[PATCH] m32r/m32rsim: Remove
Joel Sherrill
joel at rtems.org
Wed Dec 9 23:57:09 UTC 2015
This patch does not apply. The checked out repo needs to be rebaselined.
I added instructions on the ticket.
The rtems-testing patches include the architecture m32r and are not
restricted
to just the m32rsim BSP. Those patches need reducing and the remaining ones
combined into a single patch. Instructions are also on the ticket.
Not a lot of work. Just needs to be right. :)
On Wed, Dec 9, 2015 at 1:27 PM, Aun-Ali Zaidi <admin at kodeit.net> wrote:
> updates #2447.
> c/src/lib/libbsp/m32r/acinclude.m4 | 2 -
> c/src/lib/libbsp/m32r/m32rsim/Makefile.am | 48 ----
> c/src/lib/libbsp/m32r/m32rsim/bsp_specs | 13 --
> c/src/lib/libbsp/m32r/m32rsim/configure.ac | 20 --
> c/src/lib/libbsp/m32r/m32rsim/console/console-io.c | 60 -----
> c/src/lib/libbsp/m32r/m32rsim/console/syscalls.S | 41 ----
> c/src/lib/libbsp/m32r/m32rsim/console/trap0.S | 16 --
> c/src/lib/libbsp/m32r/m32rsim/doxygen.h | 15 --
> c/src/lib/libbsp/m32r/m32rsim/include/bsp.h | 69 ------
> c/src/lib/libbsp/m32r/m32rsim/include/tm27.h | 42 ----
> .../m32rsim/make/custom/m32rsim-testsuite.tcfg | 5 -
> .../libbsp/m32r/m32rsim/make/custom/m32rsim.cfg | 16 --
> c/src/lib/libbsp/m32r/m32rsim/preinstall.am | 71 ------
> c/src/lib/libbsp/m32r/m32rsim/start/start.S | 57 -----
> c/src/lib/libbsp/m32r/m32rsim/startup/bspreset.c | 17 --
> c/src/lib/libbsp/m32r/m32rsim/startup/linkcmds | 253
> 16 files changed, 745 deletions(-)
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/Makefile.am
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/bsp_specs
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/configure.ac
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/console/console-io.c
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/console/syscalls.S
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/console/trap0.S
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/doxygen.h
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/include/bsp.h
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/include/tm27.h
> delete mode 100644
> c/src/lib/libbsp/m32r/m32rsim/make/custom/m32rsim-testsuite.tcfg
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/make/custom/m32rsim.cfg
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/preinstall.am
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/start/start.S
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/startup/bspreset.c
> delete mode 100644 c/src/lib/libbsp/m32r/m32rsim/startup/linkcmds
> diff --git a/c/src/lib/libbsp/m32r/acinclude.m4
> b/c/src/lib/libbsp/m32r/acinclude.m4
> index 1d9c699..296a6f7 100644
> --- a/c/src/lib/libbsp/m32r/acinclude.m4
> +++ b/c/src/lib/libbsp/m32r/acinclude.m4
> @@ -2,8 +2,6 @@
> AC_DEFUN([RTEMS_CHECK_BSPDIR],
> case "$1" in
> - m32rsim )
> - AC_CONFIG_SUBDIRS([m32rsim]);;
> AC_MSG_ERROR([Invalid BSP]);;
> esac
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/Makefile.am
> b/c/src/lib/libbsp/m32r/m32rsim/Makefile.am
> deleted file mode 100644
> index ec3dcda..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/Makefile.am
> +++ /dev/null
> @@ -1,48 +0,0 @@
> -ACLOCAL_AMFLAGS = -I ../../../../aclocal
> -include $(top_srcdir)/../../../../automake/compile.am
> -include $(top_srcdir)/../../bsp.am
> -include_bspdir = $(includedir)/bsp
> -dist_project_lib_DATA = bsp_specs
> -include_HEADERS = include/bsp.h
> -include_HEADERS += include/tm27.h
> -nodist_include_HEADERS = include/bspopts.h
> -nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
