[PATCH 1/2] cpukit/task{set,get}note.c: Remove obsolete Notepads
Mon Dec 21 07:15:37 UTC 2015
On 21/12/15 02:13, Aun-Ali Zaidi wrote:
> updates #2493.
>   cpukit/rtems/include/rtems/rtems/tasks.h | 2 +-
>   cpukit/rtems/src/taskgetnote.c           | 2 --
>   cpukit/rtems/src/tasksetnote.c           | 2 --
>   3 files changed, 1 insertion(+), 5 deletions(-)
> diff --git a/cpukit/rtems/include/rtems/rtems/tasks.h b/cpukit/rtems/include/rtems/rtems/tasks.h
> index 1ad537d..114624d 100644
> --- a/cpukit/rtems/include/rtems/rtems/tasks.h
> +++ b/cpukit/rtems/include/rtems/rtems/tasks.h
> @@ -678,7 +678,7 @@ typedef struct {
>      *  @note MUST BE LAST ENTRY.
> -  uint32_t Notepads[ RTEMS_ZERO_LENGTH_ARRAY ] RTEMS_DEPRECATED;
> +  //uint32_t Notepads[ RTEMS_ZERO_LENGTH_ARRAY ] RTEMS_DEPRECATED;
Please don't use comments or #if 0 to remove things.
>   }  RTEMS_API_Control;
> diff --git a/cpukit/rtems/src/taskgetnote.c b/cpukit/rtems/src/taskgetnote.c
> index c097d9c..ba40d2e 100644
> --- a/cpukit/rtems/src/taskgetnote.c
> +++ b/cpukit/rtems/src/taskgetnote.c
> @@ -60,7 +60,6 @@ rtems_status_code rtems_task_get_note(
>     if ( _Objects_Are_ids_equal( id, OBJECTS_ID_OF_SELF ) ||
>          _Objects_Are_ids_equal( id, executing->Object.id ) ) {
>         api = executing->API_Extensions[ THREAD_API_RTEMS ];
> -      *note = api->Notepads[ notepad ];
>         return RTEMS_SUCCESSFUL;
> @@ -69,7 +68,6 @@ rtems_status_code rtems_task_get_note(
>       case OBJECTS_LOCAL:
>         api = the_thread->API_Extensions[ THREAD_API_RTEMS ];
>         _Objects_Put( &the_thread->Object );
What is the purpose of this function after your change?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
