rlwimi %2,%1,29,0,2; " \
- "mulli %4,%2,10; " \
- "sub %4,%0+1,%4; " \
- "mr %0+1,%2; " : \
- "=r" (num), "=&r" (t1), "=&r" (t2), "=&r"(t3), "=&b" (rmd) : \
- "0" (num)); \
-} while(0);
-#define SIGN 1 /* unsigned/signed long */
-#define LARGE 2 /* use 'ABCDEF' instead of 'abcdef' */
-#define HEX 4 /* hexadecimal instead of decimal */
-#define ADDR 8 /* Value is an addres (p) */
-#define ZEROPAD 16 /* pad with zero */
-#define HALF 32
-#define LONG 64 /* long argument */
-#define LLONG 128 /* 64 bit argument */
-static char * number(char * str, int size, int type, u64 num)
- char fill,sign,tmp[24];
- const char *digits="0123456789abcdef";
- int i;
- if (type & LARGE)
- digits = "0123456789ABCDEF";
- fill = (type & ZEROPAD) ? '0' : ' ';
- sign = 0;
- if (type & SIGN) {
- if ((s64)num <0) {
- sign = '-';
- num = -num;
- size--;
- i = 0;
- do {
- unsigned rem;
- if (type&HEX) {
- rem = num & 0x0f;
- num >>=4;
- } else {
- div10(num, rem);
- tmp[i++] = digits[rem];
- } while (num != 0);
- size -= i;
- if (!(type&(ZEROPAD)))
- while(size-->0)
- *str++ = ' ';
- if (sign)
- *str++ = sign;
- while (size-- > 0)
- *str++ = fill;
- while (i-- > 0)
- *str++ = tmp[i];
- *str++ = ' ';
- return str;
- int len;
- u64 num;
- int i;
- char * str;
- const char *s;
- int flags; /* flags to number() and private */
- int field_width; /* width of output field */
- for (str=buf ; *fmt ; ++fmt) {
- if (*fmt != '%') {
- *str++ = *fmt;
- continue;
- /* process flags, only 0 padding needed */
- flags = 0;
- if (*++fmt == '0' ) {
- flags |= ZEROPAD;
- fmt++;
- /* get field width */
- field_width = -1;
- if (is_digit(*fmt))
- field_width = skip_atoi(&fmt);
- /* get the conversion qualifier */
- if (*fmt == 'h') {
- flags |= HALF;
- fmt++;
- } else if (*fmt == 'L') {
- flags |= LLONG;
- fmt++;
- } else if (*fmt == 'l') {
- flags |= LONG;
- fmt++;
- switch (*fmt) {
- case 'c':
- *str++ = (unsigned char) va_arg(args, int);
- while (--field_width > 0)
- *str++ = ' ';
- continue;
- case 's':
- s = va_arg(args, char *);
- len = strlen(s);
- for (i = 0; i < len; ++i)
- *str++ = *s++;
- while (len < field_width--)
- *str++ = ' ';
- continue;
- case 'p':
- if (field_width == -1) {
- field_width = 2*sizeof(void *);
- flags |= ZEROPAD|HEX|ADDR;
- break;
- case 'X':
- flags |= LARGE;
- case 'x':
- flags |= HEX;
- break;
- case 'd':
- case 'i':
- flags |= SIGN;
- case 'u':
- break;
- default:
- if (*fmt != '%')
- *str++ = '%';
- if (*fmt)
- *str++ = *fmt;
- else
- --fmt;
- continue;
- /* This ugly code tries to minimize the number of va_arg()
- * since they expand to a lot of code on PPC under the SYSV
- * calling conventions (but not with -mcall-aix which has
- * other problems). Arguments have at least the size of a
- * long allocated, and we use this fact to minimize bloat.
- * (and pointers are assimilated to unsigned long too).
- if (sizeof(long long) > sizeof(long) && flags & LLONG)
- num = va_arg(args, unsigned long long);
- else {
- u_long n = va_arg(args, unsigned long);
- if (flags & HALF) {
- if (flags & SIGN)
- n = (short) n;
- else
- n = (unsigned short) n;
- } else if (! flags & LONG) {
- /* Here the compiler correctly removes this
- * do nothing code on 32 bit PPC.
- if (flags & SIGN)
- n = (int) n;
- else
- n = (unsigned) n;
- if (flags & SIGN) num = (long) n; else num = n;
- str = number(str, field_width, flags, num);
- *str = '\0';
- return str-buf;
-#endif
-#endif
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/printk_support.c b/c/src/lib/libbsp/powerpc/ep1a/console/printk_support.c
index e5b75f4..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/printk_support.c
+++ /dev/null
@@ -1,49 +0,0 @@
- * This file contains the ep1a printk support routines.
- * COPYRIGHT (c) 2011-2014.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <bsp.h>
-#include <assert.h>
-#include <rtems/bspIo.h>
-rtems_device_minor_number BSPPrintkPort = 0;
-/* const char arg to be compatible with BSP_output_char decl. */
-static void debug_putc_onlcr(const char c)
- volatile int i;
- * Note: Hack to get printk to work. Depends upon bit
- * and silverchip to initialize the port and just
- * forces a character to be polled out of com1
- * regardless of where the console is.
- volatile unsigned char *ptr = (void *)0xff800000;
- if ('\n'==c){
- *ptr = '\r';
- for (i=0;i<0x0fff;i++);
- *ptr = c;
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.c b/c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.c
index deee170..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.c
+++ /dev/null
@@ -1,402 +0,0 @@
-/* rsPMCQ1.c - Radstone PMCQ1 Common Initialisation Code
- * Copyright 2000 Radstone Technology
- * THIS FILE IS PROVIDED TO YOU, THE USER, "AS IS", WITHOUT WARRANTY OF ANY
- * KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK
- * AS TO THE QUALITY AND PERFORMANCE OF ALL CODE IN THIS FILE IS WITH YOU.
- * You are hereby granted permission to use, copy, modify, and distribute
- * this file, provided that this notice, plus the above copyright notice
- * and disclaimer, appears in all copies. Radstone Technology will provide
- * no support for this code.
- * COPYRIGHT (c) 2005.
-DESCRIPTION
-These functions are responsible for scanning for PMCQ1's and setting up
-the Motorola MC68360's if present.
-USAGE
-call rsPMCQ1Init() to perform ba sic initialisation of the PMCQ1's.
-/* includes */
-#include <libcpu/io.h>
-#include <bsp.h>
-#include "rsPMCQ1.h"
-#include "m68360.h"
-/* defines */
-#if 1
-#define DEBUG_360
-#endif
-/* Local data */
-PPMCQ1BoardData pmcq1BoardData = NULL;
-static unsigned char rsPMCQ1Initialized = FALSE;
-/* forward declarations */
-static void MsDelay(void)
- printk(".");
-static void write8( int addr, int data ){
- out_8((uint8_t *)addr, (uint8_t)data);
-static void write16( int addr, int data ) {
- out_be16((uint16_t *)addr, (uint16_t)data );
-static void write32( int addr, int data ) {
- out_be32((uint32_t *)addr, (uint32_t)data );
-static void rsPMCQ1_scc_nullFunc(void) {}
-* rsPMCQ1Int - handle a PMCQ1 interrupt
-* This routine gets called when the QUICC or MA causes
-* an interrupt.
-* RETURNS: NONE.
-static void rsPMCQ1Int( void *ptr )
- unsigned long status;
- unsigned long status1;
- unsigned long mask;
- uint32_t data;
- PPMCQ1BoardData boardData = ptr;
- status = PMCQ1_Read_EPLD(boardData->baseaddr, PMCQ1_INT_STATUS );
- mask = PMCQ1_Read_EPLD(boardData->baseaddr, PMCQ1_INT_MASK );
- if (((mask & PMCQ1_INT_MASK_QUICC) == 0) && (status & PMCQ1_INT_STATUS_QUICC))
- /* If there is a handler call it otherwise mask the interrupt */
- if (boardData->quiccInt) {
- boardData->quiccInt(boardData->quiccArg);
- } else {
- *(volatile unsigned long *)(boardData->baseaddr + PMCQ1_INT_MASK) |= PMCQ1_INT_MASK_QUICC;
- if (((mask & PMCQ1_INT_MASK_MA) == 0) && (status & PMCQ1_INT_STATUS_MA))
- if (boardData->maInt) {
- boardData->maInt(boardData->maArg);
- data = PMCQ1_Read_EPLD(boardData->baseaddr, PMCQ1_INT_STATUS );
- data &= (~PMCQ1_INT_STATUS_MA);
- PMCQ1_Write_EPLD(boardData->baseaddr, PMCQ1_INT_STATUS, data );
- } else {
- *(volatile unsigned long *)(boardData->baseaddr + PMCQ1_INT_MASK) |= PMCQ1_INT_MASK_MA;
- RTEMS_COMPILER_MEMORY_BARRIER();
- /* Clear Interrupt on QSPAN */
- *(volatile unsigned long *)(boardData->bridgeaddr + 0x600) = 0x00001000;
- /* read back the status register to ensure that the pci write has completed */
- status1 = *(volatile unsigned long *)(boardData->bridgeaddr + 0x600);
- (void) status1; /* avoid set but not used warning */
-* rsPMCQ1MaIntConnect - connect a MiniAce interrupt routine
-* This routine is called to connect a MiniAce interrupt handler
-* upto a PMCQ1.
-* RETURNS: OK if PMCQ1 found, ERROR if not.
