[PATCH 2/2] bsps: Call bsp_work_area_initialize() early
Wed Dec 9 08:15:30 UTC 2015
Call bsp_work_area_initialize() before bsp_start().  This allows
bsp_start() to use malloc() etc. which is beneficial for systems with a
plug-and-play hardware enumeration.
Update #2408.
 c/src/lib/libbsp/i386/pc386/include/bsp.h          |  2 -
 .../lib/libbsp/i386/pc386/startup/bspgetworkarea.c | 13 ++++--
 c/src/lib/libbsp/i386/pc386/startup/bspstart.c     |  5 ---
 c/src/lib/libbsp/shared/bootcard.c                 |  8 ++--
 c/src/lib/libbsp/shared/include/bootcard.h         |  2 +-
 c/src/lib/libbsp/sparc/erc32/Makefile.am           |  1 -
 c/src/lib/libbsp/sparc/erc32/include/bsp.h         |  7 ----
 c/src/lib/libbsp/sparc/leon2/Makefile.am           |  1 -
 c/src/lib/libbsp/sparc/leon2/include/bsp.h         |  7 ----
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |  3 +-
 c/src/lib/libbsp/sparc/leon3/include/bsp.h         |  7 ----
 c/src/lib/libbsp/sparc/shared/amba/ambapp.c        | 10 ++---
 .../libbsp/sparc/shared/startup/bspgetworkarea.c   |  8 +---
 .../lib/libbsp/sparc/shared/startup/early_malloc.c | 47 ---------------------
 doc/bsp_howto/init.t                               | 49 ++++++++++++----------
 15 files changed, 49 insertions(+), 121 deletions(-)
 delete mode 100644 c/src/lib/libbsp/sparc/shared/startup/early_malloc.c
diff --git a/c/src/lib/libbsp/i386/pc386/include/bsp.h b/c/src/lib/libbsp/i386/pc386/include/bsp.h
index 5a82ac2..d9f24e4 100644
--- a/c/src/lib/libbsp/i386/pc386/include/bsp.h
+++ b/c/src/lib/libbsp/i386/pc386/include/bsp.h
@@ -187,8 +187,6 @@ void Calibrate_loop_1ms(void);           /* from 'timer.c'  */
 void rtems_irq_mngt_init(void);          /* from 'irq_init.c' */
-void bsp_size_memory(void);              /* from 'bspstart.c' */
 #if (BSP_IS_EDISON == 0)
   void Clock_driver_install_handler(void);             /* from 'ckinit.c'  */
   void Clock_driver_support_initialize_hardware(void); /* from 'ckinit.c'  */
diff --git a/c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c b/c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c
index 2e4bf5c..5207bac 100644
--- a/c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c
+++ b/c/src/lib/libbsp/i386/pc386/startup/bspgetworkarea.c
@@ -52,7 +52,7 @@ uint32_t bsp_mem_size = 0;
 /* Size of stack used during initialization. Defined in 'start.s'.  */
 extern uint32_t _stack_size;
+static void bsp_size_memory(void)
   uintptr_t topAddr;
@@ -126,8 +126,15 @@ void bsp_size_memory(void)
 void bsp_work_area_initialize(void)
-  void *area_start = (void *) rtemsWorkAreaStart;
-  uintptr_t area_size  = (uintptr_t) bsp_mem_size - (uintptr_t) rtemsWorkAreaStart;
+  void *area_start;
+  uintptr_t area_size;
+   *  We need to determine how much memory there is in the system.
+  bsp_size_memory();
+  area_start = (void *) rtemsWorkAreaStart;
+  area_size  = (uintptr_t) bsp_mem_size - (uintptr_t) rtemsWorkAreaStart;
   bsp_work_area_initialize_default( area_start, area_size );
diff --git a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
index 9b1be64..ac871f0 100644
--- a/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
+++ b/c/src/lib/libbsp/i386/pc386/startup/bspstart.c
@@ -58,11 +58,6 @@ static void bsp_pci_initialize_helper(void)
 static void bsp_start_default( void )
-   *  We need to determine how much memory there is in the system.
