[PATCH 15/15] rtems/common.sh: Remove m32r references
Aun-Ali Zaidi admin at kodeit.net
Wed Dec 9 19:57:14 UTC 2015
closes #2447.
 rtems/common.sh | 5 ++---
 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/rtems/common.sh b/rtems/common.sh
index 5485b9e..636953b 100644
--- a/rtems/common.sh
+++ b/rtems/common.sh
@@ -35,8 +35,8 @@ print_rtems_cpus()
   echo
   echo "CPU is one of the following: "
   echo "  arm   avr	bfin	h8300	i386	lm32	m32c"
-  echo "  m32r 	m68k	mips	moxie	nios2	or1k	powerpc"
-  echo "  sh	sparc	sparc64	v850"
+  echo "  m68k	mips	moxie	nios2	or1k	powerpc	sh"
+  echo "  sparc	sparc64	v850"
   echo
   echo "Formats without a -XXX suffix are the preferred target."
   echo
@@ -61,7 +61,6 @@ case ${CPU} in
   i386)        ;;
   lm32)        ;;
   m32c)        ;;
-  m32r)        ;;
   m68k)        ;;
   mips)        ;;
   moxie)       ;;
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