-unsigned int rsPMCQ1MaIntConnect (
- unsigned long busNo, /* Pci Bus number of PMCQ1 */
- unsigned long slotNo, /* Pci Slot number of PMCQ1 */
- unsigned long funcNo, /* Pci Function number of PMCQ1 */
- FUNCTION_PTR routine,/* interrupt routine */
- uintptr_t arg /* argument to pass to interrupt routine */
- PPMCQ1BoardData boardData;
- uint32_t data;
- unsigned int status = RTEMS_IO_ERROR;
- for (boardData = pmcq1BoardData; boardData; boardData = boardData->pNext)
- if ((boardData->busNo == busNo) && (boardData->slotNo == slotNo) &&
- (boardData->funcNo == funcNo))
- boardData->maInt = routine;
- boardData->maArg = arg;
- data = PMCQ1_Read_EPLD(boardData->baseaddr, PMCQ1_INT_MASK );
- data &= (~PMCQ1_INT_MASK_MA);
- PMCQ1_Write_EPLD(boardData->baseaddr, PMCQ1_INT_MASK, data );
- status = RTEMS_SUCCESSFUL;
- break;
- return (status);
-* rsPMCQ1QuiccIntConnect - connect a Quicc interrupt routine
-* This routine is called to connect a Quicc interrupt handler
-* upto a PMCQ1.
-unsigned int rsPMCQ1QuiccIntConnect(
- boardData->quiccInt = routine;
- boardData->quiccArg = arg;
- break;
- return (status);
-* rsPMCQ1Init - initialize the PMCQ1's
-* This routine is called to initialize the PCI card to a quiescent state.
-unsigned int rsPMCQ1Init(void)
- int busNo;
- int slotNo;
- uint32_t baseaddr = 0;
- uint32_t bridgeaddr = 0;
- unsigned long pbti0_ctl;
- int i;
- unsigned char int_vector;
- int fun;
- uint32_t temp;
- rtems_irq_connect_data IrqData = {
- .name = 0,
- .hdl = rsPMCQ1Int,
- .handle = NULL,
- .on = (rtems_irq_enable) rsPMCQ1_scc_nullFunc,
- .off = (rtems_irq_disable) rsPMCQ1_scc_nullFunc,
- .isOn = (rtems_irq_is_enabled) rsPMCQ1_scc_nullFunc,
- if (rsPMCQ1Initialized)
- for (i=0;;i++){
- if ( pci_find_device(PCI_VEN_ID_RADSTONE, PCI_DEV_ID_PMCQ1, i, &busNo, &slotNo, &fun) != 0 )
- break;
- pci_read_config_dword(busNo, slotNo, 0, PCI_BASE_ADDRESS_2, &baseaddr);
- pci_read_config_dword(busNo, slotNo, 0, PCI_BASE_ADDRESS_0, &bridgeaddr);
-#ifdef DEBUG_360
- printk("PMCQ1 baseaddr 0x%08x bridgeaddr 0x%08x\n", baseaddr, bridgeaddr );
-#endif
- /* Set function code to normal mode and enable window */
- pbti0_ctl = *(unsigned long *)(bridgeaddr + 0x100) & 0xff0fffff;
- eieio();
- *(unsigned long *)(bridgeaddr + 0x100) = pbti0_ctl | 0x00500080;
- eieio();
- /* Assert QBUS reset */
- *(unsigned long *)(bridgeaddr + 0x800) |= 0x00000080;
- eieio();
- * Hold QBus in reset for 1ms
- MsDelay();
- /* Take QBUS out of reset */
- *(unsigned long *)(bridgeaddr + 0x800) &= ~0x00000080;
- eieio();
- MsDelay();
- /* If a QUICC is fitted initialise it */
- if (PMCQ1_Read_EPLD(baseaddr, PMCQ1_BUILD_OPTION) & PMCQ1_QUICC_FITTED)
-#ifdef DEBUG_360
- printk(" Found QUICC busNo %d slotNo %d\n", busNo, slotNo);
-#endif
- /* Initialise MBAR (must use function code of 7) */
- *(unsigned long *)(bridgeaddr + 0x100) = pbti0_ctl | 0x00700080;
- eieio();
- /* place internal 8K SRAM and registers at address 0x0 */
- *(unsigned long *)(baseaddr + Q1_360_MBAR) = 0x1;
- eieio();
- /* Set function code to normal mode */
- eieio();
- /* Disable the SWT and perform basic initialisation */
- write8(baseaddr+Q1_360_SIM_SYPCR,0);
- eieio();
- write32(baseaddr+Q1_360_SIM_MCR,0xa0001029);
- write16(baseaddr+Q1_360_SIM_PICR,0);
- write16(baseaddr+Q1_360_SIM_PITR,0);
- write16(baseaddr+Q1_360_CPM_ICCR,0x770);
- write16(baseaddr+Q1_360_CPM_SDCR,0x770);
- write32(baseaddr+Q1_360_CPM_CICR,0x00e49f00);
- write16(baseaddr+Q1_360_SIM_PEPAR,0x2080);
- eieio();
- /* Enable SRAM */
- write32(baseaddr+Q1_360_SIM_GMR,0x00001000); /* external master wait state */
- eieio();
- write32(baseaddr+Q1_360_SIM_OR0,0x1ff00000); /*| MEMC_OR_FC*/
- eieio();
- write32(baseaddr+Q1_360_SIM_BR0,0);
- eieio();
- write32(baseaddr+Q1_360_SIM_OR1,(0x5ff00000 | 0x00000780)); /*| MEMC_OR_FC*/
- eieio();
- write32(baseaddr+Q1_360_SIM_BR1,(0x00000040 | 0x00000001 | 0x00200280) );
- eieio();
- * If a second PCI window is present then make it opposite
- * endian to simplify 1553 integration.
- pci_read_config_dword(busNo, slotNo, 0, PCI_BASE_ADDRESS_3, &temp);
- if (temp) {
- *(unsigned long *)(bridgeaddr + 0x110) |= 0x00500880;
- * Create descriptor structure for this card
- if ((boardData = malloc(sizeof(struct _PMCQ1BoardData))) == NULL)
- printk("Error Unable to allocate memory for _PMCQ1BoardData\n");
- return(RTEMS_IO_ERROR);
- boardData->pNext = pmcq1BoardData;
- boardData->busNo = busNo;
- boardData->slotNo = slotNo;
- boardData->funcNo = 0;
- boardData->baseaddr = baseaddr;
- boardData->bridgeaddr = bridgeaddr;
- boardData->quiccInt = NULL;
- boardData->maInt = NULL;
- pmcq1BoardData = boardData;
- mc68360_scc_create_chip( boardData, int_vector );
- * Connect PMCQ1 interrupt handler.
- pci_read_config_byte(busNo, slotNo, 0, 0x3c, &int_vector);
-#ifdef DEBUG_360
- printk("PMCQ1 int_vector %d\n", int_vector);
-#endif
- IrqData.name = ((unsigned int)BSP_PCI_IRQ0 + int_vector);
- IrqData.handle = boardData;
- if (!BSP_install_rtems_shared_irq_handler (&IrqData)) {
- printk("Error installing interrupt handler!\n");
- rtems_fatal_error_occurred(1);
- * Enable PMCQ1 Interrupts from QSPAN-II
- *(unsigned long *)(bridgeaddr + 0x600) = 0x00001000;
- eieio();
- *(unsigned long *)(bridgeaddr + 0x604) |= 0x00001000;
- eieio();
- if (i > 0)
- rsPMCQ1Initialized = TRUE;
- return((i > 0) ? RTEMS_SUCCESSFUL : RTEMS_IO_ERROR);
-uint32_t PMCQ1_Read_EPLD( uint32_t base, uint32_t reg )
- uint32_t data;
- data = ( *((unsigned long *) (base + reg)) );
-#ifdef DEBUG_360
- printk("EPLD Read 0x%x: 0x%08x\n", reg + base, data );
-#endif
- return data;
-void PMCQ1_Write_EPLD( uint32_t base, uint32_t reg, uint32_t data )
- *((unsigned long *) (base + reg)) = data;
-#ifdef DEBUG_360
- printk("EPLD Write 0x%x: 0x%08x\n", reg+base, data );
-#endif
diff --git a/c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.h b/c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.h
index c0c0924..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/console/rsPMCQ1.h
+++ /dev/null
@@ -1,163 +0,0 @@
-/* rsPMCQ1.h - Radstone PMCQ1 private header
- modification history
- 01a,20Dec00,jpb created
-#ifndef __INCPMCQ1H
-#define __INCPMCQ1H
- * PMCQ1 definitions
- * 360 definitions
-#define Q1_360_MBAR 0x0003ff00 /* master base address register */
-#define REG_B_OFFSET 0x1000 /* offset to the internal registers */
-#define Q1_360_SIM_MCR (REG_B_OFFSET+0x00)
-#define Q1_360_SIM_PEPAR (REG_B_OFFSET+0x16)
-#define Q1_360_SIM_SYPCR (REG_B_OFFSET+0x22)
-#define Q1_360_SIM_PICR (REG_B_OFFSET+0x26)
-#define Q1_360_SIM_PITR (REG_B_OFFSET+0x2A)
-#define Q1_360_SIM_GMR (REG_B_OFFSET+0x40)
-#define Q1_360_SIM_BR0 (REG_B_OFFSET+0x50)
