[PATCH 09/15] gcc/parallelize_build: Remove m32r reference
Aun-Ali Zaidi admin at kodeit.net
Wed Dec 9 19:57:08 UTC 2015
updates #2447.
 gcc/parallelize_build | 1 -
 1 file changed, 1 deletion(-)
diff --git a/gcc/parallelize_build b/gcc/parallelize_build
index cf55c21..4652e4e 100755
--- a/gcc/parallelize_build
+++ b/gcc/parallelize_build
@@ -185,7 +185,6 @@ ${BASEDIR}/rtems-testing/gcc/do_one  -B1 -A ${args} h8300 h8sim
 ${BASEDIR}/rtems-testing/gcc/do_one  -B1 -A ${args} i386 pc386
 ${BASEDIR}/rtems-testing/gcc/do_one  -B1 -A ${args} lm32 lm32_evr
 ${BASEDIR}/rtems-testing/gcc/do_one  -B1 -A ${args} m32c m32csim
-${BASEDIR}/rtems-testing/gcc/do_one  -B1 -A ${args} m32r m32rsim
 ${BASEDIR}/rtems-testing/gcc/do_one  -B1 -A ${args} m68k uC5282
 ${BASEDIR}/rtems-testing/gcc/do_one  -B1 -A ${args} mips jmr3904
 ${BASEDIR}/rtems-testing/gcc/do_one  -B1 -A ${args} powerpc psim
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