> -nodist_include_bsp_HEADERS += ../../shared/include/console-polled.h
> -DISTCLEANFILES = include/bspopts.h
> -noinst_PROGRAMS =
> -nodist_include_HEADERS += ../../shared/include/coverhd.h
> -EXTRA_DIST = start/start.S
> -start.$(OBJEXT): start/start.S
> - $(CPPASCOMPILE) -o $@ -c $<
> -project_lib_DATA = start.$(OBJEXT)
> -dist_project_lib_DATA += startup/linkcmds
> -startup_SOURCES = ../../shared/bspclean.c ../../shared/bsplibc.c \
> - ../../shared/bsppredriverhook.c ../../shared/bsppretaskinghook.c \
> - ../../shared/bspgetworkarea.c ../../shared/bsppost.c \
> - ../../shared/bspstart.c ../../shared/bootcard.c ../../shared/sbrk.c \
> - ../../shared/gnatinstallhandler.c startup/bspreset.c
> -clock_SOURCES = ../../shared/clock_driver_simidle.c
> -console_SOURCES = ../../shared/console-polled.c console/console-io.c \
> - console/trap0.S
> -timer_SOURCES = ../../shared/timerstub.c
> -noinst_LIBRARIES = libbsp.a
> -libbsp_a_SOURCES = $(startup_SOURCES) $(clock_SOURCES) $(console_SOURCES)
> - $(timer_SOURCES)
> -# Cache
> -libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
> -libbsp_a_SOURCES += ../../shared/include/cache_.h
> -libbsp_a_CPPFLAGS = -I$(srcdir)/../../shared/include
> -include $(srcdir)/preinstall.am
> -include $(top_srcdir)/../../../../automake/local.am
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/bsp_specs
> b/c/src/lib/libbsp/m32r/m32rsim/bsp_specs
> index 3093175..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/bsp_specs
> +++ /dev/null
> @@ -1,13 +0,0 @@
> -%rename endfile old_endfile
> -%rename startfile old_startfile
> -%rename link old_link
> -*startfile:
> -%{!qrtems: %(old_startfile)} \
> -%{!nostdlib: %{qrtems: start.o%s crtinit.o%s crtbegin.o%s -e _start}}
> -*link:
> -%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
> -*endfile:
> -%{!qrtems: %(old_endfiles)} %{qrtems: crtend.o%s crtfini.o%s }
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/configure.ac
> b/c/src/lib/libbsp/m32r/m32rsim/configure.ac
> index a519ac1..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/configure.ac
> +++ /dev/null
> @@ -1,20 +0,0 @@
> -## Process this file with autoconf to produce a configure script.
> -AC_PREREQ([2.69])
> -AC_INIT([rtems-c-src-lib-libbsp-h8300-h8sim],[_RTEMS_VERSION],[
> https://devel.rtems.org/newticket])
> -AC_CONFIG_SRCDIR([bsp_specs])
> -RTEMS_TOP(../../../../../..)
> -RTEMS_CANONICAL_TARGET_CPU
> -AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
> -RTEMS_BSP_CONFIGURE
> -RTEMS_PROG_CC_FOR_TARGET
> -RTEMS_CANONICALIZE_TOOLS
> -RTEMS_PROG_CCAS
> -RTEMS_BSP_CLEANUP_OPTIONS(0, 1)
> -# Explicitly list all Makefiles here
> -AC_CONFIG_FILES([Makefile])
> -AC_OUTPUT
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/console/console-io.c
> b/c/src/lib/libbsp/m32r/m32rsim/console/console-io.c
> index 4c8c945..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/console/console-io.c
> +++ /dev/null
> @@ -1,60 +0,0 @@
> - * COPYRIGHT (c) 1989-2011.
> - * On-Line Applications Research Corporation (OAR).
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> -#include <bsp.h>
> -#include <bsp/console-polled.h>
> -#include <rtems/libio.h>
> -#include <stdlib.h>
> -#include <assert.h>
> -#include <reent.h>
> - * console_initialize_hardware
> - * This routine initializes the console hardware.
> -void console_initialize_hardware(void)
> - return;
> - * console_outbyte_polled
> - * This routine transmits a character using polling.
> -void console_outbyte_polled(
> - int port,
> - char ch
> - TRAP0(SYS_write, 1, &ch, 1);
> - * console_inbyte_nonblocking
> - * This routine polls for a character.