-#define Q1_360_SIM_OR0 (REG_B_OFFSET+0x54)
-#define Q1_360_SIM_BR1 (REG_B_OFFSET+0x60)
-#define Q1_360_SIM_OR1 (REG_B_OFFSET+0x64)
-#define Q1_360_CPM_ICCR (REG_B_OFFSET+0x500)
-#define Q1_360_CPM_SDCR (REG_B_OFFSET+0x51E)
-#define Q1_360_CPM_CICR (REG_B_OFFSET+0x540)
- * EPLD offsets
- * Only top 4 data bits are used
-#define PMCQ1_CODE_VERSION 0x00040000 /* Code Version */
-#define PMCQ1_BOARD_REVISION 0x00040004 /* Board Revision */
-#define PMCQ1_BUILD_OPTION 0x00040008 /* Build Option */
-#define PMCQ1_ACE_FITTED 0x80000000
-#define PMCQ1_QUICC_FITTED 0x40000000
-#define PMCQ1_SRAM_SIZE 0x30000000 /* 01 - 1MB */
-#define PMCQ1_SRAM_FITTED 0x20000000
-#define PMCQ1_INT_STATUS 0x0004000c /* Interrupt Status */
-#define PMCQ1_INT_STATUS_MA 0x20000000
-#define PMCQ1_INT_STATUS_QUICC 0x10000000
-#define PMCQ1_INT_MASK 0x00040010 /* Interrupt Mask */
-#define PMCQ1_INT_MASK_QUICC 0x20000000
-#define PMCQ1_INT_MASK_MA 0x10000000
-#define PMCQ1_RT_ADDRESS 0x00040014 /* RT Address Latch */
-#define PMCQ1_DRIVER_ENABLE 0x0004001c /* Channel Drive Enable */
-#define PMCQ1_DRIVER_ENABLE_3 0x80000000
-#define PMCQ1_DRIVER_ENABLE_2 0x40000000
-#define PMCQ1_DRIVER_ENABLE_1 0x20000000
-#define PMCQ1_DRIVER_ENABLE_0 0x10000000
-#define PMCQ1_MINIACE_REGS 0x000c0000
-#define PMCQ1_MINIACE_MEM 0x00100000
-#define PMCQ1_RAM 0x00200000
-#define PMCQ1_Read_EPLD( _base, _reg ) ( *((unsigned long *) ((unsigned32)_base + _reg)) )
-#define PMCQ1_Write_EPLD( _base, _reg, _data ) *((unsigned long *) ((unsigned32)_base + _reg)) = _data
-uint32_t PMCQ1_Read_EPLD( uint32_t base, uint32_t reg );
-void PMCQ1_Write_EPLD( uint32_t base, uint32_t reg, uint32_t data );
- * QSPAN-II register offsets
-#define QSPAN2_INT_STATUS 0x00000600
-typedef void (*FUNCTION_PTR) (int);
-#define PCI_ID(v, d) ((d << 16) | v)
-#define PCI_VEN_ID_RADSTONE 0x11b5
-#define PCI_DEV_ID_PMC1553 0x0001
-#define PCI_DEV_ID_PMCF1 0x0002
-#define PCI_DEV_ID_PMCMMA 0x0003
-#define PCI_DEV_ID_PMCQ1 0x0007
-#define PCI_DEV_ID_PMCQ2 0x0008
-#define PCI_DEV_ID_PMCF1V2 0x0012
-typedef struct _PMCQ1BoardData
- struct _PMCQ1BoardData *pNext;
- unsigned long busNo;
- unsigned long slotNo;
- unsigned long funcNo;
- unsigned long baseaddr;
- unsigned long bridgeaddr;
- FUNCTION_PTR quiccInt;
- uintptr_t quiccArg;
- FUNCTION_PTR maInt;
- uintptr_t maArg;
-} PMCQ1BoardData, *PPMCQ1BoardData;
-extern PPMCQ1BoardData pmcq1BoardData;
- * Function declarations
-extern unsigned int rsPMCQ1QuiccIntConnect(
- uintptr_t arg
-unsigned int rsPMCQ1Init(void);
-#endif /* __INCPMCQ1H */
diff --git a/c/src/lib/libbsp/powerpc/ep1a/include/bsp.h b/c/src/lib/libbsp/powerpc/ep1a/include/bsp.h
index d989785..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/include/bsp.h
+++ /dev/null
@@ -1,209 +0,0 @@
- * COPYRIGHT (c) 1989-2008.
-#ifndef LIBBSP_POWERPC_EP1A_BSP_H
-#define LIBBSP_POWERPC_EP1A_BSP_H
-#include <bspopts.h>
-#include <bsp/default-initial-extension.h>
-#include <rtems.h>
-#include <rtems/console.h>
-#include <rtems/clockdrv.h>
-#include <bsp/vectors.h>
-/* fundamental addresses for BSP (CHRPxxx and PREPxxx are from libcpu/io.h) */
-#define _IO_BASE CHRP_ISA_IO_BASE
-#define _ISA_MEM_BASE CHRP_ISA_MEM_BASE
-/* address of our ram on the PCI bus */
-#define PCI_DRAM_OFFSET CHRP_PCI_DRAM_OFFSET
-#define PCI_MEM_BASE 0x80000000
-#define PCI_MEM_BASE_ADJUSTMENT 0
-/* offset of pci memory as seen from the CPU */
-#undef PCI_MEM_BASE
-#define PCI_MEM_BASE 0x00000000
-/* Override the default values for the following DEFAULT */
-#define PCI_CONFIG_ADDR 0xfec00000 /* 0xcf8 */
-#define PCI_CONFIG_DATA 0xfee00000 /* 0xcfc */
- * EP1A configuration Registers.
- * Note: All addresses assume flash boot.
-#define EQUIPMENT_PRESENT_REGISTER1 ((volatile unsigned char *)0xffa00000)
-#define EQUIPMENT_PRESENT_REGISTER2 ((volatile unsigned char *)0xffa00008)
-#define BOARD_REVISION_REGISTER1 ((volatile unsigned char *)0xffa00010)
-#define BOARD_REVISION_REGISTER2 ((volatile unsigned char *)0xffa00018)
-#define GENERAL_REGISTER1 ((volatile unsigned char *)0xffa00020)
-#define GENERAL_REGISTER2 ((volatile unsigned char *)0xffa00028)
-#define WATCHDOG_TRIGGER ((volatile unsigned char *)0xffa00030)
-/* EQUIPMENT_PRESENT_REGISTER1 */
-#define BANK_MEMORY_SIZE_128MB 0x20
-#define BANK_MEMORY_SIZE_64MB 0x10
-#define ECC_ENABLED 0x04
-/* EQUIPMENT-PRESENT_REGISTER2 */
-#define PLL_CFG_MASK 0xf8
-#define MHZ_33_66_200 0x70 /* PCI MEM CPU Frequency */
-#define MHZ_33_100_200 0x80 /* PCI MEM CPU Frequency */
-#define MHZ_33_66_266 0xb0 /* PCI MEM CPU Frequency */
-#define MHZ_33_66_333 0x50 /* PCI MEM CPU Frequency */
-#define MHZ_33_100_333 0x08 /* PCI MEM CPU Frequency */
-#define MHZ_33_100_350 0x78 /* PCI MEM CPU Frequency */
-#define PMC_SLOT1_PRESENT 0x02
-#define PMC_SLOT2_PRESENT 0x01
-/* BOARD_REVISION_REGISTER1 */
-#define ARTWORK_REVISION_MASK 0xf0
-#define BUILD_REVISION_MASK 0x0f
-/* BOARD_REVISION_REGISTER2 */
-#define HARDWARE_ID_MASK 0xe0
-#define HARDWARE_ID_PPC5_EP1A 0xe0
-#define HARDWARE_ID_EP1B 0xc0
-/* GENERAL_REGISTER1 */
-#define DISABLE_WATCHDOG 0x80
-#define DISABLE_RESET_SWITCH 0x40
-#define DISABLE_USER_FLASH 0x20
-#define DISABLE_BOOT_FLASH 0x10
-#define LED4_OFF 0x08
-#define LED3_OFF 0x04
-#define LED2_OFF 0x02
-#define LED1_OFF 0x01
-/* GENERAL_REGISTER2 */
-#define BSP_FLASH_VPP_ENABLE 0x01
-#define BSP_FLASH_PAGE_MASK 0x38
-#define BSP_FLASH_PAGE_SHIFT 0x03
-#define BSP_BIT_SLOWSTART 0x04
-#define BSP_OFFLINE 0x02
-#define BSP_SYSFAIL 0x01
-/* WATCHDOG_TRIGGER */
-#define BSP_FLASH_BASE 0xff000000
-#define BSP_VME_A16_BASE 0x9fff0000
-#define BSP_VME_A24_BASE 0x9f000000
- * address definitions for several devices
-#define UART_OFFSET_1_8245 (0x04500)
-#define UART_OFFSET_2_8245 (0x04600)
-#define UART_BASE_COM1 0xff800000
-#define UART_BASE_COM2 0xff800040
-#include <bsp/openpic.h>
-/* Note docs list 0x41000 but OpenPIC has a 0x1000 pad at the start
- * assume that open pic specifies this pad but not mentioned in
- * 8245 docs.
- * This is an offset from EUMBBAR
-#define BSP_OPEN_PIC_BASE_OFFSET 0x40000
-/* BSP_PIC_DO_EOI is optionally used by the 'vmeUniverse' driver
- * to implement VME IRQ priorities in software.
- * Note that this requires support by the interrupt controller
- * driver (cf. libbsp/shared/powerpc/irq/openpic_i8259_irq.c)
- * and the BSP-specific universe initialization/configuration
- * (cf. libbsp/shared/powerpc/vme/VMEConfig.h vme_universe.c)
- * ********* IMPORTANT NOTE ********
- * When deriving from this file (new BSPs)
- * DO NOT define "BSP_PIC_DO_EOI" if you don't know what
- * you are doing i.e., w/o implementing the required pieces
- * mentioned above.
