[PATCH] h8300/h8sim: Remove
Aun-Ali Zaidi
admin at kodeit.net
Mon Dec 14 00:47:53 UTC 2015
updates #2453.
c/src/lib/libbsp/h8300/h8sim/Makefile.am | 55 ---------
c/src/lib/libbsp/h8300/h8sim/bsp_specs | 14 ---
c/src/lib/libbsp/h8300/h8sim/configure.ac | 20 ----
c/src/lib/libbsp/h8300/h8sim/console/console-io.c | 65 -----------
c/src/lib/libbsp/h8300/h8sim/console/syscalls.S | 46 --------
c/src/lib/libbsp/h8300/h8sim/doxygen.h | 15 ---
c/src/lib/libbsp/h8300/h8sim/include/bsp.h | 50 ---------
.../h8300/h8sim/make/custom/h8sim-testsuite.tcfg | 12 --
c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim.cfg | 16 ---
.../h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg | 16 ---
.../lib/libbsp/h8300/h8sim/make/custom/h8sxsim.cfg | 16 ---
c/src/lib/libbsp/h8300/h8sim/preinstall.am | 71 ------------
c/src/lib/libbsp/h8300/h8sim/start/start.S | 48 --------
.../libbsp/h8300/h8sim/startup/h8bdinstallirq.c | 17 ---
c/src/lib/libbsp/h8300/h8sim/startup/linkcmds | 123 ---------------------
15 files changed, 584 deletions(-)
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/Makefile.am
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/bsp_specs
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/configure.ac
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/console/console-io.c
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/console/syscalls.S
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/doxygen.h
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/include/bsp.h
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim-testsuite.tcfg
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim.cfg
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim.cfg
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/preinstall.am
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/start/start.S
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/startup/h8bdinstallirq.c
delete mode 100644 c/src/lib/libbsp/h8300/h8sim/startup/linkcmds
diff --git a/c/src/lib/libbsp/h8300/h8sim/Makefile.am b/c/src/lib/libbsp/h8300/h8sim/Makefile.am
deleted file mode 100644
index de36975..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/Makefile.am
+++ /dev/null
@@ -1,55 +0,0 @@
-ACLOCAL_AMFLAGS = -I ../../../../aclocal
-include $(top_srcdir)/../../../../automake/compile.am
-include_bspdir = $(includedir)/bsp
-dist_project_lib_DATA = bsp_specs
-include_HEADERS = include/bsp.h
-include_HEADERS += ../../shared/include/tm27.h
-nodist_include_HEADERS = include/bspopts.h
-nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
-nodist_include_bsp_HEADERS += ../../shared/include/console-polled.h
-DISTCLEANFILES = include/bspopts.h
-nodist_include_HEADERS += ../../shared/include/coverhd.h
-noinst_LIBRARIES = libbspstart.a
-libbspstart_a_SOURCES = start/start.S
-project_lib_DATA = start.$(OBJEXT)
-dist_project_lib_DATA += startup/linkcmds
-noinst_LIBRARIES += libbsp.a
-libbsp_a_SOURCES =
-# startup
-libbsp_a_SOURCES += ../../shared/bspclean.c
-libbsp_a_SOURCES += ../../shared/bsplibc.c
-libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
-libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
-libbsp_a_SOURCES += ../../shared/bsppost.c
-libbsp_a_SOURCES += ../../shared/bspstart.c
-libbsp_a_SOURCES += startup/h8bdinstallirq.c
-libbsp_a_SOURCES += ../../shared/bootcard.c
-libbsp_a_SOURCES += ../../shared/sbrk.c
-libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
-# clock
-libbsp_a_SOURCES += ../../shared/clock_driver_simidle.c
-# console
-libbsp_a_SOURCES += ../../shared/console-polled.c
-libbsp_a_SOURCES += console/console-io.c
-libbsp_a_SOURCES += console/syscalls.S
-# timer
-libbsp_a_SOURCES += ../../shared/timerstub.c
-# Cache
-libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
-libbsp_a_SOURCES += ../../shared/include/cache_.h
-libbsp_a_CPPFLAGS = -I$(srcdir)/../../shared/include
-include $(srcdir)/preinstall.am
-include $(top_srcdir)/../../../../automake/local.am
diff --git a/c/src/lib/libbsp/h8300/h8sim/bsp_specs b/c/src/lib/libbsp/h8300/h8sim/bsp_specs
index b243ab6..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/bsp_specs
+++ /dev/null
@@ -1,14 +0,0 @@
-%rename endfile old_endfile
-%rename startfile old_startfile
-%rename link old_link
-*startfile:
-%{!qrtems: %(old_startfile)} \
-%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
-*link:
-%(old_link) %{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
-*endfile:
-%{!qrtems: %(old_endfile)} %{qrtems: crtend.o%s crtn.o%s}
diff --git a/c/src/lib/libbsp/h8300/h8sim/configure.ac b/c/src/lib/libbsp/h8300/h8sim/configure.ac
index e0c22cb..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/configure.ac
+++ /dev/null
@@ -1,20 +0,0 @@
-## Process this file with autoconf to produce a configure script.