> -int console_inbyte_nonblocking(
> - int port
> - return -1;
> -#include <rtems/bspIo.h>
> -static void console_output_char(char c) { console_outbyte_polled( 0, c );
> -BSP_output_char_function_type BSP_output_char =
> console_output_char;
> -BSP_polling_getchar_function_type BSP_poll_char = NULL;
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/console/syscalls.S
> b/c/src/lib/libbsp/m32r/m32rsim/console/syscalls.S
> index caee247..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/console/syscalls.S
> +++ /dev/null
> @@ -1,41 +0,0 @@
> - * System call support for simulator in gdb.
> - * Adapted from newlib 1.16.0.
> -#define SYS_exit 1
> -#define SYS_open 2
> -#define SYS_close 3
> -#define SYS_read 4
> -#define SYS_write 5
> -#define SYS_lseek 6
> -#define SYS_unlink 7
> -#define SYS_getpid 8
> -#define SYS_kill 9
> -#define SYS_fstat 10
> -#define POUND #
> -#define SYSCALL(N) mov.b POUND N,0x400
> -#define S(n) _sys_##n: .global _sys_##n | SYSCALL(SYS_##n) | rts
> -S(write)
> -S(exit)
> - .global _abort
> -_abort:
> - /* This is for debuggers. The simulator stops here too. */
> - brk
> - /* Else, fall back on the simulator's "kill me" option. */
> -#if defined(__r8c_cpu__) || defined(__m16c_cpu__)
> - mov.w #42,r1
> -#else
> - mov.w #42,r0
> -#endif
> - SYSCALL(SYS_kill)
> - /* Else, exit. */
> - jmp.a __exit
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/console/trap0.S
> b/c/src/lib/libbsp/m32r/m32rsim/console/trap0.S
> index 04efa13..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/console/trap0.S
> +++ /dev/null
> @@ -1,16 +0,0 @@
> -; Trap 0 handler (syscall interface).
> -; The trap handler returns the result in r0 and the error code (errno
> value)
> -; in r2. r1 is reserved in case an 8 byte quantity ever needs to be
> -; returned in registers.
> - .text
> - .global __trap0
> -__trap0:
> - trap #0 ; trap 0 returns result in r0, error code
> in r2
> - cmpui r2,#1 ; is error code zero?
> - bc .Lret ; yes, skip setting errno
> - ld r4,@(sp) ; no, set errno
> - st r2, at r4
> -.Lret:
> - jmp lr ; return to caller
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/doxygen.h
> b/c/src/lib/libbsp/m32r/m32rsim/doxygen.h
> index c4dc5e8..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/doxygen.h
> +++ /dev/null
> @@ -1,15 +0,0 @@
> - * @defgroup bsp_m32r M32R
> - * @ingroup bsp_kit
> - * @brief M32R Board Support Packages
> - * @defgroup m32r_m32rsim M32R M32RSIM Modules
> - * @ingroup bsp_m32r
> - * @brief M32R M32RSIM Modules
> \ No newline at end of file
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/include/bsp.h
> b/c/src/lib/libbsp/m32r/m32rsim/include/bsp.h
> index 1a30ce6..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/include/bsp.h
> +++ /dev/null
> @@ -1,69 +0,0 @@
> - * @file
> - * @ingroup m32r_bsp
> - * @brief m32r definitions in gdb
> -/* bsp.h
> - * This include file contains some definitions specific to the
> - * h8 simulator in gdb.
> - * COPYRIGHT (c) 1989-1999.