-#define BSP_PIC_DO_EOI openpic_eoi(0)
-#ifndef ASM
-#define outport_byte(port,value) outb(value,port)
-#define outport_word(port,value) outw(value,port)
-#define outport_long(port,value) outl(value,port)
-#define inport_byte(port,value) (value = inb(port))
-#define inport_word(port,value) (value = inw(port))
-#define inport_long(port,value) (value = inl(port))
- * EUMMBAR
-extern unsigned int EUMBBAR;
- * Total memory
-extern unsigned int BSP_mem_size;
- * PCI Bus Frequency
-extern unsigned int BSP_bus_frequency;
- * processor clock frequency
-extern unsigned int BSP_processor_frequency;
- * Time base divisior (how many tick for 1 second).
-extern unsigned int BSP_time_base_divisor;
-#define BSP_Convert_decrementer( _value ) \
- ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value)))
-#define Processor_Synchronize() \
- __asm__ (" eieio ")
-extern void BSP_panic(char *s);
-extern int BSP_disconnect_clock_handler (void);
-extern int BSP_connect_clock_handler (void);
- * FLASH
-int BSP_FLASH_Enable_writes( uint32_t area );
-int BSP_FLASH_Disable_writes( uint32_t area );
-void BSP_FLASH_set_page( uint8_t page );
-#define BSP_FLASH_ENABLE_WRITES( _area) BSP_FLASH_Enable_writes( _area )
-#define BSP_FLASH_DISABLE_WRITES(_area) BSP_FLASH_Disable_writes( _area )
-#define BSP_FLASH_SET_PAGE(_page) BSP_FLASH_set_page( _page )
-/* clear hostbridge errors
- * enableMCP: whether to enable MCP checkstop / machine check interrupts
- * on the hostbridge and in HID0.
- * NOTE: HID0 and MEREN are left alone if this flag is 0
- * quiet : be silent
- * RETURNS : raven MERST register contents (lowermost 16 bits), 0 if
- * there were no errors
-extern unsigned long _BSP_clear_hostbridge_errors(int enableMCP, int quiet);
-#endif
-#endif
diff --git a/c/src/lib/libbsp/powerpc/ep1a/include/tm27.h b/c/src/lib/libbsp/powerpc/ep1a/include/tm27.h
index 8f819a5..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/include/tm27.h
+++ /dev/null
@@ -1,64 +0,0 @@
- * @file
- * @ingroup powerpc_ep1a
- * @brief Implementations for interrupt mechanisms for Time Test 27
- * COPYRIGHT (c) 1989-2014.
-#ifndef _RTEMS_TMTEST27
-#error "This is an RTEMS internal file you must not include directly."
-#endif
-#ifndef __tm27_h
-#define __tm27_h
-#include <bsp/irq.h>
-#define MUST_WAIT_FOR_INTERRUPT 1
-void nullFunc() {}
-static rtems_irq_connect_data clockIrqData = {BSP_DECREMENTER,
- 0,
- (rtems_irq_enable)nullFunc,
- (rtems_irq_disable)nullFunc,
- (rtems_irq_is_enabled) nullFunc};
-void Install_tm27_vector(void (*_handler)())
- clockIrqData.hdl = _handler;
- if (!BSP_install_rtems_irq_handler (&clockIrqData)) {
- printk("Error installing clock interrupt handler!\n");
-#define Cause_tm27_intr() \
- do { \
- uint32_t _clicks = 8; \
- __asm__ volatile( "mtdec %0" : "=r" ((_clicks)) : "r" ((_clicks)) ); \
- } while (0)
-#define Clear_tm27_intr() \
- do { \
- uint32_t _clicks = 0xffffffff; \
- } while (0)
-#define Lower_tm27_intr() \
- do { \
- uint32_t _msr = 0; \
- _ISR_Set_level( 0 ); \
- __asm__ volatile( "mfmsr %0 ;" : "=r" (_msr) : "r" (_msr) ); \
- _msr |= 0x8002; \
- __asm__ volatile( "mtmsr %0 ;" : "=r" (_msr) : "r" (_msr) ); \
- } while (0)
-#endif
diff --git a/c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c b/c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c
index cba05a4..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/irq/irq_init.c
+++ /dev/null
@@ -1,216 +0,0 @@
- * This file contains the implementation of rtems initialization
- * related to interrupt handling.
- * CopyRight (C) 1999 valette at crf.canon.fr
- * Enhanced by Jay Kulpinski <jskulpin at eng01.gdds.com>
- * to make it valid for MVME2300 Motorola boards.
- * Till Straumann <strauman at slac.stanford.edu>, 12/20/2001:
- * Use the new interface to openpic_init
-#include <bsp/pci.h>
-#include <bsp/residual.h>
-#include <bsp.h>
-#include <bsp/motorola.h>
-#define SHOW_ISA_PCI_BRIDGE_SETTINGS
-#define TRACE_IRQ_INIT
-static void IRQ_Default_rtems_irq_hdl(
- rtems_irq_hdl_param ptr
-static void IRQ_Default_rtems_irq_enable(
- const struct __rtems_irq_connect_data__ *ptr
-static void IRQ_Default_rtems_irq_disable(
-static int IRQ_Default_rtems_irq_is_enabled(
- const struct __rtems_irq_connect_data__ *ptr)
- return 1;
-static rtems_irq_connect_data rtemsIrq[BSP_IRQ_NUMBER];
-static rtems_irq_global_settings initial_config;
-static rtems_irq_connect_data defaultIrq = {
- .name = 0,
- .hdl = IRQ_Default_rtems_irq_hdl,
- .handle = NULL,
- .on = IRQ_Default_rtems_irq_enable,
- .on = IRQ_Default_rtems_irq_disable,
- .isOn = IRQ_Default_rtems_irq_is_enabled
-static rtems_irq_prio irqPrioTable[BSP_IRQ_NUMBER]={
- * actual rpiorities for interrupt :
- * 0 means that only current interrupt is masked
- * 255 means all other interrupts are masked
- * ISA interrupts.
- * The second entry has a priority of 255 because
- * it is the slave pic entry and is should always remain
- * unmasked.
- 0,0,
- 255,
- 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
- * PCI Interrupts
- 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, 8, /* for raven prio 0 means unactive... */
- * Processor exceptions handled as interrupts
- 0
-static unsigned char mcp750_openpic_initpolarities[] = {
- 1, /* 0 8259 cascade */
- 0, /* 1 all the rest of them */
- 0, /* 2 all the rest of them */
- 0, /* 3 all the rest of them */
- 0, /* 4 all the rest of them */
- 0, /* 5 all the rest of them */
- 0, /* 6 all the rest of them */
- 0, /* 7 all the rest of them */
- 0, /* 8 all the rest of them */
- 0, /* 9 all the rest of them */
- 0, /* 10 all the rest of them */
- 0, /* 11 all the rest of them */
- 0, /* 12 all the rest of them */
- 0, /* 13 all the rest of them */
- 0, /* 14 all the rest of them */
- 0, /* 15 all the rest of them */
- 0, /* 16 all the rest of them */
- 0, /* 17 all the rest of them */
- 1, /* 18 all the rest of them */
- 1, /* 19 all the rest of them */
- 1, /* 20 all the rest of them */
- 1, /* 21 all the rest of them */
- 1, /* 22 all the rest of them */
- 1, /* 23 all the rest of them */
- 1, /* 24 all the rest of them */
- 1, /* 25 all the rest of them */
-static unsigned char mcp750_openpic_initsenses[] = {
- 1, /* 0 MCP750_INT_PCB(8259) */
- 0, /* 1 MCP750_INT_FALCON_ECC_ERR */
- 1, /* 2 MCP750_INT_PCI_ETHERNET */
- 1, /* 3 MCP750_INT_PCI_PMC */
- 1, /* 4 MCP750_INT_PCI_WATCHDOG_TIMER1 */
- 1, /* 5 MCP750_INT_PCI_PRST_SIGNAL */
- 1, /* 6 MCP750_INT_PCI_FALL_SIGNAL */
- 1, /* 7 MCP750_INT_PCI_DEG_SIGNAL */
- 1, /* 8 MCP750_INT_PCI_BUS1_INTA */
- 1, /* 9 MCP750_INT_PCI_BUS1_INTB */
- 1, /*10 MCP750_INT_PCI_BUS1_INTC */
- 1, /*11 MCP750_INT_PCI_BUS1_INTD */
- 1, /*12 MCP750_INT_PCI_BUS2_INTA */
- 1, /*13 MCP750_INT_PCI_BUS2_INTB */
- 1, /*14 MCP750_INT_PCI_BUS2_INTC */
- 1, /*15 MCP750_INT_PCI_BUS2_INTD */
- 1,
- 1,
- 1,
- 1,
- 1,
- 1,
- 1,
- 1,
- 1,
- 1
- * This code assumes the exceptions management setup has already
- * been done. We just need to replace the exceptions that will
- * be handled like interrupt. On mcp750/mpc750 and many PPC processors
- * this means the decrementer exception and the external exception.
-void BSP_rtems_irq_mng_init(unsigned cpuId)
- int i;
- * First initialize the Interrupt management hardware
-#ifdef TRACE_IRQ_INIT
- printk("Going to initialize openpic compliant device\n");
-#endif
- /* FIXME (t.s.): we should probably setup the EOI delay by
- * passing a non-zero 'epic_freq' argument (frequency of the
- * EPIC serial interface) but I don't know the value on this
- * board (8245 SDRAM freq, IIRC)...