-  bsp_size_memory();
    * Turn off watchdog
 #if (BSP_IS_EDISON == 1)
diff --git a/c/src/lib/libbsp/shared/bootcard.c b/c/src/lib/libbsp/shared/bootcard.c
index eeb5746..cbeb7b2 100644
--- a/c/src/lib/libbsp/shared/bootcard.c
+++ b/c/src/lib/libbsp/shared/bootcard.c
@@ -75,14 +75,14 @@ void boot_card(
   bsp_boot_cmdline = cmdline;
-   * Invoke Board Support Package initialization routine written in C.
+   *  Initialize the RTEMS Workspace and the C Program Heap.
-  bsp_start();
+  bsp_work_area_initialize();
-   *  Initialize the RTEMS Workspace and the C Program Heap.
+   * Invoke Board Support Package initialization routine written in C.
-  bsp_work_area_initialize();
+  bsp_start();
    *  Initialize RTEMS data structures
diff --git a/c/src/lib/libbsp/shared/include/bootcard.h b/c/src/lib/libbsp/shared/include/bootcard.h
index 93d5041..7c0d3f1 100644
--- a/c/src/lib/libbsp/shared/include/bootcard.h
+++ b/c/src/lib/libbsp/shared/include/bootcard.h
@@ -78,9 +78,9 @@ void bsp_reset(void);
  * - disable interrupts, interrupts will be enabled during the first context
  *   switch
- * - bsp_start() - more advanced initialization
  * - bsp_work_area_initialize() - initialize the RTEMS Workspace and the C
  *   Program Heap
+ * - bsp_start() - more advanced initialization
  * - rtems_initialize_data_structures()
  * - initialize C Library
  * - bsp_pretasking_hook()
diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
index b00853a..f0465b0 100644
--- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
+++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
@@ -43,7 +43,6 @@ libbsp_a_SOURCES += startup/erc32mec.c
 libbsp_a_SOURCES += startup/boardinit.S
 libbsp_a_SOURCES += startup/bspidle.c
 libbsp_a_SOURCES += startup/bspdelay.c
-libbsp_a_SOURCES += ../../sparc/shared/startup/early_malloc.c
 libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_exit.c
 libbsp_a_SOURCES += ../../sparc/shared/startup/bsp_fatal_halt.c
 # ISR Handler
diff --git a/c/src/lib/libbsp/sparc/erc32/include/bsp.h b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
index 942a873..8633634 100644
--- a/c/src/lib/libbsp/sparc/erc32/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/erc32/include/bsp.h
@@ -93,13 +93,6 @@ void BSP_fatal_exit(uint32_t error);
 void bsp_spurious_initialize( void );
-/* Allocate 8-byte aligned non-freeable pre-malloc() memory. The function
- * can be called at any time. The work-area will shrink when called before
- * bsp_work_area_initialize(). malloc() is called to get memory when this
- * function is called after bsp_work_area_initialize().
