[PATCH 2/2] score: Delete unused API extensions
Tue Dec 8 07:35:11 UTC 2015
Update #2408.
 cpukit/sapi/src/exinit.c                  |  7 -------
 cpukit/score/include/rtems/score/apiext.h | 28 +---------------------------
 cpukit/score/src/apiext.c                 | 24 +-----------------------
 3 files changed, 2 insertions(+), 57 deletions(-)
diff --git a/cpukit/sapi/src/exinit.c b/cpukit/sapi/src/exinit.c
index b29d8c0..794ccb4 100644
--- a/cpukit/sapi/src/exinit.c
+++ b/cpukit/sapi/src/exinit.c
@@ -164,13 +164,6 @@ void rtems_initialize_before_drivers(void)
   #if defined(RTEMS_MULTIPROCESSING)
     _MPCI_Create_server();
   #endif
-  #if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
-     *  Run the API and BSPs predriver hook.
-    _API_extensions_Run_predriver();
-  #endif
 void rtems_initialize_device_drivers(void)
diff --git a/cpukit/score/include/rtems/score/apiext.h b/cpukit/score/include/rtems/score/apiext.h
index 44f16e5..fca47f2 100644
--- a/cpukit/score/include/rtems/score/apiext.h
+++ b/cpukit/score/include/rtems/score/apiext.h
@@ -19,7 +19,6 @@
 #define _RTEMS_SCORE_APIEXT_H
-#include <rtems/score/thread.h>
 #ifdef __cplusplus
 extern "C" {
@@ -39,13 +38,6 @@ extern "C" {
-#if defined(FUNCTIONALITY_NOT_CURRENTLY_USED_BY_ANY_API)
-   *  This type defines the prototype of the Predriver Hook.
-  typedef void (*API_extensions_Predriver_hook)(void);
-#endif
  *  This type defines the prototype of the Postdriver Hook.
@@ -58,16 +50,7 @@ typedef void (*API_extensions_Postdriver_hook)(void);
 typedef struct {
   /** This field allows this structure to be used with the Chain Handler. */
   Chain_Node                      Node;
-     * This field is the callout invoked during RTEMS initialization after
-     * RTEMS data structures are initialized before device driver initialization
-     * has occurred.
-     * @note If this field is NULL, no extension is invoked.
-    API_extensions_Predriver_hook   predriver_hook;
-  #endif
    * RTEMS data structures and device driver initialization has occurred
@@ -94,15 +77,6 @@ void _API_extensions_Add(
   API_extensions_Control *the_extension
- *  @brief Execute all pre-driver extensions.
- *  This routine executes all of the predriver callouts.
-  void _API_extensions_Run_predriver( void );
-#endif
  *  @brief Execute all post-driver extensions.
diff --git a/cpukit/score/src/apiext.c b/cpukit/score/src/apiext.c
index 1d5ce96..fd8ca0f 100644
--- a/cpukit/score/src/apiext.c
+++ b/cpukit/score/src/apiext.c
@@ -30,25 +30,6 @@ void _API_extensions_Add(
   _Chain_Append( &_API_extensions_List, &the_extension->Node );
-    Chain_Node             *the_node;
-    API_extensions_Control *the_extension;
-    for ( the_node = _Chain_First( &_API_extensions_List );
-	  !_Chain_Is_tail( &_API_extensions_List, the_node ) ;
-	  the_node = the_node->next ) {
-      the_extension = (API_extensions_Control *) the_node;
-      if ( the_extension->predriver_hook )
-	(*the_extension->predriver_hook)();
-#endif
 void _API_extensions_Run_postdriver( void )
@@ -63,9 +44,6 @@ void _API_extensions_Run_postdriver( void )
      *  Currently all APIs configure this hook so it is always non-NULL.
-    if ( the_extension->postdriver_hook )
-#endif
-      (*the_extension->postdriver_hook)();
+    (*the_extension->postdriver_hook)();
1.8.4.5
