[PATCH 01/15] dejagnu/boards/rtems-m32r-m32rsim.exp: Remove
Aun-Ali Zaidi admin at kodeit.net
Wed Dec 9 19:57:00 UTC 2015
updates #2447.
 dejagnu/boards/rtems-m32r-m32rsim.exp | 40 -----------------------------------
 1 file changed, 40 deletions(-)
 delete mode 100755 dejagnu/boards/rtems-m32r-m32rsim.exp
diff --git a/dejagnu/boards/rtems-m32r-m32rsim.exp b/dejagnu/boards/rtems-m32r-m32rsim.exp
deleted file mode 100755
index 4670610..0000000
--- a/dejagnu/boards/rtems-m32r-m32rsim.exp
+++ /dev/null
@@ -1,40 +0,0 @@
-# This is a list of toolchains that are supported on this board.
-set_board_info target_install {}
-# Load the generic configuration for this board, This will define a basic
-# set of routines needed by the tool to communicate with the board.
-load_generic_config "sim"
-# basic-sim.exp is a basic description for the standard Cygnus simulator.
-load_base_board_description "basic-sim"
-# The name of the simulator is "nosim"
-setup_sim nosim
-# No multilib flags needed by default.
-process_multilib_options ""
-# The compiler used to build for this board. This has *nothing* to do
-# with what compiler is tested if we're testing gcc.
-set_board_info compiler  "[find_gcc]"
-set_board_info cflags  "[newlib_include_flags] -B${RTEMS_MAKEFILE_PATH}/lib/ -specs bsp_specs -qrtems"
-set_board_info ldflags "[newlib_link_flags] ${RTEMS_CONFIG_OBJ}"
-# The simulator isn't really remote.
-set_board_info isremote 0
-# We only have a small stack available to us
-set_board_info gcc,stack_size 2048
-# wrapper script which handles the device tree
-set_board_info sim "m32rsim"
-set_board_info sim,options "-i"
-# No support for signals on this target.
-set_board_info gdb,nosignals 1
-# The simulator doesn't return exit statuses and we need to indicate this.
-set_board_info needs_status_wrapper 1
-# Can't call functions from GDB.
-# set_board_info gdb,cannot_call_functions 1
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