- openpic_init(1, mcp750_openpic_initpolarities, mcp750_openpic_initsenses, 0, 16, 0 /* epic_freq */);
- printk("Going to initialize the PCI/ISA bridge IRQ related setting (VIA 82C586)\n");
-#endif
- * Initialize Rtems management interrupt table
- * re-init the rtemsIrq table
- for (i = 0; i < BSP_IRQ_NUMBER; i++) {
- rtemsIrq[i] = defaultIrq;
- rtemsIrq[i].name = i;
- * Init initial Interrupt management config
- initial_config.irqNb = BSP_IRQ_NUMBER;
- initial_config.defaultEntry = defaultIrq;
- initial_config.irqHdlTbl = rtemsIrq;
- initial_config.irqBase = BSP_LOWEST_OFFSET;
- initial_config.irqPrioTbl = irqPrioTable;
-printk("Call BSP_rtems_irq_mngt_set\n");
- if (!BSP_rtems_irq_mngt_set(&initial_config)) {
- * put something here that will show the failure...
- BSP_panic("Unable to initialize RTEMS interrupt Management!!! System locked\n");
- printk("RTEMS IRQ management is now operationnal\n");
-#endif
diff --git a/c/src/lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c b/c/src/lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c
index 23b1ce2..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/irq/openpic_xxx_irq.c
+++ /dev/null
@@ -1,234 +0,0 @@
- * This file contains the i8259/openpic-specific implementation of
- * the function described in irq.h
- * Copyright (C) 1998, 1999 valette at crf.canon.fr
-#include <stdlib.h>
-#include <bsp.h>
-#include <bsp/irq_supp.h>
-#include <bsp/VMEConfig.h>
-#include <rtems/bspIo.h> /* for printk */
-#define RAVEN_INTR_ACK_REG 0xfeff0030
-#ifdef BSP_PCI_ISA_BRIDGE_IRQ
- * pointer to the mask representing the additionnal irq vectors
- * that must be disabled when a particular entry is activated.
- * They will be dynamically computed from the priority table given
- * in BSP_rtems_irq_mngt_set();
- * CAUTION : this table is accessed directly by interrupt routine
- * prologue.
-rtems_i8259_masks irq_mask_or_tbl[BSP_IRQ_NUMBER];
-#endif
- * default handler connected on each irq after bsp initialization
-static rtems_irq_connect_data default_rtems_entry;
-static rtems_irq_connect_data* rtems_hdl_tbl;
- * Check if IRQ is an ISA IRQ
-static inline int is_isa_irq(const rtems_irq_number irqLine)
- return (((int) irqLine <= BSP_ISA_IRQ_MAX_OFFSET) &
- ((int) irqLine >= BSP_ISA_IRQ_LOWEST_OFFSET)
-#endif
- * Check if IRQ is an OPENPIC IRQ
-static inline int is_pci_irq(const rtems_irq_number irqLine)
- return (((int) irqLine <= BSP_PCI_IRQ_MAX_OFFSET) &
- ((int) irqLine >= BSP_PCI_IRQ_LOWEST_OFFSET)
- * ------------------------ RTEMS Irq helper functions ----------------
-void
-BSP_enable_irq_at_pic(const rtems_irq_number name)
- if (is_isa_irq(name)) {
- * Enable interrupt at PIC level
-printk("ERROR BSP_irq_enable_at_i8259s Being Called for %d\n", (int)name);
- BSP_irq_enable_at_i8259s ((int) name);
-#endif
- if (is_pci_irq(name)) {
- * Enable interrupt at OPENPIC level
-printk(" openpic_enable_irq %d\n", (int)name );
- openpic_enable_irq ((int) name);
-int
-BSP_disable_irq_at_pic(const rtems_irq_number name)
- * disable interrupt at PIC level
- return BSP_irq_disable_at_i8259s ((int) name);
-#endif
- * disable interrupt at OPENPIC level
- return openpic_disable_irq ((int) name );
- return -1;
- * RTEMS Global Interrupt Handler Management Routines
-int BSP_setup_the_pic(rtems_irq_global_settings* config)
- int i;
- * Store various code accelerators
- default_rtems_entry = config->defaultEntry;
- rtems_hdl_tbl = config->irqHdlTbl;
- * continue with PCI IRQ
- for (i=BSP_PCI_IRQ_LOWEST_OFFSET; i < BSP_PCI_IRQ_LOWEST_OFFSET + BSP_PCI_IRQ_NUMBER ; i++) {
- * Note that openpic_set_priority() sets the TASK priority of the PIC
- openpic_set_source_priority(i - BSP_PCI_IRQ_LOWEST_OFFSET,
- config->irqPrioTbl[i]);
- if (rtems_hdl_tbl[i].hdl != default_rtems_entry.hdl) {
- openpic_enable_irq ((int) i );
- else {
- openpic_disable_irq ((int) i );
- if ( BSP_ISA_IRQ_NUMBER > 0 ) {
- * Must enable PCI/ISA bridge IRQ
- openpic_enable_irq (0);
-#endif
- return 1;
-int _BSP_vme_bridge_irq = -1;
-unsigned BSP_spuriousIntr = 0;
- * High level IRQ handler called from shared_raw_irq_code_entry
-int C_dispatch_irq_handler (BSP_Exception_frame *frame, unsigned int excNum)
- register unsigned int irq;
- register unsigned isaIntr; /* boolean */
- register unsigned oldMask = 0; /* old isa pic masks */
- register unsigned newMask; /* new isa pic masks */
-#endif
- if (excNum == ASM_DEC_VECTOR) {
-/* printk("ASM_DEC_VECTOR\n"); */
- bsp_irq_dispatch_list(rtems_hdl_tbl, BSP_DECREMENTER, default_rtems_entry.hdl);
- return 0;
- irq = openpic_irq(0);
- if (irq == OPENPIC_VEC_SPURIOUS) {
-/* printk("OPENPIC_VEC_SPURIOUS interrupt %d\n", OPENPIC_VEC_SPURIOUS ); */
- ++BSP_spuriousIntr;
- return 0;
- /* some BSPs might want to use a different numbering... */
- irq = irq - OPENPIC_VEC_SOURCE + BSP_PCI_IRQ_LOWEST_OFFSET;
-/* printk("OpenPic Irq: %d\n", irq); */
- isaIntr = (irq == BSP_PCI_ISA_BRIDGE_IRQ);
- if (isaIntr) {
-/* printk("BSP_PCI_ISA_BRIDGE_IRQ\n"); */
- * Acknowledge and read 8259 vector
- irq = (unsigned int) (*(unsigned char *) RAVEN_INTR_ACK_REG);
- * store current PIC mask
- oldMask = i8259s_cache;
- newMask = oldMask | irq_mask_or_tbl [irq];
- i8259s_cache = newMask;
- outport_byte(PIC_MASTER_IMR_IO_PORT, i8259s_cache & 0xff);
- outport_byte(PIC_SLAVE_IMR_IO_PORT, ((i8259s_cache & 0xff00) >> 8));
- BSP_irq_ack_at_i8259s (irq);
- openpic_eoi(0);
-#endif
- /* dispatch handlers */
-/* printk("dispatch\n"); */
-irq -=16;
- bsp_irq_dispatch_list(rtems_hdl_tbl, irq, default_rtems_entry.hdl);
-/* printk("Back from dispatch\n"); */
- if (isaIntr) {\
- i8259s_cache = oldMask;
- else
-#endif
-#ifdef BSP_PCI_VME_DRIVER_DOES_EOI
- /* leave it to the VME bridge driver to do EOI, so
- * it can re-enable the openpic while handling
- * VME interrupts (-> VME priorities in software)
- if (_BSP_vme_bridge_irq != irq)
-#endif
- openpic_eoi(0);
- return 0;
diff --git a/c/src/lib/libbsp/powerpc/ep1a/make/custom/ep1a.cfg b/c/src/lib/libbsp/powerpc/ep1a/make/custom/ep1a.cfg
index 2b2c2d2..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/make/custom/ep1a.cfg
+++ /dev/null
@@ -1,17 +0,0 @@
-# Config file for the Radstone PowerPC 8245 ep1a
-include $(RTEMS_ROOT)/make/custom/default.cfg
-RTEMS_CPU=powerpc
-RTEMS_CPU_MODEL=mpc8245
-# This contains the compiler options necessary to select the CPU model
-# and (hopefully) optimize for it.
-CPU_CFLAGS = -mcpu=603e -Dppc603e -mmultiple -mstring -mstrict-align
-# optimize flag: typically -O2
-CFLAGS_OPTIMIZE_V = -O2 -g
diff --git a/c/src/lib/libbsp/powerpc/ep1a/pci/no_host_bridge.c b/c/src/lib/libbsp/powerpc/ep1a/pci/no_host_bridge.c
index 123f793..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/pci/no_host_bridge.c
+++ /dev/null
@@ -1,28 +0,0 @@
-#include <bsp.h>
- * For the 8240 and the 8245 there is no host bridge the
- * Open PIC device is built into the processor chip.
