[PATCH] api: Remove deprecated Notepads
Wed Dec 23 08:20:52 UTC 2015
Hello Aun-Ali,
I think you removed a bit too much from some tests. You should only
remove the task note aspect of a particular test. Tests that deal with
task notes only should be remove completely.
With respect to the documentation, it is undecided what we do here, see
my last comment to previous patch.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