-AC_PREREQ([2.69])
-AC_INIT([rtems-c-src-lib-libbsp-h8300-h8sim],[_RTEMS_VERSION],[https://devel.rtems.org/newticket])
-AC_CONFIG_SRCDIR([bsp_specs])
-RTEMS_TOP(../../../../../..)
-RTEMS_CANONICAL_TARGET_CPU
-AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.12.2])
-RTEMS_BSP_CONFIGURE
-RTEMS_PROG_CC_FOR_TARGET
-RTEMS_CANONICALIZE_TOOLS
-RTEMS_PROG_CCAS
-RTEMS_BSP_CLEANUP_OPTIONS(0, 1, 0)
-# Explicitly list all Makefiles here
-AC_CONFIG_FILES([Makefile])
-AC_OUTPUT
diff --git a/c/src/lib/libbsp/h8300/h8sim/console/console-io.c b/c/src/lib/libbsp/h8300/h8sim/console/console-io.c
index 195ac5c..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/console/console-io.c
+++ /dev/null
@@ -1,65 +0,0 @@
- * This file contains the hardware specific portions of the TTY driver
- * for the serial ports on the h8300 simulator in gdb.
- * COPYRIGHT (c) 1989-2008.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <bsp.h>
-#include <bsp/console-polled.h>
-#include <rtems/libio.h>
-#include <stdlib.h>
-#include <assert.h>
- * console_initialize_hardware
- * This routine initializes the console hardware.
-void console_initialize_hardware(void)
- return;
- * console_outbyte_polled
- * This routine transmits a character using polling.
-ssize_t _sys_write(int fd, const void *buf, size_t count);
-void console_outbyte_polled(
- int port,
- char ch
- _sys_write( 1, &ch, 1 );
- * console_inbyte_nonblocking
- * This routine polls for a character.
-int console_inbyte_nonblocking(
- int port
- return -1;
-#include <rtems/bspIo.h>
-static void H8simBSP_output_char(char c) { console_outbyte_polled( 0, c ); }
-BSP_output_char_function_type BSP_output_char = H8simBSP_output_char;
-BSP_polling_getchar_function_type BSP_poll_char = NULL;
diff --git a/c/src/lib/libbsp/h8300/h8sim/console/syscalls.S b/c/src/lib/libbsp/h8300/h8sim/console/syscalls.S
index a9816b8..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/console/syscalls.S
+++ /dev/null
@@ -1,46 +0,0 @@
- * System call support for simulator in gdb.
- * Copied from newlib 1.16.0.