-void detect_host_bridge(void)
- OpenPIC=(volatile struct OpenPIC *) (EUMBBAR + BSP_OPEN_PIC_BASE_OFFSET );
diff --git a/c/src/lib/libbsp/powerpc/ep1a/preinstall.am b/c/src/lib/libbsp/powerpc/ep1a/preinstall.am
index 88a9e13..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/preinstall.am
+++ /dev/null
@@ -1,143 +0,0 @@
-## Automatically generated by ampolish3 - Do not edit
-if AMPOLISH3
-$(srcdir)/preinstall.am: Makefile.am
- $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
-endif
-PREINSTALL_DIRS =
-DISTCLEANFILES += $(PREINSTALL_DIRS)
-all-am: $(PREINSTALL_FILES)
-PREINSTALL_FILES =
-CLEANFILES = $(PREINSTALL_FILES)
-all-local: $(TMPINSTALL_FILES)
-TMPINSTALL_FILES =
-CLEANFILES += $(TMPINSTALL_FILES)
-$(PROJECT_LIB)/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_LIB)
- @: > $(PROJECT_LIB)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
-$(PROJECT_INCLUDE)/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_INCLUDE)
- @: > $(PROJECT_INCLUDE)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
-$(PROJECT_INCLUDE)/bsp/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
- @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
-PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
-$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
-$(PROJECT_INCLUDE)/tm27.h: include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
-$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
-$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
-$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
-$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
-PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
-$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
-TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
-$(PROJECT_LIB)/rtems_crti.$(OBJEXT): rtems_crti.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/rtems_crti.$(OBJEXT)
-TMPINSTALL_FILES += $(PROJECT_LIB)/rtems_crti.$(OBJEXT)
-$(PROJECT_INCLUDE)/bsp/uart.h: ../../powerpc/shared/console/uart.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/uart.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/uart.h
-$(PROJECT_INCLUDE)/bsp/motorola.h: ../../powerpc/shared/motorola/motorola.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/motorola.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/motorola.h
-$(PROJECT_INCLUDE)/bsp/residual.h: ../../powerpc/shared/residual/residual.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/residual.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/residual.h
-$(PROJECT_INCLUDE)/bsp/pnp.h: ../../powerpc/shared/residual/pnp.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/pnp.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/pnp.h
-$(PROJECT_INCLUDE)/bsp/consoleIo.h: ../../powerpc/shared/console/consoleIo.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/consoleIo.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/consoleIo.h
-$(PROJECT_INCLUDE)/bsp/rsPMCQ1.h: console/rsPMCQ1.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/rsPMCQ1.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/rsPMCQ1.h
-$(PROJECT_INCLUDE)/bsp/console_private.h: ../../shared/console_private.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/console_private.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/console_private.h
-$(PROJECT_INCLUDE)/bsp/openpic.h: ../../powerpc/shared/openpic/openpic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/openpic.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/openpic.h
-$(PROJECT_INCLUDE)/bsp/pci.h: ../../powerpc/shared/pci/pci.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/pci.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/pci.h
-$(PROJECT_INCLUDE)/bsp/irq.h: ../../powerpc/shared/irq/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
-$(PROJECT_INCLUDE)/bsp/irq_supp.h: ../../../libcpu/@RTEMS_CPU@/@exceptions@/bspsupport/irq_supp.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq_supp.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq_supp.h
-$(PROJECT_INCLUDE)/bsp/vmeUniverse.h: ../../shared/vmeUniverse/vmeUniverse.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/vmeUniverse.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/vmeUniverse.h
-$(PROJECT_INCLUDE)/bsp/VMEConfig.h: vme/VMEConfig.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/VMEConfig.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/VMEConfig.h
-$(PROJECT_INCLUDE)/bsp/vme_am_defs.h: ../../shared/vmeUniverse/vme_am_defs.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/vme_am_defs.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/vme_am_defs.h
-$(PROJECT_INCLUDE)/bsp/VME.h: ../../shared/vmeUniverse/VME.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/VME.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/VME.h
-$(PROJECT_INCLUDE)/bsp/vmeUniverseDMA.h: ../../shared/vmeUniverse/vmeUniverseDMA.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/vmeUniverseDMA.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/vmeUniverseDMA.h
-$(PROJECT_INCLUDE)/bsp/bspVmeDmaList.h: ../../shared/vmeUniverse/bspVmeDmaList.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bspVmeDmaList.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bspVmeDmaList.h
-$(PROJECT_INCLUDE)/bsp/VMEDMA.h: ../../shared/vmeUniverse/VMEDMA.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/VMEDMA.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/VMEDMA.h
diff --git a/c/src/lib/libbsp/powerpc/ep1a/start/start.S b/c/src/lib/libbsp/powerpc/ep1a/start/start.S
deleted file mode 100644
index 51596ac..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/start/start.S
+++ /dev/null
@@ -1,146 +0,0 @@
- * This is based on the mvme-crt0.S file from libgloss/rs6000.
- * crt0.S -- startup file for PowerPC systems.
- * (c) 1998, Radstone Technology plc.
- * This is an unpublished work the copyright in which vests
- * in Radstone Technology plc. All rights reserved.
- * The information contained herein is the property of Radstone
- * Technology plc. and is supplied without liability for
- * errors or omissions and no part may be reproduced, used or
- * disclosed except as authorized by contract or other written
- * permission. The copyright and the foregoing
- * restriction on reproduction, use and disclosure extend to
- * all the media in which this information may be
- * embodied.
- * Copyright (c) 1995 Cygnus Support
- * The authors hereby grant permission to use, copy, modify, distribute,
- * and license this software and its documentation for any purpose, provided
- * that existing copyright notices are retained in all copies and that this
- * notice is included verbatim in any distributions. No written agreement,
- * license, or royalty fee is required for any of the authorized uses.
- * Modifications to this software may be copyrighted by their authors
- * and need not follow the licensing terms described here, provided that
- * the new terms are clearly indicated on the first page of each file where
- * they apply.
-#include <ppc-asm.h>
-#include <bsp.h>
-#include <rtems/asm.h>
-#include <rtems/score/cpu.h>
-#define H0_60X_ICE 0x8000 /* HID0 I-Cache Enable */
-#define H0_60X_DCE 0x4000 /* HID0 D-Cache Enable */
- .file "start.s"
- .extern FUNC_NAME(atexit)
- .globl FUNC_NAME(__atexit)
- .section ".sdata","aw"
- .align 2
-FUNC_NAME(__atexit): /* tell C's eabi-ctor's we have an atexit function */
- .long FUNC_NAME(atexit)@fixup /* and that it is to register __do_global_dtors */
- .section ".fixup","aw"
- .align 2
- .long FUNC_NAME(__atexit)
- .text
- .globl __rtems_entry_point
- .type __rtems_entry_point, at function
-__rtems_entry_point:
- /* Set MSR */
- * Enable data and instruction address translation and floating point
- li r3,MSR_IR | MSR_DR | MSR_FP
- mtmsr r3
- /* XXX - ADD BACK IN CACHING INSTRUCTIONS */
- /* clear bss */
- lis r6,__bss_start at h
- ori r6,r6,__bss_start at l
- lis r7,__bss_end at h
- ori r7,r7,__bss_end at l
- cmplw 1,r6,r7
- bc 4,4,.Lbss_done
- subf r8,r6,r7 /* number of bytes to zero */
- srwi r9,r8,2 /* number of words to zero */
- mtctr r9
- li r0,0 /* zero to clear memory */
- addi r6,r6,-4 /* adjust so we can use stwu */
-.Lbss_loop:
- stwu r0,4(r6) /* zero bss */
- bdnz .Lbss_loop
-.Lbss_done:
- /* clear sbss */
- lis r6,__sbss_start at h
- ori r6,r6,__sbss_start at l
- lis r7,__sbss_end at h
- ori r7,r7,__sbss_end at l
- cmplw 1,r6,r7
- bc 4,4,.Lsbss_done
- mtctr r9
-.Lsbss_loop:
- stwu r0,4(r6) /* zero sbss */
- bdnz .Lsbss_loop
-.Lsbss_done:
- lis sp,__stack at h
- ori sp,sp,__stack at l
- /* set up initial stack frame */
- addi sp,sp,-4 /* make sure we don't overwrite debug mem */
- lis r0,0
- stw r0,0(sp) /* clear back chain */
- stwu sp,-56(sp) /* push another stack frame */
- li r3, 0 /* command line */
- /* Let her rip */
- bl FUNC_NAME(boot_card)
- * This should never get reached
- * Return MSR to its reset state
- li r3,0
- mtmsr r3
- isync
- * Call reset entry point
- lis r3,0xfff0
- ori r3,r3,0x100
- mtlr r3
- blr
-.Lstart:
- .size __rtems_entry_point,.Lstart-__rtems_entry_point
- .comm environ,4,4
diff --git a/c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c b/c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c
index dc675e2..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/startup/bspstart.c
+++ /dev/null
@@ -1,353 +0,0 @@
- * This routine does the bulk of the system initialization.
-#include <bsp/consoleIo.h>
-#include <bsp/bootcard.h>
-#include <libcpu/spr.h>
-#include <bsp/VME.h>
-#include <bsp.h>
-#include <libcpu/bat.h>
-#include <libcpu/pte121.h>
-#include <libcpu/cpuIdent.h>
-#include <rtems/powerpc/powerpc.h>
-#include <rtems/counter.h>
-extern unsigned long __bss_start[], __SBSS_START__[], __SBSS_END__[];
-extern unsigned long __SBSS2_START__[], __SBSS2_END__[];
-extern unsigned long __rtems_end[];
-extern void L1_caches_enables(void);
-extern unsigned get_L2CR(void);
-extern void set_L2CR(unsigned);
-extern Triv121PgTbl BSP_pgtbl_setup(void);
-extern void BSP_pgtbl_activate(Triv121PgTbl);
-extern void BSP_vme_config(void);
-extern void ShowBATS(void);
-uint32_t bsp_clicks_per_usec;
-SPR_RW(SPRG1)
-uint8_t LightIdx = 0;
-extern int RAM_END;
-unsigned int BSP_mem_size = (unsigned int)&RAM_END;
-static void BSP_Increment_Light(void)
- uint8_t data;
- data = *GENERAL_REGISTER1;
- data &= 0xf0;
- data |= LightIdx++;
- *GENERAL_REGISTER1 = data;
- * Vital Board data Start using DATA RESIDUAL
-uint32_t VME_Slot1 = FALSE;
-unsigned int BSP_bus_frequency;
-unsigned int BSP_processor_frequency;
-unsigned int BSP_time_base_divisor = 1000; /* XXX - Just a guess */
-void BSP_panic(char *s)
- printk("%s PANIC %s\n",_RTEMS_version, s);
- __asm__ __volatile ("sc");
-void _BSP_Fatal_error(unsigned int v)
- printk("%s PANIC ERROR %x\n",_RTEMS_version, v);
- uint32_t area
- unsigned char data;
- data |= DISABLE_USER_FLASH;
- return RTEMS_SUCCESSFUL;
- uint32_t area /* IN */
- data &= (~DISABLE_USER_FLASH);
- uint8_t page
- /* Set the flash page register. */
- data = *GENERAL_REGISTER2;
- data &= ~(BSP_FLASH_PAGE_MASK);
- data |= 0x80 | (page << BSP_FLASH_PAGE_SHIFT);
- *GENERAL_REGISTER2 = data;
- * bsp_pretasking_hook
- * BSP pretasking hook. Called just before drivers are initialized.
