[PATCH 04/15] sim-scripts/m32rsim.in: Remove
    Aun-Ali Zaidi
    admin at kodeit.net
    Wed Dec  9 19:57:03 UTC 2015
updates #2447.
 sim-scripts/m32rsim.in | 25 -------------------------
 1 file changed, 25 deletions(-)
 delete mode 100644 sim-scripts/m32rsim.in
diff --git a/sim-scripts/m32rsim.in b/sim-scripts/m32rsim.in
deleted file mode 100644
index fe2b7ce..0000000
--- a/sim-scripts/m32rsim.in
+++ /dev/null
@@ -1,25 +0,0 @@
-#  M32R/m32rsim Support
-runARGS()
-  echo ${1}
-checkBSPFaults()
-  return 0
-bspLimit()
-  testname=$1
-  case ${testname} in
-    *stackchk*)limit=5 ;;
-    *fatal*)   limit=1 ;;
-    *minimum*) limit=1 ;;
-    *psxtime*) limit=180 ;;
-    *)         limit=60 ;;
-  esac
-  echo ${limit}
2.1.4
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