-;;;; libc/machine/h8300/setarch.h
-#ifdef __H8300H__
-#ifdef __NORMAL_MODE__
- .h8300hn
-#else
- .h8300h
-#endif
-#endif
-#ifdef __H8300S__
- .h8300sn
-#else
- .h8300s
-#endif
-#endif
-#ifdef __H8300SX__
- .h8300sxn
-#else
- .h8300sx
-#endif
-#endif
-;;;; libc/sys/h8300/write.S
-;ssize_t _sys_write(int fd, const void *buf, size_t count);
-;Integer arguments have to be zero extended.
-; #include "setarch.h"
- .section .text
- .align 2
- .global __sys_write
-__sys_write:
-#if defined(__H8300H__) || defined(__H8300S__) || defined (__H8300SX__)
-#if __INT_MAX__ == 32767
- extu.l er0
-#endif
-#endif
- jsr @@0xc7
- rts
- .end
diff --git a/c/src/lib/libbsp/h8300/h8sim/doxygen.h b/c/src/lib/libbsp/h8300/h8sim/doxygen.h
index b2ced3e..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/doxygen.h
+++ /dev/null
@@ -1,15 +0,0 @@
- * @defgroup bsp_h8300 H8300
- * @ingroup bsp_kit
- * @brief H8300 Board Support Packages
- * @defgroup h8300_h8sim H8300 H8SIM Modules
- * @ingroup bsp_h8300
- * @brief H8300 H8SIM Modules
diff --git a/c/src/lib/libbsp/h8300/h8sim/include/bsp.h b/c/src/lib/libbsp/h8300/h8sim/include/bsp.h
index 6c45dc6..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/include/bsp.h
+++ /dev/null
@@ -1,50 +0,0 @@
- * @file
- * @ingroup h8300_bsp
- * @brief h8 simulator definitions in gdb
- * This include file contains some definitions specific to the
- * h8 simulator in gdb.
- * COPYRIGHT (c) 1989-2013.
-#ifndef LIBBSP_H8300_H8SIM_BSP_H
-#define LIBBSP_H8300_H8SIM_BSP_H
-#include <bspopts.h>
-#include <bsp/default-initial-extension.h>
-#include <rtems.h>
-#include <rtems/iosupp.h>
-#include <rtems/console.h>
-#include <rtems/clockdrv.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @defgroup h8300_bsp Clock Tick Support
- * @ingroup h8300_h8sim
- * @brief Clock Tick Support Package
-Thread clock_driver_sim_idle_body(uintptr_t);
-#define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim-testsuite.tcfg b/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim-testsuite.tcfg
index 2b47429..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim-testsuite.tcfg
+++ /dev/null
@@ -1,12 +0,0 @@
-# The GDB H8300 Simulator does not have a tick interrupt.
-include: testdata/require-tick-isr.tcfg
-include: testdata/disable-jffs2-tests.tcfg
-include: testdata/disable-mrfs-tests.tcfg
-fsbdpart01
-fsdosfsformat01
-fsdosfsname01
-fsdosfswrite01
diff --git a/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim.cfg b/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim.cfg
index 5cfb1ed..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sim.cfg
+++ /dev/null
@@ -1,16 +0,0 @@
-# Config file for the H8 simulator in gdb
-include $(RTEMS_ROOT)/make/custom/default.cfg
-RTEMS_CPU=h8300
-RTEMS_CPU_MODEL=h8300h
-# This contains the compiler options necessary to select the CPU model
-# and (hopefully) optimize for it.
