index 657b2f4..e69de29 100644
Joel Sherrill
joel at rtems.org
Wed Dec 23 00:31:20 UTC 2015
I screwed up and used an email address that wasn't allowed to send to the
list. Zaphod mentioned it was a GCI Doxygen task.
This doesn't look like a proper git patch. This link should help.
https://devel.rtems.org/wiki/Developer/Git#GitAccessforUsers
I am on my phone but it looks like too many lines are touched by the patch.
Did you edit on Windows? What editor?
On Dec 22, 2015 6:19 PM, "Joel Sherrill" <joel.sherrill at gmail.com> wrote:
What's the purpose of this change? I really can't tell.
On Dec 22, 2015 6:17 PM, "Zaphod Beeblebrox" <liamgreenlee at gmail.com> wrote:
> -#ifndef _BSPABORT_H
> -#define _BSPABORT_H
> -#include <rtems/system.h>
> -#include <rtems.h>
> -#include <rtems/bspIo.h>
> -#define INSN_MASK 0xc5
> -#define INSN_STM1 0x80
> -#define INSN_STM2 0x84
> -#define INSN_STR 0x40
> -#define INSN_STRB 0x44
> -#define INSN_LDM1 0x81
> -#define INSN_LDM23 0x85
> -#define INSN_LDR 0x41
> -#define INSN_LDRB 0x45
> -#define GET_RD(x) ((x & 0x0000f000) >> 12)
> -#define GET_RN(x) ((x & 0x000f0000) >> 16)
> -#define GET_U(x) ((x & 0x00800000) >> 23)
> -#define GET_I(x) ((x & 0x02000000) >> 25)
> -#define GET_REG(r, ctx) (((uint32_t *)ctx)[r])
> -#define SET_REG(r, ctx, v) (((uint32_t *)ctx)[r] = v)
> -#define GET_OFFSET(insn) (insn & 0xfff)
> - * Prototypes
> -void _print_full_context(uint32_t);
> -void do_data_abort(uint32_t, uint32_t, Context_Control *);
> -#endif /* _BSPABORT_H */
> +- * ARM CPU Dependent Source
> +- * If you want a small footprint RTEMS, pls use simple_abort.c
> +- * COPYRIGHT (c) 2007 Ray Xu.
> +- * mailto: Rayx at gmail dot com
> +- * COPYRIGHT (c) 2000 Canon Research Centre France SA.
> +- * Emmanuel Raguet, mailto:raguet at crf.canon.fr
> +- * Copyright (c) 2002 Advent Networks, Inc
> +- * Jay Monkman <jmonkman at adventnetworks.com>
> +- * The license and distribution terms for this file may be
> +- * found in the file LICENSE in this distribution or at
> +- * http://www.rtems.org/license/LICENSE.
> +-#include <rtems/system.h>
> +-#include <rtems.h>
> +-#include <rtems/bspIo.h>
> +-#include "abort.h"
> +-uint32_t g_data_abort_cnt = 0;
> +-/*this is a big overhead for MCU only got 16K RAM*/
> +-uint32_t g_data_abort_insn_list[1024];
> +-char *_print_full_context_mode2txt[0x20]={
> +- [0x0]="user", /* User */
> +- [0x1]="fiq", /* FIQ - Fast Interrupt Request */
> +- [0x2]="irq", /* IRQ - Interrupt Request */
> +- [0x3]="super", /* Supervisor */
> +- [0x7]="abort", /* Abort */
> +- [0xb]="undef", /* Undefined */
> +- [0xf]="system" /* System */
> +-void _print_full_context(uint32_t spsr)
> +- char *mode;
> +- uint32_t prev_sp,prev_lr,cpsr,arm_switch_reg;
> +- int i;
> +- printk("active thread thread 0x%08x\n", rtems_task_self());
> +- mode=_print_full_context_mode2txt[spsr&0x1f];
> +- if(!mode) mode="unknown";
> +- __asm__ volatile (ARM_SWITCH_TO_ARM
> +- " MRS %[cpsr], cpsr \n"
> +- " ORR %[arm_switch_reg], %[spsr], #0xc0 \n"
> +- " MSR cpsr_c, %[arm_switch_reg] \n"
> +- " MOV %[prev_sp], sp \n"
> +- " MOV %[prev_lr], lr \n"
> +- " MSR cpsr_c, %[cpsr] \n"
> +- ARM_SWITCH_BACK
> +- : [arm_switch_reg] "=&r" (arm_switch_reg), [prev_sp] "=&r"
> (prev_sp), [prev_lr] "=&r" (prev_lr),
> +- [cpsr] "=&r" (cpsr)
> +- : [spsr] "r" (spsr)
> +- : "cc");
> +- printk("Previous sp=0x%08x lr=0x%08x and actual cpsr=%08x\n",
> +- prev_sp, prev_lr, cpsr);
> +- for(i=0;i<48;){
> +- printk(" 0x%08x",((uint32_t*)prev_sp)[i++]);
> +- if((i%6) == 0)
> +- printk("\n");
> +-/* This function is supposed to figure out what caused the
> +- * data abort, do that, then return.