-void bsp_pretasking_hook(void)
- rsPMCQ1Init();
-unsigned int EUMBBAR;
-static unsigned int get_eumbbar(void)
- register int a, e;
- __asm__ volatile( "lis %0,0xfec0; ori %0,%0,0x0000": "=r" (a) );
- __asm__ volatile("sync");
- __asm__ volatile("lis %0,0x8000; ori %0,%0,0x0078": "=r"(e) );
- __asm__ volatile("stwbrx %0,0x0,%1": "=r"(e): "r"(a));
- __asm__ volatile("lis %0,0xfee0; ori %0,%0,0x0000": "=r" (a) );
- __asm__ volatile("lwbrx %0,0x0,%1": "=r" (e): "r" (a));
- __asm__ volatile("isync");
- return e;
-static void Read_ep1a_config_registers( ppc_cpu_id_t myCpu ) {
- unsigned char value;
- * Print out the board and revision.
- printk("Board: ");
- printk( get_ppc_cpu_type_name(myCpu) );
- value = *BOARD_REVISION_REGISTER2 & HARDWARE_ID_MASK;
- if ( value == HARDWARE_ID_PPC5_EP1A )
- printk(" EP1A ");
- else if ( value == HARDWARE_ID_EP1B )
- printk(" EP1B ");
- else
- printk(" Unknown ");
- value = *BOARD_REVISION_REGISTER2&0x1;
- printk("Board ID %08x", value);
- if(value == 0x0){
- VME_Slot1 = TRUE;
- printk("VME Slot 1\n");
- else{
- VME_Slot1 = FALSE;
- printk("\n");
- printk("Revision: ");
- value = *BOARD_REVISION_REGISTER1;
- printk("%d%c\n\n", value>>4, 'A'+(value&BUILD_REVISION_MASK) );
- * Get the CPU, XXX frequency
- value = *EQUIPMENT_PRESENT_REGISTER2 & PLL_CFG_MASK;
- switch( value ) {
- case MHZ_33_66_200: /* PCI, MEM, & CPU Frequency */
- BSP_processor_frequency = 200000000;
- BSP_bus_frequency = 33000000;
- break;
- case MHZ_33_100_200: /* PCI, MEM, & CPU Frequency */
- break;
- case MHZ_33_66_266: /* PCI, MEM, & CPU Frequency */
- BSP_processor_frequency = 266000000;
- break;
- case MHZ_33_66_333: /* PCI, MEM, & CPU Frequency */
- BSP_processor_frequency = 333000000;
- break;
- case MHZ_33_100_333: /* PCI, MEM, & CPU Frequency */
- break;
- case MHZ_33_100_350: /* PCI, MEM, & CPU Frequency */
- BSP_processor_frequency = 350000000;
- break;
- default:
- printk("ERROR: Unknown Processor frequency 0x%02x please fill in bspstart.c\n",value);
- break;
- * bsp_start
-void bsp_start( void )
- uintptr_t intrStackStart;
- uintptr_t intrStackSize;
- ppc_cpu_id_t myCpu;
- Triv121PgTbl pt=0; /* R = e; */
- * Get CPU identification dynamically. Note that the get_ppc_cpu_type()
- * function store the result in global variables so that it can be used
- * latter...
- BSP_Increment_Light();
- myCpu = get_ppc_cpu_type();
- get_ppc_cpu_revision();
- EUMBBAR = get_eumbbar();
- printk("EUMBBAR 0x%08x\n", EUMBBAR );
- * Note this sets BSP_processor_frequency based upon register settings.
- * It must be done prior to setting up hooks.
- Read_ep1a_config_registers( myCpu );
- bsp_clicks_per_usec = BSP_processor_frequency/(BSP_time_base_divisor * 1000);
- rtems_counter_initialize_converter(
- BSP_processor_frequency / (BSP_time_base_divisor / 1000)
-ShowBATS();
-#if 0 /* XXX - Add back in cache enable when we get this up and running!! */
- * enables L1 Cache. Note that the L1_caches_enables() codes checks for
- * relevant CPU type so that the reason why there is no use of myCpu...
- L1_caches_enables();
-#endif
- * Initialize the interrupt related settings.
- intrStackStart = (uintptr_t) __rtems_end;
- intrStackSize = rtems_configuration_get_interrupt_stack_size();
- * Initialize default raw exception hanlders.
- ppc_exc_initialize(intrStackStart, intrStackSize);
- * Init MMU block address translation to enable hardware
- * access
- setdbat(1, 0xf0000000, 0xf0000000, 0x10000000, IO_PAGE);
- setdbat(3, 0x90000000, 0x90000000, 0x10000000, IO_PAGE);
-#ifdef SHOW_MORE_INIT_SETTINGS
- printk("Going to start PCI buses scanning and initialization\n");
-#endif
- pci_initialize();
- printk("Number of PCI buses found is : %d\n", pci_bus_count());
-#endif
-#ifdef TEST_RAW_EXCEPTION_CODE
- printk("Testing exception handling Part 1\n");
- * Cause a software exception
- * Check we can still catch exceptions and returned coorectly.
- printk("Testing exception handling Part 2\n");
-#endif
- * Initalize RTEMS IRQ system
- BSP_rtems_irq_mng_init(0);
- /* Activate the page table mappings only after
- * initializing interrupts because the irq_mng_init()
- * routine needs to modify the text
- if (pt) {
- printk("Page table setup finished; will activate it NOW...\n");
-#endif
- BSP_pgtbl_activate(pt);
- * Initialize VME bridge - needs working PCI
- * and IRQ subsystems...
- printk("Going to initialize VME bridge\n");
-#endif
- /* VME initialization is in a separate file so apps which don't use
- * VME or want a different configuration may link against a customized
- * routine.
- BSP_vme_config();
- ShowBATS();
- printk("Exit from bspstart\n");
-#endif
diff --git a/c/src/lib/libbsp/powerpc/ep1a/startup/linkcmds b/c/src/lib/libbsp/powerpc/ep1a/startup/linkcmds
index 69644e3..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/startup/linkcmds
+++ /dev/null
@@ -1,208 +0,0 @@
-OUTPUT_FORMAT("elf32-powerpc", "elf32-powerpc",
- "elf32-powerpc")
-OUTPUT_ARCH(powerpc)
-ENTRY(_start)
- * Number of Decrementer countdowns per millisecond
- * Calculated by: (66.67 Mhz * 1000) / 4 cycles per click
-SECTIONS
- .vectors 0x00100 :
- *(.vectors)
- /* Read-only sections, merged into text segment: */
- /* SDS ROM worked at 0x30000 */
- . = 0x30000;
- .interp : { *(.interp) }
- .hash : { *(.hash) }
- .dynsym : { *(.dynsym) }
- .dynstr : { *(.dynstr) }
- .rela.text : { *(.rela.text) }
- .rela.data : { *(.rela.data) }
- .rela.rodata : { *(.rela.rodata) }
- .rela.got : { *(.rela.got) }
- .rela.got1 : { *(.rela.got1) }
- .rela.got2 : { *(.rela.got2) }
- .rela.ctors : { *(.rela.ctors) }
- .rela.dtors : { *(.rela.dtors) }
- .rela.init : { *(.rela.init) }
- .rela.fini : { *(.rela.fini) }
- .rela.bss : { *(.rela.bss) }
- .rela.plt : { *(.rela.plt) }
- .rela.sdata : { *(.rela.sdata2) }
- .rela.sbss : { *(.rela.sbss2) }
- .rela.sdata2 : { *(.rela.sdata2) }
- .rela.sbss2 : { *(.rela.sbss2) }
- .plt : { *(.plt) }
- .text :
- _start = .;
- *(.text*)
- * Special FreeBSD sysctl sections.
- . = ALIGN (16);
- __start_set_sysctl_set = .;
- *(set_sysctl_*);
- __stop_set_sysctl_set = ABSOLUTE(.);
- *(set_domain_*);
- *(set_pseudo_*);
- *(.gnu.linkonce.t.*)
- *(.descriptors)
- /* .gnu.warning sections are handled specially by elf32.em. */
- *(.gnu.warning)
- } =0
- .init : { _init = .; *(.init) }
- .fini : { _fini = .; *(.fini) }
- .rodata : { *(.rodata*) KEEP (*(SORT(.rtemsroset.*))) *(.gnu.linkonce.r*) }
- .rodata1 : { *(.rodata1) }
- .tdata : {
- _TLS_Data_begin = .;
- *(.tdata .tdata.* .gnu.linkonce.td.*)
- _TLS_Data_end = .;
- .tbss : {
- _TLS_BSS_begin = .;
- *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
- _TLS_BSS_end = .;
- _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
- _TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin : _TLS_BSS_begin;
- _TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
- _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
- _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
- _TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
- .eh_frame : { *(.eh_frame) }
- _etext = .;
- PROVIDE (etext = .);
- PROVIDE (__SDATA2_START__ = .);
- .sdata2 : { *(.sdata2) *(.gnu.linkonce.s2.*) }
- .sbss2 : { *(.sbss2) *(.gnu.linkonce.sb2.*) }
- PROVIDE (__SBSS2_START__ = .);
- .sbss2 : { *(.sbss2) }
- PROVIDE (__SBSS2_END__ = .);
- /* Adjust the address for the data segment. We want to adjust up to
- the same address within the page on the next page up. It would
- be more correct to do this:
- . = ALIGN(0x40000) + (ALIGN(8) & (0x40000 - 1));
- The current expression does not correctly handle the case of a
- text segment ending precisely at the end of a page; it causes the
- data segment to skip a page. The above expression does not have
- this problem, but it will currently (2/95) cause BFD to allocate
- a single segment, combining both text and data, for this case.
