[PATCH] libnetworking/gethostbyht.c: Bugfix for hostf validity test
Mon Dec 14 22:57:34 UTC 2015
Hi Aun-Ali,
I see this is the same diff as the one attached to the ticket. In this
case, you should retain the code's author information by using the
--author="First Last <email>" in the git-commit command line argument.
The author of that patch appears to be Tim Cussins
<timcussins at eml.cc>.
It is important to keep track of code authorship, as open source
licenses are protected by copyright law so we need to know who holds
copyrights. Usually, the copyright holder is the author of code, or
their employer.
Thanks,
Gedare
On Mon, Dec 14, 2015 at 2:51 PM, Aun-Ali Zaidi <admin at kodeit.net> wrote:
> closes #1709.
>  cpukit/libnetworking/libc/gethostbyht.c | 2 +-
>  1 file changed, 1 insertion(+), 1 deletion(-)
> diff --git a/cpukit/libnetworking/libc/gethostbyht.c b/cpukit/libnetworking/libc/gethostbyht.c
> index 17723d7..f31bdee 100644
> --- a/cpukit/libnetworking/libc/gethostbyht.c
> +++ b/cpukit/libnetworking/libc/gethostbyht.c
> @@ -223,7 +223,7 @@ struct hostent* gethostent_r(char* buf, int len)
>    int    curlen;
> -  if (!hostf) return 0;
> +  if (hostf<=0) return 0;
>    fseek(hostf,0,SEEK_END);
>    curlen=ftell(hostf);
>    fseek(hostf,0,SEEK_SET);
> 2.1.4
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
> devel mailing list
> devel at rtems.org
