[PATCH 3/5] bsps/bfin: Use default bsp_pretasking_hook()
Wed Dec 9 15:14:12 UTC 2015
Rename BSP-specific bsp_pretasking_hook() to bsp_predriver_hook().
Update #2408.
 c/src/lib/libbsp/bfin/TLL6527M/Makefile.am          | 2 +-
 c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c   | 4 ++--
 c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am        | 2 +-
 c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c | 4 ++--
 c/src/lib/libbsp/bfin/eZKit533/Makefile.am          | 2 +-
 c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c   | 4 ++--
 6 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/c/src/lib/libbsp/bfin/TLL6527M/Makefile.am b/c/src/lib/libbsp/bfin/TLL6527M/Makefile.am
index a913042..ef7df34 100644
--- a/c/src/lib/libbsp/bfin/TLL6527M/Makefile.am
+++ b/c/src/lib/libbsp/bfin/TLL6527M/Makefile.am
@@ -27,7 +27,7 @@ dist_project_lib_DATA += startup/linkcmds
 noinst_LIBRARIES += libbsp.a
 libbsp_a_SOURCES = ../../shared/bsplibc.c ../../shared/bsppost.c \
-	../../shared/bsppredriverhook.c startup/bspstart.c \
+	../../shared/bsppretaskinghook.c startup/bspstart.c \
 	../../shared/bspclean.c ../../shared/sbrk.c ../../shared/setvec.c \
 	../../shared/bootcard.c ../../shared/gnatinstallhandler.c \
 	../../shared/bspgetworkarea.c
diff --git a/c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c b/c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c
index 07290d4..2614273 100644
--- a/c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c
+++ b/c/src/lib/libbsp/bfin/TLL6527M/startup/bspstart.c
@@ -122,9 +122,9 @@ static void Init_Flags(void)
- *  bsp_pretasking_hook
+ *  bsp_predriver_hook
-void bsp_pretasking_hook(void)
+void bsp_predriver_hook(void)
   bfin_interrupt_init();
diff --git a/c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am b/c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am
index d128ca4..b107e8f 100644
--- a/c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am
+++ b/c/src/lib/libbsp/bfin/bf537Stamp/Makefile.am
@@ -27,7 +27,7 @@ noinst_LIBRARIES += libbsp.a
 libbsp_a_SOURCES =
 libbsp_a_SOURCES += ../../shared/bsplibc.c ../../shared/bsppost.c \
diff --git a/c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c b/c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c
index 8e77656..074feb8 100644
--- a/c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c
+++ b/c/src/lib/libbsp/bfin/bf537Stamp/startup/bspstart.c
@@ -70,9 +70,9 @@ static void initEBIU(void);
 static void initGPIO(void);
- *  BSP pretasking hook.
+ *  BSP predriver hook.
diff --git a/c/src/lib/libbsp/bfin/eZKit533/Makefile.am b/c/src/lib/libbsp/bfin/eZKit533/Makefile.am
index 7d08f25..0760057 100644
--- a/c/src/lib/libbsp/bfin/eZKit533/Makefile.am
+++ b/c/src/lib/libbsp/bfin/eZKit533/Makefile.am
@@ -28,7 +28,7 @@ noinst_LIBRARIES += libbsp.a
 libbsp_a_SOURCES =
diff --git a/c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c b/c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c
index 6c7f1d5..4b34e8c 100644
--- a/c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c
+++ b/c/src/lib/libbsp/bfin/eZKit533/startup/bspstart.c
@@ -118,10 +118,10 @@ static void Init_Flags(void)
- * BSP pretasking hook.  Called just before drivers are initialized.
+ * BSP predriver hook.  Called just before drivers are initialized.
  * Used to setup libc and install any BSP extensions.
1.8.4.5