> +- * All unhandled instructions cause the system to hang.
> +-void do_data_abort(
> +- uint32_t insn,
> +- uint32_t spsr,
> +- Context_Control *ctx
> +- /* Clarify, which type is correct, CPU_Exception_frame or
> Context_Control */
> +- uint8_t decode;
> +- uint8_t insn_type;
> +- rtems_interrupt_level level;
> +- g_data_abort_insn_list[g_data_abort_cnt & 0x3ff] = ctx->register_lr
> - 8;
> +- g_data_abort_cnt++;
> +- decode = ((insn >> 20) & 0xff);
> +- insn_type = decode & INSN_MASK;
> +- switch(insn_type) {
> +- case INSN_STM1:
> +- printk("\n\nINSN_STM1\n");
> +- break;
> +- case INSN_STM2:
> +- printk("\n\nINSN_STM2\n");
> +- break;
> +- case INSN_STR:
> +- printk("\n\nINSN_STR\n");
> +- break;
> +- case INSN_STRB:
> +- printk("\n\nINSN_STRB\n");
> +- break;
> +- case INSN_LDM1:
> +- printk("\n\nINSN_LDM1\n");
> +- break;
> +- case INSN_LDM23:
> +- printk("\n\nINSN_LDM23\n");
> +- break;
> +- case INSN_LDR:
> +- printk("\n\nINSN_LDR\n");
> +- break;
> +- case INSN_LDRB:
> +- printk("\n\nINSN_LDRB\n");
> +- break;
> +- default:
> +- printk("\n\nUnrecognized instruction\n");
> +- break;
> +- printk("data_abort at address 0x%x, instruction: 0x%x, spsr =
> 0x%x\n",
> +- ctx->register_lr - 8, insn, spsr);
> +- _print_full_context(spsr);
> +- /* disable interrupts, wait forever */
> +- rtems_interrupt_disable(level);
> +- (void) level; /* avoid set but unused warning */
> +- while(1) {
> +- continue;
> +diff --git c/src/lib/libbsp/arm/shared/abort/abort.h
> +index 6d8704f..e69de29 100644
> +--- c/src/lib/libbsp/arm/shared/abort/abort.h
> ++++ c/src/lib/libbsp/arm/shared/abort/abort.h
> +@@ -1,52 +0,0 @@
> +-#ifndef _BSPABORT_H
> +-#define _BSPABORT_H
> +-#define INSN_MASK 0xc5
> +-#define INSN_STM1 0x80
> +-#define INSN_STM2 0x84
> +-#define INSN_STR 0x40
> +-#define INSN_STRB 0x44
> +-#define INSN_LDM1 0x81
> +-#define INSN_LDM23 0x85
> +-#define INSN_LDR 0x41
> +-#define INSN_LDRB 0x45
> +-#define GET_RD(x) ((x & 0x0000f000) >> 12)
> +-#define GET_RN(x) ((x & 0x000f0000) >> 16)
> +-#define GET_U(x) ((x & 0x00800000) >> 23)
> +-#define GET_I(x) ((x & 0x02000000) >> 25)
> +-#define GET_REG(r, ctx) (((uint32_t *)ctx)[r])
> +-#define SET_REG(r, ctx, v) (((uint32_t *)ctx)[r] = v)
> +-#define GET_OFFSET(insn) (insn & 0xfff)
> +- * Prototypes
> +-void _print_full_context(uint32_t);
> +-void do_data_abort(uint32_t, uint32_t, Context_Control *);
> +-#endif /* _BSPABORT_H */
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c
> b/c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c
> index 76211da..035333a 100644
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/i2c/cadence-i2c.c
> @@ -1,4 +1,7 @@
> +/*@file
> + *@ingroup xilinx-zynq_i2c
> + *@brief
> * Copyright (c) 2014 embedded brains GmbH. All rights reserved.