-void *bsp_early_malloc(int size);
 /* Interrupt Service Routine (ISR) pointer */
 typedef void (*bsp_shared_isr)(void *arg);
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 7eada59..2b5d195 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -42,7 +42,6 @@ libbsp_a_SOURCES += startup/setvec.c
 libbsp_a_SOURCES += startup/spurious.c
diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
index 09cf7f7..acc310a 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
@@ -117,13 +117,6 @@ void BSP_fatal_exit(uint32_t error);
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index d261f99..95f10eb 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -38,8 +38,7 @@ libbsp_a_SOURCES += ../../shared/bsplibc.c \
     ../../shared/bsppretaskinghook.c startup/bsppredriver.c \
     ../../sparc/shared/startup/bspgetworkarea.c ../../shared/sbrk.c \
     startup/setvec.c \
-    startup/spurious.c startup/bspidle.S startup/bspdelay.c \
-    ../../sparc/shared/startup/early_malloc.c
+    startup/spurious.c startup/bspidle.S startup/bspdelay.c
 libbsp_a_SOURCES += startup/cpucounter.c
 libbsp_a_SOURCES += startup/bsp_fatal_halt.c
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index 5642e14..1397716 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
@@ -140,13 +140,6 @@ void bsp_spurious_initialize( void );
 void rtems_bsp_delay(int usecs);
diff --git a/c/src/lib/libbsp/sparc/shared/amba/ambapp.c b/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
index dba56c1..e4f1aac 100644
--- a/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
+++ b/c/src/lib/libbsp/sparc/shared/amba/ambapp.c
@@ -23,18 +23,16 @@
 /* Allocate one AMBA device */
 static struct ambapp_dev *ambapp_alloc_dev_struct(int dev_type)
-  int size = sizeof(struct ambapp_dev);
   struct ambapp_dev *dev;
+  size_t size = sizeof(*dev);
   if (dev_type == DEV_APB_SLV)
     size += sizeof(struct ambapp_apb_info);
   else
     size += sizeof(struct ambapp_ahb_info); /* AHB */
-  dev = (struct ambapp_dev *)bsp_early_malloc(size);
-  if (dev == NULL)
-    return NULL;
-  memset(dev, 0 , size);
-  dev->dev_type = dev_type;
+  dev = (struct ambapp_dev *)calloc(1, size);
+  if (dev != NULL)
+    dev->dev_type = dev_type;
   return dev;
diff --git a/c/src/lib/libbsp/sparc/shared/startup/bspgetworkarea.c b/c/src/lib/libbsp/sparc/shared/startup/bspgetworkarea.c
index a68d295..b05113d 100644
--- a/c/src/lib/libbsp/sparc/shared/startup/bspgetworkarea.c
+++ b/c/src/lib/libbsp/sparc/shared/startup/bspgetworkarea.c
@@ -20,9 +20,6 @@
 /* Tells us where to put the workspace in case remote debugger is present.  */
 extern uint32_t rdb_start;
-/* Must be aligned to 8, _end is aligned to 8 */
-unsigned int early_mem = (unsigned int)&end;
  *  This method returns the base address and size of the area which
  *  is to be allocated between the RTEMS Workspace and the C Program
@@ -34,10 +31,9 @@ void bsp_work_area_initialize(void)
   #define STACK_SIZE (16 * 1024)
   /* Early dynamic memory allocator is placed just above _end  */
-  void *work_area_start = (void *)early_mem;
+  void *work_area_start = (void *)&end;
   uintptr_t work_area_size  =
-    (uintptr_t)rdb_start - (uintptr_t)early_mem - STACK_SIZE;
-  early_mem        = ~0; /* Signal bsp_early_malloc not to be used anymore */
+    (uintptr_t)rdb_start - (uintptr_t)&end - STACK_SIZE;
    *  The following may be helpful in debugging what goes wrong when
diff --git a/c/src/lib/libbsp/sparc/shared/startup/early_malloc.c b/c/src/lib/libbsp/sparc/shared/startup/early_malloc.c
deleted file mode 100644
index 911a7b0..0000000
--- a/c/src/lib/libbsp/sparc/shared/startup/early_malloc.c
+++ /dev/null
@@ -1,47 +0,0 @@
- *  Early dynamic memory allocation (not freeable) for BSP
- *  boot routines. Minimum alignment 8 bytes. Memory is
- *  allocated after _end, it will shrink the workspace.
- *  COPYRIGHT (c) 2011.
- *  Aeroflex Gaisler AB
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#include <bsp.h>
-#include <stdlib.h>
-/* Tells us where to put the workspace in case remote debugger is present. */
-extern uint32_t rdb_start;
-/* Must be aligned to 8 */
-extern unsigned int early_mem;
-/* must be identical to STACK_SIZE in start.S */
-#define STACK_SIZE (16 * 1024)
- * bsp_work_area_initialize(). malloc() is called to get memory when this function
- * is called after bsp_work_area_initialize().