> -#ifndef LIBBSP_M32R_M32RSIM_BSP_H
> -#define LIBBSP_M32R_M32RSIM_BSP_H
> -#include <bspopts.h>
> -#include <bsp/default-initial-extension.h>
> -#include <rtems.h>
> -#include <rtems/iosupp.h>
> -#include <rtems/console.h>
> -#include <rtems/clockdrv.h>
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> - * @defgroup m32r_bsp Clock Tick Support
> - * @ingroup m32r_m32rsim
> - * @brief Clock Tick Support Package
> -Thread clock_driver_sim_idle_body(uintptr_t);
> -#define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
> -/* Trap support interface from Newlib 1.16.0 */
> -#define SYS_exit 1
> -#define SYS_open 2
> -#define SYS_read 4
> -#define SYS_kill 9
> -int __trap0 (int function, int p1, int p2, int p3, struct _reent *r);
> -#define TRAP0(f, p1, p2, p3) \
> - __trap0 (f, (int) (p1), (int) (p2), (int) (p3), _REENT)
> -#ifdef __cplusplus
> -#endif
> -#endif
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/include/tm27.h
> b/c/src/lib/libbsp/m32r/m32rsim/include/tm27.h
> index a775386..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/include/tm27.h
> +++ /dev/null
> @@ -1,42 +0,0 @@
> - * @file
> - * @ingroup m32r_tm27
> - * @brief Time Test 27
> - * tm27.h
> -#ifndef _RTEMS_TMTEST27
> -#error "This is an RTEMS internal file you must not include directly."
> -#endif
> -#ifndef __tm27_h
> -#define __tm27_h
> - * @defgroup m32r_tm27 Time Test 27
> - * @brief Define the interrupt mechanism for Time Test 27
> -#define MUST_WAIT_FOR_INTERRUPT 0
> -#define Install_tm27_vector( handler ) /* set_vector( (handler), 6, 1 ) */
> -#define Cause_tm27_intr() /* XXX */
> -#define Clear_tm27_intr() /* XXX */
> -#define Lower_tm27_intr() /* empty */
> -#endif
> diff --git
> a/c/src/lib/libbsp/m32r/m32rsim/make/custom/m32rsim-testsuite.tcfg
> b/c/src/lib/libbsp/m32r/m32rsim/make/custom/m32rsim-testsuite.tcfg
> index f6837cc..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/make/custom/m32rsim-testsuite.tcfg
> +++ /dev/null
> @@ -1,5 +0,0 @@
> -# The GDB M32R Simulator does not have a tick interrupt.
> -include: testdata/require-tick-isr.tcfg
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/make/custom/m32rsim.cfg
> b/c/src/lib/libbsp/m32r/m32rsim/make/custom/m32rsim.cfg
> index 7fca821..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/make/custom/m32rsim.cfg
> +++ /dev/null
> @@ -1,16 +0,0 @@
> -# Config file for the M32C GDB Simulator
> -include $(RTEMS_ROOT)/make/custom/default.cfg
> -RTEMS_CPU=m32r
> -RTEMS_CPU_MODEL=m32r
> -# This contains the compiler options necessary to select the CPU model
> -# and (hopefully) optimize for it.
> -CPU_CFLAGS =
> -# optimize flag: typically -O2
> -# see GCC PR37665
> -CFLAGS_OPTIMIZE_V = -O2 -g
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/preinstall.am
> b/c/src/lib/libbsp/m32r/m32rsim/preinstall.am
> index 586785b..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/preinstall.am
> +++ /dev/null
> @@ -1,71 +0,0 @@
> -## Automatically generated by ampolish3 - Do not edit
> -if AMPOLISH3
> -$(srcdir)/preinstall.am: Makefile.am
> - $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
> -endif
> -PREINSTALL_DIRS =
> -DISTCLEANFILES += $(PREINSTALL_DIRS)
> -all-am: $(PREINSTALL_FILES)
> -PREINSTALL_FILES =
> -CLEANFILES = $(PREINSTALL_FILES)
> -all-local: $(TMPINSTALL_FILES)
> -TMPINSTALL_FILES =
> -CLEANFILES += $(TMPINSTALL_FILES)
> -$(PROJECT_LIB)/$(dirstamp):
> - @$(MKDIR_P) $(PROJECT_LIB)
> - @: > $(PROJECT_LIB)/$(dirstamp)
> -PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
> -$(PROJECT_INCLUDE)/$(dirstamp):
> - @$(MKDIR_P) $(PROJECT_INCLUDE)
> - @: > $(PROJECT_INCLUDE)/$(dirstamp)
> -PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
> -$(PROJECT_INCLUDE)/bsp/$(dirstamp):
> - @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
> - @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> -PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> -$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
> - $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
> -PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
> -$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
> - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
> -$(PROJECT_INCLUDE)/tm27.h: include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
> - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
> -$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h
> - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
> -$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h
> - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
> -$(PROJECT_INCLUDE)/bsp/console-polled.h:
> ../../shared/include/console-polled.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/console-polled.h
> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/console-polled.h
> -$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h
> - $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
> -PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
> -$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
> - $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
> -TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
> -$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
> - $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
> -PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/start/start.S
> b/c/src/lib/libbsp/m32r/m32rsim/start/start.S
> index 9b11389..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/start/start.S
> +++ /dev/null
> @@ -1,57 +0,0 @@
> - * From Newlib 1.16.0
> - .text
> - .balign 4
> - .global _start
> -_start:
> - seth sp, #shigh(_stack)
> - add3 sp, sp, #low(_stack)
> - ldi fp, #0
> -# Clear the BSS. Do it in two parts for efficiency: longwords first
> -# for most of it, then the remaining 0 to 3 bytes.