-CPU_CFLAGS = -mh -mint32
-# optimize flag: typically -O2
-CFLAGS_OPTIMIZE_V = -O2 -g
diff --git a/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg b/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg
index 189a4e8..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim-testsuite.tcfg
+++ /dev/null
@@ -1,16 +0,0 @@
-capture
-capture01
-fsbdpart01
-fsdosfsformat01
-fsdosfsname01
-fsdosfswrite01
-fsrfsbitmap01
-tmcontext01
diff --git a/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim.cfg b/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim.cfg
index cec951a..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/make/custom/h8sxsim.cfg
+++ /dev/null
@@ -1,16 +0,0 @@
-# Config file for the H8 simulator in gdb compiled for SX
-RTEMS_CPU=h8300
-CPU_CFLAGS = -msx
-CFLAGS_OPTIMIZE_V = -Os -g
diff --git a/c/src/lib/libbsp/h8300/h8sim/preinstall.am b/c/src/lib/libbsp/h8300/h8sim/preinstall.am
index f3d7d23..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/preinstall.am
+++ /dev/null
@@ -1,71 +0,0 @@
-## Automatically generated by ampolish3 - Do not edit
-if AMPOLISH3
-$(srcdir)/preinstall.am: Makefile.am
- $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
-endif
-PREINSTALL_DIRS =
-DISTCLEANFILES += $(PREINSTALL_DIRS)
-all-am: $(PREINSTALL_FILES)
-PREINSTALL_FILES =
-CLEANFILES = $(PREINSTALL_FILES)
-all-local: $(TMPINSTALL_FILES)
-TMPINSTALL_FILES =
-CLEANFILES += $(TMPINSTALL_FILES)
-$(PROJECT_LIB)/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_LIB)
- @: > $(PROJECT_LIB)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
-$(PROJECT_INCLUDE)/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_INCLUDE)
- @: > $(PROJECT_INCLUDE)/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
-$(PROJECT_INCLUDE)/bsp/$(dirstamp):
- @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
- @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
-$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
-PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
-$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
-$(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
-$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
-$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
-$(PROJECT_INCLUDE)/bsp/console-polled.h: ../../shared/include/console-polled.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/console-polled.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/console-polled.h
-$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
-$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
-TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
-$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
-PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds
diff --git a/c/src/lib/libbsp/h8300/h8sim/start/start.S b/c/src/lib/libbsp/h8300/h8sim/start/start.S
index ca0fba2..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/start/start.S
+++ /dev/null
@@ -1,48 +0,0 @@
-; h8/300 and h8/300h start up file.
-#ifdef __H8300__
- .text
- .global _start
-_start:
- mov.w #_stack_init,sp
- mov.w #_edata,r0
- mov.w #_clear_end,r1
- mov.w #0,r2
-.loop: mov.w r2, at r0
- adds #2,r0
- cmp r1,r0
- blo .loop
- mov.w #0,r0 ; pass in NULL
- jsr @_boot_card
- .global _bsp_reset
-_bsp_reset:
- mov.w #0,r0 ; indicate reason to exit
- sleep
- jmp @_start ; restart
-#else
- .h8300h
-#else /* must be __H300S__ */
- .h8300s
-#endif
- .text
- .global _start
-_start:
- mov.l #_stack_init,sp
- mov.l #_edata,er0
- mov.l #_clear_end,er1
- mov.w #0,r2 ; not sure about alignment requirements
-.loop: mov.w r2, at er0 ; playing it safe for now
- adds #2,er0
- cmp.l er1,er0
- blo .loop
- jsr @_boot_card
-_bsp_reset:
- sleep
-#endif /* end of H8300 */
diff --git a/c/src/lib/libbsp/h8300/h8sim/startup/h8bdinstallirq.c b/c/src/lib/libbsp/h8300/h8sim/startup/h8bdinstallirq.c
index 9620376..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/startup/h8bdinstallirq.c
+++ /dev/null
@@ -1,17 +0,0 @@
-#include <rtems.h>
-void H8BD_Install_IRQ(
- uint32_t vector,
- proc_ptr new_handler,
- proc_ptr *old_handler )
-{ /* empty */
diff --git a/c/src/lib/libbsp/h8300/h8sim/startup/linkcmds b/c/src/lib/libbsp/h8300/h8sim/startup/linkcmds
index 0534e05..0000000
--- a/c/src/lib/libbsp/h8300/h8sim/startup/linkcmds
+++ /dev/null
@@ -1,123 +0,0 @@
- * Declare some sizes.
-_RamBase = DEFINED(_RamBase) ? _RamBase : 0x0;
-_RamSize = DEFINED(_RamSize) ? _RamSize : 16M;
-_HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x0;
-_StackSize = DEFINED(_StackSize) ? _StackSize : 0x1000;
-ENTRY("_start")
-/* The memory size is 16M to coincide with the simulator.
