[PATCH] bsps/h8sim*: Remove
Aun-Ali Zaidi admin at kodeit.net
Mon Dec 14 00:49:25 UTC 2015
closes #2453.
 tester/rtems/testing/bsps/h8sim-run.mc | 54 --------------------------------
 tester/rtems/testing/bsps/h8sim.mc     | 56 ----------------------------------
 2 files changed, 110 deletions(-)
 delete mode 100644 tester/rtems/testing/bsps/h8sim-run.mc
 delete mode 100644 tester/rtems/testing/bsps/h8sim.mc
diff --git a/tester/rtems/testing/bsps/h8sim-run.mc b/tester/rtems/testing/bsps/h8sim-run.mc
deleted file mode 100644
index 60e6331..0000000
--- a/tester/rtems/testing/bsps/h8sim-run.mc
+++ /dev/null
@@ -1,54 +0,0 @@
-# RTEMS Tools Project (http://www.rtems.org/)
-# Copyright 2015 On-Line Applications Research Corporation (OAR).
-# All rights reserved.
-# This file is part of the RTEMS Tools package in 'rtems-tools'.
-# Redistribution and use in source and binary forms, with or without
-# modification, are permitted provided that the following conditions are met:
-# 1. Redistributions of source code must retain the above copyright notice,
-# this list of conditions and the following disclaimer.
-# 2. Redistributions in binary form must reproduce the above copyright notice,
-# this list of conditions and the following disclaimer in the documentation
-# and/or other materials provided with the distribution.
-# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
-# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
-# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
-# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
-# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
-# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-# POSSIBILITY OF SUCH DAMAGE.
-# All paths in defaults must be Unix format. Do not store any Windows format
-# paths in the defaults.
-# Every entry must describe the type of checking a host must pass.
-# Records:
-#  key: type, attribute, value
-#   type     : none, dir, exe, triplet
-#   attribute: none, required, optional
-#   value    : 'single line', '''multi line'''
-# The h8sim BSP
-[global]
-bsp:              none,    none,     'h8sim'
-[h8sim]
-h8sim:              none,    none,     '%{_rtscripts}/run.cfg'
-h8sim_arch:         none,    none,     'h8300'
-bsp_run_cmd:      none,    none,     '%{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-run'
-bsp_run_opts:     none,    none,     '-a -nouartrx'
diff --git a/tester/rtems/testing/bsps/h8sim.mc b/tester/rtems/testing/bsps/h8sim.mc
index b98e4a5..0000000
--- a/tester/rtems/testing/bsps/h8sim.mc
+++ /dev/null
@@ -1,56 +0,0 @@
-# Records:
-# The h8sim BSP
-[global]
-[h8sim]
-h8sim:                 none,    none,     '%{_rtscripts}/gdb.cfg'
-gdb_script:          none,    none,     'h8sim_gdb_script'
-h8sim_gdb_script:      none,    none,     '''target sim
-                                           load
-                                           run'''
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
