libfs: are we actually using User/Group IDs?
    Chris Johns
    chrisj at rtems.org
    Mon Dec  7 01:42:44 UTC 2015
On 12/05/15 06:49, Martin Galvan wrote:
> Certainly! This filesystem has been so far implemented in Linux, so
> I'd assume it's GPLv2.
Would it be worth contacting the developer/maintainer and ask about a
dual license or something we can use?
> If this isn't compatible with the RTEMS
> license, perhaps we could distribute it separately through the Source
> Builder.
The configurations in the master repo for the RSB need to follow the
same rules as RTEMS in regards to licenses. It becomes too difficult to
place the responsibility on to our users.
The RSB should support out of tree configurations if set up correctly.
This means you could maintain and release a configuration file the RSB
can use to build a GPL package.
