[PATCH 4/5] bsps/powerpc: Use default bsp_pretasking_hook()
Wed Dec 9 15:14:13 UTC 2015
Update #2408.
 c/src/lib/libbsp/powerpc/Makefile.am               |  2 +-
 c/src/lib/libbsp/powerpc/beatnik/Makefile.am       |  4 +-
 .../libbsp/powerpc/motorola_powerpc/Makefile.am    |  4 +-
 c/src/lib/libbsp/powerpc/mvme3100/Makefile.am      |  3 +-
 c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h    |  1 +
 .../lib/libbsp/powerpc/mvme3100/startup/bspstart.c |  7 ---
 c/src/lib/libbsp/powerpc/mvme5500/Makefile.am      |  4 +-
 .../lib/libbsp/powerpc/mvme5500/startup/bspstart.c |  6 +-
 .../powerpc/shared/startup/bsppredriverhook.c      | 70 ++++++++++++++++++++++
 .../libbsp/powerpc/shared/startup/pretaskinghook.c | 65 --------------------
 10 files changed, 83 insertions(+), 83 deletions(-)
 create mode 100644 c/src/lib/libbsp/powerpc/shared/startup/bsppredriverhook.c
 delete mode 100644 c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c
diff --git a/c/src/lib/libbsp/powerpc/Makefile.am b/c/src/lib/libbsp/powerpc/Makefile.am
index 03a7b31..a2795f2 100644
--- a/c/src/lib/libbsp/powerpc/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/Makefile.am
@@ -58,7 +58,7 @@ EXTRA_DIST += shared/start/start.S shared/start/rtems_crti.S \
 ## shared/startup
 EXTRA_DIST += shared/startup/bspstart.c shared/startup/pgtbl_setup.c \
     shared/startup/pgtbl_activate.c shared/startup/linkcmds \
-	shared/startup/zerobss.c shared/startup/pretaskinghook.c
+	shared/startup/zerobss.c shared/startup/bsppredriverhook.c
 ## shared/tod
 EXTRA_DIST += shared/tod/todcfg.c
diff --git a/c/src/lib/libbsp/powerpc/beatnik/Makefile.am b/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
index 24351ed..ec557f5 100644
--- a/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/beatnik/Makefile.am
@@ -61,13 +61,13 @@ libbsp_a_SOURCES += startup/bspstart.c \
     ../../powerpc/shared/startup/panic.c \
     ../../powerpc/shared/startup/bspgetworkarea.c \
     ../../powerpc/shared/startup/probeMemEnd.c \
-    ../../powerpc/shared/startup/pretaskinghook.c \
+    ../../powerpc/shared/startup/bsppredriverhook.c \
     ../../powerpc/shared/startup/zerobss.c \
     ../../powerpc/shared/startup/pgtbl_setup.c \
     ../../powerpc/shared/startup/pgtbl_activate.c \
     ../../powerpc/shared/startup/sbrk.c ../../shared/bootcard.c \
     startup/bspclean.c ../../shared/bsplibc.c ../../shared/bsppost.c \
-    ../../shared/bsppredriverhook.c \
+    ../../shared/bsppretaskinghook.c \
     ../../shared/gnatinstallhandler.c
 include_bsp_HEADERS += ../shared/motorola/vpd.h
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am b/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
index 5e18b7e..a925d08 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
@@ -43,8 +43,8 @@ libbsp_a_SOURCES =
 libbsp_a_SOURCES += ../../powerpc/shared/startup/bspstart.c \
  	../../powerpc/shared/showbats.c \
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am b/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am
index 22e793e..9c39e01 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/mvme3100/Makefile.am
@@ -51,10 +51,11 @@ libbsp_a_SOURCES =
 # startup
     startup/misc.c ../../powerpc/shared/startup/bspgetworkarea.c \
     ../../shared/bspclean.c ../../shared/bsplibc.c ../../shared/bsppost.c \
 # tod
 libbsp_a_SOURCES += ../../shared/tod.c tod/todcfg.c
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h b/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h
index a6a6976..9ef360c 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h
+++ b/c/src/lib/libbsp/powerpc/mvme3100/include/bsp.h
@@ -178,6 +178,7 @@ extern "C" {
 int BSP_i2c_initialize(void);
+#define BSP_PREDRIVER_I2C_INIT
 /* System Control Register */
 #define BSP_MVME3100_SYS_CR				((volatile uint8_t *)0xe2000001)
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
index d384f55..6ab2864 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/mvme3100/startup/bspstart.c
@@ -201,13 +201,6 @@ BSP_calc_freqs( void )
   printk("CPU Clock Freq:                    %10u Hz\n", BSP_processor_frequency);
-void
-bsp_predriver_hook(void)
-  /* Some drivers (RTC) may need i2c */
-  BSP_i2c_initialize();
  *  bsp_start
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am b/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am
index 805a1f9..3e64af1 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/mvme5500/Makefile.am
@@ -29,11 +29,11 @@ EXTRA_DIST = startup/bootpstuff.c
 # startup
     ../../powerpc/shared/startup/pgtbl_setup.c startup/pgtbl_activate.c \
-    ../../shared/bsppredriverhook.c startup/bspclean.c \
+    ../../shared/bsppretaskinghook.c startup/bspclean.c \
     ../../shared/gnatinstallhandler.c startup/bspreset.c \
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c b/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
index e921b71..c37de68 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
+++ b/c/src/lib/libbsp/powerpc/mvme5500/startup/bspstart.c
@@ -144,14 +144,14 @@ void _BSP_Fatal_error(unsigned int v)
  * 0..RTEMS..__rtems_end | INIT_STACK | IRQ_STACK | ...... | workspace | TOP
- * and later calls our pretasking_hook() which ends up initializing
+ * and later calls our bsp_predriver_hook() which ends up initializing
  * libc which in turn initializes the heap
  * 0..RTEMS..__rtems_end | INIT_STACK | IRQ_STACK | heap | workspace | TOP
  * The idea here is to first move the commandline to the future 'heap' area
- * from where it will be picked up by our pretasking_hook().