- Don't change either without considering the other. */
-MEMORY
- /* 0xc4 is a magic entry. We should have the linker just
- skip over it one day... */
- vectors : o = 0x0000, l = 0xc4
- magicvectors : o = 0xc4, l = 0x3c
- /* We still only use 256k as the main ram size. */
- ram : o = 0x0100, l = 0xfffefc /* 16MB RAM --> 0x3fefc */
- /* The stack starts at the top of main ram. */
- topram : o = 0xfffffc, l = 0x4 /* 256K RAM --> 0x3fffc */
- /* This holds variables in the "tiny" sections. */
- tiny : o = 0xff8000, l = 0x7f00
- /* At the very top of the address space is the 8-bit area. */
- eight : o = 0xffff00, l = 0x100
-SECTIONS
- .vectors :
- *(.vectors)
- } > vectors
- .text :
- *(.text*)
- *(.gnu.linkonce.t*)
- KEEP (*(.init))
- KEEP (*(.fini))
- * Special FreeBSD sysctl sections.
- . = ALIGN (16);
- ___start_set_sysctl_set = .;
- *(set_sys*); /* sysctl set */
- ___stop_set_sysctl_set = ABSOLUTE(.);
- *(set_dom*); /* domain set */
- *(set_pse*);
- * Read-only data
- . = ALIGN (16);
- PROVIDE(_rodata_start = . );
- *(.rodata*)
- KEEP (*(SORT(.rtemsroset.*)))
- *(.gnu.linkonce.r*)
- PROVIDE(_erodata = . );
- _etext = .;
- } >ram
- .tdata SIZEOF(.text) + ADDR(.text): {
- __TLS_Data_begin = .;
- *(.tdata .tdata.* .gnu.linkonce.td.*)
- __TLS_Data_end = .;
- } >ram
- .tbss SIZEOF(.tdata) + ADDR(.tdata): {
- __TLS_BSS_begin = .;
- *(.tbss .tbss.* .gnu.linkonce.tb.*) *(.tcommon)
- __TLS_BSS_end = .;
- } >ram
- __TLS_Data_size = __TLS_Data_end - __TLS_Data_begin;
- __TLS_Data_begin = __TLS_Data_size != 0 ? __TLS_Data_begin : __TLS_BSS_begin;
- __TLS_Data_end = __TLS_Data_size != 0 ? __TLS_Data_end : __TLS_BSS_begin;
- __TLS_BSS_size = __TLS_BSS_end - __TLS_BSS_begin;
- __TLS_Size = __TLS_BSS_end - __TLS_Data_begin;
- __TLS_Alignment = MAX (ALIGNOF (.tdata), ALIGNOF (.tbss));
- .tors SIZEOF(.tbss) + ADDR(.tbss): {
- ___ctors = . ;
- *(.ctors)
- ___ctors_end = . ;
- ___dtors = . ;
- *(.dtors)
- ___dtors_end = . ;
- } >ram
- .data SIZEOF(.tors) + ADDR(.tors):
- *(.data*)
- KEEP (*(SORT(.rtemsrwset.*)))
- *(.gcc_exc*)
- CONSTRUCTORS
- _edata = .;
- } >ram
- .bss SIZEOF(.data) + ADDR(.data):
- _bss_start = .;
- *(.bss* .gnu.linkonce.b.*)
- *(COMMON)
- . = ALIGN (64);
- . += _StackSize;
- _stack_init = .;
- _clear_end = .;
- _WorkAreaBase = .;
- _end = .;
- __end = .;
- } >ram
- .tiny : {
- *(.tiny)
- } > tiny
- .eight : {
- *(.eight)
- } > eight
- .stab 0 (NOLOAD) : {
- [ .stab ]
- .stabstr 0 (NOLOAD) : {
- [ .stabstr ]
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