-	void *start;
-	/* Not early anymore? */
-	if (early_mem == ~0)
-		return malloc(size);
-	size = (size + 7) & ~0x7;
-	if (rdb_start - STACK_SIZE - early_mem < size)
-		return NULL;
-	start = (void *)early_mem;
-	early_mem += size;
-	return start;
diff --git a/doc/bsp_howto/init.t b/doc/bsp_howto/init.t
index 55e1e05..d557df6 100644
--- a/doc/bsp_howto/init.t
+++ b/doc/bsp_howto/init.t
@@ -148,10 +148,6 @@ The @code{boot_card()} routine performs the following functions:
 @item It sets the command line argument variables
 for later use by the application.
- at item It invokes the BSP specific routine @code{bsp_start()} which is
-written in C and thus able to perform more advanced initialization.
-Often MMU and bus initialization occurs here.
 @item It invokes the BSP specific routine @code{bsp_work_area_initialize()}
 which is supposed to initialize the RTEMS Workspace and the C Program Heap.
 Usually the default implementation in
@@ -160,6 +156,12 @@ implementations can use @code{bsp_work_area_initialize_default()} or
 @code{bsp_work_area_initialize_with_table()} available as inline functions from
 @code{#include <bsp/bootcard.h>}.
+ at item It invokes the BSP specific routine @code{bsp_start()} which is
+written in C and thus able to perform more advanced initialization.
+Often MMU, bus and interrupt controller initialization occurs here.  Since the
+RTEMS Workspace and the C Program Heap was already initialized by
+ at code{bsp_work_area_initialize()}, this routine may use @code{malloc()}, etc.
 @item It invokes the RTEMS directive
 @code{rtems_initialize_data_structures()} to initialize the RTEMS
 executive to a state where objects can be created but tasking is not
@@ -214,30 +216,33 @@ entered, any C++ Global Constructors will be invoked.
 That's it.  We just went through the entire sequence.
- at subsection bsp_start() - BSP Specific Initialization
+ at subsection bsp_work_area_initialize() - BSP Specific Work Area Initialization
 This is the first BSP specific C routine to execute during system
-initialization.  This routine often performs required fundamental
-hardware initialization such as setting bus controller registers
-that do not have a direct impact on whether or not C code can execute.
-The source code for this routine is usually found in the following
-file:
+initialization.  It must initialize the support for allocating memory from the
+C Program Heap and RTEMS Workspace commonly referred to as the work areas.
+Many BSPs place the work areas at the end of RAM although this is certainly not
+a requirement.  Usually the default implementation in
+ at file{c/src/lib/libbsp/shared/bspgetworkarea.c} should be sufficient.  Custom
+implementations can use @code{bsp_work_area_initialize_default()} or
+ at code{bsp_work_area_initialize_with_table()} available as inline functions from
+ at code{#include <bsp/bootcard.h>}.
- at example
-c/src/lib/libbsp/CPU/BSP/startup/bspstart.c
- at end example
+ at subsection bsp_start() - BSP Specific Initialization
-On older BSPs not using @code{boot_card()}'s support for allocating memory
-to the C Program Heap and RTEMS Workspace, one of the most important
-functions performed by this routine is determining where the RTEMS
-Workspace is to be located in memory.  All RTEMS objects and task stacks
-will be allocated from this Workspace.  The RTEMS Workspace is distinct
-from the application heap used for @code{malloc()}.  Many BSPs place
-the RTEMS Workspace area at the end of RAM although this is certainly
-not a requirement.
+This is the second BSP specific C routine to execute during system
+initialization.  It is called right after @code{bsp_work_area_initialize()}.
+The @code{bsp_start()} routine often performs required fundamental hardware
+initialization such as setting bus controller registers that do not have a
+direct impact on whether or not C code can execute.  The interrupt controllers
+are usually initialized here.  The source code for this routine is usually
+found in the file @file{c/src/lib/libbsp/$@{CPU@}/$@{BSP@}/startup/bspstart.c}.
+It is not allowed to create any operating system objects, e.g. RTEMS
+semaphores.
 After completing execution, this routine returns to the @code{boot_card()}
-routine.
+routine.  In case of errors, the initialization should be terminated via
+ at code{bsp_fatal()}.
 @subsection RTEMS Pretasking Callback
1.8.4.5