> * embedded brains GmbH
> @@ -57,19 +60,31 @@ typedef struct {
> bool hold;
> rtems_id task_id;
> uint32_t input_clock;
> - rtems_vector_number irq;
> + rtems_vector_number irq;xilinx-zynq_i2c
> } cadence_i2c_bus;
> + at ingroup xilinx-zynq_i2c
> + at brief Disable cadence interrupts
> static void cadence_i2c_disable_interrupts(volatile cadence_i2c *regs)
> regs->irqdisable = 0xffff;
> + at brief Clear irq status
> static void cadence_i2c_clear_irq_status(volatile cadence_i2c *regs)
> regs->irqstatus = regs->irqstatus;
> + at brief Reset cadence
> static void cadence_i2c_reset(cadence_i2c_bus *bus)
> volatile cadence_i2c *regs = bus->regs;
> @@ -90,6 +105,10 @@ static void cadence_i2c_reset(cadence_i2c_bus *bus)
> cadence_i2c_clear_irq_status(regs);
> + at brief Set cadence i2c address size
> static uint32_t cadence_i2c_set_address_size(
> const i2c_msg *msg,
> uint32_t control
> @@ -104,6 +123,10 @@ static uint32_t cadence_i2c_set_address_size(
> return control;
> + at brief Setup read transfer
> static void cadence_i2c_setup_read_transfer(
> cadence_i2c_bus *bus,
> volatile cadence_i2c *regs,
> @@ -138,6 +161,10 @@ static void cadence_i2c_next_byte(cadence_i2c_bus
> *bus)
> + at brief Cadence i2c write to fifo
> static void cadence_i2c_write_to_fifo(
> @@ -164,6 +191,10 @@ static void cadence_i2c_write_to_fifo(
> + at brief Setup cadence i2c write transfer
> static void cadence_i2c_setup_write_transfer(
> @@ -176,6 +207,10 @@ static void cadence_i2c_setup_write_transfer(
> cadence_i2c_write_to_fifo(bus, regs);
> + at brief Setup cadence i2c transfer
> static void cadence_i2c_setup_transfer(
> @@ -218,6 +253,10 @@ static void cadence_i2c_setup_transfer(
> regs->address = CADENCE_I2C_ADDRESS(msgs->addr);
> + at brief Continue cadence i2c read transfer
> static void cadence_i2c_continue_read_transfer(
> @@ -253,6 +292,10 @@ static void cadence_i2c_continue_read_transfer(
> + at brief Interrup cadence i2c
> static void cadence_i2c_interrupt(void *arg)
> cadence_i2c_bus *bus = arg;
> @@ -321,6 +364,10 @@ static void cadence_i2c_interrupt(void *arg)
> + at brief Cadence i2c transfer
> static int cadence_i2c_transfer(
> i2c_bus *base,
> i2c_msg *msgs,
> @@ -362,6 +409,11 @@ static int cadence_i2c_transfer(
> return bus->irqstatus == 0 ? 0 : -EIO;
> + at brief Set cadence i2c clock
> static int cadence_i2c_set_clock(i2c_bus *base, unsigned long clock)
> cadence_i2c_bus *bus = (cadence_i2c_bus *) base;
> @@ -407,6 +459,10 @@ static int cadence_i2c_set_clock(i2c_bus *base,
> return 0;
> + at brief Destroy cadence i2c
> static void cadence_i2c_destroy(i2c_bus *base)
> diff --git a/c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h
> b/c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h
> index c06a47c..a5a4e02 100644
> --- a/c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h
> +++ b/c/src/lib/libbsp/arm/xilinx-zynq/include/cadence-i2c-regs.h
> @@ -1,4 +1,8 @@
> + *@file
> + *@defgroup xilinx-zynq_i2c Cadenc I2C Setup
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20151222/20105beb/attachment-0001.html>
