[PATCH 1/2] cpukit/task{set,get}note.c: Remove obsolete Notepads
Tue Dec 22 14:22:47 UTC 2015
On 21/12/15 20:15, Joel Sherrill wrote:
> On Dec 21, 2015 1:07 PM, "Sebastian Huber"
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> > Do we want to remove the task note functions so that an application
> gets compiler and linker errors or warnings? Or do we make the
> functions empty and return an error status code?
> These were really bad APIs long before SMP was a consideration. I
> would be happy to see them completely gone.
> We need to capture their removal in a 4.12 release notes with
> transition info. We weren't good at this for 4.11. Perhaps the manual
> can replace the text section on them with a note they are gone as of
> 4.12 and you should use TLS or keys.
I updated the tickets.
For the documentation, should we add a chapter for deprecated/removed
directives or should we keep the documentation of deprecated/removed
directives and mention their status in place?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