> - seth r2, #shigh(__bss_start)
> - add3 r2, r2, #low(__bss_start); R2 = start of BSS
> - seth r3, #shigh(_end)
> - add3 r3, r3, #low(_end) ; R3 = end of BSS + 1
> - sub r3, r2 ; R3 = BSS size in bytes
> - mv r4, r3
> - srli r4, #2 ; R4 = BSS size in longwords (rounded down)
> - ldi r1, #0 ; clear R1 for longword store
> - addi r2, #-4 ; account for pre-inc store
> - beqz r4, .Lendloop1 ; any more to go?
> -.Lloop1:
> - st r1, @+r2 ; yep, zero out another longword
> - addi r4, #-1 ; decrement count
> - bnez r4, .Lloop1 ; go do some more
> -.Lendloop1:
> - and3 r4, r3, #3 ; get no. of remaining BSS bytes to clear
> - addi r2, #4 ; account for pre-inc store
> - beqz r4, .Lendloop2 ; any more to go?
> -.Lloop2:
> - stb r1, @r2 ; yep, zero out another byte
> - addi r2, #1 ; bump address
> - bnez r4, .Lloop2 ; go do some more
> -.Lendloop2:
> -# Run code in the .init section.
> -# This will queue the .fini section to be run with atexit.
> - # bl __init
> -# Call main, then exit.
> - ldi r1, #0 ; r1 = argv
> - ldi r0, #0 ; r0 = argc
> - bl boot_card
> -# If that fails just loop.
> -.Lexit:
> - bra .Lexit
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/startup/bspreset.c
> b/c/src/lib/libbsp/m32r/m32rsim/startup/bspreset.c
> index 01e77a0..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/startup/bspreset.c
> +++ /dev/null
> @@ -1,17 +0,0 @@
> -#include <rtems.h>
> -#include <bsp/bootcard.h>
> -#include <bsp.h>
> -void bsp_reset( void )
> - TRAP0(SYS_exit, 0, 0, 0);
> diff --git a/c/src/lib/libbsp/m32r/m32rsim/startup/linkcmds
> b/c/src/lib/libbsp/m32r/m32rsim/startup/linkcmds
> index 018d405..0000000
> --- a/c/src/lib/libbsp/m32r/m32rsim/startup/linkcmds
> +++ /dev/null
> @@ -1,253 +0,0 @@
> - * Declare some sizes.
