Resolution of Ticket #1709.
Wed Dec 16 12:56:47 UTC 2015
Hi Aun-Ali,
Please remove the boilerplate confidentiality statement at the end of
your email when sending to this mailing list.
https://devel.rtems.org/wiki/TBR/Website/RTEMSMailingLists#Policies
Thanks for your contribution!
On Tue, Dec 15, 2015 at 8:01 PM, Aun-Ali Zaidi <admin at kodeit.net> wrote:
> Ticket #1709 addresses a potential invalid pointer validity test.
> The pointer validity comes from an faulty conditional test that could
> allow 'NULL' values to pass through, resulting in a null pointer to a
> file descriptor causing long-term issues.
> The patch for this issue was proposed 5 years ago and the current source
> tree contains a fixed validity check, thus making the attached patch
> pointless.
> This ticket should be closed and the corresponding issue should be resolved.
> #Close 1709.
> Aun-Ali
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
> devel mailing list
> devel at rtems.org