- This will prevent the text segment from being shared among
- multiple executions of the program; I think that is more
- important than losing a page of the virtual address space (note
- that no actual memory is lost; the page which is skipped can not
- be referenced). */
- . = ALIGN(8) + 0x40000;
- PROVIDE (sdata = .);
- .data :
- PROVIDE(__DATA_START__ = ABSOLUTE(.) );
- *(.data)
- KEEP (*(SORT(.rtemsrwset.*)))
- *(.gnu.linkonce.d.*)
- CONSTRUCTORS
- PROVIDE (__EXCEPT_START__ = .);
- .gcc_except_table : { *(.gcc_except_table*) }
- PROVIDE (__EXCEPT_END__ = .);
- .data1 : { *(.data1) }
- .got1 : { *(.got1) }
- .dynamic : { *(.dynamic) }
- /* Put .ctors and .dtors next to the .got2 section, so that the pointers
- get relocated with -mrelocatable. Also put in the .fixup pointers.
- The current compiler no longer needs this, but keep it around for 2.7.2 */
- PROVIDE (_GOT2_START_ = .);
- .got2 : { *(.got2) }
- PROVIDE (__GOT2_END__ = .);
- PROVIDE (__CTOR_LIST__ = .);
- .ctors : { *(.ctors) }
- PROVIDE (__CTOR_END__ = .);
- PROVIDE (__DTOR_LIST__ = .);
- .dtors : { *(.dtors) }
- PROVIDE (__DTOR_END__ = .);
- PROVIDE (_FIXUP_START_ = .);
- .fixup : { *(.fixup) }
- PROVIDE (_FIXUP_END_ = .);
- PROVIDE (__FIXUP_END__ = .);
- PROVIDE (_GOT2_END_ = .);
- PROVIDE (_GOT_START_ = .);
- s.got = .;
- .got : { *(.got) }
- .got.plt : { *(.got.plt) }
- PROVIDE (_GOT_END_ = .);
- PROVIDE (__GOT_END__ = .);
- /* We want the small data sections together, so single-instruction offsets
- can access them all, and initialized data all before uninitialized, so
- we can shorten the on-disk segment size. */
- PROVIDE (__SDATA_START__ = .);
- .sdata : { *(.sdata*) *(.gnu.linkonce.s.*) }
- _edata = .;
- PROVIDE (edata = .);
- PROVIDE (RAM_END = ADDR(.text) + 10M);
- . = ALIGN(8) + 0x1000;
- PROVIDE (__SBSS_START__ = .);
- .sbss :
- PROVIDE (__sbss_start = .);
- *(.sbss* .sbss.* .gnu.linkonce.sb.*)
- *(.scommon)
- PROVIDE (__sbss_end = .);
- PROVIDE (__SBSS_END__ = .);
- .bss :
- PROVIDE (__bss_start = .);
- *(.dynbss)
- *(.bss .bss* .gnu.linkonce.b*)
- *(COMMON)
- PROVIDE (__bss_end = .);
- . = ALIGN(8) + 0x8000;
- PROVIDE (__stack = .);
- _end = . ;
- __rtems_end = . ;
- PROVIDE (end = .);
- /* These are needed for ELF backends which have not yet been
- converted to the new style linker. */
- .stab 0 : { *(.stab) }
- .stabstr 0 : { *(.stabstr) }
- /* DWARF debug sections.
- Symbols in the DWARF debugging sections are relative to the beginning
- of the section so we begin them at 0. */
- /* DWARF 1 */
- .debug 0 : { *(.debug) }
- .line 0 : { *(.line) }
- /* GNU DWARF 1 extensions */
- .debug_srcinfo 0 : { *(.debug_srcinfo) }
- .debug_sfnames 0 : { *(.debug_sfnames) }
- /* DWARF 1.1 and DWARF 2 */
- .debug_aranges 0 : { *(.debug_aranges) }
- .debug_pubnames 0 : { *(.debug_pubnames) }
- /* DWARF 2 */
- .debug_info 0 : { *(.debug_info) }
- .debug_abbrev 0 : { *(.debug_abbrev) }
- .debug_line 0 : { *(.debug_line) }
- .debug_frame 0 : { *(.debug_frame) }
- .debug_str 0 : { *(.debug_str) }
- .debug_loc 0 : { *(.debug_loc) }
- .debug_macinfo 0 : { *(.debug_macinfo) }
- /* SGI/MIPS DWARF 2 extensions */
- .debug_weaknames 0 : { *(.debug_weaknames) }
- .debug_funcnames 0 : { *(.debug_funcnames) }
- .debug_typenames 0 : { *(.debug_typenames) }
- .debug_varnames 0 : { *(.debug_varnames) }
- /* These must appear regardless of . */
diff --git a/c/src/lib/libbsp/powerpc/ep1a/vme/VMEConfig.h b/c/src/lib/libbsp/powerpc/ep1a/vme/VMEConfig.h
index 1a57610..0000000
--- a/c/src/lib/libbsp/powerpc/ep1a/vme/VMEConfig.h
+++ /dev/null
@@ -1,113 +0,0 @@
-#ifndef RTEMS_BSP_VME_CONFIG_H
-#define RTEMS_BSP_VME_CONFIG_H
-/* BSP specific address space configuration parameters */
- * Authorship
- * This software was created by
- * Till Straumann <strauman at slac.stanford.edu>, 2002,
- * Stanford Linear Accelerator Center, Stanford University.
- * Acknowledgement of sponsorship
- * This software was produced by
- * the Stanford Linear Accelerator Center, Stanford University,
- * under Contract DE-AC03-76SFO0515 with the Department of Energy.
- * Government disclaimer of liability
- * Neither the United States nor the United States Department of Energy,
- * nor any of their employees, makes any warranty, express or implied, or
- * assumes any legal liability or responsibility for the accuracy,
- * completeness, or usefulness of any data, apparatus, product, or process
- * disclosed, or represents that its use would not infringe privately owned
- * rights.
- * Stanford disclaimer of liability
- * Stanford University makes no representations or warranties, express or
- * implied, nor assumes any liability for the use of this software.
- * Stanford disclaimer of copyright
- * Stanford University, owner of the copyright, hereby disclaims its
- * copyright and all other rights in this software. Hence, anyone may
- * freely use it for any purpose without restriction.
- * Maintenance of notices
- * In the interest of clarity regarding the origin and status of this
- * SLAC software, this and all the preceding Stanford University notices
- * are to remain affixed to any copy or derivative of this software made
- * or distributed by the recipient and are to be affixed to any copy of
- * software made or distributed by the recipient that contains a copy or
- * derivative of this software.
- * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
- * The BSP maps VME address ranges into
- * one BAT.
- * NOTE: the BSP (startup/bspstart.c) uses
- * hardcoded window lengths that match this
- * layout:
- * BSP_VME_BAT_IDX defines
- * which BAT to use for mapping the VME bus.
- * If this is undefined, no extra BAT will be
- * configured and VME has to share the available
- * PCI address space with PCI devices.
-#undef BSP_VME_BAT_IDX
-#define _VME_A32_WIN0_ON_PCI 0x90000000
-#define _VME_A24_ON_PCI 0x9f000000
-#define _VME_A16_ON_PCI 0x9fff0000
-/* start of the A32 window on the VME bus
- * TODO: this should perhaps be a configuration option
-#define _VME_A32_WIN0_ON_VME 0x20000000
-/* if _VME_DRAM_OFFSET is defined, the BSP
- * will map our RAM onto the VME bus, starting
- * at _VME_DRAM_OFFSET
-#undef _VME_DRAM_OFFSET
-#define _VME_DRAM_OFFSET 0xc0000000
-#define _VME_DRAM_32_OFFSET1 0x20000000
-#define _VME_DRAM_32_OFFSET2 0x20b00000
-#define _VME_DRAM_24_OFFSET1 0x00000000
-#define _VME_DRAM_24_OFFSET2 0x00100000
-#define _VME_DRAM_16_OFFSET1 0x00000000
-#define _VME_DRAM_16_OFFSET2 0x00008000
-#define _VME_A24_SIZE 0x00100000
-#define _VME_A16_SIZE 0x00008000
-#undef _VME_CSR_ON_PCI
-/* Tell the interrupt manager that the universe driver
- * already called openpic_eoi() and that this step hence
- * must be omitted.
-#define BSP_PCI_VME_DRIVER_DOES_EOI
-/* don't reference vmeUniverse0PciIrqLine directly here - leave it up to
- * bspstart() to set BSP_vme_bridge_irq. That way, we can generate variants
- * of the BSP with / without the universe driver...
-extern int _BSP_vme_bridge_irq;
-extern int BSP_VMEInit(void);
-extern int BSP_VMEIrqMgrInstall(void);
-#define BSP_VME_UNIVERSE_INSTALL_IRQ_MGR(err) \
- do { \
- err = vmeUniverseInstallIrqMgr(0,5,1,6); \
- } while (0)
-#endif
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