> -RamBase = DEFINED(RamBase) ? RamBase : 0x000000;
> -RamSize = DEFINED(RamSize) ? RamSize : 0x800000;
> -HeapSize = DEFINED(HeapSize) ? HeapSize : 0x0;
> -StackSize = DEFINED(StackSize) ? StackSize : 0x1000;
> -/* Default linker script, for normal executables */
> -OUTPUT_FORMAT("elf32-m32r", "elf32-m32r",
> - "elf32-m32r")
> -OUTPUT_ARCH(m32r)
> -ENTRY(_start)
> -SEARCH_DIR("/home/joel/work-gnat/svn/m32r-install/m32r-elf/lib");
> -SECTIONS
> - /* Read-only sections, merged into text segment: */
> - PROVIDE (__executable_start = 0x100); . = 0x100;
> - .interp : { *(.interp) }
> - .note.gnu.build-id : { *(.note.gnu.build-id) }
> - .hash : { *(.hash) }
> - .gnu.hash : { *(.gnu.hash) }
> - .dynsym : { *(.dynsym) }
> - .dynstr : { *(.dynstr) }
> - .gnu.version : { *(.gnu.version) }
> - .gnu.version_d : { *(.gnu.version_d) }
> - .gnu.version_r : { *(.gnu.version_r) }
> - .rel.init : { *(.rel.init) }
> - .rela.init : { *(.rela.init) }
> - .rel.text : { *(.rel.text .rel.text.* .rel.gnu.linkonce.t.*) }
> - .rela.text : { *(.rela.text .rela.text.* .rela.gnu.linkonce.t.*) }
> - .rel.fini : { *(.rel.fini) }
> - .rela.fini : { *(.rela.fini) }
> - .rel.rodata : { *(.rel.rodata .rel.rodata.* .rel.gnu.linkonce.r.*) }
> - .rela.rodata : { *(.rela.rodata .rela.rodata.*
> .rela.gnu.linkonce.r.*) }
> - .rel.data.rel.ro : { *(.rel.data.rel.ro*
> .rel.gnu.linkonce.d.rel.ro.*) }
> - .rela.data.rel.ro : { *(.rela.data.rel.ro*
> .rela.gnu.linkonce.d.rel.ro.*) }
> - .rel.data : { *(.rel.data .rel.data.* .rel.gnu.linkonce.d.*) }
> - .rela.data : { *(.rela.data .rela.data.* .rela.gnu.linkonce.d.*) }
> - .rel.tdata : { *(.rel.tdata .rel.tdata.* .rel.gnu.linkonce.td.*) }
> - .rela.tdata : { *(.rela.tdata .rela.tdata.* .rela.gnu.linkonce.td.*)
> - .rel.tbss : { *(.rel.tbss .rel.tbss.* .rel.gnu.linkonce.tb.*) }
> - .rela.tbss : { *(.rela.tbss .rela.tbss.* .rela.gnu.linkonce.tb.*) }
> - .rel.ctors : { *(.rel.ctors) }
> - .rela.ctors : { *(.rela.ctors) }
> - .rel.dtors : { *(.rel.dtors) }
> - .rela.dtors : { *(.rela.dtors) }
> - .rel.got : { *(.rel.got) }
> - .rela.got : { *(.rela.got) }
> - .rel.sdata : { *(.rel.sdata .rel.sdata.* .rel.gnu.linkonce.s.*) }
> - .rela.sdata : { *(.rela.sdata .rela.sdata.* .rela.gnu.linkonce.s.*)
> - .rel.sbss : { *(.rel.sbss .rel.sbss.* .rel.gnu.linkonce.sb.*) }
> - .rela.sbss : { *(.rela.sbss .rela.sbss.* .rela.gnu.linkonce.sb.*) }
> - .rel.sdata2 : { *(.rel.sdata2 .rel.sdata2.* .rel.gnu.linkonce.s2.*)
> - .rela.sdata2 : { *(.rela.sdata2 .rela.sdata2.*
> .rela.gnu.linkonce.s2.*) }
> - .rel.sbss2 : { *(.rel.sbss2 .rel.sbss2.* .rel.gnu.linkonce.sb2.*) }
> - .rela.sbss2 : { *(.rela.sbss2 .rela.sbss2.*
> .rela.gnu.linkonce.sb2.*) }
> - .rel.bss : { *(.rel.bss .rel.bss.* .rel.gnu.linkonce.b.*) }
> - .rela.bss : { *(.rela.bss .rela.bss.* .rela.gnu.linkonce.b.*) }
> - .rel.plt : { *(.rel.plt) }
