BBB GPIO disable interrupt bug
Federico Garcia Cruz federico.garciacruz at tallertechnologies.com
Thu Dec 10 15:29:36 UTC 2015
Hi,
I'm still working with the latest version of RTEMS in a BBB. I was testing
gpio interrupts and I found that "rtems_gpio_bsp_disable_interrupt" is not
working fine. When this function is called, disables not just the specific
pin interrupt but all the pins interrupts. The problem is that this
function uses mmio_set which does something like:
AM335X_GPIO_IRQSTATUS_CLR_0 = AM335X_GPIO_IRQSTATUS | BIT(pin)
so that it is clearing all the enalbed bank interrupts.
I've changed mmio_set for mmio_write and it's working fine. Here's the
patch:
diff --git a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
index bd26051..5990211 100644
--- a/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
+++ b/c/src/lib/libbsp/arm/beagle/gpio/bbb-gpio.c
@@ -360,7 +369,7 @@ rtems_status_code rtems_gpio_bsp_disable_interrupt(
   rtems_gpio_interrupt interrupt
   /* Clear IRQ generation for the specific pin */
-  mmio_set(bbb_reg(bank, AM335X_GPIO_IRQSTATUS_CLR_0), BIT(pin));
+  mmio_write(bbb_reg(bank, AM335X_GPIO_IRQSTATUS_CLR_0), BIT(pin));
   switch ( interrupt ) {
     case FALLING_EDGE:
<http://www.tallertechnologies.com>
Software Engineer
San Lorenzo 47, 3rd Floor, Office 5
Córdoba, Argentina
Phone: +54 351 4217888 / +54 351 4218211
<http://www.linkedin.com/company/taller-technologies>
<https://www.facebook.com/tallertechnologies>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151210/35b3da91/attachment.html>
