Docs do not build
Fri Dec 11 02:27:40 UTC 2015
Hi
I didn't have time to look into this but it looks like something isn't
quite right on building the user docs since the linker set chapter was
added.
Could easily be something I was doing. I am hustling trying to get things
wrapped up before Christmas.
rm -rf $backupdir; exit $rc
/data/docs/rtems/doc/user//linkersets.texi:6: Prev field of node `Linker
Sets'
not pointed to.
/data/docs/rtems/doc/user//dirstat.texi:64: This node (Directive Status
Codes
STATUS_TEXT - Returns the enumeration name for a status code) has the bad
Next.
/data/docs/rtems/doc/user//dirstat.texi:64: Next field of node `Directive
Status
Codes STATUS_TEXT - Returns the enumeration name for a status code' not
pointed
to (perhaps incorrect sectioning?).
/data/docs/rtems/doc/user//example.texi:6: This node (Example Application)
has
the bad Prev.
/data/docs/rtems/doc/user//stackchk.texi:7: Prev field of node `Stack Bounds
Checker' not pointed to.
/data/docs/rtems/doc/user//smp.texi:1086: This node (Symmetric
Multiprocessing
Services TASK_SET_AFFINITY - Set task processor affinity) has the bad Next.
/data/docs/rtems/doc/user//libpci.texi:493: Next field of node `PCI Library
PCI
Shell command' not pointed to (perhaps incorrect sectioning?).
/data/docs/rtems/doc/user//stackchk.texi:7: This node (Stack Bounds
Checker) has
the bad Prev.
makeinfo: Removing output file `c_ <http://c_user.info/>user.info
<http://c_user.info/>' due to errors; use --force to
preserve.
Makefile:311: recipe for target 'c_ <http://c_user.info/>user.info
<http://c_user.info/>' failed
gmake[1]: *** [c_ <http://c_user.info/>user.info <http://c_user.info/>]
Error 1
gmake[1]: Leaving directory '/data/docs/rtems/doc/user'
Makefile:370: recipe for target 'all-recursive' failed
gmake: *** [all-recursive] Error 1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151210/8cf688e8/attachment.html>