> - .rela.plt : { *(.rela.plt) }
> - .init :
> - KEEP (*(.init))
> - } =0
> - .plt : { *(.plt) }
> - .text :
> - *(.text .stub .text.* .gnu.linkonce.t.*)
> - /* .gnu.warning sections are handled specially by elf32.em. */
> - *(.gnu.warning)
> - } =0
> - .fini :
> - KEEP (*(.fini))
> - } =0
> - PROVIDE (__etext = .);
> - PROVIDE (_etext = .);
> - PROVIDE (etext = .);
> - .rodata : { *(.rodata .rodata.* KEEP (*(SORT(.rtemsroset.*)))
> - .rodata1 : { *(.rodata1) }
> - .tdata : {
> - _TLS_Data_begin = .;
> - *(.tdata .tdata.* .gnu.linkonce.td.*)
> - _TLS_Data_end = .;
> - .tbss : {
> - _TLS_BSS_begin = .;
> - *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
> - _TLS_BSS_end = .;
> - _TLS_Data_size = _TLS_Data_end - _TLS_Data_begin;
> - _TLS_Data_begin = _TLS_Data_size != 0 ? _TLS_Data_begin :
> _TLS_BSS_begin;
> - _TLS_Data_end = _TLS_Data_size != 0 ? _TLS_Data_end : _TLS_BSS_begin;
> - _TLS_BSS_size = _TLS_BSS_end - _TLS_BSS_begin;
> - _TLS_Size = _TLS_BSS_end - _TLS_Data_begin;
> - _TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
> - .sdata2 :
> - *(.sdata2 .sdata2.* .gnu.linkonce.s2.*)
> - .sbss2 : { *(.sbss2 .sbss2.* .gnu.linkonce.sb2.*) }
> - .eh_frame_hdr : { *(.eh_frame_hdr) }
> - .eh_frame : ONLY_IF_RO { KEEP (*(.eh_frame)) }
> - .gcc_except_table : ONLY_IF_RO { *(.gcc_except_table
> .gcc_except_table.*) }
> - /* Adjust the address for the data segment. We want to adjust up to
> - the same address within the page on the next page up. */
> - . = ALIGN(32) + (. & (32 - 1));
> - /* Exception handling */
> - .eh_frame : ONLY_IF_RW { KEEP (*(.eh_frame)) }
> - .gcc_except_table : ONLY_IF_RW { *(.gcc_except_table
> - /* Thread Local Storage sections */
> - .tdata : { *(.tdata .tdata.* .gnu.linkonce.td.*) }
> - .tbss : { *(.tbss .tbss.* .gnu.linkonce.tb.*)
> *(.tcommon) }
> - .preinit_array :
> - PROVIDE_HIDDEN (__preinit_array_start = .);
> - KEEP (*(.preinit_array))
> - PROVIDE_HIDDEN (__preinit_array_end = .);
> - .init_array :
> - PROVIDE_HIDDEN (__init_array_start = .);
> - KEEP (*(SORT(.init_array.*)))
> - KEEP (*(.init_array))
> - PROVIDE_HIDDEN (__init_array_end = .);
> - .fini_array :
> - PROVIDE_HIDDEN (__fini_array_start = .);
> - KEEP (*(.fini_array))
> - KEEP (*(SORT(.fini_array.*)))
> - PROVIDE_HIDDEN (__fini_array_end = .);
> - .ctors :
> - /* gcc uses crtbegin.o to find the start of
> - the constructors, so we make sure it is
> - first. Because this is a wildcard, it
> - doesn't matter if the user does not
> - actually link against crtbegin.o; the
> - linker won't look for a file to match a
> - wildcard. The wildcard also means that it
> - doesn't matter which directory crtbegin.o
> - is in. */
> - KEEP (*crtbegin.o(.ctors))
> - KEEP (*crtbegin?.o(.ctors))
> - /* We don't want to include the .ctor section from
> - the crtend.o file until after the sorted ctors.