- * pretasking_hook() then moves it either to INIT_STACK or the workspace
+ * from where it will be picked up by our bsp_predriver_hook().
+ * bsp_predriver_hook() then moves it either to INIT_STACK or the workspace
  * area using proper allocation, initializes libc and finally moves
  * the data to the environment / malloced areas...
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/bsppredriverhook.c b/c/src/lib/libbsp/powerpc/shared/startup/bsppredriverhook.c
new file mode 100644
index 0000000..fc3916e
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/shared/startup/bsppredriverhook.c
@@ -0,0 +1,70 @@
+ *  bsp_predriver_hook().
+ *  Optionally initializes I2C and VME.
+ *  COPYRIGHT (c) 1989-2014.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+ *  Modified to support the MCP750.
+ *  Modifications Copyright (C) 1999 Eric Valette. valette at crf.canon.fr
+#include <string.h>
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#ifndef BSP_HAS_NO_VME
+#include <bsp/VME.h>
+#endif
+#ifdef SHOW_MORE_INIT_SETTINGS
+#include <rtems/bspIo.h>
+#endif
+ *  Description:
+ *      BSP predriver hook.  Called just before drivers are initialized.
+ *  NOTES:
+ *      Must not use libc (to do io) from here, since drivers are
+ *      not yet initialized.
+void bsp_predriver_hook(void)
+#ifdef BSP_PREDRIVER_I2C_INIT
+  /* Some drivers (RTC) may need i2c */
+  BSP_i2c_initialize();
+#endif
+  /* Note that VME support may be omitted also by
+   * providing a no-op  BSP_vme_config routine
+   * Initialize VME bridge - needs working PCI
+   * and IRQ subsystems...
+   * NOTE: vmeUniverse driver now uses shared interrupts.
+   *       this requires malloc/free which are not available
+   *       from bspstart()...
+  printk("Going to initialize VME bridge\n");
+#endif
+  BSP_vme_config();
+#endif
+  printk("Leaving bsp_predriver_hook\n");
+#endif
diff --git a/c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c b/c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c
deleted file mode 100644
index dbdf80e..0000000
--- a/c/src/lib/libbsp/powerpc/shared/startup/pretaskinghook.c
+++ /dev/null
@@ -1,65 +0,0 @@
- *  bsp_pretasking_hook().
- *  Initializes the heap, libc and VME.
- *  COPYRIGHT (c) 1989-2014.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
- *  Modified to support the MCP750.
- *  Modifications Copyright (C) 1999 Eric Valette. valette at crf.canon.fr
-#include <string.h>
-#include <bsp.h>
-#include <bsp/bootcard.h>
-#ifndef BSP_HAS_NO_VME
-#include <bsp/VME.h>
-#endif
-#ifdef SHOW_MORE_INIT_SETTINGS
-#include <rtems/bspIo.h>
-#endif
- *  Description:
- *      BSP pretasking hook.  Called just before drivers are initialized.
- *  NOTES:
- *      Must not use libc (to do io) from here, since drivers are
- *      not yet initialized.
-void bsp_pretasking_hook(void)
-  /* Note that VME support may be omitted also by
-   * providing a no-op  BSP_vme_config routine
-   * Initialize VME bridge - needs working PCI
-   * and IRQ subsystems...
-   * NOTE: vmeUniverse driver now uses shared interrupts.
-   *       this requires malloc/free which are not available
-   *       from bspstart()...
-  printk("Going to initialize VME bridge\n");
-#endif
-  BSP_vme_config();
-#endif
-  printk("Leaving bsp_pretasking_hook\n");
-#endif
1.8.4.5
