Make script rtems-bsps compatible with GNU find
Mon Dec 14 21:14:09 UTC 2015
On 12/15/15 00:11, Pavel Pisa wrote:
> If the -maxdepth is accepted by your/others BSD, OS X, Cygwin
> finds flavors then next change would make script to run on Linux.
Thank you for this and the patch. I will update the rtems-bsps script on
4.11 and master. It will be in 4.11.0-rc2.