> - The .ctor section from the crtend file contains the
> - end of ctors marker and it must be last */
> - KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .ctors))
> - KEEP (*(SORT(.ctors.*)))
> - KEEP (*(.ctors))
> - .dtors :
> - KEEP (*crtbegin.o(.dtors))
> - KEEP (*crtbegin?.o(.dtors))
> - KEEP (*(EXCLUDE_FILE (*crtend.o *crtend?.o ) .dtors))
> - KEEP (*(SORT(.dtors.*)))
> - KEEP (*(.dtors))
> - .jcr : { KEEP (*(.jcr)) }
> - .data.rel.ro : { *(.data.rel.ro.local* .gnu.linkonce.d.rel.ro.local.*)
> *(.data.rel.ro* .gnu.linkonce.d.rel.ro.*) }
> - .dynamic : { *(.dynamic) }
> - .data :
> - *(.data .data.* .gnu.linkonce.d.*)
> - KEEP (*(SORT(.rtemsrwset.*)))
> - SORT(CONSTRUCTORS)
> - .data1 : { *(.data1) }
> - .got : { *(.got.plt) *(.got) }
> - /* We want the small data sections together, so single-instruction
> offsets
> - can access them all, and initialized data all before uninitialized,
> so
> - we can shorten the on-disk segment size. */
> - .sdata :
> - *(.sdata .sdata.* .gnu.linkonce.s.*)
> - _edata = .; PROVIDE (edata = .);
> - __bss_start = .;
> - .sbss :
> - *(.dynsbss)
> - *(.sbss .sbss.* .gnu.linkonce.sb.*)
> - *(.scommon)
> - .bss :
> - *(.dynbss)
> - *(.bss .bss.* .gnu.linkonce.b.*)
> - *(COMMON)
> - /* Align here to ensure that the .bss section occupies space up to
> - _end. Align after .bss to ensure correct alignment even if the
> - .bss section disappears because there are no input sections.
> - FIXME: Why do we need it? When there is no .bss section, we don't
> - pad the .data section. */
> - . = ALIGN(. != 0 ? 32 / 8 : 1);
> - . = ALIGN(32 / 8);
> - _end = .; PROVIDE (end = .);
> - . = ALIGN(16);
> - . += StackSize;
> - PROVIDE (_stack = .);
> - PROVIDE (WorkAreaBase = .);
> - . = 0x800000;
> - /* Stabs debugging sections. */
> - .stab 0 : { *(.stab) }
> - .stabstr 0 : { *(.stabstr) }
> - .stab.excl 0 : { *(.stab.excl) }
> - .stab.exclstr 0 : { *(.stab.exclstr) }
> - .stab.index 0 : { *(.stab.index) }
> - .stab.indexstr 0 : { *(.stab.indexstr) }
> - .comment 0 : { *(.comment) }
> - /* DWARF debug sections.
> - Symbols in the DWARF debugging sections are relative to the beginning
> - of the section so we begin them at 0. */
> - /* DWARF 1 */
> - .debug 0 : { *(.debug) }
> - .line 0 : { *(.line) }
> - /* GNU DWARF 1 extensions */
> - .debug_srcinfo 0 : { *(.debug_srcinfo) }
> - .debug_sfnames 0 : { *(.debug_sfnames) }
> - /* DWARF 1.1 and DWARF 2 */
> - .debug_aranges 0 : { *(.debug_aranges) }
> - .debug_pubnames 0 : { *(.debug_pubnames) }
> - /* DWARF 2 */
> - .debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) }
> - .debug_abbrev 0 : { *(.debug_abbrev) }
> - .debug_line 0 : { *(.debug_line) }
> - .debug_frame 0 : { *(.debug_frame) }
> - .debug_str 0 : { *(.debug_str) }
> - .debug_loc 0 : { *(.debug_loc) }
> - .debug_macinfo 0 : { *(.debug_macinfo) }
> - /* SGI/MIPS DWARF 2 extensions */
> - .debug_weaknames 0 : { *(.debug_weaknames) }
> - .debug_funcnames 0 : { *(.debug_funcnames) }
> - .debug_typenames 0 : { *(.debug_typenames) }
> - .debug_varnames 0 : { *(.debug_varnames) }
> - /* DWARF 3 */
> - .debug_pubtypes 0 : { *(.debug_pubtypes) }
> - .debug_ranges 0 : { *(.debug_ranges) }
> - /* DWARF extension */
> - .debug_macro 0 : { *(.debug_macro) }
> - .gnu.attributes 0 : { KEEP (*(.gnu.attributes)) }
> - /* PROVIDE (_stack = 0x800000); */
> - /DISCARD/ : { *(.note.GNU-stack) *(.gnu_debuglink) }
> 2.1.4
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager.
> This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately by e-mail if you have received this e-mail by mistake and
> delete this e-mail from your system. If you are not the intended recipient
> you are notified that disclosing, copying, distributing or taking any
> action in reliance on the contents of this information is strictly
> prohibited.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151209/e360c24f/attachment-0001.html>
