[PATCH] Use linker set for system initialization
Thu Dec 10 08:20:28 UTC 2015
This patch actually changes the system initialization to use a linker
set. The next step is to split up the
rtems_initialize_data_structures
bsp_libc_init
rtems_initialize_before_drivers
rtems_initialize_device_drivers
bsp_postdriver_hook
routines into independent parts so that only features used by the
application end up in the final executable. I will work in this early in
the new year.
The final step is to always enable the POSIX API.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
